  4. Upgrad js-controller 1.2.3 -> 1.2.6 = Fehler
    6.3k
39 Beiträge 12 Kommentatoren 6.8k Aufrufe
  • wendy2702W Online
    wendy2702W Online
    Habe das gleiche Problem an einem von drei Systemen.
    Alle 3 mit Jessie, an allen vor dem JS-Controller upgrade ein apt update & apt upgrade gemacht.
    Alle drei mit
    root@openmediavault /opt/iobroker > node -v
    v6.13.1
    root@openmediavault /opt/iobroker > npm -v
    3.10.10
    Auf den beiden Slave lief es ohne Probleme.
    Der Master bringt das:
    sudo iobroker upgrade self
    Update js-controller from @1.2.3 to @1.2.6
    npm install iobroker.js-controller@1.2.6 --production --prefix "/opt/iobroker" (System call)
    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.enigma2/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis-mywidgets/package.json'
    npm ERR! Linux 4.9.0-0.bpo.5-amd64
    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@1.2.6" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v6.13.1
    npm ERR! npm  v3.10.10
    npm ERR! path /opt/iobroker/node_modules/.staging/abbrev-bc1a4de2
    npm ERR! code ENOENT
    npm ERR! errno -2
    npm ERR! syscall rename
    npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/abbrev-bc1a4de2' -> '/opt/iobroker/node_modules/npm/node_modules/abbrev'
    npm ERR! enoent This is most likely not a problem with npm itself
    npm ERR! enoent and is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log
    host.openmediavault Cannot install iobroker.js-controller@1.2.6: 254
     Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json'
    EDIT: hiermit gelöst
    cd /opt/iobroker
    iobroker stop
    npm install iobroker.js-controller --production
    iobroker start
      dering
      @arteck:
      mach zuerst ein update node v6.3.1 auf 6.12.x oder 6.13.x `
      Ich schaffe es leider nicht auf die neueste Version zu aktualisieren…ich glaube irgendetwas ist ganz vermurkst...
      Ich bin auch irgendwann von nodejs 4.x auf 6.x gewechselt...vielleicht hat das damit zutun.
      Ich werde wohl die SD Karte mit einem aktuellen Image bespielen, mit neuestem nodejs usw. und dann das Backup einspielen.
      Wer einen Kaffee spendieren will: https://paypal.me/HermannDering
        dering
        @wendy2702:
        cd /opt/iobroker
        iobroker stop
        iobroker start
        Hatte ich auch schon versucht…leider ohne Erfolg.
        Dennoch danke für Eure Ideen.
        • wendy2702W Online
          wendy2702W Online
          Wie hast du denn versucht den Upgrade von Node zu machen?
          Bei mir war das bei
          apt update
          apt upgrade
          Mit dabei
            knopers1
            ich habe gestern ein Upgrade vom Node gemacht.
            Habe jetzt:
            node v6.13.1
            npm  v3.10.10
            so bin ich vorgegangen.
            iobroker stop
            sudo apt-get --purge remove node
            sudo apt-get --purge remove nodejs
            sudo apt-get autoremove
            curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
            sudo apt-get update && sudo apt-get upgrade
            sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev nodejs
            cd /opt/iobroker
            sudo ./reinstall.sh
            iobroker start
            Mit dem ./reinstall.sh dauerte es ewigkeiten…. Lässt sich Node irgendwie einfacher installieren? Vom Gefühl wurde alles erneut installiert. Dabei wollte ich nur den Node upgraden!
            • arteckA Offline
              arteckA Offline
              arteck
              de reinstall würde ich erst dann ausführen wenn irgendwas nicht läuft
              bzw bei ersionssprung von 4 auf 6 von 6 auf 8
              • wendy2702W Online
                wendy2702W Online
                Ich habe den Node Upgrade gestern auch gemacht.
                Version von 4 auf 6…
                da ich scheinbar keine Adapter nutze die mit 6 noch nicht klar kommen lief bei mir alles und reinstall.sh war bisher nicht notwendig.
                Wenn du schon eine Node 6.x drauf hast sollte ein upgrade wie schon geschrieben mit
                apt update
                apt upgrade
                auf die aktuelle Node 6.x gehen.
                War zumindest bei meinen zwei älteren Node 6 Systemen so.
                  dering
                  Fragt mich nicht was ich gemacht habe. Ich dachte schon ich hab das ganze System zerschossen.
