  4. [gelöst] Smartmeter im Multihost
    6.0k
81 Beiträge 7 Kommentatoren 9.6k Aufrufe
  • L Offline
    ludino
    Hier mal der Log von der neuinstallation.
    Ach ja strg f5 gemacht
    $ ./iobroker add smartmeter
    NPM version: 3.10.10
    npm install iobroker.smartmeter --production --save --prefix "/opt/iobroker" (System call)
    prebuild-install
    info begin Prebuild-install version 2.5.1
    prebuild-install info looking for local prebuild @ prebuilds/serialport-v6.1.1-node-v48-linux-arm.tar.gz
    prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
    gyp
    WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.14.1"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/smartmeter-obis/node_modules/serialport/.node-gyp"
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:../src/serialport.cpp:95:30: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    data->callback.Call(2, argv);
    In file included from ../src/./serialport.h:6:0,
    from ../src/serialport.cpp:1:
    ../../../../nan/nan.h:1618:3: note: declared here
    Call(int argc, v8::Local v8::valueargv[]) const {
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:../src/serialport.cpp:150:30: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:../src/serialport.cpp:188:30: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:../src/serialport.cpp:231:30: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:../src/serialport.cpp:285:30: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:../src/serialport.cpp:336:30: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:../src/serialport.cpp:383:30: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:../src/serialport.cpp:424:30: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:../src/poller.cpp:69:29: warning: ‘v8::Local v8::valueNan::Callback::Call(int, v8::Localv8::value*) const’ is deprecated [-Wdeprecated-declarations]
    obj->callback.Call(2, argv);
    In file included from ../src/poller.cpp:1:0:
    host.raspberrypi install adapter smartmeter
    got /opt/iobroker/node_modules/iobroker.smartmeter/admin
    upload [5] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/words.js words.js application/javascript
    upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
    upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
    upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
    upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
    upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
    host.raspberrypi object system.adapter.smartmeter created
    host.raspberrypi create instance smartmeter
    host.raspberrypi object system.adapter.smartmeter.0.outputCount created
    host.raspberrypi object system.adapter.smartmeter.0.inputCount created
    host.raspberrypi object system.adapter.smartmeter.0.uptime created
    host.raspberrypi object system.adapter.smartmeter.0.memRss created
    host.raspberrypi object system.adapter.smartmeter.0.memHeapTotal created
    host.raspberrypi object system.adapter.smartmeter.0.memHeapUsed created
    host.raspberrypi object system.adapter.smartmeter.0.connected created
    host.raspberrypi object system.adapter.smartmeter.0.alive created
    host.raspberrypi object system.adapter.smartmeter.0 created
    process exited with code 0</v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value>
    und hier der log vom debug
    <code>2018-04-13 19:34:38.437 - [32minfo[39m: iobroker host.raspberrypi install adapter smartmeter
    2018-04-13 19:34:38.463 - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.smartmeter/admin
    2018-04-13 19:34:38.491 - [32minfo[39m: iobroker upload [5] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/words.js words.js application/javascript
    2018-04-13 19:34:38.589 - [32minfo[39m: iobroker upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
    2018-04-13 19:34:38.650 - [32minfo[39m: iobroker upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
    2018-04-13 19:34:38.721 - [32minfo[39m: iobroker upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
    2018-04-13 19:34:38.821 - [32minfo[39m: iobroker upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
    2018-04-13 19:34:38.882 - [32minfo[39m: iobroker upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
    2018-04-13 19:34:38.995 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter created
    2018-04-13 19:34:39.031 - [32minfo[39m: iobroker host.raspberrypi create instance smartmeter
    2018-04-13 19:34:39.042 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0.outputCount created
    2018-04-13 19:34:39.072 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0.inputCount created
    2018-04-13 19:34:39.102 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0.uptime created
    2018-04-13 19:34:39.133 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0.memRss created
    2018-04-13 19:34:39.162 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0.memHeapTotal created
    2018-04-13 19:34:39.195 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0.memHeapUsed created
    2018-04-13 19:34:39.240 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0.connected created
    2018-04-13 19:34:39.281 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0.alive created
    2018-04-13 19:34:39.323 - [32minfo[39m: host.raspberrypi object change system.adapter.smartmeter.0
    2018-04-13 19:34:39.332 - [32minfo[39m: iobroker host.raspberrypi object system.adapter.smartmeter.0 created
    2018-04-13 19:34:39.358 - [32minfo[39m: iobroker exit 0
    2018-04-13 19:36:43.037 - [32minfo[39m: host.raspberrypi object change system.adapter.smartmeter.0
    2018-04-13 19:37:38.884 - [32minfo[39m: host.raspberrypi object change system.adapter.smartmeter.0
    2018-04-13 19:37:41.960 - [32minfo[39m: host.raspberrypi object change system.adapter.smartmeter.0
    2018-04-13 19:37:41.961 - [32minfo[39m: host.raspberrypi "system.adapter.smartmeter.0" enabled
    2018-04-13 19:37:42.021 - [32minfo[39m: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 2759
    2018-04-13 19:37:44.306 - [34mdebug[39m: smartmeter.0 objectDB connected
    2018-04-13 19:37:44.416 - [34mdebug[39m: smartmeter.0 statesDB connected
    2018-04-13 19:37:44.536 - [32minfo[39m: smartmeter.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.14.1
    2018-04-13 19:37:44.547 - [34mdebug[39m: smartmeter.0 SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"10","anotherQueryDelay":"1000","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":9600,"transportSerialDataBits":7,"transportSerialStopBits":1,"transportSerialParity":"even","transportSerialMessageTimeout":null,"protocolD0WakeupCharacters":0}
    2018-04-13 19:37:44.555 - [34mdebug[39m: smartmeter.0 CREATE SERIALPORT: 9600 7 1 even
    2018-04-13 19:37:44.583 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
    2018-04-13 19:37:44.598 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (0 + NEW 2)
    2018-04-13 19:37:44.603 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:37:44.604 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n" -> null
    2018-04-13 19:37:44.609 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:37:45.643 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (2 + NEW 12)
    2018-04-13 19:37:45.644 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:37:45.645 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA202" -> null
    2018-04-13 19:37:45.657 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (14 + NEW 14)
    2018-04-13 19:37:45.658 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:37:45.660 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.03\r\n\r\n1-0" -> ["/ESY5Q3DA2024 V3.03\r\n","/ESY5Q3DA2024 V3.03"]
    2018-04-13 19:37:45.661 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:37:45.665 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
    2018-04-13 19:37:45.670 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 5
    2018-04-13 19:37:45.672 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:37:45.673 - [34mdebug[39m: smartmeter.0 SerialResponseTransport do not support sending of Data! Ignore them
    2018-04-13 19:37:45.674 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:37:45.675 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:37:45.675 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:37:45.676 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING: 5
    2018-04-13 19:37:45.677 - [34mdebug[39m: smartmeter.0 MORE DATA AVAILABLE, PROCESS THEM 5
    2018-04-13 19:37:45.677 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN CHECKMESSAGE
    2018-04-13 19:37:45.679 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0" -> null
    2018-04-13 19:37:45.680 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (5 + NEW 16)
    2018-04-13 19:37:45.681 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.682 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(17930" -> null
    2018-04-13 19:37:45.728 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (21 + NEW 46)
    2018-04-13 19:37:45.730 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.731 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2" -> null
    2018-04-13 19:37:45.740 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (67 + NEW 16)
    2018-04-13 19:37:45.741 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.742 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(0005960" -> null
    2018-04-13 19:37:45.752 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (83 + NEW 14)
    2018-04-13 19:37:45.754 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.755 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)" -> null
    2018-04-13 19:37:45.768 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (97 + NEW 16)
    2018-04-13 19:37:45.769 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.770 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.2552" -> null
    2018-04-13 19:37:45.785 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (113 + NEW 16)
