  4. Upgrad js-controller 1.2.3 -> 1.2.6 = Fehler
    1.0k
    3.2k
39 Beiträge 12 Kommentatoren 6.5k Aufrufe
  • D Online
    D Online
    dering
    eigentlich wollte ich einfach nur den js-controller auf die neueste Version aktualisieren, jedoch erhalte ich Fehler.
    Ich hab es wie beschrieben durchgeführt:
    cd /opt/iobroker
    iobroker stop
    iobroker update
    iobroker upgrade self
    Leider kann ich auf die ganz alten Ausgaben nicht mehr zugreifen. Wenn ich versuche iobroker zu starten, erhalte ich folgende Meldung:
    root@iobroker:/opt/iobroker# iobroker start
    module.js:442
        throw err;
    Error: Cannot find module 'yargs'
        at Function.Module._resolveFilename (module.js:440:15)
        at Function.Module._load (module.js:388:25)
        at Module.require (module.js:468:17)
        at require (internal/module.js:20:19)
        at initYargs (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:28:13)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3097:18)
        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
        at Module._compile (module.js:541:32)
        at Object.Module._extensions..js (module.js:550:10)
        at Module.load (module.js:458:32)</anonymous>
    root@iobroker:/opt/iobroker# iobroker update
    module.js:442
        throw err;
    root@iobroker:/opt/iobroker# npm cache clean
    root@iobroker:/opt/iobroker# npm install iobroker.js-controller --production
    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    iobroker@1.0.0 /opt/iobroker
    +-- iobroker.admin@3.2.4  extraneous
    +-- mime@1.6.0  extraneous
    +-- tar@4.4.0  extraneous
    +-- winston-syslog@2.0.0  extraneous
    `-- yargs@11.0.0  extraneous
    npm WARN optional Skipping failed optional dependency /iobroker.radar/noble/xpc-connection:
    npm WARN notsup Not compatible with your operating system or architecture: xpc-connection@0.1.4
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/cliui/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/cross-spawn/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/execa/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/gauge/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/lru-cache/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-pre-gyp/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/tar-pack/package.json'
    npm ERR! Linux 4.1.18-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller" "--production"
    npm ERR! node v6.3.1
    npm ERR! npm  v3.10.3
    npm ERR! path /opt/iobroker/node_modules/.staging/abbrev-bc1a4de2
    npm ERR! code ENOENT
    npm ERR! errno -2
    npm ERR! syscall rename
    npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/abbrev-bc1a4de2' -> '/opt/iobroker/node_modules/npm/node_modules/abbrev'
    npm ERR! enoent This is most likely not a problem with npm itself
    npm ERR! enoent and is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log
    Ich weiß nicht mehr weiter. Wer hat Ideen?
    Wer einen Kaffee spendieren will: https://paypal.me/HermannDering
    • D Online
      D Online
      dering
      ich habe über folgenden Befehl:
      npm i yargs
      das Paket wieder installiert. Danach meckert iobroker stop auch nciht mehr:
      root@iobroker:/opt/iobroker# iobroker stop
      iobroker controller daemon is not running
      also nochmal ein iobroker upgrade self:
      root@iobroker:/opt/iobroker# iobroker upgrade self
      Update js-controller from @1.2.3 to @1.2.6
      npm install iobroker.js-controller@1.2.6 --production --prefix "/opt/iobroker" (System call)
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller@1.2.6" "--production" "--prefix" "/opt/iobroker"
      npm ERR! path /opt/iobroker/node_modules/.staging/ansi-be95de54
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/ansi-be95de54' -> '/opt/iobroker/node_modules/npm/node_modules/ansi'
      npm ERR! enoent
      host.iobroker Cannot install iobroker.js-controller@1.2.6: 254
      • arteckA Offline
        arteckA Offline
        arteck
        mach zuerst ein update node v6.3.1 auf 6.12.x oder 6.13.x
        • wendy2702W Offline
          wendy2702W Offline
          Habe das gleiche Problem an einem von drei Systemen.
