  4. Load average am Anschlag -> Neustart
52 Beiträge 8 Kommentatoren 546 Aufrufe 6 Beobachtet
    schrieb zuletzt editiert von Homoran
    Hat aber alles nichts geholfen
    Was ist jetzt Ursache und was die Folge?
    Muss jetzt die logs durchwühlen
    EDIT:
    2026-08-28 13:50:00.225 - info: javascript.0 (1262) script.js.Wetter_und_Klima.Pegeldifferenz_Koblenz: Stopping script
    2026-08-28 13:50:00.230 - info: javascript.1 (1331) script.js.Wetter_und_Klima.Pegeldifferenz_Koblenz: start JavaScript (Blockly)
    2026-08-28 13:50:00.233 - info: javascript.1 (1331) script.js.Wetter_und_Klima.Pegeldifferenz_Koblenz: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-08-28 13:50:06.100 - info: javascript.0 (1262) script.js.Wetter_und_Klima.Pegeldifferenz_Koeln: Stopping script
    2026-08-28 13:50:07.292 - info: javascript.1 (1331) script.js.Wetter_und_Klima.Pegeldifferenz_Koeln: start JavaScript (Blockly)
    2026-08-28 13:50:07.302 - info: javascript.1 (1331) script.js.Wetter_und_Klima.Pegeldifferenz_Koeln: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-08-28 13:50:22.591 - info: javascript.0 (1262) script.js.Wetter_und_Klima.Qualmwarnung: Stopping script
    2026-08-28 13:50:22.595 - info: javascript.1 (1331) script.js.Wetter_und_Klima.Qualmwarnung: Stopping script
    2026-08-28 13:50:22.605 - info: javascript.1 (1331) script.js.Wetter_und_Klima.Qualmwarnung: start JavaScript (Blockly)
    2026-08-28 13:50:22.618 - info: javascript.1 (1331) script.js.Wetter_und_Klima.Qualmwarnung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-08-28 13:52:33.575 - info: javascript.1 (1331) script.js.Skript2: Stopping script
    2026-08-28 13:53:21.133 - info: javascript.0 (1262) Got terminate signal TERMINATE_YOURSELF
    2026-08-28 13:53:21.134 - info: javascript.0 (1262) terminating
    2026-08-28 13:53:21.135 - info: javascript.0 (1262) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-08-28 13:53:21.634 - info: javascript.0 (1262) terminating
    2026-08-28 14:01:57.184 - info: shuttercontrol.0 (1805) Sunprotect #415 Set ID: Nähzimmer value: 65%
    2026-08-28 14:19:32.832 - info: hm-rpc.0 (1565) Temporary error occurred for "setValue" with "["JEQ0646431:1","STATE",true]": Error: XML-RPC fault: Failure
    2026-08-28 14:36:38.726 - error: admin.0 (1247) admin.0 already running
    2026-08-28 14:36:38.728 - warn: admin.0 (1247) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:36:39.371 - error: host.BrokerRaspi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:36:41.539 - error: history.0 (1260) history.0 already running
    2026-08-28 14:36:41.540 - warn: history.0 (1260) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:36:42.151 - error: host.BrokerRaspi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:36:46.074 - error: javascript.1 (1272) javascript.1 already running
    2026-08-28 14:36:46.076 - warn: javascript.1 (1272) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:36:46.686 - error: host.BrokerRaspi instance system.adapter.javascript.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:36:49.498 - error: backitup.0 (1284) backitup.0 already running
    2026-08-28 14:36:49.500 - warn: backitup.0 (1284) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:36:50.112 - error: host.BrokerRaspi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:36:53.482 - error: brightsky.0 (1296) brightsky.0 already running
    2026-08-28 14:36:53.483 - warn: brightsky.0 (1296) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:36:54.095 - error: host.BrokerRaspi instance system.adapter.brightsky.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:36:57.076 - error: daikin.0 (1308) daikin.0 already running
    2026-08-28 14:36:57.078 - warn: daikin.0 (1308) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:36:57.688 - error: host.BrokerRaspi instance system.adapter.daikin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:37:01.020 - error: daikin.1 (1324) daikin.1 already running
    2026-08-28 14:37:01.021 - warn: daikin.1 (1324) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:37:01.632 - error: host.BrokerRaspi instance system.adapter.daikin.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:37:05.044 - error: daikin.2 (1336) daikin.2 already running
    2026-08-28 14:37:05.045 - warn: daikin.2 (1336) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:37:05.656 - error: host.BrokerRaspi instance system.adapter.daikin.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:37:09.237 - error: daikin.3 (1348) daikin.3 already running
    2026-08-28 14:37:09.240 - warn: daikin.3 (1348) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:37:09.856 - error: host.BrokerRaspi instance system.adapter.daikin.3 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:37:14.911 - error: denon.0 (1374) denon.0 already running
    2026-08-28 14:37:14.912 - warn: denon.0 (1374) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-08-28 14:37:15.890 - error: host.BrokerRaspi instance system.adapter.denon.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-08-28 14:37:18.561 - info: history.0 (1373) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.history, node: v22.23.2, js-controller: 7.2.2
    2026-08-28 14:37:18.704 - info: history.0 (1373) enabled logging of system.adapter.admin.0.memHeapUsed (Count=1), Alias=false
    2026-08-28 14:37:18.705 - info: history.0 (1373) enabled logging of system.adapter.backitup.0.memHeapUsed (Count=2), Alias=false
    2026-08-28 14:37:18.705 - info: history.0 (1373) enabled logging of system.host.BrokerRaspi.cpu (Count=3), Alias=false
    2026-08-28 14:37:18.706 - info: history.0 (1373) enabled logging of system.host.BrokerRaspi.mem (Count=4), Alias=false
    2026-08-28 14:37:18.706 - info: history.0 (1373) enabled logging of system.host.BrokerRaspi.memHeapUsed (Count=5)
    NICHTS!!