    2018-04-13 19:37:45.787 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.788 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r" -> null
    2018-04-13 19:37:45.800 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (129 + NEW 14)
    2018-04-13 19:37:45.801 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.802 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255" -> null
    2018-04-13 19:37:45.817 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (143 + NEW 16)
    2018-04-13 19:37:45.817 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.818 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)" -> null
    2018-04-13 19:37:45.833 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (159 + NEW 15)
    2018-04-13 19:37:45.833 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.834 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255*" -> null
    2018-04-13 19:37:45.857 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (174 + NEW 16)
    2018-04-13 19:37:45.858 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.860 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)" -> null
    2018-04-13 19:37:45.865 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (190 + NEW 15)
    2018-04-13 19:37:45.866 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.868 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)\r\n1-0:1.7.2552" -> null
    2018-04-13 19:37:45.882 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (205 + NEW 15)
    2018-04-13 19:37:45.883 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.885 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)\r\n1-0:1.7.255255(000176.04W)" -> null
    2018-04-13 19:37:45.897 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (220 + NEW 16)
    2018-04-13 19:37:45.898 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.899 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)\r\n1-0:1.7.255255(000176.04W)\r\n1-0:96.5.5255" -> null
    2018-04-13 19:37:45.912 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (236 + NEW 15)
    2018-04-13 19:37:45.913 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.915 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)\r\n1-0:1.7.255255(000176.04W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1." -> null
    2018-04-13 19:37:45.929 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (251 + NEW 15)
    2018-04-13 19:37:45.930 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.931 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)\r\n1-0:1.7.255255(000176.04W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY111" -> null
    2018-04-13 19:37:45.945 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (266 + NEW 13)
    2018-04-13 19:37:45.946 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:45.946 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)\r\n1-0:1.7.255255(000176.04W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n" -> ["1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)\r\n1-0:1.7.255255(000176.04W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n","1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0044124kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000124.82W)\r\n1-0:41.7.255255(000011.72W)\r\n1-0:61.7.255255(000039.50W)\r\n1-0:1.7.255255(000176.04W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n"]
    2018-04-13 19:37:45.947 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:37:45.947 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN HANDLEMESSAGE
    2018-04-13 19:37:45.960 - [34mdebug[39m: smartmeter.0 STORE DATA
    2018-04-13 19:37:45.966 - [34mdebug[39m: smartmeter.0 1-0:0.0.0255: Meter owner number = 179303
    2018-04-13 19:37:45.967 - [34mdebug[39m: smartmeter.0 Create Channel 1-0:0_0_0
    255 with name Meter owner number
    2018-04-13 19:37:45.969 - [34mdebug[39m: smartmeter.0 Create State 1-0:0_0_0255.rawvalue
    2018-04-13 19:37:45.971 - [34mdebug[39m: smartmeter.0 Create State 1-0:0_0_0
    255.value
    2018-04-13 19:37:45.972 - [34mdebug[39m: smartmeter.0 Set State 1-0:0_0_0255.rawvalue = 179303
    2018-04-13 19:37:45.974 - [34mdebug[39m: smartmeter.0 Set State 1-0:0_0_0
    255.value = 179303
    2018-04-13 19:37:45.976 - [34mdebug[39m: smartmeter.0 1-0:1.8.0255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 17097.0044124 kWh
    2018-04-13 19:37:45.977 - [34mdebug[39m: smartmeter.0 Create Channel 1-0:1_8_0
    255 with name Zählerstand 1 Summe Wirkarbeit Bezug + (Total)
    2018-04-13 19:37:45.978 - [34mdebug[39m: smartmeter.0 Create State 1-0:1_8_0255.rawvalue
    255.value
    2018-04-13 19:37:45.979 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.rawvalue = 00017097.0044124kWh
    2018-04-13 19:37:45.980 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.value = 17097.0044124
    2018-04-13 19:37:45.981 - [34mdebug[39m: smartmeter.0 1-0:2.8.0
    255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 59606.82 kWh
    2018-04-13 19:37:45.981 - [34mdebug[39m: smartmeter.0 Create Channel 1-0:2_8_0255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (Total)
    2018-04-13 19:37:45.981 - [34mdebug[39m: smartmeter.0 Create State 1-0:2_8_0
    255.rawvalue
    2018-04-13 19:37:45.982 - [34mdebug[39m: smartmeter.0 Create State 1-0:2_8_0255.value
    2018-04-13 19:37:45.982 - [34mdebug[39m: smartmeter.0 Set State 1-0:2_8_0
    255.rawvalue = 00059606.8200000kWh
    255.value = 59606.82
    2018-04-13 19:37:45.983 - [34mdebug[39m: smartmeter.0 1-0:21.7.255255: Momentanwert L1 Wirkarbeit Bezug + = 124.82 W
    2018-04-13 19:37:45.983 - [34mdebug[39m: smartmeter.0 Create Channel 1-0:21_7_255
    255 with name Momentanwert L1 Wirkarbeit Bezug +
    2018-04-13 19:37:45.984 - [34mdebug[39m: smartmeter.0 Create State 1-0:21_7_255255.rawvalue
    255.value
    2018-04-13 19:37:45.984 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255255.rawvalue = 000124.82W
    2018-04-13 19:37:45.985 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255255.value = 124.82
    2018-04-13 19:37:45.985 - [34mdebug[39m: smartmeter.0 1-0:41.7.255
    255: Momentanwert L2 Wirkarbeit Bezug + = 11.72 W
    2018-04-13 19:37:45.986 - [34mdebug[39m: smartmeter.0 Create Channel 1-0:41_7_255255 with name Momentanwert L2 Wirkarbeit Bezug +
    2018-04-13 19:37:45.986 - [34mdebug[39m: smartmeter.0 Create State 1-0:41_7_255
    255.rawvalue
    2018-04-13 19:37:45.986 - [34mdebug[39m: smartmeter.0 Create State 1-0:41_7_255255.value
    2018-04-13 19:37:45.987 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255
    255.rawvalue = 000011.72W
    255.value = 11.72
    2018-04-13 19:37:45.988 - [34mdebug[39m: smartmeter.0 1-0:61.7.255255: Momentanwert L3 Wirkarbeit Bezug + = 39.5 W
    2018-04-13 19:37:45.988 - [34mdebug[39m: smartmeter.0 Create Channel 1-0:61_7_255
    255 with name Momentanwert L3 Wirkarbeit Bezug +
    2018-04-13 19:37:45.988 - [34mdebug[39m: smartmeter.0 Create State 1-0:61_7_255255.rawvalue
    2018-04-13 19:37:45.989 - [34mdebug[39m: smartmeter.0 Create State 1-0:61_7_255
    255.value
    2018-04-13 19:37:45.989 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.rawvalue = 000039.50W
    2018-04-13 19:37:45.989 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.value = 39.5
    2018-04-13 19:37:45.990 - [34mdebug[39m: smartmeter.0 1-0:1.7.255
    255: Momentanwert Summe Wirkarbeit Bezug + = 176.04 W
    2018-04-13 19:37:45.990 - [34mdebug[39m: smartmeter.0 Create Channel 1-0:1_7_255255 with name Momentanwert Summe Wirkarbeit Bezug +
    2018-04-13 19:37:45.991 - [34mdebug[39m: smartmeter.0 Create State 1-0:1_7_255
    255.rawvalue
    2018-04-13 19:37:45.991 - [34mdebug[39m: smartmeter.0 Create State 1-0:1_7_255255.value
    2018-04-13 19:37:45.991 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255
    255.rawvalue = 000176.04W
    2018-04-13 19:37:45.992 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255
    255.value = 176.04
    2018-04-13 19:37:45.992 - [34mdebug[39m: smartmeter.0 1-0:96.5.5255: Status = 82
    2018-04-13 19:37:45.993 - [34mdebug[39m: smartmeter.0 Create Channel 1-0:96_5_5
    255 with name Status
    2018-04-13 19:37:45.997 - [34mdebug[39m: smartmeter.0 Create State 1-0:96_5_5255.rawvalue
    2018-04-13 19:37:45.998 - [34mdebug[39m: smartmeter.0 Create State 1-0:96_5_5
    255.value
    2018-04-13 19:37:45.999 - [34mdebug[39m: smartmeter.0 Set State 1-0:96_5_5255.rawvalue = 82
    255.value = 82
    2018-04-13 19:37:46.000 - [34mdebug[39m: smartmeter.0 0-0:96.1.255255: Factory number = 1ESY1115000303
    2018-04-13 19:37:46.002 - [34mdebug[39m: smartmeter.0 Create Channel 0-0:96_1_255
    255 with name Factory number
    2018-04-13 19:37:46.006 - [34mdebug[39m: smartmeter.0 Create State 0-0:96_1_255255.rawvalue
    255.value
    2018-04-13 19:37:46.011 - [34mdebug[39m: smartmeter.0 Set State 0-0:96_1_255255.rawvalue = 1ESY1115000303
    2018-04-13 19:37:46.016 - [34mdebug[39m: smartmeter.0 Set State 0-0:96_1_255
    255.value = 1ESY1115000303
    2018-04-13 19:37:46.018 - [32minfo[39m: smartmeter.0 Received 9 values, 9 updated
    2018-04-13 19:37:46.020 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 1
    2018-04-13 19:37:46.020 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:37:46.021 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:37:46.022 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:37:46.022 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:37:46.023 - [34mdebug[39m: smartmeter.0 DELETE rest of data (1)
    2018-04-13 19:37:46.025 - [34mdebug[39m: smartmeter.0 SCHEDULE NEXT RUN IN 10s
    2018-04-13 19:37:46.046 - [34mdebug[39m: smartmeter.0 SERIALPORT CLOSE
    2018-04-13 19:37:56.040 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
    2018-04-13 19:37:56.044 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:37:56.058 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (0 + NEW 2)
    2018-04-13 19:37:56.059 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:37:56.060 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n" -> null
    2018-04-13 19:37:57.660 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (2 + NEW 12)
