admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED
@Thomas-Braun
*** iob diag is starting up, please wait ***
The state system.host.iob.versions.nodeNewestNext was not found!
The state system.host.iob.versions.npmNewestNext was not found!========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Ubuntu 26.04.1 LTS Static hostname: iob Icon name: computer-desktop Chassis: desktop 🖥 Kernel: Linux 7.0.0-34-generic Architecture: x86-64 Hardware Vendor: Lenovo Hardware Model: ThinkCentre M710q Hardware SKU: LENOVO_MT_10MR_BU_LENOVO_FM_ThinkCentre M710q Firmware Version: M1AKT30A Firmware Date: Wed 2018-01-03 Firmware Age: 8y 8month 3w 6d OS is similar to: debian model name : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz Docker : false Virtualization : none Unknown Kernel : x86_64 Userland : 64bit System was installed 626 days ago (on 2025-01-12). Systemuptime and Load: 22:16:39 up 2:20, 1 user, load average: 0.51, 1.55, 2.15 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Ubuntu LTS release codenamed 'resolute'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 22:16:39 CEST Universal time: Wed 2026-09-30 20:16:39 UTC RTC time: Wed 2026-09-30 20:16:39 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iob HOME=/home/iob GROUPS=iob adm cdrom sudo dip plugdev lxd iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 6.7G 7.8G 7.0M 2.0G 9.4G Swap: 4.3G 298M 4.0G Total: 20G 7.0G 11G Active iob-Instances: 54 15363 M total memory 6366 M used memory 1375 M active memory 5713 M inactive memory 7451 M free memory 153 M buffer memory 1732 M swap cache 4095 M total swap 284 M used swap 3811 M free swap *** top - Table Of Processes *** top - 22:16:40 up 2:20, 1 user, load average: 0.51, 1.55, 2.15 Tasks: 235 total, 2 running, 233 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.0 us, 4.1 sy, 0.0 ni, 93.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 15364.0 total, 7453.7 free, 6364.8 used, 1885.8 buff/cache MiB Swap: 4096.0 total, 3811.1 free, 284.9 used. 8999.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * motioneye.service loaded failed failed motionEye Server Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 1.6G 1.5M 1.5G 1% /run efivarfs efivarfs 256K 56K 196K 22% /sys/firmware/efi/efivars /dev/mapper/ubuntu--vg-ubuntu--lv ext4 98G 57G 36G 62% / tmpfs tmpfs 7.6G 4.0K 7.6G 1% /dev/shm none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-resolved.service tmpfs tmpfs 128M 0 128M 0% /mnt/hannah_mem tmpfs tmpfs 7.6G 5.9M 7.5G 1% /tmp /dev/sda2 ext4 2.0G 249M 1.6G 14% /boot /dev/sda1 vfat 1.1G 6.4M 1.1G 1% /boot/efi none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-networkd.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 1.6G 8.0K 1.6G 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Wed Sep 30 19:55:51 2026] Btrfs loaded, zoned=yes, fsverity=yes [Wed Sep 30 19:55:51 2026] EXT4-fs (dm-0): mounted filesystem 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e ro with ordered data mode. Quota mode: none. [Wed Sep 30 19:55:52 2026] systemd[1]: /usr/lib/systemd/system/system-xfs_scrub.slice:15: Support for option CPUAccounting= has been removed and it is ignored [Wed Sep 30 19:55:52 2026] systemd[1]: Created slice system-xfs_scrub.slice - xfs_scrub background service slice. [Wed Sep 30 19:55:52 2026] EXT4-fs (dm-0): re-mounted 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e r/w. [Wed Sep 30 19:55:54 2026] EXT4-fs (sda2): mounted filesystem b861858a-b19e-4131-a0e3-fc3a2d28be18 r/w with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/core24/1643 /dev/loop0 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core24/2124 /dev/loop1 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3579 /dev/loop2 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27710 /dev/loop3 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3613 /dev/loop4 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27738 /dev/loop5 squashfs ro,nodev,relatime,errors=continue,threads=single `-/boot /dev/sda2 ext4 rw,relatime `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 6.9G /var/ 5.6G /var/log 4.0G /var/log/journal/e8a87e3a1d4745f58598c1733b85f896 4.0G /var/log/journal 1.2G /var/lib Archived and active journals take up 3.9G in the file system. /opt/iobroker/backups: 26G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 4.9G /opt/iobroker/iobroker-data/ 3.9G /opt/iobroker/iobroker-data/history 679M /opt/iobroker/iobroker-data/files 217M /opt/iobroker/iobroker-data/backup-objects 106M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 79M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/hannah.admin/build/index.js.map 22M /opt/iobroker/iobroker-data/files/residents.admin/build/index.js.map 22M /opt/iobroker/iobroker-data/files/hannah.admin/build/tab.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307YK6K-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...d3e33719c2d21c-if00-port0 ...d3e33719c2d21c-if00-port0 ✓ Matching ..._UART_D307YK6K-if00-port0 ✗ Not matching *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 22.22.1+dfsg+~cs22.19.15-1ubuntu1 500 500 http://de.archive.ubuntu.com/ubuntu resolute/universe amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: Mini-pc-Master Mini-pc-Master (version: 7.2.2, hostname: Mini-pc-Master, alive, uptime: 1010) Core adapters versions js-controller: 7.2.2 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 11 +-- @iobroker/type-detector@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.type-detector.git#bef8c38d3c7749781fe92aa32da6437d02d453d5) +-- iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#105b168bc40c34d10e98cfb26b885ca9e00c6e69) | +-- nan@2.22.0 (git+ssh://git@github.com/JCMais/nan.git#0ec2eca8b2fd7518affb3945d087e393ad839b7e) +-- iobroker.hoymiles-wifi@0.2.7 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#8260d47b5f69cada23977a45c53a1befb6f585ea) +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946) +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059) +-- iobroker.parcel@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#3c4fb0ea5aa15a0d49a52f2fbd2546a836169fec) +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f) +-- iobroker.spotify-premium@3.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.spotify-premium.git#cbfe89f8f04f2f05913bce18cb5f8b41350d212d) +-- iobroker.statistics@5.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.statistics.git#db6d21fc130c630147ac159785f10eb9b77f68a8) +-- iobroker.vis-materialdesign@0.5.93 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#31b045e7c1ba599cf4005803636593de91334143) Adapter State system.adapter.accuweather.0 : accuweather : Mini-pc-Master - disabled system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : Mini-pc-Master - enabled system.adapter.alexa2.0 : alexa2 : Mini-pc-Master - disabled system.adapter.alias-manager.0 : alias-manager : Mini-pc-Master - disabled + system.adapter.backitup.0 : backitup : Mini-pc-Master - enabled + system.adapter.ble.0 : ble : Mini-pc-Master - enabled system.adapter.chromecast.0 : chromecast : Mini-pc-Master - disabled + system.adapter.cloud.0 : cloud : Mini-pc-Master - enabled + system.adapter.daswetter.0 : daswetter : Mini-pc-Master - enabled + system.adapter.device-reminder.0 : device-reminder : Mini-pc-Master - enabled + system.adapter.device-watcher.0 : device-watcher : Mini-pc-Master - enabled system.adapter.devices.0 : devices : Mini-pc-Master - disabled + system.adapter.discovery.0 : discovery : Mini-pc-Master - enabled system.adapter.dwd.0 : dwd : Mini-pc-Master - enabled + system.adapter.echarts.0 : echarts : Mini-pc-Master - enabled + system.adapter.email.0 : email : Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss.0 : energiefluss : Mini-pc-Master - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : Mini-pc-Master - enabled + system.adapter.fritzdect.0 : fritzdect : Mini-pc-Master - enabled + system.adapter.fullybrowser.0 : fullybrowser : Mini-pc-Master - enabled + system.adapter.hannah.0 : hannah : Mini-pc-Master - enabled + system.adapter.history.0 : history : Mini-pc-Master - enabled system.adapter.hoymiles-wifi.0 : hoymiles-wifi : Mini-pc-Master - disabled system.adapter.ical.0 : ical : Mini-pc-Master - enabled system.adapter.ical.1 : ical : Mini-pc-Master - enabled system.adapter.icons-icons8.0 : icons-icons8 : Mini-pc-Master - disabled system.adapter.icons-material-png.0 : icons-material-png : Mini-pc-Master - disabled system.adapter.icons-material-svg.0 : icons-material-svg : Mini-pc-Master - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : Mini-pc-Master - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Mini-pc-Master - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Mini-pc-Master - disabled + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.info.0 : info : Mini-pc-Master - enabled + system.adapter.iot.0 : iot : Mini-pc-Master - enabled + system.adapter.javascript.0 : javascript : Mini-pc-Master - enabled + system.adapter.linux-control.0 : linux-control : Mini-pc-Master - enabled + system.adapter.logparser.0 : logparser : Mini-pc-Master - enabled system.adapter.matter.0 : matter : Mini-pc-Master - disabled system.adapter.motioneye.0 : motioneye : Mini-pc-Master - disabled + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 system.adapter.mqtt.1 : mqtt : Mini-pc-Master - disabled, port: 1885, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.nina.0 : nina : Mini-pc-Master - enabled + system.adapter.parcel.0 : parcel : Mini-pc-Master - enabled + system.adapter.ping.0 : ping : Mini-pc-Master - enabled system.adapter.radar2.0 : radar2 : Mini-pc-Master - disabled + system.adapter.reolink.0 : reolink : Mini-pc-Master - enabled + system.adapter.reolink.1 : reolink : Mini-pc-Master - enabled + system.adapter.residents.0 : residents : Mini-pc-Master - enabled + system.adapter.rpi2.0 : rpi2 : Mini-pc-Master - enabled system.adapter.rpi2.1 : rpi2 : pi-3 - disabled + system.adapter.sayit.0 : sayit : Mini-pc-Master - enabled system.adapter.sayit.1 : sayit : Mini-pc-Master - disabled + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 system.adapter.smartcontrol.0 : smartcontrol : Mini-pc-Master - disabled + system.adapter.smartmeter.0 : smartmeter : Mini-pc-Master - enabled + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : Mini-pc-Master - enabled system.adapter.spotify-premium.0 : spotify-premium : Mini-pc-Master - disabled + system.adapter.sql.0 : sql : Mini-pc-Master - enabled + system.adapter.statistics.0 : statistics : Mini-pc-Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : Mini-pc-Master - enabled + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : Mini-pc-Master - enabled + system.adapter.tr-064.0 : tr-064 : Mini-pc-Master - enabled + system.adapter.trashschedule.0 : trashschedule : Mini-pc-Master - enabled + system.adapter.tuya.0 : tuya : Mini-pc-Master - enabled + system.adapter.upnp.0 : upnp : Mini-pc-Master - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Mini-pc-Master - disabled system.adapter.vis-2.0 : vis-2 : Mini-pc-Master - disabled system.adapter.vis-bars.0 : vis-bars : Mini-pc-Master - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Mini-pc-Master - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : Mini-pc-Master - disabled system.adapter.vis-history.0 : vis-history : Mini-pc-Master - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Mini-pc-Master - disabled system.adapter.vis-icontwo.0 : vis-icontwo : Mini-pc-Master - disabled system.adapter.vis-inventwo.0 : vis-inventwo : Mini-pc-Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Mini-pc-Master - disabled system.adapter.vis-justgage.0 : vis-justgage : Mini-pc-Master - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : Mini-pc-Master - disabled system.adapter.vis-metro.0 : vis-metro : Mini-pc-Master - disabled system.adapter.vis-players.0 : vis-players : Mini-pc-Master - disabled system.adapter.vis-plumb.0 : vis-plumb : Mini-pc-Master - enabled system.adapter.vis-rgraph.0 : vis-rgraph : Mini-pc-Master - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : Mini-pc-Master - disabled system.adapter.vis.0 : vis : Mini-pc-Master - enabled system.adapter.weatherunderground.0 : weatherunderground : Mini-pc-Master - enabled + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.yr.0 : yr : Mini-pc-Master - enabled + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.accuweather' │ 'accuweather' │ '2.3.0' │ 'none' │ │ 1 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 2 │ 'system.adapter.alarm' │ 'alarm' │ '5.0.1' │ 'none' │ │ 3 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 4 │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0' │ 'none' │ │ 5 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 6 │ 'system.adapter.ble' │ 'ble' │ '0.14.0' │ 'none' │ │ 7 │ 'system.adapter.chromecast' │ 'chromecast' │ '4.2.0' │ 'none' │ │ 8 │ 'system.adapter.cloud' │ 'cloud' │ '6.0.1' │ 'none' │ │ 9 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.9' │ 'none' │ │ 10 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 11 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 12 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 13 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 14 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 15 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 16 │ 'system.adapter.email' │ 'email' │ '3.0.0' │ 'none' │ │ 17 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 18 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 19 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 20 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 21 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 