<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Matter (Adapter) Problem]]></title><description><![CDATA[<p dir="auto">Hallo, seit ein paar Tagen gibt es Probleme mit dem Matter Adapter, dort sieht es täglich so aus:</p>
<p dir="auto"><img src="/assets/uploads/files/1791811844781-01.png" alt="01.png" class="img-markdown  img-fluid" width="612" height="472" /></p>
<p dir="auto">Die Matter Instanz ist grün und es gibt keine Logs dazu:<br />
<img src="/assets/uploads/files/1791811887410-02.png" alt="02.png" class="img-markdown  img-fluid" width="1046" height="178" /></p>
<p dir="auto">Ein Neustart des Matter Adapters nützt leider nichts, dann kommt im Log aber folgendes:</p>
<pre><code>2026-10-12 15:14:51.838 - info: host.smart stopInstance system.adapter.matter.0 (force=false, process=true)
2026-10-12 15:14:51.840 - info: matter.0 (3855) Got terminate signal TERMINATE_YOURSELF
2026-10-12 15:14:51.841 - debug: matter.0 (3855) Send to GUI: {"command":"stopped"}
2026-10-12 15:14:51.842 - info: matter.0 (3855) Stopping Controller...
2026-10-12 15:14:51.842 - info: matter.0 (3855) terminating
2026-10-12 15:14:51.842 - debug: matter.0 (3855) Plugin sentry destroyed
2026-10-12 15:14:51.842 - info: matter.0 (3855) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2026-10-12 15:14:51.884 - info: host.smart stopInstance system.adapter.matter.0 send kill signal
2026-10-12 15:14:52.415 - info: host.smart instance system.adapter.matter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2026-10-12 15:15:12.016 - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 3874
2026-10-12 15:15:13.702 - info: dwd.0 (3874) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v24.21.0, js-controller: 7.2.2
2026-10-12 15:15:14.069 - info: dwd.0 (3874) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2026-10-12 15:15:14.582 - info: host.smart instance system.adapter.dwd.0 having pid 3874 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2026-10-12 15:15:25.330 - info: host.smart instance system.adapter.matter.0 in version "1.3.1" started with pid 3891
2026-10-12 15:15:29.132 - debug: matter.0 (3891) Redis Objects: Use Redis connection: 127.0.0.1:9001
2026-10-12 15:15:29.179 - debug: matter.0 (3891) Objects client ready ... initialize now
2026-10-12 15:15:29.224 - debug: matter.0 (3891) Objects create System PubSub Client
2026-10-12 15:15:29.225 - debug: matter.0 (3891) Objects create User PubSub Client
2026-10-12 15:15:29.278 - debug: matter.0 (3891) Objects client initialize lua scripts
2026-10-12 15:15:29.281 - debug: matter.0 (3891) Objects connected to redis: 127.0.0.1:9001
2026-10-12 15:15:29.308 - debug: matter.0 (3891) Redis States: Use Redis connection: 127.0.0.1:9000
2026-10-12 15:15:29.322 - debug: matter.0 (3891) States create System PubSub Client
2026-10-12 15:15:29.323 - debug: matter.0 (3891) States create User PubSub Client
2026-10-12 15:15:29.392 - debug: matter.0 (3891) States connected to redis: 127.0.0.1:9000
2026-10-12 15:15:29.416 - debug: matter.0 (3891) Plugin sentry Initialize Plugin (enabled=true)
2026-10-12 15:15:30.380 - info: matter.0 (3891) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.matter, node: v24.21.0, js-controller: 7.2.2
2026-10-12 15:15:30.408 - debug: matter.0 (3891) Sync devices
2026-10-12 15:15:30.451 - debug: matter.0 (3891) Process 0 bridges ...
2026-10-12 15:15:30.452 - debug: matter.0 (3891) Process 0 devices ...
2026-10-12 15:15:30.452 - debug: matter.0 (3891) Sync controller
2026-10-12 15:15:30.456 - info: matter.0 (3891) Creating controller with Fabric Label: ioBroker matter.0
2026-10-12 15:15:30.456 - debug: matter.0 (3891) Sync done
2026-10-12 15:15:30.456 - debug: matter.0 (3891) Devices synced
2026-10-12 15:15:30.512 - debug: matter.0 (3891) [STORAGE] Initializing storage for storage.controller
2026-10-12 15:15:30.578 - debug: matter.0 (3891) [STORAGE] Initializing storage for storage.controller
2026-10-12 15:15:30.967 - debug: matter.0 (3891) 2026-10-12 15:15:30.967 INFO ServerNodeStore Opened controller storage location: /opt/iobroker/iobroker-data/matter.0/controller driver: iobroker
2026-10-12 15:15:30.978 - debug: matter.0 (3891) 2026-10-12 15:15:30.978 INFO SessionManager restoring resumption record for node @1:2b8c81c11dd9ca8a and peer node @1:2b8c81c11dd9ca8a for fabric id 0x789b95528e8679 (0xfff1, "ioBroker matter.0")
2026-10-12 15:15:30.979 - debug: matter.0 (3891) 2026-10-12 15:15:30.979 INFO SessionManager restoring resumption record for node @1:c7acec81beae7d8e and peer node @1:c7acec81beae7d8e for fabric id 0x789b95528e8679 (0xfff1, "ioBroker matter.0")
2026-10-12 15:15:30.980 - debug: matter.0 (3891) 2026-10-12 15:15:30.979 INFO SessionManager restoring resumption record for node @1:c922f78cf1c6e2c and peer node @1:c922f78cf1c6e2c for fabric id 0x789b95528e8679 (0xfff1, "ioBroker matter.0")
2026-10-12 15:15:30.980 - debug: matter.0 (3891) 2026-10-12 15:15:30.980 INFO SessionManager restoring resumption record for node @1:1 and peer node @1:1 for fabric id 0x789b95528e8679 (0xfff1, "ioBroker matter.0")
2026-10-12 15:15:30.981 - debug: matter.0 (3891) 2026-10-12 15:15:30.981 INFO SessionManager restoring resumption record for node @1:2 and peer node @1:2 for fabric id 0x789b95528e8679 (0xfff1, "ioBroker matter.0")
2026-10-12 15:15:30.981 - debug: matter.0 (3891) 2026-10-12 15:15:30.981 INFO SessionManager restoring resumption record for node @1:4 and peer node @1:4 for fabric id 0x789b95528e8679 (0xfff1, "ioBroker matter.0")
2026-10-12 15:15:30.981 - debug: matter.0 (3891) 2026-10-12 15:15:30.981 INFO SessionManager restoring resumption record for node @1:3 and peer node @1:3 for fabric id 0x789b95528e8679 (0xfff1, "ioBroker matter.0")
2026-10-12 15:15:30.981 - debug: matter.0 (3891) 2026-10-12 15:15:30.981 INFO SessionManager restoring resumption record for node @1:5 and peer node @1:5 for fabric id 0x789b95528e8679 (0xfff1, "ioBroker matter.0")
2026-10-12 15:15:31.032 - info: matter.0 (3891) 2026-10-12 15:15:31.031 WARN BasicInformationServer Using development values for some BasicInformation attributes: vendorId: 65521 vendorName: Matter.js Test Vendor productId: 32768 productName: Matter.js Test Product hardwareVersion: 0 softwareVersion: 0
2026-10-12 15:15:31.133 - debug: matter.0 (3891) 2026-10-12 15:15:31.133 INFO BaseEventStore Loaded volatile event store with next number 54001
2026-10-12 15:15:31.145 - debug: matter.0 (3891) 2026-10-12 15:15:31.144 INFO Endpoint controller ready endpoint#: 0 type: RootNode (0x16, rev 4) behaviors: 💤parts ✓index ✓accessControl ✓basicInformation ✓generalCommissioning ✓generalDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement ✓commissioning ✓network 💤productDescription 💤subscriptions 💤sessions ✓events 💤controller ✓descriptor
2026-10-12 15:15:31.360 - debug: matter.0 (3891) 2026-10-12 15:15:31.360 INFO Endpoint controller.@1:2b8c81c11dd9ca8a ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓commissioning ✓network ✓descriptor ✓accessControl ✓basicInformation ✓otaSoftwareUpdateRequestor ✓localizationConfiguration ✓timeFormatLocalization ✓generalCommissioning ✓networkCommissioning ✓generalDiagnostics ✓threadNetworkDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement
2026-10-12 15:15:31.405 - debug: matter.0 (3891) 2026-10-12 15:15:31.405 INFO Endpoint controller.@1:2b8c81c11dd9ca8a.ep1 ready endpoint#: 1 type: ColorTemperatureLight (0x010c, rev 1) behaviors: ✓descriptor ✓identify ✓groups ✓onOff ✓colorControl ✓levelControl
2026-10-12 15:15:31.532 - debug: matter.0 (3891) 2026-10-12 15:15:31.532 INFO Endpoint controller.@1:2 ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓commissioning ✓network ✓descriptor ✓accessControl ✓basicInformation ✓otaSoftwareUpdateRequestor ✓powerSource ✓generalCommissioning ✓networkCommissioning ✓generalDiagnostics ✓threadNetworkDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement ✓icdManagement ✓icd
2026-10-12 15:15:31.538 - debug: matter.0 (3891) 2026-10-12 15:15:31.538 INFO Endpoint controller.@1:2.ep1 ready endpoint#: 1 type: ContactSensor (0x15, rev 2) behaviors: ✓descriptor ✓identify ✓booleanState
2026-10-12 15:15:31.637 - debug: matter.0 (3891) 2026-10-12 15:15:31.636 INFO Endpoint controller.@1:4 ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓commissioning ✓network ✓descriptor ✓accessControl ✓basicInformation ✓otaSoftwareUpdateRequestor ✓generalCommissioning ✓networkCommissioning ✓generalDiagnostics ✓threadNetworkDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement
2026-10-12 15:15:31.642 - debug: matter.0 (3891) 2026-10-12 15:15:31.642 INFO Endpoint controller.@1:4.ep1 ready endpoint#: 1 type: OnOffPlugInUnit (0x010a, rev 3) behaviors: ✓descriptor ✓identify ✓groups ✓onOff
2026-10-12 15:15:31.663 - debug: matter.0 (3891) 2026-10-12 15:15:31.663 INFO Endpoint controller.@1:4.ep2 ready endpoint#: 2 type: Unknown (unknown) behaviors: ✓descriptor ✓electricalPowerMeasurement ✓electricalEnergyMeasurement ✓powerTopology
2026-10-12 15:15:31.731 - debug: matter.0 (3891) 2026-10-12 15:15:31.730 INFO Endpoint controller.@1:3 ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓commissioning ✓network ✓descriptor ✓accessControl ✓basicInformation ✓otaSoftwareUpdateRequestor ✓generalCommissioning ✓networkCommissioning ✓generalDiagnostics ✓threadNetworkDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement
2026-10-12 15:15:31.737 - debug: matter.0 (3891) 2026-10-12 15:15:31.737 INFO Endpoint controller.@1:3.ep1 ready endpoint#: 1 type: OnOffPlugInUnit (0x010a, rev 3) behaviors: ✓descriptor ✓identify ✓groups ✓onOff
2026-10-12 15:15:31.742 - debug: matter.0 (3891) 2026-10-12 15:15:31.742 INFO Endpoint controller.@1:3.ep2 ready endpoint#: 2 type: Unknown (unknown) behaviors: ✓descriptor ✓electricalPowerMeasurement ✓electricalEnergyMeasurement ✓powerTopology
2026-10-12 15:15:31.813 - debug: matter.0 (3891) 2026-10-12 15:15:31.813 INFO Endpoint controller.@1:5 ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓commissioning ✓network ✓descriptor ✓accessControl ✓basicInformation ✓otaSoftwareUpdateRequestor ✓powerSource ✓generalCommissioning ✓networkCommissioning ✓generalDiagnostics ✓threadNetworkDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement ✓icdManagement ✓icd
2026-10-12 15:15:31.821 - debug: matter.0 (3891) 2026-10-12 15:15:31.821 INFO Endpoint controller.@1:5.ep1 ready endpoint#: 1 type: GenericSwitch (0x0f, rev 3) behaviors: ✓descriptor ✓identify ✓switch
2026-10-12 15:15:31.825 - debug: matter.0 (3891) 2026-10-12 15:15:31.825 INFO Endpoint controller.@1:5.ep2 ready endpoint#: 2 type: GenericSwitch (0x0f, rev 3) behaviors: ✓descriptor ✓identify ✓switch
2026-10-12 15:15:31.876 - debug: matter.0 (3891) 2026-10-12 15:15:31.876 INFO Endpoint controller.@1:c7acec81beae7d8e ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓commissioning ✓network ✓descriptor ✓accessControl ✓basicInformation ✓otaSoftwareUpdateRequestor ✓generalCommissioning ✓networkCommissioning ✓generalDiagnostics ✓threadNetworkDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement
2026-10-12 15:15:31.881 - debug: matter.0 (3891) 2026-10-12 15:15:31.881 INFO Endpoint controller.@1:c7acec81beae7d8e.ep1 ready endpoint#: 1 type: OnOffPlugInUnit (0x010a, rev 3) behaviors: ✓descriptor ✓identify ✓groups ✓onOff
2026-10-12 15:15:31.885 - debug: matter.0 (3891) 2026-10-12 15:15:31.885 INFO Endpoint controller.@1:c7acec81beae7d8e.ep2 ready endpoint#: 2 type: Unknown (unknown) behaviors: ✓descriptor ✓electricalPowerMeasurement ✓electricalEnergyMeasurement ✓powerTopology
2026-10-12 15:15:31.972 - debug: matter.0 (3891) 2026-10-12 15:15:31.972 INFO Endpoint controller.@1:c922f78cf1c6e2c ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓commissioning ✓network ✓descriptor ✓accessControl ✓basicInformation ✓otaSoftwareUpdateRequestor ✓timeFormatLocalization ✓generalCommissioning ✓networkCommissioning ✓generalDiagnostics ✓threadNetworkDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement
2026-10-12 15:15:32.024 - debug: matter.0 (3891) 2026-10-12 15:15:32.024 INFO Endpoint controller.@1:c922f78cf1c6e2c.ep1 ready endpoint#: 1 type: ExtendedColorLight (0x010d, rev 1) behaviors: ✓descriptor ✓identify ✓groups ✓onOff ✓colorControl ✓levelControl
2026-10-12 15:15:32.079 - debug: matter.0 (3891) 2026-10-12 15:15:32.079 INFO Endpoint controller.@1:1 ready endpoint#: 0 type: RootNode (0x16) behaviors: 💤parts ✓index ✓commissioning ✓network ✓descriptor ✓accessControl ✓basicInformation ✓otaSoftwareUpdateRequestor ✓timeFormatLocalization ✓generalCommissioning ✓networkCommissioning ✓generalDiagnostics ✓threadNetworkDiagnostics ✓administratorCommissioning ✓operationalCredentials ✓groupKeyManagement
