  4. Probleme mit script bei Datenabfrage von Solarlog per curl
11 Beiträge 4 Kommentatoren 2.7k Aufrufe 1 Beobachtet
  • F Offline
    Farmer-cb
    Hallo
    frage meine 2 Datenlogger (solarlog 500) per curl ab,
    bei einem funktioniert die Abfrage einwandfrei, beim anderen, kommt seit ca 3 Tagen folgende fehlermeldung:
    12:12:21.173	[info]	javascript.0 Stop script script.js.common.Datenlogger.xxx
    12:12:21.292	[info]	javascript.0 Start javascript script.js.common.Datenlogger.xxx
    12:12:21.292	[warn]	javascript.0 script.js.common.Datenlogger.xxx: setForeignState(id=javascript.0.Daten.Dauersignale.always_true, state=true) - was not executed, while debug mode is active
    12:12:21.293	[warn]	javascript.0 script.js.common.Datenlogger.xxx: setForeignState(id=javascript.0.Daten.Dauersignale.always_false, state=false) - was not executed, while debug mode is active
    12:12:21.293	[info]	javascript.0 script.js.common.Datenlogger.xxx: solarlog url: http://ip-adresse/getjp
    12:12:21.294	[info]	javascript.0 script.js.common.Datenlogger.xxx: registered 0 subscriptions and 1 schedule
    12:12:21.403	[warn]	javascript.0 script.js.common.Datenlogger.xxx: Command curl -X POST -H "Content-Type: application/json" -d '{"110":null,"111":null,"141":{"32000":{"119":null,"145":null,"149":null}},"177":null,"178":null,"608":null,"609":null,"780":null,"781":null,"782":null,"800":{"104":null,"147":null},"801":{"170":null}}' http://192.168.13.2/getjp was not executed, while debug mode is active
    12:12:21.447	[error]	javascript.0 SyntaxError: Unexpected token u in JSON at position 0 at Object.parse (native) at script.js.common.Datenlogger.xxx:86:22 at Immediate. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1396:33) at runCallback (timers.js:672:20) at tryOnImmediate (timers.js:645:5) at processImmediate [as _immediateCallback] (timers.js:617:5)
    12:12:21.568	[error]	Caught by controller[0]: at script.js.common.Datenlogger.xxx:86:22
    hier meine Abfrage (Skript):
    var request = require('request');
    var url = 'http://ip-adresse/getjp';
    var loggen= false;
    log ('solarlog url: '+url);
    var name1            = "javascript.0.Daten.Datenlogger.xxx.Name_1";
    var erzeugung1       = "javascript.0.Daten.Datenlogger.xxx.Erzeugung_1";
    var status1          = "javascript.0.Daten.Datenlogger.xxx.Status_1";
    var name2            = "javascript.0.Daten.Datenlogger.xxx.Name_2";
    var erzeugung2       = "javascript.0.Daten.Datenlogger.xxx.Erzeugung_2";
    var status2          = "javascript.0.Daten.Datenlogger.xxx.Status_2";
    var gesamt           = "javascript.0.Daten.Datenlogger.xxx.Gesamterzeugung";
    var datum            = "javascript.0.Daten.Datenlogger.xxx.Datum";
    createState(name1,           {name: "Name_1", unit: ""});
    createState(erzeugung1,      {name: "Erzeugung_1",     unit: "W"});
    createState(status1,         {name: "Status_1",     unit: ""});
    createState(name2,           {name: "Name_2", unit: ""});
    createState(erzeugung2,      {name: "Erzeugung_2",     unit: "W"});
    createState(status2,         {name: "Status_2",     unit: ""});
    createState(gesamt,          {name: "Gesamterzeugung", unit: "W"});
    createState(datum,           {name: "Datum", unit: ""});
    var abfrage = "curl -X POST -H \u0022Content-Type: application/json\u0022 -d '{\"110\":null,\"111\":null,\"141\":{\"32000\":{\"119\":null,\"145\":null,\"149\":null}},\"177\":null,\"178\":null,\"608\":null,\"609\":null,\"780\":null,\"781\":null,\"782\":null,\"800\":{\"104\":null,\"147\":null},\"801\":{\"170\":null}}' "+url;
    function abfrageStarten2() {
        exec(abfrage, function(err, stdout, stderr) {
            if (err) {
                log("Error: " + err,"warn");
                return;
           var pv = JSON.parse(stdout);
            //log (  'zeitpunkt: '+pv["801"]["170"]["100"]);
            //log (       'name: '+pv["141"]["0"]["119"]);
            //log (       'name: '+pv["141"]["1"]["119"]);
            //log (       'status: '+pv["608"]["0"]);
            //log (       'status: '+pv["608"]["1"]);
            //log (       'Watt: '+pv["782"]["0"]);
            //log (       'Watt: '+pv["782"]["1"]);
            var leistung1       =(pv["782"]["0"]*1);
            var leistung2       =(pv["782"]["1"]*1);
            var gesamtleistung  =leistung1+leistung2;
            setState(name1, pv["141"]["0"]["119"]);
            setState(name2, pv["141"]["1"]["119"]);
            setState(erzeugung1, leistung1);
            setState(erzeugung2, leistung2);
            setState(gesamt, gesamtleistung);
            setState(status1, pv["608"]["0"]);
            setState(status2, pv["608"]["1"]);
            setState(datum, pv["801"]["170"]["100"]);
    setTimeout(abfrageStarten2, 100);  // Script start
    schedule("*/15 * * * * *", abfrageStarten2);  // alle 15sek
    was mache ich hier verkehrt, vorallem weill ja ein identisches skript für den anderen Datenlogger einwandfrei läuft.