22 │ 'system.adapter.hannah' │ 'hannah' │ '1.5.0' │ 'none' │ │ 23 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 24 │ 'system.adapter.hoymiles-wifi' │ 'hoymiles-wifi' │ '0.2.6' │ 'none' │ │ 25 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 26 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 27 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 28 │ 'system.adapter.icons-material-svg' │ 'icons-material-svg' │ '0.1.0' │ 'none' │ │ 29 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 30 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 31 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3' │ 'none' │ │ 32 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 33 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 34 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 35 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 36 │ 'system.adapter.linux-control' │ 'linux-control' │ '1.1.5' │ 'none' │ │ 37 │ 'system.adapter.logparser' │ 'logparser' │ '2.5.0' │ 'none' │ │ 38 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 39 │ 'system.adapter.motioneye' │ 'motioneye' │ '1.3.1' │ 'none' │ │ 40 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 41 │ 'system.adapter.nina' │ 'nina' │ '0.0.26' │ 'none' │ │ 42 │ 'system.adapter.parcel' │ 'parcel' │ '0.3.3' │ 'none' │ │ 43 │ 'system.adapter.ping' │ 'ping' │ '2.2.4' │ 'none' │ │ 44 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 45 │ 'system.adapter.reolink' │ 'reolink' │ '1.4.2' │ 'none' │ │ 46 │ 'system.adapter.residents' │ 'residents' │ '1.1.1' │ 'none' │ │ 47 │ 'system.adapter.rpi2' │ 'rpi2' │ '2.4.0' │ 'none' │ │ 48 │ 'system.adapter.sayit' │ 'sayit' │ '5.1.0' │ 'none' │ │ 49 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 50 │ 'system.adapter.smartcontrol' │ 'smartcontrol' │ '2.0.1' │ 'none' │ │ 51 │ 'system.adapter.smartmeter' │ 'smartmeter' │ '3.4.0' │ 'none' │ │ 52 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 53 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 54 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 55 │ 'system.adapter.spotify-premium' │ 'spotify-premium' │ '3.0.1' │ 'none' │ │ 56 │ 'system.adapter.sql' │ 'sql' │ '3.0.1' │ 'none' │ │ 57 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 58 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 59 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 60 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 61 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 62 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 63 │ 'system.adapter.tuya' │ 'tuya' │ '3.17.0' │ 'none' │ │ 64 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 65 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 66 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 67 │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1' │ 'none' │ │ 68 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 69 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 70 │ 'system.adapter.vis-fancyswitch' │ 'vis-fancyswitch' │ '1.1.0' │ 'none' │ │ 71 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 72 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 73 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 74 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 75 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 76 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 77 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.93' │ 'none' │ │ 78 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 79 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 80 │ 'system.adapter.vis-plumb' │ 'vis-plumb' │ '1.0.2' │ 'none' │ │ 81 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 82 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 83 │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0' │ 'none' │ │ 84 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 85 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 86 │ 'system.adapter.yr' │ 'yr' │ '5.3.0' │ 'none' │ │ 87 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "accuweather" : 2.3.0 , installed 2.3.0 Adapter "admin" : 8.0.14 , installed 8.0.14 Adapter "alarm" : 5.0.1 , installed 5.0.1 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "chromecast" : 4.2.0 , installed 4.2.0 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.9 , installed 4.5.9 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 3.0.0 , installed 3.0.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "logparser" : 2.5.0 , installed 2.5.0 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "motioneye" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "nina" : 0.0.25 , installed 0.0.26 Adapter "ping" : 3.0.1 , installed 2.2.4 [Updatable] Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "reolink" : 1.4.2 , installed 1.4.2 Adapter "residents" : 1.1.1 , installed 1.1.1 Adapter "rpi2" : 3.0.2 , installed 2.4.0 [Updatable] Adapter "sayit" : 5.1.0 , installed 5.1.0 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "spotify-premium": 3.0.1 , installed 3.0.1 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.93 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 40397 States: 35698 *** OS-Repositories and Updates *** Hit:1 http://de.archive.ubuntu.com/ubuntu resolute InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu resolute-updates InRelease Hit:3 http://de.archive.ubuntu.com/ubuntu resolute-backports InRelease Hit:4 http://security.ubuntu.com/ubuntu resolute-security InRelease Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.122:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=279638,fd=72)) udp UNCONN 0 0 0.0.0.0:coap 0.0.0.0:* users:(("io.shelly.0",pid=279425,fd=36)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=279686,fd=44)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=279686,fd=45)) udp UNCONN 0 0 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=18)) udp UNCONN 0 0 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=16)) udp UNCONN 0 0 192.168.178.122%enp0s31f6:bootpc 0.0.0.0:* users:(("systemd-network",pid=891,fd=37)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=5),("systemd",pid=1,fd=267)) udp UNCONN 0 0 0.0.0.0:42159 0.0.0.0:* users:(("io.upnp.0",pid=280800,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=280800,fd=31)) udp UNCONN 0 0 *:7775 *:* users:(("hannah-proxy",pid=1332,fd=9)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=7),("systemd",pid=1,fd=269)) udp UNCONN 0 0 [fe80::6e4b:90ff:fe46:83a9]%enp0s31f6:dhcpv6-client [::]:* users:(("systemd-network",pid=891,fd=35)) tcp LISTEN 0 4096 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=19)) tcp LISTEN 0 2048 192.168.178.122:http-alt 0.0.0.0:* users:(("python",pid=1043,fd=8)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=1008,fd=3)) tcp LISTEN 0 4096 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=8391,fd=3),("systemd",pid=1,fd=240)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=4),("systemd",pid=1,fd=266)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=276931,fd=29)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=276931,fd=23)) tcp LISTEN 0 511 0.0.0.0:1884 0.0.0.0:* users:(("io.mqtt.0",pid=279163,fd=35)) tcp LISTEN 0 511 0.0.0.0:1887 0.0.0.0:* users:(("io.sonoff.0",pid=279630,fd=40)) tcp LISTEN 0 511 0.0.0.0:1888 0.0.0.0:* users:(("io.mqtt.2",pid=279862,fd=35)) tcp LISTEN 0 511 0.0.0.0:1889 0.0.0.0:* users:(("io.mqtt.2",pid=279862,fd=36)) tcp LISTEN 0 4096 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=17)) tcp LISTEN 0 2048 0.0.0.0:5000 0.0.0.0:* users:(("gunicorn",pid=96468,fd=3),("gunicorn",pid=1377,fd=3),("gunicorn",pid=1334,fd=3)) tcp LISTEN 0 511 192.168.178.122:1882 0.0.0.0:* users:(("io.shelly.1",pid=279500,fd=36)) tcp LISTEN 0 511 *:2323 *:* users:(("io.fullybrowser",pid=278388,fd=30)) tcp LISTEN 0 4096 [::]:ssh [::]:* users:(("sshd",pid=8391,fd=4),("systemd",pid=1,fd=241)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=6),("systemd",pid=1,fd=268)) tcp LISTEN 0 4096 *:50060 *:* users:(("hannah-logcolle",pid=1331,fd=7)) tcp LISTEN 0 4096 *:50051 *:* users:(("python",pid=1335,fd=22)) tcp LISTEN 0 511 *:8083 *:* users:(("io.web.0",pid=280457,fd=35)) tcp LISTEN 0 511 *:8084 *:* users:(("io.socketio.0",pid=280262,fd=34)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=1008,fd=41)) tcp LISTEN 0 511 *:8087 *:* users:(("io.ws.0",pid=280477,fd=34)) *** Log File - Last 25 Lines *** 2026-09-30 22:02:39.808 - warn: reolink.0 (280191) State "reolink.0.Device.Name" has no existing object, this might lead to an error in future versions 2026-09-30 22:02:42.834 - warn: sourceanalytix.0 (280283) This instance has 18273 objects, the limit for this instance is set to 5000. 2026-09-30 22:02:42.844 - error: tuya.0 (279686) Login for MQTT failed: TypeError: Cannot destructure property 'access_token' of 'res.result' as it is undefined. 2026-09-30 22:02:43.222 - error: sourceanalytix.0 (280283) Selected Type Gas does not exist in Price Definitions 2026-09-30 22:02:43.223 - error: sourceanalytix.0 (280283) Please choose proper type for state 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand 2026-09-30 22:02:43.223 - error: sourceanalytix.0 (280283) Or add price definition Gas in adapter settings 2026-09-30 22:02:43.223 - error: sourceanalytix.0 (280283) Cannot handle calculations for 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand, check log messages and adjust settings! 2026-09-30 22:02:43.224 - error: sourceanalytix.0 (280283) Initialization of 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand failed, check warn messages ! 2026-09-30 22:03:15.096 - error: linux-control.0 (280538) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2026-09-30 22:03:31.655 - error: reolink.1 (280975) Error: connect ECONNREFUSED 192.168.178.66:80: ECONNREFUSED 2026-09-30 22:03:41.412 - warn: iot.0 (281542) Your ioBroker IoT license will expire in 4 day(s) on Sat Oct 03 2026. Please renew your license to continue using all features without interruption. 2026-09-30 22:03:53.203 - warn: energiefluss-erweitert.1 (284247) Workspace configuration is NOT password protected! 2026-09-30 22:04:07.119 - error: sourceanalytix.0 (280283) Check settings for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower ! Known valueAtDeviceReset : (176903.80000000016) > known cumulative value (176262.80000000016) cannot proceed 2026-09-30 22:04:07.120 - error: sourceanalytix.0 (280283) Troubleshoot Data mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower custom Data : {"_id":"mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower","common":{"name":"inverter-Solar/Homy-800/ch0/MaxPower","write":true,"read":true,"role":"variable","desc":"mqtt server variable","type":"number","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":176903.80000000016,"start_week":176903.80000000016,"start_month":175416.10000000018,"start_quarter":122587.40000000001,"start_year":10440.599999999997,"alias":"Solar hm-800","consumption":true,"meter_values":true,"costs":true,"selectedPrice":"ElectricityDelivery","valueAtDeviceReset":176903.80000000016,"valueAtDeviceInit":106.4,"cumulativeValue":176903.80000000016}}},"native":{"topic":"inverter-Solar/Homy-800/ch0/MaxPower"},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1787584996560} 2026-09-30 22:04:07.121 - error: sourceanalytix.0 (280283) Cannot handle calculations for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower, check log messages and adjust settings! 2026-09-30 22:04:07.121 - error: sourceanalytix.0 (280283) Initialization of mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower failed, check warn messages ! 2026-09-30 22:04:07.173 - error: sourceanalytix.0 (280283) Check settings for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay ! Known valueAtDeviceReset : (1120.1749999999993) > known cumulative value (1117.1789999999992) cannot proceed 2026-09-30 22:04:07.173 - error: sourceanalytix.0 (280283) Troubleshoot Data sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay custom Data : {"type":"state","common":{"name":"01_currentDay","type":"number","role":"value","read":true,"write":false,"unit":"kWh","def":0,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":1120.1749999999993,"start_week":1110.508999999999,"start_month":1101.817999999999,"start_quarter":995.2539999999998,"start_year":584.993,"alias":"solar","selectedPrice":"ElectricityDelivery","consumption":true,"meter_values":true,"valueAtDeviceReset":1120.1749999999993,"valueAtDeviceInit":0,"cumulativeValue":1120.1749999999993}}},"native":{},"_id":"sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1790798646969} 2026-09-30 22:04:07.173 - error: sourceanalytix.0 (280283) Cannot handle calculations for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay, check log messages and adjust settings! 2026-09-30 22:04:07.174 - error: sourceanalytix.0 (280283) Initialization of sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay failed, check warn messages ! 2026-09-30 22:04:07.180 - warn: sourceanalytix.0 (280283) Cannot handle calculations for 3 of 15 enabled states, check error messages 2026-09-30 22:04:16.523 - error: parcel.0 (284210) https://www.dhl.de/int-aviseanzeigen/advices?width=414 2026-09-30 22:04:16.524 - error: parcel.0 (284210) [Update/fetch] GET https://www.dhl.de/int-aviseanzeigen/advices?width=414 → ERR_BAD_RESPONSE (Request failed with status code 500) 2026-09-30 22:04:16.525 - error: parcel.0 (284210) [Update/fetch] body: [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 22:04:16.525 - error: parcel.0 (284210) [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}]============= Mark until here for C&P =============
iob diag has finished.