    2018-04-13 19:37:57.660 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:37:57.661 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA202" -> null
    2018-04-13 19:37:57.670 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (14 + NEW 16)
    2018-04-13 19:37:57.671 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:37:57.672 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.03\r\n\r\n1-0:0" -> ["/ESY5Q3DA2024 V3.03\r\n","/ESY5Q3DA2024 V3.03"]
    2018-04-13 19:37:57.673 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:37:57.676 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
    2018-04-13 19:37:57.678 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 7
    2018-04-13 19:37:57.680 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:37:57.681 - [34mdebug[39m: smartmeter.0 SerialResponseTransport do not support sending of Data! Ignore them
    2018-04-13 19:37:57.682 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:37:57.682 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:37:57.683 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:37:57.684 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING: 7
    2018-04-13 19:37:57.684 - [34mdebug[39m: smartmeter.0 MORE DATA AVAILABLE, PROCESS THEM 7
    2018-04-13 19:37:57.685 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN CHECKMESSAGE
    2018-04-13 19:37:57.685 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0" -> null
    2018-04-13 19:37:57.687 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (7 + NEW 14)
    2018-04-13 19:37:57.688 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.688 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(17930" -> null
    2018-04-13 19:37:57.718 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (21 + NEW 16)
    2018-04-13 19:37:57.719 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.719 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.025" -> null
    2018-04-13 19:37:57.721 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (37 + NEW 15)
    2018-04-13 19:37:57.723 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.724 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049" -> null
    2018-04-13 19:37:57.736 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (52 + NEW 15)
    2018-04-13 19:37:57.737 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.738 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2" -> null
    2018-04-13 19:37:57.752 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (67 + NEW 16)
    2018-04-13 19:37:57.754 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.755 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(0005960" -> null
    2018-04-13 19:37:57.766 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (83 + NEW 15)
    2018-04-13 19:37:57.766 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.767 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r" -> null
    2018-04-13 19:37:57.781 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (98 + NEW 15)
    2018-04-13 19:37:57.782 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.784 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.2552" -> null
    2018-04-13 19:37:57.797 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (113 + NEW 16)
    2018-04-13 19:37:57.798 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.799 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r" -> null
    2018-04-13 19:37:57.816 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (129 + NEW 15)
    2018-04-13 19:37:57.817 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.817 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.2552" -> null
    2018-04-13 19:37:57.828 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (144 + NEW 15)
    2018-04-13 19:37:57.829 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.830 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)" -> null
    2018-04-13 19:37:57.845 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (159 + NEW 16)
    2018-04-13 19:37:57.845 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.846 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.2552" -> null
    2018-04-13 19:37:57.861 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (175 + NEW 15)
    2018-04-13 19:37:57.862 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.862 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)" -> null
    2018-04-13 19:37:57.876 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (190 + NEW 15)
    2018-04-13 19:37:57.876 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.877 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)\r\n1-0:1.7.2552" -> null
    2018-04-13 19:37:57.892 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (205 + NEW 15)
    2018-04-13 19:37:57.893 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.893 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)\r\n1-0:1.7.255255(000174.86W)" -> null
    2018-04-13 19:37:57.909 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (220 + NEW 16)
    2018-04-13 19:37:57.909 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.910 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)\r\n1-0:1.7.255255(000174.86W)\r\n1-0:96.5.5255" -> null
    2018-04-13 19:37:57.925 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (236 + NEW 16)
    2018-04-13 19:37:57.926 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.926 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)\r\n1-0:1.7.255255(000174.86W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.2" -> null
    2018-04-13 19:37:57.941 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (252 + NEW 14)
    2018-04-13 19:37:57.941 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.942 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)\r\n1-0:1.7.255255(000174.86W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY111" -> null
    2018-04-13 19:37:57.964 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (266 + NEW 13)
    2018-04-13 19:37:57.964 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:37:57.964 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)\r\n1-0:1.7.255255(000174.86W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n" -> ["1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)\r\n1-0:1.7.255255(000174.86W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n","1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0049985kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.66W)\r\n1-0:41.7.255255(000011.73W)\r\n1-0:61.7.255255(000037.47W)\r\n1-0:1.7.255255(000174.86W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n"]
    2018-04-13 19:37:57.967 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:37:57.967 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN HANDLEMESSAGE
    2018-04-13 19:37:57.969 - [34mdebug[39m: smartmeter.0 STORE DATA
    2018-04-13 19:37:57.969 - [34mdebug[39m: smartmeter.0 1-0:0.0.0
    2018-04-13 19:37:57.970 - [34mdebug[39m: smartmeter.0 Data for 1-0:0_0_0255 unchanged
    2018-04-13 19:37:57.971 - [34mdebug[39m: smartmeter.0 1-0:1.8.0
    255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 17097.0049985 kWh
    2018-04-13 19:37:57.971 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.rawvalue = 00017097.0049985kWh
    2018-04-13 19:37:57.972 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.value = 17097.0049985
    2018-04-13 19:37:57.973 - [34mdebug[39m: smartmeter.0 1-0:2.8.0
    2018-04-13 19:37:57.973 - [34mdebug[39m: smartmeter.0 Data for 1-0:2_8_0255 unchanged
    2018-04-13 19:37:57.974 - [34mdebug[39m: smartmeter.0 1-0:21.7.255
    255: Momentanwert L1 Wirkarbeit Bezug + = 125.66 W
    2018-04-13 19:37:57.974 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255255.rawvalue = 000125.66W
    2018-04-13 19:37:57.975 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255255.value = 125.66
    2018-04-13 19:37:57.976 - [34mdebug[39m: smartmeter.0 1-0:41.7.255
    255: Momentanwert L2 Wirkarbeit Bezug + = 11.73 W
    2018-04-13 19:37:57.976 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255255.rawvalue = 000011.73W
    2018-04-13 19:37:57.977 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255255.value = 11.73
    2018-04-13 19:37:57.977 - [34mdebug[39m: smartmeter.0 1-0:61.7.255
    255: Momentanwert L3 Wirkarbeit Bezug + = 37.47 W
    2018-04-13 19:37:57.978 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.rawvalue = 000037.47W
    2018-04-13 19:37:57.978 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.value = 37.47
    2018-04-13 19:37:57.978 - [34mdebug[39m: smartmeter.0 1-0:1.7.255
    255: Momentanwert Summe Wirkarbeit Bezug + = 174.86 W
    2018-04-13 19:37:57.979 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255255.rawvalue = 000174.86W
    2018-04-13 19:37:57.979 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255255.value = 174.86
    2018-04-13 19:37:57.980 - [34mdebug[39m: smartmeter.0 1-0:96.5.5
    255: Status = 82
    2018-04-13 19:37:57.980 - [34mdebug[39m: smartmeter.0 Data for 1-0:96_5_5255 unchanged
    2018-04-13 19:37:57.980 - [34mdebug[39m: smartmeter.0 0-0:96.1.255
    2018-04-13 19:37:57.980 - [34mdebug[39m: smartmeter.0 Data for 0-0:96_1_255255 unchanged
    2018-04-13 19:37:57.981 - [32minfo[39m: smartmeter.0 Received 9 values, 5 updated
    2018-04-13 19:37:57.981 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 1
    2018-04-13 19:37:57.981 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:37:57.981 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:37:57.983 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:37:57.983 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:37:57.984 - [34mdebug[39m: smartmeter.0 DELETE rest of data (1)
    2018-04-13 19:37:57.985 - [34mdebug[39m: smartmeter.0 SCHEDULE NEXT RUN IN 10s
    2018-04-13 19:37:57.990 - [34mdebug[39m: smartmeter.0 SERIALPORT CLOSE
    2018-04-13 19:38:07.997 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
    2018-04-13 19:38:08.001 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:08.012 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (0 + NEW 2)
