Matter (Adapter) Problem
Claude hat das hier gerade rausgefunden und sagt:
Controller fails to start: "Storage is locked by another process" (stale ota/matter.pid, PID no longer exists)Description
After a few days of normal operation, matter.0 shows a green instance but no devices are available. Restarting the instance does not help. The controller fails to start on every attempt with a storage lock error. The lock is held by a PID that no longer exists (stale lock).
Rebooting the whole Raspberry Pi also fixes it, but I now have to do that regularly. Removing the stale lock files manually (see below) fixes it without a reboot.
Environment
ioBroker.matter: 1.3.1
js-controller: 7.2.2
admin: 8.0.14
Node.js: 24.21.0
OS: Debian 13 (trixie), Raspberry Pi 5 (8 GB), arm64
Thread network via Apple border router, 8 IKEA Thread devices
SymptomsInstance is green, no log output, devices are missing in the adapter UI
After restarting the instance, the log shows the error below and the devices are still missing
The error occurred on every start attempt (e.g. 13:10, 15:36, 15:44)
Logerror: matter.0 (3445) Failed to start the controller: [crashed-dependency] MatterController unavailable due to initialization error Caused by: [endpoint-behaviors] Behaviors have errors Cause #0: [behavior-initialization] Error initializing controller.ota-provider.otaSoftwareUpdateProvider Caused by: [crashed-dependency] controller.ota-provider.softwareupdates initialization failed Cause #1: [behavior-initialization] Error initializing controller.ota-provider.softwareupdates Caused by: [crashed-dependency] DclOtaUpdateService unavailable due to initialization error Caused by: [storage-lock] Storage is locked by another process (pid 2087) at acquireLock (@matter/nodejs/src/fs/lock-utils.ts:139:19) at acquireDirectoryLock (@matter/nodejs/src/fs/lock-utils.ts:90:5) at DatafileRoot.#acquireRef (@matter/general/src/storage/DatafileRoot.ts:74:29) at FlatFileBlobStorageDriver.initialize (@matter/nodejs/src/storage/fs/FlatFileBlobStorageDriver.ts:46:9) at StorageService.#openBlobFilesystem (@matter/general/src/storage/StorageService.ts:395:13)Analysis
ps -p 2087 returns nothing, so the process named in the error does not exist anymore.
fuser on the lock file shows no process holding it.
The directory iobroker-data/matter.0/ota/ contained:
matter.lock (0 bytes)
matter.pid (content: 2087 999e67500e993e0a)
driver.json
Both matter.lock and matter.pid were dated the previous day (Oct 19, 15:20), i.e. left over from an earlier run.
Workaroundiob stop matter.0 mv iobroker-data/matter.0/ota/matter.pid iobroker-data/matter.0/ota/matter.lock <somewhere else> iob start matter.0After this, all 8 nodes connected again immediately.
Expected behavior
A stale lock (PID not running) should be detected and ignored or cleaned up, and the lock should be released on adapter shutdown or termination. Even if the lock cannot be acquired, a failing OTA service should not prevent the whole controller from starting.
Könnte vielleicht dann auftreten, wenn ich den „update“ Knop klicke.
Allerdings ist Claude gerade wieder aufgebraucht. Werde ich morgen mit ihm weiter bereden. -
Environment
admin: 8.0.14
Node.js: 24.21.0
driver.json
Expected behavior
Ich habe einen AppleTV (den mit LAN) und einen HomePod mini, wenn du das meinst.
Eine Fritzbox 7530 und einen 8 Port LAN Switch von Netgear.
Es lief ja alles schon monatelang perfekt.
Die MoT Teile sind alle von IKEA.Es kam in letzter Zeit nix neues dazu.
Environment
admin: 8.0.14
Node.js: 24.21.0
driver.json
Expected behavior
Allerdings ist Claude gerade wieder aufgebraucht. Werde ich morgen mit ihm weiter bereden.@darkblu Die Analyse passt. Mit dem Netzwerk hat das nichts zu tun: Der Controller startet gar nicht, weil im Verzeichnis
iobroker-data/matter.0/ota/eine alte Sperre von einem früheren Prozess liegen bleibt. Deshalb hilft auch der Neustart der Instanz nicht, nur der Reboot oder das Löschen der Dateien.Bis es behoben ist, ist dein Workaround in Ordnung:
iob stop matter.0 rm /opt/iobroker/iobroker-data/matter.0/ota/matter.lock /opt/iobroker/iobroker-data/matter.0/ota/matter.pid iob start matter.0Bitte kopier die Analyse auch in dein Issue https://github.com/ioBroker/ioBroker.matter/issues/898, vor allem den Inhalt vom Verzeichnis
otaund die Uhrzeit der Dateien. Spannend wäre auch, was um die Zeit der Dateien (19.10. 15:20) im Log passiert ist: Wurde die Instanz da gestoppt, gab es ein Update oder einen Neustart vom js-controller?In matter.js wurde in letzter Zeit an diesen Sperrdateien einiges geändert, und die nächste Adapterversion bringt ein neueres matter.js mit. @apollon77 kann bestimmt sagen, ob dein Fall damit erledigt ist.
@bluefox ,
gestern um 15:20:00 bis 15:20:59 sind im Log über 1500 Sachen passiert.
Ich blicke da aber nicht durch.Die Dateien aus dem ota Ordner habe ich auch bei Github hochgeladen, bzw nur die .json, die .pid und .lock gehen nicht.
Allerdings ist die .lock leer,
in der .pid steht: 3751 228c20699dd9506edie sind aber auch von heute, siehe screenshot:
@bluefox ,
@darkblu Dass die beiden Dateien heute wieder da sind, ist normal. Die laufende Instanz legt sie beim Start an und hält die Sperre, solange sie läuft. Zum Problem wird es erst, wenn der Prozess weg ist und die Dateien liegen bleiben. Prüf mal, ob 3751 gerade deine matter.0 ist:
ps -fp 3751Wenn dort matter.0 steht, ist alles in Ordnung.
