  4. [Aufruf] deConz Adapter Testen 1.1.2
    1.0k
zigbeedeconz
532 Beiträge 57 Kommentatoren 180.5k Aufrufe 24 Beobachtet
  • C Offline
    comchris
    #149
    Hallo ich habe seit ein paar Tagen leider ein Problem mit dem Adapter.
    deconz.0	2018-04-08 09:13:36.180	info	terminating
    deconz.0	2018-04-08 09:13:35.672	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    deconz.0	2018-04-08 09:13:35.672	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    deconz.0	2018-04-08 09:13:35.672	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    deconz.0	2018-04-08 09:13:35.672	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    deconz.0	2018-04-08 09:13:35.672	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    deconz.0	2018-04-08 09:13:35.672	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    deconz.0	2018-04-08 09:13:35.672	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    deconz.0	2018-04-08 09:13:35.672	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1462:35)
    deconz.0	2018-04-08 09:13:35.672	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1578:21
    deconz.0	2018-04-08 09:13:35.672	error	at /opt/iobroker/node_modules/iobroker.deconz/main.js:340:96
    deconz.0	2018-04-08 09:13:35.672	error	TypeError: Cannot read property 'id' of undefined
    deconz.0	2018-04-08 09:13:35.662	error	uncaught exception: Cannot read property 'id' of undefined
    deconz.0	2018-04-08 09:12:48.008	info	starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.deconz, node: v4.9.1
    Der Adapter startet des öfteren immer neu hier ist die Fehlermeldung bei Neustart, hab nun schon verschiedenes probiert, Adapter neu installiert npm und nudejs Versionen verschiedene probiert, alles ohne Ergebnis. Ich kann jedoch nicht ausschließen dass bei meinem Iobroker irgendwas nicht funktioniert und deshalb der Adapter immer wieder neu startet, wobei alle anderen einwandfrei funktionieren.
    Ich habe als Deconz version habe ich 2.5.16 Nudejs version ist 4.9.1 und npm 2.15.11.
    Eingebunden habe ich ca 25 Ikea Lampen Fernbedienung und diverse Xiaomi Sensoren, hab aber immer auch auf die Namensgebung geachtet (verschachteln) dies klappt auch wunderbar.
    Ich hoffe ihr könnt mir helfen.
    • Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      #150
      @comchris bitte lösch den Adapter und installier den Adapter neu.
      Gesendet von meinem m8 mit Tapatalk
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • C Offline
        comchris
        #151
        5061_iobroker_steckdose.jpeg Ich habe den Adapter schon mehrfach neu installiert, - hab es aber jetzt nochmal probiert bis dato scheint alles gut zu sein. Ich habe aber noch eine weitere Vermutung. Heute morgen habe ich noch festgestellt dass ein Osram Plug (Steckdose) bei mir zweimal auftaucht einmal mit dem richtigen Namen wie in Phoscon App benannt und einmal als Power19 warum auch immer - also so wie bei TenSai der wohl auch Osram Plugs hat (Standart), hier aber als Typ SENSOR …. Und einmal als Gruppe (Steckdose). Ich hab diese heute morgen mal komplett gelöscht und bis dato nicht wieder eingebunden. - werde dies wenn ich ein komplettes Backup meines Systems habe ausprobieren. Anders kann ich mir es fast schon nicht mehr erklären, weil ich wie gesagt schon öfters den Adapter deinstalliert und neu installiert habe... werde berichten...
        Hab es jetzt ausprobiert promt war der gleiche Fehler da, ich glaub er mag die Osram Plugs nicht, hab ein paar Screenshots gemacht..
        deconz.0	2018-04-08 20:11:57.525	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
        deconz.0	2018-04-08 20:11:57.525	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        deconz.0	2018-04-08 20:11:57.525	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
        deconz.0	2018-04-08 20:11:57.525	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        deconz.0	2018-04-08 20:11:57.525	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        deconz.0	2018-04-08 20:11:57.525	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
        deconz.0	2018-04-08 20:11:57.525	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
        deconz.0	2018-04-08 20:11:57.525	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1462:35)
        deconz.0	2018-04-08 20:11:57.525	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1578:21
        deconz.0	2018-04-08 20:11:57.525	error	at /opt/iobroker/node_modules/iobroker.deconz/main.js:341:100
        deconz.0	2018-04-08 20:11:57.525	error	TypeError: Cannot read property 'id' of undefined
        deconz.0	2018-04-08 20:11:57.500	error	uncaught exception: Cannot read property 'id' of undefined
        iobroker	2018-04-08 20:11:56.722	info	host.iobroker-qnap: Only 400 objects left to be deleted.
        iobroker	2018-04-08 20:11:56.394	info	host.iobroker-qnap Deleting 451 object(s).
        iobroker	2018-04-08 20:11:52.897	info	host.iobroker-qnap Counted 8 states (system.adapter.deconz.0.*) from states
        iobroker	2018-04-08 20:11:52.866	info	host.iobroker-qnap Counted 251 states (io.deconz.0.*) from states
        iobroker	2018-04-08 20:11:52.794	info	host.iobroker-qnap Counted 387 states of deconz.0
        iobroker	2018-04-08 20:11:52.420	info	host.iobroker-qnap Counted 63 devices of deconz.0
        iobroker	2018-04-08 20:11:52.393	info	host.iobroker-qnap Counted 1 instances of deconz
        iobroker	2018-04-08 20:11:52.358	info	Delete adapter "deconz.0"
        iobroker	2018-04-08 20:11:51.048	info	del deconz.0
        deconz.0	2018-04-08 20:11:35.317	info	starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.deconz, node: v4.9.1
        host.iobroker-qnap	2018-04-08 20:11:33.516	info	instance system.adapter.deconz.0 started with pid 1708
        host.iobroker-qnap	2018-04-08 20:11:03.502	info	Restart adapter system.adapter.deconz.0 because enabled
        • Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          #152
          @comchris:
          Ich habe aber noch eine weitere Vermutung. Heute morgen habe ich noch festgestellt dass ein Osram Plug (Steckdose) `
          Hm ja das ergibt schon Sinn weil die Osram Steckdosen als 2 Geräte gesehen werden, einmal als Lampe/Aktor und dann als Sensor (Leistungsmessung).
          Genau an dieser Stelle ergibt es dann aber schon wieder keinen Sinn mehr weil es getrennte Geräte sind.