    2018-04-13 19:38:08.013 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:08.014 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n" -> null
    2018-04-13 19:38:09.658 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (2 + NEW 5)
    2018-04-13 19:38:09.659 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:09.660 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5" -> null
    2018-04-13 19:38:09.675 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (7 + NEW 15)
    2018-04-13 19:38:09.678 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:09.679 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.03\r" -> null
    2018-04-13 19:38:09.690 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (22 + NEW 15)
    2018-04-13 19:38:09.691 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:09.693 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.03\r\n\r\n1-0:0.0.0
    25" -> ["/ESY5Q3DA2024 V3.03\r\n","/ESY5Q3DA2024 V3.03"]
    2018-04-13 19:38:09.694 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:38:09.695 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
    2018-04-13 19:38:09.696 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 14
    2018-04-13 19:38:09.697 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:38:09.698 - [34mdebug[39m: smartmeter.0 SerialResponseTransport do not support sending of Data! Ignore them
    2018-04-13 19:38:09.698 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:09.699 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:38:09.699 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:38:09.699 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING: 14
    2018-04-13 19:38:09.700 - [34mdebug[39m: smartmeter.0 MORE DATA AVAILABLE, PROCESS THEM 14
    2018-04-13 19:38:09.700 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN CHECKMESSAGE
    2018-04-13 19:38:09.701 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.025" -> null
    2018-04-13 19:38:09.719 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (14 + NEW 15)
    2018-04-13 19:38:09.720 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.720 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:" -> null
    2018-04-13 19:38:09.729 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (29 + NEW 16)
    2018-04-13 19:38:09.730 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.731 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(000170" -> null
    2018-04-13 19:38:09.744 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (45 + NEW 16)
    2018-04-13 19:38:09.746 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.747 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r" -> null
    2018-04-13 19:38:09.759 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (61 + NEW 14)
    2018-04-13 19:38:09.760 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.761 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255" -> null
    2018-04-13 19:38:09.775 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (75 + NEW 16)
    2018-04-13 19:38:09.776 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.777 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.820000" -> null
    2018-04-13 19:38:09.787 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (91 + NEW 16)
    2018-04-13 19:38:09.788 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.789 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7" -> null
    2018-04-13 19:38:09.802 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (107 + NEW 14)
    2018-04-13 19:38:09.802 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.803 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(00012" -> null
    2018-04-13 19:38:09.818 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (121 + NEW 16)
    2018-04-13 19:38:09.818 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.820 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41." -> null
    2018-04-13 19:38:09.834 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (137 + NEW 16)
    2018-04-13 19:38:09.835 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.835 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011" -> null
    2018-04-13 19:38:09.849 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (153 + NEW 14)
    2018-04-13 19:38:09.850 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.850 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61" -> null
    2018-04-13 19:38:09.868 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (167 + NEW 16)
    2018-04-13 19:38:09.868 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.869 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(00003" -> null
    2018-04-13 19:38:09.883 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (183 + NEW 16)
    2018-04-13 19:38:09.884 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.885 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7" -> null
    2018-04-13 19:38:09.897 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (199 + NEW 14)
    2018-04-13 19:38:09.898 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.898 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7.255255(00017" -> null
    2018-04-13 19:38:09.914 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (213 + NEW 16)
    2018-04-13 19:38:09.915 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.916 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7.255255(000176.39W)\r\n1-0:96." -> null
    2018-04-13 19:38:09.930 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (229 + NEW 16)
    2018-04-13 19:38:09.931 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.931 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7.255255(000176.39W)\r\n1-0:96.5.5255(82)\r\n0-0" -> null
    2018-04-13 19:38:09.946 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (245 + NEW 14)
    2018-04-13 19:38:09.946 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.947 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7.255255(000176.39W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(" -> null
    2018-04-13 19:38:09.962 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (259 + NEW 16)
    2018-04-13 19:38:09.962 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.963 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7.255255(000176.39W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r" -> null
    2018-04-13 19:38:09.978 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (275 + NEW 4)
    2018-04-13 19:38:09.978 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:09.979 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7.255255(000176.39W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n" -> ["1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7.255255(000176.39W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n","1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0055873kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.82W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000039.11W)\r\n1-0:1.7.255255(000176.39W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n"]
    2018-04-13 19:38:09.979 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:38:09.979 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN HANDLEMESSAGE
    2018-04-13 19:38:09.980 - [34mdebug[39m: smartmeter.0 STORE DATA
    2018-04-13 19:38:09.980 - [34mdebug[39m: smartmeter.0 1-0:0.0.0
    2018-04-13 19:38:09.981 - [34mdebug[39m: smartmeter.0 Data for 1-0:0_0_0255 unchanged
    2018-04-13 19:38:09.981 - [34mdebug[39m: smartmeter.0 1-0:1.8.0
    255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 17097.0055873 kWh
    2018-04-13 19:38:09.981 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.rawvalue = 00017097.0055873kWh
    2018-04-13 19:38:09.982 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.value = 17097.0055873
    2018-04-13 19:38:09.983 - [34mdebug[39m: smartmeter.0 1-0:2.8.0
    2018-04-13 19:38:09.983 - [34mdebug[39m: smartmeter.0 Data for 1-0:2_8_0255 unchanged
    2018-04-13 19:38:09.984 - [34mdebug[39m: smartmeter.0 1-0:21.7.255
    255: Momentanwert L1 Wirkarbeit Bezug + = 125.82 W
    2018-04-13 19:38:09.984 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255255.rawvalue = 000125.82W
    2018-04-13 19:38:09.984 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255255.value = 125.82
    2018-04-13 19:38:09.985 - [34mdebug[39m: smartmeter.0 1-0:41.7.255
    255: Momentanwert L2 Wirkarbeit Bezug + = 11.46 W
    2018-04-13 19:38:09.985 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255255.rawvalue = 000011.46W
    2018-04-13 19:38:09.986 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255255.value = 11.46
    2018-04-13 19:38:09.986 - [34mdebug[39m: smartmeter.0 1-0:61.7.255
    255: Momentanwert L3 Wirkarbeit Bezug + = 39.11 W
    2018-04-13 19:38:09.986 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.rawvalue = 000039.11W
    2018-04-13 19:38:09.987 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.value = 39.11
    2018-04-13 19:38:09.987 - [34mdebug[39m: smartmeter.0 1-0:1.7.255
    255: Momentanwert Summe Wirkarbeit Bezug + = 176.39 W
    2018-04-13 19:38:09.987 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255255.rawvalue = 000176.39W
    2018-04-13 19:38:09.988 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255255.value = 176.39
    2018-04-13 19:38:09.988 - [34mdebug[39m: smartmeter.0 1-0:96.5.5
    255: Status = 82
    2018-04-13 19:38:09.988 - [34mdebug[39m: smartmeter.0 Data for 1-0:96_5_5255 unchanged
    2018-04-13 19:38:09.988 - [34mdebug[39m: smartmeter.0 0-0:96.1.255
    2018-04-13 19:38:09.989 - [34mdebug[39m: smartmeter.0 Data for 0-0:96_1_255255 unchanged
    2018-04-13 19:38:09.989 - [32minfo[39m: smartmeter.0 Received 9 values, 5 updated
    2018-04-13 19:38:09.989 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 1
    2018-04-13 19:38:09.990 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:38:09.990 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:09.990 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:38:09.991 - [34mdebug[39m: smartmeter.0 DELETE rest of data (1)