Die 1500 Zeilen musst du nicht alle lesen. Uns interessiert nur, was matter.0 und der Host um die Zeit gemacht haben:
zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0|host\." | head -200Poste die Ausgabe bitte hier oder im Issue. Wichtig ist vor allem, ob die Instanz da gestoppt oder neu gestartet wurde und ob dabei "send kill signal" oder ein Exit-Code auftaucht.
Damit wir das nächste Mal direkt sehen, was passiert: Wenn es wieder auftritt, lösch die Dateien erst nach diesem Befehl:
ls -la --time-style=full-iso /opt/iobroker/iobroker-data/matter.0/ota/ cat /opt/iobroker/iobroker-data/matter.0/ota/matter.pidDann suchen wir im Log nach genau dieser Uhrzeit und PID.
hier die Ausgabe von:
ps -fp 3751dirk@smart:~ $ ps -fp 3751 UID PID PPID C STIME TTY TIME CMDhätte ich wohl gestern abend direkt machen sollen ?
und hier die Ausgabe von:
zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0|host\." | head -200dirk@smart:~ $ zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0|host\." | head -200 2026-10-19 15:10:10.035 - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 6194 2026-10-19 15:10:12.668 - info: host.smart instance system.adapter.dwd.0 having pid 6194 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-10-19 15:13:21.477 - info: host.smart stopInstance system.adapter.admin.0 (force=false, process=true) 2026-10-19 15:13:21.520 - info: host.smart stopInstance system.adapter.admin.0 send kill signal 2026-10-19 15:13:22.074 - info: host.smart instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-10-19 15:13:25.078 - info: host.smart instance system.adapter.admin.0 in version "8.0.14" started with pid 6215 2026-10-19 15:13:55.665 - info: host.smart stopInstance system.adapter.admin.0 (force=false, process=true) 2026-10-19 15:13:55.716 - info: host.smart stopInstance system.adapter.admin.0 send kill signal 2026-10-19 15:13:56.276 - info: host.smart instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-10-19 15:13:59.221 - info: host.smart instance system.adapter.admin.0 in version "8.0.14" started with pid 6263 2026-10-19 15:14:42.595 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/voltage changed to 237000 2026-10-19 15:14:42.597 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/apparentCurrent changed to 2 2026-10-19 15:14:42.599 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/activePower changed to 100 2026-10-19 15:14:42.600 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/apparentPower changed to 500 2026-10-19 15:14:42.602 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/rmsVoltage changed to 237000 2026-10-19 15:14:42.604 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/rmsCurrent changed to 2 2026-10-19 15:14:42.605 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/rmsPower changed to 474 2026-10-19 15:14:42.607 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/powerFactor changed to 2100 2026-10-19 15:14:42.607 - debug: matter.0 (2075) Set matter.0.controller.14388134951535934862.ElectricalSensor-2.VOLTAGE to 237 (ack = true) 2026-10-19 15:14:42.607 - debug: matter.0 (2075) Set matter.0.controller.14388134951535934862.ElectricalSensor-2.ELECTRIC_POWER to 0.1 (ack = true) 2026-10-19 15:14:44.603 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/activePower changed to 0 2026-10-19 15:14:44.605 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/rmsCurrent changed to 0 2026-10-19 15:14:44.607 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/rmsPower changed to 0 2026-10-19 15:14:44.607 - debug: matter.0 (2075) Set matter.0.controller.14388134951535934862.ElectricalSensor-2.ELECTRIC_POWER to 0 (ack = true) 2026-10-19 15:14:45.623 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/apparentCurrent changed to 0 2026-10-19 15:14:45.625 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/apparentPower changed to 0 2026-10-19 15:14:45.627 - debug: matter.0 (2075) handleChangedAttribute "14388134951535934862": Attribute undefined/2/0x0090/powerFactor changed to 0 2026-10-19 15:15:10.055 - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 6310 2026-10-19 15:15:12.694 - info: host.smart instance system.adapter.dwd.0 having pid 6310 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-10-19 15:15:32.152 - info: host.smart received SIGTERM 2026-10-19 15:15:32.159 - debug: matter.0 (2075) Send to GUI: {"command":"stopped"} 2026-10-19 15:15:32.152 - info: host.smart stopInstance system.adapter.admin.0 (force=false, process=true) 2026-10-19 15:15:32.152 - info: host.smart stopInstance system.adapter.influxdb.0 (force=false, process=true) 2026-10-19 15:15:32.153 - info: host.smart stopInstance system.adapter.javascript.0 (force=false, process=true) 2026-10-19 15:15:32.153 - info: host.smart stopInstance system.adapter.whatsapp-cmb.0 (force=false, process=true) 2026-10-19 15:15:32.153 - info: host.smart stopInstance system.adapter.backitup.0 (force=false, process=true) 2026-10-19 15:15:32.154 - info: host.smart stopInstance system.adapter.alexa2.0 (force=false, process=true) 2026-10-19 15:15:32.154 - info: host.smart stopInstance system.adapter.cloud.0 (force=false, process=true) 2026-10-19 15:15:32.180 - info: host.smart stopInstance system.adapter.device-watcher.0 (force=false, process=true) 2026-10-19 15:15:32.181 - info: host.smart stopInstance system.adapter.feiertage.0 (force=false, process=false) 2026-10-19 15:15:32.181 - info: host.smart stopInstance canceled schedule system.adapter.feiertage.0 2026-10-19 15:15:32.181 - info: host.smart stopInstance system.adapter.fullybrowser.0 (force=false, process=true) 2026-10-19 15:15:32.181 - info: host.smart stopInstance system.adapter.hmip.0 (force=false, process=true) 2026-10-19 15:15:32.181 - info: host.smart stopInstance system.adapter.homeconnect.0 (force=false, process=true) 2026-10-19 15:15:32.182 - info: host.smart stopInstance system.adapter.hue.0 (force=false, process=true) 2026-10-19 15:15:32.182 - info: host.smart stopInstance system.adapter.ical.0 (force=false, process=false) 2026-10-19 15:15:32.182 - info: host.smart stopInstance canceled schedule system.adapter.ical.0 2026-10-19 15:15:32.182 - info: host.smart stopInstance system.adapter.modbus.0 (force=false, process=true) 2026-10-19 15:15:32.182 - info: host.smart