  4. [gelöst] Smartmeter im Multihost
    6.0k
81 Beiträge 7 Kommentatoren 9.6k Aufrufe
  • L Offline
    ludino
    Klar kann ich das machen,
    storeAdapter
    subtitlesInstanzen
    view_listObjekte
    view_headlineLog
    flash_onEreignisse
    codeSkripte
    storageHosts
    visibility
    build
    HOST RASPBERRYPIioBroker.admin 3.3.9
    pause delete
    smart
    close
    Wert
    Zeit Geändert
    stateChange system.adapter.smartmeter.0.outputCount 28 true smartmeter.0 2018-04-13 22:37:56.973 2018-04-13 22:37:56.973
    stateChange system.adapter.smartmeter.0.inputCount 0 true smartmeter.0 2018-04-13 22:37:56.973 2018-04-13 22:37:56.973
    stateChange system.adapter.smartmeter.0.uptime 1578 true smartmeter.0 2018-04-13 22:37:56.972 2018-04-13 22:37:56.972
    stateChange system.adapter.smartmeter.0.memHeapUsed 11.41 true smartmeter.0 2018-04-13 22:37:56.971 2018-04-13 22:37:56.971
    stateChange system.adapter.smartmeter.0.memHeapTotal 16.98 true smartmeter.0 2018-04-13 22:37:56.971 2018-04-13 22:17:11.458
    stateChange system.adapter.smartmeter.0.memRss 39.61 true smartmeter.0 2018-04-13 22:37:56.970 2018-04-13 22:37:56.970
    stateChange system.adapter.smartmeter.0.connected true true smartmeter.0 2018-04-13 22:37:56.966 2018-04-13 22:11:41.365
    stateChange system.adapter.smartmeter.0.alive true true smartmeter.0 2018-04-13 22:37:56.960 2018-04-13 22:11:41.349
    stateChange smartmeter.0.1-0:1_7_255255.value 303.94 true smartmeter.0 2018-04-13 22:37:54.560 2018-04-13 22:37:54.560
    255.rawvalue "000303.94W" true smartmeter.0 2018-04-13 22:37:54.560 2018-04-13 22:37:54.560
    stateChange smartmeter.0.1-0:61_7_255
    255.value 66.24 true smartmeter.0 2018-04-13 22:37:54.559 2018-04-13 22:37:54.559
    stateChange smartmeter.0.1-0:61_7_255255.rawvalue "000066.24W" true smartmeter.0 2018-04-13 22:37:54.558 2018-04-13 22:37:54.558
    stateChange smartmeter.0.1-0:41_7_255255.value 11.61 true smartmeter.0 2018-04-13 22:37:54.558 2018-04-13 22:37:54.558
    255.rawvalue "000011.61W" true smartmeter.0 2018-04-13 22:37:54.557 2018-04-13 22:37:54.557
    stateChange smartmeter.0.1-0:21_7_255
    255.value 226.09 true smartmeter.0 2018-04-13 22:37:54.553 2018-04-13 22:37:54.553
    stateChange smartmeter.0.1-0:21_7_255255.rawvalue "000226.09W" true smartmeter.0 2018-04-13 22:37:54.546 2018-04-13 22:37:54.546
    stateChange smartmeter.0.1-0:1_8_0255.value 17097.6423771 true smartmeter.0 2018-04-13 22:37:54.543 2018-04-13 22:37:54.543
    255.rawvalue "00017097.6423771kWh" true smartmeter.0 2018-04-13 22:37:54.531 2018-04-13 22:37:54.531
    255.value 306.8 true smartmeter.0 2018-04-13 22:37:42.559 2018-04-13 22:37:42.559
    stateChange smartmeter.0.1-0:1_7_255255.rawvalue "000306.80W" true smartmeter.0 2018-04-13 22:37:42.559 2018-04-13 22:37:42.559
    stateChange smartmeter.0.1-0:61_7_255255.value 65.59 true smartmeter.0 2018-04-13 22:37:42.558 2018-04-13 22:37:42.558
    255.rawvalue "000065.59W" true smartmeter.0 2018-04-13 22:37:42.558 2018-04-13 22:37:42.558
    255.value 11.83 true smartmeter.0 2018-04-13 22:37:42.557 2018-04-13 22:37:42.557
    stateChange smartmeter.0.1-0:41_7_255255.rawvalue "000011.83W" true smartmeter.0 2018-04-13 22:37:42.557 2018-04-13 22:37:42.557
    stateChange smartmeter.0.1-0:21_7_255255.value 229.38 true smartmeter.0 2018-04-13 22:37:42.556 2018-04-13 22:37:42.556
    255.rawvalue "000229.38W" true smartmeter.0 2018-04-13 22:37:42.555 2018-04-13 22:37:42.555
    255.value 17097.6413603 true smartmeter.0 2018-04-13 22:37:42.552 2018-04-13 22:37:42.552
    stateChange smartmeter.0.1-0:1_8_0255.rawvalue "00017097.6413603kWh" true
    • L Offline
      ludino
      @wendy2702:
      Wie sieht die SD Karte aus… genug Platz? `
      ich denke genug
      Filesystem Size Used Avail Use% Mounted on
      /dev/root 30G 1.5G 27G 6% /
      devtmpfs 460M 0 460M 0% /dev
      tmpfs 464M 0 464M 0% /dev/shm
      tmpfs 464M 12M 452M 3% /run
      tmpfs 5.0M 4.0K 5.0M 1% /run/lock
      tmpfs 464M 0 464M 0% /sys/fs/cgroup
      /dev/mmcblk0p1 42M 22M 20M 53% /boot
      tmpfs 93M 0 93M 0% /run/user/1000
      • wendy2702W Online
        wendy2702W Online
        Dann bin ich jetzt Ideen los [emoji22]
        • L Offline
          ludino
          @wendy2702:
          Gesendet von iPhone mit Tapatalk Pro `
          Okay, aber vielen lieben dank euch allen für die super hilfe….! Vielleicht hat je noch jemand eine Idee......!
          Oder vielleicht ein Lösungsansatz was ich noch versuchen kann! Ich werde aufjeden fall morgen das system neu aufspielen und ohne irgendwelche Updates den smartmeter installieren. Wobei ich das schon so gemacht habe (bin ich mir aber nicht mehr sicher)
          Aber ich frage mich echt Wenn daten kommen (das ist ja mal offensichtlich) kann ich diese nicht auch anders abfangen)
          gruß
          • wendy2702W Online
            wendy2702W Online
            Mir fällt nur noch ne andere JS-Controller Version zum testen ein
            • L Offline
              ludino
              dann immer raus damit
              • L Offline
                ludino
                ah sorry jetzt verstanden ich versuch es
                • L Offline
                  ludino
                  als info,
                  wenn ich iobroker neu installiere ohne ein IOBROKER Update sprich admin auf 3.3.9 und js-controller auf 1.4.2 upzudaten kommen die Objekte und auch werte.
                  Auch gegentest gemacht Iobroker neu installiert admin auf 3.3.9 und js-controller auf 1.4.2 geupdatet keine Objekte vom smartmeter vorhanden.
                  Iobroker neu installiert ohne update, dann smartmeter installiert, danach update auf admin 3.3.9 und js-controller 1.4.2 alles gut und Objekte weiterhin vorhanden inklusive sich änderten werte.
                  Eventuell ein Bug im Smartmeter?
                  Vielleicht kann ich dem einem oder anderem Helfen damit.
                  Euch noch mal vielen dank für eure geduld und hilfe!
                  • apollon77A Offline
                    Zur verifizierung: DU nutzt kein Redis. Korrekt?
                    • L Offline
                      ludino
                      nein nutze ich nicht
                      • L Offline
                        ludino
                        habe aber schon das nächste problem,
                        multihost installiert und kein smartmeter. am slave nochmal installiert und wieder keine Objekte. Beide systeme auf admin 3.3.9 und js auf 1.4.2
                        jetzt werde ich das slave system erst mal wieder neu aufspielen und dann mal weiter schauen ob ich es dann im multihost am laufen bekomme aber das erst morgen.
                        • R Offline
                          RappiRN
                          Was heißt nochmal installiert?
                          Nach dem Einrichten des Slaves musst du doch nur den Host im Adapter-Reiter umstellen (auf den Slave), da brauchst du nichts selbst neu installieren!
                          Enrico
                            Unter der Annahme das es am js-controller liegt musst du den gleichen Trick nochmal machen mit downgrade.
                            • wendy2702W Online
                              wendy2702W Online
                              @ludino:
                              Iobroker neu installiert ohne update, dann smartmeter installiert, danach update auf admin 3.3.9 und js-controller 1.4.2 alles gut und Objekte weiterhin vorhanden inklusive sich änderten werte. `
                              Welche Admin und JS-Controller Version hattest du da?
                              Diese solltest du dann auch auf deinem Slave nutzen beim Adapter installieren und erst upgraden wenn die Objekte da sind.
                              Oder besser erstmal auf den „alten“ Versionen bleiben bis der Fehler gefunden und gefixt ist.
                              • L Offline
                                ludino
                                #66
                                @RappiRN:
                                Enrico `
                                Leider ist es Damit nicht getan, Es werden keine Objekte erstellt wenn der JS-Controller auf >1.4.0 ist
                                @apollon77:
                                Unter der Annahme das es am js-controller liegt musst du den gleichen Trick nochmal machen mit downgrade. `
                                Es wird am JS-Controller liegen! Aber leider ist es mit einem Downgrade nicht getan…... ich habe es getestet, vielleicht bleiben irgendwo daten hängen die es verhindern das die Objekte erstellen kann, leider bin ich da nicht der Fachmann für.
                                @wendy2702:
                                Oder besser erstmal auf den „alten“ Versionen bleiben bis der Fehler gefunden und gefixt ist. `
                                Zuspät schon wieder alles geupdatet
                                JS-Conroller 1.2.3 gleuabe ich
                                • DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #67
                                  Ich habe den Smartmeter zum ersten Mal mit 1.4.0 benutzt da ging alles, also ab 1.4.2 taucht der Fehler auf?
                                  Send from mobile device
                                  Das schöne ios hat Auto Korrektur zum k****
                                  Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
                                  • L Offline
                                    ludino
                                    #68
                                    Vermutlich ja,
                                    Habe es mit dem 1.4.2 versucht und da hat er keine Objekte installiert
                                    • DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #69
                                      Gilt das nur für den Smartmeter?
                                      Könntest du mal bitte auch einen anderen Adapter probieren wir möchten ausschließen das hier ein allgemeines Problem mit 1.4.2 entstanden ist!
                                      • L Offline
                                        ludino
                                        #70
                                        ich hatte den JS script adapter parallel getestet.
                                        Nach dem ich über Script ein test blocky erstellt habe, war der Datenpunkt da!
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #71
                                          Ok der JavaScript adapter ist aber mehr core, könntest du nog einen anderen nemen?
