  4. [Adapter] Sonoff- Tasmota
720 Beiträge 75 Kommentatoren 338.2k Aufrufe 8 Beobachtet
    klassisch
    #456
    Nach dem Update auf V2.0.2 war das Password weg. Musste ich wieder neu setzen
    ! sonoff.0 2018-04-01 06:38:39.105 warn Client [SonoffS20-02] has invalid password(*****************) or username(DVES_USER) sonoff.0 2018-04-01 06:38:39.017 warn Client [TestSonPow] has invalid password(*****************) or username(DVES_USER) sonoff.0 2018-04-01 06:38:13.355 warn Client [SonoffS20-01] has invalid password(*****************) or username(DVES_USER) sonoff.0 2018-04-01 06:38:13.343 warn Client [SonoffS20-02] has invalid password(*****************) or username(DVES_USER) sonoff.0 2018-04-01 06:38:13.000 warn Client [TestSonPow] has invalid password(*****************) or username(DVES_USER) sonoff.0 2018-04-01 06:38:07.606 info Starting MQTT authenticated server on port 1500 sonoff.0 2018-04-01 06:38:07.464 info starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.13.1 host.orangepiplus2e 2018-04-01 06:38:03.275 info instance system.adapter.sonoff.0 started with pid 14685 host.orangepiplus2e 2018-04-01 06:38:01.228 info instance system.adapter.sonoff.0 terminated with code 0 (OK) sonoff.0 2018-04-01 06:38:01.173 info terminating iobroker 2018-04-01 06:38:01.034 info exit 0 iobroker 2018-04-01 06:38:00.966 info Adapter "sonoff" updated iobroker 2018-04-01 06:38:00.896 info upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html iobroker 2018-04-01 06:38:00.823 info upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html !
    Nach dem erneuten Eingeben des PWD und PWD confirmation war wars dann i.O.
    sonoff.0 2018-04-01 06:47:07.824 info Client [SonoffS20-01] connected
    sonoff.0 2018-04-01 06:46:57.105 info Client [TestSonPow] connected
    sonoff.0 2018-04-01 06:46:57.047 info Client [SonoffS20-02] connected
    host.orangepiplus2e 2018-04-01 06:46:51.304 info instance system.adapter.sonoff.0 started with pid 17083
    host.orangepiplus2e 2018-04-01 06:46:48.875 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
    sonoff.0 2018-04-01 06:46:48.729 info terminating
    host.orangepiplus2e 2018-04-01 06:46:48.696 info stopInstance system.adapter.sonoff.0 killing pid 14685
    host.orangepiplus2e 2018-04-01 06:46:48.693 info stopInstance system.adapter.sonoff.0
    host.orangepiplus2e 2018-04-01 06:46:48.674 info object change system.adapter.sonoff.0
    sonoff.0 2018-04-01 06:46:41.056 warn Client [SonoffS20-01] has invalid password(*****************) or username(DVES_USER)
    sonoff.0 2018-04-01 06:46:30.561 warn Client [TestSonPow] has invalid password(****************) or username(DVES_USER)
    • ? Offline
      #457
      Hallo Chefkoch009,
      ich habe nun der Einfachheit halber aus dem bestehenden Projekt ein kleines Setup raus kopiert und als neues Projekt erstellt.
      Dort habe ich alle DPTs gesetzt. Wenn ich nun das Projekt in den KNX Adapter lade dann wird der Raum 1 erstellt allerdings werden 0 Objekte importiert.
      Das Testprojekt ist allerdings zu GroГџ um es hochzuladen. Wie kann ich es dir zukommen lassen?
      LG Abry88
      • N Offline
        N Offline
        nicki1807
        #458
        Hallo ,
        ich bin neu hier , und auch bei IObrocker erst am Anfang ,ich bitte um Verständnis falls ich was falsch mache.
        Habe Sonoff Basic per sonoff-Adapter installiert.
        Ich kann von der vis. und per Alexa das Sonoff Relais schalten.
        wenn ich nun per Arduino ESP8266 einen mqtt Befehl schicke (sonoff.0.schalter =true)
        ändert sich zwar der zustand im ioBroker und die vis zeigt auch true an.
        aber das Relais schaltet nicht ?
        wenn ich das sonoff Relais über den mqtt adapter instaliere kann ich schalten , aber gibt Probleme mit Visualisierung.
        dh es wird der Status des POWER angezeigt und geht irgendwie nicht.
        hat mir jemand ein Rat ?
        • SchubiS Offline
          SchubiS Offline
          Schubi
          #459
          Hallo Niki,
          also so ganz hab ich noch nicht begriffen welches Problem du hast.
