  4. Wunsch: Pollenflug-(Adapter/wasauchimmer)
    apollon77A
269 Beiträge 45 Kommentatoren 102.8k Aufrufe 21 Beobachtet
  • SmarthomeMFS
    SmarthomeMFS
    SmarthomeMF
    #85
    Hallo
    Danke für die Tolle Anleitung.
    @robsdobs:
    In diesem muss man aber "request" als "Zusätzliche NPM-Module" eintragen: `
    ok~~@robsdobs:~~
    Hast du den Enginetyp richtig? `
    ok~~@robsdobs:~~
    sollten im Tab Objete unter:javascript.0.wetter.pollenvorhersagePro Tag ein Ordner mit den Pollenarten auftauchen. `
    ja sind da ….
    Aber beim Start des Skripte bekomme ich WARN
    16:28:49.483
    [info]
    javascript.0 script.js.common.Polleninfo: compiling TypeScript source...
    16:28:49.484
    [info]
    javascript.0 script.js.common.Polleninfo: TypeScript compilation successful
    16:28:49.484
    [info]
    javascript.0 script.js.common.Polleninfo: registered 0 subscriptions and 1 schedule
    16:28:50.219
    [warn]
    javascript.0 at Request._callback (script.js.common.Polleninfo:252:21)
    16:28:50.222
    [warn]
    16:28:50.226
    [warn]
    16:28:50.229
    [warn]
    16:28:50.232
    [warn]
    16:28:50.236
    [warn]
    16:28:50.239
    [warn]
    16:28:50.242
    [warn]
    16:28:50.245
    [warn]
    16:28:50.247
    [warn]
    16:28:50.252
    [warn]
    16:28:50.256
    [warn]
    16:28:50.260
    [warn]
    16:28:50.263
    [warn]
    16:28:50.267
    [warn]
    16:28:50.270
    [warn]
    16:28:50.275
    [warn]
    16:28:50.278
    [warn]
    16:28:50.281
    [warn]
    16:28:50.283
    [warn]
    16:28:50.286
    [warn]
    16:28:50.289
    [warn]
    16:28:50.291
    [warn]
    16:28:50.294
    [warn]
    16:28:50.298
    [warn]
    16:28:50.302
    [warn]
    16:28:50.305
    [warn]
    16:28:50.308
    [warn]
    16:28:50.311
    [warn]
    16:28:50.313
    [warn]
    16:28:50.316
    [warn]
    16:28:50.319
    [warn]
    16:28:50.322
    [warn]
    16:28:50.324
    [warn]
    16:28:50.326
    [warn]
    16:28:50.328
    [warn]
    16:28:50.331
    [warn]
    16:28:50.333
    [warn]
    16:28:50.336
    [warn]
    16:28:50.337
    [warn]
    16:28:50.340
    [warn]
    16:28:50.342
    [warn]
    16:28:50.344
    [warn]
    16:28:50.346
    [warn]
    16:28:50.348
    [warn]
    16:28:50.351
    [warn]
    16:28:50.353
    [warn]
    16:28:50.364
    [warn]
    16:28:50.366
    [warn]
    16:28:50.367
    [warn]
    16:28:50.369
    [warn]
    16:28:50.371
    [warn]
    16:28:50.373
    [warn]
    16:28:50.375
    [warn]
    16:28:50.376
    [warn]
    16:28:50.378
    [warn]
    16:28:50.380
    [warn]
    16:28:50.381
    [warn]
    16:28:50.383
    [warn]
    16:28:50.385
    [warn]
    16:28:50.386
    [warn]
    16:28:50.388
    [warn]
    16:28:50.389
    [warn]
    16:28:50.391
    [warn]
    16:28:50.392
    [warn]
    16:28:50.394
    [warn]
    16:28:50.395
    [warn]
    16:28:50.397
    [warn]
    16:28:50.398
    [warn]
    16:28:50.400
    [warn]
    ich glaube er bekommt keine Daten…oder?~~@robsdobs:~~
    > Es kann sein das nach dem ersten starten dort überall 0 steht. Da dauert es dann etwas oder dann nochmal das Script stoppen und wieder starten `
    habe ich schon mehrmals neu gestartet!
    Was hab ich da falsch gemacht?
