  4. unregelmäßig Unmotivierter Neustart aller Instanzen
45 Beiträge 9 Kommentatoren 769 Aufrufe 9 Beobachtet
  • R reutli
    Gerade eben wieder ein solcher "Absturz".
    Auffällig: Es passiert immer direkt nachdem die Repos abgefragt werden?!
    Irgendwas bekannt hierzu???
    2026-08-28 11:17:40.439 - info: admin.1 (324035) Request actual repository...
    2026-08-28 11:17:40.505 - info: admin.0 (323983) Request actual repository...
    2026-08-28 11:17:40.651 - info: host.iobroker-master Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2026-08-28 11:17:43.608 - info: admin.1 (324035) Repository received successfully.
    2026-08-28 11:17:43.847 - info: admin.0 (323983) Repository received successfully.
    2026-08-28 11:17:47.181 - info: admin.0 (323983) terminating http server on port 8081
    2026-08-28 11:17:47.182 - error: admin.1 (324035) States database error: read ECONNRESET
    2026-08-28 11:17:47.192 - info: device-watcher.0 (324422) cleaned everything up...
    2026-08-28 11:17:47.194 - error: admin.1 (324035) Objects database error: read ECONNRESET
    2026-08-28 11:17:47.219 - info: smartgarden.0 (325157) 1/ cleaned everything up...
    2026-08-28 11:17:47.207 - info: backitup.0 (324349) cleaned everything up...
    2026-08-28 11:17:47.219 - error: signal-cmb.0 (325259) States database error: read ECONNRESET
    2026-08-28 11:17:47.197 - error: unifi-network.0 (325301) Objects database error: read ECONNRESET
    2026-08-28 11:17:47.308 - info: jarvis.0 (325114) Adapter stopped und unloaded.
    2026-08-28 11:17:47.189 - error: hm-rpc.0 (324550) States database error: read ECONNRESET
    2026-08-28 11:17:47.249 - error: discovery.0 (324968) States database error: read ECONNRESET
    2026-08-28 11:17:47.365 - info: javascript.0 (324200) script.js.Allgemein.Ferien_setzen: Stopping script
    2026-08-28 11:17:51.798 - info: host.iobroker-master iobroker.js-controller version 7.2.2 js-controller starting
    2026-08-28 11:17:51.799 - info: host.iobroker-master Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2026-08-28 11:17:51.799 - info: host.iobroker-master hostname: iobroker-master, node: v22.23.2
    2026-08-28 11:17:51.799 - info: host.iobroker-master ip addresses: 192.168.13.25 fe80::18dc:e7ff:fe85:6b85
    2026-08-28 11:17:51.809 - warn: host.iobroker-master-Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    2026-08-28 11:17:52.395 - warn: host.iobroker-master-Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    2026-08-28 11:17:52.664 - info: host.iobroker-master connected to Objects and States
    2026-08-28 11:17:52.671 - info: host.iobroker-master added notifications configuration of host
    2026-08-28 11:17:53.731 - info: host.iobroker-master 53 instances found
    2026-08-28 11:17:53.750 - info: host.iobroker-master starting 45 instances
    2026-08-28 11:17:53.941 - info: host.iobroker-master Delete state "system.host.iobroker-master.versions.nodeCurrent"
    @reutli
    Active iob-Instances: 	46
              905 M total memory
    Wird viel zu viel sein.
    R 1 Antwort Letzte Antwort
      @reutli
                905 M total memory
      reutli
      @Thomas-Braun sagte:
      So wenig Speicher habe ich nur auf dem SLAVE (PI3) und soviele Instanzen nur auf dem Master. Keine Ahnung was Dein diag da ausgibt 😊 , aber:
      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
      *Wer freundlich ist, dem wird freundlich geholfen *
      • R reutli
        @reutli sagte:
        Die Gesamtzahl der laufenden Instanzen 'über alles'.
        Das ist ja nicht falsch.
        Weiter unten sieht man dann die Instanzen, die auf den jeweiligen Hosts laufen. Das sind in der Tat für den Host 'iobroker' nur 3 oder 4, allerdings mit node-red ggfls. ein 'Schwergewicht'.
          @reutli sagte:
          reutli
          Der sollte aber nicht das Problem darstellen. Der ist seit Uhrzeiten drauf und macht nur ienen Pull auf eine serielle Schnittselle.
          Warum aber der Absturz im beim Repo Abgleich stattfindet, fine ich ncoht interessanter (das letzte Mail diese Woche sah es im LOG genau gleich aus:
          Erst Repo Abgleich, dann Absturz
          • P Offline
            peterfido
            schrieb am zuletzt editiert von peterfido
            Hallo Leute,
            mein ioBroker hat diese Woche, wo ich natürlich im Urlaub war, das gleiche Verhalten gezeigt:
            2026-08-25 17:06:49.777 - info: admin.0 (1126) Repository received successfully.