          Alle 3 mit Jessie, an allen vor dem JS-Controller upgrade ein apt update & apt upgrade gemacht.
          Alle drei mit
          root@openmediavault /opt/iobroker > node -v
          v6.13.1
          root@openmediavault /opt/iobroker > npm -v
          3.10.10
          Auf den beiden Slave lief es ohne Probleme.
          Der Master bringt das:
          sudo iobroker upgrade self
          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.enigma2/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis-mywidgets/package.json'
          npm ERR! Linux 4.9.0-0.bpo.5-amd64
          npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@1.2.6" "--production" "--prefix" "/opt/iobroker"
          npm ERR! node v6.13.1
          npm ERR! npm  v3.10.10
          npm ERR! errno -2
          npm ERR! enoent
          host.openmediavault Cannot install iobroker.js-controller@1.2.6: 254
           Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json'
          EDIT: hiermit gelöst
          cd /opt/iobroker
          iobroker stop
          iobroker start
          • D Online
            D Online
            dering
            @arteck:
            mach zuerst ein update node v6.3.1 auf 6.12.x oder 6.13.x `
            Ich schaffe es leider nicht auf die neueste Version zu aktualisieren…ich glaube irgendetwas ist ganz vermurkst...
            Ich bin auch irgendwann von nodejs 4.x auf 6.x gewechselt...vielleicht hat das damit zutun.
            Ich werde wohl die SD Karte mit einem aktuellen Image bespielen, mit neuestem nodejs usw. und dann das Backup einspielen.
            • D Online
              D Online
              dering
              @wendy2702:
              cd /opt/iobroker
              iobroker stop
              iobroker start
              Hatte ich auch schon versucht…leider ohne Erfolg.
              Dennoch danke für Eure Ideen.
                wendy2702W Offline
                Wie hast du denn versucht den Upgrade von Node zu machen?
                Bei mir war das bei
                apt update
                apt upgrade
                Mit dabei
                  knopers1
                  ich habe gestern ein Upgrade vom Node gemacht.
                  Habe jetzt:
                  node v6.13.1
                  npm  v3.10.10
                  so bin ich vorgegangen.
                  iobroker stop
                  sudo apt-get --purge remove node
                  sudo apt-get --purge remove nodejs
                  sudo apt-get autoremove
                  curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                  sudo apt-get update && sudo apt-get upgrade
                  sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev nodejs
                  cd /opt/iobroker
                  sudo ./reinstall.sh
                  iobroker start
                  Mit dem ./reinstall.sh dauerte es ewigkeiten…. Lässt sich Node irgendwie einfacher installieren? Vom Gefühl wurde alles erneut installiert. Dabei wollte ich nur den Node upgraden!
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    de reinstall würde ich erst dann ausführen wenn irgendwas nicht läuft
                    bzw bei ersionssprung von 4 auf 6 von 6 auf 8
                      wendy2702W Offline
                      Ich habe den Node Upgrade gestern auch gemacht.
                      Version von 4 auf 6…
                      da ich scheinbar keine Adapter nutze die mit 6 noch nicht klar kommen lief bei mir alles und reinstall.sh war bisher nicht notwendig.
                      Wenn du schon eine Node 6.x drauf hast sollte ein upgrade wie schon geschrieben mit
                      apt update
                      apt upgrade
                      auf die aktuelle Node 6.x gehen.
                      War zumindest bei meinen zwei älteren Node 6 Systemen so.
                      • D Online
                        D Online
                        dering
                        Fragt mich nicht was ich gemacht habe. Ich dachte schon ich hab das ganze System zerschossen.
                        Irgendwann hab ich den raspi einfach neugestartet und dann habe ich gesehen, dass er plötzlich alle Adapter wieder neuinstalliert.
                        Nach 20-30 Minuten war er fertig und es läuft wieder….