    Max
    ioBroker auf einem NUC ,16GB RAM, 120GB SSD) mit Proxmox
    Cloud Pro, iot, Alexa, Sonos, sonoff, Fronius, Harmony, Doorbird, Shelly, Hue, Loxone, Mihome, …
    • SmarthomeMFS
      SmarthomeMFS
      SmarthomeMF
      #86
      habe nun die Daten geprüft was angezeigt werden.
      für heute passt es …
      aber für die folgenden Tage wird überall der wert 0 angezeigt.
      auf der Homepage werden mehr angezeigt...
      https://www.wetteronline.de/pollen?fcda … paraid=Max
      Irgendwas geht da nicht!
      Hilfe blicke nicht ganz durch!
      Max
      • R
        R
        robsdobs
        #87
        @SmarthomeMF:
        Hilfe blicke nicht ganz durch! `
        Ich hab es für deinen Standort mal nachvollzogen.
        Mkit deiner Adresse funktioniert es nicht: https://www.wetteronline.de/pollen?fcda … paraid=Max
        Wenn man stattdessen folgende einträgt geht es: "https://www.wetteronline.de/pollen/perg";
        Robert
        Scripte: http://forum.iobroker.net/viewtopic.php?f=23&t=2799&p=119565#p119565,
        • SmarthomeMFS
          SmarthomeMFS
          SmarthomeMF
          #88
          @robsdobs:
          Wenn man stattdessen folgende einträgt geht es: "https://www.wetteronline.de/pollen/perg"; `
          Vielen Dank für die tolle Unterstützung hier…
          nun funktioniert das sehr gut.
          Danke für das tolle Skript.
          ich habe es so gelöst
          Max
          • L
            L
            ludino
            #89
            @ludino:
            Hast du nach dem Eintragen vom "Request" mit Speichern die Einstellungen verlassen? Sollte dann etwas dauern, weil er das Modul im Hintergrund installiert. Vielleicht auch mal im Tab Log schauen ob alles geht. `
            Jop ein tag gewartet, reingeschaut werte waren drin. Hat sich halt etwas geziert.
            Jetzt habe ich noch eine Frage zum Vis.
            Ist es möglich mir im Vis nur die Namen anzeigen zu lassen wo auch tatsächlich Pollenflug ist?
            Ich stelle es mir so vor, ich habe eine Status Seite mit einem Grünen, Gelben, Roten Punkt. Jenachdem welche Pollen fliegen neben diesen Punkte steht was für pollen fliegen. Grün (für Status 1 Schwach….... etc)
            Also sowas hier
            Wie das der Kollege gemacht hat.
            • R
              R
              robsdobs
              #90
              Ob es mit vis direkt geht weiß ich nicht.
              Wenn ich heute Abend Zeit finde, kann ich im Script auch noch eine Zusammenfassung pro Stufe für jeden Tag einfügen.
              • HomoranH
                #91
                Für diese Version hat mir @derAuge ein zweites Script geschrieben, das im Prinzip die Ergebnisse des Hauptscripts in Kategorien sammelt.
                • R
                  R
                  robsdobs
                  #92
                  Mein Kind schläft heute länger, daher hatte ich jetzt doch noch kurz zeit. :)
                  Ist jetzt im http://forum.iobroker.net/viewtopic.php?f=23&t=2799&p=119565#p119565 ab Version 1.5 mit drin.
                  Unter jedem Tag gibt es jetzt "count" mit der Anzahl je Kategorie, "text" und "html" mit einer Liste der Ergebnisse je Kategorie:
                  SegwayS 1 Antwort Letzte Antwort
                  • HomoranH
                    #93
                    Hallo robsdobs,
                    Nachdem die alte Version leider nicht mehr läuft, wollte ich jetzt auch auf die ganz neue umsteigen:
                    läuft bei mir auf error.
                    Ich habe allerdings nicht mehr den ganzen Thread (eigentlich alles was du verzapft hast) gelesen.
                    Falls da irgendwelche Dinge vorher definiert werden müssen - Sorry dafür.
                    • HomoranH
                      #94
                      EDIT:
                      Hat sich soweit erledigt, ich hatte das npm modul request vergessen. :oops:
                      Allerdings bleibt es bei diesen Warnings:
                      18:44:03.393	[warn]	javascript.0 at Request._callback (script.js.Pollenwetter_neu:279:21)
                      18:44:03.394	[warn]	javascript.0 at Request._callback (script.js.Pollenwetter_neu:279:21)
                      18:44:03.396	[warn]	javascript.0 at Request._callback (script.js.Pollenwetter_neu:279:21)
                      18:44:03.397	[warn]	javascript.0 at Request._callback (script.js.Pollenwetter_neu:279:21)
                      18:44:03.398	[warn]	javascript.0 at Request._callback (script.js.Pollenwetter_neu:279:21)
                      • R
                        R
                        robsdobs
                        #95
                        @Homoran:
                        Danke für den Hinweis, sollten jetzt mit der neuen https://forum.iobroker.net/viewtopic.php?f=23&t=2799&p=119565#p119565 weg sein.