Was ist denn:
Haste den admin mal aus dem GitHub gefischt?
Versuch den nochmal zu installieren:
iob upgrade admin@stableoder
iob upgrade admin@8.0.14 -
Nach einem Update des Betriebssystems (Ubuntu) und einem Iob Fix startet der Iobrokerzwar aber ich komme nicht mehr auf die Admin oberfläche
Adaptername: ... js-controller
Link zu Adapterrepository: www.github.com...
Adapterversion: ...7.2.2
js-controller Version: ...7.2.2
Admin Version: ...8.0.14
Hardwaresystem: Mini PC
Arbeitsspeicher: ...16GB
Festplattenart: SSD,
Betriebssystem: Ubuntu 26.04.1 LTSnode -v
Nodejs-Version: ...v22.23.2
NPM-Version: ...10.9.8
Installationsart: Manuell
Image, Docker genutzt: Nein
Ort, Name der Imagedatei: ...
Linux User bitte hier den Output von iob diag einfügen.
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Ubuntu 26.04.1 LTS Static hostname: iob Icon name: computer-desktop Chassis: desktop 🖥 Kernel: Linux 7.0.0-34-generic Architecture: x86-64 Hardware Vendor: Lenovo Hardware Model: ThinkCentre M710q Hardware SKU: LENOVO_MT_10MR_BU_LENOVO_FM_ThinkCentre M710q Firmware Version: M1AKT30A Firmware Date: Wed 2018-01-03 Firmware Age: 8y 8month 3w 6d OS is similar to: debian model name : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz Docker : false Virtualization : none Unknown Kernel : x86_64 Userland : 64bit System was installed 626 days ago (on 2025-01-12). Systemuptime and Load: 21:37:37 up 1:41, 1 user, load average: 1.42, 1.97, 2.34 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Ubuntu LTS release codenamed 'resolute'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 21:37:37 CEST Universal time: Wed 2026-09-30 19:37:37 UTC RTC time: Wed 2026-09-30 19:37:37 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iob HOME=/home/iob GROUPS=iob adm cdrom sudo dip plugdev lxd iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 6.7G 8.3G 2.6M 1.5G 9.4G Swap: 4.3G 101M 4.2G Total: 20G 6.8G 12G Active iob-Instances: 54 15363 M total memory 6379 M used memory 1528 M active memory 5141 M inactive memory 7906 M free memory 33 M buffer memory 1380 M swap cache 4095 M total swap 96 M used swap 3999 M free swap *** top - Table Of Processes *** top - 21:37:38 up 1:41, 1 user, load average: 1.42, 1.97, 2.34 Tasks: 235 total, 1 running, 234 sleeping, 0 stopped, 0 zombie %Cpu(s): 10.0 us, 4.0 sy, 0.0 ni, 82.0 id, 2.0 wa, 0.0 hi, 2.0 si, 0.0 st MiB Mem : 15364.0 total, 7906.3 free, 6379.3 used, 1414.1 buff/cache MiB Swap: 4096.0 total, 3999.4 free, 96.6 used. 8984.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * motioneye.service loaded failed failed motionEye Server Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 1.6G 1.5M 1.5G 1% /run efivarfs efivarfs 256K 56K 196K 22% /sys/firmware/efi/efivars /dev/mapper/ubuntu--vg-ubuntu--lv ext4 98G 57G 36G 62% / tmpfs tmpfs 7.6G 4.0K 7.6G 1% /dev/shm none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-resolved.service tmpfs tmpfs 128M 0 128M 0% /mnt/hannah_mem tmpfs tmpfs 7.6G 3.4M 7.5G 1% /tmp /dev/sda2 ext4 2.0G 249M 1.6G 14% /boot /dev/sda1 vfat 1.1G 6.4M 1.1G 1% /boot/efi none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-networkd.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 1.6G 8.0K 1.6G 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Wed Sep 30 19:55:51 2026] Btrfs loaded, zoned=yes, fsverity=yes [Wed Sep 30 19:55:51 2026] EXT4-fs (dm-0): mounted filesystem 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e ro with ordered data mode. Quota mode: none. [Wed Sep 30 19:55:52 2026] systemd[1]: /usr/lib/systemd/system/system-xfs_scrub.slice:15: Support for option CPUAccounting= has been removed and it is ignored [Wed Sep 30 19:55:52 2026] systemd[1]: Created slice system-xfs_scrub.slice - xfs_scrub background service slice. [Wed Sep 30 19:55:52 2026] EXT4-fs (dm-0): re-mounted 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e r/w. [Wed Sep 30 19:55:54 2026] EXT4-fs (sda2): mounted filesystem b861858a-b19e-4131-a0e3-fc3a2d28be18 r/w with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/core24/1643 /dev/loop0 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core24/2124 /dev/loop1 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3579 /dev/loop2 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27710 /dev/loop3 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3613 /dev/loop4 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27738 /dev/loop5 squashfs ro,nodev,relatime,errors=continue,threads=single `-/boot /dev/sda2 ext4 rw,relatime `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 6.9G /var/ 5.6G /var/log 4.0G /var/log/journal/e8a87e3a1d4745f58598c1733b85f896 4.0G /var/log/journal 1.2G /var/lib Archived and active journals take up 3.9G in the file system. /opt/iobroker/backups: 26G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 4.9G /opt/iobroker/iobroker-data/ 3.9G /opt/iobroker/iobroker-data/history 679M /opt/iobroker/iobroker-data/files 217M /opt/iobroker/iobroker-data/backup-objects 106M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 89M /opt/iobroker/iobroker-data/states.jsonl 73M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/hannah.admin/build/index.js.map 22M /opt/iobroker/iobroker-data/files/residents.admin/build/index.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307YK6K-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...d3e33719c2d21c-if00-port0 ...d3e33719c2d21c-if00-port0 ✓ Matching ..._UART_D307YK6K-if00-port0 ✗ Not matching *** NodeJS-Installation *** /usr/bin/nodejs v22.23.2 /usr/bin/node v22.23.2 /usr/bin/npm 10.9.8 /usr/bin/npx 10.9.8 ✓ Node.js installation is correct nodejs: Installed: 22.23.2-1nodesource1 Candidate: 22.23.2-1nodesource1 Version table: *** 22.23.2-1nodesource1 100 100 /var/lib/dpkg/status 22.22.1+dfsg+~cs22.19.15-1ubuntu1 500 500 http://de.archive.ubuntu.com/ubuntu resolute/universe amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: Mini-pc-Master Mini-pc-Master (version: 7.2.2, hostname: Mini-pc-Master, alive, uptime: 1102) Core adapters versions js-controller: 7.2.2 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 11 +-- @iobroker/type-detector@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.type-detector.git#bef8c38d3c7749781fe92aa32da6437d02d453d5) +-- iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#105b168bc40c34d10e98cfb26b885ca9e00c6e69) | +-- nan@2.22.0 (git+ssh://git@github.com/JCMais/nan.git#0ec2eca8b2fd7518affb3945d087e393ad839b7e) +-- iobroker.hoymiles-wifi@0.2.7 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#8260d47b5f69cada23977a45c53a1befb6f585ea) +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946) +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059) +-- iobroker.parcel@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#3c4fb0ea5aa15a0d49a52f2fbd2546a836169fec) +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f) +-- iobroker.spotify-premium@3.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.spotify-premium.git#cbfe89f8f04f2f05913bce18cb5f8b41350d212d) +-- iobroker.statistics@5.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.statistics.git#db6d21fc130c630147ac159785f10eb9b77f68a8) +-- iobroker.vis-materialdesign@0.5.93 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#31b045e7c1ba599cf4005803636593de91334143) Adapter State system.adapter.accuweather.0 : accuweather : Mini-pc-Master - disabled system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : Mini-pc-Master - enabled system.adapter.alexa2.0 : alexa2 : Mini-pc-Master - disabled system.adapter.alias-manager.0 : alias-manager : Mini-pc-Master - disabled + system.adapter.backitup.0 : backitup : Mini-pc-Master - enabled + system.adapter.ble.0 : ble : Mini-pc-Master - enabled system.adapter.chromecast.0 : chromecast : Mini-pc-Master - disabled + system.adapter.cloud.0 : cloud : Mini-pc-Master - enabled + system.adapter.daswetter.0 : daswetter : Mini-pc-Master - enabled + system.adapter.device-reminder.0 : device-reminder : Mini-pc-Master - enabled + system.adapter.device-watcher.0 : device-watcher : Mini-pc-Master - enabled system.adapter.devices.0 : devices : Mini-pc-Master - disabled + system.adapter.discovery.0 : discovery : Mini-pc-Master - enabled system.adapter.dwd.0 : dwd : Mini-pc-Master - enabled + system.adapter.echarts.0 : echarts : Mini-pc-Master - enabled + system.adapter.email.0 : email : Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss.0 : energiefluss : Mini-pc-Master - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : Mini-pc-Master - enabled + system.adapter.fritzdect.0 : fritzdect : Mini-pc-Master - enabled + system.adapter.fullybrowser.0 : fullybrowser : Mini-pc-Master - enabled + system.adapter.hannah.0 : hannah : Mini-pc-Master - enabled + system.adapter.history.0 : history : Mini-pc-Master - enabled system.adapter.hoymiles-wifi.0 : hoymiles-wifi : Mini-pc-Master - disabled system.adapter.ical.0 : ical : Mini-pc-Master - enabled system.adapter.ical.1 : ical : Mini-pc-Master - enabled system.adapter.icons-icons8.0 : icons-icons8 : Mini-pc-Master - disabled system.adapter.icons-material-png.0 : icons-material-png : Mini-pc-Master - disabled system.adapter.icons-material-svg.0 : icons-material-svg : Mini-pc-Master - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : Mini-pc-Master - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Mini-pc-Master - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Mini-pc-Master - disabled + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.info.0 : info : Mini-pc-Master - enabled + system.adapter.iot.0 : iot : Mini-pc-Master - enabled + system.adapter.javascript.0 : javascript : Mini-pc-Master - enabled + system.adapter.linux-control.0 : linux-control : Mini-pc-Master - enabled + system.adapter.logparser.0 : logparser : Mini-pc-Master - enabled system.adapter.matter.0 : matter : Mini-pc-Master - disabled system.adapter.motioneye.0 : motioneye : Mini-pc-Master - disabled + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 system.adapter.mqtt.1 : mqtt : Mini-pc-Master - disabled, port: 1885, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.nina.0 : nina : Mini-pc-Master - enabled + system.adapter.parcel.0 : parcel : Mini-pc-Master - enabled + system.adapter.ping.0 : ping : Mini-pc-Master - enabled system.adapter.radar2.0 : radar2 : Mini-pc-Master - disabled + system.adapter.reolink.0 : reolink : Mini-pc-Master - enabled + system.adapter.reolink.1 : reolink : Mini-pc-Master - enabled + system.adapter.residents.0 : residents : Mini-pc-Master - enabled + system.adapter.rpi2.0 : rpi2 : Mini-pc-Master - enabled system.adapter.rpi2.1 : rpi2 : pi-3 - disabled + system.adapter.sayit.0 : sayit : Mini-pc-Master - enabled system.adapter.sayit.1 : sayit : Mini-pc-Master - disabled + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 system.adapter.smartcontrol.0 : smartcontrol : Mini-pc-Master - disabled + system.adapter.smartmeter.0 : smartmeter : Mini-pc-Master - enabled + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : Mini-pc-Master - enabled system.adapter.spotify-premium.0 : spotify-premium : Mini-pc-Master - disabled + system.adapter.sql.0 : sql : Mini-pc-Master - enabled + system.adapter.statistics.0 : statistics : Mini-pc-Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : Mini-pc-Master - enabled + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : Mini-pc-Master - enabled + system.adapter.tr-064.0 : tr-064 : Mini-pc-Master - enabled + system.adapter.trashschedule.0 : trashschedule : Mini-pc-Master - enabled + system.adapter.tuya.0 : tuya : Mini-pc-Master - enabled + system.adapter.upnp.0 : upnp : Mini-pc-Master - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Mini-pc-Master - disabled system.adapter.vis-2.0 : vis-2 : Mini-pc-Master - disabled system.adapter.vis-bars.0 : vis-bars : Mini-pc-Master - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Mini-pc-Master - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : Mini-pc-Master - disabled system.adapter.vis-history.0 : vis-history : Mini-pc-Master - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Mini-pc-Master - disabled system.adapter.vis-icontwo.0 : vis-icontwo : Mini-pc-Master - disabled system.adapter.vis-inventwo.0 : vis-inventwo : Mini-pc-Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Mini-pc-Master - disabled system.adapter.vis-justgage.0 : vis-justgage : Mini-pc-Master - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : Mini-pc-Master - disabled system.adapter.vis-metro.0 : vis-metro : Mini-pc-Master - disabled system.adapter.vis-players.0 : vis-players : Mini-pc-Master - disabled system.adapter.vis-plumb.0 : vis-plumb : Mini-pc-Master - enabled system.adapter.vis-rgraph.0 : vis-rgraph : Mini-pc-Master - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : Mini-pc-Master - disabled system.adapter.vis.0 : vis : Mini-pc-Master - enabled system.adapter.weatherunderground.0 : weatherunderground : Mini-pc-Master - enabled + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.yr.0 : yr : Mini-pc-Master - enabled + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.accuweather' │ 'accuweather' │ '2.3.0' │ 'none' │ │ 1 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 2 │ 'system.adapter.alarm' │ 'alarm' │ '5.0.1' │ 'none' │ │ 3 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 4 │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0' │ 'none' │ │ 5 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 6 │ 'system.adapter.ble' │ 'ble' │ '0.14.0' │ 'none' │ │ 7 │ 'system.adapter.chromecast' │ 'chromecast' │ '4.2.0' │ 'none' │ │ 8 │ 'system.adapter.cloud' │ 'cloud' │ '6.0.1' │ 'none' │ │ 9 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.9' │ 'none' │ │ 10 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 11 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 12 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 13 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 14 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 15 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 16 │ 'system.adapter.email' │ 'email' │ '3.0.0' │ 'none' │ │ 17 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 18 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 19 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 20 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 21 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 22 │ 'system.adapter.hannah' │ 'hannah' │ '1.5.0' │ 'none' │ │ 23 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 24 │ 'system.adapter.hoymiles-wifi' │ 'hoymiles-wifi' │ '0.2.6' │ 'none' │ │ 25 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 26 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 27 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 28 │ 'system.adapter.icons-material-svg' │ 'icons-material-svg' │ '0.1.0' │ 'none' │ │ 29 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 30 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 31 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3' │ 'none' │ │ 32 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 33 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 34 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 35 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 36 │ 'system.adapter.linux-control' │ 'linux-control' │ '1.1.5' │ 'none' │ │ 37 │ 'system.adapter.logparser' │ 'logparser' │ '2.5.0' │ 'none' │ │ 38 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 39 │ 'system.adapter.motioneye' │ 'motioneye' │ '1.3.1' │ 'none' │ │ 40 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 41 │ 'system.adapter.nina' │ 'nina' │ '0.0.26' │ 'none' │ │ 42 │ 'system.adapter.parcel' │ 'parcel' │ '0.3.3' │ 'none' │ │ 43 │ 'system.adapter.ping' │ 'ping' │ '2.2.4' │ 'none' │ │ 44 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 45 │ 'system.adapter.reolink' │ 'reolink' │ '1.4.2' │ 'none' │ │ 46 │ 'system.adapter.residents' │ 'residents' │ '1.1.1' │ 'none' │ │ 47 │ 'system.adapter.rpi2' │ 'rpi2' │ '2.4.0' │ 'none' │ │ 48 │ 'system.adapter.sayit' │ 'sayit' │ '5.1.0' │ 'none' │ │ 49 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 50 │ 'system.adapter.smartcontrol' │ 'smartcontrol' │ '2.0.1' │ 'none' │ │ 51 │ 'system.adapter.smartmeter' │ 'smartmeter' │ '3.4.0' │ 'none' │ │ 52 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 53 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 54 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 55 │ 'system.adapter.spotify-premium' │ 'spotify-premium' │ '3.0.1' │ 'none' │ │ 56 │ 'system.adapter.sql' │ 'sql' │ '3.0.1' │ 'none' │ │ 57 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 58 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 59 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 60 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 61 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 62 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 63 │ 'system.adapter.tuya' │ 'tuya' │ '3.17.0' │ 'none' │ │ 64 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 65 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 66 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 67 │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1' │ 'none' │ │ 68 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 69 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 70 │ 'system.adapter.vis-fancyswitch' │ 'vis-fancyswitch' │ '1.1.0' │ 'none' │ │ 71 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 72 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 73 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 74 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 75 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 76 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 77 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.93' │ 'none' │ │ 78 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 79 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 80 │ 'system.adapter.vis-plumb' │ 'vis-plumb' │ '1.0.2' │ 'none' │ │ 81 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 82 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 83 │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0' │ 'none' │ │ 84 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 85 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 86 │ 'system.adapter.yr' │ 'yr' │ '5.3.0' │ 'none' │ │ 87 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "accuweather" : 2.3.0 , installed 2.3.0 Adapter "admin" : 8.0.14 , installed 8.0.14 Adapter "alarm" : 5.0.1 , installed 5.0.1 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "chromecast" : 4.2.0 , installed 4.2.0 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.9 , installed 4.5.9 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 3.0.0 , installed 3.0.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "logparser" : 2.5.0 , installed 2.5.0 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "motioneye" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "nina" : 0.0.25 , installed 0.0.26 Adapter "ping" : 3.0.1 , installed 2.2.4 [Updatable] Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "reolink" : 1.4.2 , installed 1.4.2 Adapter "residents" : 1.1.1 , installed 1.1.1 Adapter "rpi2" : 3.0.2 , installed 2.4.0 [Updatable] Adapter "sayit" : 5.1.0 , installed 5.1.0 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "spotify-premium": 3.0.1 , installed 3.0.1 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.93 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 40397 States: 35698 *** OS-Repositories and Updates *** Hit:1 http://de.archive.ubuntu.com/ubuntu resolute InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu resolute-updates InRelease Hit:3 http://de.archive.ubuntu.com/ubuntu resolute-backports InRelease Hit:4 http://security.ubuntu.com/ubuntu resolute-security InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.122:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=193429,fd=72)) udp UNCONN 0 0 0.0.0.0:coap 0.0.0.0:* users:(("io.shelly.0",pid=193134,fd=36)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=193481,fd=44)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=193481,fd=45)) udp UNCONN 0 0 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=18)) udp UNCONN 0 0 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=16)) udp UNCONN 0 0 192.168.178.122%enp0s31f6:bootpc 0.0.0.0:* users:(("systemd-network",pid=891,fd=37)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=5),("systemd",pid=1,fd=267)) udp UNCONN 0 0 0.0.0.0:57768 0.0.0.0:* users:(("io.upnp.0",pid=195656,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=195656,fd=31)) udp UNCONN 0 0 *:7775 *:* users:(("hannah-proxy",pid=1332,fd=9)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=7),("systemd",pid=1,fd=269)) udp UNCONN 0 0 [fe80::6e4b:90ff:fe46:83a9]%enp0s31f6:dhcpv6-client [::]:* users:(("systemd-network",pid=891,fd=35)) tcp LISTEN 0 4096 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=19)) tcp LISTEN 0 2048 192.168.178.122:http-alt 0.0.0.0:* users:(("python",pid=1043,fd=8)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=1008,fd=3)) tcp LISTEN 0 4096 