          ? Du hast Tasmota auf dem Sonoff geflasht ?
          ? Du hast den Sonoff Adapter unter ioBroker istalliert und kannst damit den Sonoff schalten?
          Was funktioniert bis hier nicht?
          Du schreibst arduino mqtt ? Was soll das sein?
          Wenn du den Mqtt Adapter in ioBroker installiert hast, dann musst diesen als Server ausführen.
          Dabei muss er entweder einen ander Port als der Sonoff verwenden oder der Sonoff Adapter wird deaktiviert.
          Im Mqtt Adapter gibt es einen Datenpunkt unter CMD der für das Schalten zutändig ist,
          Einen weiteren in STATE der als Rückmeldung fungiert.
          LG Schubi
          / Synology DS716+ / Logitech Harmony Ultimate / Netatmo / ESP8266 / RPi 3 / 4* Möller Easy 820 / Lupusec XT2 Plus /
          • modmaxM Offline
            modmaxM Offline
            modmax
            #460
            Hi Niki,
            ich bin da auch noch nicht so ganz durchgestiegen, was Du da machst oder was nicht funktioniert.
            Redest Du nun von dem Sonoff-Adapter oder dem MQTT-Adapter?
            Welche Adapter-Versionen nutzt Du?
            Wie sehen deine Objekte unter sonoff.0 bzw. mqtt.0 aus? Hier würde ein Screenshot helfen.
            Wie schaltest Du per Arduino-MQTT? Ist das ein Mosquito-Server, oder meinste die Weboberfläche des Sonoff?
            Den Datenpunkt "sonoff.0.schalter" gibt es nicht … der müßte zumindest "sonoff.0.schalter.POWER" heißen.
            MfG Markus
            • N Offline
              N Offline
              nicki1807
              #461
              Ich möchte das sonoff relais das am sonoff.0 adapter ist schalten.
              Ich verwende einen Microcontroller der am mqtt adapter angemeldet ist.
              ich sende vom controller sonoff.0.schalter.POWER mit dem wert true
              am iobroker erscheint dann hinter schalter das grüne true -> relais schaltet aber nicht .
              in der vis geht die lampe an.
              mach ich den sonoff an den mqtt adapter geht das schalten mit
              mqtt.0.cmnd.schalter.POWER = ON
              brauche eigenlich nur das schalt comando !
              Danke für eure mühe
              • modmaxM Offline
                modmaxM Offline
                modmax
                #462
                Das kann auch nicht gehen, da Du im Sonoff für den MQTT-Server nur einen Port angeben kannst, auf den der Sonoff hören soll bzw. mit dem er kommunizieren soll.
                Jedoch brauchen Sonoff-Adapter und MQTT-Adapter unterschiedliche Ports, da sich beide sonst in die Quer kommen.
                Also entweder schalten per Sonoff-Adapter ODER MQTT-Adapter.
                Beides parallel, wie Du es versuchst, geht nicht.
                • N Offline
                  N Offline
                  nicki1807
                  #463
                  Ich habe unterschiedliche ports
                  1883 mqtt
                  1884 sonoff
                  ich denke der server schickt alles zu allen ?
                  der vis. adapter zu sonof und mqtt
                  der cloud auch zu sonoff und mqtt
                  oder hab ich da ein denkfehler ? :shock:
                  • modmaxM Offline
                    modmaxM Offline
                    modmax
                    #464
                    ähm … vielleicht ... :-)
                    und was ist im sonoff gerät eingestellt für mqtt?
                    das gerät selber kann entweder nur mit dem sonoff adaptwr oder dem mqtt adapter kommunizieren.
                    cloud und vis schicken nicht an alle ... sondern nur die datenpunkte, die in vis und cloud auch benutzt weden ...
                    • N Offline
                      N Offline
                      nicki1807
                      #465
                      Also nochmal etwas verständlicher:
                      ich dachte :
                      wenn ich sonoff.0.schalter.POWER = true schicke. wird das über den sonoff adapter an die geräte mit dem selben port (sonoff und gerät) geschkt
                      Also bei mir an alle sonoff mit dem port 1884
                      wenn ich ein mqtt.0.schalter.POWER = true schicke dann das selbe aber dann auf port 1883 , weil mqtt auf port 1883 eingestellt ist.
                      und es müste möglich sein mqtt.1 port 1885 , mqtt.2 , port 1886 zu konfigurieren . und mit mqtt.X wähle ich auf welchen port das dann rausgeht.
                      oder nicht ???