2026-10-12 15:15:32.090 - debug: matter.0 (3891) 2026-10-12 15:15:32.090 INFO Endpoint controller.@1:1.ep1 ready endpoint#: 1 type: ExtendedColorLight (0x010d, rev 1) behaviors: ✓descriptor ✓identify ✓groups ✓onOff ✓colorControl ✓levelControl
2026-10-12 15:15:32.109 - debug: matter.0 (3891) 2026-10-12 15:15:32.109 INFO DclOtaUpdateService Initialize OTAUpdateService prod: https://on.dcl.csa-iot.org test: https://on.test-net.dcl.csa-iot.org
2026-10-12 15:15:32.166 - error: matter.0 (3891) Failed to start the controller: [crashed-dependency] MatterController unavailable due to initialization error
at Construction2.#crashedError (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:597:42)
at handleRejection (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:330:74)
Caused by: [endpoint-behaviors] Behaviors have errors
at /opt/iobroker/node_modules/@matter/node/src/endpoint/properties/Behaviors.ts:253:27
at all (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:752:25)
at /opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:742:17
Cause #0: [behavior-initialization] Error initializing controller.ota-provider.otaSoftwareUpdateProvider
at crash (/opt/iobroker/node_modules/@matter/node/src/behavior/internal/BehaviorBacking.ts:94:30)
at /opt/iobroker/node_modules/@matter/general/src/util/Promises.ts:199:38
Caused by: [crashed-dependency] controller.ota-provider.softwareupdates initialization failed
at Object.assertActive (/opt/iobroker/node_modules/@matter/general/src/util/Lifecycle.ts:48:23)
at Construction2.assert (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:303:23)
at /opt/iobroker/node_modules/@matter/node/src/endpoint/properties/Behaviors.ts:382:42
at OtaSoftwareUpdateProviderServer.initialize (/opt/iobroker/node_modules/@matter/node/src/behaviors/ota-software-update-provider/OtaSoftwareUpdateProviderServer.ts:90:9)
Cause #1: [behavior-initialization] Error initializing controller.ota-provider.softwareupdates
Caused by: [crashed-dependency] DclOtaUpdateService unavailable due to initialization error
Caused by: [storage-lock] Storage is locked by another process (pid 2144)
at acquireLock (/opt/iobroker/node_modules/@matter/nodejs/src/fs/lock-utils.ts:139:19)
at acquireDirectoryLock (/opt/iobroker/node_modules/@matter/nodejs/src/fs/lock-utils.ts:90:5)
at DatafileRoot.#acquireRef (/opt/iobroker/node_modules/@matter/general/src/storage/DatafileRoot.ts:74:29)
at DatafileRoot.lock (/opt/iobroker/node_modules/@matter/general/src/storage/DatafileRoot.ts:64:20)
at FlatFileBlobStorageDriver.initialize (/opt/iobroker/node_modules/@matter/general/src/storage/BlobStorageDriver.ts:55:26)
at FlatFileBlobStorageDriver.initialize (/opt/iobroker/node_modules/@matter/nodejs/src/storage/fs/FlatFileBlobStorageDriver.ts:46:9)
at StorageService.#openBlobFilesystem (/opt/iobroker/node_modules/@matter/general/src/storage/StorageService.ts:395:13)
at /opt/iobroker/node_modules/@matter/protocol/src/dcl/DclOtaUpdateService.ts:91:32
2026-10-12 15:15:32.167 - debug: matter.0 (3891) Initialization done, Objects subscribed
</code></pre>
<p dir="auto">Das einzige was Matter wieder zum laufen bringt, bzw dass die Geräte wieder da sind, ist ein ioBroker Neustart,<br />
wenn ich den Raspberry Pi 5 neu starte, mach ich vorher noch das hier:</p>
<pre><code>sudo apt update &amp;&amp; sudo apt full-upgrade
iob stop
iob update
iob fix
iob upgrade self
sudo reboot
</code></pre>
<p dir="auto">Erst dann sind die Geräte wieder da:</p>
<p dir="auto"><img src="/assets/uploads/files/1791812319631-03.png" alt="03.png" class="img-markdown  img-fluid" width="720" height="786" /></p>
<p dir="auto">Während des Neustarts steht das hier in den Protokollen zum Matter Adapter:</p>
<pre><code>2026-10-12 15:25:05.835 - debug: matter.0 (2067) 2026-10-12 15:25:05.835 INFO CaseClient @1:2•a141 New session with @1:2 4↔2 address: udp://[fd34:ff7:8b21:0:298b:8fc7:c051:3ff9]:5540 fabric: c1124f59ebabac14 (#1) SII: 17s SAI: 2.5s SAT: 1s DMRev: 18 IMRev: 12 spec: 0x1040000 maxPaths: 1 CATs:
2026-10-12 15:25:05.836 - debug: matter.0 (2067) 2026-10-12 15:25:05.836 INFO ClientNode controller.@1:2 is online
2026-10-12 15:25:05.839 - debug: matter.0 (2067) 2026-10-12 15:25:05.839 INFO IpServiceStatus @1:2 Connected
2026-10-12 15:25:05.843 - debug: matter.0 (2067) 2026-10-12 15:25:05.843 INFO Session •unsecured#dc605bb4376e1b6 Session ended
2026-10-12 15:25:05.845 - debug: matter.0 (2067) 2026-10-12 15:25:05.845 INFO ClientInteraction Read » @1:2•a141⇵1837 bootstrap attributes: 1 events: 1
2026-10-12 15:25:06.293 - debug: matter.0 (2067) 2026-10-12 15:25:06.293 INFO ClientInteraction Read « @1:2•a141⇵1837 (empty)
2026-10-12 15:25:06.296 - debug: matter.0 (2067) 2026-10-12 15:25:06.296 INFO ClientInteraction Subscribe » @1:2•a141⇵1838 min: 0 max: 30m attributes: 1 events: 1
2026-10-12 15:25:07.330 - debug: matter.0 (2067) 2026-10-12 15:25:07.330 INFO ClientInteraction Subscription successful « @1:2•a141⇵1838 2↔2 id: ccf69796 interval: 30m timeout: 30m 38s
2026-10-12 15:25:07.335 - info: matter.0 (2067) Node "2" connected
2026-10-12 15:25:07.636 - debug: matter.0 (2067) Send to GUI: {"command":"updateController"}
2026-10-12 15:25:08.279 - debug: matter.0 (2067) 2026-10-12 15:25:08.279 INFO CaseClient @1:5•a144 New session with @1:5 4↔2 address: udp://[fd34:ff7:8b21:0:17a1:b940:e98a:6533]:5540 fabric: c1124f59ebabac14 (#1) SII: 9.5s SAI: 2.1s SAT: 5s DMRev: 18 IMRev: 11 spec: 0x1040000 maxPaths: 1 CATs:
2026-10-12 15:25:08.280 - debug: matter.0 (2067) 2026-10-12 15:25:08.280 INFO ClientNode controller.@1:5 is online
2026-10-12 15:25:08.284 - debug: matter.0 (2067) 2026-10-12 15:25:08.284 INFO IpServiceStatus @1:5 Connected
2026-10-12 15:25:08.293 - debug: matter.0 (2067) 2026-10-12 15:25:08.293 INFO Session •unsecured#78c83007c2abda19 Session ended
2026-10-12 15:25:08.295 - debug: matter.0 (2067) 2026-10-12 15:25:08.295 INFO ClientInteraction Read » @1:5•a144⇵1839 bootstrap attributes: 1 events: 1
2026-10-12 15:25:08.341 - debug: matter.0 (2067) Send to GUI: {"command":"networkGraphUpdate","networkGraphData":{"nodes":[{"nodeId":"3138025706799876746","name":"KAJPLATS E27 WS G95 clear 806lm","vendorId":"0x117C","productId":"0x9009","deviceType":268,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":6,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"6vnSB9lAYQg=","threadVersion":5,"neighborTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"age":13,"averageRssi":-95,"lastRssi":-95,"lqi":1,"frameErrorRate":55,"messageErrorRate":3,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":0,"averageRssi":-98,"lastRssi":-99,"lqi":0,"frameErrorRate":45,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":19,"averageRssi":-81,"lastRssi":-81,"lqi":2,"frameErrorRate":17,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":10,"averageRssi":-50,"lastRssi":-51,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":9,"averageRssi":-87,"lastRssi":-87,"lqi":2,"frameErrorRate":3,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":35,"pathCost":3,"lqiIn":1,"lqiOut":1,"age":13,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":4096,"routerId":4,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":35,"pathCost":2,"lqiIn":0,"lqiOut":1,"age":0,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":0,"age":32,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":35,"pathCost":1,"lqiIn":0,"lqiOut":0,"age":9,"allocated":true,"linkEstablished":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":40,"pathCost":2,"lqiIn":2,"lqiOut":2,"age":19,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":35,"pathCost":2,"lqiIn":3,"lqiOut":3,"age":10,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":35,"pathCost":1,"lqiIn":2,"lqiOut":1,"age":9,"allocated":true,"linkEstablished":true}]}},{"nodeId":"2","name":"MYGGBETT door/window sensor","vendorId":"0x117C","productId":"0x8007","deviceType":21,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":2,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"umP55va/6bc=","threadVersion":5,"neighborTable":[{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":11,"averageRssi":-9,"lastRssi":-68,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":0,"pathCost":0,"lqiIn":3,"lqiOut":3,"age":11,"allocated":true,"linkEstablished":true}]}},{"nodeId":"4","name":"GRILLPLATS Plug Propeller","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"hht9Z5ki7c4=","threadVersion":4,"neighborTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"age":11,"averageRssi":-87,"lastRssi":-88,"lqi":2,"frameErrorRate":12,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":5,"averageRssi":-58,"lastRssi":-59,"lqi":3,"frameErrorRate":12,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":6,"averageRssi":-91,"lastRssi":-92,"lqi":1,"frameErrorRate":48,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":9,"averageRssi":-92,"lastRssi":-92,"lqi":1,"frameErrorRate":2,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":23,"averageRssi":-88,"lastRssi":-89,"lqi":2,"frameErrorRate":27,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":10,"averageRssi":-82,"lastRssi":-82,"lqi":2,"frameErrorRate":51,"messageErrorRate":2,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":4,"pathCost":2,"lqiIn":2,"lqiOut":3,"age":11,"allocated":true,"linkEstablished":true},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":3,"lqiOut":3,"age":5,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":1,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":62,"pathCost":2,"lqiIn":0,"lqiOut":0,"age":65,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":62,"pathCost":1,"lqiIn":1,"lqiOut":1,"age":9,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":4,"pathCost":2,"lqiIn":2,"lqiOut":2,"age":0,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":35,"pathCost":1,"lqiIn":2,"lqiOut":2,"age":11,"allocated":true,"linkEstablished":true}]}},{"nodeId":"3","name":"GRILLPLATS Plug xmastree","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"0oGHJyEbQx0=","threadVersion":4,"neighborTable":[{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":3,"averageRssi":-93,"lastRssi":-93,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":26,"averageRssi":-70,"lastRssi":-71,"lqi":3,"frameErrorRate":18,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"age":27,"averageRssi":-74,"lastRssi":-74,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":7,"averageRssi":-71,"lastRssi":-73,"lqi":3,"frameErrorRate":5,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":6,"averageRssi":-89,"lastRssi":-89,"lqi":2,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":5,"averageRssi":-68,"lastRssi":-67,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":12,"pathCost":1,"lqiIn":0,"lqiOut":1,"age":168,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":1,"age":3,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":26,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":27,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":32768,"routerId":32,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":62,"pathCost":2,"lqiIn":2,"lqiOut":1,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true}]}},{"nodeId":"5","name":"BILRESA dual button","vendorId":"0x117C","productId":"0x8001","deviceType":15,"isConnected":false,"networkType":"thread"},{"nodeId":"14388134951535934862","name":"GRILLPLATS Flurlicht EG","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"Hmibk4TrSAo=","threadVersion":4,"neighborTable":[{"extAddress":"Ko4I3TGL/Rk=","rloc16":5120,"age":7,"averageRssi":-75,"lastRssi":-75,"lqi":3,"frameErrorRate":14,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ilH89VC5gP0=","rloc16":34816,"age":4,"averageRssi":-93,"lastRssi":-94,"lqi":1,"frameErrorRate":8,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"6vnSB9lAYQg=","rloc16":54272,"age":0,"averageRssi":-89,"lastRssi":-89,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"Ko4I3TGL/Rk=","rloc16":5120,"routerId":5,"nextHop":34,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":7,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":18432,"routerId":18,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"ilH89VC5gP0=","rloc16":34816,"routerId":34,"nextHop":5,"pathCost":1,"lqiIn":1,"lqiOut":2,"age":4,"allocated":true,"linkEstablished":true},{"extAddress":"6vnSB9lAYQg=","rloc16":54272,"routerId":53,"nextHop":5,"pathCost":3,"lqiIn":1,"lqiOut":2,"age":0,"allocated":true,"linkEstablished":true}]}},{"nodeId":"905838670972218924","name":"KAJPLATS E14 Pendel 