  4. Upgrad js-controller 1.2.3 -> 1.2.6 = Fehler
    6.3k
39 Beiträge 12 Kommentatoren 6.8k Aufrufe
    dering
    ich habe über folgenden Befehl:
    npm i yargs
    das Paket wieder installiert. Danach meckert iobroker stop auch nciht mehr:
    root@iobroker:/opt/iobroker# iobroker stop
    iobroker controller daemon is not running
    also nochmal ein iobroker upgrade self:
    root@iobroker:/opt/iobroker# iobroker upgrade self
    Update js-controller from @1.2.3 to @1.2.6
    npm install iobroker.js-controller@1.2.6 --production --prefix "/opt/iobroker" (System call)
    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    npm WARN optional Skipping failed optional dependency /iobroker.radar/noble/xpc-connection:
    npm WARN notsup Not compatible with your operating system or architecture: xpc-connection@0.1.4
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/cliui/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/cross-spawn/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/execa/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/gauge/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/lru-cache/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-pre-gyp/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/tar-pack/package.json'
    npm ERR! Linux 4.1.18-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller@1.2.6" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v6.3.1
    npm ERR! npm  v3.10.3
    npm ERR! path /opt/iobroker/node_modules/.staging/ansi-be95de54
    npm ERR! code ENOENT
    npm ERR! errno -2
    npm ERR! syscall rename
    npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/ansi-be95de54' -> '/opt/iobroker/node_modules/npm/node_modules/ansi'
    npm ERR! enoent This is most likely not a problem with npm itself
    npm ERR! enoent and is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log
    host.iobroker Cannot install iobroker.js-controller@1.2.6: 254
    Wer einen Kaffee spendieren will: https://paypal.me/HermannDering
    • arteckA Offline
      arteckA Offline
      arteck
      mach zuerst ein update node v6.3.1 auf 6.12.x oder 6.13.x
      • wendy2702W Online
        wendy2702W Online
        Habe das gleiche Problem an einem von drei Systemen.
        Alle 3 mit Jessie, an allen vor dem JS-Controller upgrade ein apt update & apt upgrade gemacht.
        Alle drei mit
        root@openmediavault /opt/iobroker > node -v
        v6.13.1
        root@openmediavault /opt/iobroker > npm -v
        3.10.10
        Auf den beiden Slave lief es ohne Probleme.
        Der Master bringt das:
        sudo iobroker upgrade self
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.enigma2/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis-mywidgets/package.json'
        npm ERR! Linux 4.9.0-0.bpo.5-amd64
        npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@1.2.6" "--production" "--prefix" "/opt/iobroker"
        npm ERR! node v6.13.1
        npm ERR! npm  v3.10.10
        npm ERR! path /opt/iobroker/node_modules/.staging/abbrev-bc1a4de2
        npm ERR! errno -2
        npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/abbrev-bc1a4de2' -> '/opt/iobroker/node_modules/npm/node_modules/abbrev'
        npm ERR! enoent
        host.openmediavault Cannot install iobroker.js-controller@1.2.6: 254
         Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json'
        EDIT: hiermit gelöst
        cd /opt/iobroker
        iobroker stop
        npm install iobroker.js-controller --production
        iobroker start
          dering
          @arteck:
          mach zuerst ein update node v6.3.1 auf 6.12.x oder 6.13.x `
          Ich schaffe es leider nicht auf die neueste Version zu aktualisieren…ich glaube irgendetwas ist ganz vermurkst...
          Ich bin auch irgendwann von nodejs 4.x auf 6.x gewechselt...vielleicht hat das damit zutun.
          Ich werde wohl die SD Karte mit einem aktuellen Image bespielen, mit neuestem nodejs usw. und dann das Backup einspielen.
            dering
            @wendy2702:
            cd /opt/iobroker
            iobroker stop
            iobroker start
            Hatte ich auch schon versucht…leider ohne Erfolg.
            Dennoch danke für Eure Ideen.
            • wendy2702W Online
              wendy2702W Online
              Wie hast du denn versucht den Upgrade von Node zu machen?
              Bei mir war das bei
              apt update
              apt upgrade
              Mit dabei
                knopers1
                ich habe gestern ein Upgrade vom Node gemacht.