          Kannst du mal bitte noch einen Screenshot von Power 30 machen so wie du es für Power 2 gemacht hast.
            dimaiv
            #153
            bei mir funktioniert Adapter immer noch nicht.
            Sobald ich auf IKEA Fernbedienung irgendwas drücke, startet Adapter neu.
            Angemeldet an Deconz habe ich erstmal nur IKEA Fernbedienung.
            (Für weitere Tests habe ich auch unterschiedliche Xiaomi Sensoren und IKEA Lampen)
            Log:
            ! 2018-04-09 14:08:04.562 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 25833
            ! 2018-04-09 14:08:06.806 - debug: deconz.0 objectDB connected
            ! 2018-04-09 14:08:06.889 - debug: deconz.0 statesDB connected
            ! 2018-04-09 14:08:06.942 - info: deconz.0 starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
            ! 2018-04-09 14:08:07.033 - debug: deconz.0 API version: 1.0.9
            ! 2018-04-09 14:08:07.079 - debug: deconz.0 getAllLights: {}
            ! 2018-04-09 14:08:07.087 - debug: deconz.0 getAllSensors: {"3":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"cc9df81e0d9339c9195faf9c69d9d5b5","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"daylight":true,"lastupdated":"2018-04-09T11:33:27","status":170},"swversion":"1.0","type":"Daylight","uniqueid":"00:00:00:00:00:00:00:00-01"},"4":{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"0426f974b298c018cd63030ad8b9a418","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":4002,"lastupdated":"2018-04-09T12:05:12"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}}
            ! 2018-04-09 14:08:07.104 - debug: deconz.0 getAllGroups: {"58606":{"action":{"bri":127,"colormode":"ct","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":["4"],"etag":"0426f974b298c018cd63030ad8b9a418","hidden":false,"id":"58606","lights":[],"lightsequence":[],"multideviceids":[],"name":"TRADFRI remote control 4","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
            ! 2018-04-09 14:08:07.157 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"ct","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":["4"],"etag":"0426f974b298c018cd63030ad8b9a418","hidden":false,"id":"58606","lights":[],"lightsequence":[],"multideviceids":[],"name":"TRADFRI remote control 4","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            ! 2018-04-09 14:08:19.377 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T12:08:19"},"t":"event"}
            ! 2018-04-09 14:08:19.379 - debug: deconz.0 Id: 4 Type: sensors
            ! 2018-04-09 14:08:19.475 - error: deconz.0 uncaught exception: Cannot read property 'id' of undefined
            ! 2018-04-09 14:08:19.477 - error: deconz.0 TypeError: Cannot read property 'id' of undefined
            ! at /opt/iobroker/node_modules/iobroker.deconz/main.js:341:100
            ! at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1578:21
            ! at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1462:35)
            ! at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
            ! at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
            ! at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            ! at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            ! at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
            ! at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            ! at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
            ! 2018-04-09 14:08:19.987 - info: deconz.0 terminating
            ! 2018-04-09 14:08:20.014 - error: Caught by controller[0]: TypeError: Cannot read property 'id' of undefined
            ! 2018-04-09 14:08:20.015 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.deconz/main.js:341:100
            ! 2018-04-09 14:08:20.016 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1578:21
            ! 2018-04-09 14:08:20.016 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1462:35)
            ! 2018-04-09 14:08:20.016 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
            ! 2018-04-09 14:08:20.017 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
            ! 2018-04-09 14:08:20.017 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            ! 2018-04-09 14:08:20.017 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            ! 2018-04-09 14:08:20.017 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
            ! 2018-04-09 14:08:20.018 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            ! 2018-04-09 14:08:20.018 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
            ! 2018-04-09 14:08:20.019 - error: host.raspberrypi instance system.adapter.deconz.0 terminated with code 0 (OK)
            ! 2018-04-09 14:08:20.019 - info: host.raspberrypi Restart adapter system.adapter.deconz.0 because enabled
            Software ist aktuell , alles heute frisch installiert. Deconz 2.05.20
            ioBroker- NUC8i3 / Proxmox / VM
            Node.js v22.21.0
            NPM v10.9.4
            JS controller 7.1.0
            Admin 7.7.20
            ZigBee Adapter 3.3.1alpha.0
            Zigbee LAN Gateway CC2652P
            Zigbee Firmware 20250321
            • Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #154
              @dimaiv:
              bei mir funktioniert Adapter immer noch nicht. `
              Danke für das Feedback.
              Ich hab jetzt die ganze Abarbeitung der Problemstelle geändert und dabei eine mögliche Fehlerquelle gefunden. Ob es etwas ändert kann ich nicht sagen, einfach mal testen. Die Aktuelle Version des Adapters ist damit 0.1.8.
              • C Offline
                comchris
                #155
                Hallo jey Cee,
                hab es leider gestern nicht mehr geschafft, ok klingt logisch mit der Leistungsmessung dachte eigentlich dies Osram Plugs haben diese nicht.
                Hab mir auch gleich die 0.1.8 geholt, bis jetzt ist der Fehler auch mit dem Osram Plug nicht aufgetreten - sieht sehr gut aus VIELEN DANK!
                  dimaiv
                  #156
                  Ich habe jetzt 0.1.8 installiert.