    2018-04-13 19:38:09.992 - [34mdebug[39m: smartmeter.0 SCHEDULE NEXT RUN IN 10s
    2018-04-13 19:38:09.996 - [34mdebug[39m: smartmeter.0 SERIALPORT CLOSE
    2018-04-13 19:38:14.294 - [34mdebug[39m: smartmeter.0 system.adapter.admin.0: logging false
    2018-04-13 19:38:15.434 - [34mdebug[39m: smartmeter.0 system.adapter.admin.0: logging true
    2018-04-13 19:38:20.006 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
    2018-04-13 19:38:20.011 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:20.026 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (0 + NEW 2)
    2018-04-13 19:38:20.027 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:20.028 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n" -> null
    2018-04-13 19:38:21.667 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (2 + NEW 3)
    2018-04-13 19:38:21.668 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:21.669 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ES" -> null
    2018-04-13 19:38:21.684 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (5 + NEW 15)
    2018-04-13 19:38:21.686 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:21.686 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.0" -> null
    2018-04-13 19:38:21.699 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (20 + NEW 15)
    2018-04-13 19:38:21.700 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:21.701 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.03\r\n\r\n1-0:0.0.0
    2018-04-13 19:38:21.702 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:38:21.703 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
    2018-04-13 19:38:21.705 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 12
    2018-04-13 19:38:21.705 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:38:21.706 - [34mdebug[39m: smartmeter.0 SerialResponseTransport do not support sending of Data! Ignore them
    2018-04-13 19:38:21.707 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:21.708 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:38:21.709 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:38:21.728 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING: 12
    2018-04-13 19:38:21.741 - [34mdebug[39m: smartmeter.0 MORE DATA AVAILABLE, PROCESS THEM 12
    2018-04-13 19:38:21.742 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN CHECKMESSAGE
    2018-04-13 19:38:21.742 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0*" -> null
    2018-04-13 19:38:21.744 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (12 + NEW 31)
    2018-04-13 19:38:21.745 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.745 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(0001" -> null
    2018-04-13 19:38:21.779 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (43 + NEW 46)
    2018-04-13 19:38:21.780 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.781 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200" -> null
    2018-04-13 19:38:21.812 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (89 + NEW 31)
    2018-04-13 19:38:21.812 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.813 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(0001" -> null
    2018-04-13 19:38:21.827 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (120 + NEW 15)
    2018-04-13 19:38:21.827 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.828 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:4" -> null
    2018-04-13 19:38:21.843 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (135 + NEW 16)
    2018-04-13 19:38:21.844 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.844 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(0000" -> null
    2018-04-13 19:38:21.858 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (151 + NEW 14)
    2018-04-13 19:38:21.859 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.859 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:" -> null
    2018-04-13 19:38:21.875 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (165 + NEW 16)
    2018-04-13 19:38:21.875 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.876 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000" -> null
    2018-04-13 19:38:21.891 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (181 + NEW 16)
    2018-04-13 19:38:21.892 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.892 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1" -> null
    2018-04-13 19:38:21.906 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (197 + NEW 14)
    2018-04-13 19:38:21.907 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.907 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1.7.255255(000" -> null
    2018-04-13 19:38:21.923 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (211 + NEW 16)
    2018-04-13 19:38:21.923 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.924 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1.7.255255(000176.92W)\r\n1-0:9" -> null
    2018-04-13 19:38:21.939 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (227 + NEW 16)
    2018-04-13 19:38:21.939 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.940 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1.7.255255(000176.92W)\r\n1-0:96.5.5255(82)\r\n0" -> null
    2018-04-13 19:38:21.954 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (243 + NEW 14)
    2018-04-13 19:38:21.955 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.955 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1.7.255255(000176.92W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.25525" -> null
    2018-04-13 19:38:21.971 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (257 + NEW 16)
    2018-04-13 19:38:21.971 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.972 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1.7.255255(000176.92W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303" -> null
    2018-04-13 19:38:21.987 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (273 + NEW 6)
    2018-04-13 19:38:21.987 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:21.988 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1.7.255255(000176.92W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n" -> ["1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1.7.255255(000176.92W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n","1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0061828kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.59W)\r\n1-0:61.7.255255(000039.74W)\r\n1-0:1.7.255255(000176.92W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n"]
    2018-04-13 19:38:21.988 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:38:21.988 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN HANDLEMESSAGE
    2018-04-13 19:38:21.990 - [34mdebug[39m: smartmeter.0 STORE DATA
    2018-04-13 19:38:21.991 - [34mdebug[39m: smartmeter.0 1-0:0.0.0
    2018-04-13 19:38:21.991 - [34mdebug[39m: smartmeter.0 Data for 1-0:0_0_0255 unchanged
    2018-04-13 19:38:21.992 - [34mdebug[39m: smartmeter.0 1-0:1.8.0
    255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 17097.0061828 kWh
    2018-04-13 19:38:21.992 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.rawvalue = 00017097.0061828kWh
    2018-04-13 19:38:21.993 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.value = 17097.0061828
    2018-04-13 19:38:21.993 - [34mdebug[39m: smartmeter.0 1-0:2.8.0
    2018-04-13 19:38:21.994 - [34mdebug[39m: smartmeter.0 Data for 1-0:2_8_0255 unchanged
    2018-04-13 19:38:21.994 - [34mdebug[39m: smartmeter.0 1-0:21.7.255
    255: Momentanwert L1 Wirkarbeit Bezug + = 125.59 W
    2018-04-13 19:38:21.994 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255255.rawvalue = 000125.59W
    2018-04-13 19:38:21.995 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255255.value = 125.59
    2018-04-13 19:38:21.995 - [34mdebug[39m: smartmeter.0 1-0:41.7.255
    255: Momentanwert L2 Wirkarbeit Bezug + = 11.59 W
    2018-04-13 19:38:21.995 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255255.rawvalue = 000011.59W
    2018-04-13 19:38:21.995 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255255.value = 11.59
    2018-04-13 19:38:21.996 - [34mdebug[39m: smartmeter.0 1-0:61.7.255
    255: Momentanwert L3 Wirkarbeit Bezug + = 39.74 W
    2018-04-13 19:38:21.996 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.rawvalue = 000039.74W
    2018-04-13 19:38:21.996 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.value = 39.74
    2018-04-13 19:38:21.997 - [34mdebug[39m: smartmeter.0 1-0:1.7.255
    255: Momentanwert Summe Wirkarbeit Bezug + = 176.92 W
    2018-04-13 19:38:21.997 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255255.rawvalue = 000176.92W
    2018-04-13 19:38:21.997 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255255.value = 176.92
    2018-04-13 19:38:21.998 - [34mdebug[39m: smartmeter.0 1-0:96.5.5
    255: Status = 82
    2018-04-13 19:38:21.998 - [34mdebug[39m: smartmeter.0 Data for 1-0:96_5_5255 unchanged
    2018-04-13 19:38:21.998 - [34mdebug[39m: smartmeter.0 0-0:96.1.255
    2018-04-13 19:38:21.998 - [34mdebug[39m: smartmeter.0 Data for 0-0:96_1_255255 unchanged
    2018-04-13 19:38:21.999 - [32minfo[39m: smartmeter.0 Received 9 values, 5 updated
    2018-04-13 19:38:21.999 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 1
    2018-04-13 19:38:21.999 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:38:21.999 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:22.000 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:38:22.000 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:38:22.000 - [34mdebug[39m: smartmeter.0 DELETE rest of data (1)
    2018-04-13 19:38:22.000 - [34mdebug[39m: smartmeter.0 SCHEDULE NEXT RUN IN 10s
    2018-04-13 19:38:22.004 - [34mdebug[39m: smartmeter.0 SERIALPORT CLOSE
    2018-04-13 19:38:32.006 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