            2026-08-25 17:06:52.544 - error: admin.0 (1126) Objects database error: read ECONNRESET
            2026-08-25 17:06:52.517 - info: ws.0 (2134) terminating http server on port 8084
            2026-08-25 17:06:52.546 - error: javascript.0 (1242) Objects database error: read ECONNRESET
            2026-08-25 17:06:52.539 - error: jeelink.0 (1923) Objects database error: read ECONNRESET
            2026-08-25 17:06:52.513 - info: socketio.0 (1961) terminating http server on port 8088
            2026-08-25 17:06:52.521 - info: simple-api.0 (1942) terminating http server on port 8087
            2026-08-25 17:06:52.553 - error: sourceanalytix.0 (2298) Objects database error: read ECONNRESET
            2026-08-25 17:06:52.550 - info: admin.0 (1126) terminating http server on port 8081
            2026-08-25 17:06:52.550 - info: admin.0 (1126) <== Disconnect system.user.admin from ::ffff:192.168.56.93 NodeRED-104
            2026-08-25 17:06:52.610 - info: sourceanalytix.0 (2298) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Alexa.Alexas: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Alexa.Freddie: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Alexa.Technik: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Beleuchtung.Licht: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Beleuchtung.Terrasse: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Beleuchtung.Urlaubsbeleuchtung: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Heizung.Heizmodus: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Heizung.HzgEsszimmer: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Heizung.HzgKueche: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Heizung.HzgWohnzimmer: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Heizung.Stromzaehler: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Heizung.USRIOTHzg: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Scripte.Ausschalten: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Scripte.CronJobs: Stopping script
            2026-08-25 17:06:52.569 - info: javascript.0 (1242) script.js.Scripte.Easy: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.Helligkeit: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.Main: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.NUC: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.Pioneer: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.Synology: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.USBSticks: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.USV: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.Unifi: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.Uptime: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.WatchDogs: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Scripte.vis: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Verschluss.Alarm: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Verschluss.Anwesenheit: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Verschluss.Kamerabild: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Verschluss.Klingel: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Verschluss.UnifiProtect: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.Verschluss.Verschluss: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.steckdosen.HMIP_Steckdosen: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.steckdosen.Steckdose1: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.steckdosen.Steckdose2: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.steckdosen.Steckdose3: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.steckdosen.Steckdose4: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.steckdosen.Steckdose5: Stopping script
            2026-08-25 17:06:52.572 - info: javascript.0 (1242) script.js.steckdosen.Tasmota: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Heizung.Temperaturen: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Scripte.Kalender: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Scripte.Wallbox: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.steckdosen.Schaltuhr: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Beleuchtung.Beleuchtung: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Heizung.HzgFrauke: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Beleuchtung.LichtTelegram0: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Scripte.NSPanels: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Scripte.Verbrauchskosten: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Skripte.Unifi_Alarm_Manager: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Beleuchtung.Lichterkette: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Verschluss.FullyAlarm: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Heizung.HzgPeter: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Heizung.HzgSchlafenOben: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Verschluss.Klingelbild_2025: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Scripte.Abfall: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Beleuchtung.Schlafen_oben: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Skripte.VIS_Haus: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Scripte.Markise: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Scripte.Easy_Watchdogs: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZEVU: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZGas: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZHerd: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZPV: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZSchlafenOben: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZWaschmaschine: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZWasser: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZArbeitszimmer: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.ZPumpeKeller: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.common.Wetter_com_4: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Zaehler.Z_Klima: Stopping script
            2026-08-25 17:06:52.573 - info: javascript.0 (1242) script.js.Scripte.Wettersymbole: Stopping script
            2026-08-25 17:06:52.568 - info: hm-rpc.2 (1681) xmlrpc -> 192.168.2.28:2010/ init ["http://192.168.2.24:12010",""]
            2026-08-25 17:06:52.664 - info: hm-rpc.2 (1681) Disconnected
            2026-08-25 17:06:52.534 - info: socketio.1 (1981) terminating http server on port 8085
            2026-08-25 17:06:57.512 - error: philips-tv.0 (2197) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:06:57.517 - error: philips-tv.0 (2197) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:06:57.517 - error: tankerkoenig.0 (2175) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:06:57.521 - error: tankerkoenig.0 (2175) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:06:57.527 - error: philips-tv.1 (2349) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:06:57.529 - error: hm-rpc.2 (1681) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:06:57.528 - error: philips-tv.1 (2349) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:06:57.528 - error: nspanel-lovelace-ui.0 (2400) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            Dann noch ganz viel Rotes im Log und irgendwann ein Neustart der Adapter.
            2026-08-25 17:08:22.563 - error: philips-tv.1 (2349) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.564 - warn: ❌ hm-rpc.2 (1681) Objects database disconnected
            2026-08-25 17:08:22.564 - error: philips-tv.1 (2349) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.564 - warn: ❌ philips-tv.1 (2349) Objects database disconnected
            2026-08-25 17:08:22.565 - warn: ❌ philips-tv.1 (2349) States database disconnected
            2026-08-25 17:08:22.565 - warn: philips-tv.1 (2349) get state error: Connection is closed.
            2026-08-25 17:08:22.565 - info: philips-tv.1 (2349) terminating
            2026-08-25 17:08:22.566 - info: philips-tv.1 (2349) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.566 - info: philips-tv.1 (2349) terminating
            2026-08-25 17:08:22.567 - warn: philips-tv.1 (2349) get state error: Connection is closed.
            2026-08-25 17:08:22.567 - info: philips-tv.1 (2349) terminating
            2026-08-25 17:08:22.565 - error: tankerkoenig.0 (2175) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.569 - error: s7.1 (1815) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.570 - error: nspanel-lovelace-ui.0 (2400) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.566 - error: tankerkoenig.0 (2175) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.567 - warn: ❌ tankerkoenig.0 (2175) Objects database disconnected
            2026-08-25 17:08:22.567 - warn: ❌ tankerkoenig.0 (2175) States database disconnected
            2026-08-25 17:08:22.567 - warn: tankerkoenig.0 (2175) get state error: Connection is closed.
            2026-08-25 17:08:22.567 - warn: tankerkoenig.0 (2175) get state error: DB closed
            2026-08-25 17:08:22.568 - info: tankerkoenig.0 (2175) terminating
            2026-08-25 17:08:22.568 - info: tankerkoenig.0 (2175) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.567 - error: hm-rpc.2 (1681) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.568 - warn: ❌ hm-rpc.2 (1681) States database disconnected
            2026-08-25 17:08:22.568 - warn: hm-rpc.2 (1681) get state error: Connection is closed.
            2026-08-25 17:08:22.568 - warn: hm-rpc.2 (1681) get state error: DB closed
            2026-08-25 17:08:22.568 - info: hm-rpc.2 (1681) terminating
            2026-08-25 17:08:22.570 - info: hm-rpc.2 (1681) terminating
            2026-08-25 17:08:22.571 - info: hm-rpc.2 (1681) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.570 - error: nspanel-lovelace-ui.0 (2400) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.570 - warn: ❌ nspanel-lovelace-ui.0 (2400) States database disconnected
            2026-08-25 17:08:22.571 - warn: nspanel-lovelace-ui.0 (2400) get state error: Connection is closed.
            2026-08-25 17:08:22.571 - info: nspanel-lovelace-ui.0 (2400) terminating
            2026-08-25 17:08:22.571 - info: nspanel-lovelace-ui.0 (2400) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.572 - warn: ❌ nspanel-lovelace-ui.0 (2400) Objects database disconnected
            2026-08-25 17:08:22.564 - error: philips-tv.0 (2197) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.566 - warn: ❌ philips-tv.0 (2197) States database disconnected
            2026-08-25 17:08:22.566 - warn: philips-tv.0 (2197) get state error: Connection is closed.
            2026-08-25 17:08:22.566 - info: philips-tv.0 (2197) terminating
            2026-08-25 17:08:22.567 - info: philips-tv.0 (2197) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.568 - info: philips-tv.0 (2197) terminating
            2026-08-25 17:08:22.572 - warn: ❌ philips-tv.0 (2197) Objects database disconnected
            2026-08-25 17:08:22.573 - warn: philips-tv.0 (2197) get state error: Connection is closed.