                  Während Installation kommt Fehler:
                  ! 2018-04-09 17:46:29.378 - info: iobroker host.raspberrypi install adapter deconz
                  ! 2018-04-09 17:46:29.398 - info: iobroker got /opt/iobroker/node_modules/iobroker.deconz/admin
                  ! 2018-04-09 17:46:29.426 - info: iobroker upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                  ! 2018-04-09 17:46:29.529 - info: iobroker upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                  ! 2018-04-09 17:46:29.597 - info: iobroker upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                  ! 2018-04-09 17:46:29.677 - info: iobroker upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index.html index.html text/html
                  ! 2018-04-09 17:46:29.737 - info: iobroker upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                  ! 2018-04-09 17:46:29.958 - info: iobroker host.raspberrypi object system.adapter.deconz created
                  ! 2018-04-09 17:46:29.975 - info: iobroker host.raspberrypi object enum.functions.color created
                  ! 2018-04-09 17:46:30.019 - info: iobroker host.raspberrypi create instance deconz
                  ! 2018-04-09 17:46:30.036 - info: iobroker host.raspberrypi object system.adapter.deconz.0.outputCount created
                  ! 2018-04-09 17:46:30.071 - info: iobroker host.raspberrypi object system.adapter.deconz.0.inputCount created
                  ! 2018-04-09 17:46:30.109 - info: iobroker host.raspberrypi object system.adapter.deconz.0.uptime created
                  ! 2018-04-09 17:46:30.143 - info: iobroker host.raspberrypi object system.adapter.deconz.0.memRss created
                  ! 2018-04-09 17:46:30.177 - info: iobroker host.raspberrypi object system.adapter.deconz.0.memHeapTotal created
                  ! 2018-04-09 17:46:30.211 - info: iobroker host.raspberrypi object system.adapter.deconz.0.memHeapUsed created
                  ! 2018-04-09 17:46:30.245 - info: iobroker host.raspberrypi object system.adapter.deconz.0.connected created
                  ! 2018-04-09 17:46:30.282 - info: iobroker host.raspberrypi object system.adapter.deconz.0.alive created
                  ! 2018-04-09 17:46:30.325 - info: host.raspberrypi object change system.adapter.deconz.0
                  ! 2018-04-09 17:46:30.356 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 11981
                  ! 2018-04-09 17:46:30.362 - info: iobroker host.raspberrypi object system.adapter.deconz.0 created
                  ! 2018-04-09 17:46:30.381 - info: iobroker exit 0
                  ! 2018-04-09 17:46:33.006 - info: deconz.0 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
                  ! 2018-04-09 17:46:33.037 - warn: deconz.0 No API Key found
                  ! 2018-04-09 17:47:06.075 - info: deconz.0 192.168.2.145:
                  ! 2018-04-09 17:47:06.169 - info: deconz.0 STATUS: 200
                  ! 2018-04-09 17:47:06.171 - info: deconz.0 "2DCA0C026B"
                  ! 2018-04-09 17:47:06.219 - error: deconz.0 uncaught exception: Unexpected token u in JSON at position 0
                  ! 2018-04-09 17:47:06.220 - error: deconz.0 SyntaxError: Unexpected token u in JSON at position 0
                  ! at Object.parse (native)
                  ! at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:377:28)
                  ! at self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
                  ! at emitOne (events.js:96:13)
                  ! at Request.emit (events.js:188:7)
                  ! at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:878:8)
                  ! at ClientRequest.emit (events.js:188:7)
                  ! at Socket.socketErrorListener (_http_client.js:310:9)
                  ! 2018-04-09 17:47:06.728 - info: deconz.0 terminating
                  ! 2018-04-09 17:47:06.752 - error: Caught by controller[0]: SyntaxError: Unexpected token u in JSON at position 0
                  ! 2018-04-09 17:47:06.753 - error: Caught by controller[0]: at Object.parse (native)
                  ! 2018-04-09 17:47:06.754 - error: Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:377:28)
                  ! 2018-04-09 17:47:06.754 - error: Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
                  ! 2018-04-09 17:47:06.755 - error: Caught by controller[0]: at emitOne (events.js:96:13)
                  ! 2018-04-09 17:47:06.755 - error: Caught by controller[0]: at Request.emit (events.js:188:7)
                  ! 2018-04-09 17:47:06.755 - error: Caught by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:878:8)
                  ! 2018-04-09 17:47:06.755 - error: Caught by controller[0]: at ClientRequest.emit (events.js:188:7)
                  ! 2018-04-09 17:47:06.756 - error: Caught by controller[0]: at Socket.socketErrorListener (_http_client.js:310:9)
                  ! 2018-04-09 17:47:06.756 - error: Caught by controller[0]: at emitOne (events.js:96:13)
                  ! 2018-04-09 17:47:06.756 - error: host.raspberrypi instance system.adapter.deconz.0 terminated with code 0 (OK)
                  ! 2018-04-09 17:47:06.757 - info: host.raspberrypi Restart adapter system.adapter.deconz.0 because enabled
                  ! 2018-04-09 17:47:08.706 - info: host.raspberrypi object change system.adapter.deconz.0
                  ! 2018-04-09 17:47:08.726 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 12238
                  ! 2018-04-09 17:47:11.101 - info: deconz.0 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
                  ! 2018-04-09 17:49:01.477 - info: host.raspberrypi object change system.adapter.deconz.0
                  ! 2018-04-09 17:49:01.484 - info: host.raspberrypi stopInstance system.adapter.deconz.0
                  ! 2018-04-09 17:49:01.485 - info: host.raspberrypi stopInstance system.adapter.deconz.0 killing pid 12238
                  ! 2018-04-09 17:49:01.998 - info: deconz.0 terminating
                  ! 2018-04-09 17:49:02.026 - info: host.raspberrypi instance system.adapter.deconz.0 terminated with code 0 (OK)
                  ! 2018-04-09 17:49:04.017 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 13284
                  ! 2018-04-09 17:49:06.253 - debug: deconz.0 objectDB connected
                  ! 2018-04-09 17:49:06.330 - debug: deconz.0 statesDB connected
                  ! 2018-04-09 17:49:06.400 - info: deconz.0 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
                  ! 2018-04-09 17:49:06.483 - debug: deconz.0 API version: 1.0.9
                  ! 2018-04-09 17:49:06.527 - debug: deconz.0 getAllLights: {}
                  ! 2018-04-09 17:49:06.535 - debug: deconz.0 getAllSensors: {"3":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"cc9df81e0d9339c9195faf9c69d9d5b5","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"daylight":true,"lastupdated":"2018-04-09T11:33:27","status":170},"swversion":"1.0","type":"Daylight","uniqueid":"00:00:00:00:00:00:00:00-01"},"4":{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b281113b52a9d41027f82437c35e6301","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":4002,"lastupdated":"2018-04-09T15:48:47"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}}
                  ! 2018-04-09 17:49:06.551 - debug: deconz.0 getAllGroups: {"58606":{"action":{"bri":127,"colormode":"ct","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":["4"],"etag":"b281113b52a9d41027f82437c35e6301","hidden":false,"id":"58606","lights":[],"lightsequence":[],"multideviceids":[],"name":"TRADFRI remote control 4","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
                  ! 2018-04-09 17:49:06.590 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"ct","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":["4"],"etag":"b281113b52a9d41027f82437c35e6301","hidden":false,"id":"58606","lights":[],"lightsequence":[],"multideviceids":[],"name":"TRADFRI remote control 4","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
                  Dann wenn ich Fernbedienung betätige wird zur dazugehörige Objekt noch ein gleichen hinzugefügt, und so die ganze Zeit:
                  ! 2018-04-09 17:59:00.462 - debug: deconz.0 system.adapter.admin.0: logging true
                  ! 2018-04-09 17:59:14.576 - debug: deconz.0 system.adapter.admin.0: logging false