                        • S
                          S
                          susi_a
                          #96
                          @robsdobs:
                          @Homoran:
                          Danke für den Hinweis, sollten jetzt mit der neuen https://forum.iobroker.net/viewtopic.php?f=23&t=2799&p=119565#p119565 weg sein. `
                          Hallo Robert,
                          vielen Dank für Dein Script - funktioniert bei mir auch wunderbar.
                          Kleine Info:
                          Die Warnmeldungen "Request._callback" bekomme ich jedoch auch noch mit dem aktuellen Script - Ursache scheint der Day6 (d6) zu sein - die Wettervorhersage ist mittlerweile wohl nur für 6 Tage (d0-d5) - Day6 (d6) ist aber wohl der 7.Tag.
                          javascript.0	2018-05-02 11:00:52.749	warn	State "wetter.pollenvorhersage.d6" not found
                          Viele Grüße
                          • R
                            R
                            RKBroker
                            #97
                            @SmarthomeMF:
                            @robsdobs:
                            ich habe es so gelöst `
                            @SmarthomeMF
                            Sieht super aus. Wie hast du das erstellt? Bin selber noch in der Lernphase…
                            • SmarthomeMFS
                              SmarthomeMFS
                              SmarthomeMF
                              #98
                              @RKBroker:
                              @SmarthomeMF
                              Sieht super aus. Wie hast du das erstellt? Bin selber noch in der Lernphase.. `
                              das war schon eine menge Arbeit…..
                              hier die erste Tabelle
                              [{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Heute","title_color":"black","title_top":"5","title_left":"5","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"67px","top":"151px","width":"182px","height":"594px","z-index":"5","background-color":"#969696","font-size":"xx-large"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Ambrosia","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"210px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Ampfer","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"249px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Beifuß","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"288px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Birke","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"326px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Buche","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"365px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Eiche","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"404px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Erle","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"443px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Gräser","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"481px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Hasel","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"520px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Pappel","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"559px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Roggen","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"598px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Ulme","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"636px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Wegerich","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"675px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"Weide","title_color":"#ffffff","title_top":"0","title_left":"0","header_height":"0","header_color":"black","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"79px","top":"714px","width":"113px","height":"28px","font-size":"x-large","font-variant":"small-caps","font-style":"","font-family":""Trebuchet MS", Arial, Helvetica, sans-serif","font-weight":"bold","z-index":"7","border-color":"","border-style":"none"},"widgetSet":"basic"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.ambrosia","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":"","signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.ambrosia","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.ambrosia","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.ambrosia"},"style":{"left":"173px","top":"209px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.ampfer","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.ampfer","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.ampfer","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.ampfer"},"style":{"left":"173px","top":"247px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.beifuß","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.beifuß","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.beifuß","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.beifuß"},"style":{"left":"173px","top":"286px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.birke","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.birke","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.birke","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.birke"},"style":{"left":"173px","top":"324px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"6","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.buche","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.buche","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.buche","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.buche"},"style":{"left":"173px","top":"363px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"6","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.eiche","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.eiche","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.eiche","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.eiche"},"style":{"left":"173px","top":"402px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.erle","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.erle","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.erle","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.erle"},"style":{"left":"173px","top":"440px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.gräser","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.gräser","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.gräser","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.gräser"},"style":{"left":"173px","top":"479px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.hasel","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.hasel","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.hasel","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.hasel"},"style":{"left":"173px","top":"517px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.pappel","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.pappel","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.pappel","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.pappel"},"style":{"left":"173px","top":"556px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.roggen","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.roggen","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.roggen","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.roggen"},"style":{"left":"173px","top":"595px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"6","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.ulme","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.ulme","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.ulme","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.ulme"},"style":{"left":"173px","top":"633px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.wegerich","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.wegerich","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.wegerich","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.wegerich"},"style":{"left":"173px","top":"672px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"},{"tpl":"tplHqOdometer","data":{"oid":"javascript.0.wetter.pollenvorhersage.d0.weide","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","style":"default","format":"(dd)","factor":"1","leadingZeros":"true","signals-cond-0":"==","signals-val-0":"1","signals-icon-0":"/icons-open-icon-library-png/actions/edit-remove-2.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"2","signals-icon-1":"/icons-open-icon-library-png/actions/rating.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"3","signals-icon-2":"/icons-open-icon-library-png/actions/media-playback-stop-7.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.wetter.pollenvorhersage.d0.weide","signals-oid-1":"javascript.0.wetter.pollenvorhersage.d0.weide","signals-oid-2":"javascript.0.wetter.pollenvorhersage.d0.weide"},"style":{"left":"173px","top":"711px","color":"#ffffff","width":"63px","height":"28px","text-align":"right","z-index":"7","border-color":""},"widgetSet":"hqwidgets"}]
                              dazu gehtst du im "Edit vis" auf den Button Widget Importieren und copierst da den Code rein.