1","vendorId":"0x117C","productId":"0x9006","deviceType":269,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"IrVCRCv+Esw=","threadVersion":5,"neighborTable":[{"extAddress":"umP55va/6bc=","rloc16":35867,"age":5,"averageRssi":-75,"lastRssi":-76,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":false,"fullThreadDevice":false,"fullNetworkData":false,"isChild":true},{"extAddress":"kvzUg8uUYIM=","rloc16":35888,"age":3,"averageRssi":-95,"lastRssi":-94,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":false,"fullThreadDevice":false,"fullNetworkData":false,"isChild":true},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":8,"averageRssi":-86,"lastRssi":-85,"lqi":2,"frameErrorRate":4,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":24,"averageRssi":-87,"lastRssi":-82,"lqi":2,"frameErrorRate":31,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":6,"averageRssi":-68,"lastRssi":-70,"lqi":3,"frameErrorRate":17,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":12,"averageRssi":-88,"lastRssi":-88,"lqi":2,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":1,"averageRssi":-50,"lastRssi":-51,"lqi":3,"frameErrorRate":6,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":62,"pathCost":2,"lqiIn":0,"lqiOut":0,"age":105,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":32,"pathCost":3,"lqiIn":2,"lqiOut":2,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":2,"lqiOut":3,"age":24,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":32,"pathCost":1,"lqiIn":1,"lqiOut":0,"age":6,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":4,"pathCost":1,"lqiIn":2,"lqiOut":1,"age":12,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":1,"allocated":true,"linkEstablished":true}]}},{"nodeId":"1","name":"KAJPLATS E14 Pendel 2","vendorId":"0x117C","productId":"0x9006","deviceType":269,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"chAHb/erIbY=","threadVersion":5,"neighborTable":[{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":5,"averageRssi":-93,"lastRssi":-93,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":22,"averageRssi":-72,"lastRssi":-72,"lqi":3,"frameErrorRate":7,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":8,"averageRssi":-70,"lastRssi":-71,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":25,"averageRssi":-52,"lastRssi":-52,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":17,"averageRssi":-85,"lastRssi":-85,"lqi":2,"frameErrorRate":28,"messageErrorRate":1,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":12,"pathCost":1,"lqiIn":0,"lqiOut":0,"age":20,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":2,"age":5,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":22,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":32,"pathCost":1,"lqiIn":1,"lqiOut":3,"age":27,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":25,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":35,"pathCost":3,"lqiIn":2,"lqiOut":2,"age":17,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false}]}}],"timestamp":1791811508341}}
2026-10-12 15:25:08.925 - debug: matter.0 (2067) 2026-10-12 15:25:08.925 INFO ClientInteraction Read « @1:5•a144⇵1839 2↔2 attributes: 31 events: 15
2026-10-12 15:25:08.929 - debug: matter.0 (2067) 2026-10-12 15:25:08.928 INFO ClientEventEmitter Received event switch.initialPress on controller.@1:5.ep1 newPosition: 1
2026-10-12 15:25:08.934 - debug: matter.0 (2067) 2026-10-12 15:25:08.934 INFO ClientEventEmitter Received event switch.shortRelease on controller.@1:5.ep1 previousPosition: 1
2026-10-12 15:25:08.940 - debug: matter.0 (2067) 2026-10-12 15:25:08.939 INFO ClientEventEmitter Received event threadNetworkDiagnostics.connectionStatus on controller.@1:5 connectionStatus: 1
2026-10-12 15:25:08.945 - debug: matter.0 (2067) 2026-10-12 15:25:08.945 INFO ClientEventEmitter Received event threadNetworkDiagnostics.networkFaultChange on controller.@1:5 current: 1 previous: 1
2026-10-12 15:25:08.951 - debug: matter.0 (2067) 2026-10-12 15:25:08.950 INFO ClientEventEmitter Received event switch.multiPressComplete on controller.@1:5.ep1 previousPosition: 1 totalNumberOfPressesCounted: 1
2026-10-12 15:25:08.954 - debug: matter.0 (2067) 2026-10-12 15:25:08.954 INFO ClientEventEmitter Received event switch.initialPress on controller.@1:5.ep1 newPosition: 1
2026-10-12 15:25:08.958 - debug: matter.0 (2067) 2026-10-12 15:25:08.958 INFO ClientEventEmitter Received event switch.shortRelease on controller.@1:5.ep1 previousPosition: 1
2026-10-12 15:25:08.961 - debug: matter.0 (2067) 2026-10-12 15:25:08.961 INFO ClientEventEmitter Received event switch.initialPress on controller.@1:5.ep1 newPosition: 1
2026-10-12 15:25:08.966 - debug: matter.0 (2067) 2026-10-12 15:25:08.966 INFO ClientEventEmitter Received event switch.multiPressOngoing on controller.@1:5.ep1 newPosition: 1 currentNumberOfPressesCounted: 2
2026-10-12 15:25:08.970 - debug: matter.0 (2067) 2026-10-12 15:25:08.970 INFO ClientEventEmitter Received event switch.shortRelease on controller.@1:5.ep1 previousPosition: 1
2026-10-12 15:25:08.973 - debug: matter.0 (2067) 2026-10-12 15:25:08.973 INFO ClientEventEmitter Received event switch.initialPress on controller.@1:5.ep2 newPosition: 1
2026-10-12 15:25:08.976 - debug: matter.0 (2067) 2026-10-12 15:25:08.976 INFO ClientEventEmitter Received event switch.multiPressComplete on controller.@1:5.ep1 previousPosition: 1 totalNumberOfPressesCounted: 2
2026-10-12 15:25:08.980 - debug: matter.0 (2067) 2026-10-12 15:25:08.980 INFO ClientEventEmitter Received event switch.shortRelease on controller.@1:5.ep2 previousPosition: 1
2026-10-12 15:25:08.983 - debug: matter.0 (2067) 2026-10-12 15:25:08.983 INFO ClientEventEmitter Received event switch.multiPressComplete on controller.@1:5.ep2 previousPosition: 1 totalNumberOfPressesCounted: 1
2026-10-12 15:25:08.987 - debug: matter.0 (2067) 2026-10-12 15:25:08.986 INFO ClientEventEmitter Received event threadNetworkDiagnostics.connectionStatus on controller.@1:5 connectionStatus: 0
2026-10-12 15:25:08.991 - debug: matter.0 (2067) 2026-10-12 15:25:08.991 INFO ClientInteraction Subscribe » @1:5•a144⇵183a min: 0 max: 15m attributes: 1 events: 1
2026-10-12 15:25:09.725 - debug: matter.0 (2067) 2026-10-12 15:25:09.725 INFO ClientInteraction Subscription successful « @1:5•a144⇵183a 2↔2 id: 4c19b87f interval: 15m timeout: 15m 38s
2026-10-12 15:25:09.729 - info: matter.0 (2067) Node "5" connected
2026-10-12 15:25:10.029 - debug: matter.0 (2067) Send to GUI: {"command":"updateController"}
2026-10-12 15:25:10.733 - debug: matter.0 (2067) Send to GUI: {"command":"networkGraphUpdate","networkGraphData":{"nodes":[{"nodeId":"3138025706799876746","name":"KAJPLATS E27 WS G95 clear 806lm","vendorId":"0x117C","productId":"0x9009","deviceType":268,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":6,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"6vnSB9lAYQg=","threadVersion":5,"neighborTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"age":13,"averageRssi":-95,"lastRssi":-95,"lqi":1,"frameErrorRate":55,"messageErrorRate":3,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":0,"averageRssi":-98,"lastRssi":-99,"lqi":0,"frameErrorRate":45,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":19,"averageRssi":-81,"lastRssi":-81,"lqi":2,"frameErrorRate":17,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":10,"averageRssi":-50,"lastRssi":-51,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":9,"averageRssi":-87,"lastRssi":-87,"lqi":2,"frameErrorRate":3,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":35,"pathCost":3,"lqiIn":1,"lqiOut":1,"age":13,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":4096,"routerId":4,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":35,"pathCost":2,"lqiIn":0,"lqiOut":1,"age":0,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":0,"age":32,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":35,"pathCost":1,"lqiIn":0,"lqiOut":0,"age":9,"allocated":true,"linkEstablished":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":40,"pathCost":2,"lqiIn":2,"lqiOut":2,"age":19,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":35,"pathCost":2,"lqiIn":3,"lqiOut":3,"age":10,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":35,"pathCost":1,"lqiIn":2,"lqiOut":1,"age":9,"allocated":true,"linkEstablished":true}]}},{"nodeId":"2","name":"MYGGBETT door/window sensor","vendorId":"0x117C","productId":"0x8007","deviceType":21,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":2,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"umP55va/6bc=","threadVersion":5,"neighborTable":[{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":11,"averageRssi":-9,"lastRssi":-68,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":0,"pathCost":0,"lqiIn":3,"lqiOut":3,"age":11,"allocated":true,"linkEstablished":true}]}},{"nodeId":"4","name":"GRILLPLATS Plug Propeller","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"hht9Z5ki7c4=","threadVersion":4,"neighborTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"age":11,"averageRssi":-87,"lastRssi":-88,"lqi":2,"frameErrorRate":12,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":5,"averageRssi":-58,"lastRssi":-59,"lqi":3,"frameErrorRate":12,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":6,"averageRssi":-91,"lastRssi":-92,"lqi":1,"frameErrorRate":48,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":9,"averageRssi":-92,"lastRssi":-92,"lqi":1,"frameErrorRate":2,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":23,"averageRssi":-88,"lastRssi":-89,"lqi":2,"frameErrorRate":27,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":10,"averageRssi":-82,"lastRssi":-82,"lqi":2,"frameErrorRate":51,"messageErrorRate":2,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":4,"pathCost":2,"lqiIn":2,"lqiOut":3,"age":11,"allocated":true,"linkEstablished":true},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":3,"lqiOut":3,"age":5,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":1,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":62,"pathCost":2,"lqiIn":0,"lqiOut":0,"age":65,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":62,"pathCost":1,"lqiIn":1,"lqiOut":1,"age":9,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":4,"pathCost":2,"lqiIn":2,"lqiOut":2,"age":0,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":35,"pathCost":1,"lqiIn":2,"lqiOut":2,"age":11,"allocated":true,"linkEstablished":true}]}},{"nodeId":"3","name":"GRILLPLATS Plug xmastree","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"0oGHJyEbQx0=","threadVersion":4,"neighborTable":[{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":3,"averageRssi":-93,"lastRssi":-93,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":26,"averageRssi":-70,"lastRssi":-71,"lqi":3,"frameErrorRate":18,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"age":27,"averageRssi":-74,"lastRssi":-74,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":7,"averageRssi":-71,"lastRssi":-73,"lqi":3,"frameErrorRate":5,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":6,"averageRssi":-89,"lastRssi":-89,"lqi":2,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":5,"averageRssi":-68,"lastRssi":-67,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":12,"pathCost":1,"lqiIn":0,"lqiOut":1,"age":168,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":1,"age":3,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":26,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":27,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":32768,"routerId":32,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":62,"pathCost":2,"lqiIn":2,"lqiOut":1,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true}]}},{"nodeId":"5","name":"BILRESA dual button","vendorId":"0x117C","productId":"0x8001","deviceType":15,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":2,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"kvzUg8uUYIM=","threadVersion":5,"neighborTable":[{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":526,"averageRssi":-11,"lastRssi":0,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":0,"pathCost":0,"lqiIn":3,"lqiOut":1,"age":14,"allocated":true,"linkEstablished":true}]}},{"nodeId":"14388134951535934862","name":"GRILLPLATS Flurlicht