    bin auch für vorschläge offen, wenn es eine andere möglichkeit der Abfrage gibt
    smartes Haus durch Digitalstrom, enocean, SPS S7-1215, Homematik, Shelly, Alexa, iobroker auf einem HP-mini mit Proxmox
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Ich lese hier das curl abfragen nicht unterstützt werden ?!
      Du müsstest json oder modbus nehmen
      https://www.loxforum.com/forum/german/s … p-auslesen
       E-Mail von Solarlog:
      "der Browserbefehl zur Auslesung der min_cur.js war ein interner Befehl, zur Internen Verwendung, der in keinem Handbuch für Kunden dokumentiert ist.
      Mit Firmware 3.x sind diese Befehle nicht mehr möglich, da die Datenstruktur geändert wurde.
      Sie haben mit der Firmware 3.x die Möglichkeit über Modbus TCP Schnittstelle oder JSON Schnittstelle Ist-Werte aus dem Solar-Log[emoji769] auszulesen.
      Diese Möglichkeiten sind im aktuellem Installationshandbuch des Solar-Log[emoji769] dokumentiert.
      Das Handbuch finden Sie unter folgendem Link:
      http://www.solar-log.com/de/service-...e/deutsch.html
      Bitte prüfen Sie ob Sie über diese Schnittstellen Ihrer Gebäudesteuerung die benötigten Daten zur Verfügung stellen können."
      Alternativ frage wie lest ihr bzw du den Solarlog in Loxone aus, eine kleine Anleitung wäre supe
      Send from mobile device
      Das schöne ios hat Auto Korrektur zum k****
      Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        Und hier sogar noch ein Post im Forum zum Auslesen von solarlog per modbus :-)
        viewtopic.php?t=5549
        • J Offline
          JackWolfskind
          Wenn die gleiche curl Abfrage plötzlich nicht mehr geht , und das ohne das es auf dem einen solarlog ein FW Update gab, würde ich ein Reboot empfehlen! du wirst den curl sicher nochmal direkt aus der Unix Shell getestet haben?
          @Dutchman
          Es gibt viele Funktionen, wie Unterverbraucher die über Modbus nicht möglich sind, aber per JSON (mit curl)
          Da es anscheinend immer mal wieder Interesse an solarlog gibt, habe ich auch mak einen Solarlog - Adapter vorgeschlagen - zum support liken ;-)
          https://github.com/ioBroker/AdapterRequests/issues/51
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            @JackWolfskind:
            https://github.com/ioBroker/AdapterRequests/issues/51 `
            Das klingt gut nur noch jemanden finden der Zeit und Ahnung hat ihn zu bauen ;-).
            JSON abfragen müsste aber auch mit dem System Info Adapter gehen
            • F Offline
              Farmer-cb
              Hallo
              reboot des Datenloggers und des iobrokers wurden gemacht.
              Leider ohne erfolg.
              Bei einem Datenloger gehts, beim anderen nicht.
              @JackWolfskind:
              @Dutchman
              • F Offline
                Farmer-cb
                Servus
                an Modbus-TCP hab ich noch garnicht gedacht, Danke :D
                Habs jetzt mal umgestellt, funktioniert ohne Probleme, leider kann man über Modbus keine einzelne Wehselrichter auslesen 😢
                @Dutchman:
                Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community `
                • F Offline
                  Farmer-cb
                  Servus
                  entschuldige die blöde frage, aber wie Like ich da, muss ich mich dazu erstmal Anmelden??
                  @JackWolfskind:
                  • J Offline
                    JackWolfskind
                    Ja, da muss man leider einen Account haben um liken zu können - evtl. ist das der Hauptgrund warum es der ruhigste Enhancement Request Ort ist den ich im gesamten Samrt Home SW Umfeld kenne :roll:
                    ` > @Dutchman
                    JSON abfragen müsste aber auch mit dem System Info Adapter gehen `
                    Wenn der Adapter Json abfragen und parsen kann, dann ist das ne Möglichkeit. Allerdings kenne ich mich damit bisher noch nicht aus, muss mir mal den System Info Adapter anschauen…. vielleicht kann man ja uaf denssen Grundlage einen solarlog Adapter bauen?
                    • F Offline
                      forelleblau
                      @Dutchman:
                      @JackWolfskind:
                      jemanden hat sich gefunden…
                      viewtopic.php?f=20&t=18977#p198111
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        [emoji847]