                      :shock:
                      • N Offline
                        N Offline
                        nicki1807
                        #466
                        Die Frage ist eigentlich die :
                        wie Kann ich von einem mqtt Client ein sonoff relais schalten ,das am sonoff.0 adapter (1884) angemeldet ist.
                        Darf mein Client über den mqtt.0 adapter (1883) angemeldet sein , oder muss er über den sonoff.0 adapter (1884) angemeldet sein ?
                        und wie sieht das comando aus ?
                        • SchubiS Offline
                          SchubiS Offline
                          Schubi
                          #467
                          Jetzt wird mir dein Wunsch schon etwas klarer.
                          Also Mqtt Server mit unterschiedlichen Ports "sehen" einander nicht.
                          Der Sonoff Adapter ist kein "vollwertiger" MQTT-Server - er ist speziell für die Topics der Tasmota Software zugeschnitten.
                          Ich würde das über ein Script oder Blockly lösen.
                          • Der MC ist mit dem MQTT-Server verbunden
                          • Der Sonoff ist mit dem Sonoff-Adpter verbunden.
                          Wenn nun der MC einen Datenpunkt setzt, sollte das Script den entsprechenden Datenpunkt auf dem Sonoff setzen.
                          Also etwa so:
                          on({id: 'mqtt.0.cmnd.Endschalter.POWER', change: "any"}, function (obj) {
                            var value = obj.state.val;
                            setState("sonoff.0.EG_KE_01.POWER"/*EG_KE_01 POWER*/, getState("mqtt.0.cmnd.Endschalter.POWER").val);
                          Oder das entsprechende Blockly:
                          • N Offline
                            N Offline
                            nicki1807
                            #468
                            Jaaaaaaaaaa Super genau das wollte ich
                            das Script funktioniert !
                            das hat mir gefehlt jetzt kann ich weiter machen .
                            Vielen Dank !!
                              Arnulf
                              #469
                              @Schubi:
                              Der Sonoff Adapter ist kein "vollwertiger" MQTT-Server - er ist speziell für die Topics der Tasmota Software zugeschnitten. `
                              oh. Jetzt werde ich aber hellhörig.
                              Vielleicht ist das auch mein Problem mit dem Bewegungsmelder.
                              In wie weit ist denn der Sonofff-Adapter spezialisiert auf Tasmota?
                              Was kann er denn mehr/besser/anders als der MQTT-Adapter?
                              Was sind denn die Unterschiede?
                              Und warum sollte ich Tasmota-Adapter verwenden, wenn ich gleich ein MQTT-Adapter verwenden kann?
                              Macht es irgendeinen Sinn, beide Adapter parallel zu betreiben?
                              Ich meine das nicht böse oder abwertend. Bin nur kein Freund von Redundanzen und möchte gerne mein System optimal konfigurieren
                              • kmxakK Offline
                                kmxakK Offline
                                kmxak
                                #470
                                Gibt eine neuen FW Version.
                                https://github.com/arendst/Sonoff-Tasmota/releases
                                Gruß Alex
                                  Arnulf
                                  #471
                                  @kmxak:
                                  https://github.com/arendst/Sonoff-Tasmota/releases `
                                  :shock:
                                  OMG. Danke. Das ist ja eine riesige Liste von Änderungen.
                                  • kmxakK Offline
                                    kmxakK Offline
                                    kmxak
                                    #472
                                    Jo ich musste auch immer erst die minimal flashen und dann die richtige fw.
                                    Gesendet von meinem SM-G930F mit Tapatalk
                                    Gruß Alex
                                      Balu0127
                                      #473
                                      Hat die schon wer ausprobiert?
                                      • Espace0401E Offline
                                        Espace0401E Offline
                                        Espace0401
                                        #474
                                        Ich habe jetzt mal einen damit geflash, hat auch alles geklappt. Dieser ist aber jetzt nicht mehr über das Webinterface aufrufbar, so als wenn das WLAN abgeschaltet ist. Bin leider unterwegs und kann nicht weiter nachsehen. Sonst fand ich die neu eingebaute Timerfunktion schon sehr gut.
                                        Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
                                          klassisch
                                          #475
                                          Hat jemand die Multi DS18B20 Option im Einsatz?
                                          Kann man da die Sensoren den Kanälen fest zuordnen? Habee so eine Anwendung im Heizraum und die feste Zuordnung hat recht viel Konfigurationsaufwand gemacht. Wenn man das aber nicht macht, werden die Zuordnungen bei einem neuen, getauschten oder defekten Sensor neu gemischt.
