  4. [gelöst] Smartmeter im Multihost
    6.0k
81 Beiträge 7 Kommentatoren 9.6k Aufrufe
  • apollon77A Offline
    Also stoppe mal iobroker. Mach wirklich mal „chmod -R 777 /opt/iobroker“
      Dann nochmal schauen.
      • L Offline
        ludino
        also wenn ich lösche kommt schon diese fehlermeldung
        host.raspberrypi
        2018-04-13 22:07:52.680
        error
        Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/smartmeter.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/n
        host.raspberrypi
        2018-04-13 22:07:52.304
        info
        Do not restart adapter system.adapter.smartmeter.0 because disabled or deleted
        beim neuinstallieren
        smartmeter.0
        2018-04-13 22:11:55.025
        info
        Received 9 values, 5 updated
        smartmeter.0
        2018-04-13 22:11:43.101
        info
        Received 9 values, 9 updated
        smartmeter.0
        2018-04-13 22:11:41.387
        info
        starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.14.1
        host.raspberrypi
        2018-04-13 22:11:38.702
        info
        instance system.adapter.smartmeter.0 started with pid 2254
        host.raspberrypi
        2018-04-13 22:11:38.655
        info
        "system.adapter.smartmeter.0" enabled
        host.raspberrypi
        2018-04-13 22:11:38.654
        info
        object change system.adapter.smartmeter.0
        host.raspberrypi
        2018-04-13 22:11:36.058
        info
        iobroker
        2018-04-13 22:11:08.345
        info
        exit 0
        iobroker
        2018-04-13 22:11:08.334
        info
        host.raspberrypi object system.adapter.smartmeter.0 created
        host.raspberrypi
        2018-04-13 22:11:08.321
        info
        iobroker
        2018-04-13 22:11:08.287
        info
        host.raspberrypi object system.adapter.smartmeter.0.alive created
        iobroker
        2018-04-13 22:11:08.257
        info
        host.raspberrypi object system.adapter.smartmeter.0.connected created
        iobroker
        2018-04-13 22:11:08.224
        info
        host.raspberrypi object system.adapter.smartmeter.0.memHeapUsed created
        iobroker
        2018-04-13 22:11:08.194
        info
        host.raspberrypi object system.adapter.smartmeter.0.memHeapTotal created
        iobroker
        2018-04-13 22:11:08.167
        info
        host.raspberrypi object system.adapter.smartmeter.0.memRss created
        iobroker
        2018-04-13 22:11:08.133
        info
        host.raspberrypi object system.adapter.smartmeter.0.uptime created
        iobroker
        2018-04-13 22:11:08.100
        info
        host.raspberrypi object system.adapter.smartmeter.0.inputCount created
        iobroker
        2018-04-13 22:11:08.068
        info
        host.raspberrypi object system.adapter.smartmeter.0.outputCount created
        iobroker
        2018-04-13 22:11:08.052
        info
        host.raspberrypi create instance smartmeter
        iobroker
        2018-04-13 22:11:08.017
        info
        host.raspberrypi object system.adapter.smartmeter created
        iobroker
        2018-04-13 22:11:07.895
        info
        upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
        iobroker
        2018-04-13 22:11:07.833
        info
        upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
        iobroker
        2018-04-13 22:11:07.730
        info
        upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
        iobroker
        2018-04-13 22:11:07.656
        info
        upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
        iobroker
        2018-04-13 22:11:07.595
        info
        upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
        iobroker
        2018-04-13 22:11:07.498
        info
        upload [5] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/words.js words.js application/javascript
        iobroker
        2018-04-13 22:11:07.470
        info
        got /opt/iobroker/node_modules/iobroker.smartmeter/admin
        iobroker
        2018-04-13 22:11:07.439
        info
        host.raspberrypi install adapter smartmeter
        iobroker
        2018-04-13 22:10:58.916
        info
        iobroker
        info
        Call(int argc, v8::Local argv[]) const {
        iobroker
        info
        ../../../../nan/nan.h:1618:3: note: declared here
        iobroker
        info
        In file included from ../src/poller.cpp:1:0:
        iobroker
        info
        iobroker
        info
        obj->callback.Call(2, argv);
        iobroker
        info
        ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:../src/poller.cpp:69:29: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*)
        iobroker
        2018-04-13 22:10:51.127
