admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED
Nach einem Update des Betriebssystems (Ubuntu) und einem Iob Fix startet der Iobrokerzwar aber ich komme nicht mehr auf die Admin oberfläche
Adaptername: ... js-controller
Link zu Adapterrepository: www.github.com...
Adapterversion: ...7.2.2
js-controller Version: ...7.2.2
Admin Version: ...8.0.14
Hardwaresystem: Mini PC
Arbeitsspeicher: ...16GB
Festplattenart: SSD,
Betriebssystem: Ubuntu 26.04.1 LTSnode -v
Nodejs-Version: ...v22.23.2
NPM-Version: ...10.9.8
Installationsart: Manuell
Image, Docker genutzt: Nein
Ort, Name der Imagedatei: ...
Linux User bitte hier den Output von iob diag einfügen.
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Ubuntu 26.04.1 LTS Static hostname: iob Icon name: computer-desktop Chassis: desktop 🖥 Kernel: Linux 7.0.0-34-generic Architecture: x86-64 Hardware Vendor: Lenovo Hardware Model: ThinkCentre M710q Hardware SKU: LENOVO_MT_10MR_BU_LENOVO_FM_ThinkCentre M710q Firmware Version: M1AKT30A Firmware Date: Wed 2018-01-03 Firmware Age: 8y 8month 3w 6d OS is similar to: debian model name : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz Docker : false Virtualization : none Unknown Kernel : x86_64 Userland : 64bit System was installed 626 days ago (on 2025-01-12). Systemuptime and Load: 21:37:37 up 1:41, 1 user, load average: 1.42, 1.97, 2.34 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Ubuntu LTS release codenamed 'resolute'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 21:37:37 CEST Universal time: Wed 2026-09-30 19:37:37 UTC RTC time: Wed 2026-09-30 19:37:37 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iob HOME=/home/iob GROUPS=iob adm cdrom sudo dip plugdev lxd iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 6.7G 8.3G 2.6M 1.5G 9.4G Swap: 4.3G 101M 4.2G Total: 20G 6.8G 12G Active iob-Instances: 54 15363 M total memory 6379 M used memory 1528 M active memory 5141 M inactive memory 7906 M free memory 33 M buffer memory 1380 M swap cache 4095 M total swap 96 M used swap 3999 M free swap *** top - Table Of Processes *** top - 21:37:38 up 1:41, 1 user, load average: 1.42, 1.97, 2.34 Tasks: 235 total, 1 running, 234 sleeping, 0 stopped, 0 zombie %Cpu(s): 10.0 us, 4.0 sy, 0.0 ni, 82.0 id, 2.0 wa, 0.0 hi, 2.0 si, 0.0 st MiB Mem : 15364.0 total, 7906.3 free, 6379.3 used, 1414.1 buff/cache MiB Swap: 4096.0 total, 3999.4 free, 96.6 used. 8984.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * motioneye.service loaded failed failed motionEye Server Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 1.6G 1.5M 1.5G 1% /run efivarfs efivarfs 256K 56K 196K 22% /sys/firmware/efi/efivars /dev/mapper/ubuntu--vg-ubuntu--lv ext4 98G 57G 36G 62% / tmpfs tmpfs 7.6G 4.0K 7.6G 1% /dev/shm none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-resolved.service tmpfs tmpfs 128M 0 128M 0% /mnt/hannah_mem tmpfs tmpfs 7.6G 3.4M 7.5G 1% /tmp /dev/sda2 ext4 2.0G 249M 1.6G 14% /boot /dev/sda1 vfat 1.1G 6.4M 1.1G 1% /boot/efi none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-networkd.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 1.6G 8.0K 1.6G 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Wed Sep 30 19:55:51 2026] Btrfs loaded, zoned=yes, fsverity=yes [Wed Sep 30 19:55:51 2026] EXT4-fs (dm-0): mounted filesystem 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e ro with ordered data mode. Quota mode: none. [Wed Sep 30 19:55:52 2026] systemd[1]: /usr/lib/systemd/system/system-xfs_scrub.slice:15: Support for option CPUAccounting= has been removed and it is ignored [Wed Sep 30 19:55:52 2026] systemd[1]: Created slice system-xfs_scrub.slice - xfs_scrub background service slice. [Wed Sep 30 19:55:52 2026] EXT4-fs (dm-0): re-mounted 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e r/w. [Wed Sep 30 19:55:54 2026] EXT4-fs (sda2): mounted filesystem b861858a-b19e-4131-a0e3-fc3a2d28be18 r/w with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/core24/1643 /dev/loop0 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core24/2124 /dev/loop1 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3579 /dev/loop2 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27710 /dev/loop3 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3613 /dev/loop4 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27738 /dev/loop5 squashfs ro,nodev,relatime,errors=continue,threads=single `-/boot /dev/sda2 ext4 rw,relatime `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 6.9G /var/ 5.6G /var/log 4.0G /var/log/journal/e8a87e3a1d4745f58598c1733b85f896 4.0G /var/log/journal 1.2G /var/lib Archived and active journals take up 3.9G in the file system. /opt/iobroker/backups: 26G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 4.9G /opt/iobroker/iobroker-data/ 3.9G /opt/iobroker/iobroker-data/history 679M /opt/iobroker/iobroker-data/files 217M /opt/iobroker/iobroker-data/backup-objects 106M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 89M /opt/iobroker/iobroker-data/states.jsonl 73M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/hannah.admin/build/index.js.map 22M /opt/iobroker/iobroker-data/files/residents.admin/build/index.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307YK6K-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...d3e33719c2d21c-if00-port0 ...d3e33719c2d21c-if00-port0 ✓ Matching ..._UART_D307YK6K-if00-port0 ✗ Not matching *** NodeJS-Installation *** /usr/bin/nodejs v22.23.2 /usr/bin/node v22.23.2 /usr/bin/npm 10.9.8 /usr/bin/npx 10.9.8 ✓ Node.js installation is correct nodejs: Installed: 22.23.2-1nodesource1 Candidate: 22.23.2-1nodesource1 Version table: *** 22.23.2-1nodesource1 100 100 /var/lib/dpkg/status 22.22.1+dfsg+~cs22.19.15-1ubuntu1 500 500 http://de.archive.ubuntu.com/ubuntu resolute/universe amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: Mini-pc-Master Mini-pc-Master (version: 7.2.2, hostname: Mini-pc-Master, alive, uptime: 1102) Core adapters versions js-controller: 7.2.2 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 11 +-- @iobroker/type-detector@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.type-detector.git#bef8c38d3c7749781fe92aa32da6437d02d453d5) +-- iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#105b168bc40c34d10e98cfb26b885ca9e00c6e69) | +-- nan@2.22.0 (git+ssh://git@github.com/JCMais/nan.git#0ec2eca8b2fd7518affb3945d087e393ad839b7e) +-- iobroker.hoymiles-wifi@0.2.7 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#8260d47b5f69cada23977a45c53a1befb6f585ea) +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946) +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059) +-- iobroker.parcel@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#3c4fb0ea5aa15a0d49a52f2fbd2546a836169fec) +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f) +-- iobroker.spotify-premium@3.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.spotify-premium.git#cbfe89f8f04f2f05913bce18cb5f8b41350d212d) +-- iobroker.statistics@5.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.statistics.git#db6d21fc130c630147ac159785f10eb9b77f68a8) +-- iobroker.vis-materialdesign@0.5.93 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#31b045e7c1ba599cf4005803636593de91334143) Adapter State system.adapter.accuweather.0 : accuweather : Mini-pc-Master - disabled system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : Mini-pc-Master - enabled system.adapter.alexa2.0 : alexa2 : Mini-pc-Master - disabled system.adapter.alias-manager.0 : alias-manager : Mini-pc-Master - disabled + system.adapter.backitup.0 : backitup : Mini-pc-Master - enabled + system.adapter.ble.0 : ble : Mini-pc-Master - enabled system.adapter.chromecast.0 : chromecast : Mini-pc-Master - disabled + system.adapter.cloud.0 : cloud : Mini-pc-Master - enabled + system.adapter.daswetter.0 : daswetter : Mini-pc-Master - enabled + system.adapter.device-reminder.0 : device-reminder : Mini-pc-Master - enabled + system.adapter.device-watcher.0 : device-watcher : Mini-pc-Master - enabled system.adapter.devices.0 : devices : Mini-pc-Master - disabled + system.adapter.discovery.0 : discovery : Mini-pc-Master - enabled system.adapter.dwd.0 : dwd : Mini-pc-Master - enabled + system.adapter.echarts.0 : echarts : Mini-pc-Master - enabled + system.adapter.email.0 : email : Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss.0 : energiefluss : Mini-pc-Master - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : Mini-pc-Master - enabled + system.adapter.fritzdect.0 : fritzdect : Mini-pc-Master - enabled + system.adapter.fullybrowser.0 : fullybrowser : Mini-pc-Master - enabled + system.adapter.hannah.0 : hannah : Mini-pc-Master - enabled + system.adapter.history.0 : history : Mini-pc-Master - enabled system.adapter.hoymiles-wifi.0 : hoymiles-wifi : Mini-pc-Master - disabled system.adapter.ical.0 : ical : Mini-pc-Master - enabled system.adapter.ical.1 : ical : Mini-pc-Master - enabled system.adapter.icons-icons8.0 : icons-icons8 : Mini-pc-Master - disabled system.adapter.icons-material-png.0 : icons-material-png : Mini-pc-Master - disabled system.adapter.icons-material-svg.0 : icons-material-svg : Mini-pc-Master - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : Mini-pc-Master - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Mini-pc-Master - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Mini-pc-Master - disabled + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.info.0 : info : Mini-pc-Master - enabled + system.adapter.iot.0 : iot : Mini-pc-Master - enabled + system.adapter.javascript.0 : javascript : Mini-pc-Master - enabled + system.adapter.linux-control.0 : linux-control : Mini-pc-Master - enabled + system.adapter.logparser.0 : logparser : Mini-pc-Master - enabled system.adapter.matter.0 : matter : Mini-pc-Master - disabled system.adapter.motioneye.0 : motioneye : Mini-pc-Master - disabled + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 system.adapter.mqtt.1 : mqtt : Mini-pc-Master - disabled, port: 1885, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.nina.0 : nina : Mini-pc-Master - enabled + system.adapter.parcel.0 : parcel : Mini-pc-Master - enabled + system.adapter.ping.0 : ping : Mini-pc-Master - enabled system.adapter.radar2.0 : radar2 : Mini-pc-Master - disabled + system.adapter.reolink.0 : reolink : Mini-pc-Master - enabled + system.adapter.reolink.1 : reolink : Mini-pc-Master - enabled + system.adapter.residents.0 : residents : Mini-pc-Master - enabled + system.adapter.rpi2.0 : rpi2 : Mini-pc-Master - enabled system.adapter.rpi2.1 : rpi2 : pi-3 - disabled + system.adapter.sayit.0 : sayit : Mini-pc-Master - enabled system.adapter.sayit.1 : sayit : Mini-pc-Master - disabled + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 system.adapter.smartcontrol.0 : smartcontrol : Mini-pc-Master - disabled + system.adapter.smartmeter.0 : smartmeter : Mini-pc-Master - enabled + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : Mini-pc-Master - enabled system.adapter.spotify-premium.0 : spotify-premium : Mini-pc-Master - disabled + system.adapter.sql.0 : sql : Mini-pc-Master - enabled + system.adapter.statistics.0 : statistics : Mini-pc-Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : Mini-pc-Master - enabled + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : Mini-pc-Master - enabled + system.adapter.tr-064.0 : tr-064 : Mini-pc-Master - enabled + system.adapter.trashschedule.0 : trashschedule : Mini-pc-Master - enabled + system.adapter.tuya.0 : tuya : Mini-pc-Master - enabled + system.adapter.upnp.0 : upnp : Mini-pc-Master - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Mini-pc-Master - disabled system.adapter.vis-2.0 : vis-2 : Mini-pc-Master - disabled system.adapter.vis-bars.0 : vis-bars : Mini-pc-Master - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Mini-pc-Master - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : Mini-pc-Master - disabled system.adapter.vis-history.0 : vis-history : Mini-pc-Master - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Mini-pc-Master - disabled system.adapter.vis-icontwo.0 : vis-icontwo : Mini-pc-Master - disabled system.adapter.vis-inventwo.0 : vis-inventwo : Mini-pc-Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Mini-pc-Master - disabled system.adapter.vis-justgage.0 : vis-justgage : Mini-pc-Master - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : Mini-pc-Master - disabled system.adapter.vis-metro.0 : vis-metro : Mini-pc-Master - disabled system.adapter.vis-players.0 : vis-players : Mini-pc-Master - disabled system.adapter.vis-plumb.0 : vis-plumb : Mini-pc-Master - enabled system.adapter.vis-rgraph.0 : vis-rgraph : Mini-pc-Master - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : Mini-pc-Master - disabled system.adapter.vis.0 : vis : Mini-pc-Master - enabled system.adapter.weatherunderground.0 : weatherunderground : Mini-pc-Master - enabled + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.yr.0 : yr : Mini-pc-Master - enabled + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.accuweather' │ 'accuweather' │ '2.3.0' │ 'none' │ │ 1 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 2 │ 'system.adapter.alarm' │ 'alarm' │ '5.0.1' │ 'none' │ │ 3 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 4 │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0' │ 'none' │ │ 5 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 6 │ 'system.adapter.ble' │ 'ble' │ '0.14.0' │ 'none' │ │ 7 │ 'system.adapter.chromecast' │ 'chromecast' │ '4.2.0' │ 'none' │ │ 8 │ 'system.adapter.cloud' │ 'cloud' │ '6.0.1' │ 