EG","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"Hmibk4TrSAo=","threadVersion":4,"neighborTable":[{"extAddress":"Ko4I3TGL/Rk=","rloc16":5120,"age":7,"averageRssi":-75,"lastRssi":-75,"lqi":3,"frameErrorRate":14,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ilH89VC5gP0=","rloc16":34816,"age":4,"averageRssi":-93,"lastRssi":-94,"lqi":1,"frameErrorRate":8,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"6vnSB9lAYQg=","rloc16":54272,"age":0,"averageRssi":-89,"lastRssi":-89,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"Ko4I3TGL/Rk=","rloc16":5120,"routerId":5,"nextHop":34,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":7,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":18432,"routerId":18,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"ilH89VC5gP0=","rloc16":34816,"routerId":34,"nextHop":5,"pathCost":1,"lqiIn":1,"lqiOut":2,"age":4,"allocated":true,"linkEstablished":true},{"extAddress":"6vnSB9lAYQg=","rloc16":54272,"routerId":53,"nextHop":5,"pathCost":3,"lqiIn":1,"lqiOut":2,"age":0,"allocated":true,"linkEstablished":true}]}},{"nodeId":"905838670972218924","name":"KAJPLATS E14 Pendel 1","vendorId":"0x117C","productId":"0x9006","deviceType":269,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"IrVCRCv+Esw=","threadVersion":5,"neighborTable":[{"extAddress":"umP55va/6bc=","rloc16":35867,"age":5,"averageRssi":-75,"lastRssi":-76,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":false,"fullThreadDevice":false,"fullNetworkData":false,"isChild":true},{"extAddress":"kvzUg8uUYIM=","rloc16":35888,"age":3,"averageRssi":-95,"lastRssi":-94,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":false,"fullThreadDevice":false,"fullNetworkData":false,"isChild":true},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":8,"averageRssi":-86,"lastRssi":-85,"lqi":2,"frameErrorRate":4,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":24,"averageRssi":-87,"lastRssi":-82,"lqi":2,"frameErrorRate":31,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":6,"averageRssi":-68,"lastRssi":-70,"lqi":3,"frameErrorRate":17,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":12,"averageRssi":-88,"lastRssi":-88,"lqi":2,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":1,"averageRssi":-50,"lastRssi":-51,"lqi":3,"frameErrorRate":6,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":62,"pathCost":2,"lqiIn":0,"lqiOut":0,"age":105,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":32,"pathCost":3,"lqiIn":2,"lqiOut":2,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":2,"lqiOut":3,"age":24,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":32,"pathCost":1,"lqiIn":1,"lqiOut":0,"age":6,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":4,"pathCost":1,"lqiIn":2,"lqiOut":1,"age":12,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":1,"allocated":true,"linkEstablished":true}]}},{"nodeId":"1","name":"KAJPLATS E14 Pendel 2","vendorId":"0x117C","productId":"0x9006","deviceType":269,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"chAHb/erIbY=","threadVersion":5,"neighborTable":[{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":5,"averageRssi":-93,"lastRssi":-93,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":22,"averageRssi":-72,"lastRssi":-72,"lqi":3,"frameErrorRate":7,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":8,"averageRssi":-70,"lastRssi":-71,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":25,"averageRssi":-52,"lastRssi":-52,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":17,"averageRssi":-85,"lastRssi":-85,"lqi":2,"frameErrorRate":28,"messageErrorRate":1,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":12,"pathCost":1,"lqiIn":0,"lqiOut":0,"age":20,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":2,"age":5,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":22,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":32,"pathCost":1,"lqiIn":1,"lqiOut":3,"age":27,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":25,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":35,"pathCost":3,"lqiIn":2,"lqiOut":2,"age":17,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false}]}}],"timestamp":1791811510733}}
</code></pre>
<p dir="auto">Also alles OK.</p>
<p dir="auto">Leider muss ich das nun täglich so machen, nervt ein wenig <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f622.png?v=216b35ebc9e" class="not-responsive emoji emoji-android emoji--cry" style="height:1.4em;width:auto;vertical-align:middle" title=":cry:" alt="😢" /></p>
<p dir="auto">Das einzige was ich in den letzten Tagen geändert habe, war das einspielen der üblichen Raspi Updates und das Update auf:<br />
<img src="/assets/uploads/files/1791812573634-04.png" alt="04.png" class="img-markdown  img-fluid" width="322" height="263" /></p>
<p dir="auto">Jemand eine Idee woran das liegen könnte ?</p>
]]></description><link>https://forum.iobroker.net/topic/85551/matter-adapter-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 21 Oct 2026 05:08:21 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/85551.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Oct 2026 13:47:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 18:29:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkblu" aria-label="Profile: darkblu">@<bdi>darkblu</bdi></a> Dass die beiden Dateien heute wieder da sind, ist normal. Die laufende Instanz legt sie beim Start an und hält die Sperre, solange sie läuft. Zum Problem wird es erst, wenn der Prozess weg ist und die Dateien liegen bleiben. Prüf mal, ob 3751 gerade deine matter.0 ist:</p>
<pre><code>ps -fp 3751
</code></pre>
<p dir="auto">Wenn dort matter.0 steht, ist alles in Ordnung.</p>
<p dir="auto">Die 1500 Zeilen musst du nicht alle lesen. Uns interessiert nur, was matter.0 und der Host um die Zeit gemacht haben:</p>
<pre><code>zgrep "2026-10-19 15:[12]" /opt/iobroker/log/iobroker.2026-10-19.log* | grep -E "matter\.0|host\." | head -200
</code></pre>
<p dir="auto">Poste die Ausgabe bitte hier oder im Issue. Wichtig ist vor allem, ob die Instanz da gestoppt oder neu gestartet wurde und ob dabei "send kill signal" oder ein Exit-Code auftaucht.</p>
<p dir="auto">Damit wir das nächste Mal direkt sehen, was passiert: Wenn es wieder auftritt, lösch die Dateien erst nach diesem Befehl:</p>
<pre><code>ls -la --time-style=full-iso /opt/iobroker/iobroker-data/matter.0/ota/
cat /opt/iobroker/iobroker-data/matter.0/ota/matter.pid
</code></pre>
<p dir="auto">Dann suchen wir im Log nach genau dieser Uhrzeit und PID.</p>
]]></description><link>https://forum.iobroker.net/post/1359763</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359763</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Tue, 20 Oct 2026 18:29:19 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 17:44:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: bluefox">@<bdi>bluefox</bdi></a> ,<br />
gestern um 15:20:00 bis 15:20:59 sind im Log über 1500 Sachen passiert.<br />
Ich blicke da aber nicht durch.</p>
<p dir="auto">Die Dateien aus dem ota Ordner habe ich auch bei Github hochgeladen, bzw nur die .json, die .pid und .lock gehen nicht.<br />
Allerdings ist die .lock leer,<br />
in der .pid steht: 3751 228c20699dd9506e</p>
<p dir="auto">die sind aber auch von heute, siehe screenshot:</p>
<p dir="auto"><img src="/assets/uploads/files/1792518110416-e508b3cd-830b-4c80-8874-50e2624a1db8-image.jpeg" alt="image.jpeg" class="img-markdown  img-fluid" width="1168" height="125" /></p>
]]></description><link>https://forum.iobroker.net/post/1359758</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359758</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 20 Oct 2026 17:44:17 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 17:44:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: bluefox">@<bdi>bluefox</bdi></a> , Github Issue hatte ich zuerst aktualisiert. Ist also schon erledigt.</p>
<p dir="auto">Was am 19.10 um 15:20 passiert ist weiss ich nicht mehr, ist ja schon ein Tag her. Ich gucke gleich mal ob ich da noch was liefern kann.</p>
]]></description><link>https://forum.iobroker.net/post/1359743</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359743</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 20 Oct 2026 17:44:29 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 16:03:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkblu" aria-label="Profile: darkblu">@<bdi>darkblu</bdi></a> Die Analyse passt. Mit dem Netzwerk hat das nichts zu tun: Der Controller startet gar nicht, weil im Verzeichnis <code>iobroker-data/matter.0/ota/</code> eine alte Sperre von einem früheren Prozess liegen bleibt. Deshalb hilft auch der Neustart der Instanz nicht, nur der Reboot oder das Löschen der Dateien.</p>
<p dir="auto">Bis es behoben ist, ist dein Workaround in Ordnung:</p>
<pre><code>iob stop matter.0
rm /opt/iobroker/iobroker-data/matter.0/ota/matter.lock /opt/iobroker/iobroker-data/matter.0/ota/matter.pid
iob start matter.0
</code></pre>
<p dir="auto">Bitte kopier die Analyse auch in dein Issue <a href="https://github.com/ioBroker/ioBroker.matter/issues/898" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.matter/issues/898</a>, vor allem den Inhalt vom Verzeichnis <code>ota</code> und die Uhrzeit der Dateien. Spannend wäre auch, was um die Zeit der Dateien (19.10. 15:20) im Log passiert ist: Wurde die Instanz da gestoppt, gab es ein Update oder einen Neustart vom js-controller?</p>
<p dir="auto">In matter.js wurde in letzter Zeit an diesen Sperrdateien einiges geändert, und die nächste Adapterversion bringt ein neueres matter.js mit. <a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> kann bestimmt sagen, ob dein Fall damit erledigt ist.</p>
]]></description><link>https://forum.iobroker.net/post/1359742</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359742</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Tue, 20 Oct 2026 16:03:18 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 16:02:53 GMT]]></title><description><![CDATA[<p dir="auto">Ich habe einen AppleTV (den mit LAN) und einen HomePod mini, wenn du das meinst.<br />
Eine Fritzbox 7530 und einen 8 Port LAN Switch von Netgear.<br />
Es lief ja alles schon monatelang perfekt.<br />
Die MoT Teile sind alle von IKEA.</p>
<p dir="auto">Es kam in letzter Zeit nix neues dazu.</p>
]]></description><link>https://forum.iobroker.net/post/1359740</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359740</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 20 Oct 2026 16:02:53 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 15:39:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkblu" aria-label="Profile: darkblu">@<bdi>darkblu</bdi></a> er findet keine Geräte im Netzwerk, also noch mal was für Geräte hast du von Apple und was für einen Router hast du und  auch Netzwerkswitch etc.</p>
]]></description><link>https://forum.iobroker.net/post/1359735</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359735</guid><dc:creator><![CDATA[Fabio]]></dc:creator><pubDate>Tue, 20 Oct 2026 15:39:25 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 15:30:41 GMT]]></title><description><![CDATA[<p dir="auto">Claude hat das hier gerade rausgefunden und sagt:<br />
Controller fails to start: "Storage is locked by another process" (stale ota/matter.pid, PID no longer exists)</p>
<p dir="auto">Description</p>
<p dir="auto">After a few days of normal operation, matter.0 shows a green instance but no devices are available. Restarting the instance does not help. The controller fails to start on every attempt with a storage lock error. The lock is held by a PID that no longer exists (stale lock).</p>
<p dir="auto">Rebooting the whole Raspberry Pi also fixes it, but I now have to do that regularly. Removing the stale lock files manually (see below) fixes it without a reboot.</p>
<p dir="auto">Environment</p>
<p dir="auto">ioBroker.matter: 1.3.1<br />
js-controller: 7.2.2<br />
admin: 8.0.14<br />
Node.js: 24.21.0<br />
OS: Debian 13 (trixie), Raspberry Pi 5 (8 GB), arm64<br />
Thread network via Apple border router, 8 IKEA Thread devices<br />
Symptoms</p>
<p dir="auto">Instance is green, no log output, devices are missing in the adapter UI<br />
After restarting the instance, the log shows the error below and the devices are still missing<br />
The error occurred on every start attempt (e.g. 13:10, 15:36, 15:44)<br />
Log</p>
<pre><code>
error: matter.0 (3445) Failed to start the controller: [crashed-dependency] MatterController unavailable due to initialization error
Caused by: [storage-lock] Storage is locked by another process (pid 2087)
    at acquireLock (@matter/nodejs/src/fs/lock-utils.ts:139:19)
    at acquireDirectoryLock (@matter/nodejs/src/fs/lock-utils.ts:90:5)
    at DatafileRoot.#acquireRef (@matter/general/src/storage/DatafileRoot.ts:74:29)
    at FlatFileBlobStorageDriver.initialize (@matter/nodejs/src/storage/fs/FlatFileBlobStorageDriver.ts:46:9)