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        from ../src/serialport.cpp:1:
        iobroker
        info
        In file included from ../src/./serialport.h:6:0,
        iobroker
        info
        iobroker
        info
        data->callback.Call(1, argv);
        iobroker
        info
        ../src/serialport.cpp:424:30: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is deprecated [-Wdeprecated-declarations]
        iobroker
        info
        ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        data->callback.Call(2, argv);
        iobroker
        info
        ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:../src/serialport.cpp:383:30: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is depre
        iobroker
        2018-04-13 22:10:51.108
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:../src/serialport.cpp:336:30: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is deprecated [-
        iobroker
        2018-04-13 22:10:51.090
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:../src/serialport.cpp:285:30: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is deprecated [-
        iobroker
        2018-04-13 22:10:51.079
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:../src/serialport.cpp:231:30: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is deprecated
        iobroker
        2018-04-13 22:10:51.072
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:../src/serialport.cpp:188:30: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is deprecated
        iobroker
        2018-04-13 22:10:51.065
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:../src/serialport.cpp:150:30: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is deprecated
        iobroker
        2018-04-13 22:10:51.056
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        iobroker
        info
        ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:../src/serialport.cpp:95:30: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is deprecated [-
        iobroker
        2018-04-13 22:10:46.375
        info
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/.node-gyp"
        iobroker
        2018-04-13 22:10:46.367
        info
        EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.14.1"
        iobroker
        2018-04-13 22:10:46.365
        info
        WARN
        iobroker
        2018-04-13 22:10:46.363
        info
        iobroker
        2018-04-13 22:10:46.359
        info
        gyp
        iobroker
        2018-04-13 22:10:44.521
        info
        EACCES: permission denied, access '/root/.npm'
        iobroker
        2018-04-13 22:10:44.517
        info
        WARN install
        iobroker
        2018-04-13 22:10:44.515
        info
        prebuild-install
        iobroker
        2018-04-13 22:10:44.503
        info
        looking for local prebuild @ prebuilds/serialport-v6.1.1-node-v48-linux-arm.tar.gz
        iobroker
        2018-04-13 22:10:44.501
        info
        info
        iobroker
        2018-04-13 22:10:44.499
        info
        prebuild-install
        iobroker
        2018-04-13 22:10:44.492
        info
        begin Prebuild-install version 2.5.1
        iobroker
        2018-04-13 22:10:44.481
        info
        info
        iobroker
        2018-04-13 22:10:44.479
        info
        iobroker
        2018-04-13 22:10:44.472
        info
        prebuild-install
        iobroker
        2018-04-13 22:09:47.754
        info
        npm install iobroker.smartmeter --production --save --prefix "/opt/iobroker" (System call)
        iobroker
        2018-04-13 22:09:46.627
        info
        NPM version: 3.10.10
        iobroker
        2018-04-13 22:09:43.143
        info
        add smartmeter
        iobroker
        2018-04-13 22:08:18.806
        info
        exit 0
        und wie soll es sein keine objekte.
        Hilft vielleicht eine Neuinstallation, was ich aber nicht glaube, hatte es anfangs auf einem PI zero am laufen ohne objekte, dann eine neu installation auf einem pi 3 und da das gleiche!
        • L Offline
          ludino
          achja
          pi@raspberrypi:~ $ sudo chmod -R 777 /opt/iobroker
          pi@raspberrypi:~ $ sudo iobroker start
          Starting iobroker controller daemon…
          iobroker controller daemon started. PID: 1719
          pi@raspberrypi:~ $
            Also im Log oben stehen beim ersten Start das Channels und States anegelgt werden und auch wann Daten aktualisiert werden.
            Kannst Du im Tab "Events" mal schauen ob wenn neue Daten reinkommen dort einträge für smartmeter.0 kommen ?!
            Aber ansonsten bin ich mit meinem Latein echt am Ende
            • wendy2702W Online
              wendy2702W Online
              Eins noch…
              Wie sieht die SD Karte aus... genug Platz?