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=8391,fd=3),("systemd",pid=1,fd=240)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=4),("systemd",pid=1,fd=266)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=191165,fd=29)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=191165,fd=23)) tcp LISTEN 0 511 0.0.0.0:1884 0.0.0.0:* users:(("io.mqtt.0",pid=192946,fd=35)) tcp LISTEN 0 511 0.0.0.0:1887 0.0.0.0:* users:(("io.sonoff.0",pid=193393,fd=40)) tcp LISTEN 0 511 0.0.0.0:1888 0.0.0.0:* users:(("io.mqtt.2",pid=194550,fd=35)) tcp LISTEN 0 511 0.0.0.0:1889 0.0.0.0:* users:(("io.mqtt.2",pid=194550,fd=36)) tcp LISTEN 0 4096 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=17)) tcp LISTEN 0 2048 0.0.0.0:5000 0.0.0.0:* users:(("gunicorn",pid=96468,fd=3),("gunicorn",pid=1377,fd=3),("gunicorn",pid=1334,fd=3)) tcp LISTEN 0 511 192.168.178.122:1882 0.0.0.0:* users:(("io.shelly.1",pid=193266,fd=36)) tcp LISTEN 0 511 *:2323 *:* users:(("io.fullybrowser",pid=192725,fd=30)) tcp LISTEN 0 4096 [::]:ssh [::]:* users:(("sshd",pid=8391,fd=4),("systemd",pid=1,fd=241)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=6),("systemd",pid=1,fd=268)) tcp LISTEN 0 4096 *:50060 *:* users:(("hannah-logcolle",pid=1331,fd=7)) tcp LISTEN 0 4096 *:50051 *:* users:(("python",pid=1335,fd=22)) tcp LISTEN 0 511 *:8083 *:* users:(("io.web.0",pid=195518,fd=35)) tcp LISTEN 0 511 *:8084 *:* users:(("io.socketio.0",pid=195380,fd=34)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=1008,fd=41)) tcp LISTEN 0 511 *:8087 *:* users:(("io.ws.0",pid=195532,fd=34)) *** Log File - Last 25 Lines *** 2026-09-30 21:23:45.278 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.279 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.283 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.285 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.314 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.317 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.322 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.322 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.339 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.340 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:47.101 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:47.179 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:55.041 - error: parcel.0 (196107) https://www.dhl.de/int-aviseanzeigen/advices?width=414 2026-09-30 21:23:55.042 - error: parcel.0 (196107) [Update/fetch] GET https://www.dhl.de/int-aviseanzeigen/advices?width=414 → ERR_BAD_RESPONSE (Request failed with status code 500) 2026-09-30 21:23:55.043 - error: parcel.0 (196107) [Update/fetch] body: [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 21:23:55.043 - error: parcel.0 (196107) [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 21:24:08.787 - error: sourceanalytix.0 (195386) Check settings for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower ! Known valueAtDeviceReset : (176903.80000000016) > known cumulative value (176262.80000000016) cannot proceed 2026-09-30 21:24:08.787 - error: sourceanalytix.0 (195386) Troubleshoot Data mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower custom Data : {"_id":"mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower","common":{"name":"inverter-Solar/Homy-800/ch0/MaxPower","write":true,"read":true,"role":"variable","desc":"mqtt server variable","type":"number","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":176903.80000000016,"start_week":176903.80000000016,"start_month":175416.10000000018,"start_quarter":122587.40000000001,"start_year":10440.599999999997,"alias":"Solar hm-800","consumption":true,"meter_values":true,"costs":true,"selectedPrice":"ElectricityDelivery","valueAtDeviceReset":176903.80000000016,"valueAtDeviceInit":106.4,"cumulativeValue":176903.80000000016}}},"native":{"topic":"inverter-Solar/Homy-800/ch0/MaxPower"},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1787584996560} 2026-09-30 21:24:08.788 - error: sourceanalytix.0 (195386) Cannot handle calculations for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower, check log messages and adjust settings! 2026-09-30 21:24:08.789 - error: sourceanalytix.0 (195386) Initialization of mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower failed, check warn messages ! 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Check settings for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay ! Known valueAtDeviceReset : (1120.1749999999993) > known cumulative value (1117.1789999999992) cannot proceed 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Troubleshoot Data sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay custom Data : {"type":"state","common":{"name":"01_currentDay","type":"number","role":"value","read":true,"write":false,"unit":"kWh","def":0,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":1120.1749999999993,"start_week":1110.508999999999,"start_month":1101.817999999999,"start_quarter":995.2539999999998,"start_year":584.993,"alias":"solar","selectedPrice":"ElectricityDelivery","consumption":true,"meter_values":true,"valueAtDeviceReset":1120.1749999999993,"valueAtDeviceInit":0,"cumulativeValue":1120.1749999999993}}},"native":{},"_id":"sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1790796248575} 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Cannot handle calculations for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay, check log messages and adjust settings! 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Initialization of sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay failed, check warn messages ! 2026-09-30 21:24:08.838 - warn: sourceanalytix.0 (195386) Cannot handle calculations for 3 of 15 enabled states, check error messages============= Mark until here for C&P =============
iob diag has finished.code_text
iob@iob:~$
Admin ist definitiv NICHT via Github installierbar .
Sieht für mich aber danach aus, als wenn das zumindest mal versucht worden ist und da irgendwas kleben geblieben ist.
Ich kenne das Modul auch gar nicht. Auf meinen Systemen ist es jedenfalls nicht installiert, schon gar nicht als git-Installation. -
Was ist denn:
iob upgrade admin@8.0.14@Thomas-Braun
Hab den Admin noch nie über Github installiert.Admin ist auf 8.0.14 und gestartet. Hilft aber auch nicht
@Thomas-Braun
Ausgaben vom drüber installieren?
iob@iob:~$ iob upgrade admin@stable Can not check version information to display upgrade infos: Invalid Version: stable Update admin from @8.0.14 to @stable Could not uninstall npm packet "iobroker.admin": Invalid Version: stable host.Mini-pc-Master Adapter "system.adapter.admin.0" is stopped. NPM version: 11.19.0 Installing iobroker.admin@stable... (System call) removed 1 package in 13s 420 packages are looking for funding run `npm fund` for details Updating objects from io-package.json for adapter "admin" with version "8.0.14" Update "system.adapter.admin.0" upload [41] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/mf-entry-bootstrap-0-5d5a409e.js custom/assets/mf-entry-bootstrap-0-5d5a409e.js application/javascript upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/mf-manifest.json custom/mf-manifest.json application/json upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json upload [3] admin.acode_textdmin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 host.Mini-pc-Master Adapter "system.adapter.admin.0" is started -
@Thomas-Braun
Hier wird dazu das von der KI gefunden:
Der Installationsweg: Wenn Sie – oder ein von Ihnen installiertes Skript/Beta-Update – den Admin-Adapter direkt über GitHub (z. B. den "Katzen"-Button im ioBroker-Admin) installiert haben, lädt ioBroker das gesamte Paket herunter. Node.js registriert dies intern dann unter dem Namen des Quellordners, welcher im GitHub-Repository admin-mono heißt.
@Thomas-Braun
Hatte ich doch gerade gemcht. Sorry falsch verstandeniob@iob:~$ iob upgrade admin@8.0.14 Would you like to reinstall version 8.0.14 of admin now? [(y)es, (n)o]: y Update admin from @8.0.14 to @8.0.14 Uninstall npm packet "iobroker.admin" for a clean re-installation removed 124 packages in 13s 411 packages are looking for funding run `npm fund` for details host.Mini-pc-Master Adapter "system.adapter.admin.0" is stopped. NPM version: 11.19.0 Installing iobroker.admin@8.0.14... (System call) added 124 packages in 20s 422 packages are looking for funding run `npm fund` for details Updating objects from io-package.json for adapter "admin" with version "8.0.14" Update "system.adapter.admin.0" upload [41] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/mf-entry-bootstrap-0-5d5a409e.js custom/assets/mf-entry-bootstrap-0-5d5a409e.js application/javascript upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/mf-manifest.json custom/mf-manifest.json application/json upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 host.Mini-pc-Master Adapter "system.adapter.admin.0" is started -
@Thomas-Braun
Hatte ich doch gerade gemcht. Sorry falsch verstandeniob@iob:~$ iob upgrade admin@8.0.14 Would you like to reinstall version 8.0.14 of admin now? [(y)es, (n)o]: y Update admin from @8.0.14 to @8.0.14 Uninstall npm packet "iobroker.admin" for a clean re-installation removed 124 packages in 13s 411 packages are looking for funding run `npm fund` for details host.Mini-pc-Master Adapter "system.adapter.admin.0" is stopped. NPM version: 11.19.0 Installing iobroker.admin@8.0.14... (System call) added 124 packages in 20s 422 packages are looking for funding run `npm fund` for details Updating objects from io-package.json for adapter "admin" with version "8.0.14" Update "system.adapter.admin.0" upload [41] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/mf-entry-bootstrap-0-5d5a409e.js custom/assets/mf-entry-bootstrap-0-5d5a409e.js application/javascript upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/mf-manifest.json custom/mf-manifest.json application/json upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 host.Mini-pc-Master Adapter "system.adapter.admin.0" is startedUnd dann setzt du jetzt die ganzen aus dem GitHub geangelten Adapter auf die jeweils aktuelle Version aus dem Repo. Damit da bei dem Chaos mal etwas aufgeräumt wird.
Da bin ich jetzt im Terminal etwas über fragt und weiß nicht wie das geht.
Die iobroker weboberfläche läuft ja auch noch nicht. -
Die iobroker weboberfläche läuft ja auch noch nicht.iob repo unset stable iob repo set beta iob update iob upgrade icons-open-icon-library-png@0.1.2 iob upgrade parcel@0.3.3 iob upgrade sourceanalytix@0.6.0 iob upgrade spotify-premium@3.0.1 iob upgrade iobroker.statistics@5.0.0 iob upgrade iobroker.vis-materialdesign@0.5.9 iob repo unset beta iob repo set stable iob updateUnd dann noch mal schauen.