                  Irgendwann hab ich den raspi einfach neugestartet und dann habe ich gesehen, dass er plötzlich alle Adapter wieder neuinstalliert.
                  Nach 20-30 Minuten war er fertig und es läuft wieder….
                  js-controller mit 1.2.6
                  Mir ist das trotzdem sehr koscher. Ich werde am Wochenende den Raspi neu installieren mit aktuellsten Versionen und spiele das Backup wieder ein.
                  • wendy2702W Online
                    wendy2702W Online
                    Na dann ;)
                    Kannst du das bitte noch im Titel als [Gelöst] markieren.
                    • C Offline
                      csamaggi
                      Da es auch bei mir Probleme gab mit dem Update auf 1.2.6.
                      Dort wurden dann einfach einige Adapter nicht mehr gestartet oder einfach beendet habe ich nun nach der Anleitung hier die Node aktualisiert.
                      Nun läuft es auf 1.2.6 so wie es scheint, jedoch kann ich kein Update auf 1.2.7 machen dann bekomme ich diese Meldung.
                      ` > Update js-controller from @1.2.6 to @1.2.7
                      NPM version: 5.6.0
                      NPM 5 is only supported starting with version 5.7.1!
                      Please use "npm install -g npm@4" to downgrade npm to 4.x or
                      use to install a supported version of npm 5!
                      You need to make sure to repeat this step after installing an update to NodeJS and/or npm
                      Ok dachte ich schau ich mal welche Version von NPM ich habe raus kam 3.10.10.
                      Dann habe ich der Anweisung im dortigen Text gefolgt aber ohne Erfolg.
                      Ich habe "npm install -g npm@>=5.7.1" ausgeführt aber das führte zu folgendem Fehler.
                      ` > npm install -g npm@=>5.7.1
                      npm ERR! Linux 4.9.0-3-amd64
                      npm ERR! argv "/usr/local/bin/node" "/usr/bin/npm" "install" "-g" "npm@="
                      npm ERR! node v9.8.0
                      npm ERR! code ETARGET
                      npm ERR! notarget No compatible version found: npm@=
                      npm ERR! notarget Valid install targets:
                      npm ERR! notarget 5.7.1, 5.7.0, 5.6.0, 5.5.1, 5.5.0, 5.4.2, 5.4.1, 5.4.0, 5.3.0, 5.2.0, 5.1.0, 5.0.4, 5.0.3, 5.0.2, 5.0.1, 5.0.0, 4.6.1, 4.6.0, 4.5.0, 4.4.4, 4.4.3, 4.4.2, 4.4.1, 4.4.0, 4.3.0, 4.2.0, 4.1.2, 4.1.1, 4.1.0, 4.0.5, 4.0.3, 4.0.2, 4.0.1, 4.0.0, 3.10.10, 3.10.9, 3.10.8, 3.10.7, 3.10.6, 3.10.5, 3.10.4, 3.10.3, 3.10.2, 3.10.1, 3.10.0, 3.9.6, 3.9.5, 3.9.4, 3.9.3, 3.9.2, 3.9.1, 3.9.0, 3.8.9, 3.8.8, 3.8.7, 3.8.6, 3.8.5, 3.8.4, 3.8.3, 3.8.2, 3.8.1, 3.8.0, 3.7.5, 3.7.4, 3.7.3, 3.7.2, 3.7.1, 3.7.0, 3.6.0, 3.5.4, 3.5.3, 3.5.2, 3.5.1, 3.5.0, 3.4.1, 3.4.0, 3.3.12, 3.3.11, 3.3.10, 3.3.9, 3.3.8, 3.3.7, 3.3.6, 3.3.5, 3.3.4, 3.3.3, 3.3.2, 3.3.1, 3.3.0, 3.2.2, 3.2.1, 3.2.0, 3.1.3, 3.1.2, 3.1.1, 3.1.0, 3.0.0, 2.15.12, 2.15.11, 2.15.10, 2.15.9, 2.15.8, 2.15.7, 2.15.6, 2.15.5, 2.15.4, 2.15.3, 2.15.2, 2.15.1, 2.15.0, 2.14.22, 2.14.21, 2.14.20, 2.14.19, 2.14.18, 2.14.17, 2.14.16, 2.14.15, 2.14.14, 2.14.13, 2.14.12, 2.14.11, 2.14.10, 2.14.9, 2.14.8, 2.14.7, 2.14.6, 2.14.5, 2.14.4, 