stopInstance system.adapter.mqtt.0 (force=false, process=true) 2026-10-19 15:15:32.182 - info: host.smart stopInstance system.adapter.nuki.0 (force=false, process=true) 2026-10-19 15:15:32.183 - info: host.smart stopInstance system.adapter.shelly.0 (force=false, process=true) 2026-10-19 15:15:32.183 - info: host.smart stopInstance system.adapter.shelly.1 (force=false, process=true) 2026-10-19 15:15:32.183 - info: host.smart stopInstance system.adapter.sonoff.0 (force=false, process=true) 2026-10-19 15:15:32.183 - info: host.smart stopInstance system.adapter.sonos.0 (force=false, process=true) 2026-10-19 15:15:32.183 - info: host.smart stopInstance system.adapter.tr-064.0 (force=false, process=true) 2026-10-19 15:15:32.183 - info: host.smart stopInstance system.adapter.tuya.0 (force=false, process=true) 2026-10-19 15:15:32.183 - info: host.smart stopInstance system.adapter.uv-protect.0 (force=false, process=false) 2026-10-19 15:15:32.184 - info: host.smart stopInstance system.adapter.zigbee.0 (force=false, process=true) 2026-10-19 15:15:32.184 - info: host.smart stopInstance system.adapter.synology.0 (force=false, process=true) 2026-10-19 15:15:32.212 - info: host.smart stopInstance system.adapter.zendure-solarflow.0 (force=false, process=true) 2026-10-19 15:15:32.213 - info: host.smart stopInstance system.adapter.discovery.0 (force=false, process=true) 2026-10-19 15:15:32.213 - info: host.smart stopInstance system.adapter.sourceanalytix.0 (force=false, process=true) 2026-10-19 15:15:32.213 - info: host.smart stopInstance system.adapter.smart-eq.0 (force=false, process=true) 2026-10-19 15:15:32.213 - info: host.smart stopInstance system.adapter.web.0 (force=false, process=true) 2026-10-19 15:15:32.213 - info: host.smart stopInstance system.adapter.vis.0 (force=false, process=false) 2026-10-19 15:15:32.213 - info: host.smart stopInstance system.adapter.dwd.0 (force=false, process=false) 2026-10-19 15:15:32.213 - info: host.smart stopInstance canceled schedule system.adapter.dwd.0 2026-10-19 15:15:32.213 - info: host.smart stopInstance system.adapter.echarts.0 (force=false, process=true) 2026-10-19 15:15:32.214 - info: host.smart stopInstance system.adapter.energiefluss.0 (force=false, process=false) 2026-10-19 15:15:32.214 - info: host.smart stopInstance system.adapter.iot.0 (force=false, process=true) 2026-10-19 15:15:32.214 - info: host.smart stopInstance system.adapter.linux-control.0 (force=false, process=true) 2026-10-19 15:15:32.214 - info: host.smart stopInstance system.adapter.reolink.0 (force=false, process=false) 2026-10-19 15:15:32.214 - info: host.smart stopInstance system.adapter.statistics.0 (force=false, process=true) 2026-10-19 15:15:32.214 - info: host.smart stopInstance system.adapter.trashschedule.0 (force=false, process=true) 2026-10-19 15:15:32.214 - info: host.smart stopInstance system.adapter.upnp.0 (force=false, process=true) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.vis-canvas-gauges.0 (force=false, process=false) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.vis-players.0 (force=false, process=false) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.vis-plumb.0 (force=false, process=false) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.wled.0 (force=false, process=true) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.mytime.0 (force=false, process=true) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.mitsubishi-local-control.0 (force=false, process=true) 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-19 15:15:32.216 - info: host.smart stopInstance system.adapter.awtrix-ng.0 (force=false, process=true) 2026-10-19 15:15:32.216 - info: host.smart stopInstance system.adapter.awtrix-ng.1 (force=false, process=true) 2026-10-19 15:15:32.225 - info: host.smart stopInstance system.adapter.awtrix-ng.2 (force=false, process=true) 2026-10-19 15:15:32.159 - info: matter.0 (2075) 2026-10-19 15:15:32.159 NOTICE Runtime Shutting down 2026-10-19 15:15:32.166 - info: matter.0 (2075) Node "3138025706799876746" disconnected 2026-10-19 15:15:32.170 - info: matter.0 (2075) Node "2" disconnected 2026-10-19 15:15:32.172 - info: matter.0 (2075) Node "4" disconnected 2026-10-19 15:15:32.176 - info: matter.0 (2075) Node "5" disconnected 2026-10-19 15:15:32.181 - info: matter.0 (2075) Node "3" disconnected 2026-10-19 15:15:32.186 - info: matter.0 (2075) Node "14388134951535934862" disconnected 2026-10-19 15:15:32.189 - info: matter.0 (2075) Node "905838670972218924" disconnected 2026-10-19 15:15:32.192 - info: matter.0 (2075) Node "1" disconnected 2026-10-19 15:15:32.196 - info: matter.0 (2075) Stopping Controller... 2026-10-19 15:15:32.198 - info: matter.0 (2075) 2026-10-19 15:15:32.198 NOTICE Node controller going offline 2026-10-19 15:15:32.203 - debug: matter.0 (2075) 2026-10-19 15:15:32.203 INFO ClientNode controller.@1:2b8c81c11dd9ca8a going offline 2026-10-19 15:15:32.206 - debug: matter.0 (2075) 2026-10-19 15:15:32.206 INFO ClientNode controller.@1:2 going offline 2026-10-19 15:15:32.206 - debug: matter.0 (2075) 2026-10-19 15:15:32.206 INFO ClientNode controller.@1:4 going offline 2026-10-19 15:15:32.207 - debug: matter.0 (2075) 2026-10-19 15:15:32.207 INFO ClientNode controller.@1:5 going offline 2026-10-19 15:15:32.207 - debug: matter.0 (2075) 2026-10-19 15:15:32.207 INFO ClientNode controller.@1:3 going offline 2026-10-19 15:15:32.209 - debug: matter.0 (2075) 2026-10-19 15:15:32.209 INFO ClientNode controller.@1:c7acec81beae7d8e going offline 2026-10-19 15:15:32.210 - debug: matter.0 (2075) 2026-10-19 15:15:32.210 INFO ClientNode controller.@1:c922f78cf1c6e2c going offline 2026-10-19 15:15:32.210 - debug: matter.0 (2075) 2026-10-19 15:15:32.210 INFO ClientNode controller.@1:1 going offline 2026-10-19 15:15:32.212 - debug: matter.0 (2075) 2026-10-19 15:15:32.212 INFO ClientNode controller.@1:2b8c81c11dd9ca8a is offline 2026-10-19 15:15:32.213 - debug: matter.0 (2075) 2026-10-19 15:15:32.213 INFO ClientNode controller.@1:2 is offline 2026-10-19 15:15:32.213 - debug: matter.0 (2075) 2026-10-19 15:15:32.213 INFO ClientNode controller.@1:4 is offline 2026-10-19 15:15:32.214 - debug: matter.0 (2075) 2026-10-19 15:15:32.214 INFO ClientNode controller.