                        js-controller mit 1.2.6
                        Mir ist das trotzdem sehr koscher. Ich werde am Wochenende den Raspi neu installieren mit aktuellsten Versionen und spiele das Backup wieder ein.
                          wendy2702W Offline
                          Na dann ;)
                          Kannst du das bitte noch im Titel als [Gelöst] markieren.
                          • C Offline
                            csamaggi
                            Da es auch bei mir Probleme gab mit dem Update auf 1.2.6.
                            Dort wurden dann einfach einige Adapter nicht mehr gestartet oder einfach beendet habe ich nun nach der Anleitung hier die Node aktualisiert.
                            Nun läuft es auf 1.2.6 so wie es scheint, jedoch kann ich kein Update auf 1.2.7 machen dann bekomme ich diese Meldung.
                            ` > Update js-controller from @1.2.6 to @1.2.7
                            NPM version: 5.6.0
                            NPM 5 is only supported starting with version 5.7.1!
                            Please use "npm install -g npm@4" to downgrade npm to 4.x or
                            use to install a supported version of npm 5!
                            You need to make sure to repeat this step after installing an update to NodeJS and/or npm
                            Ok dachte ich schau ich mal welche Version von NPM ich habe raus kam 3.10.10.
                            Dann habe ich der Anweisung im dortigen Text gefolgt aber ohne Erfolg.
                            Ich habe "npm install -g npm@>=5.7.1" ausgeführt aber das führte zu folgendem Fehler.
                            ` > npm install -g npm@=>5.7.1
                            npm ERR! Linux 4.9.0-3-amd64
                            npm ERR! argv "/usr/local/bin/node" "/usr/bin/npm" "install" "-g" "npm@="
                            npm ERR! node v9.8.0
                            npm ERR! code ETARGET
                            npm ERR! notarget No compatible version found: npm@=
                            npm ERR! notarget Valid install targets:
                            npm ERR! notarget 5.7.1, 5.7.0, 5.6.0, 5.5.1, 5.5.0, 5.4.2, 5.4.1, 5.4.0, 5.3.0, 5.2.0, 5.1.0, 5.0.4, 5.0.3, 5.0.2, 5.0.1, 5.0.0, 4.6.1, 4.6.0, 4.5.0, 4.4.4, 4.4.3, 4.4.2, 4.4.1, 4.4.0, 4.3.0, 4.2.0, 4.1.2, 4.1.1, 4.1.0, 4.0.5, 4.0.3, 4.0.2, 4.0.1, 4.0.0, 3.10.10, 3.10.9, 3.10.8, 3.10.7, 3.10.6, 3.10.5, 3.10.4, 3.10.3, 3.10.2, 3.10.1, 3.10.0, 3.9.6, 3.9.5, 3.9.4, 3.9.3, 3.9.2, 3.9.1, 3.9.0, 3.8.9, 3.8.8, 3.8.7, 3.8.6, 3.8.5, 3.8.4, 3.8.3, 3.8.2, 