    at StorageService.#openBlobFilesystem (@matter/general/src/storage/StorageService.ts:395:13)
</code></pre>
<p dir="auto">Analysis</p>
<p dir="auto">ps -p 2087 returns nothing, so the process named in the error does not exist anymore.<br />
fuser on the lock file shows no process holding it.<br />
The directory iobroker-data/matter.0/ota/ contained:<br />
matter.lock (0 bytes)<br />
matter.pid (content: 2087 999e67500e993e0a)<br />
driver.json<br />
Both matter.lock and matter.pid were dated the previous day (Oct 19, 15:20), i.e. left over from an earlier run.<br />
Workaround</p>
<pre><code>
iob stop matter.0
mv iobroker-data/matter.0/ota/matter.pid iobroker-data/matter.0/ota/matter.lock &lt;somewhere else&gt;
iob start matter.0
</code></pre>
<p dir="auto">After this, all 8 nodes connected again immediately.</p>
<p dir="auto">Expected behavior</p>
<p dir="auto">A stale lock (PID not running) should be detected and ignored or cleaned up, and the lock should be released on adapter shutdown or termination. Even if the lock cannot be acquired, a failing OTA service should not prevent the whole controller from starting.</p>
<p dir="auto">Könnte vielleicht dann auftreten, wenn ich den „update“ Knop klicke.<br />
Allerdings ist Claude gerade wieder aufgebraucht. Werde ich morgen mit ihm weiter bereden.</p>
]]></description><link>https://forum.iobroker.net/post/1359731</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359731</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 20 Oct 2026 15:30:41 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 15:26:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkblu" aria-label="Profile: darkblu">@<bdi>darkblu</bdi></a> <a href="/post/1359729">sagte</a>:</p>
<p dir="auto">Sie kommen von Apple Home in den ioBroker.</p>
</blockquote>
<p dir="auto">was hast du für ein Setup. Lass mich raten Homepod Mini 1 Generation evtl. Apple TV 4 K mit Lan?</p>
]]></description><link>https://forum.iobroker.net/post/1359730</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359730</guid><dc:creator><![CDATA[Fabio]]></dc:creator><pubDate>Tue, 20 Oct 2026 15:26:08 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 15:22:43 GMT]]></title><description><![CDATA[<p dir="auto">Sie kommen von Apple Home in den ioBroker.</p>
]]></description><link>https://forum.iobroker.net/post/1359729</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359729</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 20 Oct 2026 15:22:43 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 15:16:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkblu" aria-label="Profile: darkblu">@<bdi>darkblu</bdi></a> woher hast du die Geräte den freigegeben?<br />
Grüße<br />
Fabio</p>
]]></description><link>https://forum.iobroker.net/post/1359727</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359727</guid><dc:creator><![CDATA[Fabio]]></dc:creator><pubDate>Tue, 20 Oct 2026 15:16:17 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 20 Oct 2026 13:55:29 GMT]]></title><description><![CDATA[<p dir="auto">hier mal ein update, die Geräte kommen und gehen wie von Geisterhand.<br />
Mal sind sie tagelang da und dann wieder ohne eine Auffälligkeit weg.<br />
Sie kommen und gehen wie sie wollen. <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=216b35ebc9e" class="not-responsive emoji emoji-android emoji--confused" style="height:1.4em;width:auto;vertical-align:middle" title=":confused:" alt="😕" /></p>
<p dir="auto">Aktuell sind sie wieder weg, in den Objekten sieht es aber aktuell so aus:</p>
<p dir="auto"><img src="/assets/uploads/files/1792504476751-bc102cb7-c344-4b5b-b4fd-77f4c381c455-image.jpeg" alt="image.jpeg" class="img-markdown  img-fluid" width="1030" height="537" /></p>
<p dir="auto">Scheinbar alle da und ok.</p>
]]></description><link>https://forum.iobroker.net/post/1359714</link><guid isPermaLink="true">https://forum.iobroker.net/post/1359714</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 20 Oct 2026 13:55:29 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 13 Oct 2026 14:43:19 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: Bluefox">@<bdi>Bluefox</bdi></a> <a href="/post/1358641">said</a>:</p>
<p dir="auto">Ja, aber Versionsnummer? Und es wäre besser issue anzulegen</p>
</blockquote>
<p dir="auto">Matter V1.3.1 und Issue ist auf Github angelegt</p>
]]></description><link>https://forum.iobroker.net/post/1358642</link><guid isPermaLink="true">https://forum.iobroker.net/post/1358642</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 13 Oct 2026 14:43:19 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 13 Oct 2026 14:37:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkblu" aria-label="Profile: darkblu">@<bdi>darkblu</bdi></a> <a href="/post/1358615">sagte</a>:</p>
<p dir="auto">Ich spreche jetzt mal direkt <a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: bluefox">@<bdi>bluefox</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> an, könnt ihr helfen ?</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1358641</link><guid isPermaLink="true">https://forum.iobroker.net/post/1358641</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Tue, 13 Oct 2026 14:37:18 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 13 Oct 2026 13:42:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkblu" aria-label="Profile: darkblu">@<bdi>darkblu</bdi></a> <a href="/post/1358628">sagte</a>:</p>
<p dir="auto">Bei den Logs klicke ich allerdings sehr oft auf: "von der Disk dauerhaft löschen"</p>
</blockquote>
<p dir="auto">Ist vielleicht nicht sooooooo clever. Die iobroker Logs unterliegen der LogRotation.</p>
]]></description><link>https://forum.iobroker.net/post/1358632</link><guid isPermaLink="true">https://forum.iobroker.net/post/1358632</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 13 Oct 2026 13:42:07 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 13 Oct 2026 13:28:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> , erledigt.<br />
]]></description><link>https://forum.iobroker.net/post/1358628</link><guid isPermaLink="true">https://forum.iobroker.net/post/1358628</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 13 Oct 2026 13:28:47 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 13 Oct 2026 13:05:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkblu" aria-label="Profile: darkblu">@<bdi>darkblu</bdi></a> schon mal auf <a href="https://github.com/ioBroker/ioBroker.matter/issues" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.matter/issues</a> nachgesehen, ggf ein neues issue mit ausführlicher Beschreibung und Verlinkung auf diesen Thread erstellen.</p>
<blockquote>
<p dir="auto">eine Möglichkeit sich die Adapter nach Installationsdatum anzeigen zu lassen</p>
</blockquote>
<p dir="auto">du kannst z.b. deine Logs durchsehen</p>
]]></description><link>https://forum.iobroker.net/post/1358620</link><guid isPermaLink="true">https://forum.iobroker.net/post/1358620</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 13 Oct 2026 13:05:29 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Tue, 13 Oct 2026 13:02:50 GMT]]></title><description><![CDATA[<p dir="auto">und 22 Stunden später wieder das gleiche:</p>
<p dir="auto"><img src="/assets/uploads/files/1791895632618-011.png" alt="011.png" class="img-markdown  img-fluid" width="549" height="392" /></p>
<p dir="auto">und wieder diese Fehlermeldung, wenn ich den grünen Matter Adapter, bzw Instanz neustarte:</p>
<pre><code>matter.0
2026-10-13 14:44:38.786	error	Failed to start the controller: [crashed-dependency] MatterController unavailable due to initialization error at Construction2.#crashedError (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:597:42) at handleRejection (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:330:74) Caused by: [endpoint-behaviors] Behaviors have errors at /opt/iobroker/node_modules/@matter/node/src/endpoint/properties/Behaviors.ts:253:27 at all (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:752:25) at /opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:742:17 Cause #0: [behavior-initialization] Error initializing controller.ota-provider.otaSoftwareUpdateProvider at crash (/opt/iobroker/node_modules/@matter/node/src/behavior/internal/BehaviorBacking.ts:94:30) at /opt/iobroker/node_modules/@matter/general/src/util/Promises.ts:199:38 Caused by: [crashed-dependency] controller.ota-provider.softwareupdates initialization failed at Object.assertActive (/opt/iobroker/node_modules/@matter/general/src/util/Lifecycle.ts:48:23) at Construction2.assert (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:303:23) at /opt/iobroker/node_modules/@matter/node/src/endpoint/properties/Behaviors.ts:382:42 at OtaSoftwareUpdateProviderServer.initialize (/opt/iobroker/node_modules/@matter/node/src/behaviors/ota-software-update-provider/OtaSoftwareUpdateProviderServer.ts:90:9) Cause #1: [behavior-initialization] Error initializing controller.ota-provider.softwareupdates at crash (/opt/iobroker/node_modules/@matter/node/src/behavior/internal/BehaviorBacking.ts:94:30) at /opt/iobroker/node_modules/@matter/general/src/util/Promises.ts:199:38 Caused by: [crashed-dependency] DclOtaUpdateService unavailable due to initialization error at Construction2.#crashedError (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:597:42) at handleRejection (/opt/iobroker/node_modules/@matter/general/src/util/Construction.ts:330:74) Caused by: [storage-lock] Storage is locked by another process (pid 2067) at acquireLock (/opt/iobroker/node_modules/@matter/nodejs/src/fs/lock-utils.ts:139:19) at acquireDirectoryLock (/opt/iobroker/node_modules/@matter/nodejs/src/fs/lock-utils.ts:90:5) at DatafileRoot.#acquireRef (/opt/iobroker/node_modules/@matter/general/src/storage/DatafileRoot.ts:74:29) at DatafileRoot.lock (/opt/iobroker/node_modules/@matter/general/src/storage/DatafileRoot.ts:64:20) at FlatFileBlobStorageDriver.initialize (/opt/iobroker/node_modules/@matter/general/src/storage/BlobStorageDriver.ts:55:26) at FlatFileBlobStorageDriver.initialize (/opt/iobroker/node_modules/@matter/nodejs/src/storage/fs/FlatFileBlobStorageDriver.ts:46:9) at StorageService.#openBlobFilesystem (/opt/iobroker/node_modules/@matter/general/src/storage/StorageService.ts:395:13) at /opt/iobroker/node_modules/@matter/protocol/src/dcl/DclOtaUpdateService.ts:91:32 Caused by: [storage-lock] Storage is locked by another process (pid 2067) at acquireLock (/opt/iobroker/node_modules/@matter/nodejs/src/fs/lock-utils.ts:139:19) at acquireDirectoryLock (/opt/iobroker/node_modules/@matter/nodejs/src/fs/lock-utils.ts:90:5) at DatafileRoot.#acquireRef (/opt/iobroker/node_modules/@matter/general/src/storage/DatafileRoot.ts:74:29) at DatafileRoot.lock (/opt/iobroker/node_modules/@matter/general/src/storage/DatafileRoot.ts:64:20) at FlatFileBlobStorageDriver.initialize (/opt/iobroker/node_modules/@matter/general/src/storage/BlobStorageDriver.ts:55:26) at FlatFileBlobStorageDriver.initialize (/opt/iobroker/node_modules/@matter/nodejs/src/storage/fs/FlatFileBlobStorageDriver.ts:46:9) at StorageService.#openBlobFilesystem (/opt/iobroker/node_modules/@matter/general/src/storage/StorageService.ts:395:13) at /opt/iobroker/node_modules/@matter/protocol/src/dcl/DclOtaUpdateService.ts:91:32
</code></pre>
<p dir="auto">Es gab die Tage ein paar Adapter updates, kann mich aber nicht erinnern welche das waren.<br />
Gibt es eine Möglichkeit sich die Adapter nach Installationsdatum anzeigen zu lassen ?</p>
]]></description><link>https://forum.iobroker.net/post/1358615</link><guid isPermaLink="true">https://forum.iobroker.net/post/1358615</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Tue, 13 Oct 2026 13:02:50 GMT</pubDate></item><item><title><![CDATA[Reply to Matter (Adapter) Problem on Mon, 12 Oct 2026 13:56:16 GMT]]></title><description><![CDATA[<p dir="auto">hier noch ein iob diag, vielleicht findet sich ja da etwas:</p>
<pre><code>```bash
Script v.2026-08-30
*** BASE SYSTEM ***
Operating System: Debian GNU/Linux 13 (trixie)
 Static hostname: smart
       Icon name: computer
          Kernel: Linux 6.18.50+rpt-rpi-2712
    Architecture: arm64
OS is similar to:
Model           : Raspberry Pi 5 Model B Rev 1.0
Docker          : false
Virtualization  : none
Unknown
Kernel          : aarch64
Userland        : 64bit
System was installed 830 days ago (on 2024-07-04).
Systemuptime and Load:
 15:50:29 up 28 min,  1 user,  load average: 0.56, 0.50, 0.43
CPU threads     : 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'trixie'!
