- ioBroker Community Home
- Deutsch
- Praktische Anwendungen (Showcase)
- Hannah — Open Source Smart-Home-Sprachassistentin
Gibt es da eine Bestimmte stelle wo das eingefügt werden mussservices:
hannah-core:
image: quay.io/m1kad0/hannah-core:latest
container_name: hannah-core
restart: unless-stopped
pull_policy: always
depends_on:
mysql-db:
condition: service_healthy
mosquitto:
ports:
- "50051:50051"
networks:
- hannah_network
volumes:
- core_data:/app/data
- core_activity_audio:/app/activity_audio
- core_audio_dumps:/app/audio_dumps
environment:
HANNAH_CORE_MQTT__HOST: "mosquitto"
HANNAH_CORE_ACTIVITY_LOG__HOST: "mysql-db"
HANNAH_CORE_ACTIVITY_LOG__PORT: "3306"
HANNAH_CORE_ACTIVITY_LOG__USER: "hannah_user" -
@Leonie
hannah-logs-20261109-153424.tar.gz
I (471) octal_psram: good-die : 0x01 (Pass) I (475) octal_psram: Latency : 0x01 (Fixed) I (480) octal_psram: VCC : 0x01 (3V) I (484) octal_psram: SRF : 0x01 (Fast Refresh) I (489) octal_psram: BurstType : 0x01 (Hybrid Wrap) I (494) octal_psram: BurstLen : 0x01 (32 Byte) I (498) octal_psram: Readlatency : 0x02 (10 cycles@Fixed) I (503) octal_psram: DriveStrength: 0x00 (1/1) I (507) MSPI Timing: Enter psram timing tuning I (512) esp_psram: Found 8MB PSRAM device I (515) esp_psram: Speed: 80MHz I (518) cpu_start: Multicore app I (944) esp_psram: SPI SRAM memory test OK I (952) cpu_start: GPIO 44 and 43 are used as console UART I/O pins I (953) cpu_start: Pro cpu start user code I (953) cpu_start: cpu freq: 160000000 Hz I (955) app_init: Application information: I (958) app_init: Project name: hannah_satellite I (963) app_init: App version: 1 I (967) app_init: Compile time: Oct 31 2026 12:16:21 I (972) app_init: ELF file SHA256: 4edd092c6... I (976) app_init: ESP-IDF: v5.5.2 I (980) efuse_init: Min chip rev: v0.0 I (984) efuse_init: Max chip rev: v0.99 I (988) efuse_init: Chip rev: v0.2 I (991) heap_init: Initializing. RAM available for dynamic allocation: I (998) heap_init: At 3FCAF618 len 0003A0F8 (232 KiB): RAM I (1003) heap_init: At 3FCE9710 len 00005724 (21 KiB): RAM I (1008) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (1013) heap_init: At 600FE000 len 00001FE8 (7 KiB): RTCRAM I (1019) esp_psram: Adding pool of 8192K of PSRAM memory to heap allocator I (1026) spi_flash: detected chip: generic I (1029) spi_flash: flash io: dio I (1033) sleep_gpio: Configure to isolate all GPIO pins in sleep state I (1039) sleep_gpio: Enable automatic switching of GPIO sleep configuration I (1045) esp_core_dump_flash: Init core dump to flash I (1050) esp_core_dump_flash: Found partition 'coredump' @ d10000 524288 bytes I (1091) esp_core_dump_flash: Core dump data checksum is correct I (1091) esp_core_dump_flash: Found core dump 28964 bytes in flash @ 0xd10000 I (1093) coexist: coex firmware version: 7260f71 I (1097) coexist: coexist rom version e7ae62f I (1102) main_task: Started on CPU0 I (1105) esp_psram: Reserving pool of 32K of internal memory for DMA/internal allocations I (1113) main_task: Calling app_main() I (1116) main: Hannah Satellite starting... I (1148) hannah_led: Status-LED an GPIO 18 I (1204) config: Config: device=hannah-satellite-keller wifi=jacko mqtt=192.168.178.122:1887 (device_id fest aus sdkconfig) I (1205) hannah_led: LED-Helligkeit aus NVS: 50% I (1210) hannah_led: LED ring initialized (1 LEDs, GPIO 48) I (1214) hannah_led: LED IDLE → BOOT I (1221) pp: pp rom version: e7ae62f I (1222) net80211: net80211 rom version: e7ae62f I (1226) wifi:wifi driver task: 3fceeb70, prio:23, stack:6656, core=0 I (1241) wifi:wifi firmware version: ee91c8c I (1241) wifi:wifi certification version: v7.0 I (1241) wifi:config NVS flash: enabled I (1243) wifi:config nano formatting: disabled I (1247) wifi:Init data frame dynamic rx buffer num: 32 I (1252) wifi:Init static rx mgmt buffer num: 5 I (1256) wifi:Init management short buffer num: 32 I (1261) wifi:Init dynamic tx buffer num: 32 I (1265) wifi:Init static tx FG buffer num: 2 I (1269) wifi:Init static rx buffer size: 1600 I (1273) wifi:Init static rx buffer num: 10 I (1277) wifi:Init dynamic rx buffer num: 32 I (1282) wifi_init: rx ba win: 6 I (1284) wifi_init: accept mbox: 6 I (1287) wifi_init: tcpip mbox: 32 I (1290) wifi_init: udp mbox: 64 I (1293) wifi_init: tcp mbox: 6 I (1296) wifi_init: tcp tx win: 5760 I (1299) wifi_init: tcp rx win: 5760 I (1302) wifi_init: tcp mss: 1440 I (1305) wifi_init: WiFi IRAM OP enabled I (1309) wifi_init: WiFi RX IRAM OP enabled I (1314) hannah_net: SNTP gestartet (DHCP-NTP bevorzugt, Fallback: pool.ntp.org, Retry: 30s). I (1322) phy_init: phy_version 711,97bcf0a2,Aug 25 2025,19:04:10 I (1369) wifi:mode : sta (8c:bf:ea:19:86:18) I (1369) wifi:enable tsf I (1371) hannah_net: WiFi STA → SSID: jacko I (1374) hannah_net: hannah_net initialisiert. I (1379) webserver: Webserver gestartet — http://0.0.0.0/ I (1379) webserver: Syslog: Ziel kommt von Hannah (hannah/syslog). I (1384) main: Reset-Grund: Power-On, Neustart #247 I (1446) esp_core_dump_flash: Core dump data checksum is correct W (1446) main: Coredump im Flash vorhanden — abrufbar via GET /debug/coredump E (1474) sensors: BMP280 nicht gefunden (ID=0xb2) E (1475) sensors: Sensor-Initialisierung fehlgeschlagen I (2263) hannah_asset: SPIFFS: 296431/8667281 bytes I (2264) hannah_audio: Lautstärke aus NVS: 30% I (2266) hannah_audio: Speaker I2S1: 48000Hz mono W (2267) i2s_common: dma frame num is out of dma buffer size, limited to 511 I (2274) hannah_audio: Mic I2S0: 16000Hz stereo I (2882) wakeword: TFLite geladen: Arena 128 KB, verwendet 23568 B. Input int8 scale=0.101961 zp=-128, Output uint8 scale=0.003906 zp=0. I (2885) wakeword: Wakeword-Input: 1 Frame(s) à 40 Werte (40 B gesamt). I (2891) wakeword: Wakeword bereit (AudioFrontend + TFLite Micro). I (2897) hannah_audio: Mic-Task: Wakeword-Modus (Schwelle=0.75, VAD=1500ms). I (2904) hannah_audio: hannah_audio initialisiert (Mic=I2S, Speaker=an). I (2904) hannah_audio: Speaker-Task gestartet. I (2914) ota: Warte 60s auf WiFi/MQTT... I (2916) ota: OTA-Check aktiv (Erstprüfung in 60s, Intervall 300s). I (2930) BLE_INIT: BT controller compile version [5106725] I (2937) BLE_INIT: Using main XTAL as clock source I (2951) BLE_INIT: Feature Config, ADV:1, BLE_50:1, DTM:1, SCAN:1, CCA:0, SMP:1, CONNECT:1 I (2965) BLE_INIT: Bluetooth MAC: 8c:bf:ea:19:86:1a I (3019) NimBLE: Failed to restore IRKs from store; status=8 I (3020) NimBLE: GAP procedure initiated: discovery; I (3020) NimBLE: own_addr_type=0 filter_policy=0 passive=1 limited=0 filter_duplicates=0 I (3027) NimBLE: duration=forever I (3030) NimBLE: I (3033) ble: BLE-Scan gestartet (passiv, kontinuierlich). I (3050) ble: BLE-Scanner initialisiert. I (3057) main: All components initialized. I (3066) main_task: Returned from app_main() I (4507) wifi:new:<11,0>, old:<1,0>, ap:<255,255>, sta:<11,0>, prof:1, snd_ch_cfg:0x0 I (4508) wifi:state: init -> auth (0xb0) I (4513) wifi:state: auth -> assoc (0x0) I (4519) wifi:state: assoc -> run (0x10) I (4551) wifi:connected with jacko, aid = 23, channel 11, BW20, bssid = 60:b5:8d:47:f9:cc I (4552) wifi:security: WPA2-PSK, phy: bgn, rssi: -54 I (4557) wifi:pm start, type: 1 I (4557) wifi:dp: 1, bi: 102400, li: 3, scale listen interval from 307200 us to 307200 us I (4565) wifi:set rx beacon pti, rx_bcn_pti: 14, bcn_timeout: 25000, mt_pti: 14, mt_time: 10000 I (4586) wifi:<ba-add>idx:0 (ifx:0, 60:b5:8d:47:f9:cc), tid:0, ssn:1, winSize:64 I (4618) wifi:AP's beacon interval = 102400 us, DTIM period = 1 I (5591) esp_netif_handlers: sta ip: 192.168.178.74, mask: 255.255.255.0, gw: 192.168.178.1 I (5592) hannah_net: IP: 192.168.178.74 I (5593) hannah_net: MQTT → mqtt://192.168.178.122:1887 (id=hannah-satellite-keller-f409) I (5754) hannah_net: MQTT verbunden. I (5795) hannah_net: UDP-Socket → Proxy 192.168.178.122:7775 (listen :7776) I (5797) hannah_net: Register: device=hannah-satellite-keller port=7776 I (5832) hannah_asset: Asset connect: 16000Hz 1ch, 24960 bytes PCM I (5840) hannah_led: LED BOOT → SPEAK I (5863) hannah_led: LED-Helligkeit gesetzt: 50% I (5895) ble: Watchlist aktualisiert: 3 MAC(s). I (5906) hannah_asset: Relevanzliste aktualisiert: 3 Asset(s). I (5915) hannah_net: Sampling-Modus: aus (type=noise) I (5916) hannah_led: LED SPEAK → IDLE I (5916) hannah_audio: Capture-Modus deaktiviert — normaler Betrieb I (6076) sendspin.client: Loaded static keypair; client_id=V2lQ7XIKT0givIQsdDYfT6KQctRRqvCAmyl1N-N4hnM W (6080) sendspin.conn_mgr: server_max_connections (2) is below 4 (1 admitted + 2 nursery + 1 spare); surplus peers will be refused at accept instead of receiving a goodbye I (6091) sendspin.ws_server: Starting server on port: 8928 (max connections: 2) I (6101) hannah_sendspin: Sendspin-Client gestartet I (6105) mdns_mem: mDNS task will be created from SPIRAM I (6110) hannah_sendspin: mDNS: _sendspin._tcp, Instanz=V2lQ7XIKT0givIQsdDYfT6KQctRRqvCAmyl1N-N4hnM, name=Hannah hannah-satellite-keller, Port 8928, Hostname hannah-hannah-satellite-keller I (7719) hannah_audio: Mic-Warmup abgeschlossen. noise_ema=0.0964 I (11027) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=32419 (min 26995) psram frei=6681572 | stack frei=2288 I (11030) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=420600 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (11374) hannah_net: Heap: frei=6711488 min_je=6701728 intern=32007 outbox=0 W (15915) hannah_net: SNTP sync timeout nach 10000 ms. I (15916) hannah_asset: Manifest-Fetch Versuch 1/3 (free heap: 6711488) I (15916) hannah_asset: Manifest abrufen: http://192.168.178.122:8096/manifest?namespace=satellite I (16017) hannah_asset: Asset alarm_ring aktuell. I (16018) hannah_asset: Asset timer_jingle aktuell. I (16020) hannah_asset: Asset message_chime aktuell. W (16022) hannah_asset: Asset wakeword: nicht im Manifest. I (16026) hannah_asset: Asset connect aktuell. I (16959) hannah_asset: Asset-Sync abgeschlossen (5 relevant). I (19086) hannah_net: SNTP sync OK: Mon Nov 9 15:32:54 2026 I (19087) wifi:<ba-add>idx:1 (ifx:0, 60:b5:8d:47:f9:cc), tid:4, ssn:1, winSize:64 I (19306) hannah_sendspin: Diagnose: MA per mDNS 0 (-) | Sendspin-Clients per mDNS 0 | TCP :8928 listen=1 syn_rcvd=0 established=0 sonstige=0 time_wait=0 letzter_peer=- | Suchfenster 13 s I (21035) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31551 (min 26803) psram frei=6681572 | stack frei=2288 I (21039) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480360 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (21377) hannah_net: Heap: frei=6711052 min_je=6700176 intern=31307 outbox=0 I (31036) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31551 (min 26711) psram frei=6681572 | stack frei=2288 I (31040) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480120 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (31379) hannah_net: Heap: frei=6711052 min_je=6699996 intern=31307 outbox=0 I (41045) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31551 (min 26711) psram frei=6681572 | stack frei=2288 I (41048) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480360 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (41383) hannah_net: Heap: frei=6711052 min_je=6699996 intern=31307 outbox=0 I (51047) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31551 (min 26711) psram frei=6681572 | stack frei=2288 I (51051) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480120 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (51385) hannah_net: Heap: frei=6711052 min_je=6699996 intern=31307 outbox=0 I (61056) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31551 (min 26711) psram frei=6681572 | stack