            2026-08-25 17:08:22.573 - info: philips-tv.0 (2197) terminating
            2026-08-25 17:08:22.570 - error: s7.1 (1815) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.570 - warn: ❌ s7.1 (1815) States database disconnected
            2026-08-25 17:08:22.570 - warn: s7.1 (1815) get state error: Connection is closed.
            2026-08-25 17:08:22.571 - warn: s7.1 (1815) get state error: DB closed
            2026-08-25 17:08:22.571 - info: s7.1 (1815) terminating
            2026-08-25 17:08:22.571 - info: s7.1 (1815) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.572 - warn: ❌ s7.1 (1815) Objects database disconnected
            2026-08-25 17:08:22.573 - warn: nspanel-lovelace-ui.0 (2400) get state error: Connection is closed.
            2026-08-25 17:08:22.573 - info: nspanel-lovelace-ui.0 (2400) terminating
            2026-08-25 17:08:22.579 - error: vis-2.0 (2254) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.579 - error: vis-2.0 (2254) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.579 - warn: ❌ vis-2.0 (2254) Objects database disconnected
            2026-08-25 17:08:22.579 - warn: ❌ vis-2.0 (2254) States database disconnected
            2026-08-25 17:08:22.580 - warn: vis-2.0 (2254) get state error: Connection is closed.
            2026-08-25 17:08:22.580 - warn: vis-2.0 (2254) get state error: DB closed
            2026-08-25 17:08:22.580 - info: vis-2.0 (2254) terminating
            2026-08-25 17:08:22.580 - info: vis-2.0 (2254) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.581 - error: hue.0 (1467) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.582 - error: telegram.1 (2214918) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.582 - warn: ❌ hue.0 (1467) Objects database disconnected
            2026-08-25 17:08:22.583 - error: socketio.1 (1981) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.583 - warn: ❌ socketio.1 (1981) Objects database disconnected
            2026-08-25 17:08:22.584 - error: socketio.1 (1981) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.585 - warn: ❌ socketio.1 (1981) States database disconnected
            2026-08-25 17:08:22.585 - warn: socketio.1 (1981) get state error: Connection is closed.
            2026-08-25 17:08:22.585 - warn: socketio.1 (1981) get state error: DB closed
            2026-08-25 17:08:22.585 - info: socketio.1 (1981) terminating
            2026-08-25 17:08:22.585 - info: socketio.1 (1981) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.582 - error: telegram.1 (2214918) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.583 - warn: ❌ telegram.1 (2214918) Objects database disconnected
            2026-08-25 17:08:22.584 - warn: ❌ telegram.1 (2214918) States database disconnected
            2026-08-25 17:08:22.584 - warn: telegram.1 (2214918) get state error: Connection is closed.
            2026-08-25 17:08:22.584 - info: telegram.1 (2214918) terminating
            2026-08-25 17:08:22.585 - info: telegram.1 (2214918) terminating
            2026-08-25 17:08:22.585 - info: telegram.1 (2214918) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.593 - error: hue.0 (1467) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.594 - warn: ❌ hue.0 (1467) States database disconnected
            2026-08-25 17:08:22.594 - warn: hue.0 (1467) get state error: Connection is closed.
            2026-08-25 17:08:22.594 - warn: hue.0 (1467) get state error: DB closed
            2026-08-25 17:08:22.594 - info: hue.0 (1467) terminating
            2026-08-25 17:08:22.595 - info: hue.0 (1467) terminating
            2026-08-25 17:08:22.595 - info: hue.0 (1467) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.602 - error: nut.0 (1524) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.602 - error: nut.0 (1524) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.603 - warn: ❌ nut.0 (1524) States database disconnected
            2026-08-25 17:08:22.604 - warn: nut.0 (1524) get state error: Connection is closed.
            2026-08-25 17:08:22.604 - warn: nut.0 (1524) get state error: DB closed
            2026-08-25 17:08:22.605 - info: nut.0 (1524) terminating
            2026-08-25 17:08:22.607 - info: nut.0 (1524) terminating
            2026-08-25 17:08:22.608 - info: nut.0 (1524) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.608 - warn: ❌ nut.0 (1524) Objects database disconnected
            2026-08-25 17:08:22.610 - error: nut.0 (1524) Can not update connected state: Error: DB closed
            2026-08-25 17:08:22.628 - error: jeelink.0 (1923) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.629 - error: jeelink.0 (1923) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.630 - warn: ❌ jeelink.0 (1923) States database disconnected
            2026-08-25 17:08:22.630 - warn: jeelink.0 (1923) get state error: Connection is closed.
            2026-08-25 17:08:22.630 - warn: jeelink.0 (1923) get state error: DB closed
            2026-08-25 17:08:22.630 - info: jeelink.0 (1923) terminating
            2026-08-25 17:08:22.631 - info: jeelink.0 (1923) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.631 - info: jeelink.0 (1923) terminating
            2026-08-25 17:08:22.631 - warn: ❌ jeelink.0 (1923) Objects database disconnected
            2026-08-25 17:08:22.632 - warn: jeelink.0 (1923) Could not perform strict object check of state jeelink.0.LaCrosse_1.newBatt: DB closed
            2026-08-25 17:08:22.632 - warn: jeelink.0 (1923) get state error: Connection is closed.
            2026-08-25 17:08:22.633 - error: jeelink.0 (1923) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.633 - error: jeelink.0 (1923) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.633 - error: jeelink.0 (1923) Error: DB closed
            at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
            at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:160:20)
            at Object.onceWrapper (node:events:634:26)
            at Socket.emit (node:events:519:28)
            at TCP. (node:net:347:12)
            2026-08-25 17:08:22.634 - error: jeelink.0 (1923) Error: DB closed
            2026-08-25 17:08:22.634 - error: jeelink.0 (1923) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.634 - error: jeelink.0 (1923) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.635 - error: jeelink.0 (1923) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.635 - error: jeelink.0 (1923) Error: DB closed
            2026-08-25 17:08:22.635 - error: jeelink.0 (1923) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.636 - error: jeelink.0 (1923) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.636 - error: chromecast.0 (1715) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.636 - error: jeelink.0 (1923) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.636 - error: jeelink.0 (1923) Error: DB closed
            at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
            at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
            at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2366:37)
            at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2407:29)
            at process.processImmediate (node:internal/timers:486:21)
            2026-08-25 17:08:22.638 - error: chromecast.0 (1715) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.640 - error: s7.0 (1698) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.640 - error: s7.0 (1698) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.641 - warn: ❌ s7.0 (1698) Objects database disconnected
            2026-08-25 17:08:22.641 - warn: ❌ s7.0 (1698) States database disconnected
            2026-08-25 17:08:22.641 - warn: s7.0 (1698) get state error: Connection is closed.