@1:5 is offline 2026-10-19 15:15:32.215 - debug: matter.0 (2075) 2026-10-19 15:15:32.215 INFO ClientNode controller.@1:3 is offline 2026-10-19 15:15:32.215 - debug: matter.0 (2075) 2026-10-19 15:15:32.215 INFO ClientNode controller.@1:c7acec81beae7d8e is offline 2026-10-19 15:15:32.216 - debug: matter.0 (2075) 2026-10-19 15:15:32.216 INFO ClientNode controller.@1:c922f78cf1c6e2c is offline 2026-10-19 15:15:32.216 - debug: matter.0 (2075) 2026-10-19 15:15:32.216 INFO ClientNode controller.@1:1 is offline 2026-10-19 15:15:32.387 - info: host.smart stopInstance system.adapter.admin.0 send kill signal 2026-10-19 15:15:32.405 - debug: matter.0 (2075) 2026-10-19 15:15:32.405 INFO Transaction ◦offline#2eb locked controller.generalDiagnostics.state 2026-10-19 15:15:32.419 - info: matter.0 (2075) Got terminate signal TERMINATE_YOURSELF 2026-10-19 15:15:32.427 - info: host.smart stopInstance system.adapter.javascript.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.whatsapp-cmb.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.backitup.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.alexa2.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.cloud.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.device-watcher.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.fullybrowser.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.hmip.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.homeconnect.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.hue.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.modbus.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.mqtt.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.nuki.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.shelly.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.shelly.1 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.sonoff.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.sonos.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.tr-064.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.tuya.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.zigbee.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.synology.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.zendure-solarflow.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.discovery.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.sourceanalytix.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.smart-eq.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.web.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.echarts.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.iot.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.linux-control.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.statistics.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.trashschedule.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.upnp.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.wled.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.mytime.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.mitsubishi-local-control.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.awtrix-ng.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.awtrix-ng.1 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.awtrix-ng.2 send kill signal 2026-10-19 15:15:32.563 - warn: host.smart instance system.adapter.javascript.0 terminated due to SIGTERM 2026-10-19 15:15:32.563 - info: host.smart instance system.adapter.javascript.0 terminated with code null () 2026-10-19 15:15:32.604 - debug: matter.0 (2075) 2026-10-19 15:15:32.604 INFO Transaction ◦offline#2eb committed and unlocked 1 resource 2026-10-19 15:15:32.606 - debug: matter.0 (2075) 2026-10-19 15:15:32.606 INFO MdnsAdvertisement Unpublishing kind: operational service: mdns:C1124F59EBABAC14-E3CF4773CA77CE57._matter._tcp.local time: 12h 30m 7s 2026-10-19 15:15:32.610 - debug: matter.0 (2075) 2026-10-19 15:15:32.610 INFO Session @1:2b8c81c11dd9ca8a•65bd Session ended 2026-10-19 15:15:32.610 - debug: matter.0 (2075) 2026-10-19 15:15:32.610 INFO Session @1:2•65be Session ended 2026-10-19 15:15:32.610 - debug: matter.0 (2075) 2026-10-19 15:15:32.610 INFO Session @1:4•65bf Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:3•65c1 Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:c922f78cf1c6e2c•65c3 Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:c7acec81beae7d8e•65c2 Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:1•65c4 Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:5•65c0 Session ended 2026-10-19 15:15:32.618 - info: matter.0 (2075) 2026-10-19 15:15:32.618 NOTICE Node controller is offline 2026-10-19 15:15:32.656 - debug: matter.0 (2075) 2026-10-19 15:15:32.656 INFO ServerNodeStore Closed controller storage location: /opt/iobroker/iobroker-data/matter.0/controller driver: iobroker locks: 0 2026-10-19 15:15:32.740 - info: matter.0 (2075) terminating 2026-10-19 15:15:32.741 - debug: matter.0 (2075) Plugin sentry destroyed 2026-10-19 15:15:32.741 - info: matter.0 (2075) Terminated (NO_ERROR): Without reason 2026-10-19 15:15:32.931 - info: host.smart instance system.adapter.synology.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:32.979 - info: host.smart instance system.adapter.mitsubishi-local-control.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.014 - info: host.smart instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.137 - info: host.smart instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.298 - info: host.smart instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.317 - info: host.smart instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.389 - info: host.smart stopInstance timeout system.adapter.admin.0 killing pid 6263 2026-10-19 15:15:33.421 - info: host.smart instance system.adapter.sonos.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.422 - info: host.smart instance system.adapter.upnp.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.445 - info: host.smart instance system.adapter.mytime.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.446 - info: host.smart instance system.adapter.hmip.