                              das sieht dan so aus ![4668_unbenannt_03.png](/assets/uploads/files/4668_unbenannt_03.png)
                              Max
                              • R
                                R
                                RKBroker
                                #99
                                Super!! Vielen Dank. Muss wohl noch einiges lernen. Man bin ich ein Troll, hatte die Widget nicht installiert…
                                Nochmals vielen Dank!!!
                                • T
                                  T
                                  tomg1970
                                  #100
                                  Wow super Widget … Hast du das Bittttteeee für MORGEN auch?
                                  Welche Widgets muss ich installieren, um die farbigen Button zu haben?
                                  DANKEEE
                                  • kmxakK
                                    kmxakK
                                    kmxak
                                    #101
                                    bekomme seit neustem immer folgenden Fehler:
                                    17:53:03.666	[error]	javascript.0 script.js.User.Verschiedene.Pollenflug: script.js.User.Verschiedene.Pollenflug:9
                                    17:53:03.666	[error]	javascript.0 at script.js.User.Verschiedene.Pollenflug:9:23
                                    javascript.0	2018-06-07 17:51:17.240	error	at ContextifyScript.Script.runInContext (vm.js:35:29)
                                    javascript.0	2018-06-07 17:51:17.240	error	at script.js.User.Verschiedene.Pollenflug:9:23
                                    javascript.0	2018-06-07 17:51:17.239	error	ReferenceError: exports is not defined
                                    javascript.0	2018-06-07 17:51:17.239	error	^
                                    javascript.0	2018-06-07 17:51:17.239	error	Object.defineProperty(exports, "__esModule", { value: true });
                                    javascript.0	2018-06-07 17:51:17.239	error	script.js.User.Verschiedene.Pollenflug: script.js.User.Verschiedene.Pollenflug:9
                                    sagt mir aber nix, einer eine Idee?
                                    Gruß Alex
                                    • P
                                      P
                                      pix
                                      #102
                                      ich wollte eigentlich nur mal mein umfangreiches VIS Element für den Pollenflug sichern, dachte dann aber, es könnte vielleicht auch jemandem anderen helfen. Darum packe ich das mal ins Forum.
                                      Die Datenpunkte aus dem https://forum.iobroker.net/viewtopic.php?f=23&t=2799&hilit=pollenflug&start=60#p119565
                                      Die Tabellen-Überschrift ist noch nicht so schön formatiert, aber funktioniert.
                                      Für die Daten verwende ich das JUSTGAGE VALUE & INDICATOR Widget (bitte ggf. zuerst installieren)
                                      Widgets (nur als TXT-Datei, da zu viele Zeichen):
                                      Alle Datenpunkte liegen in der javascript-Instanz 2, also bitte "javascript.2" ggf. gegen z.B. "javascript.0" ersetzen
                                      261_pollenflug_widget.txt :
                                      Pix
                                      F 3 Antworten Letzte Antwort
                                      • R
                                        R
                                        robsdobs
                                        #103
                                        @kmxak:
                                        sagt mir aber nix, einer eine Idee? `
                                        Bitte den Javascript Adapter auf die neuste Version updaten und die neuste Version des Scriptes probieren.
                                        • F
                                          F
                                          Fatmax
                                          #104
                                          Ich bekomme leider immer folgende Fehlermeldung im Log.
                                          Auch die Objekte werden nicht angelegt.
                                          Hat jemand eine Idee?
                                          Liebe Grüße,
                                          Fatmax
                                          84.0k