                  ! 2018-04-09 17:59:25.557 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:25"},"t":"event"}
                  ! 2018-04-09 17:59:25.599 - debug: deconz.0 Id: 4 Type: sensors
                  ! 2018-04-09 17:59:25.626 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2679fabeb9bdd9357173b81629d3ea3d","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:25"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:31.667 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:31"},"t":"event"}
                  ! 2018-04-09 17:59:31.684 - debug: deconz.0 Id: 4 Type: sensors
                  ! 2018-04-09 17:59:31.694 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"e83846f452e8afdb9ef78cf598fbbe9a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:31"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:31.706 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"e83846f452e8afdb9ef78cf598fbbe9a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:31"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:41.679 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":2002,"lastupdated":"2018-04-09T15:59:41"},"t":"event"}
                  ! 2018-04-09 17:59:41.704 - debug: deconz.0 Id: 4 Type: sensors
                  ! 2018-04-09 17:59:41.721 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"73242e6b862321ec010efa511fab2255","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":2002,"lastupdated":"2018-04-09T15:59:41"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:41.754 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"73242e6b862321ec010efa511fab2255","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":2002,"lastupdated":"2018-04-09T15:59:41"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:41.766 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"73242e6b862321ec010efa511fab2255","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":2002,"lastupdated":"2018-04-09T15:59:41"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:55.285 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"t":"event"}
                  ! 2018-04-09 17:59:55.310 - debug: deconz.0 Id: 4 Type: sensors
                  ! 2018-04-09 17:59:55.338 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b21990522b2f23dc0ab584b991735a6a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:55.360 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b21990522b2f23dc0ab584b991735a6a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:55.367 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b21990522b2f23dc0ab584b991735a6a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 17:59:55.375 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"b21990522b2f23dc0ab584b991735a6a","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T15:59:55"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:14.643 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"t":"event"}
                  ! 2018-04-09 18:02:14.675 - debug: deconz.0 Id: 4 Type: sensors
                  ! 2018-04-09 18:02:14.713 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:14.733 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:14.780 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:14.784 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:14.788 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"7928716aa2089b6c20b70b624a207c52","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:14"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:16.459 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"t":"event"}
                  ! 2018-04-09 18:02:16.483 - debug: deconz.0 Id: 4 Type: sensors
                  ! 2018-04-09 18:02:16.541 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:16.570 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:16.576 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:16.589 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:16.594 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:16.599 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"2d4e0266010f911dc746ac0ddd6cc1d5","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:16"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:18.026 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"t":"event"}
                  ! 2018-04-09 18:02:18.042 - debug: deconz.0 Id: 4 Type: sensors
                  ! 2018-04-09 18:02:18.061 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:18.083 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:18.089 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:18.093 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:18.108 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:18.112 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:18.116 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"42e1d45ef44de8f0f3184e48ab278bcb","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:18"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:19.141 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"t":"event"}
                  ! 2018-04-09 18:02:19.176 - debug: deconz.0 Id: 4 Type: sensors
                  ! 2018-04-09 18:02:19.215 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:19.238 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:19.280 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:19.287 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:19.300 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:19.309 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:19.313 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:19.317 - debug: deconz.0 getSensor: "{"config":{"alert":"none","battery":47,"group":"58606","on":true,"reachable":true},"ep":1,"etag":"07574e8bf4b36f929170e7f4a2fd1e02","manufacturername":"IKEA of Sweden","mode":3,"modelid":"TRADFRI remote control","name":"TRАDFRIFernbed1","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:19"},"swversion":"1.2.214","type":"ZHASwitch","uniqueid":"00:0b:57:ff:fe:bc:37:59-01-1000"}"
                  ! 2018-04-09 18:02:20.203 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"buttonevent":1002,"lastupdated":"2018-04-09T16:02:20"},"t":"event"}
                  Node.js v22.21.0
                  NPM v10.9.4
                  JS controller 7.1.0
                  Admin 7.7.20
                  • F Offline
                    Fatmax
                    #157
                    muss Deconz eigentlich unter GUI laufen?
                    Es wird zwar installiert, aber ich bekomme es nicht zum Starten.
                    Die Phoscon-App bzw. die Weboberfläche sind vorhanden.
                    Beim Adapter funktioniert die Erstellung des API-Keys nicht. Ich gehe in der Weboberfläche auf Unlock, es kommt aber kein Key in Iobroker an.
                    Bitte um Hilfe, ich bin schon am verzweifeln und überlege den Stick wieder wegzugeben.
                    Liebe Grüße,
                    Fatmax
                    • Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      #158
                      @Fatmax:
                      muss Deconz eigentlich unter GUI laufen? `
                      Nein, das muss ohne gehen.
                      @Fatmax:
                      Beim Adapter funktioniert die Erstellung des API-Keys nicht. Ich gehe in der Weboberfläche auf Unlock, es kommt aber kein Key in Iobroker an. `
                      Wenn du das Passwort von deConz nicht geändert hast, reicht es in der Adapter Einstellung auf "Erstelle API Key" zu Klicken.
                      Was sagt den das Log des Adapters?
                      • G Offline
                        Gerni
                        #159
                        Funktionierte Headless bei mir auch nicht so richtig. Habe dann einmal alles neu installiert, Raspian mit Desktop, dort deConz installiert und seit dem läuft es. Die deConz selbst brauche ich jedoch nicht - oder ich weiß nicht wozu :-D
                        Den API Key konnte ich auch nicht in ioBroker erstellen lassen. Manuell klappte es dann.
                        Bisher keine Probleme.
                        deConz Adapter von Jey Cee nutze ich jedoch auch nur in Version 0.1.1 glaub ich - jedenfalls nicht die aktuellste. Da testet Jey Cee ja aktuell noch einiges mit meiner Xiaomi Hardware und für Tests am System hab ich aktuell schlechte Möglichkeiten.