                Habe jetzt:
                node v6.13.1
                npm  v3.10.10
                so bin ich vorgegangen.
                iobroker stop
                sudo apt-get --purge remove node
                sudo apt-get --purge remove nodejs
                sudo apt-get autoremove
                curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                sudo apt-get update && sudo apt-get upgrade
                sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev nodejs
                cd /opt/iobroker
                sudo ./reinstall.sh
                iobroker start
                Mit dem ./reinstall.sh dauerte es ewigkeiten…. Lässt sich Node irgendwie einfacher installieren? Vom Gefühl wurde alles erneut installiert. Dabei wollte ich nur den Node upgraden!
                • arteckA Offline
                  arteckA Offline
                  arteck
                  de reinstall würde ich erst dann ausführen wenn irgendwas nicht läuft
                  bzw bei ersionssprung von 4 auf 6 von 6 auf 8
                  • wendy2702W Online
                    wendy2702W Online
                    Ich habe den Node Upgrade gestern auch gemacht.
                    Version von 4 auf 6…
                    da ich scheinbar keine Adapter nutze die mit 6 noch nicht klar kommen lief bei mir alles und reinstall.sh war bisher nicht notwendig.
                    Wenn du schon eine Node 6.x drauf hast sollte ein upgrade wie schon geschrieben mit
                    apt update
                    apt upgrade
                    auf die aktuelle Node 6.x gehen.
                    War zumindest bei meinen zwei älteren Node 6 Systemen so.
                      dering
                      Fragt mich nicht was ich gemacht habe. Ich dachte schon ich hab das ganze System zerschossen.
                      Irgendwann hab ich den raspi einfach neugestartet und dann habe ich gesehen, dass er plötzlich alle Adapter wieder neuinstalliert.
                      Nach 20-30 Minuten war er fertig und es läuft wieder….
                      js-controller mit 1.2.6
                      Mir ist das trotzdem sehr koscher. Ich werde am Wochenende den Raspi neu installieren mit aktuellsten Versionen und spiele das Backup wieder ein.
                      • wendy2702W Online
                        wendy2702W Online
                        Na dann ;)
                        Kannst du das bitte noch im Titel als [Gelöst] markieren.
                        • C Offline
                          csamaggi
                          Da es auch bei mir Probleme gab mit dem Update auf 1.2.6.
                          Dort wurden dann einfach einige Adapter nicht mehr gestartet oder einfach beendet habe ich nun nach der Anleitung hier die Node aktualisiert.
                          Nun läuft es auf 1.2.6 so wie es scheint, jedoch kann ich kein Update auf 1.2.7 machen dann bekomme ich diese Meldung.
                          ` > Update js-controller from @1.2.6 to @1.2.7
                          NPM version: 5.6.0
                          NPM 5 is only supported starting with version 5.7.1!
                          Please use "npm install -g npm@4" to downgrade npm to 4.x or
                          use to install a supported version of npm 5!
                          You need to make sure to repeat this step after installing an update to NodeJS and/or npm
                          Ok dachte ich schau ich mal welche Version von NPM ich habe raus kam 3.10.10.