'none' │ │ 9 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.9' │ 'none' │ │ 10 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 11 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 12 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 13 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 14 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 15 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 16 │ 'system.adapter.email' │ 'email' │ '3.0.0' │ 'none' │ │ 17 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 18 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 19 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 20 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 21 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 22 │ 'system.adapter.hannah' │ 'hannah' │ '1.5.0' │ 'none' │ │ 23 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 24 │ 'system.adapter.hoymiles-wifi' │ 'hoymiles-wifi' │ '0.2.6' │ 'none' │ │ 25 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 26 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 27 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 28 │ 'system.adapter.icons-material-svg' │ 'icons-material-svg' │ '0.1.0' │ 'none' │ │ 29 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 30 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 31 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3' │ 'none' │ │ 32 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 33 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 34 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 35 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 36 │ 'system.adapter.linux-control' │ 'linux-control' │ '1.1.5' │ 'none' │ │ 37 │ 'system.adapter.logparser' │ 'logparser' │ '2.5.0' │ 'none' │ │ 38 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 39 │ 'system.adapter.motioneye' │ 'motioneye' │ '1.3.1' │ 'none' │ │ 40 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 41 │ 'system.adapter.nina' │ 'nina' │ '0.0.26' │ 'none' │ │ 42 │ 'system.adapter.parcel' │ 'parcel' │ '0.3.3' │ 'none' │ │ 43 │ 'system.adapter.ping' │ 'ping' │ '2.2.4' │ 'none' │ │ 44 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 45 │ 'system.adapter.reolink' │ 'reolink' │ '1.4.2' │ 'none' │ │ 46 │ 'system.adapter.residents' │ 'residents' │ '1.1.1' │ 'none' │ │ 47 │ 'system.adapter.rpi2' │ 'rpi2' │ '2.4.0' │ 'none' │ │ 48 │ 'system.adapter.sayit' │ 'sayit' │ '5.1.0' │ 'none' │ │ 49 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 50 │ 'system.adapter.smartcontrol' │ 'smartcontrol' │ '2.0.1' │ 'none' │ │ 51 │ 'system.adapter.smartmeter' │ 'smartmeter' │ '3.4.0' │ 'none' │ │ 52 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 53 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 54 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 55 │ 'system.adapter.spotify-premium' │ 'spotify-premium' │ '3.0.1' │ 'none' │ │ 56 │ 'system.adapter.sql' │ 'sql' │ '3.0.1' │ 'none' │ │ 57 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 58 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 59 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 60 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 61 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 62 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 63 │ 'system.adapter.tuya' │ 'tuya' │ '3.17.0' │ 'none' │ │ 64 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 65 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 66 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 67 │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1' │ 'none' │ │ 68 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 69 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 70 │ 'system.adapter.vis-fancyswitch' │ 'vis-fancyswitch' │ '1.1.0' │ 'none' │ │ 71 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 72 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 73 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 74 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 75 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 76 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 77 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.93' │ 'none' │ │ 78 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 79 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 80 │ 'system.adapter.vis-plumb' │ 'vis-plumb' │ '1.0.2' │ 'none' │ │ 81 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 82 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 83 │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0' │ 'none' │ │ 84 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 85 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 86 │ 'system.adapter.yr' │ 'yr' │ '5.3.0' │ 'none' │ │ 87 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "accuweather" : 2.3.0 , installed 2.3.0 Adapter "admin" : 8.0.14 , installed 8.0.14 Adapter "alarm" : 5.0.1 , installed 5.0.1 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "chromecast" : 4.2.0 , installed 4.2.0 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.9 , installed 4.5.9 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 3.0.0 , installed 3.0.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "logparser" : 2.5.0 , installed 2.5.0 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "motioneye" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "nina" : 0.0.25 , installed 0.0.26 Adapter "ping" : 3.0.1 , installed 2.2.4 [Updatable] Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "reolink" : 1.4.2 , installed 1.4.2 Adapter "residents" : 1.1.1 , installed 1.1.1 Adapter "rpi2" : 3.0.2 , installed 2.4.0 [Updatable] Adapter "sayit" : 5.1.0 , installed 5.1.0 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "spotify-premium": 3.0.1 , installed 3.0.1 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.93 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 40397 States: 35698 *** OS-Repositories and Updates *** Hit:1 http://de.archive.ubuntu.com/ubuntu resolute InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu resolute-updates InRelease Hit:3 http://de.archive.ubuntu.com/ubuntu resolute-backports InRelease Hit:4 http://security.ubuntu.com/ubuntu resolute-security InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.122:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=193429,fd=72)) udp UNCONN 0 0 0.0.0.0:coap 0.0.0.0:* users:(("io.shelly.0",pid=193134,fd=36)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=193481,fd=44)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=193481,fd=45)) udp UNCONN 0 0 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=18)) udp UNCONN 0 0 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=16)) udp UNCONN 0 0 192.168.178.122%enp0s31f6:bootpc 0.0.0.0:* users:(("systemd-network",pid=891,fd=37)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=5),("systemd",pid=1,fd=267)) udp UNCONN 0 0 0.0.0.0:57768 0.0.0.0:* users:(("io.upnp.0",pid=195656,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=195656,fd=31)) udp UNCONN 0 0 *:7775 *:* users:(("hannah-proxy",pid=1332,fd=9)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=7),("systemd",pid=1,fd=269)) udp UNCONN 0 0 [fe80::6e4b:90ff:fe46:83a9]%enp0s31f6:dhcpv6-client [::]:* users:(("systemd-network",pid=891,fd=35)) tcp LISTEN 0 4096 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=19)) tcp LISTEN 0 2048 192.168.178.122:http-alt 0.0.0.0:* users:(("python",pid=1043,fd=8)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=1008,fd=3)) tcp LISTEN 0 4096 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=8391,fd=3),("systemd",pid=1,fd=240)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=4),("systemd",pid=1,fd=266)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=191165,fd=29)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=191165,fd=23)) tcp LISTEN 0 511 0.0.0.0:1884 0.0.0.0:* users:(("io.mqtt.0",pid=192946,fd=35)) tcp LISTEN 0 511 0.0.0.0:1887 0.0.0.0:* users:(("io.sonoff.0",pid=193393,fd=40)) tcp LISTEN 0 511 0.0.0.0:1888 0.0.0.0:* users:(("io.mqtt.2",pid=194550,fd=35)) tcp LISTEN 0 511 0.0.0.0:1889 0.0.0.0:* users:(("io.mqtt.2",pid=194550,fd=36)) tcp LISTEN 0 4096 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=17)) tcp LISTEN 0 2048 0.0.0.0:5000 0.0.0.0:* users:(("gunicorn",pid=96468,fd=3),("gunicorn",pid=1377,fd=3),("gunicorn",pid=1334,fd=3)) tcp LISTEN 0 511 192.168.178.122:1882 0.0.0.0:* users:(("io.shelly.1",pid=193266,fd=36)) tcp LISTEN 0 511 *:2323 *:* users:(("io.fullybrowser",pid=192725,fd=30)) tcp LISTEN 0 4096 [::]:ssh [::]:* users:(("sshd",pid=8391,fd=4),("systemd",pid=1,fd=241)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=6),("systemd",pid=1,fd=268)) tcp LISTEN 0 4096 *:50060 *:* users:(("hannah-logcolle",pid=1331,fd=7)) tcp LISTEN 0 4096 *:50051 *:* users:(("python",pid=1335,fd=22)) tcp LISTEN 0 511 *:8083 *:* users:(("io.web.0",pid=195518,fd=35)) tcp LISTEN 0 511 *:8084 *:* users:(("io.socketio.0",pid=195380,fd=34)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=1008,fd=41)) tcp LISTEN 0 511 *:8087 *:* users:(("io.ws.0",pid=195532,fd=34)) *** Log File - Last 25 Lines *** 2026-09-30 21:23:45.278 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.279 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.283 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.285 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.314 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.317 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.322 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.322 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.339 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.340 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:47.101 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:47.179 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:55.041 - error: parcel.0 (196107) https://www.dhl.de/int-aviseanzeigen/advices?width=414 2026-09-30 21:23:55.042 - error: parcel.0 (196107) [Update/fetch] GET https://www.dhl.de/int-aviseanzeigen/advices?width=414 → ERR_BAD_RESPONSE (Request failed with status code 500) 2026-09-30 21:23:55.043 - error: parcel.0 (196107) [Update/fetch] body: [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 21:23:55.043 - error: parcel.0 (196107) [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 21:24:08.787 - error: sourceanalytix.0 (195386) Check settings for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower ! Known valueAtDeviceReset : (176903.80000000016) > known cumulative value (176262.80000000016) cannot proceed 2026-09-30 21:24:08.787 - error: sourceanalytix.0 (195386) Troubleshoot Data mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower custom Data : {"_id":"mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower","common":{"name":"inverter-Solar/Homy-800/ch0/MaxPower","write":true,"read":true,"role":"variable","desc":"mqtt server variable","type":"number","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":176903.80000000016,"start_week":176903.80000000016,"start_month":175416.10000000018,"start_quarter":122587.40000000001,"start_year":10440.599999999997,"alias":"Solar hm-800","consumption":true,"meter_values":true,"costs":true,"selectedPrice":"ElectricityDelivery","valueAtDeviceReset":176903.80000000016,"valueAtDeviceInit":106.4,"cumulativeValue":176903.80000000016}}},"native":{"topic":"inverter-Solar/Homy-800/ch0/MaxPower"},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1787584996560} 2026-09-30 21:24:08.788 - error: sourceanalytix.0 (195386) Cannot handle calculations for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower, check log messages and adjust settings! 2026-09-30 21:24:08.789 - error: sourceanalytix.0 (195386) Initialization of mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower failed, check warn messages ! 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Check settings for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay ! Known valueAtDeviceReset : (1120.1749999999993) > known cumulative value (1117.1789999999992) cannot proceed 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Troubleshoot Data sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay custom Data : {"type":"state","common":{"name":"01_currentDay","type":"number","role":"value","read":true,"write":false,"unit":"kWh","def":0,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":1120.1749999999993,"start_week":1110.508999999999,"start_month":1101.817999999999,"start_quarter":995.2539999999998,"start_year":584.993,"alias":"solar","selectedPrice":"ElectricityDelivery","consumption":true,"meter_values":true,"valueAtDeviceReset":1120.1749999999993,"valueAtDeviceInit":0,"cumulativeValue":1120.1749999999993}}},"native":{},"_id":"sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1790796248575} 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Cannot handle calculations for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay, check log messages and adjust settings! 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Initialization of sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay failed, check warn messages ! 2026-09-30 21:24:08.838 - warn: sourceanalytix.0 (195386) Cannot handle calculations for 3 of 15 enabled states, check error messages============= Mark until here for C&P =============
iob diag has finished.code_text
iob@iob:~$
Bring das möglichst runter. Den iobroker.info Adapter rauswerfen, den gibt es nicht mehr.