                        Also nicht aufgeben, wenn das Ding einmal eingerichtet ist läuft das echt klasse. Bin jedenfalls begeistert. Wenn dann noch die Xiaomi Geräte 100% funktionieren und alle Daten gelesen werden können ist das Hammer. Nutze zudem IKEA Lampen und auch Lampen von Innr bisher ohne Probleme oder Ausfälle.
                        Jede Menge verschiedenes Zeug
                          dimaiv
                          #160
                          @dimaiv:
                          Screenshot 2018-04-09 18.02.38.png `
                          Auch wenn ich nichts mache, wird alle 45 Minuten ein Objekt als Unterobjekt hinzugefügt.
                          Node.js v22.21.0
                          NPM v10.9.4
                          JS controller 7.1.0
                          Admin 7.7.20
                          • BigWumpusB Offline
                            BigWumpusB Offline
                            BigWumpus
                            #161
                            Ich probiere jetzt auch schon Tage…
                            Irgendwann verstehe ich, wozu es Deconz und Phoscon gibt.
                            Den iobroker-Adapter habe ich von 0.1.1 auf 0.1.8 gebracht.
                            In der WebApp (vermutlich Deconz) habe ich den User/PW delight/delight drin.
                            Den API-Key kann ich nicht erstellen.
                            Selbst die REST-Kiste klappt nicht, weil die Kiste nicht antwortet.
                            Ich habe eine OSRAM-Plug und einen XIAOMI Bewegungsmelder angelernt.
                            Aber die IOBroker-Anbindung geht nicht.
                            Was kann es noch sein ???
                            Pi3B ioBroker: SONOFFs Tasmota mit TasmoAdmin, Shelly2.5 Rollladen
                            Pi2B RaspBee DeConz ZigBee: Philips&Innr&OSRAM Lampen/Stecker, Xiaomi Sensoren, Lichttaster und -Schalter
                            Heizung: EQ-3 Max!
                            Netz: AVM 7490, Devolo Magic 1
                              dimaiv
                              #162
                              Ich habe Deconz Adapter letzte Tage bestimmt 20 mal installiert, und jedes mal hat es gut funktioniert mit dem API-Key erstellen.
                              IP Adresse eingeben, Port 8080 löschen, in Phoscon App "App verbinden" drücken, und in der Adapter Einstellungen auf "Erstelle API Key" drücken.
                              Nicht mal 1 sek warten, API-Key ist da…
                              Bei mir läuft alles auf einem PI 3B.
                              Node.js v22.21.0
                              NPM v10.9.4
                              JS controller 7.1.0
                              Admin 7.7.20
                              • Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                #163
                                @BigWumpus:
                                Den API-Key kann ich nicht erstellen. `
                                @Gerni:
                                Den API Key konnte ich auch nicht in ioBroker erstellen lassen. Manuell klappte es dann. `
                                @Fatmax:
                                Wichtig ist das man nachdem man IP und Port in der Adapter Konfiguration eingetragen hat auf "Speichern" zu Klicken und erst dann den API Key erstellen.
                                @BigWumpus:
                                Selbst die REST-Kiste klappt nicht, weil die Kiste nicht antwortet. `
                                Sorry, ich versteh leider nicht was du damit sagen möchtest.
                                  BigWumpusB Offline
                                  BigWumpus
                                  #164
                                  Nach 1000 gelesenen Threads die Lösung:
                                  Das Feld "Port" muß leer sein !
                                  Port 8080 ist nicht mehr !
                                  Heizung: EQ-3 Max!
                                    Kugelkopf
                                    #165
                                    @BigWumpus:
                                    Port 8080 ist nicht mehr ! `
                                    Was genau meinst du damit? Geht es jetzt um das verbinden des deconz Adapters in iobroker ?
                                    Habe seit 2 Tagen auch meine Xiaomi/Aqara Sensoren von Gearbest bekommen. Ist 1 Tür/Fenster Sensor und 3 Temp/Luftfeuchte Sensoren.
                                    Der Tür Sensor funktioniert ganz gut soweit erstmal. Glaube ich zumindest. Muss das noch mal genauer checken. Jedoch funktionieren die Temp Sensoren nicht. Sie werden nur 1x in ioBroker aktualisiert und danach nie wieder. Auf der Phoscon selte kann ich die Änderungen sehen, in ioBroker bewegt sich jedoch überhaupt nichts. Nur ein neustarten des deconz adapters in iobroker ruft wieder aktuelle Werte ab.
                                    Hinzugefügt habe ich die Adapter auf der Phoscon Seite.
                                    Benutze deconz im headless Modus und verwende Adapterversion 0.1.8.
                                    Deconz Version: 2.05.20
                                    Anbei gibt es einen Screenshot von meinen Objekten und aus der Phoscon App.
                                    5370_bildschirmfoto_2018-04-14_um_17.21.41.png 5370_bildschirmfoto_2018-04-14_um_17.21.26.png 5370_bildschirmfoto_2018-04-14_um_17.20.28.png
                                    • F Offline
                                      Fatmax
                                      #166
                                      @BigWumpus:
                                      Das war nach Wochen nun die Lösung des Rätsels.
                                      Ich kann nun bestätigen, dass folgendes (teilweise) funktioniert:
                                      ~~![](</s><URL url=)<link_text text="https://xiaomi-mi.com/uploads/Catalogue ... 808447.jpg">https://xiaomi-mi.com/uploads/CatalogueImage/pv_xiaomi-mi-wireless-switch-02_14104_1458808447.jpg</link_text>" />
                                      ->Battery und temperature wird nicht angezeigt, keine Ahnung, ob das überhaupt übertragen wird.
                                      ->Aufgefallen ist mir, dass das buttonevent nicht zurückgesetzt wird, wenn man nichts drückt.
                                      ~~![](</s><URL url=)<link_text text="https://xiaomi-mi.com/uploads/Catalogue ... 320631.jpg">https://xiaomi-mi.com/uploads/CatalogueImage/pv_xiaomi-mi-temperature-humidity-sensor-01_14106_1459320631.jpg</link_text>" />
                                      ->Ich habe diese 3x in Verwendung.