3.8.1, 3.8.0, 3.7.5, 3.7.4, 3.7.3, 3.7.2, 3.7.1, 3.7.0, 3.6.0, 3.5.4, 3.5.3, 3.5.2, 3.5.1, 3.5.0, 3.4.1, 3.4.0, 3.3.12, 3.3.11, 3.3.10, 3.3.9, 3.3.8, 3.3.7, 3.3.6, 3.3.5, 3.3.4, 3.3.3, 3.3.2, 3.3.1, 3.3.0, 3.2.2, 3.2.1, 3.2.0, 3.1.3, 3.1.2, 3.1.1, 3.1.0, 3.0.0, 2.15.12, 2.15.11, 2.15.10, 2.15.9, 2.15.8, 2.15.7, 2.15.6, 2.15.5, 2.15.4, 2.15.3, 2.15.2, 2.15.1, 2.15.0, 2.14.22, 2.14.21, 2.14.20, 2.14.19, 2.14.18, 2.14.17, 2.14.16, 2.14.15, 2.14.14, 2.14.13, 2.14.12, 2.14.11, 2.14.10, 2.14.9, 2.14.8, 2.14.7, 2.14.6, 2.14.5, 2.14.4, 2.14.3, 2.14.2, 2.14.1, 2.14.0, 2.13.5, 2.13.4, 2.13.3, 2.13.2, 2.13.1, 2.13.0, 2.12.1, 2.12.0, 2.11.3, 2.11.2, 2.11.1, 2.11.0, 2.10.1, 2.10.0, 2.9.1, 2.9.0, 2.8.4, 2.8.3, 2.8.2, 2.8.1, 2.8.0, 2.7.6, 2.7.5, 2.7.4, 2.7.3, 2.7.2, 2.7.1, 2.7.0, 2.6.1, 2.6.0, 2.5.1, 2.5.0, 2.4.1, 2.4.0, 2.3.0, 2.2.0, 2.1.18, 2.1.17, 2.1.16, 2.1.15, 2.1.14, 2.1.13, 2.1.12, 2.1.11, 2.1.10, 2.1.9, 2.1.8, 2.1.7, 2.1.6, 2.1.5, 2.1.4, 2.1.3, 2.1.2, 2.1.1, 2.1.0, 2.0.2, 2.0.1, 2.0.0, 2.0.0-beta.3, 2.0.0-beta.2, 2.0.0-beta.1, 2.0.0-beta.0, 2.0.0-alpha-5, 2.0.0-alpha.7, 2.0.0-alpha.6.0, 2.0.0-alpha.6, 1.5.0-alpha-4, 1.5.0-alpha-3, 1.5.0-alpha-2, 1.5.0-alpha-1, 1.5.0-alpha-0, 1.4.29, 1.4.28, 1.4.27, 1.4.26, 1.4.25, 1.4.24, 1.4.23, 1.4.22, 1.4.21, 1.4.20, 1.4.19, 1.4.18, 1.4.17, 1.4.16, 1.4.15, 1.4.14, 1.4.13, 1.4.12, 1.4.11, 1.4.10, 1.4.9, 1.4.8, 1.4.7, 1.4.6, 1.4.5, 1.4.4, 1.4.3, 1.4.2, 1.4.1, 1.4.0, 1.3.26, 1.3.25, 1.3.24, 1.3.23, 1.3.22, 1.3.21, 1.3.20, 1.3.18, 1.3.17, 1.3.16, 1.3.15, 1.3.14, 1.3.13, 1.3.12, 1.3.11, 1.3.10, 1.3.9, 1.3.8, 1.3.7, 1.3.6, 1.3.5, 1.3.4, 1.3.2, 1.3.1, 1.3.0, 1.2.8000, 1.2.32, 1.2.31, 1.2.30, 1.2.28, 1.2.27, 1.2.25, 1.2.24, 1.2.23, 1.2.22, 1.2.21, 1.2.20, 1.2.19, 1.1.71, 1.1.70, 1.1.25
                            npm ERR! notarget
                            npm ERR! notarget This is most likely not a problem with npm itself.
                            npm ERR! notarget In most cases you or one of your dependencies are requesting
                            npm ERR! notarget a package version that doesn't exist.
                            npm ERR! /home/io/npm-debug.log `
                            Hoffe ihr könnt mir da weiterhelfen.
                            Wie gesagt bisher scheint es mit der Versio 1.2.6 zu laufen aber wenn ich später noch updaten will ist es wohl unausweichlich die NPM upzudaten.
                            MFG Maggi
                              MrLee
                              Moin!
                              Habe auf 2 Hosts keine Probleme gehabt und auf dem Raspi mit node8 ebenfalls die Warnmeldung.