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:15:33.773 - info: host.smart stopInstance timeout system.adapter.whatsapp-cmb.0 killing pid 1320 2026-10-19 15:15:33.779 - info: host.smart stopInstance timeout system.adapter.fullybrowser.0 killing pid 1438 2026-10-19 15:15:33.780 - info: host.smart stopInstance timeout system.adapter.homeconnect.0 killing pid 1471 2026-10-19 15:15:33.780 - info: host.smart stopInstance timeout system.adapter.hue.0 killing pid 1488 2026-10-19 15:15:33.783 - info: host.smart stopInstance timeout system.adapter.modbus.0 killing pid 1522 2026-10-19 15:15:33.783 - info: host.smart stopInstance timeout system.adapter.mqtt.0 killing pid 1539 2026-10-19 15:15:33.784 - info: host.smart stopInstance timeout system.adapter.shelly.0 killing pid 1572 2026-10-19 15:15:33.784 - info: host.smart stopInstance timeout system.adapter.shelly.1 killing pid 1589 2026-10-19 15:15:33.784 - info: host.smart stopInstance timeout system.adapter.sonoff.0 killing pid 1606 2026-10-19 15:15:33.784 - info: host.smart stopInstance timeout system.adapter.web.0 killing pid 1774 2026-10-19 15:15:33.784 - info: host.smart stopInstance timeout system.adapter.echarts.0 killing pid 1824 2026-10-19 15:15:33.785 - info: host.smart stopInstance timeout system.adapter.awtrix-ng.0 killing pid 2083 2026-10-19 15:15:33.785 - info: host.smart stopInstance timeout system.adapter.awtrix-ng.1 killing pid 2108 2026-10-19 15:15:33.785 - info: host.smart stopInstance timeout system.adapter.awtrix-ng.2 killing pid 2125Dann warte ich aufs "nächste Mal" und mache dann das hier:
checkls -la --time-style=full-iso /opt/iobroker/iobroker-data/matter.0/ota/ cat /opt/iobroker/iobroker-data/matter.0/ota/matter.pid -
checkls -la --time-style=full-iso /opt/iobroker/iobroker-data/matter.0/ota/ cat /opt/iobroker/iobroker-data/matter.0/ota/matter.pid@darkblu Nicht schlimm, das sagt auch so schon etwas. Wenn 3751 nicht mehr existiert, gehört die aktuelle Sperre in
ota/vermutlich schon wieder zu einem Prozess, den es nicht mehr gibt. Bitte schau, ob und mit welcher PID matter.0 gerade läuft, und vergleich das mit der Datei:ps -ef | grep "[m]atter.0" ls -la --time-style=full-iso /opt/iobroker/iobroker-data/matter.0/ota/ cat /opt/iobroker/iobroker-data/matter.0/ota/matter.pidSteht in der Datei eine andere PID als bei der laufenden Instanz, ist die Sperre wieder verwaist. Dann sollte im Log beim letzten Start auch wieder
storage-lockauftauchen.Im Log vom 19.10. sieht man um 15:15:32
host.smart received SIGTERM. Da wurde also der ganze ioBroker gestoppt, kurz bevor die alten Sperrdateien um 15:20 entstanden sind. War das ein Reboot vom Pi? Das zeigt:last -x reboot shutdown | head -20Leider hat
head -200die Ausgabe genau an der spannenden Stelle abgeschnitten. Bitte noch einmal ohne die vielen Debug-Zeilen:zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0|SIGTERM|kill|exit" | grep -vE "handleChangedAttribute|Set matter\.0" | head -100Mich interessiert, ob matter.0 (2075) beim Herunterfahren sauber mit "Terminated" beendet wurde und mit welcher PID sie danach wieder gestartet ist. Ich vermute, dass die Sperre beim Stoppen bzw. Reboot liegen bleibt.
ps -ef | grep "[m]atter.0" ls -la --time-style=full-iso /opt/iobroker/iobroker-data/matter.0/ota/ cat /opt/iobroker/iobroker-data/matter.0/ota/matter.piddie Ausgabe sagt: 2071 und in der .pid steht auch 2071
last -x reboot shutdown | head -20das zeigt leider nur das hier:
-bash: last: command not found...Bitte noch einmal ohne die vielen Debug-Zeilen:
zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0|SIGTERM|kill|exit" | grep -vE "handleChangedAttribute|Set matter\.0" | head -100hier die erneute Ausgabe:
dirk@smart:~ $ zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0|SIGTERM|kill|exit" | grep -vE "handleChangedAttribute|Set matter\.0" | head -100 2026-10-19 15:13:21.520 - info: host.smart stopInstance system.adapter.admin.0 send kill signal 2026-10-19 15:13:55.716 - info: host.smart stopInstance system.adapter.admin.0 send kill signal 2026-10-19 15:15:32.152 - info: host.smart received SIGTERM 2026-10-19 15:15:32.159 - debug: matter.0 (2075) Send to GUI: {"command":"stopped"} 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-19 15:15:32.159 - info: matter.0 (2075) 2026-10-19 15:15:32.159 NOTICE Runtime Shutting down 2026-10-19 15:15:32.166 - info: matter.0 (2075) Node "3138025706799876746" disconnected 2026-10-19 15:15:32.170 - info: matter.0 (2075) Node "2" disconnected 2026-10-19 15:15:32.172 - info: matter.0 (2075) Node "4" disconnected 2026-10-19 15:15:32.176 - info: matter.0 (2075) Node "5" disconnected 2026-10-19 15:15:32.181 - info: matter.0 (2075) Node "3" disconnected 2026-10-19 15:15:32.186 - info: matter.0 (2075) Node "14388134951535934862" disconnected 2026-10-19 15:15:32.189 - info: matter.0 (2075) Node "905838670972218924" disconnected 2026-10-19 15:15:32.192 - info: matter.0 (2075) Node "1" disconnected 2026-10-19 15:15:32.196 - info: matter.0 (2075) Stopping Controller... 2026-10-19 15:15:32.198 - info: matter.0 (2075) 2026-10-19 15:15:32.198 NOTICE Node controller going offline 2026-10-19 15:15:32.203 - debug: matter.0 (2075) 2026-10-19 15:15:32.203 INFO ClientNode controller.@1:2b8c81c11dd9ca8a going offline 2026-10-19 15:15:32.206 - debug: matter.0 (2075) 2026-10-19 15:15:32.206 INFO ClientNode controller.@1:2 going offline 2026-10-19 15:15:32.206 - debug: matter.0 (2075) 2026-10-19 15:15:32.206 INFO ClientNode controller.@1:4 going offline 2026-10-19 15:15:32.207 - debug: matter.0 (2075) 2026-10-19 15:15:32.207 INFO ClientNode controller.@1:5 going offline 2026-10-19 15:15:32.207 - debug: matter.0 (2075) 2026-10-19 15:15:32.207 INFO ClientNode controller.@1:3 going offline 2026-10-19 15:15:32.209 - debug: matter.0 (2075) 2026-10-19 15:15:32.209 INFO ClientNode controller.@1:c7acec81beae7d8e going offline 2026-10-19 15:15:32.210 - debug: matter.0 (2075) 2026-10-19 15:15:32.210 INFO ClientNode controller.@1:c922f78cf1c6e2c going offline 2026-10-19 15:15:32.210 - debug: matter.0 (2075) 2026-10-19 15:15:32.210 INFO ClientNode controller.@1:1 going offline 2026-10-19 15:15:32.212 - debug: matter.0 (2075) 2026-10-19 15:15:32.212 INFO ClientNode controller.@1:2b8c81c11dd9ca8a is offline 2026-10-19 15:15:32.213 - debug: matter.0 (2075) 2026-10-19 15:15:32.213 INFO ClientNode controller.@1:2 is offline 2026-10-19 15:15:32.213 - debug: matter.0 (2075) 2026-10-19 15:15:32.213 INFO ClientNode controller.