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** TIME AND TIMEZONES ***
               Local time: Mon 2026-10-12 15:50:29 CEST
           Universal time: Mon 2026-10-12 13:50:29 UTC
                 RTC time: Mon 2026-10-12 13:50:29
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
dirk
HOME=/home/dirk
GROUPS=dirk adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
iobroker
HOME=/home/iobroker
*** DISPLAY-SERVER SETUP ***
Display-Server:         Unknown
Display-Manager:        Not found
Desktop:
Session:                tty
Boot Target:            multi-user.target
*** MEMORY ***
Mem:            8.5G        6.0G        1.9G         18M        738M        2.4G
Swap:           209M         75M        133M
Total:          8.7G        6.1G        2.0G
Active iob-Instances:   42
         8062 M total memory
         5769 M used memory
         2122 M active memory
         3684 M inactive memory
         1822 M free memory
           72 M buffer memory
          631 M swap cache
          199 M total swap
           72 M used swap
          127 M free swap
top - 15:50:30 up 28 min,  1 user,  load average: 0.56, 0.50, 0.43
Tasks: 209 total,   2 running, 207 sleeping,   0 stopped,   0 zombie
%Cpu(s): 16.3 us,  2.3 sy,  0.0 ni, 81.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   8062.3 total,   1816.9 free,   5770.7 used,    708.4 buff/cache
MiB Swap:    200.0 total,    127.6 free,     72.4 used.   2291.6 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  3.9G     0  3.9G   0% /dev
tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
/dev/sda2      ext4      117G   14G   98G  12% /
tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
tmpfs          tmpfs     4.0G  8.7M  4.0G   1% /tmp
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
/dev/sda1      vfat      510M   76M  435M  15% /boot/firmware
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
tmpfs          tmpfs     807M   32K  807M   1% /run/user/1000
Messages concerning filesystems in dmesg (Last 15 lines only):
[Mon Oct 12 15:21:46 2026] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
[Mon Oct 12 15:21:47 2026] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
Show mounted filesystems:
TARGET           SOURCE    FSTYPE OPTIONS
/                /dev/sda2 ext4   rw,noatime
`-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
1.2G    /var/
513M    /var/log
511M    /var/log/journal/0bb91f04b362427fada72bc0b1702d31
217M    /var/lib
Archived and active journals take up 520.1M in the file system.
/opt/iobroker/backups:
3.6G    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
636M    /opt/iobroker/iobroker-data/
385M    /opt/iobroker/iobroker-data/files
177M    /opt/iobroker/iobroker-data/backup-objects
59M     /opt/iobroker/iobroker-data/files/vis
58M     /opt/iobroker/iobroker-data/files/mytime.admin/custom
44M     /opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomMytimeSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-Ctb_nNMK.js.map
35M     /opt/iobroker/iobroker-data/objects.jsonl
23M     /opt/iobroker/iobroker-data/files/zendure-solarflow.admin/build/index.js.map
19M     /opt/iobroker/iobroker-data/states.jsonl
16M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-EdnNzxJx.js
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2440876-if00
*** ZigBee Settings ***
Zigbee Network Settings on your coordinator / in nvbackup are:
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
=== ZigBee Port Overview ===
Instance        Configured Port                     Available by-id Port                Status
zigbee.0        ..._ConBee_II_DE2440876-if00        ..._ConBee_II_DE2440876-if00        ✓ Matching
*** NodeJS-Installation ***
/usr/bin/nodejs         v24.21.0
/usr/bin/node           v24.21.0
/usr/bin/npm            11.19.0
/usr/bin/npx            11.19.0
✓ Node.js installation is correct
nodejs:
  Installed: 24.21.0-1nodesource1
  Candidate: 24.21.0-1nodesource1
  Version table:
 *** 24.21.0-1nodesource1 1001
        500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
        100 /var/lib/dpkg/status
     24.20.0-1nodesource1 1001
     24.19.0-1nodesource1 1001
     24.18.1-1nodesource1 1001
     24.18.0-1nodesource1 1001
     24.17.0-1nodesource1 1001
     24.16.0-1nodesource1 1001
     24.15.0-1nodesource1 1001
     24.14.1-1nodesource1 1001
     24.14.0-1nodesource1 1001
     24.13.1-1nodesource1 1001
     24.13.0-1nodesource1 1001
     24.12.0-1nodesource1 1001
     24.11.1-1nodesource1 1001
     24.11.0-1nodesource1 1001
     24.10.0-1nodesource1 1001
     24.9.0-1nodesource1 1001
     24.8.0-1nodesource1 1001
     24.7.0-1nodesource1 1001
     24.6.0-1nodesource1 1001
     24.5.0-1nodesource1 1001
     24.4.1-1nodesource1 1001
     24.4.0-1nodesource1 1001
     24.3.0-1nodesource1 1001
     24.1.0-1nodesource1 1001
     24.0.2-1nodesource1 1001
     24.0.1-1nodesource1 1001
     24.0.0-1nodesource1 1001
     20.19.2+dfsg-1+deb13u3 500
        500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
     20.19.2+dfsg-1+deb13u2 500
        500 http://deb.debian.org/debian trixie/main arm64 Packages
No problems detected
Errors in npm tree: 0
No known Vulnerabilities detected!
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
smart               smart (version: 7.2.2, hostname: smart         , alive, uptime: 1712)
Core adapters versions
admin:          8.0.14
javascript:     10.1.3
nodejs modules from github:     2
+-- iobroker.smart-eq@0.1.1 (git+ssh://git@github.com/TA2k/ioBroker.smart-eq.git#9eec31511c3b94b2281b5565abe75b3f4cab5f27)
| +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
Adapter State
+ system.adapter.admin.0                  : admin                 : smart                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.alexa2.0                 : alexa2                : smart                                    -  enabled
  system.adapter.alias-manager.0          : alias-manager         : smart                                    -  enabled
+ system.adapter.awtrix-ng.0              : awtrix-ng             : smart                                    -  enabled
+ system.adapter.awtrix-ng.1              : awtrix-ng             : smart                                    -  enabled
+ system.adapter.awtrix-ng.2              : awtrix-ng             : smart                                    -  enabled
+ system.adapter.backitup.0               : backitup              : smart                                    -  enabled
+ system.adapter.cloud.0                  : cloud                 : smart                                    -  enabled
+ system.adapter.device-watcher.0         : device-watcher        : smart                                    -  enabled
+ system.adapter.discovery.0              : discovery             : smart                                    -  enabled
  system.adapter.dwd.0                    : dwd                   : smart                                    -  enabled
+ system.adapter.echarts.0                : echarts               : smart                                    -  enabled
  system.adapter.energiefluss.0           : energiefluss          : smart                                    - disabled
  system.adapter.feiertage.0              : feiertage             : smart                                    -  enabled
+ system.adapter.fullybrowser.0           : fullybrowser          : smart                                    -  enabled
+ system.adapter.hmip.0                   : hmip                  : smart                                    -  enabled
+ system.adapter.homeconnect.0            : homeconnect           : smart                                    -  enabled
+ system.adapter.hue.0                    : hue                   : smart                                    -  enabled, port: 443
  system.adapter.ical.0                   : ical                  : smart                                    -  enabled
  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : smart                                    -  enabled
  system.adapter.icons-material-png.0     : icons-material-png    : smart                                    -  enabled
  system.adapter.icons-mfd-png.0          : icons-mfd-png         : smart                                    -  enabled
  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : smart                                    -  enabled
  system.adapter.icons-smarthome.0        : icons-smarthome       : smart                                    -  enabled
+ system.adapter.influxdb.0               : influxdb              : smart                                    -  enabled, port: 8086
+ system.adapter.iot.0                    : iot                   : smart                                    -  enabled
+ system.adapter.javascript.0             : javascript            : smart                                    -  enabled
+ system.adapter.linux-control.0          : linux-control         : smart                                    -  enabled
+ system.adapter.matter.0                 : matter                : smart                                    -  enabled
+ system.adapter.mitsubishi-local-control.0: mitsubishi-local-control: smart                                    -  enabled
+ system.adapter.modbus.0                 : modbus                : smart                                    -  enabled
+ system.adapter.mqtt.0                   : mqtt                  : smart                                    -  enabled, port: 1887, bind: 0.0.0.0
+ system.adapter.mytime.0                 : mytime                : smart                                    -  enabled
+ system.adapter.nuki.0                   : nuki                  : smart                                    -  enabled
  system.adapter.reolink.0                : reolink               : smart                                    - disabled
+ system.adapter.shelly.0                 : shelly                : smart                                    -  enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.shelly.1                 : shelly                : smart                                    -  enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.smart-eq.0               : smart-eq              : smart                                    -  enabled
+ system.adapter.sonoff.0                 : sonoff                : smart                                    -  enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.sonos.0                  : sonos                 : smart                                    -  enabled
+ system.adapter.sourceanalytix.0         : sourceanalytix        : smart                                    -  enabled
+ system.adapter.statistics.0             : statistics            : smart                                    -  enabled
+ system.adapter.synology.0               : synology              : smart                                    -  enabled, port: 5000
+ system.adapter.tr-064.0                 : tr-064                : smart                                    -  enabled
+ system.adapter.trashschedule.0          : trashschedule         : smart                                    -  enabled
+ system.adapter.tuya.0                   : tuya                  : smart                                    -  enabled
+ system.adapter.upnp.0                   : upnp                  : smart                                    -  enabled
  system.adapter.uv-protect.0             : uv-protect            : smart                                    - disabled
  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : smart                                    -  enabled
  system.adapter.vis-colorpicker.0        : vis-colorpicker       : smart                                    -  enabled
  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smart                                    -  enabled
  system.adapter.vis-icontwo.0            : vis-icontwo           : smart                                    -  enabled
  system.adapter.vis-inventwo.0           : vis-inventwo          : smart                                    -  enabled
  system.adapter.vis-materialdesign.0     : vis-materialdesign    : smart                                    -  enabled
  system.adapter.vis-players.0            : vis-players           : smart                                    -  enabled
  system.adapter.vis-plumb.0              : vis-plumb             : smart                                    -  enabled
  system.adapter.vis-timeandweather.0     : vis-timeandweather    : smart                                    -  enabled
  system.adapter.vis.0                    : vis                   : smart                                    -  enabled
+ system.adapter.web.0                    : web                   : smart                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : smart                                    -  enabled
+ system.adapter.wled.0                   : wled                  : smart                                    -  enabled
+ system.adapter.zendure-solarflow.0      : zendure-solarflow     : smart                                    -  enabled
+ system.adapter.zigbee.0                 : zigbee                : smart                                    -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2440876-if00
+ instance is alive
ioBroker-Repositories
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
│ (index) │ id                                        │ name                       │ version   │ upgrade policy │
│ 0       │ 'system.adapter.admin'                    │ 'admin'                    │ '8.0.14'  │ 'none'         │
│ 1       │ 'system.adapter.alexa2'                   │ 'alexa2'                   │ '3.28.3'  │ 'none'         │
│ 2       │ 'system.adapter.alias-manager'            │ 'alias-manager'            │ '2.1.0'   │ 'none'         │
│ 3       │ 'system.adapter.awtrix-ng'                │ 'awtrix-ng'                │ '0.3.0'   │ 'none'         │
│ 4       │ 'system.adapter.backitup'                 │ 'backitup'                 │ '4.0.3'   │ 'none'         │
│ 5       │ 'system.adapter.cloud'                    │ 'cloud'                    │ '6.2.7'   │ 'none'         │