            2026-08-25 17:08:22.641 - warn: s7.0 (1698) get state error: DB closed
            2026-08-25 17:08:22.641 - info: s7.0 (1698) terminating
            2026-08-25 17:08:22.642 - info: s7.0 (1698) terminating
            2026-08-25 17:08:22.642 - info: s7.0 (1698) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.644 - error: simple-api.0 (1942) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.645 - warn: ❌ simple-api.0 (1942) States database disconnected
            2026-08-25 17:08:22.645 - warn: simple-api.0 (1942) get state error: Connection is closed.
            2026-08-25 17:08:22.645 - warn: simple-api.0 (1942) get state error: DB closed
            2026-08-25 17:08:22.645 - info: simple-api.0 (1942) terminating
            2026-08-25 17:08:22.645 - info: simple-api.0 (1942) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.646 - error: admin.0 (1126) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.647 - warn: ❌ admin.0 (1126) States database disconnected
            2026-08-25 17:08:22.647 - warn: admin.0 (1126) get state error: Connection is closed.
            2026-08-25 17:08:22.647 - warn: admin.0 (1126) get state error: DB closed
            2026-08-25 17:08:22.647 - info: admin.0 (1126) terminating
            2026-08-25 17:08:22.648 - info: admin.0 (1126) terminating
            2026-08-25 17:08:22.648 - info: admin.0 (1126) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.651 - error: sourceanalytix.0 (2298) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.649 - error: socketio.0 (1961) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.649 - error: simple-api.0 (1942) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.650 - warn: ❌ simple-api.0 (1942) Objects database disconnected
            2026-08-25 17:08:22.650 - error: simple-api.0 (1942) Cannot get state: Error: DB closed
            2026-08-25 17:08:22.651 - error: simple-api.0 (1942) Cannot get state: Error: DB closed
            2026-08-25 17:08:22.649 - warn: ❌ socketio.0 (1961) Objects database disconnected
            2026-08-25 17:08:22.650 - error: socketio.0 (1961) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.650 - warn: ❌ socketio.0 (1961) States database disconnected
            2026-08-25 17:08:22.650 - warn: socketio.0 (1961) get state error: Connection is closed.
            2026-08-25 17:08:22.650 - warn: socketio.0 (1961) get state error: DB closed
            2026-08-25 17:08:22.650 - info: socketio.0 (1961) terminating
            2026-08-25 17:08:22.651 - info: socketio.0 (1961) terminating
            2026-08-25 17:08:22.651 - info: socketio.0 (1961) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.651 - error: sourceanalytix.0 (2298) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.652 - warn: ❌ sourceanalytix.0 (2298) Objects database disconnected
            2026-08-25 17:08:22.652 - warn: ❌ sourceanalytix.0 (2298) States database disconnected
            2026-08-25 17:08:22.652 - warn: sourceanalytix.0 (2298) get state error: Connection is closed.
            2026-08-25 17:08:22.652 - warn: sourceanalytix.0 (2298) get state error: DB closed
            2026-08-25 17:08:22.652 - info: sourceanalytix.0 (2298) terminating
            2026-08-25 17:08:22.652 - info: sourceanalytix.0 (2298) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:22.662 - error: admin.0 (1126) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.662 - warn: ❌ admin.0 (1126) Objects database disconnected
            2026-08-25 17:08:22.663 - error: admin.0 (1126) Cannot add repository read timestamp: Error: DB closed
            2026-08-25 17:08:22.638 - error: chromecast.0 (1715) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.639 - error: chromecast.0 (1715) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.639 - error: chromecast.0 (1715) Error: DB closed
            at TCP.callbackTrampoline (node:internal/async_hooks:130:17)
            2026-08-25 17:08:22.657 - error: chromecast.0 (1715) uncaught exception: write EPIPE
            2026-08-25 17:08:22.657 - error: chromecast.0 (1715) Error: write EPIPE
            at afterWriteDispatched (node:internal/stream_base_commons:159:15)
            at writeGeneric (node:internal/stream_base_commons:150:3)
            at Socket._writeGeneric (node:net:967:11)
            at Socket._write (node:net:979:8)
            at writeOrBuffer (node:internal/streams/writable:572:12)
            at _write (node:internal/streams/writable:501:10)
            at Socket.Writable.write (node:internal/streams/writable:510:10)
            at console.value (node:internal/console/constructor:303:16)
            at console.warn (node:internal/console/constructor:426:26)
            at file:///opt/iobroker/node_modules/@sentry/node-core/src/integrations/onunhandledrejection.ts:142:15
            2026-08-25 17:08:22.658 - error: chromecast.0 (1715) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.658 - error: chromecast.0 (1715) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.658 - error: chromecast.0 (1715) Error: DB closed
            2026-08-25 17:08:22.658 - error: chromecast.0 (1715) uncaught exception: write EPIPE
            2026-08-25 17:08:22.658 - error: chromecast.0 (1715) Error: write EPIPE
            2026-08-25 17:08:22.659 - error: chromecast.0 (1715) uncaught exception: write EPIPE
            2026-08-25 17:08:22.659 - error: chromecast.0 (1715) Error: write EPIPE
            2026-08-25 17:08:22.659 - error: chromecast.0 (1715) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.659 - error: chromecast.0 (1715) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.659 - error: chromecast.0 (1715) Error: DB closed
            2026-08-25 17:08:22.660 - error: chromecast.0 (1715) uncaught exception: write EPIPE
            2026-08-25 17:08:22.660 - error: chromecast.0 (1715) Error: write EPIPE
            2026-08-25 17:08:22.660 - error: chromecast.0 (1715) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.660 - error: chromecast.0 (1715) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.660 - error: chromecast.0 (1715) Error: DB closed
            2026-08-25 17:08:22.661 - error: chromecast.0 (1715) uncaught exception: write EPIPE
            2026-08-25 17:08:22.661 - error: chromecast.0 (1715) Error: write EPIPE
            2026-08-25 17:08:22.661 - error: chromecast.0 (1715) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2026-08-25 17:08:22.661 - error: chromecast.0 (1715) unhandled promise rejection: DB closed
            2026-08-25 17:08:22.661 - error: chromecast.0 (1715) Error: DB closed
            2026-08-25 17:08:22.666 - error: admin.0 (1126) Cannot find view "system" for search "instance" : Connection is closed.
            2026-08-25 17:08:22.666 - error: admin.0 (1126) Cannot check revoked versions: Error: Cannot find view "system"
            2026-08-25 17:08:22.668 - error: javascript.0 (1242) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-08-25 17:08:22.669 - error: javascript.0 (1242) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-08-25 17:08:22.669 - warn: ❌ javascript.0 (1242) Objects database disconnected
            2026-08-25 17:08:22.676 - warn: ❌ javascript.0 (1242) States database disconnected
            2026-08-25 17:08:22.676 - warn: javascript.0 (1242) get state error: Connection is closed.