                                      ->In der Geräteverwaltung des Adapters werden die selben Sensoren erkannt, es sind aber unterschiedliche Objekte angelegt:
                                      ->bei dem Sensor im Schlafzimmer fehlt buttonevent, bei dem im Wohnzimmer funktioniert battery und buttonevent nicht.
                                      ~~![](</s><URL url=)<link_text text="https://xiaomi-mi.com/uploads/Catalogue ... 342091.jpg">https://xiaomi-mi.com/uploads/CatalogueImage/pv_xiaomi-aqara-window-door-sensor-01_15779_1506342091.jpg</link_text>" />
                                      ->funktioniert soweit ich das sehe einwandfrei.
                                      ~~![](</s><URL url=)<link_text text="https://xiaomi-mi.com/uploads/Catalogue ... 883212.jpg">https://xiaomi-mi.com/uploads/CatalogueImage/pv_xiaomi-mi-cube-pink-01_14302_1464883212.jpg</link_text>" />
                                      ->der mysteriöse Würfel :D
                                      ->es werden 2 Objekte angelegt:
                                      filename="Xiaomi-Würfel.JPG" index="2">~~
                                      ->das 1. Objekt ist für die Würfelseite, das 2. Objekt ist für die Rotation.
                                      ->die Werte ändern sich in den Objekten, je nachdem was man macht.
                                      ->Keine Ahnung wie man das weiter verwenden kann :lol: :lol:
                                      Was noch nicht geht sind meine 4 Ikea Tradfri Lampen.
                                      Ich hatte diese einmal in der Weboberfläche von Deconz drinnen, nun gehen sie nicht mehr.
                                      Es wird dazu ein Objekt "Daylight" im Iobroker-Deconz-Adapter angelegt -> lt. Geräteverwaltung ist die Modell-ID "PHDL00" und der Hersteller "Philips".
                                      Kann ich die irgendwie reseten, dass sich diese neu verbinden? Habe den Lichtschalter mehrmals an und ausgeschaltet, was aber nicht hilft.~~~~~~~~
                                      Liebe Grüße,
                                      Fatmax
                                      • Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        #167
                                        @Kugelkopf:
                                        Jedoch funktionieren die Temp Sensoren nicht. `
                                        Ich kann das nicht Nachvollziehen, hab 3 verschiedene Versionen des Adapters auf drei Unterschiedlichen hosts am Laufen und bei allen Funktioniert das.
                                        Du hast aber auch einen anderen Sensor als ich ihn hier habe. Ich habe jetzt gleich mal "Pressure" hinzugefügt, das hatte ich bis jetzt noch nicht auf dem Schirm.
                                        @Fatmax:
                                        ->Aufgefallen ist mir, dass das buttonevent nicht zurückgesetzt wird, wenn man nichts drückt. ` Richtig, da kein releases event von deconz übertragen wird. Das müsste ich Programtechnisch zurück setzen, aber ich bin mir nicht sicher ob das sinnvoll ist, andere Taster könnten sich hier ganz anders verhalten.
                                        @Fatmax:
                                        ->In der Geräteverwaltung des Adapters werden die selben Sensoren erkannt, es sind aber unterschiedliche Objekte angelegt: `
                                        Sorry ich weiss nicht was du mir damit sagen möchtest. Kannst du das bitte anders erklären?
                                        Ich vermute du willst darauf hinaus das die Sensoren, nicht alle, als mehrere Sensoren behandelt werden. Das wird von deConz so geliefert.
                                        Komisch ist das der Objektbaum den du mir zeigst die Sensoren zusammenfasst, das dürfte gar nicht sein, erklärt aber warum nicht alle Werte angezeigt werden.
                                        @Fatmax:
                                        Es wird dazu ein Objekt "Daylight" im Iobroker-Deconz-Adapter angelegt -> lt. Geräteverwaltung ist die Modell-ID "PHDL00" und der Hersteller "Philips". ` Hast du eine Hue Bridge in deinem Netzwerk? Das ist ein Softwareobjekt der Hue Bridge was dazu genutzt wird die Astrozeit als Entscheidungswert zu verwenden. Möglich das es auch von deConz selbst kommt.
                                        @Fatmax:
                                        Kann ich die irgendwie reseten, dass sich diese neu verbinden? `
                                        Lampe 6x hintereinander ein- und ausschalten (vom Strom trennen)
                                        Was anderes weiss ich auch nicht. Das hat bei mir funktioniert, aber nicht immer auf anhieb.
                                          Kugelkopf
                                          #168
                                          @Jey Cee:
                                          @Kugelkopf:
                                          Du hast aber auch einen anderen Sensor als ich ihn hier habe. Ich habe jetzt gleich mal "Pressure" hinzugefügt, das hatte ich bis jetzt noch nicht auf dem Schirm. `
                                          Moin Moin!
                                          Ich hab nun mal die Sensoren aus der Phoscon App gelöscht und nur einen davon hinzugefügt: "Multisensor". Des weiteren habe ich zuvor den Adapter in ioBroker komplett gelöscht und von Github neu heruntergeladen und hinzugefügt.