│ 6       │ 'system.adapter.device-watcher'           │ 'device-watcher'           │ '2.15.17' │ 'none'         │
│ 7       │ 'system.adapter.discovery'                │ 'discovery'                │ '5.0.0'   │ 'none'         │
│ 8       │ 'system.adapter.dwd'                      │ 'dwd'                      │ '2.8.5'   │ 'none'         │
│ 9       │ 'system.adapter.echarts'                  │ 'echarts'                  │ '3.1.0'   │ 'none'         │
│ 10      │ 'system.adapter.energiefluss'             │ 'energiefluss'             │ '3.6.2'   │ 'none'         │
│ 11      │ 'system.adapter.feiertage'                │ 'feiertage'                │ '1.4.0'   │ 'none'         │
│ 12      │ 'system.adapter.fullybrowser'             │ 'fullybrowser'             │ '3.1.2'   │ 'none'         │
│ 13      │ 'system.adapter.hmip'                     │ 'hmip'                     │ '3.1.1'   │ 'none'         │
│ 14      │ 'system.adapter.homeconnect'              │ 'homeconnect'              │ '1.6.1'   │ 'none'         │
│ 15      │ 'system.adapter.hue'                      │ 'hue'                      │ '3.16.2'  │ 'none'         │
│ 16      │ 'system.adapter.ical'                     │ 'ical'                     │ '1.21.0'  │ 'none'         │
│ 17      │ 'system.adapter.icons-fatcow-hosting'     │ 'icons-fatcow-hosting'     │ '0.1.0'   │ 'none'         │
│ 18      │ 'system.adapter.icons-material-png'       │ 'icons-material-png'       │ '0.1.0'   │ 'none'         │
│ 19      │ 'system.adapter.icons-mfd-png'            │ 'icons-mfd-png'            │ '1.2.1'   │ 'none'         │
│ 20      │ 'system.adapter.icons-mfd-svg'            │ 'icons-mfd-svg'            │ '1.2.0'   │ 'none'         │
│ 21      │ 'system.adapter.icons-smarthome'          │ 'icons-smarthome'          │ '1.0.0'   │ 'none'         │
│ 22      │ 'system.adapter.influxdb'                 │ 'influxdb'                 │ '4.0.2'   │ 'none'         │
│ 23      │ 'system.adapter.iot'                      │ 'iot'                      │ '7.1.2'   │ 'none'         │
│ 24      │ 'system.adapter.javascript'               │ 'javascript'               │ '10.1.3'  │ 'none'         │
│ 25      │ 'system.adapter.linux-control'            │ 'linux-control'            │ '1.1.5'   │ 'none'         │
│ 26      │ 'system.adapter.matter'                   │ 'matter'                   │ '1.3.1'   │ 'none'         │
│ 27      │ 'system.adapter.mitsubishi-local-control' │ 'mitsubishi-local-control' │ '1.0.6'   │ 'none'         │
│ 28      │ 'system.adapter.modbus'                   │ 'modbus'                   │ '8.0.3'   │ 'none'         │
│ 29      │ 'system.adapter.mqtt'                     │ 'mqtt'                     │ '6.1.4'   │ 'none'         │
│ 30      │ 'system.adapter.mytime'                   │ 'mytime'                   │ '3.0.1'   │ 'none'         │
│ 31      │ 'system.adapter.nuki'                     │ 'nuki'                     │ '2.0.0'   │ 'none'         │
│ 32      │ 'system.adapter.reolink'                  │ 'reolink'                  │ '1.4.2'   │ 'none'         │
│ 33      │ 'system.adapter.shelly'                   │ 'shelly'                   │ '12.0.0'  │ 'none'         │
│ 34      │ 'system.adapter.simple-api'               │ 'simple-api'               │ '2.8.0'   │ 'none'         │
│ 35      │ 'system.adapter.smart-eq'                 │ 'smart-eq'                 │ '0.1.1'   │ 'none'         │
│ 36      │ 'system.adapter.socketio'                 │ 'socketio'                 │ '7.1.3'   │ 'none'         │
│ 37      │ 'system.adapter.sonoff'                   │ 'sonoff'                   │ '3.3.0'   │ 'none'         │
│ 38      │ 'system.adapter.sonos'                    │ 'sonos'                    │ '3.0.0'   │ 'none'         │
│ 39      │ 'system.adapter.sourceanalytix'           │ 'sourceanalytix'           │ '0.4.14'  │ 'none'         │
│ 40      │ 'system.adapter.statistics'               │ 'statistics'               │ '5.0.0'   │ 'none'         │
│ 41      │ 'system.adapter.synology'                 │ 'synology'                 │ '3.1.0'   │ 'none'         │
│ 42      │ 'system.adapter.tr-064'                   │ 'tr-064'                   │ '4.3.0'   │ 'none'         │
│ 43      │ 'system.adapter.trashschedule'            │ 'trashschedule'            │ '5.3.0'   │ 'none'         │
│ 44      │ 'system.adapter.tuya'                     │ 'tuya'                     │ '3.17.0'  │ 'none'         │
│ 45      │ 'system.adapter.upnp'                     │ 'upnp'                     │ '1.1.0'   │ 'none'         │
│ 46      │ 'system.adapter.uv-protect'               │ 'uv-protect'               │ '0.7.1'   │ 'none'         │
│ 47      │ 'system.adapter.vis'                      │ 'vis'                      │ '1.5.6'   │ 'none'         │
│ 48      │ 'system.adapter.vis-canvas-gauges'        │ 'vis-canvas-gauges'        │ '1.0.1'   │ 'none'         │
│ 49      │ 'system.adapter.vis-colorpicker'          │ 'vis-colorpicker'          │ '2.1.0'   │ 'none'         │
│ 50      │ 'system.adapter.vis-hqwidgets'            │ 'vis-hqwidgets'            │ '1.6.1'   │ 'none'         │
│ 51      │ 'system.adapter.vis-icontwo'              │ 'vis-icontwo'              │ '2.11.6'  │ 'none'         │
│ 52      │ 'system.adapter.vis-inventwo'             │ 'vis-inventwo'             │ '4.1.1'   │ 'none'         │
│ 53      │ 'system.adapter.vis-materialdesign'       │ 'vis-materialdesign'       │ '0.5.9'   │ 'none'         │
│ 54      │ 'system.adapter.vis-players'              │ 'vis-players'              │ '0.1.6'   │ 'none'         │
│ 55      │ 'system.adapter.vis-plumb'                │ 'vis-plumb'                │ '1.0.2'   │ 'none'         │
│ 56      │ 'system.adapter.vis-timeandweather'       │ 'vis-timeandweather'       │ '1.2.2'   │ 'none'         │
│ 57      │ 'system.adapter.web'                      │ 'web'                      │ '8.0.0'   │ 'none'         │
│ 58      │ 'system.adapter.whatsapp-cmb'             │ 'whatsapp-cmb'             │ '0.3.0'   │ 'none'         │
│ 59      │ 'system.adapter.wled'                     │ 'wled'                     │ '0.7.3'   │ 'none'         │
│ 60      │ 'system.adapter.ws'                       │ 'ws'                       │ '4.1.0'   │ 'none'         │
│ 61      │ 'system.adapter.zendure-solarflow'        │ 'zendure-solarflow'        │ '5.3.1'   │ 'none'         │
│ 62      │ 'system.adapter.zigbee'                   │ 'zigbee'                   │ '3.5.5'   │ 'none'         │
ioBroker-Adapter Versions and update status
Used repository: stable
Adapter    "admin"        : 8.0.14   , installed 8.0.14
Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
Adapter    "alias-manager": 2.1.0    , installed 2.1.0
Adapter    "backitup"     : 4.0.3    , installed 4.0.3
Adapter    "cloud"        : 6.2.7    , installed 6.2.7
Adapter    "device-watcher": 2.15.17 , installed 2.15.17
Adapter    "echarts"      : 3.1.0    , installed 3.1.0
Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
Adapter    "hmip"         : 3.1.1    , installed 3.1.1
Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
Adapter    "hue"          : 3.16.2   , installed 3.16.2
Adapter    "ical"         : 1.21.0   , installed 1.21.0
Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
Adapter    "iot"          : 7.1.2    , installed 7.1.2
Adapter    "javascript"   : 10.1.3   , installed 10.1.3
Controller "js-controller": 7.2.2    , installed 7.2.2
Adapter    "linux-control": 1.1.5    , installed 1.1.5
Adapter    "matter"       : 1.3.1    , installed 1.3.1
Adapter    "mitsubishi-local-control": 1.0.6, installed 1.0.6
Adapter    "modbus"       : 8.0.3    , installed 8.0.3
Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
Adapter    "mytime"       : 3.0.1    , installed 3.0.1
Adapter    "nuki"         : 2.0.0    , installed 2.0.0
Adapter    "reolink"      : 1.4.2    , installed 1.4.2
Adapter    "shelly"       : 12.0.0   , installed 12.0.0
Adapter    "socketio"     : 7.1.3    , installed 7.1.3
Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
Adapter    "sonos"        : 3.0.0    , installed 3.0.0
Adapter    "statistics"   : 5.0.0    , installed 5.0.0
Adapter    "synology"     : 3.1.0    , installed 3.1.0
Adapter    "trashschedule": 5.3.0    , installed 5.3.0
Adapter    "tuya"         : 3.17.0   , installed 3.17.0
Adapter    "upnp"         : 1.1.0    , installed 1.1.0
Adapter    "uv-protect"   : 0.7.1    , installed 0.7.1
Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
Adapter    "vis-icontwo"  : 2.11.6   , installed 2.11.6
Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
Adapter    "web"          : 8.0.0    , installed 8.0.0
Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
Adapter    "wled"         : 0.7.3    , installed 0.7.3
Adapter    "ws"           : 4.1.0    , installed 4.1.0
Adapter    "zendure-solarflow": 5.3.1, installed 5.3.1
Adapter    "zigbee"       : 3.5.5    , installed 3.5.5
Objects and States
Objects:        16027
States:         13518
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
Hit:3 http://deb.debian.org/debian trixie-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
Get:6 https://repos.influxdata.com/debian stable InRelease [6922 B]
Fetched 6922 B in 0s (44.8 kB/s)
Reading package lists...
Pending systemupdates: 0
*** Listening Ports ***
Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
udp   UNCONN 0      0                          0.0.0.0:53431              0.0.0.0:*    users:(("io.matter.0",pid=2067,fd=38))
udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("io.matter.0",pid=2067,fd=41))
udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("io.matter.0",pid=2067,fd=35))
udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("io.wled.0",pid=2018,fd=22))
udp   UNCONN 0      0                   192.168.178.40:mdns               0.0.0.0:*    users:(("io.tr-064.0",pid=1647,fd=38))
udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=683,fd=12))
udp   UNCONN 0      0                          0.0.0.0:coap               0.0.0.0:*    users:(("io.shelly.0",pid=1580,fd=36))
udp   UNCONN 0      0                          0.0.0.0:1900               0.0.0.0:*    users:(("io.upnp.0",pid=1985,fd=30))
udp   UNCONN 0      0                          0.0.0.0:6666               0.0.0.0:*    users:(("io.tuya.0",pid=1664,fd=45))
udp   UNCONN 0      0                          0.0.0.0:6667               0.0.0.0:*    users:(("io.tuya.0",pid=1664,fd=46))
udp   UNCONN 0      0                          0.0.0.0:44134              0.0.0.0:*    users:(("avahi-daemon",pid=683,fd=14))
udp   UNCONN 0      0                                *:53431                    *:*    users:(("io.matter.0",pid=2067,fd=37))
udp   UNCONN 0      0      [fe80::1fd4:b7df:3bac:66f8]:dhcpv6-client            *:*    users:(("NetworkManager",pid=733,fd=24))
udp   UNCONN 0      0                                *:mdns                     *:*    users:(("io.matter.0",pid=2067,fd=42))
udp   UNCONN 0      0                                *:mdns                     *:*    users:(("io.matter.0",pid=2067,fd=36))
udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=683,fd=13))
udp   UNCONN 0      0                                *:59438                    *:*    users:(("avahi-daemon",pid=683,fd=15))
tcp   LISTEN 0      20                       127.0.0.1:smtp               0.0.0.0:*    users:(("exim4",pid=1148,fd=5))
tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=1201,fd=23))
tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=1201,fd=29))
tcp   LISTEN 0      511                 192.168.178.40:9092               0.0.0.0:*    users:(("io.nuki.0",pid=1564,fd=31))
tcp   LISTEN 0      4096                     127.0.0.1:omniorb            0.0.0.0:*    users:(("influxd",pid=1159,fd=3))
tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=873,fd=6))
tcp   LISTEN 0      511                        0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=1614,fd=40))
tcp   LISTEN 0      511                        0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.1",pid=1597,fd=36))
tcp   LISTEN 0      511                        0.0.0.0:1887               0.0.0.0:*    users:(("io.mqtt.0",pid=1547,fd=35))
tcp   LISTEN 0      511                              *:3001                     *:*    users:(("io.fullybrowser",pid=1446,fd=30))
tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=1782,fd=35))
tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=1223,fd=40))
tcp   LISTEN 0      4096                             *:8086                     *:*    users:(("influxd",pid=1159,fd=19))
tcp   LISTEN 0      511                              *:3500                     *:*    users:(("io.sonos.0",pid=1631,fd=31))
tcp   LISTEN 0      511                              *:53431                    *:*    users:(("io.matter.0",pid=2067,fd=39))
tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=873,fd=7))
tcp   LISTEN 0      20                           [::1]:smtp                  [::]:*    users:(("exim4",pid=1148,fd=6))
2026-10-12 15:48:11.894  - debug: matter.0 (2067) handleChangedAttribute "5": Attribute undefined/0/0x0031/lastConnectErrorValue changed to null
2026-10-12 15:48:11.894  - debug: matter.0 (2067) 2026-10-12 15:48:11.894 INFO ClientEventEmitter Received event threadNetworkDiagnostics.connectionStatus on controller.@1:5 connectionStatus: 0
2026-10-12 15:48:11.899  - debug: matter.0 (2067) handleTriggeredEvent "5": Event undefined/0/0x0035/connectionStatus triggered with [{"eventNumber":"2808","epochTimestamp":12948968900,"priority":1,"data":{"connectionStatus":0}}]