            2026-08-25 17:08:22.676 - warn: javascript.0 (1242) get state error: DB closed
            2026-08-25 17:08:22.676 - info: javascript.0 (1242) terminating
            2026-08-25 17:08:22.677 - info: javascript.0 (1242) terminating
            2026-08-25 17:08:22.678 - info: javascript.0 (1242) Terminated (NO_ERROR): Without reason
            2026-08-25 17:08:26.659 - info: host.iob iobroker.js-controller version 7.2.2 js-controller starting
            2026-08-25 17:08:26.660 - info: host.iob Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
            2026-08-25 17:08:26.660 - info: host.iob hostname: iob, node: v22.23.2
            2026-08-25 17:08:26.660 - info: host.iob ip addresses: 192.168.2.24 fe80::7832:49ff:fe74:fc81 192.168.56.24 2a00:6020:9058:4bf3:4e4:39ff:fe99:756f fe80::4e4:39ff:fe99:756f 192.168.12.24 fe80::be24:11ff:fe4c:17ca
            2026-08-25 17:08:27.674 - info: host.iob connected to Objects and States
            2026-08-25 17:08:27.685 - info: host.iob added notifications configuration of host
            2026-08-25 17:08:28.465 - info: host.iob 99 instances found
            2026-08-25 17:08:28.483 - info: host.iob starting 60 instances
            2026-08-25 17:08:28.671 - info: host.iob Delete state "system.host.iob.versions.nodeCurrent"
            2026-08-25 17:08:28.706 - info: host.iob Delete state "system.host.iob.versions.nodeNewest"
            2026-08-25 17:08:28.707 - info: host.iob Delete state "system.host.iob.versions.nodeNewestNext"
            2026-08-25 17:08:28.707 - info: host.iob Delete state "system.host.iob.versions.npmCurrent"
            2026-08-25 17:08:28.708 - info: host.iob Delete state "system.host.iob.versions.npmNewest"
            2026-08-25 17:08:28.714 - info: host.iob instance system.adapter.admin.0 in version "7.8.23" started with pid 2345373
            2026-08-25 17:08:28.753 - info: host.iob Delete state "system.host.iob.versions.npmNewestNext"
            2026-08-25 17:08:28.754 - info: host.iob Some obsolete host states deleted.
            2026-08-25 17:08:29.785 - error: admin.0 (2345373) admin.0 already running
            2026-08-25 17:08:29.787 - warn: admin.0 (2345373) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:08:30.342 - error: host.iob instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:08:30.342 - info: host.iob Restart adapter system.adapter.admin.0 because enabled
            2026-08-25 17:08:32.700 - info: host.iob instance system.adapter.influxdb.0 in version "4.0.2" started with pid 2345385
            2026-08-25 17:08:33.228 - error: influxdb.0 (2345385) influxdb.0 already running
            2026-08-25 17:08:33.230 - warn: influxdb.0 (2345385) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:08:33.775 - error: host.iob instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:08:33.776 - info: host.iob Restart adapter system.adapter.influxdb.0 because enabled
            2026-08-25 17:08:36.700 - info: host.iob instance system.adapter.node-red.0 in version "6.0.7" started with pid 2345397
            2026-08-25 17:08:37.171 - error: node-red.0 (2345397) node-red.0 already running
            2026-08-25 17:08:37.172 - warn: node-red.0 (2345397) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:08:37.716 - error: host.iob instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:08:37.716 - info: host.iob Restart adapter system.adapter.node-red.0 because enabled
            2026-08-25 17:08:40.693 - info: host.iob instance system.adapter.javascript.0 in version "9.0.18" started with pid 2345410
            2026-08-25 17:08:41.380 - error: javascript.0 (2345410) javascript.0 already running
            2026-08-25 17:08:41.382 - warn: javascript.0 (2345410) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:08:41.930 - error: host.iob instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:08:41.930 - info: host.iob Restart adapter system.adapter.javascript.0 because enabled
            2026-08-25 17:08:44.696 - info: host.iob instance system.adapter.pushover.0 in version "5.0.0" started with pid 2345422
            2026-08-25 17:08:45.135 - error: pushover.0 (2345422) pushover.0 already running
            2026-08-25 17:08:45.137 - warn: pushover.0 (2345422) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:08:45.682 - error: host.iob instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:08:45.682 - info: host.iob Restart adapter system.adapter.pushover.0 because enabled
            2026-08-25 17:08:48.689 - info: host.iob instance system.adapter.telegram.0 in version "4.1.0" started with pid 2345434
            2026-08-25 17:08:49.317 - error: telegram.0 (2345434) telegram.0 already running
            2026-08-25 17:08:49.319 - warn: telegram.0 (2345434) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:08:49.867 - error: host.iob instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:08:49.867 - info: host.iob Restart adapter system.adapter.telegram.0 because enabled
            2026-08-25 17:08:51.070 - info: host.iob instance system.adapter.telegram.0 in version "4.1.0" started with pid 2345446
            2026-08-25 17:08:52.054 - info: telegram.0 (2345446) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v22.23.2, js-controller: 7.2.2
            2026-08-25 17:08:52.679 - info: host.iob instance system.adapter.telegram.1 in version "4.1.0" started with pid 2345463
            2026-08-25 17:08:53.224 - error: telegram.1 (2345463) telegram.1 already running
            2026-08-25 17:08:53.225 - warn: telegram.1 (2345463) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:08:53.773 - error: host.iob instance system.adapter.telegram.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:08:53.773 - info: host.iob Restart adapter system.adapter.telegram.1 because enabled
            2026-08-25 17:08:54.985 - info: host.iob instance system.adapter.telegram.1 in version "4.1.0" started with pid 2345475
            2026-08-25 17:08:55.912 - info: telegram.1 (2345475) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v22.23.2, js-controller: 7.2.2
            2026-08-25 17:08:56.688 - info: host.iob instance system.adapter.history.0 in version "4.0.0" started with pid 2345492
            2026-08-25 17:08:57.117 - error: history.0 (2345492) history.0 already running
            2026-08-25 17:08:57.118 - warn: history.0 (2345492) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:08:57.666 - error: host.iob instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:08:57.666 - info: host.iob Restart adapter system.adapter.history.0 because enabled
            2026-08-25 17:09:00.733 - info: host.iob instance system.adapter.admin.0 in version "7.8.23" started with pid 2345504
            2026-08-25 17:09:00.783 - info: host.iob instance system.adapter.influxdb.1 in version "4.0.2" started with pid 2345512
            2026-08-25 17:09:01.323 - error: influxdb.1 (2345512) influxdb.1 already running
            2026-08-25 17:09:01.323 - warn: influxdb.1 (2345512) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2026-08-25 17:09:01.875 - error: host.iob instance system.adapter.influxdb.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2026-08-25 17:09:01.875 - info: host.iob Restart adapter system.adapter.influxdb.1 because enabled
            2026-08-25 17:09:01.910 - info: admin.0 (2345504) starting. Version 7.8.23 in /opt/iobroker/node_modules/iobroker.admin, node: v22.23.2, js-controller: 7.2.2
            2026-08-25 17:09:01.924 - info: admin.0 (2345504) requesting all objects
            2026-08-25 17:09:02.703 - info: admin.0 (2345504) received all objects
            2026-08-25 17:09:02.851 - info: admin.0 (2345504) Request actual repository...