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Ubuntu 26.04.1 LTS Static hostname: iob Icon name: computer-desktop Chassis: desktop 🖥 Kernel: Linux 7.0.0-34-generic Architecture: x86-64 Hardware Vendor: Lenovo Hardware Model: ThinkCentre M710q Hardware SKU: LENOVO_MT_10MR_BU_LENOVO_FM_ThinkCentre M710q Firmware Version: M1AKT30A Firmware Date: Wed 2018-01-03 Firmware Age: 8y 8month 3w 6d OS is similar to: debian model name : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz Docker : false Virtualization : none Unknown Kernel : x86_64 Userland : 64bit System was installed 626 days ago (on 2025-01-12). Systemuptime and Load: 23:50:04 up 3:54, 1 user, load average: 6.77, 3.86, 2.72 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Ubuntu LTS release codenamed 'resolute'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 23:50:04 CEST Universal time: Wed 2026-09-30 21:50:04 UTC RTC time: Wed 2026-09-30 21:50:04 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iob HOME=/home/iob GROUPS=iob adm cdrom sudo dip plugdev lxd iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 9.3G 4.6G 7.1M 2.6G 6.8G Swap: 4.3G 359M 3.9G Total: 20G 9.7G 8.5G Active iob-Instances: 33 15363 M total memory 8889 M used memory 7587 M active memory 2170 M inactive memory 4361 M free memory 277 M buffer memory 2176 M swap cache 4095 M total swap 342 M used swap 3753 M free swap *** top - Table Of Processes *** top - 23:50:04 up 3:54, 1 user, load average: 6.77, 3.86, 2.72 Tasks: 272 total, 5 running, 267 sleeping, 0 stopped, 0 zombie %Cpu(s): 75.5 us, 10.2 sy, 0.0 ni, 12.2 id, 0.0 wa, 0.0 hi, 2.0 si, 0.0 st MiB Mem : 15364.0 total, 4361.0 free, 8889.7 used, 2453.6 buff/cache MiB Swap: 4096.0 total, 3753.4 free, 342.6 used. 6474.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * motioneye.service loaded failed failed motionEye Server Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 1.6G 1.5M 1.5G 1% /run efivarfs efivarfs 256K 56K 196K 22% /sys/firmware/efi/efivars /dev/mapper/ubuntu--vg-ubuntu--lv ext4 98G 58G 36G 62% / tmpfs tmpfs 7.6G 4.0K 7.6G 1% /dev/shm none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-resolved.service tmpfs tmpfs 128M 0 128M 0% /mnt/hannah_mem tmpfs tmpfs 7.6G 6.0M 7.5G 1% /tmp /dev/sda2 ext4 2.0G 249M 1.6G 14% /boot /dev/sda1 vfat 1.1G 6.4M 1.1G 1% /boot/efi none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-networkd.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 1.6G 8.0K 1.6G 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/core24/1643 /dev/loop0 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core24/2124 /dev/loop1 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3579 /dev/loop2 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27710 /dev/loop3 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3613 /dev/loop4 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27738 /dev/loop5 squashfs ro,nodev,relatime,errors=continue,threads=single `-/boot /dev/sda2 ext4 rw,relatime `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 6.9G /var/ 5.6G /var/log 4.0G /var/log/journal/e8a87e3a1d4745f58598c1733b85f896 4.0G /var/log/journal 1.2G /var/lib Archived and active journals take up 3.9G in the file system. /opt/iobroker/backups: 26G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 4.9G /opt/iobroker/iobroker-data/ 3.9G /opt/iobroker/iobroker-data/history 679M /opt/iobroker/iobroker-data/files 217M /opt/iobroker/iobroker-data/backup-objects 106M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 76M /opt/iobroker/iobroker-data/objects.jsonl 37M /opt/iobroker/iobroker-data/states.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/hannah.admin/build/index.js.map 22M /opt/iobroker/iobroker-data/files/residents.admin/build/index.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307YK6K-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...d3e33719c2d21c-if00-port0 ...d3e33719c2d21c-if00-port0 ✓ Matching ..._UART_D307YK6K-if00-port0 ✗ Not matching *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 22.22.1+dfsg+~cs22.19.15-1ubuntu1 500 500 http://de.archive.ubuntu.com/ubuntu resolute/universe amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: Mini-pc-Master Mini-pc-Master (version: 7.2.2, hostname: Mini-pc-Master, alive, uptime: 199) Core adapters versions js-controller: 7.2.2 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 5 +-- @iobroker/type-detector@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.type-detector.git#bef8c38d3c7749781fe92aa32da6437d02d453d5) +-- iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#105b168bc40c34d10e98cfb26b885ca9e00c6e69) | +-- nan@2.22.0 (git+ssh://git@github.com/JCMais/nan.git#0ec2eca8b2fd7518affb3945d087e393ad839b7e) +-- iobroker.hoymiles-wifi@0.2.7 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#8260d47b5f69cada23977a45c53a1befb6f585ea) +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059) Adapter State system.adapter.accuweather.0 : accuweather : Mini-pc-Master - disabled system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : Mini-pc-Master - enabled system.adapter.alexa2.0 : alexa2 : Mini-pc-Master - disabled system.adapter.alias-manager.0 : alias-manager : Mini-pc-Master - disabled + system.adapter.backitup.0 : backitup : Mini-pc-Master - enabled system.adapter.ble.0 : ble : Mini-pc-Master - enabled system.adapter.chromecast.0 : chromecast : Mini-pc-Master - disabled + system.adapter.cloud.0 : cloud : Mini-pc-Master - enabled system.adapter.daswetter.0 : daswetter : Mini-pc-Master - enabled + system.adapter.device-reminder.0 : device-reminder : Mini-pc-Master - enabled + system.adapter.device-watcher.0 : device-watcher : Mini-pc-Master - enabled system.adapter.devices.0 : devices : Mini-pc-Master - disabled + system.adapter.discovery.0 : discovery : Mini-pc-Master - enabled system.adapter.dwd.0 : dwd : Mini-pc-Master - enabled + system.adapter.echarts.0 : echarts : Mini-pc-Master - enabled system.adapter.email.0 : email : Mini-pc-Master - enabled system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Mini-pc-Master - enabled system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss.0 : energiefluss : Mini-pc-Master - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : Mini-pc-Master - enabled + system.adapter.fritzdect.0 : fritzdect : Mini-pc-Master - enabled + system.adapter.fullybrowser.0 : fullybrowser : Mini-pc-Master - enabled system.adapter.hannah.0 : hannah : Mini-pc-Master - enabled + system.adapter.history.0 : history : Mini-pc-Master - enabled system.adapter.hoymiles-wifi.0 : hoymiles-wifi : Mini-pc-Master - disabled system.adapter.ical.0 : ical : Mini-pc-Master - enabled system.adapter.ical.1 : ical : Mini-pc-Master - enabled system.adapter.icons-icons8.0 : icons-icons8 : Mini-pc-Master - disabled system.adapter.icons-material-png.0 : icons-material-png : Mini-pc-Master - disabled system.adapter.icons-material-svg.0 : icons-material-svg : Mini-pc-Master - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : Mini-pc-Master - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Mini-pc-Master - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Mini-pc-Master - disabled + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 system.adapter.info.0 : info : Mini-pc-Master - enabled system.adapter.iot.0 : iot : Mini-pc-Master - enabled + system.adapter.javascript.0 : javascript : Mini-pc-Master - enabled system.adapter.linux-control.0 : linux-control : Mini-pc-Master - enabled + system.adapter.logparser.0 : logparser : Mini-pc-Master - enabled system.adapter.matter.0 : matter : Mini-pc-Master - disabled system.adapter.motioneye.0 : motioneye : Mini-pc-Master - disabled + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 system.adapter.mqtt.1 : mqtt : Mini-pc-Master - disabled, port: 1885, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.nina.0 : nina : Mini-pc-Master - enabled system.adapter.parcel.0 : parcel : Mini-pc-Master - enabled + system.adapter.ping.0 : ping : Mini-pc-Master - enabled system.adapter.radar2.0 : radar2 : Mini-pc-Master - disabled + system.adapter.reolink.0 : reolink : Mini-pc-Master - enabled system.adapter.reolink.1 : reolink : Mini-pc-Master - enabled + system.adapter.residents.0 : residents : Mini-pc-Master - enabled + system.adapter.rpi2.0 : rpi2 : Mini-pc-Master - enabled system.adapter.rpi2.1 : rpi2 : pi-3 - disabled + system.adapter.sayit.0 : sayit : Mini-pc-Master - enabled system.adapter.sayit.1 : sayit : Mini-pc-Master - disabled + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 system.adapter.smartcontrol.0 : smartcontrol : Mini-pc-Master - disabled + system.adapter.smartmeter.0 : smartmeter : Mini-pc-Master - enabled + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : Mini-pc-Master - enabled system.adapter.spotify-premium.0 : spotify-premium : Mini-pc-Master - disabled + system.adapter.sql.0 : sql : Mini-pc-Master - enabled system.adapter.statistics.0 : statistics : Mini-pc-Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : Mini-pc-Master - enabled + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : Mini-pc-Master - enabled + system.adapter.tr-064.0 : tr-064 : Mini-pc-Master - enabled + system.adapter.trashschedule.0 : trashschedule : Mini-pc-Master - enabled + system.adapter.tuya.0 : tuya : Mini-pc-Master - enabled system.adapter.upnp.0 : upnp : Mini-pc-Master - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Mini-pc-Master - disabled system.adapter.vis-2.0 : vis-2 : Mini-pc-Master - disabled system.adapter.vis-bars.0 : vis-bars : Mini-pc-Master - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Mini-pc-Master - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : Mini-pc-Master - disabled system.adapter.vis-history.0 : vis-history : Mini-pc-Master - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Mini-pc-Master - disabled system.adapter.vis-icontwo.0 : vis-icontwo : Mini-pc-Master - disabled system.adapter.vis-inventwo.0 : vis-inventwo : Mini-pc-Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Mini-pc-Master - disabled system.adapter.vis-justgage.0 : vis-justgage : Mini-pc-Master - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : Mini-pc-Master - disabled system.adapter.vis-metro.0 : vis-metro : Mini-pc-Master - disabled system.adapter.vis-players.0 : vis-players : Mini-pc-Master - disabled system.adapter.vis-plumb.0 : vis-plumb : Mini-pc-Master - enabled system.adapter.vis-rgraph.0 : vis-rgraph : Mini-pc-Master - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : Mini-pc-Master - disabled system.adapter.vis.0 : vis : Mini-pc-Master - enabled + system.adapter.weatherunderground.0 : weatherunderground : Mini-pc-Master - enabled + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.yr.0 : yr : Mini-pc-Master - enabled + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.accuweather' │ 'accuweather' │ '2.3.0' │ 'none' │ │ 1 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 2 │ 'system.adapter.alarm' │ 'alarm' │ '5.0.1' │ 'none' │ │ 3 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 4 │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0' │ 'none' │ │ 5 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 6 │ 'system.adapter.ble' │ 'ble' │ '0.14.0' │ 'none' │ │ 7 │ 'system.adapter.chromecast' │ 'chromecast' │ '4.2.0' │ 'none' │ │ 8 │ 'system.adapter.cloud' │ 'cloud' │ '6.0.1' │ 'none' │ │ 9 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.9' │ 'none' │ │ 10 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 11 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 12 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 13 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 14 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 15 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 16 │ 'system.adapter.email' │ 'email' │ '3.0.0' │ 'none' │ │ 17 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 18 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 19 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 20 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 