2026-10-12 15:48:12.897  - debug: matter.0 (2067) Send to GUI: {"command":"networkGraphUpdate","networkGraphData":{"nodes":[{"nodeId":"3138025706799876746","name":"KAJPLATS E27 WS G95 clear 806lm","vendorId":"0x117C","productId":"0x9009","deviceType":268,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":6,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"6vnSB9lAYQg=","threadVersion":5,"neighborTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"age":13,"averageRssi":-95,"lastRssi":-95,"lqi":1,"frameErrorRate":55,"messageErrorRate":3,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":0,"averageRssi":-98,"lastRssi":-99,"lqi":0,"frameErrorRate":45,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":19,"averageRssi":-81,"lastRssi":-81,"lqi":2,"frameErrorRate":17,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":10,"averageRssi":-50,"lastRssi":-51,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":9,"averageRssi":-87,"lastRssi":-87,"lqi":2,"frameErrorRate":3,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":35,"pathCost":3,"lqiIn":1,"lqiOut":1,"age":13,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":4096,"routerId":4,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":35,"pathCost":2,"lqiIn":0,"lqiOut":1,"age":0,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":0,"age":32,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":35,"pathCost":1,"lqiIn":0,"lqiOut":0,"age":9,"allocated":true,"linkEstablished":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":40,"pathCost":2,"lqiIn":2,"lqiOut":2,"age":19,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":35,"pathCost":2,"lqiIn":3,"lqiOut":3,"age":10,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":35,"pathCost":1,"lqiIn":2,"lqiOut":1,"age":9,"allocated":true,"linkEstablished":true}]}},{"nodeId":"2","name":"MYGGBETT door/window sensor","vendorId":"0x117C","productId":"0x8007","deviceType":21,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":2,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"umP55va/6bc=","threadVersion":5,"neighborTable":[{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":11,"averageRssi":-9,"lastRssi":-68,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":0,"pathCost":0,"lqiIn":3,"lqiOut":3,"age":11,"allocated":true,"linkEstablished":true}]}},{"nodeId":"4","name":"GRILLPLATS Plug Propeller","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"hht9Z5ki7c4=","threadVersion":4,"neighborTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"age":11,"averageRssi":-87,"lastRssi":-88,"lqi":2,"frameErrorRate":12,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":5,"averageRssi":-58,"lastRssi":-59,"lqi":3,"frameErrorRate":12,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":6,"averageRssi":-91,"lastRssi":-92,"lqi":1,"frameErrorRate":48,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":9,"averageRssi":-92,"lastRssi":-92,"lqi":1,"frameErrorRate":2,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":23,"averageRssi":-88,"lastRssi":-89,"lqi":2,"frameErrorRate":27,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":10,"averageRssi":-82,"lastRssi":-82,"lqi":2,"frameErrorRate":51,"messageErrorRate":2,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":4,"pathCost":2,"lqiIn":2,"lqiOut":3,"age":11,"allocated":true,"linkEstablished":true},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":3,"lqiOut":3,"age":5,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":1,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":62,"pathCost":2,"lqiIn":0,"lqiOut":0,"age":65,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":62,"pathCost":1,"lqiIn":1,"lqiOut":1,"age":9,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":4,"pathCost":2,"lqiIn":2,"lqiOut":2,"age":0,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":35,"pathCost":1,"lqiIn":2,"lqiOut":2,"age":11,"allocated":true,"linkEstablished":true}]}},{"nodeId":"3","name":"GRILLPLATS Plug xmastree","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"0oGHJyEbQx0=","threadVersion":4,"neighborTable":[{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":3,"averageRssi":-93,"lastRssi":-93,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":26,"averageRssi":-70,"lastRssi":-71,"lqi":3,"frameErrorRate":18,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"age":27,"averageRssi":-74,"lastRssi":-74,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":7,"averageRssi":-71,"lastRssi":-73,"lqi":3,"frameErrorRate":5,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":6,"averageRssi":-89,"lastRssi":-89,"lqi":2,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":5,"averageRssi":-68,"lastRssi":-67,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":12,"pathCost":1,"lqiIn":0,"lqiOut":1,"age":168,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":1,"age":3,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":26,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":27,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":32768,"routerId":32,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":62,"pathCost":2,"lqiIn":2,"lqiOut":1,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true}]}},{"nodeId":"5","name":"BILRESA dual button","vendorId":"0x117C","productId":"0x8001","deviceType":15,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":2,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"kvzUg8uUYIM=","threadVersion":5,"neighborTable":[{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":526,"averageRssi":-11,"lastRssi":0,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":0,"pathCost":0,"lqiIn":3,"lqiOut":1,"age":14,"allocated":true,"linkEstablished":true}]}},{"nodeId":"14388134951535934862","name":"GRILLPLATS Flurlicht EG","vendorId":"0x117C","productId":"0x1000","deviceType":266,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"Hmibk4TrSAo=","threadVersion":4,"neighborTable":[{"extAddress":"Ko4I3TGL/Rk=","rloc16":5120,"age":7,"averageRssi":-75,"lastRssi":-75,"lqi":3,"frameErrorRate":14,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ilH89VC5gP0=","rloc16":34816,"age":4,"averageRssi":-93,"lastRssi":-94,"lqi":1,"frameErrorRate":8,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"6vnSB9lAYQg=","rloc16":54272,"age":0,"averageRssi":-89,"lastRssi":-89,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"Ko4I3TGL/Rk=","rloc16":5120,"routerId":5,"nextHop":34,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":7,"allocated":true,"linkEstablished":true},{"extAddress":"AAAAAAAAAAA=","rloc16":18432,"routerId":18,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"ilH89VC5gP0=","rloc16":34816,"routerId":34,"nextHop":5,"pathCost":1,"lqiIn":1,"lqiOut":2,"age":4,"allocated":true,"linkEstablished":true},{"extAddress":"6vnSB9lAYQg=","rloc16":54272,"routerId":53,"nextHop":5,"pathCost":3,"lqiIn":1,"lqiOut":2,"age":0,"allocated":true,"linkEstablished":true}]}},{"nodeId":"905838670972218924","name":"KAJPLATS E14 Pendel 1","vendorId":"0x117C","productId":"0x9006","deviceType":269,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"IrVCRCv+Esw=","threadVersion":5,"neighborTable":[{"extAddress":"umP55va/6bc=","rloc16":35867,"age":5,"averageRssi":-75,"lastRssi":-76,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":false,"fullThreadDevice":false,"fullNetworkData":false,"isChild":true},{"extAddress":"kvzUg8uUYIM=","rloc16":35888,"age":3,"averageRssi":-95,"lastRssi":-94,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":false,"fullThreadDevice":false,"fullNetworkData":false,"isChild":true},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":8,"averageRssi":-86,"lastRssi":-85,"lqi":2,"frameErrorRate":4,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":24,"averageRssi":-87,"lastRssi":-82,"lqi":2,"frameErrorRate":31,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":6,"averageRssi":-68,"lastRssi":-70,"lqi":3,"frameErrorRate":17,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":12,"averageRssi":-88,"lastRssi":-88,"lqi":2,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"chAHb/erIbY=","rloc16":63488,"age":1,"averageRssi":-50,"lastRssi":-51,"lqi":3,"frameErrorRate":6,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":62,"pathCost":2,"lqiIn":0,"lqiOut":0,"age":105,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":32,"pathCost":3,"lqiIn":2,"lqiOut":2,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":62,"pathCost":1,"lqiIn":2,"lqiOut":3,"age":24,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":32,"pathCost":1,"lqiIn":1,"lqiOut":0,"age":6,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":62,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":6,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":4,"pathCost":1,"lqiIn":2,"lqiOut":1,"age":12,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":1,"allocated":true,"linkEstablished":true}]}},{"nodeId":"1","name":"KAJPLATS E14 Pendel 2","vendorId":"0x117C","productId":"0x9006","deviceType":269,"isConnected":true,"networkType":"thread","thread":{"channel":24,"routingRole":5,"extendedPanId":"8Q+2G5LRX9c=","rloc16":null,"extendedAddress":"chAHb/erIbY=","threadVersion":5,"neighborTable":[{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"age":5,"averageRssi":-93,"lastRssi":-93,"lqi":1,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"age":22,"averageRssi":-72,"lastRssi":-72,"lqi":3,"frameErrorRate":7,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"age":8,"averageRssi":-70,"lastRssi":-71,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"age":25,"averageRssi":-52,"lastRssi":-52,"lqi":3,"frameErrorRate":0,"messageErrorRate":0,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"age":17,"averageRssi":-85,"lastRssi":-85,"lqi":2,"frameErrorRate":28,"messageErrorRate":1,"rxOnWhenIdle":true,"fullThreadDevice":true,"fullNetworkData":true,"isChild":false}],"routeTable":[{"extAddress":"LlGSkIdM7xw=","rloc16":1024,"routerId":1,"nextHop":12,"pathCost":1,"lqiIn":0,"lqiOut":0,"age":20,"allocated":true,"linkEstablished":false},{"extAddress":"6vnSB9lAYQg=","rloc16":4096,"routerId":4,"nextHop":35,"pathCost":2,"lqiIn":1,"lqiOut":2,"age":5,"allocated":true,"linkEstablished":true},{"extAddress":"ki4OzbJqcFU=","rloc16":12288,"routerId":12,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":22,"allocated":true,"linkEstablished":true},{"extAddress":"Hmibk4TrSAo=","rloc16":15360,"routerId":15,"nextHop":32,"pathCost":1,"lqiIn":1,"lqiOut":3,"age":27,"allocated":true,"linkEstablished":false},{"extAddress":"0oGHJyEbQx0=","rloc16":32768,"routerId":32,"nextHop":12,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":8,"allocated":true,"linkEstablished":true},{"extAddress":"IrVCRCv+Esw=","rloc16":35840,"routerId":35,"nextHop":32,"pathCost":1,"lqiIn":3,"lqiOut":3,"age":25,"allocated":true,"linkEstablished":true},{"extAddress":"hht9Z5ki7c4=","rloc16":40960,"routerId":40,"nextHop":35,"pathCost":3,"lqiIn":2,"lqiOut":2,"age":17,"allocated":true,"linkEstablished":true},{"extAddress":"chAHb/erIbY=","rloc16":63488,"routerId":62,"nextHop":63,"pathCost":0,"lqiIn":0,"lqiOut":0,"age":0,"allocated":true,"linkEstablished":false}]}}],"timestamp":1791812892897}}
2026-10-12 15:48:50.156  - info: javascript.0 (1299) script.js.Hue_Push_API: missing update instructions for sensors.temperature.temperature_report
2026-10-12 15:48:50.156  - info: javascript.0 (1299) script.js.Hue_Push_API: {"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"},"temperature":{"temperature":38.4,"temperature_report":{"changed":"2026-10-12T13:48:50.117Z","temperature":38.4}}}
2026-10-12 15:50:02.012  - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 2435
2026-10-12 15:50:03.673  - info: dwd.0 (2435) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v24.21.0, js-controller: 7.2.2
2026-10-12 15:50:04.191  - info: dwd.0 (2435) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2026-10-12 15:50:04.711  - info: host.smart instance system.adapter.dwd.0 having pid 2435 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2026-10-12 15:50:12.721  - debug: matter.0 (2067) Received state change for matter.0.controller.14388134951535934862.OnOffPlugInUnit-1.SET: false (ack=false) --&gt; false (triggerUpdate=true)
2026-10-12 15:50:12.722  - debug: matter.0 (2067) Handle change event for power with value false
2026-10-12 15:50:12.723  - debug: matter.0 (2067) 2026-10-12 15:50:12.723 INFO ClientInteraction Invoke » @1:c7acec81beae7d8e•a145⇵1840 1.onOff.off with (no payload)
2026-10-12 15:50:12.778  - debug: matter.0 (2067) 2026-10-12 15:50:12.778 INFO ClientInteraction Invoke « @1:c7acec81beae7d8e•a145⇵1840 1.onOff.off status: Success (0)
2026-10-12 15:50:28.521  - info: javascript.0 (1299) script.js.Hue_Push_API: missing update instructions for sensors.light.light_level_report
2026-10-12 15:50:28.521  - info: javascript.0 (1299) script.js.Hue_Push_API: {"light":{"light_level":45512,"light_level_report":{"changed":"2026-10-12T13:50:28.467Z","light_level":45512}},"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"}}
2026-10-12 15:50:31.529  - info: fullybrowser.0 (1446) 🗸 192.168.178.128: Command screenOff successfully set to true
2026-10-12 15:50:49.405  - info: javascript.0 (1299) script.js.Hue_Push_API: missing update instructions for sensors.motion.motion_report
2026-10-12 15:50:49.406  - info: javascript.0 (1299) script.js.Hue_Push_API: {"motion":{"motion":true,"motion_report":{"changed":"2026-10-12T13:50:49.350Z","motion":true}},"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"}}
2026-10-12 15:50:59.410  - info: javascript.0 (1299) script.js.Hue_Push_API: missing update instructions for sensors.motion.motion_report
2026-10-12 15:50:59.410  - info: javascript.0 (1299) script.js.Hue_Push_API: {"motion":{"motion":false,"motion_report":{"changed":"2026-10-12T13:50:59.350Z","motion":false}},"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"}}
2026-10-12 15:51:01.582  - info: javascript.0 (1299) script.js.Hue_Push_API: missing update instructions for sensors.motion.motion_report
2026-10-12 15:51:01.582  - info: javascript.0 (1299) script.js.Hue_Push_API: {"motion":{"motion":true,"motion_report":{"changed":"2026-10-12T13:51:01.533Z","motion":true}},"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"}}
2026-10-12 15:51:11.581  - info: javascript.0 (1299) script.js.Hue_Push_API: missing update instructions for sensors.motion.motion_report
2026-10-12 15:51:11.581  - info: javascript.0 (1299) script.js.Hue_Push_API: {"motion":{"motion":false,"motion_report":{"changed":"2026-10-12T13:51:11.530Z","motion":false}},"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"}}
</code></pre>
<pre><code></code></pre>
]]></description><link>https://forum.iobroker.net/post/1358511</link><guid isPermaLink="true">https://forum.iobroker.net/post/1358511</guid><dc:creator><![CDATA[darkblu]]></dc:creator><pubDate>Mon, 12 Oct 2026 13:56:16 GMT</pubDate></item></channel></rss>