Der admin läuft nicht.
iob start admin.0Da fehlt das Repo für nodejs. Da aber nodejs@24 eh die neue Empfehlung ist kannste das direkt per
iob nodejs-updatemal korrigieren.
hallo, ähnliches Problem, ADMIN update ist hängengebleiben/abgestürzt und admin.0 und alias-manager laufen nicht und lassen sich auch nicht starten.
hier mein iob diag;========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: iob Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Kernel: Linux 6.12.111+deb13-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org Firmware Date: Tue 2014-04-01 Firmware Age: 12y 6month OS is similar to: model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : 64bit System was installed 200 days ago (on 2026-03-14). Systemuptime and Load: 21:45:38 up 1:02, 1 user, load average: 0.25, 0.32, 0.35 CPU threads : 2 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 21:45:39 CEST Universal time: Wed 2026-09-30 19:45:39 UTC RTC time: Wed 2026-09-30 19:45:39 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: no NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': peter HOME=/home/peter GROUPS=peter cdrom floppy sudo audio dip video plugdev users netdev iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.3G 2.2G 4.4G 593K 961M 5.1G Swap: 4.3G 0B 4.3G Total: 11G 2.2G 8.7G Active iob-Instances: 13 6939 M total memory 2115 M used memory 1780 M active memory 692 M inactive memory 4177 M free memory 95 M buffer memory 822 M swap cache 4119 M total swap 0 M used swap 4119 M free swap *** top - Table Of Processes *** top - 21:45:39 up 1:02, 1 user, load average: 0.25, 0.32, 0.35 Tasks: 132 total, 2 running, 130 sleeping, 0 stopped, 0 zombie %Cpu(s): 18.2 us, 4.5 sy, 0.0 ni, 77.3 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 6939.8 total, 4176.0 free, 2116.9 used, 917.3 buff/cache MiB Swap: 4120.0 total, 4120.0 free, 0.0 used. 4822.9 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.4G 0 3.4G 0% /dev tmpfs tmpfs 694M 580K 694M 1% /run /dev/sda1 ext4 9.9G 9.1G 219M 98% / tmpfs tmpfs 3.4G 0 3.4G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service /dev/sda7 ext4 1.2G 6.0M 1.1G 1% /tmp /dev/sda8 ext4 61G 8.7G 49G 16% /home tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 694M 8.0K 694M 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Wed Sep 30 20:43:22 2026] EXT4-fs (sda1): mounted filesystem c821652a-938f-46bf-91c5-58a1ad8b22ad ro with ordered data mode. Quota mode: none. [Wed Sep 30 20:43:23 2026] EXT4-fs (sda1): re-mounted c821652a-938f-46bf-91c5-58a1ad8b22ad r/w. [Wed Sep 30 20:43:24 2026] EXT4-fs (sda7): mounted filesystem c6e93e30-f42d-493a-9566-d59476c35122 r/w with ordered data mode. Quota mode: none. [Wed Sep 30 20:43:24 2026] EXT4-fs (sda8): mounted filesystem f40fb640-c5eb-48fe-8da1-6e7360346595 r/w with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro |-/tmp /dev/sda7 ext4 rw,relatime |-/home /dev/sda8 ext4 rw,relatime `-/var /dev/sda8[/var/var] ext4 rw,relatime Files in neuralgic directories: /var: 4.1G /var/ 2.7G /var/lib 2.5G /var/lib/influxdb/engine/data/4d14edf996ac7061/autogen 2.5G /var/lib/influxdb/engine/data/4d14edf996ac7061 2.5G /var/lib/influxdb/engine/data Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 63.2M in the file system. /opt/iobroker/backups: 2.5G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 4.4G /opt/iobroker/iobroker-data/ 4.3G /opt/iobroker/iobroker-data/history 82M /opt/iobroker/iobroker-data/backup-objects 75M /opt/iobroker/iobroker-data/files 62M /opt/iobroker/iobroker-data/history/20260514 The five largest files in iobroker-data are: 31M /opt/iobroker/iobroker-data/objects.jsonl 6.8M /opt/iobroker/iobroker-data/files/javascript.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomJavascriptSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-DMefPDeL.js 6.8M /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomBackItUpSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-Bs-T0f9g.js 6.1M /opt/iobroker/iobroker-data/history/20260514/history.smartmeter.0.1-0~16_7_0__255.value.json 6.1M /opt/iobroker/iobroker-data/history/20260514/history.alias.0.Stromzähler.aktuelle Leistung.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0086-if00-port0 No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://security.debian.org/debian-security trixie-security/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iob iob (version: 7.2.2, hostname: iob , alive, uptime: 1412) Core adapters versions js-controller: 7.2.2 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 0 Adapter State system.adapter.admin.0 : admin : iob - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : iob - enabled + system.adapter.backitup.0 : backitup : iob - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iob - enabled + system.adapter.history.0 : history : iob - enabled + system.adapter.influxdb.0 : influxdb : iob - enabled, port: 8086 + system.adapter.javascript.0 : javascript : iob - enabled + system.adapter.mqtt-client.0 : mqtt-client : iob - enabled, port: 1883 + system.adapter.mqtt.0 : mqtt : iob - enabled, port: 1883, bind: 192.168.52.34 + system.adapter.opendtu.0 : opendtu : iob - enabled system.adapter.pvforecast.0 : pvforecast : iob - disabled + system.adapter.smartmeter.0 : smartmeter : iob - enabled + system.adapter.statistics.0 : statistics : iob - enabled system.adapter.viessmann.0 : viessmann : iob - disabled, port: 3002 + system.adapter.web.0 : web : iob - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zendure-solarflow.0 : zendure-solarflow : iob - enabled + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : iob - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : iob - enabled, port: 8086 + system.adapter.mqtt-client.0 : mqtt-client : iob - enabled, port: 1883 + system.adapter.mqtt.0 : mqtt : iob - enabled, port: 1883, bind: 192.168.52.34 + system.adapter.web.0 : web : iob - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬─────────────────────────────────────────┬──────────────────────────┬──────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼─────────────────────────────────────────┼──────────────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 1 │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0' │ 'none' │ │ 2 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 3 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.3' │ 'none' │ │ 4 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 5 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 6 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 7 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 8 │ 'system.adapter.mqtt-client' │ 'mqtt-client' │ '4.0.0' │ 'none' │ │ 9 │ 'system.adapter.opendtu' │ 'opendtu' │ '3.1.0' │ 'none' │ │ 10 │ 'system.adapter.pvforecast' │ 'pvforecast' │ '6.2.0' │ 'none' │ │ 11 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.6' │ 'none' │ │ 12 │ 'system.adapter.smartmeter' │ 'smartmeter' │ '3.4.0' │ 'none' │ │ 13 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 14 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 15 │ 'system.adapter.viessmann' │ 'viessmann' │ '2.0.5' │ 'none' │ │ 16 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 17 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 18 │ 'system.adapter.zendure-solarflow' │ 'zendure-solarflow' │ '5.3.1' │ 'none' │ └─────────┴─────────────────────────────────────────┴──────────────────────────┴──────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.0.14 , installed 8.0.14 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.3 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "mqtt-client" : 4.0.0 , installed 4.0.0 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "pvforecast" : 6.2.0 , installed 6.2.0 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "viessmann" : 2.0.5 , installed 2.0.5 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "zendure-solarflow": 5.3.1, installed 5.3.1 Objects and States Please stand by - This may take a while Objects: 4035 States: 3431 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org/debian-security trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.52.34:bootpc 0.0.0.0:* users:(("dhcpcd",pid=806,fd=3)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=590,fd=5),("systemd",pid=1,fd=160)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=590,fd=7),("systemd",pid=1,fd=166)) udp UNCONN 0 0 [2002:55d8:5d89:0:be24:11ff:fe28:3255]:dhcpv6-client [::]:* users:(("dhcpcd",pid=839,fd=3)) udp UNCONN 0 0 [2002:55d8:5d89:0:b178:95cc:e574:b7cc]:dhcpv6-client [::]:* users:(("dhcpcd",pid=738,fd=3)) udp UNCONN 0 0 [fe80::6dae:ccd9:ebd:ac6c]%ens18:dhcpv6-client [::]:* users:(("dhcpcd",pid=709,fd=3)) tcp LISTEN 0 100 0.0.0.0:1883 0.0.0.0:* users:(("mosquitto",pid=699,fd=5)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=590,fd=4),("systemd",pid=1,fd=159)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=673,fd=6)) tcp LISTEN 0 100 0.0.0.0:8883 0.0.0.0:* users:(("mosquitto",pid=699,fd=7)) tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:* users:(("iobroker.js-con",pid=4856,fd=29)) tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:* users:(("iobroker.js-con",pid=4856,fd=23)) tcp LISTEN 0 100 [::]:1883 [::]:* users:(("mosquitto",pid=699,fd=6)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=590,fd=6),("systemd",pid=1,fd=164)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=673,fd=7)) tcp LISTEN 0 100 [::]:8883 [::]:* users:(("mosquitto",pid=699,fd=8)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=5097,fd=35)) *** Log File - Last 25 Lines *** 2026-09-30 21:45:13.862 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: newLimit positiv: 260 ist > oldLimit: 250 Es wird mehr entladen als zuvor. 2026-09-30 21:45:13.861 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:13.864 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: auto_in_out_Limit ist positiv oder 0: 260 2026-09-30 21:45:18.860 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:23.861 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:28.862 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:28.864 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: newLimit positiv: 250 ist < oldLimit: 260 Es wird weniger entladen als zuvor. 2026-09-30 21:45:28.865 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: auto_in_out_Limit ist positiv oder 0: 250 2026-09-30 21:45:33.863 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:38.865 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:43.865 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:43.867 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: Es gibt nichts zu tun, theoretisches positives newLimit: 250; oldLimit: 250 2026-09-30 21:45:48.866 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:48.870 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: newLimit positiv: 260 ist > oldLimit: 250 Es wird mehr entladen als zuvor. 2026-09-30 21:45:48.871 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: auto_in_out_Limit ist positiv oder 0: 260 2026-09-30 21:45:53.866 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:45:58.866 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:46:03.870 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: Es gibt nichts zu tun, theoretisches positives newLimit: 260; oldLimit: 260 2026-09-30 21:46:03.871 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:46:08.869 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:46:08.871 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: Es gibt nichts zu tun, theoretisches positives newLimit: 260; oldLimit: 260 2026-09-30 21:46:13.873 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: newLimit positiv: 250 ist < oldLimit: 260 Es wird weniger entladen als zuvor. 2026-09-30 21:46:13.870 - info: smartmeter.0 (5006) Received 7 values, 1 updated 2026-09-30 21:46:13.873 - info: javascript.0 (4922) script.js.common.maxclaudi_dpl_acMode_kV: auto_in_out_Limit ist positiv oder 0: 250 2026-09-30 21:46:18.870 - info: smartmeter.0 (5006) Received 7 values, 1 updated============= Mark until here for C&P =============
peter@iob:~$
peter@iob:~$
Users in groups 'adm', 'systemd-journal' can see all messages.Setz den user 'peter' in die Gruppe 'adm'.
iob start admin.0sagt?