21 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 22 │ 'system.adapter.hannah' │ 'hannah' │ '1.5.0' │ 'none' │ │ 23 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 24 │ 'system.adapter.hoymiles-wifi' │ 'hoymiles-wifi' │ '0.2.6' │ 'none' │ │ 25 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 26 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 27 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 28 │ 'system.adapter.icons-material-svg' │ 'icons-material-svg' │ '0.1.0' │ 'none' │ │ 29 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 30 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 31 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2' │ 'none' │ │ 32 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 33 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 34 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 35 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 36 │ 'system.adapter.linux-control' │ 'linux-control' │ '1.1.5' │ 'none' │ │ 37 │ 'system.adapter.logparser' │ 'logparser' │ '2.5.0' │ 'none' │ │ 38 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 39 │ 'system.adapter.motioneye' │ 'motioneye' │ '1.3.1' │ 'none' │ │ 40 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 41 │ 'system.adapter.nina' │ 'nina' │ '0.0.26' │ 'none' │ │ 42 │ 'system.adapter.parcel' │ 'parcel' │ '0.3.3' │ 'none' │ │ 43 │ 'system.adapter.ping' │ 'ping' │ '2.2.4' │ 'none' │ │ 44 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 45 │ 'system.adapter.reolink' │ 'reolink' │ '1.4.2' │ 'none' │ │ 46 │ 'system.adapter.residents' │ 'residents' │ '1.1.1' │ 'none' │ │ 47 │ 'system.adapter.rpi2' │ 'rpi2' │ '2.4.0' │ 'none' │ │ 48 │ 'system.adapter.sayit' │ 'sayit' │ '5.1.0' │ 'none' │ │ 49 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 50 │ 'system.adapter.smartcontrol' │ 'smartcontrol' │ '2.0.1' │ 'none' │ │ 51 │ 'system.adapter.smartmeter' │ 'smartmeter' │ '3.4.0' │ 'none' │ │ 52 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 53 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 54 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.6.0' │ 'none' │ │ 55 │ 'system.adapter.spotify-premium' │ 'spotify-premium' │ '3.0.1' │ 'none' │ │ 56 │ 'system.adapter.sql' │ 'sql' │ '3.0.1' │ 'none' │ │ 57 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 58 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 59 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 60 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 61 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 62 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 63 │ 'system.adapter.tuya' │ 'tuya' │ '3.17.0' │ 'none' │ │ 64 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 65 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 66 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 67 │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1' │ 'none' │ │ 68 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 69 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 70 │ 'system.adapter.vis-fancyswitch' │ 'vis-fancyswitch' │ '1.1.0' │ 'none' │ │ 71 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 72 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 73 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 74 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 75 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 76 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 77 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.9' │ 'none' │ │ 78 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 79 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 80 │ 'system.adapter.vis-plumb' │ 'vis-plumb' │ '1.0.2' │ 'none' │ │ 81 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 82 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 83 │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0' │ 'none' │ │ 84 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 85 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 86 │ 'system.adapter.yr' │ 'yr' │ '5.3.0' │ 'none' │ │ 87 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "accuweather" : 2.3.0 , installed 2.3.0 Adapter "admin" : 8.0.14 , installed 8.0.14 Adapter "alarm" : 5.0.1 , installed 5.0.1 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "chromecast" : 4.2.0 , installed 4.2.0 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.9 , installed 4.5.9 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 3.0.0 , installed 3.0.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "logparser" : 2.5.0 , installed 2.5.0 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "motioneye" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "nina" : 0.0.25 , installed 0.0.26 Adapter "ping" : 3.0.1 , installed 2.2.4 [Updatable] Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "reolink" : 1.4.2 , installed 1.4.2 Adapter "residents" : 1.1.1 , installed 1.1.1 Adapter "rpi2" : 3.0.2 , installed 2.4.0 [Updatable] Adapter "sayit" : 5.1.0 , installed 5.1.0 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "spotify-premium": 3.0.1 , installed 3.0.1 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 42864 States: 38177 *** OS-Repositories and Updates *** Hit:1 http://security.ubuntu.com/ubuntu resolute-security InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu resolute InRelease Hit:3 https://deb.nodesource.com/node_24.x nodistro InRelease Hit:4 http://de.archive.ubuntu.com/ubuntu resolute-updates InRelease Hit:5 http://de.archive.ubuntu.com/ubuntu resolute-backports InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.122:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=522490,fd=72)) udp UNCONN 0 0 0.0.0.0:coap 0.0.0.0:* users:(("io.shelly.0",pid=522331,fd=36)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=522527,fd=45)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=522527,fd=46)) udp UNCONN 0 0 0.0.0.0:40397 0.0.0.0:* users:(("io.upnp.0",pid=523751,fd=30)) udp UNCONN 0 0 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=18)) udp UNCONN 0 0 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=16)) udp UNCONN 0 0 192.168.178.122%enp0s31f6:bootpc 0.0.0.0:* users:(("systemd-network",pid=891,fd=37)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=5),("systemd",pid=1,fd=267)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=523751,fd=31)) udp UNCONN 0 0 *:7775 *:* users:(("hannah-proxy",pid=1332,fd=9)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=7),("systemd",pid=1,fd=269)) udp UNCONN 0 0 [fe80::6e4b:90ff:fe46:83a9]%enp0s31f6:dhcpv6-client [::]:* users:(("systemd-network",pid=891,fd=35)) tcp LISTEN 0 4096 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=19)) tcp LISTEN 0 2048 192.168.178.122:http-alt 0.0.0.0:* users:(("python",pid=1043,fd=8)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=1008,fd=3)) tcp LISTEN 0 4096 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=8391,fd=3),("systemd",pid=1,fd=236)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=4),("systemd",pid=1,fd=266)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=519763,fd=29)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=519763,fd=23)) tcp LISTEN 0 511 0.0.0.0:1884 0.0.0.0:* users:(("io.mqtt.0",pid=522140,fd=35)) tcp LISTEN 0 511 0.0.0.0:1887 0.0.0.0:* users:(("io.sonoff.0",pid=522465,fd=40)) tcp LISTEN 0 511 0.0.0.0:1888 0.0.0.0:* users:(("io.mqtt.2",pid=522742,fd=35)) tcp LISTEN 0 511 0.0.0.0:1889 0.0.0.0:* users:(("io.mqtt.2",pid=522742,fd=36)) tcp LISTEN 0 4096 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=17)) tcp LISTEN 0 2048 0.0.0.0:5000 0.0.0.0:* users:(("gunicorn",pid=96468,fd=3),("gunicorn",pid=1377,fd=3),("gunicorn",pid=1334,fd=3)) tcp LISTEN 0 511 192.168.178.122:1882 0.0.0.0:* users:(("io.shelly.1",pid=522400,fd=36)) tcp LISTEN 0 511 *:2323 *:* users:(("io.fullybrowser",pid=521262,fd=30)) tcp LISTEN 0 4096 [::]:ssh [::]:* users:(("sshd",pid=8391,fd=4),("systemd",pid=1,fd=237)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=6),("systemd",pid=1,fd=268)) tcp LISTEN 0 4096 *:50060 *:* users:(("hannah-logcolle",pid=1331,fd=7)) tcp LISTEN 0 4096 *:50051 *:* users:(("python",pid=1335,fd=22)) tcp LISTEN 0 511 *:8083 *:* users:(("io.web.0",pid=523259,fd=35)) tcp LISTEN 0 511 *:8084 *:* users:(("io.socketio.0",pid=523055,fd=34)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=1008,fd=41)) tcp LISTEN 0 511 *:8087 *:* users:(("io.ws.0",pid=523341,fd=34)) *** Log File - Last 25 Lines *** 2026-09-30 23:49:28.509 - warn: javascript.0 (520853) at TriggerSteckdose (script.js.common.Weihnacht.Weinacht-Timer2:271:17) 2026-09-30 23:49:28.509 - warn: javascript.0 (520853) at Object.<anonymous> (script.js.common.Weihnacht.Weinacht-Timer2:586:1) 2026-09-30 23:49:28.509 - warn: javascript.0 (520853) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1875:38) 2026-09-30 23:49:28.510 - warn: javascript.0 (520853) at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:889:29) 2026-09-30 23:49:28.510 - warn: javascript.0 (520853) at JavaScript.emit (node:events:514:28) 2026-09-30 23:49:28.510 - warn: javascript.0 (520853) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11162:53) 2026-09-30 23:49:28.510 - warn: javascript.0 (520853) at processImmediate (node:internal/timers:574:21) 2026-09-30 23:49:42.923 - error: reolink.0 (522975) get white led: TypeError: Cannot read properties of undefined (reading 'WhiteLed') 2026-09-30 23:49:44.505 - warn: reolink.0 (522975) State "reolink.0.Device.Name" has no existing object, this might lead to an error in future versions 2026-09-30 23:49:46.979 - error: tuya.0 (522527) Login for MQTT failed: TypeError: Cannot destructure property 'access_token' of 'res.result' as it is undefined. 2026-09-30 23:49:51.284 - warn: sourceanalytix.0 (523099) This instance has 20738 objects, the limit for this instance is set to 5000. 2026-09-30 23:49:53.609 - error: sourceanalytix.0 (523099) Selected Type Gas does not exist in Price Definitions 2026-09-30 23:49:53.609 - error: sourceanalytix.0 (523099) Please choose proper type for state 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand 2026-09-30 23:49:53.611 - error: sourceanalytix.0 (523099) Or add price definition Gas in adapter settings 2026-09-30 23:49:53.611 - error: sourceanalytix.0 (523099) Cannot handle calculations for 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand, check log messages and adjust settings! 2026-09-30 23:49:53.621 - error: sourceanalytix.0 (523099) Initialization of 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand failed, check warn messages ! 2026-09-30 23:50:18.628 - error: linux-control.0 (523505) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2026-09-30 23:50:33.990 - error: reolink.1 (523921) Error: connect ECONNREFUSED 192.168.178.66:80: ECONNREFUSED 2026-09-30 23:50:46.082 - warn: iot.0 (524010) Your ioBroker IoT license will expire in 4 day(s) on Sat Oct 03 2026. Please renew your license to continue using all features without interruption. 2026-09-30 23:51:02.310 - warn: energiefluss-erweitert.1 (526350) Workspace configuration is NOT password protected! 2026-09-30 23:51:08.503 - warn: parcel.0 (525411) Amazon Captcha erkannt. Bitte öffne https://www.amazon.de im Browser auf dem gleichen Gerät/IP, melde dich ab und wieder an um das Captcha zu lösen. Danach den Adapter neu starten. 2026-09-30 23:51:11.050 - error: parcel.0 (525411) https://www.dhl.de/int-aviseanzeigen/advices?width=414 2026-09-30 23:51:11.051 - error: parcel.0 (525411) [Update/fetch] GET https://www.dhl.de/int-aviseanzeigen/advices?width=414 → ERR_BAD_RESPONSE (Request failed with status code 500) 2026-09-30 23:51:11.052 - error: parcel.0 (525411) [Update/fetch] body: [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 23:51:11.052 - error: parcel.0 (525411) [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}]============= Mark until here for C&P =============
iob@iob:~$
@walter.o. Dein admin hört auf dem Port 8082, ist das denn was du im Browser aufrufst?