frei=2288 I (61059) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480480 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (61388) hannah_net: Heap: frei=6711052 min_je=6699996 intern=31307 outbox=0 I (62921) ota: Firmware-Version publiziert: hannah/satellite/hannah-satellite-keller/firmware = {"version":"1","restart_reason":"Power-On","restart_count":247} I (8564) esp_core_dump_flash: Core dump data checksum is correct W (62992) ota: Coredump-Pending publiziert: hannah/satellite/hannah-satellite-keller/coredump_pending I (71057) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31415 (min 26711) psram frei=6681572 | stack frei=2288 I (71060) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480000 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (71390) hannah_net: Heap: frei=6711004 min_je=6699996 intern=31171 outbox=0 I (81392) hannah_net: Heap: frei=6711004 min_je=6699996 intern=30987 outbox=0 I (82511) hannah_sendspin: Diagnose: MA per mDNS 0 (-) | Sendspin-Clients per mDNS 0 | TCP :8928 listen=1 syn_rcvd=0 established=0 sonstige=0 time_wait=0 letzter_peer=- | Suchfenster 76 s I (82517) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31395 (min 26711) psram frei=6681572 | stack frei=2288 I (82529) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=550560 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (83954) hannah_led: LED IDLE → WAKE I (84105) hannah_led: LED WAKE → STREAM I (84105) hannah_audio: Wake-Word erkannt → Streaming. (noise_ema=0.0442) I (84121) hannah_audio: Server-Status: listening I (84541) hannah_audio: VAD RMS=0.0183 silence=0/150 I (84970) hannah_audio: VAD RMS=0.2805 silence=0/150 I (85458) hannah_audio: VAD RMS=0.0193 silence=0/150 I (85961) hannah_audio: VAD RMS=0.0708 silence=0/150 I (86460) hannah_audio: VAD RMS=0.0279 silence=43/150 I (86962) hannah_audio: VAD RMS=0.0404 silence=93/150 I (87465) hannah_audio: VAD RMS=0.0134 silence=143/150 I (87524) hannah_led: LED STREAM → IDLE I (87524) hannah_audio: VAD: Stille erkannt → audio_end. I (87568) hannah_audio: Server-Status: processing I (87568) hannah_led: LED IDLE → WAKE I (89510) hannah_audio: Server-Status: idle I (89511) hannah_led: LED WAKE → IDLE I (91395) hannah_net: Heap: frei=6710948 min_je=6695760 intern=31027 outbox=0 I (92520) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31271 (min 25571) psram frei=6681572 | stack frei=2288 I (92523) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=479640 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (101399) hannah_net: Heap: frei=6710948 min_je=6695760 intern=31027 outbox=0 I (102530) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31291 (min 25571) psram frei=6681572 | stack frei=2288 I (102534) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480480 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (111402) hannah_net: Heap: frei=6710780 min_je=6695760 intern=30859 outbox=0 I (112534) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31103 (min 25571) psram frei=6681572 | stack frei=2288 I (112538) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480240 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (121404) hannah_net: Heap: frei=6710780 min_je=6695760 intern=30859 outbox=0 I (122535) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31103 (min 25571) psram frei=6681572 | stack frei=2288 I (122539) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480000 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (130488) hannah_led: LED IDLE → WAKE I (130639) hannah_led: LED WAKE → STREAM I (130639) hannah_audio: Wake-Word erkannt → Streaming. (noise_ema=0.0424) I (130684) hannah_audio: Server-Status: listening I (131068) hannah_audio: VAD RMS=0.0818 silence=0/150 I (131406) hannah_net: Heap: frei=6710028 min_je=6695760 intern=30879 outbox=0 I (131505) hannah_audio: VAD RMS=0.0608 silence=0/150 I (131991) hannah_audio: VAD RMS=0.0492 silence=0/150 I (132487) hannah_audio: VAD RMS=0.0346 silence=0/150 I (132540) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31123 (min 25571) psram frei=6680800 | stack frei=2288 I (132544) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=480360 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (132992) hannah_audio: VAD RMS=0.0087 silence=43/150 I (133492) hannah_audio: VAD RMS=0.0157 silence=93/150 I (133991) hannah_audio: VAD RMS=0.0258 silence=143/150 I (134045) hannah_led: LED STREAM → IDLE I (134045) hannah_audio: VAD: Stille erkannt → audio_end. I (134057) hannah_audio: Server-Status: processing I (134058) hannah_led: LED IDLE → WAKE I (134669) hannah_audio: Server-Status: idle I (134670) hannah_led: LED WAKE → IDLE I (141410) hannah_net: Heap: frei=6711012 min_je=6695760 intern=31091 outbox=0 I (145705) hannah_sendspin: Diagnose: MA per mDNS 0 (-) | Sendspin-Clients per mDNS 0 | TCP :8928 listen=1 syn_rcvd=0 established=0 sonstige=0 time_wait=0 letzter_peer=- | Suchfenster 139 s I (145711) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31007 (min 25359) psram frei=6680020 | stack frei=2288 I (145724) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=632640 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% I (151412) hannah_net: Heap: frei=6711012 min_je=6695760 intern=31091 outbox=0 I (155719) hannah_sendspin: Stats: verbunden=0 zeit_sync=0 sync_err=0.00 | heap intern frei=31335 (min 25359) psram frei=6681572 | stack frei=2288 I (155723) hannah_sendspin: Musik: aufrufe=0 fehl=0 frames=0 dma_frames=479880 | in_peak=0 out_peak=0 | musik_vol=80 hannah_vol=30 stumm=0 duck=100% -
Da war noch die Frage nach dem Ausschalten der Suche nach dem Musik Assistenten
und, warum ist die Zeitangabe der Log's nicht Identisch mit der Server zeit Einstellung (log -1 std.)Schicke mir bitte die Ausgabe von "docker inspect hannah-core".