            2026-08-25 17:09:02.858 - info: admin.0 (2345504) socket.io server listening on port 8081
            2026-08-25 17:09:02.859 - info: admin.0 (2345504) http server listening on port 8081
            2026-08-25 17:09:02.859 - info: admin.0 (2345504) Use link "http://127.0.0.1:8081" to configure.
            2026-08-25 17:09:03.531 - info: host.iob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2026-08-25 17:09:03.967 - info: host.iob instance system.adapter.influxdb.0 in version "4.0.2" started with pid 2345579
            2026-08-25 17:09:05.807 - info: admin.0 (2345504) Repository received successfully.
            2026-08-25 17:09:06.124 - info: host.iob instance system.adapter.hue.0 in version "3.16.2" started with pid 2345612
            2026-08-25 17:09:07.314 - info: influxdb.0 (2345579) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v22.23.2, js-controller: 7.2.2
            2026-08-25 17:09:07.323 - info: influxdb.0 (2345579) No stored data from last exit found
            2026-08-25 17:09:07.323 - info: influxdb.0 (2345579) Connecting http://192.168.2.26:8086/ ...
            2026-08-25 17:09:07.323 - info: influxdb.0 (2345579) Influx DB Version used: 2.x
            2026-08-25 17:09:07.336 - info: influxdb.0 (2345579) Applying retention policy for iobroker to infinity. Shard Group Duration (calculated): 604800 seconds
            2026-08-25 17:09:07.374 - info: influxdb.0 (2345579) Connected!
            2026-08-25 17:09:07.495 - info: influxdb.0 (2345579) enabled logging of nut.0.battery.charge, Alias=false, 1 points now activated
            2026-08-25 17:09:07.496 - info: influxdb.0 (2345579) enabled logging of tankerkoenig.0.stations.0.e5.feed, Alias=false, 2 points now activated
            2026-08-25 17:09:07.496 - info: influxdb.0 (2345579) enabled logging of tankerkoenig.0.stations.1.e5.feed, Alias=false, 3 points now activated
            Die VM hat 8 GB RAM, welches nicht vollgelaufen war:
            Bei mir gibt es nur einen Host.
            PlatformBetriebssystem:linux
            Architektur:x64
            CPUs:4
            Geschwindigkeit:0 MHz
            Modell:12th Gen Intel(R) Core(TM) i5-1240P
            RAM:7.7 GB
            System-Betriebszeit:00:45:41
            Node.js:v22.23.2
            Zeit:1788094784836
            Zeitversatz:-120
            NPM:10.9.8
            Adapter-Anzahl:649
            Datenträgergröße:30.4 GB
            Freier Festplattenspeicher:17.0 GB
            Aktive Instanzen:44
            Pfad:/opt/iobroker/
            Betriebszeit:-1 T. 0-2:0-15:0-23
            aktiv:true
            _nodeCurrent:22.23.2
            _nodeNewest:22.23.2
            _nodeNewestNext:22.23.2
            _npmCurrent:10.9.8
            _npmNewest:10.9.8
            _npmNewestNext:10.9.8
            Peterfido
            • P Offline
              peterfido
              Am 16.08. hatte ich Updates durchgeführt. Am 18.08. ging der RAM-Verbrauch höher, aber auch wieder runter, ab 24.08. scheint der RAM-Bedarf stetig gestiegen zu sein, bis am 25.08. dann das Problem aufgetreten war. Die RAM-Grenze wurde jedoch nicht erreicht.
              Peterfido
              • P peterfido
                @peterfido das passt ungefähr zu meinem Problem
                https://forum.iobroker.net/post/1352534
                Weisst du noch was du upgedatet hattest?
                Thomas BraunT P 2 Antworten Letzte Antwort
                  Hab gerade mal in meinem System geschaut. Hier genehmigt sich der js-controller ein Drittel des RAMs (8GB auf einem RPi4) im Dauerlauf. Mir fehlen Vergleiche zur jüngeren Vergangenheit, aber ich meine das sei 'früher' weniger gewesen.
                    peterfido
                    @Homoran Nein, leider nicht. Die Logs reichen auch nicht weit genug zurück.
                    Peterfido
                    • P Offline
                      peterfido
                      Ich spiele gerade das Backup vom 29.07. in eine neue VM und schaue mal, welche Versionsnummern die Adapter so haben.
                      Peterfido
                      • Michael SchmittM Online
                        Michael Schmitt
                        @thomas-braun (falls nützlich) Pi4 4gb vor ca 3 Std reboot
                        marvman67@Raspberry:~ $ ps aux --sort=-%mem | head -n 11
                        USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
                        iobroker     954  8.4 11.6 12186424 452084 ?     Ssl  14:39  15:29 iobroker.js-controller
                        iobroker    1021  0.7  7.1 22536616 276292 ?     Sl   14:39   1:22 io.admin.0
                        iobroker    1045  1.7  6.7 12031240 262256 ?     Sl   14:40   3:07 io.javascript.0
                        iobroker    1317  0.7  5.6 11994932 218108 ?     Sl   14:40   1:20 io.matter.0
                        iobroker    1410  0.2  4.5 11953160 175936 ?     Sl   14:41   0:31 io.web.0
                        iobroker    1400  0.3  4.2 11939364 165068 ?     Sl   14:41   0:38 io.alexa2.0
                        iobroker    1066  0.2  4.1 11938520 162704 ?     Sl   14:40   0:29 io.telegram.0
                        iobroker    1361  0.2  4.0 11736980 156764 ?     Sl   14:40   0:23 io.socketio.0
                        iobroker    1105  0.2  4.0 11738704 156044 ?     Sl   14:40   0:24 io.backitup.0
                        iobroker    1333  0.2  3.9 11733720 153784 ?     Sl   14:40   0:23 io.simple-api.0
                        Ro75R 1 Antwort Letzte Antwort
                        • P Offline
                          peterfido
                          Für diese gibt es Updates:
                          Und halt das System selbst.