    2018-04-13 19:38:32.009 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:32.021 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (0 + NEW 2)
    2018-04-13 19:38:32.022 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:32.023 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n" -> null
    2018-04-13 19:38:33.682 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (2 + NEW 5)
    2018-04-13 19:38:33.683 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:33.684 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5" -> null
    2018-04-13 19:38:33.700 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (7 + NEW 15)
    2018-04-13 19:38:33.700 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:33.701 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.03\r" -> null
    2018-04-13 19:38:33.715 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (22 + NEW 15)
    2018-04-13 19:38:33.716 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:33.717 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.03\r\n\r\n1-0:0.0.0
    2018-04-13 19:38:33.718 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:38:33.718 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
    2018-04-13 19:38:33.720 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 14
    2018-04-13 19:38:33.720 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:38:33.720 - [34mdebug[39m: smartmeter.0 SerialResponseTransport do not support sending of Data! Ignore them
    2018-04-13 19:38:33.721 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:33.726 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:38:33.726 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:38:33.727 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING: 14
    2018-04-13 19:38:33.727 - [34mdebug[39m: smartmeter.0 MORE DATA AVAILABLE, PROCESS THEM 14
    2018-04-13 19:38:33.728 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN CHECKMESSAGE
    2018-04-13 19:38:33.728 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.025" -> null
    2018-04-13 19:38:33.746 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (14 + NEW 15)
    2018-04-13 19:38:33.747 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.747 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    2018-04-13 19:38:33.749 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (29 + NEW 16)
    2018-04-13 19:38:33.750 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.751 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(000170" -> null
    2018-04-13 19:38:33.768 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (45 + NEW 15)
    2018-04-13 19:38:33.769 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.770 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)" -> null
    2018-04-13 19:38:33.785 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (60 + NEW 15)
    2018-04-13 19:38:33.786 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.787 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255" -> null
    2018-04-13 19:38:33.794 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (75 + NEW 15)
    2018-04-13 19:38:33.795 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.795 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.82000" -> null
    2018-04-13 19:38:33.813 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (90 + NEW 16)
    2018-04-13 19:38:33.814 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.814 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21." -> null
    2018-04-13 19:38:33.827 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (106 + NEW 16)
    2018-04-13 19:38:33.828 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.828 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125" -> null
    2018-04-13 19:38:33.842 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (122 + NEW 14)
    2018-04-13 19:38:33.842 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.843 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41" -> null
    2018-04-13 19:38:33.861 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (136 + NEW 16)
    2018-04-13 19:38:33.861 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.862 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(00001" -> null
    2018-04-13 19:38:33.875 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (152 + NEW 16)
    2018-04-13 19:38:33.875 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.876 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61." -> null
    2018-04-13 19:38:33.890 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (168 + NEW 14)
    2018-04-13 19:38:33.890 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.891 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(0000" -> null
    2018-04-13 19:38:33.906 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (182 + NEW 16)
    2018-04-13 19:38:33.907 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.907 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1." -> null
    2018-04-13 19:38:33.923 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (198 + NEW 16)
    2018-04-13 19:38:33.923 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.924 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1.7.255255(000180" -> null
    2018-04-13 19:38:33.938 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (214 + NEW 14)
    2018-04-13 19:38:33.938 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.939 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1.7.255255(000180.90W)\r\n1-0:96" -> null
    2018-04-13 19:38:33.954 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (228 + NEW 16)
    2018-04-13 19:38:33.954 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.955 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1.7.255255(000180.90W)\r\n1-0:96.5.5255(82)\r\n0-" -> null
    2018-04-13 19:38:33.970 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (244 + NEW 16)
    2018-04-13 19:38:33.971 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.971 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1.7.255255(000180.90W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1" -> null
    2018-04-13 19:38:33.986 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (260 + NEW 14)
    2018-04-13 19:38:33.986 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:33.987 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1.7.255255(000180.90W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)" -> null
    2018-04-13 19:38:34.002 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (274 + NEW 5)
    2018-04-13 19:38:34.002 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:34.003 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1.7.255255(000180.90W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n" -> ["1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1.7.255255(000180.90W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n","1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0067888kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.59W)\r\n1-0:41.7.255255(000011.46W)\r\n1-0:61.7.255255(000043.85W)\r\n1-0:1.7.255255(000180.90W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n"]
    2018-04-13 19:38:34.003 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:38:34.003 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN HANDLEMESSAGE
    2018-04-13 19:38:34.004 - [34mdebug[39m: smartmeter.0 STORE DATA
    2018-04-13 19:38:34.005 - [34mdebug[39m: smartmeter.0 1-0:0.0.0
    2018-04-13 19:38:34.005 - [34mdebug[39m: smartmeter.0 Data for 1-0:0_0_0255 unchanged
    2018-04-13 19:38:34.005 - [34mdebug[39m: smartmeter.0 1-0:1.8.0
    255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 17097.0067888 kWh
    2018-04-13 19:38:34.005 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.rawvalue = 00017097.0067888kWh
    2018-04-13 19:38:34.007 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0255.value = 17097.0067888
    2018-04-13 19:38:34.007 - [34mdebug[39m: smartmeter.0 1-0:2.8.0
    2018-04-13 19:38:34.008 - [34mdebug[39m: smartmeter.0 Data for 1-0:2_8_0255 unchanged
    2018-04-13 19:38:34.008 - [34mdebug[39m: smartmeter.0 1-0:21.7.255
    2018-04-13 19:38:34.008 - [34mdebug[39m: smartmeter.0 Data for 1-0:21_7_255255 unchanged
    2018-04-13 19:38:34.010 - [34mdebug[39m: smartmeter.0 1-0:41.7.255
    2018-04-13 19:38:34.010 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255255.rawvalue = 000011.46W
    2018-04-13 19:38:34.012 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255255.value = 11.46
    2018-04-13 19:38:34.012 - [34mdebug[39m: smartmeter.0 1-0:61.7.255
    255: Momentanwert L3 Wirkarbeit Bezug + = 43.85 W
    2018-04-13 19:38:34.012 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.rawvalue = 000043.85W
    2018-04-13 19:38:34.013 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255255.value = 43.85
    2018-04-13 19:38:34.013 - [34mdebug[39m: smartmeter.0 1-0:1.7.255
    255: Momentanwert Summe Wirkarbeit Bezug + = 180.9 W
    2018-04-13 19:38:34.013 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255255.rawvalue = 000180.90W
    2018-04-13 19:38:34.013 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255255.value = 180.9
    2018-04-13 19:38:34.014 - [34mdebug[39m: smartmeter.0 1-0:96.5.5
    255: Status = 82
    2018-04-13 19:38:34.014 - [34mdebug[39m: smartmeter.0 Data for 1-0:96_5_5255 unchanged
    2018-04-13 19:38:34.014 - [34mdebug[39m: smartmeter.0 0-0:96.1.255
    2018-04-13 19:38:34.015 - [34mdebug[39m: smartmeter.0 Data for 0-0:96_1_255255 unchanged
    2018-04-13 19:38:34.015 - [32minfo[39m: smartmeter.0 Received 9 values, 4 updated
    2018-04-13 19:38:34.015 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 1
    2018-04-13 19:38:34.015 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:38:34.016 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:34.016 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:38:34.016 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 10 IN ISPROCESSCOMPLETE: true
    2018-04-13 19:38:34.016 - [34mdebug[39m: smartmeter.0 DELETE rest of data (1)