@1:4 is offline 2026-10-19 15:15:32.214 - debug: matter.0 (2075) 2026-10-19 15:15:32.214 INFO ClientNode controller.@1:5 is offline 2026-10-19 15:15:32.215 - debug: matter.0 (2075) 2026-10-19 15:15:32.215 INFO ClientNode controller.@1:3 is offline 2026-10-19 15:15:32.215 - debug: matter.0 (2075) 2026-10-19 15:15:32.215 INFO ClientNode controller.@1:c7acec81beae7d8e is offline 2026-10-19 15:15:32.216 - debug: matter.0 (2075) 2026-10-19 15:15:32.216 INFO ClientNode controller.@1:c922f78cf1c6e2c is offline 2026-10-19 15:15:32.216 - debug: matter.0 (2075) 2026-10-19 15:15:32.216 INFO ClientNode controller.@1:1 is offline 2026-10-19 15:15:32.387 - info: host.smart stopInstance system.adapter.admin.0 send kill signal 2026-10-19 15:15:32.405 - debug: matter.0 (2075) 2026-10-19 15:15:32.405 INFO Transaction ◦offline#2eb locked controller.generalDiagnostics.state 2026-10-19 15:15:32.419 - info: matter.0 (2075) Got terminate signal TERMINATE_YOURSELF 2026-10-19 15:15:32.427 - info: host.smart stopInstance system.adapter.javascript.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.whatsapp-cmb.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.backitup.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.alexa2.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.cloud.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.device-watcher.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.fullybrowser.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.hmip.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.homeconnect.0 send kill signal 2026-10-19 15:15:32.431 - info: host.smart stopInstance system.adapter.hue.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.modbus.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.mqtt.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.nuki.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.shelly.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.shelly.1 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.sonoff.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.sonos.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.tr-064.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.tuya.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.zigbee.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.synology.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.zendure-solarflow.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.discovery.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.sourceanalytix.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.smart-eq.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.web.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.echarts.0 send kill signal 2026-10-19 15:15:32.432 - info: host.smart stopInstance system.adapter.iot.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.linux-control.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.statistics.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.trashschedule.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.upnp.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.wled.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.mytime.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.mitsubishi-local-control.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.awtrix-ng.0 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.awtrix-ng.1 send kill signal 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.awtrix-ng.2 send kill signal 2026-10-19 15:15:32.563 - warn: host.smart instance system.adapter.javascript.0 terminated due to SIGTERM 2026-10-19 15:15:32.604 - debug: matter.0 (2075) 2026-10-19 15:15:32.604 INFO Transaction ◦offline#2eb committed and unlocked 1 resource 2026-10-19 15:15:32.606 - debug: matter.0 (2075) 2026-10-19 15:15:32.606 INFO MdnsAdvertisement Unpublishing kind: operational service: mdns:C1124F59EBABAC14-E3CF4773CA77CE57._matter._tcp.local time: 12h 30m 7s 2026-10-19 15:15:32.610 - debug: matter.0 (2075) 2026-10-19 15:15:32.610 INFO Session @1:2b8c81c11dd9ca8a•65bd Session ended 2026-10-19 15:15:32.610 - debug: matter.0 (2075) 2026-10-19 15:15:32.610 INFO Session @1:2•65be Session ended 2026-10-19 15:15:32.610 - debug: matter.0 (2075) 2026-10-19 15:15:32.610 INFO Session @1:4•65bf Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:3•65c1 Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:c922f78cf1c6e2c•65c3 Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:c7acec81beae7d8e•65c2 Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:1•65c4 Session ended 2026-10-19 15:15:32.611 - debug: matter.0 (2075) 2026-10-19 15:15:32.611 INFO Session @1:5•65c0 Session ended 2026-10-19 15:15:32.618 - info: matter.0 (2075) 2026-10-19 15:15:32.618 NOTICE Node controller is offline 2026-10-19 15:15:32.656 - debug: matter.0 (2075) 2026-10-19 15:15:32.656 INFO ServerNodeStore Closed controller storage location: /opt/iobroker/iobroker-data/matter.0/controller driver: iobroker locks: 0 2026-10-19 15:15:32.740 - info: matter.0 (2075) terminating 2026-10-19 15:15:32.741 - debug: matter.0 (2075) Plugin sentry destroyed 2026-10-19 15:15:32.741 - info: matter.0 (2075) Terminated (NO_ERROR): Without reason 2026-10-19 15:15:33.389 - info: host.smart stopInstance timeout system.adapter.admin.0 killing pid 6263 2026-10-19 15:15:33.773 - info: host.smart stopInstance timeout system.adapter.whatsapp-cmb.0 killing pid 1320 2026-10-19 15:15:33.779 - info: host.smart stopInstance timeout system.adapter.fullybrowser.0 killing pid 1438 2026-10-19 15:15:33.780 - info: host.smart stopInstance timeout system.adapter.homeconnect.0 killing pid 1471 2026-10-19 15:15:33.780 - info: host.smart stopInstance timeout system.adapter.hue.0 killing pid 1488 2026-10-19 15:15:33.783 - info: host.smart stopInstance timeout system.adapter.modbus.0 killing pid 1522 2026-10-19 15:15:33.783 - info: host.smart stopInstance timeout system.adapter.mqtt.0 killing pid 1539 2026-10-19 15:15:33.784 - info: host.smart stopInstance timeout system.adapter.shelly.0 killing pid 1572 2026-10-19 15:15:33.784 - info: host.smart stopInstance timeout system.adapter.shelly.1 killing pid 1589 2026-10-19 15:15:33.784 - info: host.smart stopInstance timeout system.adapter.sonoff.0 killing pid 1606Ich hoffe das hilft und vielen Dank.