                          Peterfido
                          • P peterfido
                            @peterfido sagte:
                            Danke!
                            Ich hatte noch ical, matter und go-e charger im kopf
                            Zigbee hab ich nicht upgedated
                            Harmony kam bei mir erst gerade eben mit breaking changes.
                            Die tue ich mir im Moment nicht an
                            • P Offline
                              peterfido
                              apt list --upgradable zeigt Folgende Updates an:
                              base-files/stable 13.8+deb13u6 amd64 [upgradable from: 13.8+deb13u5]
                              bind9-dnsutils/stable-security 1:9.20.26-1~deb13u1 amd64 [upgradable from: 1:9.20.23-1~deb13u1]
                              bind9-host/stable-security 1:9.20.26-1~deb13u1 amd64 [upgradable from: 1:9.20.23-1~deb13u1]
                              bind9-libs/stable-security 1:9.20.26-1~deb13u1 amd64 [upgradable from: 1:9.20.23-1~deb13u1]
                              bsdextrautils/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              bsdutils/stable-security 1:2.41.5-0+deb13u1 amd64 [upgradable from: 1:2.41-5]
                              chromium-common/stable-security 151.0.7922.173-1~deb13u1 amd64 [upgradable from: 149.0.7827.114-1~deb13u1]
                              chromium-sandbox/stable-security 151.0.7922.173-1~deb13u1 amd64 [upgradable from: 149.0.7827.114-1~deb13u1]
                              curl/stable 8.14.1-2+deb13u4 amd64 [upgradable from: 8.14.1-2+deb13u3]
                              dirmngr/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              eject/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              exim4-base/stable-security 4.98.2-1+deb13u4 amd64 [upgradable from: 4.98.2-1+deb13u3]
                              exim4-config/stable-security 4.98.2-1+deb13u4 all [upgradable from: 4.98.2-1+deb13u3]
                              exim4-daemon-light/stable-security 4.98.2-1+deb13u4 amd64 [upgradable from: 4.98.2-1+deb13u3]
                              fdisk/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              gnupg-utils/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              gpg-agent/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              gpg-wks-client/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              gpg-wks-server/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              gpg/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              gpgconf/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              gpgsm/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              gpgv/stable 2.4.7-21+deb13u1+b4 amd64 [upgradable from: 2.4.7-21+deb13u1+b3]
                              libblkid-dev/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              libblkid1/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              libcurl3t64-gnutls/stable 8.14.1-2+deb13u4 amd64 [upgradable from: 8.14.1-2+deb13u3]
                              libcurl4t64/stable 8.14.1-2+deb13u4 amd64 [upgradable from: 8.14.1-2+deb13u3]
                              libegl-mesa0/stable 25.0.7-2+deb13u1 amd64 [upgradable from: 25.0.7-2]
                              libexpat1-dev/stable-security 2.8.3-1~deb13u1 amd64 [upgradable from: 2.7.1-2]
                              libexpat1/stable-security 2.8.3-1~deb13u1 amd64 [upgradable from: 2.7.1-2]
                              libfdisk1/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              libgbm1/stable 25.0.7-2+deb13u1 amd64 [upgradable from: 25.0.7-2]
                              libgif-dev/stable 5.2.2-1+deb13u1 amd64 [upgradable from: 5.2.2-1+b1]
                              libgif7/stable 5.2.2-1+deb13u1 amd64 [upgradable from: 5.2.2-1+b1]
                              libgl1-mesa-dri/stable 25.0.7-2+deb13u1 amd64 [upgradable from: 25.0.7-2]
                              libglx-mesa0/stable 25.0.7-2+deb13u1 amd64 [upgradable from: 25.0.7-2]
                              libgraphite2-3/stable 1.3.14-2+deb13u1 amd64 [upgradable from: 1.3.14-2+b1]
                              libgraphite2-dev/stable 1.3.14-2+deb13u1 amd64 [upgradable from: 1.3.14-2+b1]
                              libhtml-parser-perl/stable 3.83-2~deb13u1 amd64 [upgradable from: 3.83-1+b2]
                              libhttp-daemon-perl/stable,stable-security 6.16-1+deb13u1 all [upgradable from: 6.16-1]
                              liblastlog2-2/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              libldb2/stable-security 2:2.11.0+samba4.22.10+dfsg-0+deb13u2 amd64 [upgradable from: 2:2.11.0+samba4.22.8+dfsg-0+deb13u2]
                              liblzma-dev/stable 5.8.1-1+deb13u1 amd64 [upgradable from: 5.8.1-1]
                              liblzma5/stable 5.8.1-1+deb13u1 amd64 [upgradable from: 5.8.1-1]
                              libmount-dev/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              libmount1/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              libnss3/stable-security 2:3.110-1+deb13u4 amd64 [upgradable from: 2:3.110-1+deb13u2]
                              libpython3.13-minimal/stable-updates 3.13.5-2+deb13u4 amd64 [upgradable from: 3.13.5-2+deb13u2]
                              libpython3.13-stdlib/stable-updates 3.13.5-2+deb13u4 amd64 [upgradable from: 3.13.5-2+deb13u2]
                              libsmartcols1/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              libsmbclient0/stable-security 2:4.22.10+dfsg-0+deb13u2 amd64 [upgradable from: 2:4.22.8+dfsg-0+deb13u2]
                              libssh2-1t64/stable,stable-security 1.11.1-1+deb13u1 amd64 [upgradable from: 1.11.1-1]
                              libssl3t64/stable-security 3.5.7-1~deb13u2 amd64 [upgradable from: 3.5.6-1~deb13u2]
                              libtalloc2/stable-security 2:2.4.3+samba4.22.10+dfsg-0+deb13u2 amd64 [upgradable from: 2:2.4.3+samba4.22.8+dfsg-0+deb13u2]
                              libtasn1-6/stable 4.20.0-2+deb13u1 amd64 [upgradable from: 4.20.0-2]
                              libtdb1/stable-security 2:1.4.13+samba4.22.10+dfsg-0+deb13u2 amd64 [upgradable from: 2:1.4.13+samba4.22.8+dfsg-0+deb13u2]
                              libtevent0t64/stable-security 2:0.16.2+samba4.22.10+dfsg-0+deb13u2 amd64 [upgradable from: 2:0.16.2+samba4.22.8+dfsg-0+deb13u2]
                              libtiff-dev/stable-security 4.7.0-3+deb13u3 amd64 [upgradable from: 4.7.0-3+deb13u2]
                              libtiff6/stable-security 4.7.0-3+deb13u3 amd64 [upgradable from: 4.7.0-3+deb13u2]