    2018-04-13 19:38:34.017 - [34mdebug[39m: smartmeter.0 SCHEDULE NEXT RUN IN 10s
    2018-04-13 19:38:34.020 - [34mdebug[39m: smartmeter.0 SERIALPORT CLOSE
    2018-04-13 19:38:44.025 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
    2018-04-13 19:38:44.027 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:44.040 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (0 + NEW 2)
    2018-04-13 19:38:44.040 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:44.040 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n" -> null
    2018-04-13 19:38:45.701 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (2 + NEW 13)
    2018-04-13 19:38:45.702 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:45.703 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024" -> null
    2018-04-13 19:38:45.718 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (15 + NEW 16)
    2018-04-13 19:38:45.719 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN CHECKMESSAGE
    2018-04-13 19:38:45.720 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA2024 V3.03\r\n\r\n1-0:0." -> ["/ESY5Q3DA2024 V3.03\r\n","/ESY5Q3DA2024 V3.03"]
    2018-04-13 19:38:45.720 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:38:45.721 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
    2018-04-13 19:38:45.723 - [34mdebug[39m: smartmeter.0 LEFT AFTER HANDLE-MESSAGE 8
    2018-04-13 19:38:45.723 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:38:45.724 - [34mdebug[39m: smartmeter.0 SerialResponseTransport do not support sending of Data! Ignore them
    2018-04-13 19:38:45.725 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 120000
    2018-04-13 19:38:45.726 - [34mdebug[39m: smartmeter.0 RESUME READING SERIALPORT
    2018-04-13 19:38:45.726 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
    2018-04-13 19:38:45.726 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING: 8
    2018-04-13 19:38:45.727 - [34mdebug[39m: smartmeter.0 MORE DATA AVAILABLE, PROCESS THEM 8
    2018-04-13 19:38:45.727 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN CHECKMESSAGE
    2018-04-13 19:38:45.728 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0." -> null
    2018-04-13 19:38:45.745 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (8 + NEW 14)
    2018-04-13 19:38:45.746 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.748 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303" -> null
    2018-04-13 19:38:45.750 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (22 + NEW 16)
    2018-04-13 19:38:45.751 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.752 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255" -> null
    2018-04-13 19:38:45.766 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (38 + NEW 15)
    2018-04-13 19:38:45.768 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.769 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.00738" -> null
    2018-04-13 19:38:45.782 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (53 + NEW 15)
    2018-04-13 19:38:45.783 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.784 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2." -> null
    2018-04-13 19:38:45.822 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (68 + NEW 31)
    2018-04-13 19:38:45.823 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.823 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n" -> null
    2018-04-13 19:38:45.829 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (99 + NEW 15)
    2018-04-13 19:38:45.830 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.830 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.25525" -> null
    2018-04-13 19:38:45.845 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (114 + NEW 16)
    2018-04-13 19:38:45.845 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.846 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n" -> null
    2018-04-13 19:38:45.861 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (130 + NEW 15)
    2018-04-13 19:38:45.862 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.862 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.25525" -> null
    2018-04-13 19:38:45.876 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (145 + NEW 15)
    2018-04-13 19:38:45.877 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.877 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r" -> null
    2018-04-13 19:38:45.893 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (160 + NEW 16)
    2018-04-13 19:38:45.894 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.894 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.25525" -> null
    2018-04-13 19:38:45.909 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (176 + NEW 15)
    2018-04-13 19:38:45.910 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.910 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r" -> null
    2018-04-13 19:38:45.925 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (191 + NEW 16)
    2018-04-13 19:38:45.926 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.926 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r\n1-0:1.7.255255" -> null
    2018-04-13 19:38:45.940 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (207 + NEW 14)
    2018-04-13 19:38:45.941 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.942 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r\n1-0:1.7.255255(000180.77W)\r" -> null
    2018-04-13 19:38:45.957 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (221 + NEW 16)
    2018-04-13 19:38:45.958 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.958 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r\n1-0:1.7.255255(000180.77W)\r\n1-0:96.5.5255(" -> null
    2018-04-13 19:38:45.973 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (237 + NEW 16)
    2018-04-13 19:38:45.974 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.975 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r\n1-0:1.7.255255(000180.77W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.25" -> null
    2018-04-13 19:38:45.989 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (253 + NEW 14)
    2018-04-13 19:38:45.989 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:45.990 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r\n1-0:1.7.255255(000180.77W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115" -> null
    2018-04-13 19:38:46.005 - [34mdebug[39m: smartmeter.0 ADD NEW DATA (267 + NEW 12)
    2018-04-13 19:38:46.005 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
    2018-04-13 19:38:46.006 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\r\n1-0:0.0.0
    255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r\n1-0:1.7.255255(000180.77W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n" -> ["1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r\n1-0:1.7.255255(000180.77W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n!\r\n","1-0:0.0.0255(179303)\r\n1-0:1.8.0255(00017097.0073825kWh)\r\n1-0:2.8.0255(00059606.8200000kWh)\r\n1-0:21.7.255255(000125.43W)\r\n1-0:41.7.255255(000011.75W)\r\n1-0:61.7.255255(000043.59W)\r\n1-0:1.7.255255(000180.77W)\r\n1-0:96.5.5255(82)\r\n0-0:96.1.255255(1ESY1115000303)\r\n"]
    2018-04-13 19:38:46.006 - [34mdebug[39m: smartmeter.0 PAUSE READING SERIALPORT TO HANDLE MESSAGE
    2018-04-13 19:38:46.006 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN HANDLEMESSAGE
    2018-04-13 19:38:46.007 - [34mdebug[39m: smartmeter.0 STORE DATA
    2018-04-13 19:38:46.007 - [34mdebug[39m: smartmeter.0 1-0:0.0.0255: Meter owner number = 179303
    2018-04-13 19:38:46.008 - [34mdebug[39m: smartmeter.0 Data for 1-0:0_0_0
    255 unchanged
    2018-04-13 19:38:46.008 - [34mdebug[39m: smartmeter.0 1-0:1.8.0255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 17097.0073825 kWh
    2018-04-13 19:38:46.008 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0
    255.rawvalue = 00017097.0073825kWh
    2018-04-13 19:38:46.009 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_8_0
    255.value = 17097.0073825
    2018-04-13 19:38:46.010 - [34mdebug[39m: smartmeter.0 1-0:2.8.0255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 59606.82 kWh
    2018-04-13 19:38:46.010 - [34mdebug[39m: smartmeter.0 Data for 1-0:2_8_0
    255 unchanged
    2018-04-13 19:38:46.010 - [34mdebug[39m: smartmeter.0 1-0:21.7.255255: Momentanwert L1 Wirkarbeit Bezug + = 125.43 W
    2018-04-13 19:38:46.011 - [34mdebug[39m: smartmeter.0 Set State 1-0:21_7_255
    255.rawvalue = 000125.43W
    255.value = 125.43
    2018-04-13 19:38:46.011 - [34mdebug[39m: smartmeter.0 1-0:41.7.255255: Momentanwert L2 Wirkarbeit Bezug + = 11.75 W
    2018-04-13 19:38:46.012 - [34mdebug[39m: smartmeter.0 Set State 1-0:41_7_255
    255.rawvalue = 000011.75W
    255.value = 11.75
    2018-04-13 19:38:46.012 - [34mdebug[39m: smartmeter.0 1-0:61.7.255255: Momentanwert L3 Wirkarbeit Bezug + = 43.59 W
    2018-04-13 19:38:46.012 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255
    255.rawvalue = 000043.59W
    2018-04-13 19:38:46.013 - [34mdebug[39m: smartmeter.0 Set State 1-0:61_7_255
    255.value = 43.59
    2018-04-13 19:38:46.013 - [34mdebug[39m: smartmeter.0 1-0:1.7.255255: Momentanwert Summe Wirkarbeit Bezug + = 180.77 W
    2018-04-13 19:38:46.013 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255
    255.rawvalue = 000180.77W
    2018-04-13 19:38:46.014 - [34mdebug[39m: smartmeter.0 Set State 1-0:1_7_255
    255.value = 180.77
    2018-04-13 19:38:46.014 - [34mdebug[39m: smartmeter.0 1-0:96.5.5255: Status = 82
    2018-04-13 19:38:46.014 - [34mdebug[39m: smartmeter.0 Data for 1-0:96_5_5
    255 unchanged
    2018-04-13 19:38:46.014 - [34mdebug[39m: smartmeter.0 0-0:96.1.255255: Factory number = 1ESY1115000303
    2018-04-13 19:38:46.015 - [34mdebug[39m: smartmeter.0 Data for 0-0:96_1_255
    255 unchanged
    Danke euch alles für die hilfe</code>
    • wendy2702W Online
      wendy2702W Online
      Also ich würde sagen das Debug log passt, Wenn ich das richtig sehe werden States erzeugt und geschrieben.