                              Bei mir half:
                              npm i -g npm
                              (allerdings 2 mal…)
                              bis denne
                              Mr.Lee
                              • AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @csamaggi:
                                Ne hast du nicht. Du hast > und = vertauscht ;) ">=" ist richtig, "=>" falsch!
                                • C Offline
                                  csamaggi
                                  Ich Dusel, danke AlCalzone.
                                  Wieder selbst zu schnell gewesen und nicht richtig gelesen.
                                  MFG Maggi
                                    wendy2702W Offline
                                    @MrLee:
                                    Moin!
                                    Bei mir half:
                                    npm i -g npm
                                    (allerdings 2 mal…)
                                    bis denne
                                    Mr.Lee `
                                    Der Tipp war Gold Wert.
                                    Nachdem ich gestern auf meinem Host auf 1.2.6 bin heute dann auf 1.2.7 aber wie zu erwarten nicht ohne Probleme.
                                    Letztendlich bin ich dann auf diese Zeile aufmerksam geworden nachdem ich einmal````
                                    npm -i -g npm
                                    npm WARN npm@2.15.12 had bundled packages that do not match the required version(s). They have been replaced with non-bundled versions.
                                    root@openmediavault /opt/iobroker > npm install iobroker.js-controller --production
                                    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but npm-shrinkwrap.json was generated for lockfileVersion@0. I'll try to do my best with it!
                                    npm WARN winston-daily-rotate-file@1.7.2 requires a peer of winston@2.x but none is installed. You must install peer dependencies yourself.
                                    npm ERR! path /opt/iobroker/node_modules/npm/node_modules/abbrev
                                    npm ERR! errno -2
                                    npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/npm/node_modules/abbrev' -> '/opt/iobroker/node_modules/npm/node_modules/.abbrev.DELETE'
                                    npm ERR! enoent This is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR! /root/.npm/_logs/2018-03-09T19_31_13_963Z-debug.log
                                    Obwohl ich bei der Abfrage nach Node und NPM wie auch im log zu sehen diese Versionen hatte:
                                    Wird scheinbar bei der JS-Controller installation auf eine "globale" NPM installation zurück gegriffen!?
                                    Interessanter weise habe ich jetzt folgende Versionen:
                                    5.7.1
                                    v6.13.1
                                    Wer weiß was das wieder für Probleme verursacht… :cry:
                                    EDIT: 22 Instanzen bleiben auf ROT
                                    Ich habe keine Lust mehr :roll:
                                      AlCalzoneA Offline
                                      AlCalzone
                                      @wendy2702:
                                      5.7.1
                                      v6.13.1
                                      Hast du 2 NPM mit unterschiedlichen Versionen parallel installiert? Was gibt
                                      which npm
                                      aus?
                                      npm sollte IMMER global installiert sein
                                        wendy2702W Offline
                                        Guten Morgen,
                                        bei der Installation von NPM und Node habe ich mich bisher immer an diese Anleitung gehalten:
                                        http://www.iobroker.net/docu/?page_id=5106&lang=de
                                        Abfrage ergibt das:
                                        root@openmediavault ~ > which npm
                                        /usr/bin/npm
                                        Was bedeutet das jetzt für mich?
                                        Sollte ich passend zu NPM5 auch Node upgraden?
                                          AlCalzoneA Offline
                                          AlCalzone
                                          Ich wundere mich nur, dass du in deinen Logs sowohl 3.10.10 (von npm -v) als auch 5.7.1 (von js-controller erkant) hast.
                                          Die Ausgabe stimmt mit meiner überein, das sagt erst mal nix.
                                          Was ich gerade festgestellt habe…
                                          Der empfohlene Befehl zum npm-Update hat einen Fehler. Es muss
                                          sudo npm i -g "npm@>=5.7.1"
                                          heißen (mit Anführungszeichen!), NICHT
                                          sudo npm i -g npm@>=5.7.1
                                          Aber du bist ja schon einen Schritt weiter:
                                          Was sagt der ioBroker-Log?