              • L Offline
                ludino
                Klar kann ich das machen,
                storeAdapter
                subtitlesInstanzen
                view_listObjekte
                view_headlineLog
                flash_onEreignisse
                codeSkripte
                storageHosts
                visibility
                build
                HOST RASPBERRYPIioBroker.admin 3.3.9
                pause delete
                smart
                close
                Wert
                Zeit Geändert
                stateChange system.adapter.smartmeter.0.outputCount 28 true smartmeter.0 2018-04-13 22:37:56.973 2018-04-13 22:37:56.973
                stateChange system.adapter.smartmeter.0.inputCount 0 true smartmeter.0 2018-04-13 22:37:56.973 2018-04-13 22:37:56.973
                stateChange system.adapter.smartmeter.0.uptime 1578 true smartmeter.0 2018-04-13 22:37:56.972 2018-04-13 22:37:56.972
                stateChange system.adapter.smartmeter.0.memHeapUsed 11.41 true smartmeter.0 2018-04-13 22:37:56.971 2018-04-13 22:37:56.971
                stateChange system.adapter.smartmeter.0.memHeapTotal 16.98 true smartmeter.0 2018-04-13 22:37:56.971 2018-04-13 22:17:11.458
                stateChange system.adapter.smartmeter.0.memRss 39.61 true smartmeter.0 2018-04-13 22:37:56.970 2018-04-13 22:37:56.970
                stateChange system.adapter.smartmeter.0.connected true true smartmeter.0 2018-04-13 22:37:56.966 2018-04-13 22:11:41.365
                stateChange system.adapter.smartmeter.0.alive true true smartmeter.0 2018-04-13 22:37:56.960 2018-04-13 22:11:41.349
                stateChange smartmeter.0.1-0:1_7_255255.value 303.94 true smartmeter.0 2018-04-13 22:37:54.560 2018-04-13 22:37:54.560
                255.rawvalue "000303.94W" true smartmeter.0 2018-04-13 22:37:54.560 2018-04-13 22:37:54.560
                stateChange smartmeter.0.1-0:61_7_255
                255.value 66.24 true smartmeter.0 2018-04-13 22:37:54.559 2018-04-13 22:37:54.559
                stateChange smartmeter.0.1-0:61_7_255255.rawvalue "000066.24W" true smartmeter.0 2018-04-13 22:37:54.558 2018-04-13 22:37:54.558
                stateChange smartmeter.0.1-0:41_7_255255.value 11.61 true smartmeter.0 2018-04-13 22:37:54.558 2018-04-13 22:37:54.558
                255.rawvalue "000011.61W" true smartmeter.0 2018-04-13 22:37:54.557 2018-04-13 22:37:54.557
                stateChange smartmeter.0.1-0:21_7_255
                255.value 226.09 true smartmeter.0 2018-04-13 22:37:54.553 2018-04-13 22:37:54.553
                stateChange smartmeter.0.1-0:21_7_255255.rawvalue "000226.09W" true smartmeter.0 2018-04-13 22:37:54.546 2018-04-13 22:37:54.546
                stateChange smartmeter.0.1-0:1_8_0255.value 17097.6423771 true smartmeter.0 2018-04-13 22:37:54.543 2018-04-13 22:37:54.543
                255.rawvalue "00017097.6423771kWh" true smartmeter.0 2018-04-13 22:37:54.531 2018-04-13 22:37:54.531
                255.value 306.8 true smartmeter.0 2018-04-13 22:37:42.559 2018-04-13 22:37:42.559
                stateChange smartmeter.0.1-0:1_7_255255.rawvalue "000306.80W" true smartmeter.0 2018-04-13 22:37:42.559 2018-04-13 22:37:42.559
                stateChange smartmeter.0.1-0:61_7_255255.value 65.59 true smartmeter.0 2018-04-13 22:37:42.558 2018-04-13 22:37:42.558
                255.rawvalue "000065.59W" true smartmeter.0 2018-04-13 22:37:42.558 2018-04-13 22:37:42.558
                255.value 11.83 true smartmeter.0 2018-04-13 22:37:42.557 2018-04-13 22:37:42.557
                stateChange smartmeter.0.1-0:41_7_255255.rawvalue "000011.83W" true smartmeter.0 2018-04-13 22:37:42.557 2018-04-13 22:37:42.557
                stateChange smartmeter.0.1-0:21_7_255255.value 229.38 true smartmeter.0 2018-04-13 22:37:42.556 2018-04-13 22:37:42.556
                255.rawvalue "000229.38W" true smartmeter.0 2018-04-13 22:37:42.555 2018-04-13 22:37:42.555
                255.value 17097.6413603 true smartmeter.0 2018-04-13 22:37:42.552 2018-04-13 22:37:42.552
                stateChange smartmeter.0.1-0:1_8_0255.rawvalue "00017097.6413603kWh" true
                • L Offline
                  ludino
                  @wendy2702:
                  Wie sieht die SD Karte aus… genug Platz? `
                  ich denke genug
                  Filesystem Size Used Avail Use% Mounted on
                  /dev/root 30G 1.5G 27G 6% /
                  devtmpfs 460M 0 460M 0% /dev
                  tmpfs 464M 0 464M 0% /dev/shm
                  tmpfs 464M 12M 452M 3% /run
                  tmpfs 5.0M 4.0K 5.0M 1% /run/lock
                  tmpfs 464M 0 464M 0% /sys/fs/cgroup
                  /dev/mmcblk0p1 42M 22M 20M 53% /boot
                  tmpfs 93M 0 93M 0% /run/user/1000
                  • wendy2702W Online
                    wendy2702W Online
                    Dann bin ich jetzt Ideen los [emoji22]
                    • L Offline
                      ludino
                      @wendy2702:
                      Gesendet von iPhone mit Tapatalk Pro `
                      Okay, aber vielen lieben dank euch allen für die super hilfe….! Vielleicht hat je noch jemand eine Idee......!