                                          Durch das Anpusten des Sensors habe ich die Temperatur und Luftfeuchtigkeit geändert. in ioBroker blinken unter Objekte zwar alle Werte auf in dem Moment, jedoch ändern sie sich nicht. Habe den Loglevel von deconz auf debug geändert und hier einmal angefügt:
                                          2018-04-15 16:06:56.206 - info: deconz.0 terminating
                                          2018-04-15 16:06:56.250 - info: host.raspi instance system.adapter.deconz.0 terminated with code 0 (OK)
                                          2018-04-15 16:06:58.235 - info: host.raspi instance system.adapter.deconz.0 started with pid 1850
                                          2018-04-15 16:07:00.724 - debug: deconz.0 objectDB connected
                                          2018-04-15 16:07:00.883 - debug: deconz.0 statesDB connected
                                          2018-04-15 16:07:01.049 - info: deconz.0 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.14.1
                                          2018-04-15 16:07:01.163 - debug: deconz.0 API version: 1.0.9
                                          2018-04-15 16:07:01.227 - debug: deconz.0 getAllLights: {"1":{"etag":"afeeb842dc3560c89c01ae29a3f00987","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug1","state":{"alert":"none","on":true,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:a7:7e:71-03"},"2":{"ctmax":454,"ctmin":250,"etag":"92504b46b53554c4982abd50f8340e3a","hascolor":true,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E14 WS opal 400lm","name":"TradfriE14","state":{"alert":"none","bri":2,"colormode":"ct","ct":454,"on":false,"reachable":true},"swversion":"1.2.217","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:8a:31:88-01"},"3":{"etag":"ddc48df3ef84a543ada24189cf78bcd1","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug2","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03"}}
                                          2018-04-15 16:07:01.258 - debug: deconz.0 getAllSensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"48e0cbce84f19b9a46029a93a594c586","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"daylight":true,"lastupdated":"2018-04-15T09:33:08","status":170},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:01:3e:51-01"},"14":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"0ee5dd8766e3f8913f7b5136097b6e31","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"lastupdated":"2018-04-15T14:06:23","temperature":2445},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0402"},"15":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"0ee5dd8766e3f8913f7b5136097b6e31","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"humidity":5464,"lastupdated":"2018-04-15T14:06:23"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0405"},"16":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"0ee5dd8766e3f8913f7b5136097b6e31","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"lastupdated":"2018-04-15T14:06:23","pressure":1004},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0403"},"2":{"config":{"on":true,"reachable":true},"ep":3,"etag":"de1f3e5ae1b2011948486430ca0c8b77","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 2","state":{"lastupdated":"2018-04-15T14:06:49","power":40},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:a7:7e:71-03-0b04"},"4":{"config":{"on":true,"reachable":true},"ep":3,"etag":"c3951ccae6553acba73381b8e4ad402c","manufacturername":"OSRAM","modelid":"Plug 01","name":"Zwischenstecker","state":{"lastupdated":"2018-04-15T14:05:08","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03-0b04"},"5":{"config":{"battery":98,"on":true,"reachable":true,"temperature":2500},"ep":1,"etag":"48e0cbce84f19b9a46029a93a594c586","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"DoorSensor1","state":{"lastupdated":"2018-04-15T11:55:18","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:b9:7a:01-01-0006"}}
                                          2018-04-15 16:07:01.315 - debug: deconz.0 getAllGroups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"48e0cbce84f19b9a46029a93a594c586","hidden":false,"id":"1","lights":["2"],"lightsequence":[],"multideviceids":[],"name":"Light","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"2":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"48e0cbce84f19b9a46029a93a594c586","hidden":false,"id":"2","lights":["3","1"],"lightsequence":[],"multideviceids":[],"name":"Plugs","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
                                          2018-04-15 16:07:01.454 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"48e0cbce84f19b9a46029a93a594c586","hidden":false,"id":"1","lights":["2"],"lightsequence":[],"multideviceids":[],"name":"Light","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
                                          2018-04-15 16:07:01.557 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"xy":[0,0]},"class":"Other","devicemembership":[],"etag":"48e0cbce84f19b9a46029a93a594c586","hidden":false,"id":"2","lights":["3","1"],"lightsequence":[],"multideviceids":[],"name":"Plugs","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
                                          2018-04-15 16:07:11.743 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:11","power":40},"t":"event"}
                                          2018-04-15 16:07:11.774 - debug: deconz.0 Id: 2 Type: sensors
                                          2018-04-15 16:07:11.792 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"d31757e158f4fcf93bb1016090467f20\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:11\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                                          2018-04-15 16:07:24.749 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:24","power":40},"t":"event"}
                                          2018-04-15 16:07:24.798 - debug: deconz.0 Id: 2 Type: sensors
                                          2018-04-15 16:07:24.816 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"44357774c096503a2ffcc3f28b1b611e\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:24\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                                          2018-04-15 16:07:41.738 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:41","power":40},"t":"event"}
                                          2018-04-15 16:07:41.764 - debug: deconz.0 Id: 2 Type: sensors
                                          2018-04-15 16:07:41.773 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"3b8dee02c07678a03443a5fedede11d2\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:41\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                                          2018-04-15 16:07:55.734 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:55","power":40},"t":"event"}
                                          2018-04-15 16:07:55.763 - debug: deconz.0 Id: 2 Type: sensors
                                          2018-04-15 16:07:55.777 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"d525be40cfb7ad8adc90740ebfcfad50\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:55\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                                          2018-04-15 16:07:57.284 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:57","temperature":2556},"t":"event"}
                                          2018-04-15 16:07:57.305 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":5585,"lastupdated":"2018-04-15T14:07:57"},"t":"event"}
                                          2018-04-15 16:07:57.315 - debug: deconz.0 Id: 14 Type: sensors
                                          2018-04-15 16:07:57.329 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:07:57","pressure":1004},"t":"event"}
                                          2018-04-15 16:07:57.336 - debug: deconz.0 Id: 15 Type: sensors
                                          2018-04-15 16:07:57.350 - debug: deconz.0 Id: 16 Type: sensors
                                          2018-04-15 16:07:57.360 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"eb1191dc66cd218b350e80b96a7418cf\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:07:57\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                                          2018-04-15 16:08:00.529 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:00","temperature":3011},"t":"event"}
                                          2018-04-15 16:08:00.546 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":7078,"lastupdated":"2018-04-15T14:08:00"},"t":"event"}
                                          2018-04-15 16:08:00.572 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:00","pressure":1004},"t":"event"}
                                          2018-04-15 16:08:00.586 - debug: deconz.0 Id: 14 Type: sensors
                                          2018-04-15 16:08:00.607 - debug: deconz.0 Id: 15 Type: sensors
                                          2018-04-15 16:08:00.611 - debug: deconz.0 Id: 16 Type: sensors