                              libtiffxx6/stable-security 4.7.0-3+deb13u3 amd64 [upgradable from: 4.7.0-3+deb13u2]
                              libuuid1/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              libwbclient0/stable-security 2:4.22.10+dfsg-0+deb13u2 amd64 [upgradable from: 2:4.22.8+dfsg-0+deb13u2]
                              libxml2-dev/stable 2.12.7+dfsg+really2.9.14-2.1+deb13u3 amd64 [upgradable from: 2.12.7+dfsg+really2.9.14-2.1+deb13u2]
                              libxml2/stable 2.12.7+dfsg+really2.9.14-2.1+deb13u3 amd64 [upgradable from: 2.12.7+dfsg+really2.9.14-2.1+deb13u2]
                              libxpm4/stable 1:3.5.17-1+deb13u1 amd64 [upgradable from: 1:3.5.17-1+b3]
                              linux-image-amd64/stable-security 6.12.107-1 amd64 [upgradable from: 6.12.90-2]
                              linux-libc-dev/stable-security 6.12.107-1 all [upgradable from: 6.12.90-2]
                              login/stable-security 1:4.16.0-2+really2.41.5-0+deb13u1 amd64 [upgradable from: 1:4.16.0-2+really2.41-5]
                              mesa-libgallium/stable 25.0.7-2+deb13u1 amd64 [upgradable from: 25.0.7-2]
                              mesa-vulkan-drivers/stable 25.0.7-2+deb13u1 amd64 [upgradable from: 25.0.7-2]
                              mount/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              nodejs/nodistro 22.23.2-1nodesource1 amd64 [upgradable from: 22.23.0-1nodesource1]
                              openssl-provider-legacy/stable-security 3.5.7-1~deb13u2 amd64 [upgradable from: 3.5.6-1~deb13u2]
                              openssl/stable-security 3.5.7-1~deb13u2 amd64 [upgradable from: 3.5.6-1~deb13u2]
                              python3-idna/stable 3.10-1+deb13u1 all [upgradable from: 3.10-1]
                              python3-urllib3/stable,stable-security 2.3.0-3+deb13u2 all [upgradable from: 2.3.0-3+deb13u1]
                              python3.13/stable-updates 3.13.5-2+deb13u4 amd64 [upgradable from: 3.13.5-2+deb13u2]
                              qemu-guest-agent/stable 1:10.0.11+ds-0+deb13u1 amd64 [upgradable from: 1:10.0.8+ds-0+deb13u1+b2]
                              samba-libs/stable-security 2:4.22.10+dfsg-0+deb13u2 amd64 [upgradable from: 2:4.22.8+dfsg-0+deb13u2]
                              unzip/stable-security 6.0-29+deb13u1 amd64 [upgradable from: 6.0-29]
                              util-linux-extra/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              util-linux/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              uuid-dev/stable-security 2.41.5-0+deb13u1 amd64 [upgradable from: 2.41-5]
                              xz-utils/stable 5.8.1-1+deb13u1 amd64 [upgradable from: 5.8.1-1]
                              Peterfido
                              • Michael SchmittM Michael Schmitt
                                Ro75R Online
                                Ro75R Online
                                Ro75
                                @Michael-Schmitt @thomas-braun
                                Da ja möglichweise was mit der Speicherveraltung oder einem Update klemmt. Ubuntu 22.04.5 LTS - läuft seit 42 Tagen, N5105 mit 16 GB RAM.
                                    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                                3287865 iobroker  20   0   12,0g 224512  22576 S  15,8   1,4   1307:25 io.web.0
                                3288925 iobroker  20   0   12,6g 804896  25456 S   9,9   5,0   1737:45 io.javascript.0
                                 434432 iobroker  20   0   11,7g 116764  21324 S   2,6   0,7 419:43.07 io.hue.0
                                3884311 iobroker  20   0   12,0g 196388  18956 S   2,0   1,2   2204:08 io.sql.0
                                3368243 iobroker  20   0   21,7g 138832  56148 S   1,0   0,9   2:23.29 io.linux-contro
                                3883571 iobroker  20   0   22,1g 286824  22620 S   0,7   1,8 109:46.45 io.admin.0
                                3884784 iobroker  20   0   11,9g 111968  19912 S   0,7   0,7 703:44.45 io.zigbee.0
                                 663399 iobroker  20   0   11,9g 119176  33124 S   0,0   0,7   4:04.96 io.alexa2.0
                                 797716 iobroker  20   0   11,9g 175312  33344 S   0,0   1,1  42:33.53 io.parcel.0
                                1166049 iobroker  20   0   11,3g  99628  31892 S   0,0   0,6   1:58.15 io.backitup.0
                                1685378 iobroker  20   0   11,3g  65616  20028 S   0,0   0,4  35:57.01 io.vesync.0
                                3074220 iobroker  20   0   11,9g 141296  53196 S   0,0   0,9   0:38.19 io.homeconnect.
                                3124703 iobroker  20   0   12,7g 318456  67880 S   0,0   2,0   9:17.80 io.roborock.0
                                3609322 iobroker  20   0   11,4g 156428  20532 S   0,0   1,0   1528:49 io.public-trans
                                3883527 iobroker  20   0   12,0g 162576  21652 S   0,0   1,0  77:31.98 iobroker.js-con
                                3884379 iobroker  20   0   21,8g 143348  19188 S   0,0   0,9 100:14.18 io.owntracks.0
                                3884407 iobroker  20   0   11,7g  82976  18108 S   0,0   0,5  45:53.16 io.sonoff.0
                                Ro75.
                                • Ro75R Ro75
                                  Ro75.
                                  @Ro75
                                  Welche Version des js-controllers läuft da?
                                    @Ro75
                                    Ro75R Online
                                    Ro75R Online
                                    Ro75
                                    7.2.2 - allerdings läuft bei mir alles über Redis:
                                    3881511 redis     20   0 1110692 321380   5276 S   3,7   2,0   3049:58 redis-server
                                    Ro75.
                                    • Ro75R Ro75
                                      Ro75.
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @Ro75 sagte:
                                      dass erklärt warum dein speicher Verbrauch grösser ist.. ich nehme mal an das redis läuft auch in dem gleichen kontainer wie iobroker..
                                      • arteckA arteck
                                        @Ro75 sagte:
                                        Ro75R Online
                                        Ro75R Online
                                        Ro75
                                        @arteck sagte:
                                        Kein Container. Alles ganz normal auf ubuntu.
                                        Ro75.