iob@iob:~$ cd /opt/iobroker/ && npm ls iobroker.inst@3.0.0 /opt/iobroker ├── @iobroker-javascript.0/moment@npm:moment@2.31.0 ├── @iobroker-javascript.0/net-snmp@npm:net-snmp@3.29.1 ├── @iobroker-javascript.0/ping@npm:ping@1.0.0 ├── @iobroker-javascript.0/response@npm:response@0.18.0 ├── @iobroker-javascript.0/string-pixel-width@npm:string-pixel-width@1.11.0 ├── @iobroker-javascript.0/suncalc@npm:suncalc@2.0.2 ├── @iobroker/type-detector@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.type-detector.git#bef8c38d3c7749781fe92aa32da6437d02d453d5) ├── cache@ extraneous ├── iobroker.accuweather@2.3.0 ├── iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#105b168bc40c34d10e98cfb26b885ca9e00c6e69) ├── iobroker.admin@8.0.14 ├── iobroker.alarm@5.0.1 ├── iobroker.alexa2@3.28.3 ├── iobroker.alias-manager@2.1.0 ├── iobroker.backitup@4.0.3 ├── iobroker.ble@0.14.0 ├── iobroker.chromecast@4.2.0 ├── iobroker.cloud@6.0.1 ├── iobroker.daswetter@4.5.9 ├── iobroker.device-reminder@3.1.2 ├── iobroker.device-watcher@2.15.17 ├── iobroker.devices@1.2.14 ├── iobroker.discovery@5.0.0 ├── iobroker.dwd@2.8.5 ├── iobroker.echarts@3.1.0 ├── iobroker.email@3.0.0 ├── iobroker.energiefluss-erweitert@0.8.1 ├── iobroker.energiefluss@3.6.2 ├── iobroker.fb-checkpresence@1.4.2 ├── iobroker.fritzdect@2.6.2 ├── iobroker.fullybrowser@3.1.2 ├── iobroker.hannah@1.5.0 ├── iobroker.history@4.0.0 ├── iobroker.hoymiles-wifi@0.2.7 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#8260d47b5f69cada23977a45c53a1befb6f585ea) ├── iobroker.ical@1.21.0 ├── iobroker.icons-icons8@0.0.1 ├── iobroker.icons-material-png@0.1.0 ├── iobroker.icons-material-svg@0.1.0 ├── iobroker.icons-mfd-png@1.2.1 ├── iobroker.icons-mfd-svg@1.2.0 ├── iobroker.icons-open-icon-library-png@0.1.2 ├── iobroker.influxdb@4.0.2 ├── iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059) ├── iobroker.iot@6.0.3 ├── iobroker.javascript@10.1.3 ├── iobroker.js-controller@7.2.2 ├── iobroker.linux-control@1.1.5 ├── iobroker.logparser@2.5.0 ├── iobroker.matter@1.3.1 ├── iobroker.motioneye@1.3.1 ├── iobroker.mqtt@6.1.4 ├── iobroker.nina@0.0.26 ├── iobroker.parcel@0.3.3 ├── iobroker.ping@2.2.4 ├── iobroker.radar2@2.4.0 ├── iobroker.reolink@1.4.2 ├── iobroker.residents@1.1.1 ├── iobroker.rpi2@2.4.0 ├── iobroker.sayit@5.1.0 ├── iobroker.shelly@10.6.1 ├── iobroker.smartcontrol@2.0.1 ├── iobroker.smartmeter@3.4.0 ├── iobroker.socketio@7.1.3 ├── iobroker.sonoff@3.3.0 ├── iobroker.sourceanalytix@0.6.0 ├── iobroker.spotify-premium@3.0.1 ├── iobroker.sql@3.0.1 ├── iobroker.statistics@5.0.0 ├── iobroker.tankerkoenig@3.4.0 ├── iobroker.telegram@5.0.5 ├── iobroker.text2command@4.0.0 ├── iobroker.tr-064@4.3.0 ├── iobroker.trashschedule@5.3.0 ├── iobroker.tuya@3.17.0 ├── iobroker.upnp@1.1.0 ├── iobroker.vis-2-widgets-material@1.6.1 ├── iobroker.vis-2@2.13.8 ├── iobroker.vis-bars@0.1.4 ├── iobroker.vis-canvas-gauges@1.0.1 ├── iobroker.vis-fancyswitch@1.1.0 ├── iobroker.vis-history@1.0.0 ├── iobroker.vis-hqwidgets@1.6.1 ├── iobroker.vis-icontwo@2.11.6 ├── iobroker.vis-inventwo@4.1.1 ├── iobroker.vis-jqui-mfd@1.1.3 ├── iobroker.vis-justgage@2.1.7 ├── iobroker.vis-materialdesign@0.5.9 ├── iobroker.vis-metro@1.2.0 ├── iobroker.vis-players@0.1.6 ├── iobroker.vis-plumb@1.0.2 ├── iobroker.vis-rgraph@0.0.2 ├── iobroker.vis-timeandweather@1.2.2 ├── iobroker.vis@1.5.6 ├── iobroker.weatherunderground@3.7.0 ├── iobroker.web@8.0.0 ├── iobroker.ws@4.1.0 ├── iobroker.yr@5.3.0 └── iobroker.zigbee@3.5.5 iob@iob:/opt/iobroker$ -
iob@iob:~$ cd /opt/iobroker/ && npm ls iobroker.inst@3.0.0 /opt/iobroker ├── @iobroker-javascript.0/moment@npm:moment@2.31.0 ├── @iobroker-javascript.0/net-snmp@npm:net-snmp@3.29.1 ├── @iobroker-javascript.0/ping@npm:ping@1.0.0 ├── @iobroker-javascript.0/response@npm:response@0.18.0 ├── @iobroker-javascript.0/string-pixel-width@npm:string-pixel-width@1.11.0 ├── @iobroker-javascript.0/suncalc@npm:suncalc@2.0.2 ├── @iobroker/type-detector@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.type-detector.git#bef8c38d3c7749781fe92aa32da6437d02d453d5) ├── cache@ extraneous ├── iobroker.accuweather@2.3.0 ├── iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#105b168bc40c34d10e98cfb26b885ca9e00c6e69) ├── iobroker.admin@8.0.14 ├── iobroker.alarm@5.0.1 ├── iobroker.alexa2@3.28.3 ├── iobroker.alias-manager@2.1.0 ├── iobroker.backitup@4.0.3 ├── iobroker.ble@0.14.0 ├── iobroker.chromecast@4.2.0 ├── iobroker.cloud@6.0.1 ├── iobroker.daswetter@4.5.9 ├── iobroker.device-reminder@3.1.2 ├── iobroker.device-watcher@2.15.17 ├── iobroker.devices@1.2.14 ├── iobroker.discovery@5.0.0 ├── iobroker.dwd@2.8.5 ├── iobroker.echarts@3.1.0 ├── iobroker.email@3.0.0 ├── iobroker.energiefluss-erweitert@0.8.1 ├── iobroker.energiefluss@3.6.2 ├── iobroker.fb-checkpresence@1.4.2 ├── iobroker.fritzdect@2.6.2 ├── iobroker.fullybrowser@3.1.2 ├── iobroker.hannah@1.5.0 ├── iobroker.history@4.0.0 ├── iobroker.hoymiles-wifi@0.2.7 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#8260d47b5f69cada23977a45c53a1befb6f585ea) ├── iobroker.ical@1.21.0 ├── iobroker.icons-icons8@0.0.1 ├── iobroker.icons-material-png@0.1.0 ├── iobroker.icons-material-svg@0.1.0 ├── iobroker.icons-mfd-png@1.2.1 ├── iobroker.icons-mfd-svg@1.2.0 ├── iobroker.icons-open-icon-library-png@0.1.2 ├── iobroker.influxdb@4.0.2 ├── iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059) ├── iobroker.iot@6.0.3 ├── iobroker.javascript@10.1.3 ├── iobroker.js-controller@7.2.2 ├── iobroker.linux-control@1.1.5 ├── iobroker.logparser@2.5.0 ├── iobroker.matter@1.3.1 ├── iobroker.motioneye@1.3.1 ├── iobroker.mqtt@6.1.4 ├── iobroker.nina@0.0.26 ├── iobroker.parcel@0.3.3 ├── iobroker.ping@2.2.4 ├── iobroker.radar2@2.4.0 ├── iobroker.reolink@1.4.2 ├── iobroker.residents@1.1.1 ├── iobroker.rpi2@2.4.0 ├── iobroker.sayit@5.1.0 ├── iobroker.shelly@10.6.1 ├── iobroker.smartcontrol@2.0.1 ├── iobroker.smartmeter@3.4.0 ├── iobroker.socketio@7.1.3 ├── iobroker.sonoff@3.3.0 ├── iobroker.sourceanalytix@0.6.0 ├── iobroker.spotify-premium@3.0.1 ├── iobroker.sql@3.0.1 ├── iobroker.statistics@5.0.0 ├── iobroker.tankerkoenig@3.4.0 ├── iobroker.telegram@5.0.5 ├── iobroker.text2command@4.0.0 ├── iobroker.tr-064@4.3.0 ├── iobroker.trashschedule@5.3.0 ├── iobroker.tuya@3.17.0 ├── iobroker.upnp@1.1.0 ├── iobroker.vis-2-widgets-material@1.6.1 ├── iobroker.vis-2@2.13.8 ├── iobroker.vis-bars@0.1.4 ├── iobroker.vis-canvas-gauges@1.0.1 ├── iobroker.vis-fancyswitch@1.1.0 ├── iobroker.vis-history@1.0.0 ├── iobroker.vis-hqwidgets@1.6.1 ├── iobroker.vis-icontwo@2.11.6 ├── iobroker.vis-inventwo@4.1.1 ├── iobroker.vis-jqui-mfd@1.1.3 ├── iobroker.vis-justgage@2.1.7 ├── iobroker.vis-materialdesign@0.5.9 ├── iobroker.vis-metro@1.2.0 ├── iobroker.vis-players@0.1.6 ├── iobroker.vis-plumb@1.0.2 ├── iobroker.vis-rgraph@0.0.2 ├── iobroker.vis-timeandweather@1.2.2 ├── iobroker.vis@1.5.6 ├── iobroker.weatherunderground@3.7.0 ├── iobroker.web@8.0.0 ├── iobroker.ws@4.1.0 ├── iobroker.yr@5.3.0 └── iobroker.zigbee@3.5.5 iob@iob:/opt/iobroker$Alles was nicht mit 'iobroker.' anfängt gehört da imho nicht hin.
Ich würde es rauskicken.
Und
iobroker.admin-mono
iobroker.info
auch. -