2.14.3, 2.14.2, 2.14.1, 2.14.0, 2.13.5, 2.13.4, 2.13.3, 2.13.2, 2.13.1, 2.13.0, 2.12.1, 2.12.0, 2.11.3, 2.11.2, 2.11.1, 2.11.0, 2.10.1, 2.10.0, 2.9.1, 2.9.0, 2.8.4, 2.8.3, 2.8.2, 2.8.1, 2.8.0, 2.7.6, 2.7.5, 2.7.4, 2.7.3, 2.7.2, 2.7.1, 2.7.0, 2.6.1, 2.6.0, 2.5.1, 2.5.0, 2.4.1, 2.4.0, 2.3.0, 2.2.0, 2.1.18, 2.1.17, 2.1.16, 2.1.15, 2.1.14, 2.1.13, 2.1.12, 2.1.11, 2.1.10, 2.1.9, 2.1.8, 2.1.7, 2.1.6, 2.1.5, 2.1.4, 2.1.3, 2.1.2, 2.1.1, 2.1.0, 2.0.2, 2.0.1, 2.0.0, 2.0.0-beta.3, 2.0.0-beta.2, 2.0.0-beta.1, 2.0.0-beta.0, 2.0.0-alpha-5, 2.0.0-alpha.7, 2.0.0-alpha.6.0, 2.0.0-alpha.6, 1.5.0-alpha-4, 1.5.0-alpha-3, 1.5.0-alpha-2, 1.5.0-alpha-1, 1.5.0-alpha-0, 1.4.29, 1.4.28, 1.4.27, 1.4.26, 1.4.25, 1.4.24, 1.4.23, 1.4.22, 1.4.21, 1.4.20, 1.4.19, 1.4.18, 1.4.17, 1.4.16, 1.4.15, 1.4.14, 1.4.13, 1.4.12, 1.4.11, 1.4.10, 1.4.9, 1.4.8, 1.4.7, 1.4.6, 1.4.5, 1.4.4, 1.4.3, 1.4.2, 1.4.1, 1.4.0, 1.3.26, 1.3.25, 1.3.24, 1.3.23, 1.3.22, 1.3.21, 1.3.20, 1.3.18, 1.3.17, 1.3.16, 1.3.15, 1.3.14, 1.3.13, 1.3.12, 1.3.11, 1.3.10, 1.3.9, 1.3.8, 1.3.7, 1.3.6, 1.3.5, 1.3.4, 1.3.2, 1.3.1, 1.3.0, 1.2.8000, 1.2.32, 1.2.31, 1.2.30, 1.2.28, 1.2.27, 1.2.25, 1.2.24, 1.2.23, 1.2.22, 1.2.21, 1.2.20, 1.2.19, 1.1.71, 1.1.70, 1.1.25
                      npm ERR! notarget
                      npm ERR! notarget This is most likely not a problem with npm itself.
                      npm ERR! notarget In most cases you or one of your dependencies are requesting
                      npm ERR! notarget a package version that doesn't exist.
                      npm ERR! /home/io/npm-debug.log `
                      Hoffe ihr könnt mir da weiterhelfen.
                      Wie gesagt bisher scheint es mit der Versio 1.2.6 zu laufen aber wenn ich später noch updaten will ist es wohl unausweichlich die NPM upzudaten.
                      MFG Maggi
                        MrLee
                        Moin!
                        Habe auf 2 Hosts keine Probleme gehabt und auf dem Raspi mit node8 ebenfalls die Warnmeldung.
                        Bei mir half:
                        npm i -g npm
                        (allerdings 2 mal…)
                        bis denne
                        Mr.Lee
                        • AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          @csamaggi:
                          Ne hast du nicht. Du hast > und = vertauscht ;) ">=" ist richtig, "=>" falsch!
                          • C Offline
                            csamaggi
                            Ich Dusel, danke AlCalzone.
                            Wieder selbst zu schnell gewesen und nicht richtig gelesen.
                            MFG Maggi
                            • wendy2702W Online
                              wendy2702W Online
                              @MrLee:
                              Moin!
                              Bei mir half:
                              npm i -g npm
                              (allerdings 2 mal…)
                              bis denne
                              Mr.Lee `
                              Der Tipp war Gold Wert.
                              Nachdem ich gestern auf meinem Host auf 1.2.6 bin heute dann auf 1.2.7 aber wie zu erwarten nicht ohne Probleme.