Zu deinen Fragen:
nein, das geht nicht. Tut aber auch nichts zur Sache
Weil die Logs immer in UTC sind
Zu deinen Fragen:
docker inspect hannah-core [ { "Id": "4a4dc96f98222e90fb85312129253cfc82cbdeba5f07a5cea165a2598615ac36", "Created": "2026-11-09T16:39:54.624089438Z", "Path": "python", "Args": [ "main.py", "-c", "/etc/hannah/config.yaml" ], "State": { "Status": "running", "Running": true, "Paused": false, "Restarting": false, "OOMKilled": false, "Dead": false, "Pid": 1886832, "ExitCode": 0, "Error": "", "StartedAt": "2026-11-09T16:39:58.724802069Z", "FinishedAt": "0001-01-01T00:00:00Z", "Health": { "Status": "healthy", "FailingStreak": 0, "Log": [ { "Start": "2026-11-09T18:57:19.915513983+01:00", "End": "2026-11-09T18:57:20.122736175+01:00", "ExitCode": 0, "Output": "" }, { "Start": "2026-11-09T18:57:25.12370987+01:00", "End": "2026-11-09T18:57:25.306989608+01:00", "ExitCode": 0, "Output": "" }, { "Start": "2026-11-09T18:57:30.308382459+01:00", "End": "2026-11-09T18:57:30.523811865+01:00", "ExitCode": 0, "Output": "" }, { "Start": "2026-11-09T18:57:35.525219923+01:00", "End": "2026-11-09T18:57:35.737399803+01:00", "ExitCode": 0, "Output": "" }, { "Start": "2026-11-09T18:57:40.738344302+01:00", "End": "2026-11-09T18:57:40.974876913+01:00", "ExitCode": 0, "Output": "" } ] } }, "Image": "sha256:9a1ba27c2572769c6ae1d322251d87db28ebfa5e2b5a4605bd9c5a06a5a1aaf4", "ResolvConfPath": "/var/lib/docker/containers/4a4dc96f98222e90fb85312129253cfc82cbdeba5f07a5cea165a2598615ac36/resolv.conf", "HostnamePath": "/var/lib/docker/containers/4a4dc96f98222e90fb85312129253cfc82cbdeba5f07a5cea165a2598615ac36/hostname", "HostsPath": "/var/lib/docker/containers/4a4dc96f98222e90fb85312129253cfc82cbdeba5f07a5cea165a2598615ac36/hosts", "LogPath": "/var/lib/docker/containers/4a4dc96f98222e90fb85312129253cfc82cbdeba5f07a5cea165a2598615ac36/4a4dc96f98222e90fb85312129253cfc82cbdeba5f07a5cea165a2598615ac36-json.log", "Name": "/hannah-core", "RestartCount": 0, "Driver": "overlayfs", "Platform": "linux", "MountLabel": "", "ProcessLabel": "", "AppArmorProfile": "docker-default", "ExecIDs": null, "HostConfig": { "Binds": [ "hannah_core_activity_audio:/app/activity_audio:rw", "hannah_core_audio_dumps:/app/audio_dumps:rw", "hannah_core_data:/app/data:rw" ], "ContainerIDFile": "", "LogConfig": { "Type": "json-file", "Config": {} }, "NetworkMode": "hannah_hannah_network", "PortBindings": { "50051/tcp": [ { "HostIp": "", "HostPort": "50051" } ] }, "RestartPolicy": { "Name": "unless-stopped", "MaximumRetryCount": 0 }, "AutoRemove": false, "VolumeDriver": "", "VolumesFrom": null, "ConsoleSize": [ 0, 0 ], "CapAdd": null, "CapDrop": null, "CgroupnsMode": "private", "Dns": null, "DnsOptions": null, "DnsSearch": null, "ExtraHosts": [], "GroupAdd": null, "IpcMode": "private", "Cgroup": "", "Links": null, "OomScoreAdj": 0, "PidMode": "", "Privileged": false, "PublishAllPorts": false, "ReadonlyRootfs": false, "SecurityOpt": null, "UTSMode": "", "UsernsMode": "", "ShmSize": 67108864, "Runtime": "runc", "Isolation": "", "CpuShares": 0, "Memory": 0, "NanoCpus": 0, "CgroupParent": "", "BlkioWeight": 0, "BlkioWeightDevice": null, "BlkioDeviceReadBps": null, "BlkioDeviceWriteBps": null, "BlkioDeviceReadIOps": null, "BlkioDeviceWriteIOps": null, "CpuPeriod": 0, "CpuQuota": 0, "CpuRealtimePeriod": 0, "CpuRealtimeRuntime": 0, "CpusetCpus": "", "CpusetMems": "", "Devices": null, "DeviceCgroupRules": null, "DeviceRequests": null, "MemoryReservation": 0, "MemorySwap": 0, "MemorySwappiness": null, "OomKillDisable": null, "PidsLimit": null, "Ulimits": null, "CpuCount": 0, "CpuPercent": 0, "IOMaximumIOps": 0, "IOMaximumBandwidth": 0, "MaskedPaths": [ "/proc/acpi", "/proc/asound", "/proc/interrupts", "/proc/kcore", "/proc/keys", "/proc/latency_stats", "/proc/sched_debug", "/proc/scsi", "/proc/timer_list", "/proc/timer_stats", "/sys/devices/virtual/powercap", "/sys/firmware", "/sys/devices/system/cpu/cpu0/thermal_throttle", "/sys/devices/system/cpu/cpu1/thermal_throttle", "/sys/devices/system/cpu/cpu2/thermal_throttle", "/sys/devices/system/cpu/cpu3/thermal_throttle" ], "ReadonlyPaths": [ "/proc/bus", "/proc/fs", "/proc/irq", "/proc/sys", "/proc/sysrq-trigger" ] }, "Storage": { "RootFS": { "Snapshot": { "Name": "overlayfs" } } }, "Mounts": [ { "Type": "volume", "Name": "hannah_core_activity_audio", "Source": "/var/lib/docker/volumes/hannah_core_activity_audio/_data", "Destination": "/app/activity_audio", "Driver": "local", "Mode": "rw", "RW": true, "Propagation": "" }, { "Type": "volume", "Name": "hannah_core_audio_dumps", "Source": "/var/lib/docker/volumes/hannah_core_audio_dumps/_data", "Destination": "/app/audio_dumps", "Driver": "local", "Mode": "rw", "RW": true, "Propagation": "" }, { "Type": "volume", "Name": "hannah_core_data", "Source": "/var/lib/docker/volumes/hannah_core_data/_data", "Destination": "/app/data", "Driver": "local", "Mode": "rw", "RW": true, "Propagation": "" } ], "Config": { "Hostname": "4a4dc96f9822", "Domainname": "",afcf5ac7a9ac82a290a26b27a49cd911 "User": "appuser", "AttachStdin": false, "AttachStdout": true, "AttachStderr": true, "ExposedPorts": { "50051/tcp": {}, "7776/tcp": {} }, "Tty": false, "OpenStdin": false, "StdinOnce": false, "Env": [ "HANNAH_CORE_TTS__BACKEND=piper", "HANNAH_CORE_TTS__MODEL=/app/data/de_DE-kerstin-low.onnx", "HANNAH_CORE_ACTIVITY_LOG__PORT=3306", "HANNAH_CORE_MQTT__HOST=mosquitto", "HANNAH_CORE_ACTIVITY_LOG__HOST=mysql-db", "HANNAH_CORE_VOICE_ID__BASE_URL=http://hannah-voiceid:8080", "HANNAH_CORE_ACTIVITY_LOG__USER=hannah_user", "HANNAH_CORE_ACTIVITY_LOG__DATABASE=hannah_db", "HANNAH_CORE_VOICE_ID__ENABLED=true", "HANNAH_CORE_ACTIVITY_LOG__PASSWORD=mein passwortGelöscht", "PATH=/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin", "LANG=C.UTF-8", "PYTHON_VERSION=3.14.10", "PYTHON_SHA256=de414a57119abef52784d8993e341d53aed635fc2b05c2607d9f98a2c5b72032", "PYTHONUNBUFFERED=1", "DB_PATH=/app/data/hannah.db", "HF_HOME=/app/data/hf-cache" ], "Cmd": [ "python", "main.py", "-c", "/etc/hannah/config.yaml" ], "Healthcheck": { "Test": [ "CMD", "python", "-c", "import socket; socket.create_connection(('localhost', 50051), 2)" ], "Interval": 5000000000, "Timeout": 5000000000, "StartPeriod": 60000000000, "Retries": 12 }, "Image": "quay.io/m1kad0/hannah-core:latest", "Volumes": { "/app/activity_audio": {}, "/app/audio_dumps": {}, "/app/data": {} }, "WorkingDir": "/app", "Entrypoint": null, "Labels": { "com.docker.compose.config-hash": "c703ea802fe703c0d28dde44bdd3eabafebf0fc842b1bcef6e99acef7c926272", "com.docker.compose.container-number": "1", "com.docker.compose.depends_on": "mosquitto:service_healthy:false,mysql-db:service_healthy:false", "com.docker.compose.image": "sha256:a6b8560c9410c7fe9ce22e2a02e90a86d9cbbfc4c80f95f590bf74c612e4c985", "com.docker.compose.oneoff": "False", "com.docker.compose.project": "hannah", "com.docker.compose.project.config_files": "/opt/hannah/docker-compose.yml", "com.docker.compose.project.working_dir": "/opt/hannah", "com.docker.compose.replace": "hannah-core", "com.docker.compose.service": "hannah-core", "com.docker.compose.version": "5.7.0" } }, "NetworkSettings": { "SandboxID": "4ec77be1a89d7c739a5a3040391ceb0dffff949055d54f8e1f5fb8600015764e", "SandboxKey": "/var/run/docker/netns/4ec77be1a89d", "Ports": { "50051/tcp": [ { "HostIp": "0.0.0.0", "HostPort": "50051" }, { "HostIp": "::", "HostPort": "50051" } ], "7776/tcp": null }, "Networks": { "hannah_hannah_network": { "IPAMConfig": null, "Links": null, "Aliases": [ "hannah-core", "hannah-core" ], "DriverOpts": null, "GwPriority": 0, "NetworkID": "e6f332c99d7e99f15e0b26216e4ec676815cbd2ab2a18e80897e931f2dcda1a2", "EndpointID": "23ae0836b5c5c7e25f5bbe8ec4e2a92d64072a3de2028cf18bd9f219b2636afc", "Gateway": "172.19.0.1", "IPAddress": "172.19.0.4", "MacAddress": "36:6f:fd:70:35:7d", "IPPrefixLen": 16, "IPv6Gateway": "", "GlobalIPv6Address": "", "GlobalIPv6PrefixLen": 0, "DNSNames": [ "hannah-core", "4a4dc96f9822" ] } } }, "ImageManifestDescriptor": { "mediaType": "application/vnd.docker.distribution.manifest.v2+json", "digest": "sha256:a6b8560c9410c7fe9ce22e2a02e90a86d9cbbfc4c80f95f590bf74c612e4c985", "size": 2057, "platform": { "architecture": "amd64", "os": "linux" } } } ] -