Stell das Logging auf sinnvolleres ein. Du musst nicht alle 5 Sekunden sehen, dass da 7 Werte gelesen wurden...
iob@iob:~$ iob start admin.0 sudo: 'node': command not found [INFO] Node.js v24.21.0 installed successfully. [INFO] Checking npm dependencies for compatibility with Node.js 24... [INFO] No compatibility issues found. [INFO] Starting ioBroker with 'iob start'... [INFO] ioBroker started successfully. [INFO] Node.js update completed successfully! [INFO] The NodeSource repository has been permanently added to your system. [INFO] You can now update Node.js in the future using: sudo apt update && sudo apt upgrade nodejs [WARN] DO NOT use 'nodejs-update' as part of your regular update process! [WARN] DO NOT use node version managers like 'nvm', 'n' and others in parallel. They will break your installation! [INFO] Cleaning up temporary files... iob@iob:~$ -
iob@iob:~$ iob start admin.0 sudo: 'node': command not found [INFO] Node.js v24.21.0 installed successfully. [INFO] Checking npm dependencies for compatibility with Node.js 24... [INFO] No compatibility issues found. [INFO] Starting ioBroker with 'iob start'... [INFO] ioBroker started successfully. [INFO] Node.js update completed successfully! [INFO] The NodeSource repository has been permanently added to your system. [INFO] You can now update Node.js in the future using: sudo apt update && sudo apt upgrade nodejs [WARN] DO NOT use 'nodejs-update' as part of your regular update process! [WARN] DO NOT use node version managers like 'nvm', 'n' and others in parallel. They will break your installation! [INFO] Cleaning up temporary files... iob@iob:~$Und ein vollständiges
iob diagsagt? Mir scheint da auch irgendwie komisch kopiert worden zu sein.
@Thomas-Braun
*** iob diag is starting up, please wait ***
The state system.host.iob.versions.nodeNewestNext was not found!
The state system.host.iob.versions.npmNewestNext was not found!========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Ubuntu 26.04.1 LTS Static hostname: iob Icon name: computer-desktop Chassis: desktop 🖥 Kernel: Linux 7.0.0-34-generic Architecture: x86-64 Hardware Vendor: Lenovo Hardware Model: ThinkCentre M710q Hardware SKU: LENOVO_MT_10MR_BU_LENOVO_FM_ThinkCentre M710q Firmware Version: M1AKT30A Firmware Date: Wed 2018-01-03 Firmware Age: 8y 8month 3w 6d OS is similar to: debian model name : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz Docker : false Virtualization : none Unknown Kernel : x86_64 Userland : 64bit System was installed 626 days ago (on 2025-01-12). Systemuptime and Load: 22:16:39 up 2:20, 1 user, load average: 0.51, 1.55, 2.15 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Ubuntu LTS release codenamed 'resolute'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 22:16:39 CEST Universal time: Wed 2026-09-30 20:16:39 UTC RTC time: Wed 2026-09-30 20:16:39 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iob HOME=/home/iob GROUPS=iob adm cdrom sudo dip plugdev lxd iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 6.7G 7.8G 7.0M 2.0G 9.4G Swap: 4.3G 298M 4.0G Total: 20G 7.0G 11G Active iob-Instances: 54 15363 M total memory 6366 M used memory 1375 M active memory 5713 M inactive memory 7451 M free memory 153 M buffer memory 1732 M swap cache 4095 M total swap 284 M used swap 3811 M free swap *** top - Table Of Processes *** top - 22:16:40 up 2:20, 1 user, load average: 0.51, 1.55, 2.15 Tasks: 235 total, 2 running, 233 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.0 us, 4.1 sy, 0.0 ni, 93.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 15364.0 total, 7453.7 free, 6364.8 used, 1885.8 buff/cache MiB Swap: 4096.0 total, 3811.1 free, 284.9 used. 8999.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * motioneye.service loaded failed failed motionEye Server Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 1.6G 1.5M 1.5G 1% /run efivarfs efivarfs 256K 56K 196K 22% /sys/firmware/efi/efivars /dev/mapper/ubuntu--vg-ubuntu--lv ext4 98G 57G 36G 62% / tmpfs tmpfs 7.6G 4.0K 7.6G 1% /dev/shm none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-resolved.service tmpfs tmpfs 128M 0 128M 0% /mnt/hannah_mem tmpfs tmpfs 7.6G 5.9M 7.5G 1% /tmp /dev/sda2 ext4 2.0G 249M 1.6G 14% /boot /dev/sda1 vfat 1.1G 6.4M 1.1G 1% /boot/efi none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-networkd.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 1.6G 8.0K 1.6G 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Wed Sep 30 19:55:51 2026] Btrfs loaded, zoned=yes, fsverity=yes [Wed Sep 30 19:55:51 2026] EXT4-fs (dm-0): mounted filesystem 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e ro with ordered data mode. Quota mode: none. [Wed Sep 30 19:55:52 2026] systemd[1]: /usr/lib/systemd/system/system-xfs_scrub.slice:15: Support for option CPUAccounting= has been removed and it is ignored [Wed Sep 30 19:55:52 2026] systemd[1]: Created slice system-xfs_scrub.slice - xfs_scrub background service slice. [Wed Sep 30 19:55:52 2026] EXT4-fs (dm-0): re-mounted 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e r/w. [Wed Sep 30 19:55:54 2026] EXT4-fs (sda2): mounted filesystem b861858a-b19e-4131-a0e3-fc3a2d28be18 r/w with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/core24/1643 /dev/loop0 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core24/2124 /dev/loop1 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3579 /dev/loop2 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27710 /dev/loop3 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3613 /dev/loop4 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27738 /dev/loop5 squashfs ro,nodev,relatime,errors=continue,threads=single `-/boot /dev/sda2 ext4 rw,relatime `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 6.9G /var/ 5.6G /var/log 4.0G /var/log/journal/e8a87e3a1d4745f58598c1733b85f896 4.0G /var/log/journal 1.2G /var/lib Archived and active journals take up 3.9G in the file system. /opt/iobroker/backups: 26G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 4.9G /opt/iobroker/iobroker-data/ 3.9G /opt/iobroker/iobroker-data/history 679M /opt/iobroker/iobroker-data/files 217M /opt/iobroker/iobroker-data/backup-objects 106M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 79M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/hannah.admin/build/index.js.map 22M /opt/iobroker/iobroker-data/files/residents.admin/build/index.js.map 22M /opt/iobroker/iobroker-data/files/hannah.admin/build/tab.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307YK6K-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...d3e33719c2d21c-if00-port0 ...d3e33719c2d21c-if00-port0 ✓ Matching ..._UART_D307YK6K-if00-port0 ✗ Not matching *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 22.22.1+dfsg+~cs22.19.15-1ubuntu1 500 500 http://de.archive.ubuntu.com/ubuntu resolute/universe amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: Mini-pc-Master Mini-pc-Master (version: 7.2.2, hostname: Mini-pc-Master, alive, uptime: 1010) Core adapters versions js-controller: 7.2.2 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 11 +-- @iobroker/type-detector@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.type-detector.git#bef8c38d3c7749781fe92aa32da6437d02d453d5) +-- iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#105b168bc40c34d10e98cfb26b885ca9e00c6e69) | +-- nan@2.22.0 (git+ssh://git@github.com/JCMais/nan.git#0ec2eca8b2fd7518affb3945d087e393ad839b7e) +-- iobroker.hoymiles-wifi@0.2.7 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#8260d47b5f69cada23977a45c53a1befb6f585ea) +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946) +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059) +-- iobroker.parcel@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#3c4fb0ea5aa15a0d49a52f2fbd2546a836169fec) +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f) +-- iobroker.spotify-premium@3.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.spotify-premium.git#cbfe89f8f04f2f05913bce18cb5f8b41350d212d) +-- iobroker.statistics@5.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.statistics.git#db6d21fc130c630147ac159785f10eb9b77f68a8) +-- iobroker.vis-materialdesign@0.5.93 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#31b045e7c1ba599cf4005803636593de91334143) Adapter State system.adapter.accuweather.0 : accuweather : Mini-pc-Master - disabled system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : Mini-pc-Master - enabled system.adapter.alexa2.0 : alexa2 : Mini-pc-Master - disabled system.adapter.alias-manager.0 : alias-manager : Mini-pc-Master - disabled + system.adapter.backitup.0 : backitup : Mini-pc-Master - enabled + system.adapter.ble.0 : ble : Mini-pc-Master - enabled system.adapter.chromecast.0 : chromecast : Mini-pc-Master - disabled + system.adapter.cloud.0 : cloud : Mini-pc-Master - enabled + system.adapter.daswetter.0 : daswetter : Mini-pc-Master - enabled + system.adapter.device-reminder.0 : device-reminder : Mini-pc-Master - enabled + system.adapter.device-watcher.0 : device-watcher : Mini-pc-Master - enabled system.adapter.devices.0 : devices : Mini-pc-Master - disabled + system.adapter.discovery.0 : discovery : Mini-pc-Master - enabled system.adapter.dwd.0 : dwd : Mini-pc-Master - enabled + system.adapter.echarts.0 : echarts : Mini-pc-Master - enabled + system.adapter.email.0 : email : Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss.0 : energiefluss : Mini-pc-Master - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : Mini-pc-Master - enabled + system.adapter.fritzdect.0 : fritzdect : Mini-pc-Master - enabled + system.adapter.fullybrowser.0 : fullybrowser : Mini-pc-Master - enabled + system.adapter.hannah.0 : hannah : Mini-pc-Master - enabled + system.adapter.history.0 : history : Mini-pc-Master - enabled system.adapter.hoymiles-wifi.0 : hoymiles-wifi : Mini-pc-Master - disabled system.adapter.ical.0 : ical : Mini-pc-Master - enabled system.adapter.ical.1 : ical : Mini-pc-Master - enabled system.adapter.icons-icons8.0 : icons-icons8 : Mini-pc-Master - disabled system.adapter.icons-material-png.0 : icons-material-png : Mini-pc-Master - disabled system.adapter.icons-material-svg.0 : icons-material-svg : Mini-pc-Master - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : Mini-pc-Master - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Mini-pc-Master - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Mini-pc-Master - disabled + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.info.0 : info : Mini-pc-Master - enabled + system.adapter.iot.0 : iot : Mini-pc-Master - enabled + system.adapter.javascript.0 : javascript : Mini-pc-Master - enabled + system.adapter.linux-control.0 : linux-control : Mini-pc-Master - enabled + system.adapter.logparser.0 : logparser : Mini-pc-Master - enabled system.adapter.matter.0 : matter : Mini-pc-Master - disabled system.adapter.motioneye.0 : motioneye : Mini-pc-Master - disabled + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 system.adapter.mqtt.1 : mqtt : Mini-pc-Master - disabled, port: 1885, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.nina.0 : nina : Mini-pc-Master - enabled + system.adapter.parcel.0 : parcel : Mini-pc-Master - enabled + system.adapter.ping.0 : ping : Mini-pc-Master - enabled system.adapter.radar2.0 : radar2 : Mini-pc-Master - disabled + system.adapter.reolink.0 : reolink : Mini-pc-Master - enabled + system.adapter.reolink.1 : reolink : Mini-pc-Master - enabled + system.adapter.residents.0 : residents : Mini-pc-Master - enabled + system.adapter.rpi2.0 : rpi2 : Mini-pc-Master - enabled system.adapter.rpi2.1 : rpi2 : pi-3 - disabled + system.adapter.sayit.0 : sayit : Mini-pc-Master - enabled system.adapter.sayit.1 : sayit : Mini-pc-Master - disabled + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 system.adapter.smartcontrol.0 : smartcontrol : Mini-pc-Master - disabled + system.adapter.smartmeter.0 : smartmeter : Mini-pc-Master - enabled + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : Mini-pc-Master - enabled system.adapter.spotify-premium.0 : spotify-premium : Mini-pc-Master - disabled + system.adapter.sql.0 : sql : Mini-pc-Master - enabled + system.adapter.statistics.0 : statistics : Mini-pc-Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : Mini-pc-Master - enabled + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : Mini-pc-Master - enabled + system.adapter.tr-064.0 : tr-064 : Mini-pc-Master - enabled + system.adapter.trashschedule.0 : trashschedule : Mini-pc-Master - enabled + system.adapter.tuya.0 : tuya : Mini-pc-Master - enabled + system.adapter.upnp.0 : upnp : Mini-pc-Master - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Mini-pc-Master - disabled system.adapter.vis-2.0 : vis-2 : Mini-pc-Master - disabled system.adapter.vis-bars.0 : vis-bars : Mini-pc-Master - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Mini-pc-Master - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : Mini-pc-Master - disabled system.adapter.vis-history.0 : vis-history : Mini-pc-Master - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Mini-pc-Master - disabled system.adapter.vis-icontwo.0 : vis-icontwo : Mini-pc-Master - disabled system.adapter.vis-inventwo.0 : vis-inventwo : Mini-pc-Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Mini-pc-Master - disabled system.adapter.vis-justgage.0 : vis-justgage : Mini-pc-Master - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : Mini-pc-Master - disabled system.adapter.vis-metro.0 : vis-metro : Mini-pc-Master - disabled system.adapter.vis-players.0 : vis-players : Mini-pc-Master - disabled system.adapter.vis-plumb.0 : vis-plumb : Mini-pc-Master - enabled system.adapter.vis-rgraph.0 : vis-rgraph : Mini-pc-Master - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : Mini-pc-Master - disabled system.adapter.vis.0 : vis : Mini-pc-Master - enabled system.adapter.weatherunderground.0 : weatherunderground : Mini-pc-Master - enabled + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.yr.0 : yr : Mini-pc-Master - enabled + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.accuweather' │ 'accuweather' │ '2.3.0' │ 'none' │ │ 1 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 2 │ 'system.adapter.alarm' │ 'alarm' │ '5.0.1' │ 'none' │ │ 3 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 4 │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0' │ 'none' │ │ 5 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 6 │ 'system.adapter.ble' │ 'ble' │ '0.14.0' │ 'none' │ │ 7 │ 'system.adapter.chromecast' │ 'chromecast' │ '4.2.0' │ 'none' │ │ 8 │ 'system.adapter.cloud' │ 'cloud' │ '6.0.1' │ 'none' │ │ 9 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.9' │ 'none' │ │ 10 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 11 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 12 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 13 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 14 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 15 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 16 │ 'system.adapter.email' │ 'email' │ '3.0.0' │ 'none' │ │ 17 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 18 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 19 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 20 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 21 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 22 │ 'system.adapter.hannah' │ 'hannah' │ '1.5.0' │ 'none' │ │ 23 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 24 │ 'system.adapter.hoymiles-wifi' │ 'hoymiles-wifi' │ '0.2.6' │ 'none' │ │ 25 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 26 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 27 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 28 │ 'system.adapter.icons-material-svg' │ 'icons-material-svg' │ '0.1.0' │ 'none' │ │ 29 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 30 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 31 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3' │ 'none' │ │ 32 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 33 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 34 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 35 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 36 │ 'system.adapter.linux-control' │ 'linux-control' │ '1.1.5' │ 'none' │ │ 37 │ 'system.adapter.logparser' │ 'logparser' │ '2.5.0' │ 'none' │ │ 38 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 39 │ 'system.adapter.motioneye' │ 'motioneye' │ '1.3.1' │ 'none' │ │ 40 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 41 │ 'system.adapter.nina' │ 'nina' │ '0.0.26' │ 'none' │ │ 42 │ 'system.adapter.parcel' │ 'parcel' │ '0.3.3' │ 'none' │ │ 43 │ 'system.adapter.ping' │ 'ping' │ '2.2.4' │ 'none' │ │ 44 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 45 │ 'system.adapter.reolink' │ 'reolink' │ '1.4.2' │ 'none' │ │ 46 │ 'system.adapter.residents' │ 'residents' │ '1.1.1' │ 'none' │ │ 47 │ 'system.adapter.rpi2' │ 'rpi2' │ '2.4.0' │ 'none' │ │ 48 │ 'system.adapter.sayit' │ 'sayit' │ '5.1.0' │ 'none' │ │ 49 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 50 │ 'system.adapter.smartcontrol' │ 'smartcontrol' │ '2.0.1' │ 'none' │ │ 51 │ 'system.adapter.smartmeter' │ 'smartmeter' │ '3.4.0' │ 'none' │ │ 52 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 53 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 54 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 55 │ 'system.adapter.spotify-premium' │ 'spotify-premium' │ '3.0.1' │ 'none' │ │ 56 │ 'system.adapter.sql' │ 'sql' │ '3.0.1' │ 'none' │ │ 57 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 58 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 59 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 60 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 61 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 62 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 63 │ 'system.adapter.tuya' │ 'tuya' │ '3.17.0' │ 'none' │ │ 64 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 65 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 66 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 67 │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1' │ 'none' │ │ 68 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 69 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 70 │ 'system.adapter.vis-fancyswitch' │ 'vis-fancyswitch' │ '1.1.0' │ 'none' │ │ 71 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 72 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 73 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 74 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 75 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 76 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 77 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.93' │ 'none' │ │ 78 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 79 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 80 │ 'system.adapter.vis-plumb' │ 'vis-plumb' │ '1.0.2' │ 'none' │ │ 81 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 82 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 83 │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0' │ 'none' │ │ 84 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 85 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 86 │ 'system.adapter.yr' │ 'yr' │ '5.3.0' │ 'none' │ │ 87 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "accuweather" : 2.3.0 , installed 2.3.0 Adapter "admin" : 8.0.14 , installed 8.0.14 Adapter "alarm" : 5.0.1 , installed 5.0.1 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "chromecast" : 4.2.0 , installed 4.2.0 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.9 , installed 4.5.9 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 3.0.0 , installed 3.0.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "logparser" : 2.5.0 , installed 2.5.0 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "motioneye" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "nina" : 0.0.25 , installed 0.0.26 Adapter "ping" : 3.0.1 , installed 2.2.4 [Updatable] Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "reolink" : 1.4.2 , installed 1.4.2 Adapter "residents" : 1.1.1 , installed 1.1.1 Adapter "rpi2" : 3.0.2 , installed 2.4.0 [Updatable] Adapter "sayit" : 5.1.0 , installed 5.1.0 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "spotify-premium": 3.0.1 , installed 3.0.1 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.93 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 40397 States: 35698 *** OS-Repositories and Updates *** Hit:1 http://de.archive.ubuntu.com/ubuntu resolute InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu resolute-updates InRelease Hit:3 http://de.archive.ubuntu.com/ubuntu resolute-backports InRelease Hit:4 http://security.ubuntu.com/ubuntu resolute-security InRelease Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.122:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=279638,fd=72)) udp UNCONN 0 0 0.0.0.0:coap 0.0.0.0:* users:(("io.shelly.0",pid=279425,fd=36)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=279686,fd=44)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=279686,fd=45)) udp UNCONN 0 0 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=18)) udp UNCONN 0 0 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=16)) udp UNCONN 0 0 192.168.178.122%enp0s31f6:bootpc 0.0.0.0:* users:(("systemd-network",pid=891,fd=37)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=5),("systemd",pid=1,fd=267)) udp UNCONN 0 0 0.0.0.0:42159 0.0.0.0:* users:(("io.upnp.0",pid=280800,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=280800,fd=31)) udp UNCONN 0 0 *:7775 *:* users:(("hannah-proxy",pid=1332,fd=9)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=7),("systemd",pid=1,fd=269)) udp UNCONN 0 0 [fe80::6e4b:90ff:fe46:83a9]%enp0s31f6:dhcpv6-client [::]:* users:(("systemd-network",pid=891,fd=35)) tcp LISTEN 0 4096 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=19)) tcp LISTEN 0 2048 192.168.178.122:http-alt 0.0.0.0:* users:(("python",pid=1043,fd=8)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=1008,fd=3)) tcp LISTEN 0 4096 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=8391,fd=3),("systemd",pid=1,fd=240)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=4),("systemd",pid=1,fd=266)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=276931,fd=29)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=276931,fd=23)) tcp LISTEN 0 511 0.0.0.0:1884 0.0.0.0:* users:(("io.mqtt.0",pid=279163,fd=35)) tcp LISTEN 0 511 0.0.0.0:1887 0.0.0.0:* users:(("io.sonoff.0",pid=279630,fd=40)) tcp LISTEN 0 511 0.0.0.0:1888 0.0.0.0:* users:(("io.mqtt.2",pid=279862,fd=35)) tcp LISTEN 0 511 0.0.0.0:1889 0.0.0.0:* users:(("io.mqtt.2",pid=279862,fd=36)) tcp LISTEN 0 4096 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=17)) tcp LISTEN 0 2048 0.0.0.0:5000 0.0.0.0:* users:(("gunicorn",pid=96468,fd=3),("gunicorn",pid=1377,fd=3),("gunicorn",pid=1334,fd=3)) tcp LISTEN 0 511 192.168.178.122:1882 0.0.0.0:* users:(("io.shelly.1",pid=279500,fd=36)) tcp LISTEN 0 511 *:2323 *:* users:(("io.fullybrowser",pid=278388,fd=30)) tcp LISTEN 0 4096 [::]:ssh [::]:* users:(("sshd",pid=8391,fd=4),("systemd",pid=1,fd=241)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=6),("systemd",pid=1,fd=268)) tcp LISTEN 0 4096 *:50060 *:* users:(("hannah-logcolle",pid=1331,fd=7)) tcp LISTEN 0 4096 *:50051 *:* users:(("python",pid=1335,fd=22)) tcp LISTEN 0 511 *:8083 *:* users:(("io.web.0",pid=280457,fd=35)) tcp LISTEN 0 511 *:8084 *:* users:(("io.socketio.0",pid=280262,fd=34)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=1008,fd=41)) tcp LISTEN 0 511 *:8087 *:* users:(("io.ws.0",pid=280477,fd=34)) *** Log File - Last 25 Lines *** 2026-09-30 22:02:39.808 - warn: reolink.0 (280191) State "reolink.0.Device.Name" has no existing object, this might lead to an error in future versions 2026-09-30 22:02:42.834 - warn: sourceanalytix.0 (280283) This instance has 18273 objects, the limit for this instance is set to 5000. 2026-09-30 22:02:42.844 - error: tuya.0 (279686) Login for MQTT failed: TypeError: Cannot destructure property 'access_token' of 'res.result' as it is undefined. 2026-09-30 22:02:43.222 - error: sourceanalytix.0 (280283) Selected Type Gas does not exist in Price Definitions 2026-09-30 22:02:43.223 - error: sourceanalytix.0 (280283) Please choose proper type for state 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand 2026-09-30 22:02:43.223 - error: sourceanalytix.0 (280283) Or add price definition Gas in adapter settings 2026-09-30 22:02:43.223 - error: sourceanalytix.0 (280283) Cannot handle calculations for 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand, check log messages and adjust settings! 2026-09-30 22:02:43.224 - error: sourceanalytix.0 (280283) Initialization of 0_userdata.0.Haus.Gaszaehler.gaszaehlerStand failed, check warn messages ! 2026-09-30 22:03:15.096 - error: linux-control.0 (280538) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2026-09-30 22:03:31.655 - error: reolink.1 (280975) Error: connect ECONNREFUSED 192.168.178.66:80: ECONNREFUSED 2026-09-30 22:03:41.412 - warn: iot.0 (281542) Your ioBroker IoT license will expire in 4 day(s) on Sat Oct 03 2026. Please renew your license to continue using all features without interruption. 2026-09-30 22:03:53.203 - warn: energiefluss-erweitert.1 (284247) Workspace configuration is NOT password protected! 2026-09-30 22:04:07.119 - error: sourceanalytix.0 (280283) Check settings for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower ! Known valueAtDeviceReset : (176903.80000000016) > known cumulative value (176262.80000000016) cannot proceed 2026-09-30 22:04:07.120 - error: sourceanalytix.0 (280283) Troubleshoot Data mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower custom Data : {"_id":"mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower","common":{"name":"inverter-Solar/Homy-800/ch0/MaxPower","write":true,"read":true,"role":"variable","desc":"mqtt server variable","type":"number","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":176903.80000000016,"start_week":176903.80000000016,"start_month":175416.10000000018,"start_quarter":122587.40000000001,"start_year":10440.599999999997,"alias":"Solar hm-800","consumption":true,"meter_values":true,"costs":true,"selectedPrice":"ElectricityDelivery","valueAtDeviceReset":176903.80000000016,"valueAtDeviceInit":106.4,"cumulativeValue":176903.80000000016}}},"native":{"topic":"inverter-Solar/Homy-800/ch0/MaxPower"},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1787584996560} 2026-09-30 22:04:07.121 - error: sourceanalytix.0 (280283) Cannot handle calculations for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower, check log messages and adjust settings! 2026-09-30 22:04:07.121 - error: sourceanalytix.0 (280283) Initialization of mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower failed, check warn messages ! 2026-09-30 22:04:07.173 - error: sourceanalytix.0 (280283) Check settings for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay ! Known valueAtDeviceReset : (1120.1749999999993) > known cumulative value (1117.1789999999992) cannot proceed 2026-09-30 22:04:07.173 - error: sourceanalytix.0 (280283) Troubleshoot Data sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay custom Data : {"type":"state","common":{"name":"01_currentDay","type":"number","role":"value","read":true,"write":false,"unit":"kWh","def":0,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":1120.1749999999993,"start_week":1110.508999999999,"start_month":1101.817999999999,"start_quarter":995.2539999999998,"start_year":584.993,"alias":"solar","selectedPrice":"ElectricityDelivery","consumption":true,"meter_values":true,"valueAtDeviceReset":1120.1749999999993,"valueAtDeviceInit":0,"cumulativeValue":1120.1749999999993}}},"native":{},"_id":"sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1790798646969} 2026-09-30 22:04:07.173 - error: sourceanalytix.0 (280283) Cannot handle calculations for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay, check log messages and adjust settings! 2026-09-30 22:04:07.174 - error: sourceanalytix.0 (280283) Initialization of sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay failed, check warn messages ! 2026-09-30 22:04:07.180 - warn: sourceanalytix.0 (280283) Cannot handle calculations for 3 of 15 enabled states, check error messages 2026-09-30 22:04:16.523 - error: parcel.0 (284210) https://www.dhl.de/int-aviseanzeigen/advices?width=414 2026-09-30 22:04:16.524 - error: parcel.0 (284210) [Update/fetch] GET https://www.dhl.de/int-aviseanzeigen/advices?width=414 → ERR_BAD_RESPONSE (Request failed with status code 500) 2026-09-30 22:04:16.525 - error: parcel.0 (284210) [Update/fetch] body: [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 22:04:16.525 - error: parcel.0 (284210) [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}]============= Mark until here for C&P =============
iob diag has finished.