Kann das sein, das dass mit klick dieses Buttons in Zusammenhang steht ?
Ich werde den morgen mal (wieder) klicken und beobachten ob dann irgendwann wieder steht "keine Geräte gefunden"
@darkblu Danke. Im Moment ist also alles in Ordnung: 2071 läuft, und die Sperre gehört zu genau diesem Prozess.
Im Log sieht man gut, was beim Herunterfahren am 19.10. passiert ist. Um 15:15:32.419 bekommt matter.0 (2075) das TERMINATE_YOURSELF, und nur ein paar Millisekunden später schickt der Host an alle Adapter
send kill signal. matter.0 war da noch beim Herunterfahren vom Controller (Transaction ... locked). Ich vermute, dass der Prozess hart beendet wurde, bevor er die Sperre inota/aufräumen konnte.Dazu kommt wahrscheinlich noch etwas: Nach einem Reboot vom Pi bekommen die Prozesse wieder ähnlich niedrige PIDs (2075, 2071 ...). Bleibt eine alte
matter.pidliegen und gehört die PID darin zufällig gerade zu einem anderen Prozess, hält matter.js die Sperre vermutlich für noch gültig. Das würde erklären, warum es nur manchmal passiert.lastist bei dir nicht installiert. Die Reboots siehst du auch so:journalctl --list-bootsUnd bitte noch die Zeilen, wie matter.0 nach dem Stoppen wieder gestartet ist:
zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0 \(2075\) Terminated|system\.adapter\.matter\.0|storage-lock|locked by" | head -50Mich interessiert, ob für 2075 noch ein "Terminated" kommt und mit welcher PID matter.0 danach gestartet ist. Das kommt dann auch ins Issue https://github.com/ioBroker/ioBroker.matter/issues/898, damit @apollon77 es sich in matter.js anschauen kann.
hier das Ergebnis:
2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-19 15:15:32.741 - info: matter.0 (2075) Terminated (NO_ERROR): Without reason 2026-10-19 15:15:35.020 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:20:16.716 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2087 -
hier das Ergebnis:
2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-19 15:15:32.741 - info: matter.0 (2075) Terminated (NO_ERROR): Without reason 2026-10-19 15:15:35.020 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:20:16.716 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2087@darkblu Danke, das ist eindeutig: 2075 hat sich um 15:15:32.741 sauber mit "Terminated (NO_ERROR)" beendet und der Host meldet code 0. Meine Vermutung mit dem harten Kill beim Herunterfahren stimmt für diesen Stopp also nicht.
Die Sperrdateien von 15:20 gehören dann zum neuen Prozess 2087, der um 15:20:16 gestartet ist. Spannend ist also, wie 2087 bzw. die Prozesse danach beendet wurden. Bitte schau einmal über alle Logs, wann matter.0 gestartet und gestoppt wurde:
zgrep -h -E "system\.adapter\.matter\.0|matter\.0 \([0-9]+\) Terminated|received SIGTERM|storage-lock|locked by" /opt/iobroker/log/iobroker.2026-10-*.log* | sort | head -150Und noch die Reboots:
journalctl --list-bootsIch suche einen Start ohne ein passendes "Terminated" davor, also einen Prozess, der ohne Aufräumen weg war, zum Beispiel durch Stromausfall, harten Reboot oder einen Absturz.
Wenn wieder "Keine Geräte gefunden" kommt, bitte vor dem Neustart gleich die drei Befehle von vorhin ausführen (
ps,ls,cat matter.pid) und die Ausgabe posten. Dann sehen wir direkt, welche PID in der Sperre steht. -
sodele, hier Nummer eins:
dirk@smart:~ $ zgrep -h -E "system\.adapter\.matter\.0|matter\.0 \([0-9]+\) Terminated|received SIGTERM|storage-lock|locked by" /opt/iobroker/log/iobroker.2026-10-*.log* | sort | head -150 2026-10-16 02:44:25.593 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2290 2026-10-16 02:44:32.311 - warn: matter.0 (2290) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-16 02:44:32.884 - error: host.smart instance system.adapter.matter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-16 02:44:32.884 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-16 02:45:03.397 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2585 2026-10-16 12:17:20.556 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2213 2026-10-16 12:18:52.077 - warn: matter.0 (2213) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-16 12:18:54.024 - error: host.smart instance system.adapter.matter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-16 12:18:54.024 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-16 12:19:56.639 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2598 2026-10-16 12:37:02.986 - info: host.smart received SIGTERM 2026-10-16 12:37:03.044 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-16 12:37:03.293 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-16 12:37:05.612 - info: matter.0 (2598) Terminated (NO_ERROR): Without reason 2026-10-16 12:37:06.172 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-16 12:41:53.192 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2059 2026-10-17 12:20:45.625 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2257 2026-10-17 12:26:04.699 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2389 2026-10-17 12:26:13.075 - warn: matter.0 (2389) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-17 12:26:13.658 - error: host.smart instance system.adapter.matter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-17 12:26:13.658 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-17 12:26:44.167 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2465 2026-10-17 14:17:09.408 - info: host.smart received SIGTERM 2026-10-17 14:17:09.423 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-17 14:17:09.649 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-17 14:17:12.195 - info: matter.0 (2465) Terminated (NO_ERROR): Without reason 2026-10-17 14:17:12.847 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-17 14:20:31.959 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 4145 2026-10-18 12:23:32.750 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2266 2026-10-18 12:24:58.955 - warn: matter.0 (2266) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-18 12:24:59.671 - error: host.smart instance system.adapter.matter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-18 12:24:59.671 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-18 12:25:30.732 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2632 2026-10-18 14:58:51.206 - info: matter.0 (2632) Terminated (NO_ERROR): Without reason 2026-10-18 14:58:51.836 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-18 14:58:51.837 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-18 14:59:22.329 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 3637 2026-10-18 15:29:47.786 - info: matter.0 (3637) Terminated (NO_ERROR): Without reason 