      Warum man die unter Objekte nicht sieht :shock:
      • L Offline
        ludino
        @wendy2702:
        Warum man die unter Objekte nicht sieht :shock: `
        Wer mir das sagen kann, das wäre super, ich weiß nicht mehr was ich machen soll.
        Habe ein frisch installiertes system
        admin auf 3.3.9
        JS auf 1.4.2
        und nur den smartmeter drauf… ich weiß nicht weiter
        • apollon77A Offline
          Auch mal im Admin unter Objekte auf den Button mit den zwei Pfeilen geklickt? Sicher das nicht ausversehen nach irgendwelchen States gefiltert wird?
          Log sieht perfekt aus.
            Ääääähm. Sagtest du nicht das es ein multihost System ist? Warum ist im Admin die Host Auswahl dann ausgegraut auf dem Screenshot?
            • L Offline
              ludino
              @apollon77:
              Ääääähm. Sagtest du nicht das es ein multihost System ist? Warum ist im Admin die Host Auswahl dann ausgegraut auf dem Screenshot? `
              Ja das war der start, da es da auch schon nicht funtioniert hat, habe ich ein neues system aufgesetzt, als stand alone!
              @apollon77:
              Auch mal im Admin unter Objekte auf den Button mit den zwei Pfeilen geklickt? Sicher das nicht ausversehen nach irgendwelchen States gefiltert wird? `
              Weiß gerade nicht was du meinst aber Filter müßte ich keinen haben. Oder welche States, aber wenn du mir die beiden Pfeile erklären könntest versuche ich es gerne.
              Habe als system ein PI 3 mit Admin 3.3.9 und JS 1.4.2
              • wendy2702W Online
                wendy2702W Online
                Ich denke Apollon meint den Reload button ganz links. Das waren früher mal 2 Pfeile.
                Filter wären ja in der Spalte mit den Überschriften zu setzen.
                Siehe Beispiel:
                • L Offline
                  ludino
                  Getestet
                  Nichts gebracht und filter auch keine drin leider!
                    Nachdem ich hier erst den roten Faden nicht gefunden habe, jetzt aber wieder alles auf Null steht, versuche ich es auch mal zu helfen.
                    Bitte Screenshots von der Konfiguration.
                    Werden die Datenpunkte unter smartmeter.0 nicht erst dann angelegt, wenn das Auslesen klappt.
                    Es sieht für mich so aus, als ob das eben nicht klappt. z.B.:
                    @ludino:
                    2018-04-13 19:37:44.604 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n" -> ~~[b]~~null
                    2018-04-13 19:37:45.645 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "\u0000\n/ESY5Q3DA202" -> ~~[b]~~null `
                    Wie heisst der Zähler EXAKT?
                    Laut https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/easymeter_q3d sieht die Konfig so aus:
                    ` > Der IR-Kopf wird mit der Zuleitung nach vorne montiert.
                    Der Q3D benötigt nur teilweise eine Aufforderung um seine Daten zu senden. Die Kommunikation erfolgt mit 9600bd, 7E1.
                    Eine vzlogger.conf zur Ermittlung der Daten, die der Zähler sendet:
                    "protocol": "d0",
                          "device": "/dev/ttyUSB0",
                          "baudrate": 9600,
                          "parity": "7e1"
                    hast du bereits jemals Daten empfangen können?
                    • L Offline
                      ludino
                      danke für deine Hilfe.
                      wenn ich auf der Konsole den Port auslese mit CAT kommt folgendes
                      pi@raspberrypi:/opt/iobroker $ cat /dev/ttyUSB0
                      /ESY5Q3DA2024 V3.03
                      1-0:1.8.0
                      255(00017097.2757315kWh)
                      1-0:2.8.0
                      1-0:21.7.255
                      255(000238.14W)
                      1-0:41.7.255
                      255(000011.67W)
                      1-0:61.7.255
                      255(000007.56W)
                      1-0:1.7.255
                      255(000257.37W)
                      1-0:96.5.5
                      255(82)
                      0-0:96.1.255*255(1ESY1115000303)
                      /ESY5Q3DA2024 V3.03
                      1-0:1.8.0
                      255(00017097.2758744kWh)
                      1-0:2.8.0
                      1-0:21.7.255
                      255(000238.35W)
                      1-0:41.7.255
                      255(000011.52W)
                      1-0:61.7.255
                      255(000007.47W)
                      1-0:1.7.255
                      255(000257.34W)
                      1-0:96.5.5
                      255(82)
                      deshalb gehe ich von aus das der Sensor funktioniert und daten liefert.
                      Konfig sieht so aus
                      Daten über iobroker nein nur über konsole
                      • wendy2702W Online
                        wendy2702W Online
                        Laut Debug log klappt es eigentlich auch z.B.:
                        smartmeter.0 1-0:2.8.0*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 59606.82 kWh
                        Achja, CAT und Adapter Ausgabe Zeitgleich wird zu 99% nicht funktionieren.
                        • L Offline
                          ludino
                          @wendy2702:
                          Achja, CAT und Adapter Ausgabe Zeitgleich wird zu 99% nicht funktionieren. `
                          Jop ist mir aufgefallen wenn cat läuft kommen auch keine info meldungen mehr
                          Habe es nur angemacht zum testen ob daten kommen!
                          • wendy2702W Online
                            wendy2702W Online
                            Habe keinen D0 Zähler mehr aber kann man im letzten Menü Punkt „Stromzähler“ oder so auswählen?
                            • L Offline
                              ludino
                              Danke Dir für den Hinweis, hatte ich aber auch schon versucht und leider auch ohne erfolg.
                              • wendy2702W Online
                                wendy2702W Online
                                Kannst du mal zum testen ein Admin Downgrade machen?
                                • L Offline
                                  ludino
                                  Schon gemacht, auf 2.0.9 leider auch kein erfolg
                                  Bin am überlegen ob ich den js downgrade!
                                    Es gibt anscheinend einige Threads/Posts zu "Easymeter Q3D".
                                    Bitte genau so in der Suche eingeben (mit "").
                                    Vielleicht findest du da etwas.
                                    in einem Thread hat @Apollon77 noch was am Adapter justiert, danach lief es.
                                    Die Konfiguration dort ist fast identisch zu deiner, nur zusätzlich in der letzten Zeile bei Ersatz OBIS ist dort 1. Strom (o.ä.) eingestellt.
                                    download/file.php?id=13504&mode=view
                                    • L Offline
                                      ludino
                                      Okay danke,
                                      ich werde mal lesen!!! Ich hatte in der suche nichts brauchbares gefunden melde mich wenn ich was finde!
                                      • L Offline
                                        ludino
                                        Mal alles überflogen, leider ohne erfolg….! Hmm echt Ernüchternt :(
                                          Aber mindestens zwei Posts schrieben, dass sie diesen Zähler erfolgreich in Betrieb hätten.
