  4. [Aufruf] deConz Adapter Testen 1.1.2
    1.0k
zigbeedeconz
532 Beiträge 57 Kommentatoren 180.5k Aufrufe 24 Beobachtet
    dimaiv
    #160
    @dimaiv:
    Ich habe jetzt 0.1.8 installiert.
    Während Installation kommt Fehler:
    ! 2018-04-09 17:46:29.378 - info: iobroker host.raspberrypi install adapter deconz
    ! 2018-04-09 17:46:29.398 - info: iobroker got /opt/iobroker/node_modules/iobroker.deconz/admin
    ! 2018-04-09 17:46:29.426 - info: iobroker upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
    ! 2018-04-09 17:46:29.529 - info: iobroker upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
    ! 2018-04-09 17:46:29.597 - info: iobroker upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
    ! 2018-04-09 17:46:29.677 - info: iobroker upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index.html index.html text/html
    ! 2018-04-09 17:46:29.737 - info: iobroker upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
    ! 2018-04-09 17:46:29.958 - info: iobroker host.raspberrypi object system.adapter.deconz created
    ! 2018-04-09 17:46:29.975 - info: iobroker host.raspberrypi object enum.functions.color created
    ! 2018-04-09 17:46:30.019 - info: iobroker host.raspberrypi create instance deconz
    ! 2018-04-09 17:46:30.036 - info: iobroker host.raspberrypi object system.adapter.deconz.0.outputCount created
    ! 2018-04-09 17:46:30.071 - info: iobroker host.raspberrypi object system.adapter.deconz.0.inputCount created
    ! 2018-04-09 17:46:30.109 - info: iobroker host.raspberrypi object system.adapter.deconz.0.uptime created
    ! 2018-04-09 17:46:30.143 - info: iobroker host.raspberrypi object system.adapter.deconz.0.memRss created
    ! 2018-04-09 17:46:30.177 - info: iobroker host.raspberrypi object system.adapter.deconz.0.memHeapTotal created
    ! 2018-04-09 17:46:30.211 - info: iobroker host.raspberrypi object system.adapter.deconz.0.memHeapUsed created
    ! 2018-04-09 17:46:30.245 - info: iobroker host.raspberrypi object system.adapter.deconz.0.connected created
    ! 2018-04-09 17:46:30.282 - info: iobroker host.raspberrypi object system.adapter.deconz.0.alive created
    ! 2018-04-09 17:46:30.325 - info: host.raspberrypi object change system.adapter.deconz.0
    ! 2018-04-09 17:46:30.356 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 11981
    ! 2018-04-09 17:46:30.362 - info: iobroker host.raspberrypi object system.adapter.deconz.0 created
    ! 2018-04-09 17:46:30.381 - info: iobroker exit 0
    ! 2018-04-09 17:46:33.006 - info: deconz.0 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
    ! 2018-04-09 17:46:33.037 - warn: deconz.0 No API Key found
    ! 2018-04-09 17:47:06.075 - info: deconz.0 192.168.2.145:
    ! 2018-04-09 17:47:06.169 - info: deconz.0 STATUS: 200
    ! 2018-04-09 17:47:06.171 - info: deconz.0 "2DCA0C026B"
    ! 2018-04-09 17:47:06.219 - error: deconz.0 uncaught exception: Unexpected token u in JSON at position 0
    ! 2018-04-09 17:47:06.220 - error: deconz.0 SyntaxError: Unexpected token u in JSON at position 0
    ! at Object.parse (native)
    ! at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:377:28)
    ! at self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
    ! at emitOne (events.js:96:13)
    ! at Request.emit (events.js:188:7)
    ! at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:878:8)
    ! at ClientRequest.emit (events.js:188:7)
    ! at Socket.socketErrorListener (_http_client.js:310:9)
    ! 2018-04-09 17:47:06.728 - info: deconz.0 terminating
    ! 2018-04-09 17:47:06.752 - error: Caught by controller[0]: SyntaxError: Unexpected token u in JSON at position 0
    ! 2018-04-09 17:47:06.753 - error: Caught by controller[0]: at Object.parse (native)
    ! 2018-04-09 17:47:06.754 - error: Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:377:28)
    ! 2018-04-09 17:47:06.754 - error: Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
    ! 2018-04-09 17:47:06.755 - error: Caught by controller[0]: at emitOne (events.js:96:13)
    ! 2018-04-09 17:47:06.755 - error: Caught by controller[0]: at Request.emit (events.js:188:7)
    ! 2018-04-09 17:47:06.755 - error: Caught by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:878:8)
    ! 2018-04-09 17:47:06.755 - error: Caught by controller[0]: at ClientRequest.emit (events.js:188:7)
    ! 2018-04-09 17:47:06.756 - error: Caught by controller[0]: at Socket.socketErrorListener (_http_client.js:310:9)
    ! 2018-04-09 17:47:06.756 - error: Caught by controller[0]: at emitOne (events.js:96:13)
    ! 2018-04-09 17:47:06.756 - error: host.raspberrypi instance system.adapter.deconz.0 terminated with code 0 (OK)
    ! 2018-04-09 17:47:06.757 - info: host.raspberrypi Restart adapter system.adapter.deconz.0 because enabled
    ! 2018-04-09 17:47:08.706 - info: host.raspberrypi object change system.adapter.deconz.0
    ! 2018-04-09 17:47:08.726 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 12238
    ! 2018-04-09 17:47:11.101 - info: deconz.0 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
    ! 2018-04-09 17:49:01.477 - info: host.raspberrypi object change system.adapter.deconz.0
    ! 2018-04-09 17:49:01.484 - info: host.raspberrypi stopInstance system.adapter.deconz.0
    ! 2018-04-09 17:49:01.485 - info: host.raspberrypi stopInstance system.adapter.deconz.0 killing pid 12238
    ! 2018-04-09 17:49:01.998 - info: deconz.0 terminating
    ! 2018-04-09 17:49:02.026 - info: host.raspberrypi instance system.adapter.deconz.0 terminated with code 0 (OK)
    ! 2018-04-09 17:49:04.017 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 13284
    ! 2018-04-09 17:49:06.253 - debug: deconz.0 objectDB connected
    ! 2018-04-09 17:49:06.330 - debug: deconz.0 statesDB connected
    ! 2018-04-09 17:49:06.400 - info: deconz.0 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
    ! 2018-04-09 17:49:06.483 - debug: deconz.0 API version: 1.0.9
    ! 2018-04-09 17:49:06.527 - debug: deconz.0 getAllLights: {}
    ! 2018-04-09 17:49:06.535 - debug: deconz.0 getAllSensors: {"3":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"cc9df81e0d9339c9195faf9c69d9d5b5","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"daylight":true,"lastupdated":"2018-04-09T11:33:27","status":170},"swversion":"1.0","type":"Daylight","uniqueid":"00:00:00:00:00:00:00:00-01"},"4":{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b281113b52a9d41027f82437c35e6301","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":4002,"lastupdated":"2018-04-09T15:48:47"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}}
    ! 2018-04-09 17:49:06.551 - debug: deconz.0 getAllGroups: {"58606":{"action":{"bri":127,"colormode":"ct","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":["4"],"etag":"b281113b52a9d41027f82437c35e6301","hidden":false,"id":"58606","lights":[],"lightsequence":[],"multideviceids":[],"name":"TRADFRI remote control 4","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
    ! 2018-04-09 17:49:06.590 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"ct","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":["4"],"etag":"b281113b52a9d41027f82437c35e6301","hidden":false,"id":"58606","lights":[],"lightsequence":[],"multideviceids":[],"name":"TRADFRI remote control 4","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
    Dann wenn ich Fernbedienung betätige wird zur dazugehörige Objekt noch ein gleichen hinzugefügt, und so die ganze Zeit:
    ! 2018-04-09 17:59:00.462 - debug: deconz.0 system.adapter.admin.0: logging true
    ! 2018-04-09 17:59:14.576 - debug: deconz.0 system.adapter.admin.0: logging false
    ! 2018-04-09 17:59:25.557 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:25"},"t":"event"}
    ! 2018-04-09 17:59:25.599 - debug: deconz.0 Id: 4 Type: sensors
    ! 2018-04-09 17:59:25.626 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2679fabeb9bdd9357173b81629d3ea3d","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:25"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:31.667 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:31"},"t":"event"}
    ! 2018-04-09 17:59:31.684 - debug: deconz.0 Id: 4 Type: sensors
    ! 2018-04-09 17:59:31.694 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"e83846f452e8afdb9ef78cf598fbbe9a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:31"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:31.706 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"e83846f452e8afdb9ef78cf598fbbe9a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:31"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:41.679 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":2002,"lastupdated":"2018-04-09T15:59:41"},"t":"event"}
    ! 2018-04-09 17:59:41.704 - debug: deconz.0 Id: 4 Type: sensors
    ! 2018-04-09 17:59:41.721 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"73242e6b862321ec010efa511fab2255","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":2002,"lastupdated":"2018-04-09T15:59:41"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:41.754 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"73242e6b862321ec010efa511fab2255","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":2002,"lastupdated":"2018-04-09T15:59:41"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:41.766 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"73242e6b862321ec010efa511fab2255","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":2002,"lastupdated":"2018-04-09T15:59:41"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:55.285 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"t":"event"}
    ! 2018-04-09 17:59:55.310 - debug: deconz.0 Id: 4 Type: sensors
    ! 2018-04-09 17:59:55.338 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b21990522b2f23dc0ab584b991735a6a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:55.360 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b21990522b2f23dc0ab584b991735a6a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:55.367 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b21990522b2f23dc0ab584b991735a6a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 17:59:55.375 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b21990522b2f23dc0ab584b991735a6a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:14.643 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"t":"event"}
    ! 2018-04-09 18:02:14.675 - debug: deconz.0 Id: 4 Type: sensors
    ! 2018-04-09 18:02:14.713 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:14.733 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:14.780 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:14.784 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:14.788 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:16.459 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"t":"event"}
    ! 2018-04-09 18:02:16.483 - debug: deconz.0 Id: 4 Type: sensors
    ! 2018-04-09 18:02:16.541 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:16.570 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:16.576 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:16.589 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:16.594 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:16.599 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:18.026 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"t":"event"}
    ! 2018-04-09 18:02:18.042 - debug: deconz.0 Id: 4 Type: sensors
    ! 2018-04-09 18:02:18.061 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:18.083 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:18.089 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:18.093 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:18.108 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:18.112 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:18.116 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:19.141 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"t":"event"}
    ! 2018-04-09 18:02:19.176 - debug: deconz.0 Id: 4 Type: sensors
    ! 2018-04-09 18:02:19.215 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:19.238 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:19.280 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:19.287 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:19.300 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:19.309 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:19.313 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:19.317 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
    ! 2018-04-09 18:02:20.203 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:20"},"t":"event"}
    Screenshot 2018-04-09 18.02.38.png `
    Auch wenn ich nichts mache, wird alle 45 Minuten ein Objekt als Unterobjekt hinzugefügt.
    ioBroker- NUC8i3 / Proxmox / VM
    Node.js v22.21.0
    NPM v10.9.4
    JS controller 7.1.0
    Admin 7.7.20
    ZigBee Adapter 3.3.1alpha.0
    Zigbee LAN Gateway CC2652P
    Zigbee Firmware 20250321
    • BigWumpusB Offline
      BigWumpusB Offline
      BigWumpus
      #161
      Ich probiere jetzt auch schon Tage…
      Irgendwann verstehe ich, wozu es Deconz und Phoscon gibt.
      Den iobroker-Adapter habe ich von 0.1.1 auf 0.1.8 gebracht.
      In der WebApp (vermutlich Deconz) habe ich den User/PW delight/delight drin.
      Den API-Key kann ich nicht erstellen.
      Selbst die REST-Kiste klappt nicht, weil die Kiste nicht antwortet.
      Ich habe eine OSRAM-Plug und einen XIAOMI Bewegungsmelder angelernt.
      Aber die IOBroker-Anbindung geht nicht.
      Was kann es noch sein ???
      Pi3B ioBroker: SONOFFs Tasmota mit TasmoAdmin, Shelly2.5 Rollladen
      Pi2B RaspBee DeConz ZigBee: Philips&Innr&OSRAM Lampen/Stecker, Xiaomi Sensoren, Lichttaster und -Schalter
      Heizung: EQ-3 Max!
      Netz: AVM 7490, Devolo Magic 1
        dimaiv
        #162
        Ich habe Deconz Adapter letzte Tage bestimmt 20 mal installiert, und jedes mal hat es gut funktioniert mit dem API-Key erstellen.
        IP Adresse eingeben, Port 8080 löschen, in Phoscon App "App verbinden" drücken, und in der Adapter Einstellungen auf "Erstelle API Key" drücken.
        Nicht mal 1 sek warten, API-Key ist da…
        Bei mir läuft alles auf einem PI 3B.
        Node.js v22.21.0
        NPM v10.9.4
        JS controller 7.1.0
        Admin 7.7.20
        • Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          #163
          @BigWumpus:
          Den API-Key kann ich nicht erstellen. `
          @Gerni:
          Den API Key konnte ich auch nicht in ioBroker erstellen lassen. Manuell klappte es dann. `
          @Fatmax:
          Beim Adapter funktioniert die Erstellung des API-Keys nicht. Ich gehe in der Weboberfläche auf Unlock, es kommt aber kein Key in Iobroker an. `
          Wichtig ist das man nachdem man IP und Port in der Adapter Konfiguration eingetragen hat auf "Speichern" zu Klicken und erst dann den API Key erstellen.
          @BigWumpus:
          Selbst die REST-Kiste klappt nicht, weil die Kiste nicht antwortet. `
          Sorry, ich versteh leider nicht was du damit sagen möchtest.
          Persönlicher Support
          Spenden -> paypal.me/J3YC33
            BigWumpusB Offline
            BigWumpus
            #164
            Nach 1000 gelesenen Threads die Lösung:
            Das Feld "Port" muß leer sein !
            Port 8080 ist nicht mehr !
            Heizung: EQ-3 Max!
              Kugelkopf
              #165
              @BigWumpus:
              Port 8080 ist nicht mehr ! `
              Was genau meinst du damit? Geht es jetzt um das verbinden des deconz Adapters in iobroker ?
              Habe seit 2 Tagen auch meine Xiaomi/Aqara Sensoren von Gearbest bekommen. Ist 1 Tür/Fenster Sensor und 3 Temp/Luftfeuchte Sensoren.
              Der Tür Sensor funktioniert ganz gut soweit erstmal. Glaube ich zumindest. Muss das noch mal genauer checken. Jedoch funktionieren die Temp Sensoren nicht. Sie werden nur 1x in ioBroker aktualisiert und danach nie wieder. Auf der Phoscon selte kann ich die Änderungen sehen, in ioBroker bewegt sich jedoch überhaupt nichts. Nur ein neustarten des deconz adapters in iobroker ruft wieder aktuelle Werte ab.
              Hinzugefügt habe ich die Adapter auf der Phoscon Seite.
              Benutze deconz im headless Modus und verwende Adapterversion 0.1.8.
              Deconz Version: 2.05.20
              Anbei gibt es einen Screenshot von meinen Objekten und aus der Phoscon App.
              5370_bildschirmfoto_2018-04-14_um_17.21.41.png 5370_bildschirmfoto_2018-04-14_um_17.21.26.png 5370_bildschirmfoto_2018-04-14_um_17.20.28.png
              • F Offline
                Fatmax
                #166
                @BigWumpus:
                Das war nach Wochen nun die Lösung des Rätsels.
                Ich kann nun bestätigen, dass folgendes (teilweise) funktioniert:
                ~~![](</s><URL url=)<link_text text="https://xiaomi-mi.com/uploads/Catalogue ... 808447.jpg">https://xiaomi-mi.com/uploads/CatalogueImage/pv_xiaomi-mi-wireless-switch-02_14104_1458808447.jpg</link_text>" />
                ->Battery und temperature wird nicht angezeigt, keine Ahnung, ob das überhaupt übertragen wird.
                ->Aufgefallen ist mir, dass das buttonevent nicht zurückgesetzt wird, wenn man nichts drückt.
                ~~![](</s><URL url=)<link_text text="https://xiaomi-mi.com/uploads/Catalogue ... 320631.jpg">https://xiaomi-mi.com/uploads/CatalogueImage/pv_xiaomi-mi-temperature-humidity-sensor-01_14106_1459320631.jpg</link_text>" />
                ->Ich habe diese 3x in Verwendung.
                ->In der Geräteverwaltung des Adapters werden die selben Sensoren erkannt, es sind aber unterschiedliche Objekte angelegt:
                ->bei dem Sensor im Schlafzimmer fehlt buttonevent, bei dem im Wohnzimmer funktioniert battery und buttonevent nicht.
                ~~![](</s><URL url=)<link_text text="https://xiaomi-mi.com/uploads/Catalogue ... 342091.jpg">https://xiaomi-mi.com/uploads/CatalogueImage/pv_xiaomi-aqara-window-door-sensor-01_15779_1506342091.jpg</link_text>" />
                ->funktioniert soweit ich das sehe einwandfrei.
                ~~![](</s><URL url=)<link_text text="https://xiaomi-mi.com/uploads/Catalogue ... 883212.jpg">https://xiaomi-mi.com/uploads/CatalogueImage/pv_xiaomi-mi-cube-pink-01_14302_1464883212.jpg</link_text>" />
                ->der mysteriöse Würfel :D
                ->es werden 2 Objekte angelegt:
                filename="Xiaomi-Würfel.JPG" index="2">~~
                ->das 1. Objekt ist für die Würfelseite, das 2. Objekt ist für die Rotation.
                ->die Werte ändern sich in den Objekten, je nachdem was man macht.
                ->Keine Ahnung wie man das weiter verwenden kann :lol: :lol:
                Was noch nicht geht sind meine 4 Ikea Tradfri Lampen.
                Ich hatte diese einmal in der Weboberfläche von Deconz drinnen, nun gehen sie nicht mehr.
                Es wird dazu ein Objekt "Daylight" im Iobroker-Deconz-Adapter angelegt -> lt. Geräteverwaltung ist die Modell-ID "PHDL00" und der Hersteller "Philips".
                Kann ich die irgendwie reseten, dass sich diese neu verbinden? Habe den Lichtschalter mehrmals an und ausgeschaltet, was aber nicht hilft.~~~~~~~~
                Liebe Grüße,
                Fatmax
                • Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  #167
                  @Kugelkopf:
                  Jedoch funktionieren die Temp Sensoren nicht. `
                  Ich kann das nicht Nachvollziehen, hab 3 verschiedene Versionen des Adapters auf drei Unterschiedlichen hosts am Laufen und bei allen Funktioniert das.
                  Du hast aber auch einen anderen Sensor als ich ihn hier habe. Ich habe jetzt gleich mal "Pressure" hinzugefügt, das hatte ich bis jetzt noch nicht auf dem Schirm.
                  @Fatmax:
                  ->Aufgefallen ist mir, dass das buttonevent nicht zurückgesetzt wird, wenn man nichts drückt. ` Richtig, da kein releases event von deconz übertragen wird. Das müsste ich Programtechnisch zurück setzen, aber ich bin mir nicht sicher ob das sinnvoll ist, andere Taster könnten sich hier ganz anders verhalten.
                  @Fatmax:
                  ->In der Geräteverwaltung des Adapters werden die selben Sensoren erkannt, es sind aber unterschiedliche Objekte angelegt: `
                  Sorry ich weiss nicht was du mir damit sagen möchtest. Kannst du das bitte anders erklären?
                  Ich vermute du willst darauf hinaus das die Sensoren, nicht alle, als mehrere Sensoren behandelt werden. Das wird von deConz so geliefert.
                  Komisch ist das der Objektbaum den du mir zeigst die Sensoren zusammenfasst, das dürfte gar nicht sein, erklärt aber warum nicht alle Werte angezeigt werden.
                  @Fatmax:
                  Es wird dazu ein Objekt "Daylight" im Iobroker-Deconz-Adapter angelegt -> lt. Geräteverwaltung ist die Modell-ID "PHDL00" und der Hersteller "Philips". ` Hast du eine Hue Bridge in deinem Netzwerk? Das ist ein Softwareobjekt der Hue Bridge was dazu genutzt wird die Astrozeit als Entscheidungswert zu verwenden. Möglich das es auch von deConz selbst kommt.
                  @Fatmax:
                  Kann ich die irgendwie reseten, dass sich diese neu verbinden? `
                  Lampe 6x hintereinander ein- und ausschalten (vom Strom trennen)
                  Was anderes weiss ich auch nicht. Das hat bei mir funktioniert, aber nicht immer auf anhieb.
                    Kugelkopf
                    #168
                    @Jey Cee:
                    @Kugelkopf:
                    Du hast aber auch einen anderen Sensor als ich ihn hier habe. Ich habe jetzt gleich mal "Pressure" hinzugefügt, das hatte ich bis jetzt noch nicht auf dem Schirm. `
                    Moin Moin!
                    Ich hab nun mal die Sensoren aus der Phoscon App gelöscht und nur einen davon hinzugefügt: "Multisensor". Des weiteren habe ich zuvor den Adapter in ioBroker komplett gelöscht und von Github neu heruntergeladen und hinzugefügt.
                    Durch das Anpusten des Sensors habe ich die Temperatur und Luftfeuchtigkeit geändert. in ioBroker blinken unter Objekte zwar alle Werte auf in dem Moment, jedoch ändern sie sich nicht. Habe den Loglevel von deconz auf debug geändert und hier einmal angefügt:
                    2018-04-15 16:06:56.206 - info: deconz.0 terminating
                    2018-04-15 16:06:56.250 - info: host.raspi instance system.adapter.deconz.0 terminated with code 0 (OK)
                    2018-04-15 16:06:58.235 - info: host.raspi instance system.adapter.deconz.0 started with pid 1850
                    2018-04-15 16:07:00.724 - debug: deconz.0 objectDB connected
                    2018-04-15 16:07:00.883 - debug: deconz.0 statesDB connected
                    2018-04-15 16:07:01.049 - info: deconz.0 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
                    2018-04-15 16:07:01.163 - debug: deconz.0 API version: 1.0.9
                    2018-04-15 16:07:01.227 - debug: deconz.0 getAllLights: {"1":{"etag":"afeeb842dc3560c89c01ae29a3f00987","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug1","state":{"alert":"none","on":true,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:a7:7e:71-03"},"2":{"ctmax":454,"ctmin":250,"etag":"92504b46b53554c4982abd50f8340e3a","hascolor":true,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E14 WS opal 400lm","name":"TradfriE14","state":{"alert":"none","bri":2,"colormode":"ct","ct":454,"on":false,"reachable":true},"swversion":"1.2.217","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:8a:31:88-01"},"3":{"etag":"ddc48df3ef84a543ada24189cf78bcd1","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug2","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03"}}
                    2018-04-15 16:07:01.258 - debug: deconz.0 getAllSensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"48e0cbce84f19b9a46029a93a594c586","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"daylight":true,"lastupdated":"2018-04-15T09:33:08","status":170},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:01:3e:51-01"},"14":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"0ee5dd8766e3f8913f7b5136097b6e31","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"lastupdated":"2018-04-15T14:06:23","temperature":2445},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0402"},"15":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"0ee5dd8766e3f8913f7b5136097b6e31","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"humidity":5464,"lastupdated":"2018-04-15T14:06:23"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0405"},"16":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"0ee5dd8766e3f8913f7b5136097b6e31","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"lastupdated":"2018-04-15T14:06:23","pressure":1004},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0403"},"2":{"config":{"on":true,"reachable":true},"ep":3,"etag":"de1f3e5ae1b2011948486430ca0c8b77","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 2","state":{"lastupdated":"2018-04-15T14:06:49","power":40},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:a7:7e:71-03-0b04"},"4":{"config":{"on":true,"reachable":true},"ep":3,"etag":"c3951ccae6553acba73381b8e4ad402c","manufacturername":"OSRAM","modelid":"Plug 01","name":"Zwischenstecker","state":{"lastupdated":"2018-04-15T14:05:08","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03-0b04"},"5":{"config":{"battery":98,"on":true,"reachable":true,"temperature":2500},"ep":1,"etag":"48e0cbce84f19b9a46029a93a594c586","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DoorSensor1","state":{"lastupdated":"2018-04-15T11:55:18","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:b9:7a:01-01-0006"}}
                    2018-04-15 16:07:01.315 - debug: deconz.0 getAllGroups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"48e0cbce84f19b9a46029a93a594c586","hidden":false,"id":"1","lights":["2"],"lightsequence":[],"multideviceids":[],"name":"Light","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"2":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"48e0cbce84f19b9a46029a93a594c586","hidden":false,"id":"2","lights":["3","1"],"lightsequence":[],"multideviceids":[],"name":"Plugs","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
                    2018-04-15 16:07:01.454 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"48e0cbce84f19b9a46029a93a594c586","hidden":false,"id":"1","lights":["2"],"lightsequence":[],"multideviceids":[],"name":"Light","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
                    2018-04-15 16:07:01.557 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"48e0cbce84f19b9a46029a93a594c586","hidden":false,"id":"2","lights":["3","1"],"lightsequence":[],"multideviceids":[],"name":"Plugs","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
                    2018-04-15 16:07:11.743 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:11","power":40},"t":"event"}
                    2018-04-15 16:07:11.774 - debug: deconz.0 Id: 2 Type: sensors
                    2018-04-15 16:07:11.792 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"d31757e158f4fcf93bb1016090467f20\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:11\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                    2018-04-15 16:07:24.749 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:24","power":40},"t":"event"}
                    2018-04-15 16:07:24.798 - debug: deconz.0 Id: 2 Type: sensors
                    2018-04-15 16:07:24.816 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"44357774c096503a2ffcc3f28b1b611e\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:24\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                    2018-04-15 16:07:41.738 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:41","power":40},"t":"event"}
                    2018-04-15 16:07:41.764 - debug: deconz.0 Id: 2 Type: sensors
                    2018-04-15 16:07:41.773 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"3b8dee02c07678a03443a5fedede11d2\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:41\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                    2018-04-15 16:07:55.734 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:55","power":40},"t":"event"}
                    2018-04-15 16:07:55.763 - debug: deconz.0 Id: 2 Type: sensors
                    2018-04-15 16:07:55.777 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"d525be40cfb7ad8adc90740ebfcfad50\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:55\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                    2018-04-15 16:07:57.284 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:57","temperature":2556},"t":"event"}
                    2018-04-15 16:07:57.305 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":5585,"lastupdated":"2018-04-15T14:07:57"},"t":"event"}
                    2018-04-15 16:07:57.315 - debug: deconz.0 Id: 14 Type: sensors
                    2018-04-15 16:07:57.329 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:57","pressure":1004},"t":"event"}
                    2018-04-15 16:07:57.336 - debug: deconz.0 Id: 15 Type: sensors
                    2018-04-15 16:07:57.350 - debug: deconz.0 Id: 16 Type: sensors
                    2018-04-15 16:07:57.360 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"eb1191dc66cd218b350e80b96a7418cf\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:57\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                    2018-04-15 16:08:00.529 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:00","temperature":3011},"t":"event"}
                    2018-04-15 16:08:00.546 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":7078,"lastupdated":"2018-04-15T14:08:00"},"t":"event"}
                    2018-04-15 16:08:00.572 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:00","pressure":1004},"t":"event"}
                    2018-04-15 16:08:00.586 - debug: deconz.0 Id: 14 Type: sensors
                    2018-04-15 16:08:00.607 - debug: deconz.0 Id: 15 Type: sensors
                    2018-04-15 16:08:00.611 - debug: deconz.0 Id: 16 Type: sensors
                    2018-04-15 16:08:00.621 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"7376ce2de784f574832f7921df482e46\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:00\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                    2018-04-15 16:08:03.767 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:03","temperature":2846},"t":"event"}
                    2018-04-15 16:08:03.790 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":8108,"lastupdated":"2018-04-15T14:08:03"},"t":"event"}
                    2018-04-15 16:08:03.795 - debug: deconz.0 Id: 14 Type: sensors
                    2018-04-15 16:08:03.818 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:03","pressure":1004},"t":"event"}
                    2018-04-15 16:08:03.844 - debug: deconz.0 Id: 15 Type: sensors
                    2018-04-15 16:08:03.848 - debug: deconz.0 Id: 16 Type: sensors
                    2018-04-15 16:08:03.863 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"40d612028889e36b1afcf3b88f35290b\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:03\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                    2018-04-15 16:08:07.007 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:07","temperature":2744},"t":"event"}
                    2018-04-15 16:08:07.035 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":8665,"lastupdated":"2018-04-15T14:08:07"},"t":"event"}
                    2018-04-15 16:08:07.049 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:07","pressure":1004},"t":"event"}
                    2018-04-15 16:08:07.075 - debug: deconz.0 Id: 14 Type: sensors
                    2018-04-15 16:08:07.087 - debug: deconz.0 Id: 15 Type: sensors
                    2018-04-15 16:08:07.093 - debug: deconz.0 Id: 16 Type: sensors
                    2018-04-15 16:08:07.115 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"7895ed4064ae769a3f152c66dbe389e0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:07\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                    2018-04-15 16:08:10.245 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:10","temperature":2680},"t":"event"}
                    2018-04-15 16:08:10.267 - debug: deconz.0 Id: 14 Type: sensors
                    2018-04-15 16:08:10.270 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":8978,"lastupdated":"2018-04-15T14:08:10"},"t":"event"}
                    2018-04-15 16:08:10.290 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:10","pressure":1004},"t":"event"}
                    2018-04-15 16:08:10.295 - debug: deconz.0 Id: 15 Type: sensors
                    2018-04-15 16:08:10.318 - debug: deconz.0 Id: 16 Type: sensors
                    2018-04-15 16:08:10.329 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"52a11317474029bc606103b8bf5ea35e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:10\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                    2018-04-15 16:08:16.505 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:16","temperature":2618},"t":"event"}
                    2018-04-15 16:08:16.524 - debug: deconz.0 Id: 14 Type: sensors
                    2018-04-15 16:08:16.527 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":9302,"lastupdated":"2018-04-15T14:08:16"},"t":"event"}
                    2018-04-15 16:08:16.547 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:16","pressure":1004},"t":"event"}
                    2018-04-15 16:08:16.584 - debug: deconz.0 Id: 15 Type: sensors
                    2018-04-15 16:08:16.589 - debug: deconz.0 Id: 16 Type: sensors
                    2018-04-15 16:08:16.604 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"8720d93ffb596195b7a5b082a0cb6a6e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:16\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                    2018-04-15 16:08:16.733 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:16","power":40},"t":"event"}
                    2018-04-15 16:08:16.761 - debug: deconz.0 Id: 2 Type: sensors
                    2018-04-15 16:08:16.779 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"8720d93ffb596195b7a5b082a0cb6a6e\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:16\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                    2018-04-15 16:08:22.765 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:22","temperature":2567},"t":"event"}
                    2018-04-15 16:08:22.785 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":9433,"lastupdated":"2018-04-15T14:08:22"},"t":"event"}
                    2018-04-15 16:08:22.792 - debug: deconz.0 Id: 14 Type: sensors
                    2018-04-15 16:08:22.809 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:22","pressure":1004},"t":"event"}
                    2018-04-15 16:08:22.821 - debug: deconz.0 Id: 15 Type: sensors
                    2018-04-15 16:08:22.839 - debug: deconz.0 Id: 16 Type: sensors
                    2018-04-15 16:08:22.852 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"e5b07e4449be0504efdaa5cf961c697f\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:22\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                    2018-04-15 16:08:29.727 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:29","power":40},"t":"event"}
                    2018-04-15 16:08:29.801 - debug: deconz.0 Id: 2 Type: sensors
                    2018-04-15 16:08:29.812 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"277f183c933a6f4928cd6152301004ed\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:29\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                    2018-04-15 16:08:41.101 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:41","temperature":2516},"t":"event"}
                    2018-04-15 16:08:41.119 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":9585,"lastupdated":"2018-04-15T14:08:41"},"t":"event"}
                    2018-04-15 16:08:41.124 - debug: deconz.0 Id: 14 Type: sensors
                    2018-04-15 16:08:41.142 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:41","pressure":1004},"t":"event"}
                    2018-04-15 16:08:41.150 - debug: deconz.0 Id: 15 Type: sensors
                    2018-04-15 16:08:41.167 - debug: deconz.0 Id: 16 Type: sensors
                    2018-04-15 16:08:41.176 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"49e77ed37d60b864f259357ed4d8f73f\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:41\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                    2018-04-15 16:08:45.738 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:45","power":40},"t":"event"}
                    2018-04-15 16:08:45.773 - debug: deconz.0 Id: 2 Type: sensors
                    2018-04-15 16:08:45.788 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"31b3efcd602b0065565f605ded1bf624\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:45\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                    Die Sensoren die ich hier habe, sollen angeblich baugleich mit denen von xiaomi sein. https://www.gearbest.com/access-control/pp_626702.html
                    Ich hätte dann noch ein paar Fragen offtopic:
                    Wieso habe ich auch einen Power_2, Daylight und Zwischenstecker Objekt in iobroker? Wenn ich sie lösche werden sie automatisch beim nächsten Start hinzugefügt.
                    Kann ich irgendetwas tun um den Pressure Wert auch in den Objekten zur Verfügung zu haben?
                    Viele Grüße und einen schönen Sonntag!
                    • Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      #169
                      Ach verdammt, ich könnte Kotzen. Jetzt weiss ich warum die Werte nicht Aktualisiert werden, das hatte ich längst gefixt nur ist mir nicht klar warum ich das wieder geändert hab. :?
                      @Kugelkopf:
                      in ioBroker blinken unter Objekte zwar alle Werte auf in dem Moment, jedoch ändern sie sich nicht. `
                      Hm, wenn die Werte auf Blinken muss mindestens der Zeitstempel geändert werden. Wird auch der Zeitstempel für die Letzte Änderung geändert?
                      @Kugelkopf:
                      Die Sensoren die ich hier habe, sollen angeblich baugleich mit denen von xiaomi sein. ` Sind sie auch, es gibt aber eine alte und neue Version der Sensoren. Die neuen haben eben auch Pressure.
                      @Kugelkopf:
                      Wieso habe ich auch einen Power_2 ` Hast du einen Osram Plug? Die neuen haben auch eine Leistungsmessung und werden als Sensoren und Licht in deConz eingebunden.
                      @Kugelkopf:
                      Daylight ` Da bin ich selber Überfragt woher das kommt, kann aber nur von deConz kommen wenn du keine Hue Bridge hast.
                      @Kugelkopf:
                      Wenn ich sie lösche werden sie automatisch beim nächsten Start hinzugefügt. ` So lange sie in deConz vorhanden sind werden sie immer wieder angelegt. Löscht du sie in der Adapterkonfiguration? Dann werden die Objekte nicht gelöscht, da gibt es noch ein Bug im JS-Controller. Du musst die Objekte von Hand löschen.
                      @Kugelkopf:
                      Kann ich irgendetwas tun um den Pressure Wert auch in den Objekten zur Verfügung zu haben? ` Auf die nächste Version warten, da wird das drin sein.
                        Kugelkopf
                        #170
                        @Jey Cee:
                        Kugelkopf hat geschrieben: ↑15.04.2018, 15:23
                        Hm, wenn die Werte auf Blinken muss mindestens der Zeitstempel geändert werden. Wird auch der Zeitstempel für die Letzte Änderung geändert? `
                        Wenn du mir sagst wo ich den Zeitstempel finde, dann kann ich dir sagen ob er sich geändert hat. Also der Zeitstempel in der Phoscon app unter Details des Sensors, ändert sich bei jeder Aktualisierung. Auch im ioBroker deconz debug log (von dem ich im vorherigen Beitrag ein Bild einfügte) scheint etwas zu passieren.
                        @Jey Cee:
                        Sind sie auch, es gibt aber eine alte und neue Version der Sensoren. Die neuen haben eben auch Pressure. `
                        Achso!
                        @Jey Cee:
                        Daylight
                        So lange sie in deConz vorhanden sind werden sie immer wieder angelegt. Löscht du sie in der Adapterkonfiguration? Dann werden die Objekte nicht gelöscht, da gibt es noch ein Bug im JS-Controller. Du musst die Objekte von Hand löschen. `
                        Ja ich habe tatsächlich 2 Osram Smart+ Plugs. Angeblich können die aber keine Leistung messen. Seltsam ist das dann nicht auch automatisch 2x ein Power Objekt erstellt wird. Nur 1x Power_2 und 1x Zwischenstecker. Beide haben jedoch die gleichen Inhalte:
                        Ich habe keine Hue Bridge im Haushalt. In der Phoscon App gibt es jedoch unter Sensoren folgendes:
                        Keine Ahnung wo der virtuelle Tageslichtsensor her kommt und welches Programm diesen erstellt hat.
                        Wie genau verhält es sich eigentlich, was sollte man nutzen? Die ganz normale deconz Webapp? oder Phoscon App?
                        Die deconz Webapp bietet keine Sensoren, jedoch scheint man dort ab und zu mal reingehen zu müssen um die Firmware zu updaten.
                        Vielleicht vereinfacht es die ganze Sache wenn ich mal kurz aufliste was ich habe:
                        2x Osram Smart+ Plug
                        3x Multisensor Aqara Temp/Humidity
                        1x Aqara Door/Window Sensor
                        Genutzte Adapter in ioBroker:
                        Web
                        deconz
                        miHomeVacuum
                        flot
                        history
                        Javascript
                        scenes
                        simple-api
                        socket.io
                        vis
                        yahka
                        cloud
                        rpi2.0
                        Genutzt wird das ganze auf einem Raspberry Pi 3b mit Raspbee Shield.
                        @Jey Cee:
                        Auf die nächste Version warten, da wird das drin sein. `
                        Das werde ich gerne tun! Vielen Dank für deine Mühen!!
                        • Jey CeeJ Online
                          Jey CeeJ Online
                          Jey Cee
                          #171
                          Version 0.2.0 ist jetzt auf Github verfügbar.
                          Neben der Fehlerbeseitigung mit den Sensoren, habe ich auch einen Tab für Gruppen Verwaltung eingefügt. Zurzeit können Gruppen erstellt und gelöscht werden, Objekte in ioBroker müssen noch von Hand entfernt werden. Bei den Gruppen Tauchen unter Devicemembership und Lights Zahlen auf, das sind die ID's der Jeweiligen Geräte.
                          Eine weitere Änderung ist die Objektstruktur, die ist jetzt um eine ebene Flacher so ist sie besser zu verwalten.
                          @Kugelkopf:
                          Wenn du mir sagst wo ich den Zeitstempel finde `
                          Wenn du mit dem Mauszeiger über den Wert gehst und kurz wartest poppt ein Kästchen auf.
                          @Kugelkopf:
                          Seltsam ist das dann nicht auch automatisch 2x ein Power Objekt erstellt wird. Nur 1x Power_2 und 1x Zwischenstecker. ` Naja die Benennung liegt ja am Namen der in deConz hinterlegt ist.
                          @Kugelkopf:
                          Die deconz Webapp bietet keine Sensoren, jedoch scheint man dort ab und zu mal reingehen zu müssen um die Firmware zu updaten. ` Wenn es nach mir geht weder WebApp noch Phoscon, das soll irgendwann alles mit dem Adapter möglich sein. Die Phoscon App soll ja die WebApp ersetzen, aber noch ist sie Beta.
                          Das Firmware update bezieht sich ja nur auf den ConBee Stick und das RaspBee Modul. Auch das hoffe ich in den Adapter einbauen zu können.
                          Aber das steht weit hinten auf der Liste, jetzt müssen erstmal die Geräte funktionieren und die Verwaltung Geräte/Gruppen funktionieren.
                            Kugelkopf
                            #172
                            @Jey Cee:
                            @Kugelkopf:
                            @Kugelkopf:
                            @Kugelkopf:
                            Aber das steht weit hinten auf der Liste, jetzt müssen erstmal die Geräte funktionieren und die Verwaltung Geräte/Gruppen funktionieren. `
                            Hi!!
                            Habe das Update nun installiert. 0.2.0.
                            Also ich konnte folgendes Verhalten replizieren:
                            Geändert hat sich unter meiner bisherigen Konfiguration nichts. Sprich, das verhalten blieb gleich. Die Zahlen blinken zwar kurz grün auf, der Zeitstempel verändert sich auch nicht und die Werte natürlich auch nicht.
                            Darauf hin habe ich nun das Gateway Resetet.
                            Wenn ich die Sensoren via Phoscon App hinzufüge, benennt Phsocon die Sensoren als Multisensor.
                            Genauso tauchen sie auch in der Geräteverwaltung und bei den Objekten von ioBroker auf.
                            Lösche ich den Sensor wieder und füge ich ihn wieder via deconz iobroker adapter hinzu, (ich muss zugeben, ich habe jetzt erst bemerkt das es überhaupt geht :D) erstellt er mir direkt mehrere Objekte.
                            Dann funktioniert allerdings alles bei den Sensoren!
                            In der Phoscon app sieht der Sensor dann so aus:
                            Ändere ich den Namen des Sensors in der Phoscon app und starte den Adapter neu, sieht es wieder so aus, als hätte ich den Sensor von vorne herein in Phoscon hinzugefügt.
                            Die Werte ändern sich nun auch nicht mehr in ioBroker. (Benannt in Temp1)
                            Ich weiß übrigens nicht ob es was zur Sache tut. Das Löschen in der Geräteverwaltung von deconz funktioniert seltsamerweise immer nur mit einem Gerät danach läd er zwar die Seite neu aber ich kann noch so oft auf einen Mülleimer drücken, das Gerät bleibt bestehen.
                            Macht natürlich nichts, kann es ja in der Phoscon App löschen und dann den Adapter neuladen lassen. Dann sind sie dort auch aus der Liste.
                              Kugelkopf
                              #173
                              Hier ein paar Logs:
                              1 Sensor hinzugefügt via deconz adapter:
                              (Aktualisierung funktioniert)
                              2018-04-17 00:32:55.441 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"ce4abc760a7ce05c6379d7889fff1aef\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Humidity 12\",\"state\":{\"humidity\":9678,\"lastupdated\":\"2018-04-16T22:32:55\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:32:55.454 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"ce4abc760a7ce05c6379d7889fff1aef\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Pressure 13\",\"state\":{\"lastupdated\":\"2018-04-16T22:32:55\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:33:15.647 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:33:15","temperature":2776},"t":"event"}
                              2018-04-17 00:33:15.677 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9705,"lastupdated":"2018-04-16T22:33:15"},"t":"event"}
                              2018-04-17 00:33:15.699 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:33:15","pressure":1014},"t":"event"}
                              2018-04-17 00:33:15.720 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:33:15.723 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:33:15.731 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:33:15.740 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"296b4c4c26cad65931d352a69ced7368\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temperature 11\",\"state\":{\"lastupdated\":\"2018-04-16T22:33:15\",\"temperature\":2776},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:33:15.747 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"296b4c4c26cad65931d352a69ced7368\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Humidity 12\",\"state\":{\"humidity\":9705,\"lastupdated\":\"2018-04-16T22:33:15\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:33:15.759 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"296b4c4c26cad65931d352a69ced7368\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Pressure 13\",\"state\":{\"lastupdated\":\"2018-04-16T22:33:15\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:33:25.919 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:33:25","temperature":2582},"t":"event"}
                              2018-04-17 00:33:25.938 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9673,"lastupdated":"2018-04-16T22:33:25"},"t":"event"}
                              2018-04-17 00:33:25.961 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:33:25.970 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:33:25","pressure":1014},"t":"event"}
                              2018-04-17 00:33:25.982 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"b76ac191b2e49a203bb717c4fc7b3b6d\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temperature 11\",\"state\":{\"lastupdated\":\"2018-04-16T22:33:25\",\"temperature\":2582},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:33:26.025 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:33:26.040 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"b76ac191b2e49a203bb717c4fc7b3b6d\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Humidity 12\",\"state\":{\"humidity\":9673,\"lastupdated\":\"2018-04-16T22:33:25\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:33:26.069 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:33:26.086 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"b76ac191b2e49a203bb717c4fc7b3b6d\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Pressure 13\",\"state\":{\"lastupdated\":\"2018-04-16T22:33:25\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:33:36.196 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:33:36","temperature":2513},"t":"event"}
                              2018-04-17 00:33:36.215 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9676,"lastupdated":"2018-04-16T22:33:36"},"t":"event"}
                              2018-04-17 00:33:36.238 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:33:36","pressure":1014},"t":"event"}
                              2018-04-17 00:33:36.284 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:33:36.300 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:33:36.308 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:33:36.324 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"fe8fa38bec56a9e3d22d9227f23e40b0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temperature 11\",\"state\":{\"lastupdated\":\"2018-04-16T22:33:36\",\"temperature\":2513},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:33:36.343 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"fe8fa38bec56a9e3d22d9227f23e40b0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Humidity 12\",\"state\":{\"humidity\":9676,\"lastupdated\":\"2018-04-16T22:33:36\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:33:36.350 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"fe8fa38bec56a9e3d22d9227f23e40b0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Pressure 13\",\"state\":{\"lastupdated\":\"2018-04-16T22:33:36\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:33:56.535 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:33:56","temperature":2431},"t":"event"}
                              2018-04-17 00:33:56.551 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9708,"lastupdated":"2018-04-16T22:33:56"},"t":"event"}
                              2018-04-17 00:33:56.564 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:33:56","pressure":1014},"t":"event"}
                              2018-04-17 00:33:56.597 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:33:56.606 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:33:56.610 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:33:56.623 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6ccf993d324aea7962a6e827467c1c36\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temperature 11\",\"state\":{\"lastupdated\":\"2018-04-16T22:33:56\",\"temperature\":2431},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:33:56.641 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6ccf993d324aea7962a6e827467c1c36\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Humidity 12\",\"state\":{\"humidity\":9708,\"lastupdated\":\"2018-04-16T22:33:56\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:33:56.649 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6ccf993d324aea7962a6e827467c1c36\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Pressure 13\",\"state\":{\"lastupdated\":\"2018-04-16T22:33:56\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:34:16.800 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:34:16","temperature":2377},"t":"event"}
                              2018-04-17 00:34:16.829 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:34:16.839 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9717,"lastupdated":"2018-04-16T22:34:16"},"t":"event"}
                              2018-04-17 00:34:16.843 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:34:16","pressure":1014},"t":"event"}
                              2018-04-17 00:34:16.849 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"d63450a498f7adae53589bf193e2f3c6\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temperature 11\",\"state\":{\"lastupdated\":\"2018-04-16T22:34:16\",\"temperature\":2377},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:34:16.922 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:34:16.930 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:34:16.940 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"d63450a498f7adae53589bf193e2f3c6\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Humidity 12\",\"state\":{\"humidity\":9717,\"lastupdated\":\"2018-04-16T22:34:16\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:34:16.960 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"d63450a498f7adae53589bf193e2f3c6\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Pressure 13\",\"state\":{\"lastupdated\":\"2018-04-16T22:34:16\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:34:36.999 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","name":"Temp1","r":"sensors","t":"event"}
                              2018-04-17 00:34:37.006 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","name":"Temp1","r":"sensors","t":"event"}
                              2018-04-17 00:34:37.009 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","name":"Temp1","r":"sensors","t":"event"}
                              2018-04-17 00:34:37.041 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:34:37.051 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:34:37.056 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:34:37.068 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6a8e96b5b447c6665dfbc150f78754f4\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:34:16\",\"temperature\":2377},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:34:37.091 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6a8e96b5b447c6665dfbc150f78754f4\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9717,\"lastupdated\":\"2018-04-16T22:34:16\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:34:37.097 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6a8e96b5b447c6665dfbc150f78754f4\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:34:16\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:35:07.205 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:07","temperature":3022},"t":"event"}
                              2018-04-17 00:35:07.223 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9834,"lastupdated":"2018-04-16T22:35:07"},"t":"event"}
                              2018-04-17 00:35:07.244 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:35:07.253 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:07","pressure":1014},"t":"event"}
                              2018-04-17 00:35:07.258 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:35:07.281 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"88e313a7040ac02f06c87310282da891\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:07\",\"temperature\":3022},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:35:07.298 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"88e313a7040ac02f06c87310282da891\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9834,\"lastupdated\":\"2018-04-16T22:35:07\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:35:07.357 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:35:07.384 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"88e313a7040ac02f06c87310282da891\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:07\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:35:07.394 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"88e313a7040ac02f06c87310282da891\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:07\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:35:17.488 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:17","temperature":2718},"t":"event"}
                              2018-04-17 00:35:17.507 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:35:17.514 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9744,"lastupdated":"2018-04-16T22:35:17"},"t":"event"}
                              2018-04-17 00:35:17.528 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6315bbb1396d5409061238293900b0ae\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:17\",\"temperature\":2718},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:35:17.545 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:17","pressure":1014},"t":"event"}
                              2018-04-17 00:35:17.600 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:35:17.612 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:35:17.620 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6315bbb1396d5409061238293900b0ae\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9744,\"lastupdated\":\"2018-04-16T22:35:17\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:35:17.643 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6315bbb1396d5409061238293900b0ae\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:17\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:35:27.749 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:27","temperature":2618},"t":"event"}
                              2018-04-17 00:35:27.775 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:35:27.779 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9748,"lastupdated":"2018-04-16T22:35:27"},"t":"event"}
                              2018-04-17 00:35:27.797 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"e23fb85a9c7885105714d0f9a43daf9d\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:27\",\"temperature\":2618},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:35:27.821 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:27","pressure":1014},"t":"event"}
                              2018-04-17 00:35:27.869 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:35:27.876 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:35:27.883 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"e23fb85a9c7885105714d0f9a43daf9d\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9748,\"lastupdated\":\"2018-04-16T22:35:27\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:35:27.907 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"e23fb85a9c7885105714d0f9a43daf9d\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:27\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:35:38.014 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:38","temperature":2551},"t":"event"}
                              2018-04-17 00:35:38.040 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9754,"lastupdated":"2018-04-16T22:35:38"},"t":"event"}
                              2018-04-17 00:35:38.057 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:38","pressure":1014},"t":"event"}
                              2018-04-17 00:35:38.072 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:35:38.093 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:35:38.107 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"9064cd65a3e05f3477e2968446a3a5e9\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:38\",\"temperature\":2551},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:35:38.119 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:35:38.145 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"9064cd65a3e05f3477e2968446a3a5e9\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9754,\"lastupdated\":\"2018-04-16T22:35:38\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:35:38.170 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"9064cd65a3e05f3477e2968446a3a5e9\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:38\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:35:38.176 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"9064cd65a3e05f3477e2968446a3a5e9\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:38\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:35:58.321 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:58","temperature":2485},"t":"event"}
                              2018-04-17 00:35:58.340 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9765,"lastupdated":"2018-04-16T22:35:58"},"t":"event"}
                              2018-04-17 00:35:58.363 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:35:58","pressure":1015},"t":"event"}
                              2018-04-17 00:35:58.428 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:35:58.437 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:35:58.441 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:35:58.455 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2a782bf5860b584c1eb1a707eeb7d593\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:58\",\"temperature\":2485},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:35:58.479 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2a782bf5860b584c1eb1a707eeb7d593\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9765,\"lastupdated\":\"2018-04-16T22:35:58\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:35:58.485 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2a782bf5860b584c1eb1a707eeb7d593\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:58\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:35:58.516 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2a782bf5860b584c1eb1a707eeb7d593\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:35:58\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              In der Phoscon App den Sensor umbenannt in "Temp1":
                              (Nach dem Neustart des Adapters funktioniert die Aktualisierung weiterhin. In den Objekten befindet sich weiterhin jeweils ein Unterordner für Temperature, Humidity, Pressure mit jeweils den Eigenschaften: 5370_bildschirmfoto_2018-04-16_um_15.04.07.png )
                              2018-04-17 00:37:32.746 - info: host.raspi instance system.adapter.deconz.0 started with pid 32091
                              2018-04-17 00:37:35.167 - debug: deconz.0 objectDB connected
                              2018-04-17 00:37:35.370 - debug: deconz.0 statesDB connected
                              2018-04-17 00:37:35.460 - info: deconz.0 starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
                              2018-04-17 00:37:35.559 - debug: deconz.0 API version: 1.0.9
                              2018-04-17 00:37:35.602 - debug: deconz.0 getAllLights: {"1":{"ctmax":454,"ctmin":250,"etag":"f4a23818fbadac0770b3179fa3a39cba","hascolor":true,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E14 WS opal 400lm","name":"Nachttischlampe","state":{"alert":"none","bri":254,"colormode":"ct","ct":454,"on":true,"reachable":true},"swversion":"1.2.217","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:8a:31:88-01"}}
                              2018-04-17 00:37:35.622 - debug: deconz.0 getAllSensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"c45c503906989b0c34bd5891a0fee50d","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"daylight":false,"lastupdated":"2018-04-16T20:44:24","status":230},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:01:3e:51-01"},"11":{"config":{"battery":null,"offset":null,"on":true,"reachable":true},"ep":1,"etag":"8a6dd6a2a644fea586f000a4fe5bfccd","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp1","state":{"lastupdated":"2018-04-16T22:36:28","temperature":2431},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0402"},"12":{"config":{"battery":null,"on":true,"reachable":true},"ep":1,"etag":"8a6dd6a2a644fea586f000a4fe5bfccd","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp1","state":{"humidity":9786,"lastupdated":"2018-04-16T22:36:28"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0405"},"13":{"config":{"battery":null,"on":true,"reachable":true},"ep":1,"etag":"8a6dd6a2a644fea586f000a4fe5bfccd","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp1","state":{"lastupdated":"2018-04-16T22:36:28","pressure":1015},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0403"}}
                              2018-04-17 00:37:35.644 - debug: deconz.0 getAllGroups: {"2":{"action":{"bri":128,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":128,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"db3ef8f25108b9b2475cbb97af4857af","hidden":false,"id":"2","lights":["1"],"lightsequence":[],"multideviceids":[],"name":"Lichter","scenes":[],"state":{"all_on":true,"any_on":true},"type":"LightGroup"}}
                              2018-04-17 00:37:35.757 - debug: deconz.0 getGroupAttributes: {"action":{"bri":128,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":128,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"db3ef8f25108b9b2475cbb97af4857af","hidden":false,"id":"2","lights":["1"],"lightsequence":[],"multideviceids":[],"name":"Lichter","scenes":[],"state":{"all_on":true,"any_on":true},"type":"LightGroup"}
                              2018-04-17 00:38:09.202 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:09","temperature":3157},"t":"event"}
                              2018-04-17 00:38:09.216 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9768,"lastupdated":"2018-04-16T22:38:09"},"t":"event"}
                              2018-04-17 00:38:09.239 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:09","pressure":1014},"t":"event"}
                              2018-04-17 00:38:09.315 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:38:09.326 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:38:09.342 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:38:09.357 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"01762c297d6605f66561202879c895e0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:09\",\"temperature\":3157},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:38:09.372 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"01762c297d6605f66561202879c895e0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9768,\"lastupdated\":\"2018-04-16T22:38:09\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:38:09.401 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"01762c297d6605f66561202879c895e0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:09\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:38:09.413 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"01762c297d6605f66561202879c895e0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:09\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:38:19.462 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:19","temperature":2803},"t":"event"}
                              2018-04-17 00:38:19.515 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9762,"lastupdated":"2018-04-16T22:38:19"},"t":"event"}
                              2018-04-17 00:38:19.518 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:19","pressure":1015},"t":"event"}
                              2018-04-17 00:38:19.580 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:38:19.597 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:38:19.601 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:38:19.613 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6ccdb05f99c943973d9c38500cff73fa\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:19\",\"temperature\":2803},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:38:19.655 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6ccdb05f99c943973d9c38500cff73fa\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9762,\"lastupdated\":\"2018-04-16T22:38:19\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:38:19.674 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6ccdb05f99c943973d9c38500cff73fa\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:19\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:38:19.690 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"6ccdb05f99c943973d9c38500cff73fa\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:19\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:38:29.733 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:29","temperature":2684},"t":"event"}
                              2018-04-17 00:38:29.751 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9779,"lastupdated":"2018-04-16T22:38:29"},"t":"event"}
                              2018-04-17 00:38:29.839 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:29","pressure":1014},"t":"event"}
                              2018-04-17 00:38:29.914 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:38:29.922 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:38:29.940 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:38:29.959 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2fbabca39e81b722bf68bc073950fb4e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:29\",\"temperature\":2684},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:38:29.974 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2fbabca39e81b722bf68bc073950fb4e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9779,\"lastupdated\":\"2018-04-16T22:38:29\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:38:29.991 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2fbabca39e81b722bf68bc073950fb4e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:29\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:38:29.995 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2fbabca39e81b722bf68bc073950fb4e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:29\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:38:40.014 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:40","temperature":2611},"t":"event"}
                              2018-04-17 00:38:40.037 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9783,"lastupdated":"2018-04-16T22:38:40"},"t":"event"}
                              2018-04-17 00:38:40.045 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:38:40.061 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:40","pressure":1015},"t":"event"}
                              2018-04-17 00:38:40.067 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"78cc86b2a89711d794b1a44d3633496e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:40\",\"temperature\":2611},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:38:40.135 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:38:40.138 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:38:40.154 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"78cc86b2a89711d794b1a44d3633496e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9783,\"lastupdated\":\"2018-04-16T22:38:40\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:38:40.171 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"78cc86b2a89711d794b1a44d3633496e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:40\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:38:40.183 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"78cc86b2a89711d794b1a44d3633496e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:40\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:38:50.278 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:50","temperature":2557},"t":"event"}
                              2018-04-17 00:38:50.298 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9802,"lastupdated":"2018-04-16T22:38:50"},"t":"event"}
                              2018-04-17 00:38:50.306 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:38:50.324 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"offset\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2ef315247d39adea466a47f56a8bfe2a\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:50\",\"temperature\":2557},\"type\":\"ZHATemperature\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0402\"}"
                              2018-04-17 00:38:50.336 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:38:50","pressure":1015},"t":"event"}
                              2018-04-17 00:38:50.354 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:38:50.427 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2ef315247d39adea466a47f56a8bfe2a\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"humidity\":9802,\"lastupdated\":\"2018-04-16T22:38:50\"},\"type\":\"ZHAHumidity\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0405\"}"
                              2018-04-17 00:38:50.441 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:38:50.506 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"2ef315247d39adea466a47f56a8bfe2a\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:38:50\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:39:10.594 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:39:10","temperature":2490},"t":"event"}
                              2018-04-17 00:39:10.617 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:39:10","pressure":1015},"t":"event"}
                              2018-04-17 00:39:10.622 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:39:10.631 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:39:36.368 - info: host.raspi object change system.adapter.deconz.0
                              2018-04-17 00:39:36.396 - info: host.raspi stopInstance system.adapter.deconz.0
                              2018-04-17 00:39:36.399 - info: host.raspi stopInstance system.adapter.deconz.0 killing pid 32091
                              Nach dem löschen des deconz Objektes im Objekt Tab von ioBroker und einem Neustart des Adapters um die Objekte neu aufzubauen:
                              (Aktualisierung der Werte funktioniert nicht mehr.)
                              2018-04-17 00:39:38.978 - info: host.raspi instance system.adapter.deconz.0 started with pid 495
                              2018-04-17 00:39:41.398 - debug: deconz.0 objectDB connected
                              2018-04-17 00:39:41.542 - debug: deconz.0 statesDB connected
                              2018-04-17 00:39:41.648 - info: deconz.0 starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
                              2018-04-17 00:39:41.729 - debug: deconz.0 API version: 1.0.9
                              2018-04-17 00:39:41.779 - debug: deconz.0 getAllLights: {"1":{"ctmax":454,"ctmin":250,"etag":"f4a23818fbadac0770b3179fa3a39cba","hascolor":true,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E14 WS opal 400lm","name":"Nachttischlampe","state":{"alert":"none","bri":254,"colormode":"ct","ct":454,"on":true,"reachable":true},"swversion":"1.2.217","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:8a:31:88-01"}}
                              2018-04-17 00:39:41.800 - debug: deconz.0 getAllSensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"c45c503906989b0c34bd5891a0fee50d","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"daylight":false,"lastupdated":"2018-04-16T20:44:24","status":230},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:01:3e:51-01"},"11":{"config":{"battery":null,"offset":null,"on":true,"reachable":true},"ep":1,"etag":"edf18aeeb1ffedecee427205d6b64181","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp1","state":{"lastupdated":"2018-04-16T22:39:10","temperature":2490},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0402"},"12":{"config":{"battery":null,"on":true,"reachable":true},"ep":1,"etag":"2ef315247d39adea466a47f56a8bfe2a","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp1","state":{"humidity":9802,"lastupdated":"2018-04-16T22:38:50"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0405"},"13":{"config":{"battery":null,"on":true,"reachable":true},"ep":1,"etag":"edf18aeeb1ffedecee427205d6b64181","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp1","state":{"lastupdated":"2018-04-16T22:39:10","pressure":1015},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0403"}}
                              2018-04-17 00:39:41.828 - debug: deconz.0 getAllGroups: {"2":{"action":{"bri":128,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":128,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"db3ef8f25108b9b2475cbb97af4857af","hidden":false,"id":"2","lights":["1"],"lightsequence":[],"multideviceids":[],"name":"Lichter","scenes":[],"state":{"all_on":true,"any_on":true},"type":"LightGroup"}}
                              2018-04-17 00:39:42.010 - debug: deconz.0 getGroupAttributes: {"action":{"bri":128,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":128,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"db3ef8f25108b9b2475cbb97af4857af","hidden":false,"id":"2","lights":["1"],"lightsequence":[],"multideviceids":[],"name":"Lichter","scenes":[],"state":{"all_on":true,"any_on":true},"type":"LightGroup"}
                              2018-04-17 00:40:11.269 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:11","temperature":2618},"t":"event"}
                              2018-04-17 00:40:11.284 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9828,"lastupdated":"2018-04-16T22:40:11"},"t":"event"}
                              2018-04-17 00:40:11.308 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:40:11.312 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:40:11.313 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:11","pressure":1015},"t":"event"}
                              2018-04-17 00:40:11.328 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:40:11.344 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"f2eca4a6e770d26964546704762d9c6d\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:40:11\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:40:21.532 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:21","temperature":2925},"t":"event"}
                              2018-04-17 00:40:21.551 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9882,"lastupdated":"2018-04-16T22:40:21"},"t":"event"}
                              2018-04-17 00:40:21.559 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:40:21.575 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:40:21.577 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:21","pressure":1015},"t":"event"}
                              2018-04-17 00:40:21.599 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:40:21.612 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"3e23731a0fdb22717a2dbd2d779fda24\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:40:21\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:40:31.803 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:31","temperature":2783},"t":"event"}
                              2018-04-17 00:40:31.822 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9789,"lastupdated":"2018-04-16T22:40:31"},"t":"event"}
                              2018-04-17 00:40:31.832 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:40:31.843 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:31","pressure":1015},"t":"event"}
                              2018-04-17 00:40:31.849 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:40:31.868 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:40:31.881 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"e6ea7689a60d80c458324524a6de6594\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:40:31\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:40:42.072 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:42","temperature":2667},"t":"event"}
                              2018-04-17 00:40:42.091 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9801,"lastupdated":"2018-04-16T22:40:42"},"t":"event"}
                              2018-04-17 00:40:42.112 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:42","pressure":1014},"t":"event"}
                              2018-04-17 00:40:42.194 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:40:42.209 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:40:42.215 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:40:42.222 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"e1c6eb36bf01e87b312f1da93fcf2013\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:40:42\",\"pressure\":1014},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:40:52.336 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:52","temperature":2616},"t":"event"}
                              2018-04-17 00:40:52.357 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9808,"lastupdated":"2018-04-16T22:40:52"},"t":"event"}
                              2018-04-17 00:40:52.364 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:40:52.381 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:40:52","pressure":1015},"t":"event"}
                              2018-04-17 00:40:52.387 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:40:52.404 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:40:52.415 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"7133d6cc180433c3706defddea189f83\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:40:52\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              2018-04-17 00:41:12.642 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-04-16T22:41:12","temperature":2565},"t":"event"}
                              2018-04-17 00:41:12.662 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"humidity":9829,"lastupdated":"2018-04-16T22:41:12"},"t":"event"}
                              2018-04-17 00:41:12.671 - debug: deconz.0 Id: 11 Type: sensors
                              2018-04-17 00:41:12.681 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-04-16T22:41:12","pressure":1015},"t":"event"}
                              2018-04-17 00:41:12.700 - debug: deconz.0 Id: 12 Type: sensors
                              2018-04-17 00:41:12.710 - debug: deconz.0 Id: 13 Type: sensors
                              2018-04-17 00:41:12.721 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":null,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"0eb3f17299c7336fba20b28679178f48\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Temp1\",\"state\":{\"lastupdated\":\"2018-04-16T22:41:12\",\"pressure\":1015},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                              Für mich sieht das so aus, als ob die neu erstellten Eigenschaften im Objekt Temp1, also dem umbenannten Sensor, noch weiterhin auf die alten Objekte+Eigenschaften verweisen.
                              Denn seltsamerweise, werden die Werte von Temp1 nicht mehr aktualisiert sobald die Objekte Temperature, Humidity, Pressure gelöscht werden. (siehe Bild weiter oben)
                              Dennoch ist seltsam das nach dem umbenennen und Neustarts die Werte vom neu benannten "Temp1" verändert wurden, die von den noch vorhandenen Objekten Temperature, Humidity, Pressure jedoch nicht.
                              Würde dir gerne behilflich sein!
                              Ich kenne mich zwar mit Bash und Java ein wenig aus, leider aber kaum mit Javascript bzw. mit der ganzen Art und Weise wie dieser Adapter funktioniert.
                              Viele Grüße!
                              • AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                #174
                                @Kugelkopf:
                                Sprich, das verhalten blieb gleich. Die Zahlen blinken zwar kurz grün auf, der Zeitstempel verändert sich auch nicht und die Werte natürlich auch nicht. `
                                Habe nur kurz drübergeflogen, aber es scheint diesbezüglich Unstimmigkeiten mit dem js-controller zu geben. Hast du zufällig die aktuelle Version 1.4.2 drauf?
                                  Kugelkopf
                                  #175
                                  Mir wird kein neuer Host angeboten. bin auf: 5370_bildschirmfoto_2018-04-17_um_15.42.20.png
                                  Hab bereits folgendes probiert:
                                  Komme dennoch lediglich auf Version 1.2.7.
                                  Oder habe ich irgendetwas falsch verstanden?
                                  EDIT:
                                  Habe vergessen, dass es ja noch die Github Möglichkeit gibt -.-! Ich Trottel! Hab ihn nun auf 1.4.2. und werde es noch einmal testen.
                                  Seit dem Update auf 1.4.2 kann ich ioBroker nicht mehr aufrufen…
                                    AlCalzoneA Offline
                                    AlCalzone
                                    #176
                                    @Kugelkopf:
                                    Hab ihn nun auf 1.4.2. und werde es noch einmal testen. `
                                    Ööööööh da hast du mich falsch verstanden… Version 1.4.2 hat das genannte Problem, daher ist sie auch noch nicht stable!
                                      Kugelkopf
                                      #177
                                      Hab nun das ganze System zerschossen… und bin nun dabei ein Backup wieder einzuspielen. Hoffe dann läuft es wenigstens einigermaßen erstmal wieder.
                                      Beim normalen installieren und anschließendem Updaten des JS-Controllers und der Admin Oberfläche bekam ich ständig den "Cannot get /" Fehler.
                                      • Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        #178
                                        @Kugelkopf:
                                        Ich kenne mich zwar mit Bash und Java ein wenig aus, leider aber kaum mit Javascript bzw. mit der ganzen Art und Weise wie dieser Adapter funktioniert. `
                                        Du hast mir schon geholfen, bei mir funktioniert die Phoscon App nicht und mir war nicht bewusst das die App die Multisensoren anders handhabt was die Benennung angeht. Leider hat das zur folge das ich jetzt einiges ändern muss. Oder es werden hier weiter Fehler gemeldet die gar keine sind.
                                        @Kugelkopf:
                                        Hoffe dann läuft es wenigstens einigermaßen erstmal wieder. `
                                        Ich drück dir die Daumen.
                                        Persönlicher Support
                                        Spenden -> paypal.me/J3YC33
                                          Sinalco
                                          #179
                                          @Kugelkopf:
                                          Komme dennoch lediglich auf Version 1.2.7. `
                                          Du hättest eigentlich nur im ioBroker Admin den "Aktiven Verwahrungsort" auf "latest" stellen müssen, du hast ihn vermutlich noch auf "default".
                                          Wenn er auf "latest" steht dann bekommst du die Version 1.4.2
                                          Bei mir läuft der ioBroker mit 1.4.2 normal
                                          Den deConz Adapter konnte ich leider noch nicht testen, aber ich werd mir demnächst den conbee Stock kaufen, dann gehts bei mir auch mit Beleuchtung los. :D