2026-10-18 15:29:48.347 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-18 15:29:48.348 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-18 15:30:18.849 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 3849 2026-10-19 02:45:15.023 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2075 2026-10-19 15:15:32.152 - info: host.smart received SIGTERM 2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-19 15:15:32.741 - info: matter.0 (2075) Terminated (NO_ERROR): Without reason 2026-10-19 15:15:35.020 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:20:16.716 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2087 2026-10-20 13:08:30.346 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2279 2026-10-20 13:08:36.751 - warn: matter.0 (2279) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-20 13:08:37.968 - error: host.smart instance system.adapter.matter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-20 13:08:37.968 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-20 13:09:15.647 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2557 2026-10-20 15:36:46.915 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-20 15:36:46.920 - info: matter.0 (2557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-10-20 15:36:46.960 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-20 15:36:47.481 - info: host.smart instance system.adapter.matter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-10-20 15:36:50.579 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 3405 2026-10-20 15:44:25.187 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-20 15:44:25.194 - info: matter.0 (3405) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-10-20 15:44:25.248 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-20 15:44:25.758 - info: host.smart instance system.adapter.matter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-10-20 15:44:28.770 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 3445 2026-10-20 16:17:19.467 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-20 16:17:19.467 - info: host.smart "system.adapter.matter.0" disabled 2026-10-20 16:17:19.473 - info: matter.0 (3445) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-10-20 16:17:19.514 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-20 16:17:20.035 - info: host.smart instance system.adapter.matter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-10-20 16:18:08.098 - info: host.smart "system.adapter.matter.0" enabled 2026-10-20 16:18:08.591 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 3751 2026-10-21 13:14:04.137 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2290 2026-10-21 13:14:10.889 - warn: matter.0 (2290) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-21 13:14:11.489 - error: host.smart instance system.adapter.matter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-21 13:14:11.490 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-21 13:14:42.015 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2589 2026-10-21 15:31:00.385 - info: host.smart received SIGTERM 2026-10-21 15:31:00.400 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-21 15:31:00.688 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-21 15:31:03.129 - info: matter.0 (2589) Terminated (NO_ERROR): Without reason 2026-10-21 15:31:03.689 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-21 15:35:50.783 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2071 2026-10-22 13:15:57.219 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2346 2026-10-22 13:16:02.645 - warn: matter.0 (2346) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-22 13:16:03.210 - error: host.smart instance system.adapter.matter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-22 13:16:03.210 - info: host.smart Restart adapter system.adapter.matter.0 because enabled 2026-10-22 13:16:33.843 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2500 Caused by: [storage-lock] Storage is locked by another process (pid 2087) Caused by: [storage-lock] Storage is locked by another process (pid 2087) Caused by: [storage-lock] Storage is locked by another process (pid 2087) Caused by: [storage-lock] Storage is locked by another process (pid 2087) Caused by: [storage-lock] Storage is locked by another process (pid 2087) Caused by: [storage-lock] Storage is locked by another process (pid 2087) Caused by: [storage-lock] Storage is locked by another process (pid 2612) Caused by: [storage-lock] Storage is locked by another process (pid 2612)und Nummer 2:
0 1334c797c3a145c3925ab89d133a55b6 Thu 2026-10-22 13:00:03 CEST Thu 2026-10-22 14:17:01 CESTmehr gibt es nicht aus 2026
Allerdings meint Gemini rausgefunden zu haben, das ich ein Neustart Problem habe, wahrscheinlich das Netzteil.
Das würde es ja dann erklären ? Harter Abbruch und dann ist halt keine Zeit die PID zu beenden oder zu löschen.
Das werde ich jetzt ein paar Tage beobachten und es dann mal mit einem neuen Netzteil versuchen. -
Es ist wieder passiert:
dirk@smart:~ $ ls -la --time-style=full-iso /opt/iobroker/iobroker-data/matter.0/ota/ cat /opt/iobroker/iobroker-data/matter.0/ota/matter.pid total 200 drwxrwxr-x+ 2 iobroker iobroker 4096 2026-10-23 13:15:49.957617898 +0200 . drwxrwxr-x+ 4 iobroker iobroker 188416 2026-10-23 16:55:48.634515466 +0200 .. -rw-rwxr--+ 1 iobroker iobroker 38 2026-10-23 13:15:49.961617915 +0200 driver.json -rw-rw-r--+ 1 iobroker iobroker 0 2026-10-23 13:15:49.957617898 +0200 matter.lock -rw-rw-r--+ 1 iobroker iobroker 21 2026-10-23 13:15:49.961617915 +0200 matter.pid 2090 5149aee385fbd2dcIch weiss jetzt auch zuverlässig wann und wie es passiert, das Netzteil ist hinüber und es kommt zum harten Neustart wegen Spannungsabfall. Neues Netzteil ist bestellt.
Dann werden die Dateien eben nicht ordnungsgemäß entfernt und beim Neustart liegen die dann da noch und somit steigt der Matter Adapter dann aus, bzw nimmt seinen Dienst eben nicht auf.bei dem hier:
zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0 \(2075\) Terminated|system\.adapter\.matter\.0|storage-lock|locked by" | head -50kommt das:
2026-10-19 15:15:32.215 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true) 2026-10-19 15:15:32.433 - info: host.smart stopInstance system.adapter.matter.0 send kill signal 2026-10-19 15:15:32.741 - info: matter.0 (2075) Terminated (NO_ERROR): Without reason 2026-10-19 15:15:35.020 - info: host.smart instance system.adapter.matter.0 terminated with code 0 (NO_ERROR) 2026-10-19 15:20:16.716 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 2087und in der .pid Datei steht 2090.
und danach sind die Geräte wieder da:
