TibberLink Adapter
@TobW also bei mir wird noch immer kein live Meassurement Wert geliefert.
2026-06-28 10:21:34.627 - info: host.raspberrypi instance system.adapter.tibberlink.0 in version "7.1.3" started with pid 79766 2026-06-28 10:21:39.179 - info: tibberlink.0 (79766) starting. Version 7.1.3 in /opt/iobroker/node_modules/iobroker.tibberlink, node: v22.22.2, js-controller: 7.2.2 2026-06-28 10:21:40.276 - info: tibberlink.0 (79766) Tibber Data API: vehicle polling started every 5 minute(s) 2026-06-28 10:22:39.805 - warn: tibberlink.0 (79766) Error on Tibber feed: Unknown error 2026-06-28 10:22:39.807 - warn: tibberlink.0 (79766) [tibberPulse]: received null liveMeasurement from Tibber feed — skipping 2026-06-28 10:24:39.619 - warn: tibberlink.0 (79766) Error on Tibber feed: Unknown error 2026-06-28 10:24:39.620 - warn: tibberlink.0 (79766) [tibberPulse]: received null liveMeasurement from Tibber feed — skipping 2026-06-28 10:26:39.698 - warn: tibberlink.0 (79766) Error on Tibber feed: Unknown error 2026-06-28 10:26:39.699 - warn: tibberlink.0 (79766) [tibberPulse]: received null liveMeasurement from Tibber feed — skipping 2026-06-28 10:28:40.074 - warn: tibberlink.0 (79766) Error on Tibber feed: Unknown error 2026-06-28 10:28:40.075 - warn: tibberlink.0 (79766) [tibberPulse]: received null liveMeasurement from Tibber feed — skipping 2026-06-28 10:30:39.536 - warn: tibberlink.0 (79766) Error on Tibber feed: Unknown error 2026-06-28 10:30:39.537 - warn: tibberlink.0 (79766) [tibberPulse]: received null liveMeasurement from Tibber feed — skipping 2026-06-28 10:31:39.540 - warn: tibberlink.0 (79766) A feed was disconnected very often. I keep trying to reconnect with incremental delay - Error text sent by Tibber: Disconnected from Tibber feed.Funktioniert der Adapter bei dir?
Ich habe den Log-Auszug mal bei github zu dem issue angehängt.
mir ist seit ein paar Tagen aufgefallen das im Log oft der gleiche Fehler aufggelistet wird, dass ein Wert nicht verarbeitet werden kann:influxdb.0 2026-08-26 22:27:52.469 warn Error: null value for tibberlink.0.Homes.XXXXXX.LiveMeasurement.voltagePhase3 can not be handledDiesen Meldung bekomme ich für alle Phasen zu unterschiedlichen Zeiten und auch nur bei den Phasen, sonst ist kein anderer Wert davon betroffen.
Primär ist es kein Fehler von dem Tibber Adapter, aber der Wert wird von diesem Verarbeitet. Konnte sonst noch jemand etwas ähnliches beobachten?
Wie kann ich diese Warnung los werden?Gruß Chris
Guten Morgen zusammen,
seit heute früh bekomme ich vom Tibber Pulse keine Daten mehr, dieses Mal wird auch der Hex-Wert nicht aktualisert. FOlgende Fehlermeldungen sind im log:
tibberlink.0 2026-09-25 06:56:16.613 warn [tibberLocal]: Error local polling of Tibber Pulse RAW data: AxiosError: Request failed with status code 404
tibberlink.0 2026-09-25 06:56:18.645 error An error occured during local poll of Pulse data (getDataAsHexString)Hat jemand ähnliche Probleme? Über die Integration in HA kommen Werte, da gabs aber heute morgen gleich ein Update.
Grüße und schönes Wochenende!
tibberlink.0 2026-09-25 06:56:18.645 error An error occured during local poll of Pulse data (getDataAsHexString)Bei mir der gleiche gleiche Fehler.
ich glaue, der Pulse hat eine neue Weboberfläche bekommen... zumindest sieht sie bei mir anderes aus, als ich sie dass letzte mal genutzt habe....
Da steht auch was von:
https://github.com/marq24/ha-tibber-pulse-local/releases#release-2026.9.8 -
wird schon dran gearbeitet :-)
ja, es hat eine neue firmware gegeben und jetzt werden die Daten anders abgefragt für schnelle Hilfe hilft folgender Code.
Auf das Terminal gehen und dort dann folgendes eingeben.
cd /opt/iobroker/node_modules/iobroker.tibberlink/build/lib cp tibberLocal.js tibberLocal.js.bak sed -i 's@/metrics\.json?node_id=@/node_metrics.json?node_id=@g; s@/data\.json?node_id=@/node_data.json?node_id=@g' tibberLocal.js iobroker restart tibberlink.0Hilft natürlich nur so lange bis zum nächsten Adapter Update, aber ich denke @hombach ist da fix und bringt schnell ein neues Update mit den Fixes raus.
Gruß -
Hi!
Ich habe das gleiche Problem, bekomme es aber nicht hin.
Gehe ich auf v7.3.2 wird mir nichts angezeigt. Gehe ich zurück auf v6.0.3 habe ich meine Kurve wieder.
Auch die Versionen dazwischen funktionieren nicht.
Führe ich das oben genannte aus, ändert es nichts. Ich denke es liegt daran, das ich es nicht richtig eingebe. Muss ich das genau so kopieren und einfügen? Ich mache das in der Regel Zeile für Zeile. Vielleicht liegt hier der Fehler.Danke!
Ich habe folgendes Problem:
Aktuell ist der Preis "Normal" und um 23:00 ändert er sich auf "CHEAP".
Warum steht bei Minimum das Level auf Normal und nicht auf "CHEAP". Habe ich einen Denkfehler?
Ich möchte den Minimum-Wert für einen Vergleich zu benutzen (Wenn aktueller Wert = Minimum Wert, dann ist es für Heute am günstigsten zu laden)
Danke und Gruß
Marcus -
Oh, das ist der Fehler - habe garnicht auf das Datum geschaut :)
OK - ich werde mal versuchen die Ordner zu löschen. Calculator kannte ich noch nicht - schaue ich mir auch mal an!Da das Auto nicht immer dransteckt und ich manchmal nur will, dass es Nachts am günstigsten Geladen wird, weiß ich auch noch nicht die beste Logik. Ist der erste Winter mit der Stündlichen Abrechnung für mich!