                          Dann habe ich der Anweisung im dortigen Text gefolgt aber ohne Erfolg.
                          Ich habe "npm install -g npm@>=5.7.1" ausgeführt aber das führte zu folgendem Fehler.
                          ` > npm install -g npm@=>5.7.1
                          npm ERR! Linux 4.9.0-3-amd64
                          npm ERR! argv "/usr/local/bin/node" "/usr/bin/npm" "install" "-g" "npm@="
                          npm ERR! node v9.8.0
                          npm ERR! code ETARGET
                          npm ERR! notarget No compatible version found: npm@=
                          npm ERR! notarget Valid install targets:
                          npm ERR! notarget 5.7.1, 5.7.0, 5.6.0, 5.5.1, 5.5.0, 5.4.2, 5.4.1, 5.4.0, 5.3.0, 5.2.0, 5.1.0, 5.0.4, 5.0.3, 5.0.2, 5.0.1, 5.0.0, 4.6.1, 4.6.0, 4.5.0, 4.4.4, 4.4.3, 4.4.2, 4.4.1, 4.4.0, 4.3.0, 4.2.0, 4.1.2, 4.1.1, 4.1.0, 4.0.5, 4.0.3, 4.0.2, 4.0.1, 4.0.0, 3.10.10, 3.10.9, 3.10.8, 3.10.7, 3.10.6, 3.10.5, 3.10.4, 3.10.3, 3.10.2, 3.10.1, 3.10.0, 3.9.6, 3.9.5, 3.9.4, 3.9.3, 3.9.2, 3.9.1, 3.9.0, 3.8.9, 3.8.8, 3.8.7, 3.8.6, 3.8.5, 3.8.4, 3.8.3, 3.8.2, 3.8.1, 3.8.0, 3.7.5, 3.7.4, 3.7.3, 3.7.2, 3.7.1, 3.7.0, 3.6.0, 3.5.4, 3.5.3, 3.5.2, 3.5.1, 3.5.0, 3.4.1, 3.4.0, 3.3.12, 3.3.11, 3.3.10, 3.3.9, 3.3.8, 3.3.7, 3.3.6, 3.3.5, 3.3.4, 3.3.3, 3.3.2, 3.3.1, 3.3.0, 3.2.2, 3.2.1, 3.2.0, 3.1.3, 3.1.2, 3.1.1, 3.1.0, 3.0.0, 2.15.12, 2.15.11, 2.15.10, 2.15.9, 2.15.8, 2.15.7, 2.15.6, 2.15.5, 2.15.4, 2.15.3, 2.15.2, 2.15.1, 2.15.0, 2.14.22, 2.14.21, 2.14.20, 2.14.19, 2.14.18, 2.14.17, 2.14.16, 2.14.15, 2.14.14, 2.14.13, 2.14.12, 2.14.11, 2.14.10, 2.14.9, 2.14.8, 2.14.7, 2.14.6, 2.14.5, 2.14.4, 2.14.3, 2.14.2, 2.14.1, 2.14.0, 2.13.5, 2.13.4, 2.13.3, 2.13.2, 2.13.1, 2.13.0, 2.12.1, 2.12.0, 2.11.3, 2.11.2, 2.11.1, 2.11.0, 2.10.1, 2.10.0, 2.9.1, 2.9.0, 2.8.4, 2.8.3, 2.8.2, 2.8.1, 2.8.0, 2.7.6, 2.7.5, 2.7.4, 2.7.3, 2.7.2, 2.7.1, 2.7.0, 2.6.1, 2.6.0, 2.5.1, 2.5.0, 2.4.1, 2.4.0, 2.3.0, 2.2.0, 2.1.18, 2.1.17, 2.1.16, 2.1.15, 2.1.14, 2.1.13, 2.1.12, 2.1.11, 2.1.10, 2.1.9, 2.1.8, 2.1.7, 2.1.6, 2.1.5, 2.1.4, 2.1.3, 2.1.2, 2.1.1, 2.1.0, 2.0.2, 2.0.1, 2.0.0, 2.0.0-beta.3, 2.0.0-beta.2, 2.0.0-beta.1, 2.0.0-beta.0, 2.0.0-alpha-5, 2.0.0-alpha.7, 2.0.0-alpha.6.0, 2.0.0-alpha.6, 1.5.0-alpha-4, 1.5.0-alpha-3, 1.5.0-alpha-2, 1.5.0-alpha-1, 1.5.0-alpha-0, 1.4.29, 1.4.28, 1.4.27, 1.4.26, 1.4.25, 1.4.24, 1.4.23, 1.4.22, 1.4.21, 1.4.20, 1.4.19, 1.4.18, 1.4.17, 1.4.16, 1.4.15, 1.4.14, 1.4.13, 1.4.12, 1.4.11, 1.4.10, 1.4.9, 1.4.8, 1.4.7, 1.4.6, 1.4.5, 1.4.4, 1.4.3, 1.4.2, 1.4.1, 1.4.0, 1.3.26, 1.3.25, 1.3.24, 1.3.23, 1.3.22, 1.3.21, 1.3.20, 1.3.18, 1.3.17, 1.3.16, 1.3.15, 1.3.14, 1.3.13, 1.3.12, 1.3.11, 1.3.10, 1.3.9, 1.3.8, 1.3.7, 1.3.6, 1.3.5, 1.3.4, 1.3.2, 1.3.1, 1.3.0, 1.2.8000, 1.2.32, 1.2.31, 1.2.30, 1.2.28, 1.2.27, 1.2.25, 1.2.24, 1.2.23, 1.2.22, 1.2.21, 1.2.20, 1.2.19, 1.1.71, 1.1.70, 1.1.25
                          npm ERR! notarget
                          npm ERR! notarget This is most likely not a problem with npm itself.
                          npm ERR! notarget In most cases you or one of your dependencies are requesting
                          npm ERR! notarget a package version that doesn't exist.
                          npm ERR! /home/io/npm-debug.log `
                          Hoffe ihr könnt mir da weiterhelfen.
                          Wie gesagt bisher scheint es mit der Versio 1.2.6 zu laufen aber wenn ich später noch updaten will ist es wohl unausweichlich die NPM upzudaten.