                                          2018-04-15 16:08:00.621 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"7376ce2de784f574832f7921df482e46\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:00\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                                          2018-04-15 16:08:03.767 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:03","temperature":2846},"t":"event"}
                                          2018-04-15 16:08:03.790 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":8108,"lastupdated":"2018-04-15T14:08:03"},"t":"event"}
                                          2018-04-15 16:08:03.795 - debug: deconz.0 Id: 14 Type: sensors
                                          2018-04-15 16:08:03.818 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:03","pressure":1004},"t":"event"}
                                          2018-04-15 16:08:03.844 - debug: deconz.0 Id: 15 Type: sensors
                                          2018-04-15 16:08:03.848 - debug: deconz.0 Id: 16 Type: sensors
                                          2018-04-15 16:08:03.863 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"40d612028889e36b1afcf3b88f35290b\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:03\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                                          2018-04-15 16:08:07.007 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:07","temperature":2744},"t":"event"}
                                          2018-04-15 16:08:07.035 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":8665,"lastupdated":"2018-04-15T14:08:07"},"t":"event"}
                                          2018-04-15 16:08:07.049 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:07","pressure":1004},"t":"event"}
                                          2018-04-15 16:08:07.075 - debug: deconz.0 Id: 14 Type: sensors
                                          2018-04-15 16:08:07.087 - debug: deconz.0 Id: 15 Type: sensors
                                          2018-04-15 16:08:07.093 - debug: deconz.0 Id: 16 Type: sensors
                                          2018-04-15 16:08:07.115 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"7895ed4064ae769a3f152c66dbe389e0\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:07\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                                          2018-04-15 16:08:10.245 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:10","temperature":2680},"t":"event"}
                                          2018-04-15 16:08:10.267 - debug: deconz.0 Id: 14 Type: sensors
                                          2018-04-15 16:08:10.270 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":8978,"lastupdated":"2018-04-15T14:08:10"},"t":"event"}
                                          2018-04-15 16:08:10.290 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:10","pressure":1004},"t":"event"}
                                          2018-04-15 16:08:10.295 - debug: deconz.0 Id: 15 Type: sensors
                                          2018-04-15 16:08:10.318 - debug: deconz.0 Id: 16 Type: sensors
                                          2018-04-15 16:08:10.329 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"52a11317474029bc606103b8bf5ea35e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:10\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                                          2018-04-15 16:08:16.505 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:16","temperature":2618},"t":"event"}
                                          2018-04-15 16:08:16.524 - debug: deconz.0 Id: 14 Type: sensors
                                          2018-04-15 16:08:16.527 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":9302,"lastupdated":"2018-04-15T14:08:16"},"t":"event"}
                                          2018-04-15 16:08:16.547 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:16","pressure":1004},"t":"event"}
                                          2018-04-15 16:08:16.584 - debug: deconz.0 Id: 15 Type: sensors
                                          2018-04-15 16:08:16.589 - debug: deconz.0 Id: 16 Type: sensors
                                          2018-04-15 16:08:16.604 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"8720d93ffb596195b7a5b082a0cb6a6e\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:16\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                                          2018-04-15 16:08:16.733 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:16","power":40},"t":"event"}
                                          2018-04-15 16:08:16.761 - debug: deconz.0 Id: 2 Type: sensors
                                          2018-04-15 16:08:16.779 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"8720d93ffb596195b7a5b082a0cb6a6e\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:16\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                                          2018-04-15 16:08:22.765 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:22","temperature":2567},"t":"event"}
                                          2018-04-15 16:08:22.785 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":9433,"lastupdated":"2018-04-15T14:08:22"},"t":"event"}
                                          2018-04-15 16:08:22.792 - debug: deconz.0 Id: 14 Type: sensors
                                          2018-04-15 16:08:22.809 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:22","pressure":1004},"t":"event"}
                                          2018-04-15 16:08:22.821 - debug: deconz.0 Id: 15 Type: sensors
                                          2018-04-15 16:08:22.839 - debug: deconz.0 Id: 16 Type: sensors
                                          2018-04-15 16:08:22.852 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"e5b07e4449be0504efdaa5cf961c697f\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:22\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                                          2018-04-15 16:08:29.727 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:29","power":40},"t":"event"}
                                          2018-04-15 16:08:29.801 - debug: deconz.0 Id: 2 Type: sensors
                                          2018-04-15 16:08:29.812 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"277f183c933a6f4928cd6152301004ed\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:29\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                                          2018-04-15 16:08:41.101 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:41","temperature":2516},"t":"event"}
                                          2018-04-15 16:08:41.119 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"humidity":9585,"lastupdated":"2018-04-15T14:08:41"},"t":"event"}
                                          2018-04-15 16:08:41.124 - debug: deconz.0 Id: 14 Type: sensors
                                          2018-04-15 16:08:41.142 - debug: deconz.0 Websocket message: {"e":"changed","id":"16","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:41","pressure":1004},"t":"event"}
                                          2018-04-15 16:08:41.150 - debug: deconz.0 Id: 15 Type: sensors
                                          2018-04-15 16:08:41.167 - debug: deconz.0 Id: 16 Type: sensors
                                          2018-04-15 16:08:41.176 - debug: deconz.0 getSensor: "{\"config\":{\"battery\":100,\"on\":true,\"reachable\":true},\"ep\":1,\"etag\":\"49e77ed37d60b864f259357ed4d8f73f\",\"manufacturername\":\"LUMI\",\"modelid\":\"lumi.weather\",\"name\":\"Multisensor\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:41\",\"pressure\":1004},\"type\":\"ZHAPressure\",\"uniqueid\":\"00:15:8d:00:01:f2:3d:52-01-0403\"}"
                                          2018-04-15 16:08:45.738 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-04-15T14:08:45","power":40},"t":"event"}
                                          2018-04-15 16:08:45.773 - debug: deconz.0 Id: 2 Type: sensors
                                          2018-04-15 16:08:45.788 - debug: deconz.0 getSensor: "{\"config\":{\"on\":true,\"reachable\":true},\"ep\":3,\"etag\":\"31b3efcd602b0065565f605ded1bf624\",\"manufacturername\":\"OSRAM\",\"modelid\":\"Plug 01\",\"name\":\"Power 2\",\"state\":{\"lastupdated\":\"2018-04-15T14:08:45\",\"power\":40},\"swversion\":\"V1.04.12\",\"type\":\"ZHAPower\",\"uniqueid\":\"7c:b0:3e:aa:00:a7:7e:71-03-0b04\"}"
                                          Die Sensoren die ich hier habe, sollen angeblich baugleich mit denen von xiaomi sein. https://www.gearbest.com/access-control/pp_626702.html
                                          Ich hätte dann noch ein paar Fragen offtopic:
                                          Wieso habe ich auch einen Power_2, Daylight und Zwischenstecker Objekt in iobroker? Wenn ich sie lösche werden sie automatisch beim nächsten Start hinzugefügt.
                                          Kann ich irgendetwas tun um den Pressure Wert auch in den Objekten zur Verfügung zu haben?
                                          Viele Grüße und einen schönen Sonntag!