ok, und bitte nochmal sagen, ich bin grade etwas verwirrt. Antwortet Hannah dir nun oder noch nicht? Dein Log oben sagt das es nicht geht, weil das Backend nicht konfiguriert ist, laut deinem inspect sollte es aber gehen und du hast zwischenzeitlich auch gesagt das es geht. Sorry, wenn ich da grade wirr bin.
Hey, da bin ich wieder..
Diesmal geht es um "Lerne meine Stimme"
Das spuckt Hannah eine Fehlermeldung aus die ich aber in den Log's nicht direkt wieder finde.
Ich habe mal eine Tonaufnahme der Fehlermeldung gemacht.
Ich hoffe das Leonie mir da mehr zu sagen kann. -
@Leonie
Log hannah voiceid
docker logs --since "2026-11-11T00:00:00" hannah-voiceid 2026-11-10 23:14:46,030 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:34872 - "POST /identify HTTP/1.1" 200 OK 2026-11-10 23:15:03,442 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:34658 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 06:44:22,104 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:38116 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 06:45:01,346 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:54228 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 08:10:18,025 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:43146 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 08:10:33,261 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:44994 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 08:24:11,002 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:55908 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:14:11,382 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:53612 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:30:43,774 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:45034 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:47:08,065 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:43476 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:47:22,427 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:41604 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:47:42,574 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:50520 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:48:46,428 [INFO] voiceid: Enrollment-Probe empfangen für: hannah_self_piper 2026-11-11 09:48:47,604 [INFO] voiceid: Update: Bestehendes Profil für hannah_self_piper verfeinert. INFO: 172.19.0.4:33568 - "POST /enroll HTTP/1.1" 500 Internal Server Error ERROR: Exception in ASGI application Traceback (most recent call last): File "/usr/local/lib/python3.14/site-packages/uvicorn/protocols/http/h11_impl.py", line 411, in run_asgi result = await app( # type: ignore[func-returns-value] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ self.scope, self.receive, self.send ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ File "/usr/local/lib/python3.14/site-packages/uvicorn/middleware/proxy_headers.py", line 63, in __call__ return await self.app(scope, receive, send) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/applications.py", line 1194, in __call__ await super().__call__(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/applications.py", line 96, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 186, in __call__ raise exc File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 164, in __call__ await self.app(scope, receive, _send) File "/usr/local/lib/python3.14/site-packages/fastapi/telemetry/_asgi.py", line 151, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/exceptions.py", line 63, in __call__ await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/middleware/asyncexitstack.py", line 18, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/routing.py", line 683, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2811, in app await route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1839, in handle await self.original_router.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2894, in handle await included_router._handle_selected(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1865, in _handle_selected await original_route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1328, in handle await effective_context.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 166, in app await wrap_app_handling_exceptions(app, request)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 152, in app response = await f(request) ^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 745, in app raw_response = await run_endpoint_function( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ...<3 lines>... ) ^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 372, in run_endpoint_function return await dependant.call(**values) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/app/app.py", line 156, in enroll torch.save(combined_emb, ram_file) ~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 1003, in save with _open_zipfile_writer(f) as opened_zipfile: ~~~~~~~~~~~~~~~~~~~~^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 865, in _open_zipfile_writer return container(name_or_buffer) # type: ignore[arg-type] File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 829, in __init__ torch._C.PyTorchFileWriter( ~~~~~~~~~~~~~~~~~~~~~~~~~~^ self.name, get_crc32_options(), _get_storage_alignment() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ RuntimeError: [enforce fail at inline_container.cc:746] . open file failed with strerror: Permission denied 2026-11-11 09:48:47,614 [INFO] voiceid: Enrollment-Probe empfangen für: hannah_self_piper 2026-11-11 09:48:48,123 [INFO] voiceid: Update: Bestehendes Profil für hannah_self_piper verfeinert. INFO: 172.19.0.4:33578 - "POST /enroll HTTP/1.1" 500 Internal Server Error ERROR: Exception in ASGI application Traceback (most recent call last): File "/usr/local/lib/python3.14/site-packages/uvicorn/protocols/http/h11_impl.py", line 411, in run_asgi result = await app( # type: ignore[func-returns-value] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ self.scope, self.receive, self.send ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ File "/usr/local/lib/python3.14/site-packages/uvicorn/middleware/proxy_headers.py", line 63, in __call__ return await self.app(scope, receive, send) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/applications.py", line 1194, in __call__ await super().__call__(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/applications.py", line 96, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 186, in __call__ raise exc File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 164, in __call__ await self.app(scope, receive, _send) File "/usr/local/lib/python3.14/site-packages/fastapi/telemetry/_asgi.py", line 151, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/exceptions.py", line 63, in __call__ await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/middleware/asyncexitstack.py", line 18, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/routing.py", line 683, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2811, in app await route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1839, in handle await self.original_router.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2894, in handle await included_router._handle_selected(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1865, in _handle_selected await original_route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1328, in handle await effective_context.