erledigt
iob start admin.0
sagt nichts
peter@iob:~$ iob start admin.0 peter@iob:~$ iob status iobroker is running on this host. Objects type: jsonl States type: jsonl peter@iob:~$ iob status all iobroker is running on this host. Instance "admin.0" is not running Instance "backitup.0" is running Instance "alias-manager.0" is not running Instance "energiefluss-erweitert.0" is running Instance "history.0" is running Instance "influxdb.0" is running Instance "javascript.0" is running Instance "mqtt.0" is running Instance "opendtu.0" is running Instance "pvforecast.0" is not running Instance "smartmeter.0" is running Instance "statistics.0" is running Instance "viessmann.0" is not running Instance "web.0" is running Instance "zendure-solarflow.0" is running Instance "mqtt-client.0" is running -
@Thomas-Braun
Was ist denn:
Haste den admin mal aus dem GitHub gefischt?
Versuch den nochmal zu installieren:
iob upgrade admin@stableoder
iob upgrade admin@8.0.14 -
Nach einem Update des Betriebssystems (Ubuntu) und einem Iob Fix startet der Iobrokerzwar aber ich komme nicht mehr auf die Admin oberfläche
Adaptername: ... js-controller
Link zu Adapterrepository: www.github.com...
Adapterversion: ...7.2.2
js-controller Version: ...7.2.2
Admin Version: ...8.0.14
Hardwaresystem: Mini PC
Arbeitsspeicher: ...16GB
Festplattenart: SSD,
Betriebssystem: Ubuntu 26.04.1 LTSnode -v
Nodejs-Version: ...v22.23.2
NPM-Version: ...10.9.8
Installationsart: Manuell
Image, Docker genutzt: Nein
Ort, Name der Imagedatei: ...
Linux User bitte hier den Output von iob diag einfügen.
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Ubuntu 26.04.1 LTS Static hostname: iob Icon name: computer-desktop Chassis: desktop 🖥 Kernel: Linux 7.0.0-34-generic Architecture: x86-64 Hardware Vendor: Lenovo Hardware Model: ThinkCentre M710q Hardware SKU: LENOVO_MT_10MR_BU_LENOVO_FM_ThinkCentre M710q Firmware Version: M1AKT30A Firmware Date: Wed 2018-01-03 Firmware Age: 8y 8month 3w 6d OS is similar to: debian model name : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz Docker : false Virtualization : none Unknown Kernel : x86_64 Userland : 64bit System was installed 626 days ago (on 2025-01-12). Systemuptime and Load: 21:37:37 up 1:41, 1 user, load average: 1.42, 1.97, 2.34 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Ubuntu LTS release codenamed 'resolute'! *** TIME AND TIMEZONES *** Local time: Wed 2026-09-30 21:37:37 CEST Universal time: Wed 2026-09-30 19:37:37 UTC RTC time: Wed 2026-09-30 19:37:37 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iob HOME=/home/iob GROUPS=iob adm cdrom sudo dip plugdev lxd iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 6.7G 8.3G 2.6M 1.5G 9.4G Swap: 4.3G 101M 4.2G Total: 20G 6.8G 12G Active iob-Instances: 54 15363 M total memory 6379 M used memory 1528 M active memory 5141 M inactive memory 7906 M free memory 33 M buffer memory 1380 M swap cache 4095 M total swap 96 M used swap 3999 M free swap *** top - Table Of Processes *** top - 21:37:38 up 1:41, 1 user, load average: 1.42, 1.97, 2.34 Tasks: 235 total, 1 running, 234 sleeping, 0 stopped, 0 zombie %Cpu(s): 10.0 us, 4.0 sy, 0.0 ni, 82.0 id, 2.0 wa, 0.0 hi, 2.0 si, 0.0 st MiB Mem : 15364.0 total, 7906.3 free, 6379.3 used, 1414.1 buff/cache MiB Swap: 4096.0 total, 3999.4 free, 96.6 used. 8984.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * motioneye.service loaded failed failed motionEye Server Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 1.6G 1.5M 1.5G 1% /run efivarfs efivarfs 256K 56K 196K 22% /sys/firmware/efi/efivars /dev/mapper/ubuntu--vg-ubuntu--lv ext4 98G 57G 36G 62% / tmpfs tmpfs 7.6G 4.0K 7.6G 1% /dev/shm none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-resolved.service tmpfs tmpfs 128M 0 128M 0% /mnt/hannah_mem tmpfs tmpfs 7.6G 3.4M 7.5G 1% /tmp /dev/sda2 ext4 2.0G 249M 1.6G 14% /boot /dev/sda1 vfat 1.1G 6.4M 1.1G 1% /boot/efi none tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-networkd.service none tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 1.6G 8.0K 1.6G 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Wed Sep 30 19:55:51 2026] Btrfs loaded, zoned=yes, fsverity=yes [Wed Sep 30 19:55:51 2026] EXT4-fs (dm-0): mounted filesystem 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e ro with ordered data mode. Quota mode: none. [Wed Sep 30 19:55:52 2026] systemd[1]: /usr/lib/systemd/system/system-xfs_scrub.slice:15: Support for option CPUAccounting= has been removed and it is ignored [Wed Sep 30 19:55:52 2026] systemd[1]: Created slice system-xfs_scrub.slice - xfs_scrub background service slice. [Wed Sep 30 19:55:52 2026] EXT4-fs (dm-0): re-mounted 7e3bed9d-e102-4b6b-8a23-ede8e3f8c64e r/w. [Wed Sep 30 19:55:54 2026] EXT4-fs (sda2): mounted filesystem b861858a-b19e-4131-a0e3-fc3a2d28be18 r/w with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/core24/1643 /dev/loop0 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/core24/2124 /dev/loop1 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3579 /dev/loop2 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27710 /dev/loop3 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/docker/3613 /dev/loop4 squashfs ro,nodev,relatime,errors=continue,threads=single |-/snap/snapd/27738 /dev/loop5 squashfs ro,nodev,relatime,errors=continue,threads=single `-/boot /dev/sda2 ext4 rw,relatime `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 6.9G /var/ 5.6G /var/log 4.0G /var/log/journal/e8a87e3a1d4745f58598c1733b85f896 4.0G /var/log/journal 1.2G /var/lib Archived and active journals take up 3.9G in the file system. /opt/iobroker/backups: 26G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 4.9G /opt/iobroker/iobroker-data/ 3.9G /opt/iobroker/iobroker-data/history 679M /opt/iobroker/iobroker-data/files 217M /opt/iobroker/iobroker-data/backup-objects 106M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 89M /opt/iobroker/iobroker-data/states.jsonl 73M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/hannah.admin/build/index.js.map 22M /opt/iobroker/iobroker-data/files/residents.admin/build/index.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307YK6K-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...d3e33719c2d21c-if00-port0 ...d3e33719c2d21c-if00-port0 ✓ Matching ..._UART_D307YK6K-if00-port0 ✗ Not matching *** NodeJS-Installation *** /usr/bin/nodejs v22.23.2 /usr/bin/node v22.23.2 /usr/bin/npm 10.9.8 /usr/bin/npx 10.9.8 ✓ Node.js installation is correct nodejs: Installed: 22.23.2-1nodesource1 Candidate: 22.23.2-1nodesource1 Version table: *** 22.23.2-1nodesource1 100 100 /var/lib/dpkg/status 22.22.1+dfsg+~cs22.19.15-1ubuntu1 500 500 http://de.archive.ubuntu.com/ubuntu resolute/universe amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: Mini-pc-Master Mini-pc-Master (version: 7.2.2, hostname: Mini-pc-Master, alive, uptime: 1102) Core adapters versions js-controller: 7.2.2 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 11 +-- @iobroker/type-detector@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.type-detector.git#bef8c38d3c7749781fe92aa32da6437d02d453d5) +-- iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#105b168bc40c34d10e98cfb26b885ca9e00c6e69) | +-- nan@2.22.0 (git+ssh://git@github.com/JCMais/nan.git#0ec2eca8b2fd7518affb3945d087e393ad839b7e) +-- iobroker.hoymiles-wifi@0.2.7 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#8260d47b5f69cada23977a45c53a1befb6f585ea) +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946) +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059) +-- iobroker.parcel@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#3c4fb0ea5aa15a0d49a52f2fbd2546a836169fec) +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f) +-- iobroker.spotify-premium@3.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.spotify-premium.git#cbfe89f8f04f2f05913bce18cb5f8b41350d212d) +-- iobroker.statistics@5.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.statistics.git#db6d21fc130c630147ac159785f10eb9b77f68a8) +-- iobroker.vis-materialdesign@0.5.93 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#31b045e7c1ba599cf4005803636593de91334143) Adapter State system.adapter.accuweather.0 : accuweather : Mini-pc-Master - disabled system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : Mini-pc-Master - enabled system.adapter.alexa2.0 : alexa2 : Mini-pc-Master - disabled system.adapter.alias-manager.0 : alias-manager : Mini-pc-Master - disabled + system.adapter.backitup.0 : backitup : Mini-pc-Master - enabled + system.adapter.ble.0 : ble : Mini-pc-Master - enabled system.adapter.chromecast.0 : chromecast : Mini-pc-Master - disabled + system.adapter.cloud.0 : cloud : Mini-pc-Master - enabled + system.adapter.daswetter.0 : daswetter : Mini-pc-Master - enabled + system.adapter.device-reminder.0 : device-reminder : Mini-pc-Master - enabled + system.adapter.device-watcher.0 : device-watcher : Mini-pc-Master - enabled system.adapter.devices.0 : devices : Mini-pc-Master - disabled + system.adapter.discovery.0 : discovery : Mini-pc-Master - enabled system.adapter.dwd.0 : dwd : Mini-pc-Master - enabled + system.adapter.echarts.0 : echarts : Mini-pc-Master - enabled + system.adapter.email.0 : email : Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Mini-pc-Master - enabled + system.adapter.energiefluss.0 : energiefluss : Mini-pc-Master - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : Mini-pc-Master - enabled + system.adapter.fritzdect.0 : fritzdect : Mini-pc-Master - enabled + system.adapter.fullybrowser.0 : fullybrowser : Mini-pc-Master - enabled + system.adapter.hannah.0 : hannah : Mini-pc-Master - enabled + system.adapter.history.0 : history : Mini-pc-Master - enabled system.adapter.hoymiles-wifi.0 : hoymiles-wifi : Mini-pc-Master - disabled system.adapter.ical.0 : ical : Mini-pc-Master - enabled system.adapter.ical.1 : ical : Mini-pc-Master - enabled system.adapter.icons-icons8.0 : icons-icons8 : Mini-pc-Master - disabled system.adapter.icons-material-png.0 : icons-material-png : Mini-pc-Master - disabled system.adapter.icons-material-svg.0 : icons-material-svg : Mini-pc-Master - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : Mini-pc-Master - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Mini-pc-Master - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Mini-pc-Master - disabled + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.info.0 : info : Mini-pc-Master - enabled + system.adapter.iot.0 : iot : Mini-pc-Master - enabled + system.adapter.javascript.0 : javascript : Mini-pc-Master - enabled + system.adapter.linux-control.0 : linux-control : Mini-pc-Master - enabled + system.adapter.logparser.0 : logparser : Mini-pc-Master - enabled system.adapter.matter.0 : matter : Mini-pc-Master - disabled system.adapter.motioneye.0 : motioneye : Mini-pc-Master - disabled + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 system.adapter.mqtt.1 : mqtt : Mini-pc-Master - disabled, port: 1885, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.nina.0 : nina : Mini-pc-Master - enabled + system.adapter.parcel.0 : parcel : Mini-pc-Master - enabled + system.adapter.ping.0 : ping : Mini-pc-Master - enabled system.adapter.radar2.0 : radar2 : Mini-pc-Master - disabled + system.adapter.reolink.0 : reolink : Mini-pc-Master - enabled + system.adapter.reolink.1 : reolink : Mini-pc-Master - enabled + system.adapter.residents.0 : residents : Mini-pc-Master - enabled + system.adapter.rpi2.0 : rpi2 : Mini-pc-Master - enabled system.adapter.rpi2.1 : rpi2 : pi-3 - disabled + system.adapter.sayit.0 : sayit : Mini-pc-Master - enabled system.adapter.sayit.1 : sayit : Mini-pc-Master - disabled + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 system.adapter.smartcontrol.0 : smartcontrol : Mini-pc-Master - disabled + system.adapter.smartmeter.0 : smartmeter : Mini-pc-Master - enabled + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : Mini-pc-Master - enabled system.adapter.spotify-premium.0 : spotify-premium : Mini-pc-Master - disabled + system.adapter.sql.0 : sql : Mini-pc-Master - enabled + system.adapter.statistics.0 : statistics : Mini-pc-Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : Mini-pc-Master - enabled + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : Mini-pc-Master - enabled + system.adapter.tr-064.0 : tr-064 : Mini-pc-Master - enabled + system.adapter.trashschedule.0 : trashschedule : Mini-pc-Master - enabled + system.adapter.tuya.0 : tuya : Mini-pc-Master - enabled + system.adapter.upnp.0 : upnp : Mini-pc-Master - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Mini-pc-Master - disabled system.adapter.vis-2.0 : vis-2 : Mini-pc-Master - disabled system.adapter.vis-bars.0 : vis-bars : Mini-pc-Master - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Mini-pc-Master - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : Mini-pc-Master - disabled system.adapter.vis-history.0 : vis-history : Mini-pc-Master - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Mini-pc-Master - disabled system.adapter.vis-icontwo.0 : vis-icontwo : Mini-pc-Master - disabled system.adapter.vis-inventwo.0 : vis-inventwo : Mini-pc-Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Mini-pc-Master - disabled system.adapter.vis-justgage.0 : vis-justgage : Mini-pc-Master - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : Mini-pc-Master - disabled system.adapter.vis-metro.0 : vis-metro : Mini-pc-Master - disabled system.adapter.vis-players.0 : vis-players : Mini-pc-Master - disabled system.adapter.vis-plumb.0 : vis-plumb : Mini-pc-Master - enabled system.adapter.vis-rgraph.0 : vis-rgraph : Mini-pc-Master - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : Mini-pc-Master - disabled system.adapter.vis.0 : vis : Mini-pc-Master - enabled system.adapter.weatherunderground.0 : weatherunderground : Mini-pc-Master - enabled + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.yr.0 : yr : Mini-pc-Master - enabled + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : Mini-pc-Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : Mini-pc-Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : Mini-pc-Master - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.mqtt.2 : mqtt : Mini-pc-Master - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : Mini-pc-Master - enabled, port: 1882, bind: 192.168.178.122 + system.adapter.socketio.0 : socketio : Mini-pc-Master - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : Mini-pc-Master - enabled, port: 1887, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : Mini-pc-Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : Mini-pc-Master - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : Mini-pc-Master - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : Mini-pc-Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3664bc6c5486ec1190d3e33719c2d21c-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.accuweather' │ 'accuweather' │ '2.3.0' │ 'none' │ │ 1 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 2 │ 'system.adapter.alarm' │ 'alarm' │ '5.0.1' │ 'none' │ │ 3 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 4 │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0' │ 'none' │ │ 5 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 6 │ 'system.adapter.ble' │ 'ble' │ '0.14.0' │ 'none' │ │ 7 │ 'system.adapter.chromecast' │ 'chromecast' │ '4.2.0' │ 'none' │ │ 8 │ 'system.adapter.cloud' │ 'cloud' │ '6.0.1' │ 'none' │ │ 9 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.9' │ 'none' │ │ 10 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 11 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 12 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 13 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 14 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 15 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 16 │ 'system.adapter.email' │ 'email' │ '3.0.0' │ 'none' │ │ 17 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 18 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 19 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 20 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 21 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 22 │ 'system.adapter.hannah' │ 'hannah' │ '1.5.0' │ 'none' │ │ 23 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 24 │ 'system.adapter.hoymiles-wifi' │ 'hoymiles-wifi' │ '0.2.6' │ 'none' │ │ 25 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 26 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 27 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 28 │ 'system.adapter.icons-material-svg' │ 'icons-material-svg' │ '0.1.0' │ 'none' │ │ 29 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 30 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 31 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3' │ 'none' │ │ 32 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 33 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 34 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 35 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 36 │ 'system.adapter.linux-control' │ 'linux-control' │ '1.1.5' │ 'none' │ │ 37 │ 'system.adapter.logparser' │ 'logparser' │ '2.5.0' │ 'none' │ │ 38 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 39 │ 'system.adapter.motioneye' │ 'motioneye' │ '1.3.1' │ 'none' │ │ 40 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 41 │ 'system.adapter.nina' │ 'nina' │ '0.0.26' │ 'none' │ │ 42 │ 'system.adapter.parcel' │ 'parcel' │ '0.3.3' │ 'none' │ │ 43 │ 'system.adapter.ping' │ 'ping' │ '2.2.4' │ 'none' │ │ 44 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 45 │ 'system.adapter.reolink' │ 'reolink' │ '1.4.2' │ 'none' │ │ 46 │ 'system.adapter.residents' │ 'residents' │ '1.1.1' │ 'none' │ │ 47 │ 'system.adapter.rpi2' │ 'rpi2' │ '2.4.0' │ 'none' │ │ 48 │ 'system.adapter.sayit' │ 'sayit' │ '5.1.0' │ 'none' │ │ 49 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 50 │ 'system.adapter.smartcontrol' │ 'smartcontrol' │ '2.0.1' │ 'none' │ │ 51 │ 'system.adapter.smartmeter' │ 'smartmeter' │ '3.4.0' │ 'none' │ │ 52 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 53 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 54 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 55 │ 'system.adapter.spotify-premium' │ 'spotify-premium' │ '3.0.1' │ 'none' │ │ 56 │ 'system.adapter.sql' │ 'sql' │ '3.0.1' │ 'none' │ │ 57 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 58 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 59 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 60 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 61 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 62 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 63 │ 'system.adapter.tuya' │ 'tuya' │ '3.17.0' │ 'none' │ │ 64 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 65 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 66 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 67 │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1' │ 'none' │ │ 68 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 69 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 70 │ 'system.adapter.vis-fancyswitch' │ 'vis-fancyswitch' │ '1.1.0' │ 'none' │ │ 71 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 72 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 73 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 74 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 75 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 76 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 77 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.93' │ 'none' │ │ 78 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 79 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 80 │ 'system.adapter.vis-plumb' │ 'vis-plumb' │ '1.0.2' │ 'none' │ │ 81 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 82 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 83 │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0' │ 'none' │ │ 84 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 85 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 86 │ 'system.adapter.yr' │ 'yr' │ '5.3.0' │ 'none' │ │ 87 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "accuweather" : 2.3.0 , installed 2.3.0 Adapter "admin" : 8.0.14 , installed 8.0.14 Adapter "alarm" : 5.0.1 , installed 5.0.1 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "chromecast" : 4.2.0 , installed 4.2.0 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.9 , installed 4.5.9 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 3.0.0 , installed 3.0.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "logparser" : 2.5.0 , installed 2.5.0 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "motioneye" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "nina" : 0.0.25 , installed 0.0.26 Adapter "ping" : 3.0.1 , installed 2.2.4 [Updatable] Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "reolink" : 1.4.2 , installed 1.4.2 Adapter "residents" : 1.1.1 , installed 1.1.1 Adapter "rpi2" : 3.0.2 , installed 2.4.0 [Updatable] Adapter "sayit" : 5.1.0 , installed 5.1.0 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "spotify-premium": 3.0.1 , installed 3.0.1 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.93 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 40397 States: 35698 *** OS-Repositories and Updates *** Hit:1 http://de.archive.ubuntu.com/ubuntu resolute InRelease Hit:2 http://de.archive.ubuntu.com/ubuntu resolute-updates InRelease Hit:3 http://de.archive.ubuntu.com/ubuntu resolute-backports InRelease Hit:4 http://security.ubuntu.com/ubuntu resolute-security InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.122:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=193429,fd=72)) udp UNCONN 0 0 0.0.0.0:coap 0.0.0.0:* users:(("io.shelly.0",pid=193134,fd=36)) udp UNCONN 0 0 0.0.0.0:6666 0.0.0.0:* users:(("io.tuya.0",pid=193481,fd=44)) udp UNCONN 0 0 0.0.0.0:6667 0.0.0.0:* users:(("io.tuya.0",pid=193481,fd=45)) udp UNCONN 0 0 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=18)) udp UNCONN 0 0 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=16)) udp UNCONN 0 0 192.168.178.122%enp0s31f6:bootpc 0.0.0.0:* users:(("systemd-network",pid=891,fd=37)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=5),("systemd",pid=1,fd=267)) udp UNCONN 0 0 0.0.0.0:57768 0.0.0.0:* users:(("io.upnp.0",pid=195656,fd=30)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("io.upnp.0",pid=195656,fd=31)) udp UNCONN 0 0 *:7775 *:* users:(("hannah-proxy",pid=1332,fd=9)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=7),("systemd",pid=1,fd=269)) udp UNCONN 0 0 [fe80::6e4b:90ff:fe46:83a9]%enp0s31f6:dhcpv6-client [::]:* users:(("systemd-network",pid=891,fd=35)) tcp