                      Oder vielleicht ein Lösungsansatz was ich noch versuchen kann! Ich werde aufjeden fall morgen das system neu aufspielen und ohne irgendwelche Updates den smartmeter installieren. Wobei ich das schon so gemacht habe (bin ich mir aber nicht mehr sicher)
                      Aber ich frage mich echt Wenn daten kommen (das ist ja mal offensichtlich) kann ich diese nicht auch anders abfangen)
                      gruß
                      • wendy2702W Online
                        wendy2702W Online
                        Mir fällt nur noch ne andere JS-Controller Version zum testen ein
                        • L Offline
                          ludino
                          dann immer raus damit
                          • L Offline
                            ludino
                            ah sorry jetzt verstanden ich versuch es
                            • L Offline
                              ludino
                              als info,
                              wenn ich iobroker neu installiere ohne ein IOBROKER Update sprich admin auf 3.3.9 und js-controller auf 1.4.2 upzudaten kommen die Objekte und auch werte.
                              Auch gegentest gemacht Iobroker neu installiert admin auf 3.3.9 und js-controller auf 1.4.2 geupdatet keine Objekte vom smartmeter vorhanden.
                              Iobroker neu installiert ohne update, dann smartmeter installiert, danach update auf admin 3.3.9 und js-controller 1.4.2 alles gut und Objekte weiterhin vorhanden inklusive sich änderten werte.
                              Eventuell ein Bug im Smartmeter?
                              Vielleicht kann ich dem einem oder anderem Helfen damit.
                              Euch noch mal vielen dank für eure geduld und hilfe!
                                Zur verifizierung: DU nutzt kein Redis. Korrekt?
                                • L Offline
                                  ludino
                                  nein nutze ich nicht
                                  • L Offline
                                    ludino
                                    habe aber schon das nächste problem,
                                    multihost installiert und kein smartmeter. am slave nochmal installiert und wieder keine Objekte. Beide systeme auf admin 3.3.9 und js auf 1.4.2
                                    jetzt werde ich das slave system erst mal wieder neu aufspielen und dann mal weiter schauen ob ich es dann im multihost am laufen bekomme aber das erst morgen.
                                    • R Offline
                                      RappiRN
                                      Was heißt nochmal installiert?
                                      Nach dem Einrichten des Slaves musst du doch nur den Host im Adapter-Reiter umstellen (auf den Slave), da brauchst du nichts selbst neu installieren!
                                      Enrico
                                        Unter der Annahme das es am js-controller liegt musst du den gleichen Trick nochmal machen mit downgrade.
                                        • wendy2702W Online
                                          wendy2702W Online
                                          @ludino:
                                          Iobroker neu installiert ohne update, dann smartmeter installiert, danach update auf admin 3.3.9 und js-controller 1.4.2 alles gut und Objekte weiterhin vorhanden inklusive sich änderten werte. `
                                          Welche Admin und JS-Controller Version hattest du da?
                                          Diese solltest du dann auch auf deinem Slave nutzen beim Adapter installieren und erst upgraden wenn die Objekte da sind.
                                          Oder besser erstmal auf den „alten“ Versionen bleiben bis der Fehler gefunden und gefixt ist.