                          MFG Maggi
                            MrLee
                            Moin!
                            Habe auf 2 Hosts keine Probleme gehabt und auf dem Raspi mit node8 ebenfalls die Warnmeldung.
                            Bei mir half:
                            npm i -g npm
                            (allerdings 2 mal…)
                            bis denne
                            Mr.Lee
                            • AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @csamaggi:
                              Ne hast du nicht. Du hast > und = vertauscht ;) ">=" ist richtig, "=>" falsch!
                              • C Offline
                                csamaggi
                                Ich Dusel, danke AlCalzone.
                                Wieder selbst zu schnell gewesen und nicht richtig gelesen.
                                MFG Maggi
                                • wendy2702W Online
                                  wendy2702W Online
                                  @MrLee:
                                  Moin!
                                  Bei mir half:
                                  npm i -g npm
                                  (allerdings 2 mal…)
                                  bis denne
                                  Mr.Lee `
                                  Der Tipp war Gold Wert.
                                  Nachdem ich gestern auf meinem Host auf 1.2.6 bin heute dann auf 1.2.7 aber wie zu erwarten nicht ohne Probleme.
                                  Letztendlich bin ich dann auf diese Zeile aufmerksam geworden nachdem ich einmal````
                                  npm -i -g npm
                                  npm WARN npm@2.15.12 had bundled packages that do not match the required version(s). They have been replaced with non-bundled versions.
                                  root@openmediavault /opt/iobroker > npm install iobroker.js-controller --production
                                  npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but npm-shrinkwrap.json was generated for lockfileVersion@0. I'll try to do my best with it!
                                  npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none is installed. You must install peer dependencies yourself.
                                  npm ERR! path /opt/iobroker/node_modules/npm/node_modules/abbrev
                                  npm ERR! errno -2
                                  npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/npm/node_modules/abbrev' -> '/opt/iobroker/node_modules/npm/node_modules/.abbrev.DELETE'
                                  npm ERR! enoent This is related to npm not being able to find a file.
                                  npm ERR! enoent
                                  npm ERR! /root/.npm/_logs/2018-03-09T19_31_13_963Z-debug.log
                                  Obwohl ich bei der Abfrage nach Node und NPM wie auch im log zu sehen diese Versionen hatte:
                                  Wird scheinbar bei der JS-Controller installation auf eine "globale" NPM installation zurück gegriffen!?
                                  Interessanter weise habe ich jetzt folgende Versionen:
                                  5.7.1
                                  v6.13.1
                                  Wer weiß was das wieder für Probleme verursacht… :cry:
                                  EDIT: 22 Instanzen bleiben auf ROT
                                  Ich habe keine Lust mehr :roll:
                                    AlCalzoneA Offline
                                    AlCalzone
                                    @wendy2702:
                                    5.7.1
                                    v6.13.1
                                    Hast du 2 NPM mit unterschiedlichen Versionen parallel installiert? Was gibt
                                    which npm
                                    aus?
                                    npm sollte IMMER global installiert sein
                                    • wendy2702W Online
                                      wendy2702W Online
                                      Guten Morgen,
                                      bei der Installation von NPM und Node habe ich mich bisher immer an diese Anleitung gehalten:
                                      http://www.iobroker.net/docu/?page_id=5106&lang=de
                                      Abfrage ergibt das:
                                      root@openmediavault ~ > which npm
                                      /usr/bin/npm
                                      Was bedeutet das jetzt für mich?
                                      Sollte ich passend zu NPM5 auch Node upgraden?
                                        AlCalzoneA Offline
                                        AlCalzone
                                        Ich wundere mich nur, dass du in deinen Logs sowohl 3.10.10 (von npm -v) als auch 5.7.1 (von js-controller erkant) hast.
                                        Die Ausgabe stimmt mit meiner überein, das sagt erst mal nix.
                                        Was ich gerade festgestellt habe…
                                        Der empfohlene Befehl zum npm-Update hat einen Fehler. Es muss
                                        sudo npm i -g "npm@>=5.7.1"
                                        heißen (mit Anführungszeichen!), NICHT
                                        sudo npm i -g npm@>=5.7.1
                                        Aber du bist ja schon einen Schritt weiter:
                                        Was sagt der ioBroker-Log?
                                          Hallo Mirko,
                                          Ich denke wir sollten uns mal zusammensetzen.
                                          Gottseidank ist es herzogenrath und nicht Herzogenaurach :P
                                          "Spielst" du an deiner produktiven Umgebung?
                                          Gruß Rainer