                              Letztendlich bin ich dann auf diese Zeile aufmerksam geworden nachdem ich einmal````
                              npm -i -g npm
                              npm WARN npm@2.15.12 had bundled packages that do not match the required version(s). They have been replaced with non-bundled versions.
                              root@openmediavault /opt/iobroker > npm install iobroker.js-controller --production
                              npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but npm-shrinkwrap.json was generated for lockfileVersion@0. I'll try to do my best with it!
                              npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none is installed. You must install peer dependencies yourself.
                              npm ERR! path /opt/iobroker/node_modules/npm/node_modules/abbrev
                              npm ERR! errno -2
                              npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/npm/node_modules/abbrev' -> '/opt/iobroker/node_modules/npm/node_modules/.abbrev.DELETE'
                              npm ERR! enoent This is related to npm not being able to find a file.
                              npm ERR! enoent
                              npm ERR! /root/.npm/_logs/2018-03-09T19_31_13_963Z-debug.log
                              Obwohl ich bei der Abfrage nach Node und NPM wie auch im log zu sehen diese Versionen hatte:
                              Wird scheinbar bei der JS-Controller installation auf eine "globale" NPM installation zurück gegriffen!?
                              Interessanter weise habe ich jetzt folgende Versionen:
                              5.7.1
                              v6.13.1
                              Wer weiß was das wieder für Probleme verursacht… :cry:
                              EDIT: 22 Instanzen bleiben auf ROT
                              Ich habe keine Lust mehr :roll:
                                AlCalzoneA Offline
                                AlCalzone
                                @wendy2702:
                                5.7.1
                                v6.13.1
                                Hast du 2 NPM mit unterschiedlichen Versionen parallel installiert? Was gibt
                                which npm
                                aus?
                                npm sollte IMMER global installiert sein
                                • wendy2702W Online
                                  wendy2702W Online
                                  Guten Morgen,
                                  bei der Installation von NPM und Node habe ich mich bisher immer an diese Anleitung gehalten:
                                  http://www.iobroker.net/docu/?page_id=5106&lang=de
                                  Abfrage ergibt das:
                                  root@openmediavault ~ > which npm
                                  /usr/bin/npm
                                  Was bedeutet das jetzt für mich?
                                  Sollte ich passend zu NPM5 auch Node upgraden?
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Ich wundere mich nur, dass du in deinen Logs sowohl 3.10.10 (von npm -v) als auch 5.7.1 (von js-controller erkant) hast.
                                    Die Ausgabe stimmt mit meiner überein, das sagt erst mal nix.
                                    Was ich gerade festgestellt habe…
                                    Der empfohlene Befehl zum npm-Update hat einen Fehler. Es muss
                                    sudo npm i -g "npm@>=5.7.1"
                                    heißen (mit Anführungszeichen!), NICHT
                                    sudo npm i -g npm@>=5.7.1
                                    Aber du bist ja schon einen Schritt weiter:
                                    Was sagt der ioBroker-Log?
                                      Hallo Mirko,
                                      Ich denke wir sollten uns mal zusammensetzen.
                                      Gottseidank ist es herzogenrath und nicht Herzogenaurach :P
                                      "Spielst" du an deiner produktiven Umgebung?
                                      Gruß Rainer
                                      • wendy2702W Online
                                        wendy2702W Online
                                        Da mit den Instanzen hat sich gestern Nacht erledigt.
                                        Nach einem iobroker restart hat er alle Instanzen mit dem NPM 5.7.1 neu installiert.
                                        Hat nur ein wenig gedauert und ich hatte keine Lust mehr zu warten.
                                        Aktuell läuft er wieder.
                                        Bleibt nur noch die Frage nach kombination Node & NPM ?
                                        Achja, und was mache ich mit meinen Slaves?
                                        Die sehen alle so aus:
                                        pi@iobroker-garage-gross:~ $ which npm
                                        /usr/bin/npm
                                        pi@iobroker-garage-gross:~ $ npm -v
                                        3.10.10
                                        pi@iobroker-garage-gross:~ $ node -v
                                        v6.13.1
                                        • wendy2702W Online
                                          wendy2702W Online
                                          @Homoran:
                                          Hallo Mirko,
                                          Gruß Rainer `
                                          Hi Rainer,
                                          willst du mir die Ohren lang ziehen !? :D
                                          Nächste Woche ist es eher Herzogenaurach ;)
                                          Ja, ist mein Produktiv System aber keine Panik… davon habe ich quasi 2. Bedeutet immer eine SSD mit Backup vorhanden.
                                          Mirko