LISTEN 0 4096 127.0.0.54:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=19)) tcp LISTEN 0 2048 192.168.178.122:http-alt 0.0.0.0:* users:(("python",pid=1043,fd=8)) tcp LISTEN 0 4096 127.0.0.1:omniorb 0.0.0.0:* users:(("influxd",pid=1008,fd=3)) tcp LISTEN 0 4096 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=8391,fd=3),("systemd",pid=1,fd=240)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=787,fd=4),("systemd",pid=1,fd=266)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=191165,fd=29)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=191165,fd=23)) tcp LISTEN 0 511 0.0.0.0:1884 0.0.0.0:* users:(("io.mqtt.0",pid=192946,fd=35)) tcp LISTEN 0 511 0.0.0.0:1887 0.0.0.0:* users:(("io.sonoff.0",pid=193393,fd=40)) tcp LISTEN 0 511 0.0.0.0:1888 0.0.0.0:* users:(("io.mqtt.2",pid=194550,fd=35)) tcp LISTEN 0 511 0.0.0.0:1889 0.0.0.0:* users:(("io.mqtt.2",pid=194550,fd=36)) tcp LISTEN 0 4096 127.0.0.53%lo:domain 0.0.0.0:* users:(("systemd-resolve",pid=432,fd=17)) tcp LISTEN 0 2048 0.0.0.0:5000 0.0.0.0:* users:(("gunicorn",pid=96468,fd=3),("gunicorn",pid=1377,fd=3),("gunicorn",pid=1334,fd=3)) tcp LISTEN 0 511 192.168.178.122:1882 0.0.0.0:* users:(("io.shelly.1",pid=193266,fd=36)) tcp LISTEN 0 511 *:2323 *:* users:(("io.fullybrowser",pid=192725,fd=30)) tcp LISTEN 0 4096 [::]:ssh [::]:* users:(("sshd",pid=8391,fd=4),("systemd",pid=1,fd=241)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=787,fd=6),("systemd",pid=1,fd=268)) tcp LISTEN 0 4096 *:50060 *:* users:(("hannah-logcolle",pid=1331,fd=7)) tcp LISTEN 0 4096 *:50051 *:* users:(("python",pid=1335,fd=22)) tcp LISTEN 0 511 *:8083 *:* users:(("io.web.0",pid=195518,fd=35)) tcp LISTEN 0 511 *:8084 *:* users:(("io.socketio.0",pid=195380,fd=34)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=1008,fd=41)) tcp LISTEN 0 511 *:8087 *:* users:(("io.ws.0",pid=195532,fd=34)) *** Log File - Last 25 Lines *** 2026-09-30 21:23:45.278 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.279 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.283 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.285 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.314 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.317 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.322 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.322 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.339 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:45.340 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:47.101 - warn: hannah.0 (196283) [satellites] Satellite satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:47.179 - warn: hannah.0 (196283) [satellites] Satellite Test-satellite-01 has no room assigned — skipping state creation 2026-09-30 21:23:55.041 - error: parcel.0 (196107) https://www.dhl.de/int-aviseanzeigen/advices?width=414 2026-09-30 21:23:55.042 - error: parcel.0 (196107) [Update/fetch] GET https://www.dhl.de/int-aviseanzeigen/advices?width=414 → ERR_BAD_RESPONSE (Request failed with status code 500) 2026-09-30 21:23:55.043 - error: parcel.0 (196107) [Update/fetch] body: [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 21:23:55.043 - error: parcel.0 (196107) [{"headline":"Aktuell steht der Service leider nicht zur Verfügung.","message":"Wir arbeiten mit Hochdruck daran, dass Briefankündigungen wieder angezeigt werden. Wir bitten um Entschuldigung."}] 2026-09-30 21:24:08.787 - error: sourceanalytix.0 (195386) Check settings for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower ! Known valueAtDeviceReset : (176903.80000000016) > known cumulative value (176262.80000000016) cannot proceed 2026-09-30 21:24:08.787 - error: sourceanalytix.0 (195386) Troubleshoot Data mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower custom Data : {"_id":"mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower","common":{"name":"inverter-Solar/Homy-800/ch0/MaxPower","write":true,"read":true,"role":"variable","desc":"mqtt server variable","type":"number","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":176903.80000000016,"start_week":176903.80000000016,"start_month":175416.10000000018,"start_quarter":122587.40000000001,"start_year":10440.599999999997,"alias":"Solar hm-800","consumption":true,"meter_values":true,"costs":true,"selectedPrice":"ElectricityDelivery","valueAtDeviceReset":176903.80000000016,"valueAtDeviceInit":106.4,"cumulativeValue":176903.80000000016}}},"native":{"topic":"inverter-Solar/Homy-800/ch0/MaxPower"},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1787584996560} 2026-09-30 21:24:08.788 - error: sourceanalytix.0 (195386) Cannot handle calculations for mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower, check log messages and adjust settings! 2026-09-30 21:24:08.789 - error: sourceanalytix.0 (195386) Initialization of mqtt.0.inverter-Solar.Homy-800.ch0.MaxPower failed, check warn messages ! 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Check settings for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay ! Known valueAtDeviceReset : (1120.1749999999993) > known cumulative value (1117.1789999999992) cannot proceed 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Troubleshoot Data sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay custom Data : {"type":"state","common":{"name":"01_currentDay","type":"number","role":"value","read":true,"write":false,"unit":"kWh","def":0,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":1120.1749999999993,"start_week":1110.508999999999,"start_month":1101.817999999999,"start_quarter":995.2539999999998,"start_year":584.993,"alias":"solar","selectedPrice":"ElectricityDelivery","consumption":true,"meter_values":true,"valueAtDeviceReset":1120.1749999999993,"valueAtDeviceInit":0,"cumulativeValue":1120.1749999999993}}},"native":{},"_id":"sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1790796248575} 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Cannot handle calculations for sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay, check log messages and adjust settings! 2026-09-30 21:24:08.832 - error: sourceanalytix.0 (195386) Initialization of sourceanalytix.0.fritzdect__0__DECT_116300266000__power.currentYear.delivered.01_currentDay failed, check warn messages ! 2026-09-30 21:24:08.838 - warn: sourceanalytix.0 (195386) Cannot handle calculations for 3 of 15 enabled states, check error messages============= Mark until here for C&P =============
iob diag has finished.code_text
iob@iob:~$
Admin ist definitiv NICHT via Github installierbar .
Sieht für mich aber danach aus, als wenn das zumindest mal versucht worden ist und da irgendwas kleben geblieben ist.
Ich kenne das Modul auch gar nicht. Auf meinen Systemen ist es jedenfalls nicht installiert, schon gar nicht als git-Installation. -
Was ist denn:
iob upgrade admin@8.0.14@Thomas-Braun
Hab den Admin noch nie über Github installiert.Admin ist auf 8.0.14 und gestartet. Hilft aber auch nicht
@Thomas-Braun
Ausgaben vom drüber installieren?
iob@iob:~$ iob upgrade admin@stable Can not check version information to display upgrade infos: Invalid Version: stable Update admin from @8.0.14 to @stable Could not uninstall npm packet "iobroker.admin": Invalid Version: stable host.Mini-pc-Master Adapter "system.adapter.admin.0" is stopped. NPM version: 11.19.0 Installing iobroker.admin@stable... (System call) removed 1 package in 13s 420 packages are looking for funding run `npm fund` for details Updating objects from io-package.json for adapter "admin" with version "8.0.14" Update "system.adapter.admin.0" upload [41] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/mf-entry-bootstrap-0-5d5a409e.js custom/assets/mf-entry-bootstrap-0-5d5a409e.js application/javascript upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/mf-manifest.json custom/mf-manifest.json application/json upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json upload [3] admin.acode_textdmin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 host.Mini-pc-Master Adapter "system.adapter.admin.0" is started -
@Thomas-Braun
Hier wird dazu das von der KI gefunden:
Der Installationsweg: Wenn Sie – oder ein von Ihnen installiertes Skript/Beta-Update – den Admin-Adapter direkt über GitHub (z. B. den "Katzen"-Button im ioBroker-Admin) installiert haben, lädt ioBroker das gesamte Paket herunter. Node.js registriert dies intern dann unter dem Namen des Quellordners, welcher im GitHub-Repository admin-mono heißt.
@Thomas-Braun
Hatte ich doch gerade gemcht. Sorry falsch verstandeniob@iob:~$ iob upgrade admin@8.0.14 Would you like to reinstall version 8.0.14 of admin now? [(y)es, (n)o]: y Update admin from @8.0.14 to @8.0.14 Uninstall npm packet "iobroker.admin" for a clean re-installation removed 124 packages in 13s 411 packages are looking for funding run `npm fund` for details host.Mini-pc-Master Adapter "system.adapter.admin.0" is stopped. NPM version: 11.19.0 Installing iobroker.admin@8.0.14... (System call) added 124 packages in 20s 422 packages are looking for funding run `npm fund` for details Updating objects from io-package.json for adapter "admin" with version "8.0.14" Update "system.adapter.admin.0" upload [41] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/mf-entry-bootstrap-0-5d5a409e.js custom/assets/mf-entry-bootstrap-0-5d5a409e.js application/javascript upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/mf-manifest.json custom/mf-manifest.json application/json upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 host.Mini-pc-Master Adapter "system.adapter.admin.0" is started -
@Thomas-Braun
Hatte ich doch gerade gemcht. Sorry falsch verstandeniob@iob:~$ iob upgrade admin@8.0.14 Would you like to reinstall version 8.0.14 of admin now? [(y)es, (n)o]: y Update admin from @8.0.14 to @8.0.14 Uninstall npm packet "iobroker.admin" for a clean re-installation removed 124 packages in 13s 411 packages are looking for funding run `npm fund` for details host.Mini-pc-Master Adapter "system.adapter.admin.0" is stopped. NPM version: 11.19.0 Installing iobroker.admin@8.0.14... (System call) added 124 packages in 20s 422 packages are looking for funding run `npm fund` for details Updating objects from io-package.json for adapter "admin" with version "8.0.14" Update "system.adapter.admin.0" upload [41] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/mf-entry-bootstrap-0-5d5a409e.js custom/assets/mf-entry-bootstrap-0-5d5a409e.js application/javascript upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/mf-manifest.json custom/mf-manifest.json application/json upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 host.Mini-pc-Master Adapter "system.adapter.admin.0" is startedUnd dann setzt du jetzt die ganzen aus dem GitHub geangelten Adapter auf die jeweils aktuelle Version aus dem Repo. Damit da bei dem Chaos mal etwas aufgeräumt wird.
Da bin ich jetzt im Terminal etwas über fragt und weiß nicht wie das geht.
Die iobroker weboberfläche läuft ja auch noch nicht. -
Die iobroker weboberfläche läuft ja auch noch nicht.iob repo unset stable iob repo set beta iob update iob upgrade icons-open-icon-library-png@0.1.2 iob upgrade parcel@0.3.3 iob upgrade sourceanalytix@0.6.0 iob upgrade spotify-premium@3.0.1 iob upgrade iobroker.statistics@5.0.0 iob upgrade iobroker.vis-materialdesign@0.5.9 iob repo unset beta iob repo set stable iob updateUnd dann noch mal schauen.