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 166, in app await wrap_app_handling_exceptions(app, request)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 152, in app response = await f(request) ^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 745, in app raw_response = await run_endpoint_function( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ...<3 lines>... ) ^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 372, in run_endpoint_function return await dependant.call(**values) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/app/app.py", line 156, in enroll torch.save(combined_emb, ram_file) ~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 1003, in save with _open_zipfile_writer(f) as opened_zipfile: ~~~~~~~~~~~~~~~~~~~~^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 865, in _open_zipfile_writer return container(name_or_buffer) # type: ignore[arg-type] File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 829, in __init__ torch._C.PyTorchFileWriter( ~~~~~~~~~~~~~~~~~~~~~~~~~~^ self.name, get_crc32_options(), _get_storage_alignment() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ RuntimeError: [enforce fail at inline_container.cc:746] . open file failed with strerror: Permission denied 2026-11-11 09:48:58,014 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:39530 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:49:11,707 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:35976 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:49:11,959 [INFO] voiceid: Enrollment-Probe empfangen für: hannah_self_piper 2026-11-11 09:49:12,440 [INFO] voiceid: Update: Bestehendes Profil für hannah_self_piper verfeinert. INFO: 172.19.0.4:35990 - "POST /enroll HTTP/1.1" 500 Internal Server Error ERROR: Exception in ASGI application Traceback (most recent call last): File "/usr/local/lib/python3.14/site-packages/uvicorn/protocols/http/h11_impl.py", line 411, in run_asgi result = await app( # type: ignore[func-returns-value] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ self.scope, self.receive, self.send ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ File "/usr/local/lib/python3.14/site-packages/uvicorn/middleware/proxy_headers.py", line 63, in __call__ return await self.app(scope, receive, send) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/applications.py", line 1194, in __call__ await super().__call__(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/applications.py", line 96, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 186, in __call__ raise exc File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 164, in __call__ await self.app(scope, receive, _send) File "/usr/local/lib/python3.14/site-packages/fastapi/telemetry/_asgi.py", line 151, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/exceptions.py", line 63, in __call__ await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/middleware/asyncexitstack.py", line 18, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/routing.py", line 683, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2811, in app await route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1839, in handle await self.original_router.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2894, in handle await included_router._handle_selected(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1865, in _handle_selected await original_route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1328, in handle await effective_context.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 166, in app await wrap_app_handling_exceptions(app, request)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 152, in app response = await f(request) ^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 745, in app raw_response = await run_endpoint_function( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ...<3 lines>... ) ^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 372, in run_endpoint_function return await dependant.call(**values) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/app/app.py", line 156, in enroll torch.save(combined_emb, ram_file) ~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 1003, in save with _open_zipfile_writer(f) as opened_zipfile: ~~~~~~~~~~~~~~~~~~~~^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 865, in _open_zipfile_writer return container(name_or_buffer) # type: ignore[arg-type] File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 829, in __init__ torch._C.PyTorchFileWriter( ~~~~~~~~~~~~~~~~~~~~~~~~~~^ self.name, get_crc32_options(), _get_storage_alignment() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ RuntimeError: [enforce fail at inline_container.cc:746] . open file failed with strerror: Permission denied 2026-11-11 09:49:26,955 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:58020 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 09:49:26,965 [INFO] voiceid: Enrollment-Probe empfangen für: 2 2026-11-11 09:49:30,151 [INFO] voiceid: Update: Bestehendes Profil für 2 verfeinert. INFO: 172.19.0.4:60528 - "POST /enroll HTTP/1.1" 500 Internal Server Error ERROR: Exception in ASGI application Traceback (most recent call last): File "/usr/local/lib/python3.14/site-packages/uvicorn/protocols/http/h11_impl.py", line 411, in run_asgi result = await app( # type: ignore[func-returns-value] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ self.scope, self.receive, self.send ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ File "/usr/local/lib/python3.14/site-packages/uvicorn/middleware/proxy_headers.py", line 63, in __call__ return await self.app(scope, receive, send) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/applications.py", line 1194, in __call__ await super().__call__(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/applications.py", line 96, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 186, in __call__ raise exc File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 164, in __call__ await self.app(scope, receive, _send) File "/usr/local/lib/python3.14/site-packages/fastapi/telemetry/_asgi.py", line 151, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/exceptions.py", line 63, in __call__ await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/middleware/asyncexitstack.py", line 18, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/routing.py", line 683, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2811, in app await route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1839, in handle await self.original_router.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2894, in handle await included_router._handle_selected(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1865, in _handle_selected await original_route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1328, in handle await effective_context.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 166, in app await wrap_app_handling_exceptions(app, request)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 152, in app response = await f(request) ^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 745, in app raw_response = await run_endpoint_function( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ...<3 lines>... ) ^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 372, in run_endpoint_function return await dependant.call(**values) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/app/app.py", line 156, in enroll torch.save(combined_emb, ram_file) ~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 1003, in save with _open_zipfile_writer(f) as opened_zipfile: ~~~~~~~~~~~~~~~~~~~~^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 865, in _open_zipfile_writer return container(name_or_buffer) # type: ignore[arg-type] File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 829, in __init__ torch._C.PyTorchFileWriter( ~~~~~~~~~~~~~~~~~~~~~~~~~~^ self.name, get_crc32_options(), _get_storage_alignment() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ RuntimeError: [enforce fail at inline_container.cc:746] . open file failed with strerror: Permission denied 2026-11-11 09:49:30,819 [INFO] voiceid: Enrollment-Probe empfangen für: hannah_self_piper 2026-11-11 09:49:32,500 [INFO] voiceid: Update: Bestehendes Profil für hannah_self_piper verfeinert. INFO: 172.19.0.4:60530 - "POST /enroll HTTP/1.1" 500 Internal Server Error ERROR: Exception in ASGI application Traceback (most recent call last): File "/usr/local/lib/python3.14/site-packages/uvicorn/protocols/http/h11_impl.py", line 411, in run_asgi result = await app( # type: ignore[func-returns-value] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ self.scope, self.receive, self.send ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ File "/usr/local/lib/python3.14/site-packages/uvicorn/middleware/proxy_headers.py", line 63, in __call__ return await self.app(scope, receive, send) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/applications.py", line 1194, in __call__ await super().__call__(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/applications.py", line 96, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 186, in __call__ raise exc File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 164, in __call__ await self.app(scope, receive, _send) File "/usr/local/lib/python3.14/site-packages/fastapi/telemetry/_asgi.py", line 151, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/exceptions.py", line 63, in __call__ await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/middleware/asyncexitstack.py", line 18, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/routing.py", line 683, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2811, in app await route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1839, in handle await self.original_router.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2894, in handle await included_router._handle_selected(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1865, in _handle_selected await original_route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1328, in handle await effective_context.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 166, in app await wrap_app_handling_exceptions(app, request)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 152, in app response = await f(request) ^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 745, in app raw_response = await run_endpoint_function( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ...<3 lines>... ) ^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 372, in run_endpoint_function return await dependant.call(**values) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/app/app.py", line 156, in enroll torch.save(combined_emb, ram_file) ~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 1003, in save with _open_zipfile_writer(f) as opened_zipfile: ~~~~~~~~~~~~~~~~~~~~^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 865, in _open_zipfile_writer return container(name_or_buffer) # type: ignore[arg-type] File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 829, in __init__ torch._C.PyTorchFileWriter( ~~~~~~~~~~~~~~~~~~~~~~~~~~^ self.name, get_crc32_options(), _get_storage_alignment() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ RuntimeError: [enforce fail at inline_container.cc:746] . open file failed with strerror: Permission denied 2026-11-11 09:52:44,401 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:38714 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 11:00:22,131 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:41546 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 11:40:20,246 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:54702 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 11:47:26,324 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:41648 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 14:56:15,361 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:58940 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 15:04:29,963 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:38732 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 15:04:31,897 [INFO] voiceid: Enrollment-Probe empfangen für: hannah_self_piper 2026-11-11 15:04:32,833 [INFO] voiceid: Update: Bestehendes Profil für hannah_self_piper verfeinert. INFO: 172.19.0.4:38734 - "POST /enroll HTTP/1.1" 500 Internal Server Error ERROR: Exception in ASGI application Traceback (most recent call last): File "/usr/local/lib/python3.14/site-packages/uvicorn/protocols/http/h11_impl.py", line 411, in run_asgi result = await app( # type: ignore[func-returns-value] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ self.scope, self.receive, self.send ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ File "/usr/local/lib/python3.14/site-packages/uvicorn/middleware/proxy_headers.py", line 63, in __call__ return await self.app(scope, receive, send) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/applications.py", line 1194, in __call__ await super().__call__(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/applications.py", line 96, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 186, in __call__ raise exc File "/usr/local/lib/python3.14/site-packages/starlette/middleware/errors.py", line 164, in __call__ await self.app(scope, receive, _send) File "/usr/local/lib/python3.14/site-packages/fastapi/telemetry/_asgi.py", line 151, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/middleware/exceptions.py", line 63, in __call__ await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/middleware/asyncexitstack.py", line 18, in __call__ await self.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/routing.py", line 683, in __call__ await self.middleware_stack(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2811, in app await route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1839, in handle await self.original_router.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 2894, in handle await included_router._handle_selected(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1865, in _handle_selected await original_route.handle(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 1328, in handle await effective_context.app(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 166, in app await wrap_app_handling_exceptions(app, request)(scope, receive, send) File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 53, in wrapped_app raise exc File "/usr/local/lib/python3.14/site-packages/starlette/_exception_handler.py", line 42, in wrapped_app await app(scope, receive, sender) File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 152, in app response = await f(request) ^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 745, in app raw_response = await run_endpoint_function( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ...<3 lines>... ) ^ File "/usr/local/lib/python3.14/site-packages/fastapi/routing.py", line 372, in run_endpoint_function return await dependant.call(**values) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/app/app.py", line 156, in enroll torch.save(combined_emb, ram_file) ~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 1003, in save with _open_zipfile_writer(f) as opened_zipfile: ~~~~~~~~~~~~~~~~~~~~^^^ File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 865, in _open_zipfile_writer return container(name_or_buffer) # type: ignore[arg-type] File "/usr/local/lib/python3.14/site-packages/torch/serialization.py", line 829, in __init__ torch._C.PyTorchFileWriter( ~~~~~~~~~~~~~~~~~~~~~~~~~~^ self.name, get_crc32_options(), _get_storage_alignment() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ) ^ RuntimeError: [enforce fail at inline_container.cc:746] . open file failed with strerror: Permission denied 2026-11-11 15:04:51,191 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:51272 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 15:13:37,431 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:44784 - "POST /identify HTTP/1.1" 200 OK INFO: 172.19.0.1:41488 - "GET /rest/common/info/version/full.json HTTP/1.1" 404 Not Found INFO: 172.19.0.1:41492 - "GET /rest/services HTTP/1.1" 404 Not Found INFO: 172.19.0.1:41496 - "GET /api/v1/status HTTP/1.1" 404 Not Found WARNING: Unsupported upgrade request. WARNING: No supported WebSocket library detected. Please use "pip install 'uvicorn[standard]'", or install 'websockets' or 'wsproto' manually. INFO: 172.19.0.1:41500 - "GET /api HTTP/1.1" 404 Not Found 2026-11-11 16:16:11,020 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:56764 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 17:26:54,696 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:49342 - "POST /identify HTTP/1.1" 200 OK 2026-11-11 17:35:27,255 [INFO] voiceid: Ergebnis: unknown (Score: 0.0000) INFO: 172.19.0.4:57442 - "POST /identify HTTP/1.1" 200 OKinspect hannah-voiceid
iob@iob:/opt/hannah$ docker inspect hannah-voiceid [ { "Id": "566e7c9bf09de111f97cd18fd950ea870fc9392b7385ffa06b38f4e20981fdcb", "Created": "2026-11-07T15:14:01.484039591Z", "Path": "python", "Args": [ "app.py", "--config", "/etc/hannah-voiceid/config.yaml" ], "State": { "Status": "running", "Running": true, "Paused": false, "Restarting": false, "OOMKilled": false, "Dead": false, "Pid": 3238161, "ExitCode": 0, "Error": "", "StartedAt": "2026-11-07T15:14:24.045702164Z", "FinishedAt": "0001-01-01T00:00:00Z" }, "Image": "sha256:8d67be3b01c32df918008228b1dd5c3ea22b3d4ff80ca7ad3055fd2004c5aa9f", "ResolvConfPath": "/var/lib/docker/containers/566e7c9bf09de111f97cd18fd950ea870fc9392b7385ffa06b38f4e20981fdcb/resolv.conf", "HostnamePath": "/var/lib/docker/containers/566e7c9bf09de111f97cd18fd950ea870fc9392b7385ffa06b38f4e20981fdcb/hostname", "HostsPath": "/var/lib/docker/containers/566e7c9bf09de111f97cd18fd950ea870fc9392b7385ffa06b38f4e20981fdcb/hosts", "LogPath": "/var/lib/docker/containers/566e7c9bf09de111f97cd18fd950ea870fc9392b7385ffa06b38f4e20981fdcb/566e7c9bf09de111f97cd18fd950ea870fc9392b7385ffa06b38f4e20981fdcb-json.log", "Name": "/hannah-voiceid", "RestartCount": 0, "Driver": "overlayfs", "Platform": "linux", "MountLabel": "", "ProcessLabel": "", "AppArmorProfile": "docker-default", "ExecIDs": null, "HostConfig": { "Binds": [ "hannah_hannah_mem:/mnt/hannah_mem:rw" ], "ContainerIDFile": "", "LogConfig": { "Type": "json-file", "Config": {} }, "NetworkMode": "hannah_hannah_network", "PortBindings": {}, "RestartPolicy": { "Name": "unless-stopped", "MaximumRetryCount": 0 }, "AutoRemove": false, "VolumeDriver": "", "VolumesFrom": null, "ConsoleSize": [ 0, 0 ], "CapAdd": null, "CapDrop": null, "CgroupnsMode": "private", "Dns": null, "DnsOptions": null, "DnsSearch": null, "ExtraHosts": [], "GroupAdd": null, "IpcMode": "private", "Cgroup": "", "Links": null, "OomScoreAdj": 0, "PidMode": "", "Privileged": false, "PublishAllPorts": false, "ReadonlyRootfs": false, "SecurityOpt": null, "UTSMode": "", "UsernsMode": "", "ShmSize": 67108864, "Runtime": "runc", "Isolation": "", "CpuShares": 0, "Memory": 0, "NanoCpus": 0, "CgroupParent": "", "BlkioWeight": 0, "BlkioWeightDevice": null, "BlkioDeviceReadBps": null, "BlkioDeviceWriteBps": null, "BlkioDeviceReadIOps": null, "BlkioDeviceWriteIOps": null, "CpuPeriod": 0, "CpuQuota": 0, "CpuRealtimePeriod": 0, "CpuRealtimeRuntime": 0, "CpusetCpus": "", "CpusetMems": "", "Devices": null, "DeviceCgroupRules": null, "DeviceRequests": null, "MemoryReservation": 0, "MemorySwap": 0, "MemorySwappiness": null, "OomKillDisable": null, "PidsLimit": null, "Ulimits": null, "CpuCount": 0, "CpuPercent": 0, "IOMaximumIOps": 0, "IOMaximumBandwidth": 0, "MaskedPaths": [ "/proc/acpi", "/proc/asound", "/proc/interrupts", "/proc/kcore", "/proc/keys", "/proc/latency_stats", "/proc/sched_debug", "/proc/scsi", "/proc/timer_list", "/proc/timer_stats", "/sys/devices/virtual/powercap", "/sys/firmware", "/sys/devices/system/cpu/cpu0/thermal_throttle", "/sys/devices/system/cpu/cpu1/thermal_throttle", "/sys/devices/system/cpu/cpu2/thermal_throttle", "/sys/devices/system/cpu/cpu3/thermal_throttle" ], "ReadonlyPaths": [ "/proc/bus", "/proc/fs", "/proc/irq", "/proc/sys", "/proc/sysrq-trigger" ] }, "Storage": { "RootFS": { "Snapshot": { "Name": "overlayfs" } } }, "Mounts": [ { "Type": "volume", "Name": "hannah_hannah_mem", "Source": "/var/lib/docker/volumes/hannah_hannah_mem/_data", "Destination": "/mnt/hannah_mem", "Driver": "local", "Mode": "rw", "RW": true, "Propagation": "" } ], "Config": { "Hostname": "566e7c9bf09d", "Domainname": "", "User": "appuser", "AttachStdin": false, "AttachStdout": true, "AttachStderr": true, "Tty": false, "OpenStdin": false, "StdinOnce": false, "Env": [ "HANNAH_VOICEID_HANNAH__ADDRESS=hannah-core:50051", "HANNAH_VOICEID_RECOGNITION__UNKNOWN_THRESHOLD=0.25", "HANNAH_VOICEID_RECOGNITION__UNCERTAIN_THRESHOLD=0.40", "PATH=/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin", "LANG=C.UTF-8", "PYTHON_VERSION=3.14.10", "PYTHON_SHA256=de414a57119abef52784d8993e341d53aed635fc2b05c2607d9f98a2c5b72032" ], "Cmd": [ "python", "app.py", "--config", "/etc/hannah-voiceid/config.yaml" ], "Image": "quay.io/m1kad0/hannah-voiceid:latest-cpu", "Volumes": null, "WorkingDir": "/app", "Entrypoint": null, "Labels": { "com.docker.compose.config-hash": "0fda604745dfa6fd902644104945210de532171134c36fee825e956d10a494ea", "com.docker.compose.container-number": "1", "com.docker.compose.depends_on": "hannah-core:service_healthy:false", "com.docker.compose.image": "sha256:a01956d19190a5b3650f952263a29e12fbbebbec475eee6818e56d9ee6cf3138", "com.docker.compose.oneoff": "False", "com.docker.compose.project": "hannah", "com.docker.compose.project.config_files": "/opt/hannah/docker-compose.yml", "com.docker.compose.project.working_dir": "/opt/hannah", "com.docker.compose.replace": "hannah-voiceid", "com.docker.compose.service": "hannah-voiceid", "com.docker.compose.version": "5.7.0", "org.opencontainers.image.description": "VoiceID (CPU-only torch build)" } }, "NetworkSettings": { "SandboxID": "28fc5925ba61b49bf09d1cb318ecc0268c05c44f058ef6745ea06fbc13e46834", "SandboxKey": "/var/run/docker/netns/28fc5925ba61", "Ports": {}, "Networks": { "hannah_hannah_network": { "IPAMConfig": null, "Links": null, "Aliases": [ "hannah-voiceid", "hannah-voiceid" ], "DriverOpts": null, "GwPriority": 0, "NetworkID": "e6f332c99d7e99f15e0b26216e4ec676815cbd2ab2a18e80897e931f2dcda1a2", "EndpointID": "272d42186453c5ae565b4865be21c3be5b9376087998bd95aa03f26ae7d9f78b", "Gateway": "172.19.0.1", "IPAddress": "172.19.0.7", "MacAddress": "9e:aa:66:fb:c1:3e", "IPPrefixLen": 16, "IPv6Gateway": "", "GlobalIPv6Address": "", "GlobalIPv6PrefixLen": 0, "DNSNames": [ "hannah-voiceid", "566e7c9bf09d" ] } } }, "ImageManifestDescriptor": { "mediaType": "application/vnd.docker.distribution.manifest.v2+json", "digest": "sha256:a01956d19190a5b3650f952263a29e12fbbebbec475eee6818e56d9ee6cf3138", "size": 2051, "platform": { "architecture": "amd64", "os": "linux" } } } ] -
Bitte das voiceID-Image neu pullen ("docker pull quay.io/m1kad0/hannah-voiceid:latest-cpu") und dann eine neue compose-Datei erzeugen. Konkret muss man ein neues Volume hinzufügen, ich denke besser ist es in den Docs zu schauen, die zeigen die vollständige Form.