    Bis 13:53 hab ich die Srikpte verschoben und js.0 deaktiviert.
    14:36 startet iob neu
      Die load stieg nur auf 3.54, Die Temperatur auf 54Grad.
      Da wird der Lüfter angesprungen sein
      Für so unwahrscheinlich ich das halte, will ich nichts ausschließen und....
      habe den Lüfter abgeklemmt.
      54 Grad sind absolut untertemperieet für den Pi5, entsprechend ist auch nichts im iob diag zu throttling oder overtemperature zu sehen.
      @ro75
      Ich bin gespannt
      • Michael SchmittM Online
        Michael Schmitt
        Hast du die Möglichkeit das ganze mal auf anderer Hardware laufen zu lassen?
        • Michael SchmittM Michael Schmitt
          @Michael-Schmitt sagte:
          Das IST schon die andere Hardware
            Michael Schmitt
            Ok hmm auch eine andere M.2 oder gar eine andere Anbindung ssd mit USB? Vielleicht ist ja da irgendwo der Wurm drin
              Ja
              Ja, diesmal über PCIe statt usb
              via Flachbandkabel rechts
              Und sogar ein anderes OS und eine komplette neue Installation
                EDIT:
                NICHTS!!
                arteckA Offline
                arteckA Offline
                arteck
                @Homoran sagemal hast du den neuen nut2 adapater laufen.. wenn ja der hat bei mir gerade auch 100% cpu sich gekrallt.
                • arteckA arteck
                  @arteck sagte:
                  Nein, den alten!
                  Aber bei mir krallt sich niemand die CPU
                  Lediglich die Load geht hoch.
                  Muss also I/O sein.
                  DANKE für die info!
                  Ich hab mittlerweile javascript abgestelltt, spinnt trotzdem.
                  Dann history, sofort Ruhe.
                  Da bleib ich jetzt dran.
                    @arteck sagte:
                    Nein, den alten!
                    Muss also I/O sein.
                    DANKE für die info!
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @Homoran
                    Auch mal ins syslog schauen
                    Dann
                    Ist zwar etwas weiter hergeholt und um die Suche in einem Adapter nicht zu aufwändig werden zu lassen:
                    Du hast jetzt 2 Adapter abgeschaltet.
                    Nicht das es nur an einem liegt, sondern durch die gesamtlast.
                    Auch eine Idee
                    Wenn der history Adapter viele datenpunkte pflegen muss, hat er viele dateihandles gleichzeitig offen. Wird ja alles in einzelnen Dateien gepflegt. Auch da gibt es Obergrenzen.
                    Noch eine Idee
                    Auch der interne Bus des Systems mit dem ram CPU ssd miteinander kommuniziert hat Grenzen. Da weiß ich aber nicht wie man da nachschaut. Ist aber eher am Ende der Wahrscheinlichkeiten
                    Daher mal das syslog um den Absturz herum untersuchen
                    Meine Adapter und Widgets
                    Links im Profil
                    • OliverIOO OliverIO
                      @Homoran
                      Dann
                      Auch eine Idee
                      Noch eine Idee
                      @OliverIO danke!
                      Ich hab ein wenig Probleme damit es jetzt an dem aktuellen System festzumachen, da es vorher bereits auftrat.
                      Die history erscheint mir daher sinnvoll, da dies eigentlich mal ein test werden sollte wie lange eine SD Karte halten wird, wenn man alles per json darauf speichert.
                      Das Experiment ist jetzt normal geworden, weil es noch nie Probleme gab.
                      Einmal wurde die SD Karte zu klein 😉
                      In dem neuen System habe ich mir eine 256GB Sandisk extreme Pro geleistet, die doppelt so schnelle Zugriffe erlaubt.
                      Jetzt waren Werte seit 2021 auf der Karte.
                      Hier hatte ich die Vermutung dass beim Durchsuchen der zigtausend Einträge das System an seine Grenzen Stösst und habe zwei Jahre gelöscht = 30GB.
                      Das hat jedoch nicht geholfen. Gerade habe ich nochmal ein Jahr (2023) gelöscht was nochmal 20GB Platz schaffte.
                      @OliverIO sagte:
                      Das geht mit meinen Beobachtungen konform was die Dynamik von load und mem betrifft.
                      Dann habe ich mir Gedanken gemacht, ob ich vielleicht vor dem Auftreten des Problems weitere oft ändernde Datenpunkte zusätzlich historisiert habe und nicht die anzahl, so dern die Häufigkeit beim Schreiben und Lesen jetzt zu viel ist.
                      Da arbeite ich gerade dran.
                        Ja
                        @Homoran [sagte]: diesmal über PCIe statt usb
                        Verlagere doch das History-Verzeichnis auf die SSD (Link).
                          @paul53 sagte:
                          Denke ich auch drüber nach!
                          Abgesehen von dem damit verbundenen Ende des Dauerexperiments, muss mich da noch einarbeten, wie das zu machen sei.
                          Einfach den Pfad ändern hilft ja wohl nicht.
                          Da muss ich wohl die Daten erst nach z.B. /mnt/Platte/data/history verschieben
                            @paul53 sagte:
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @Homoran
                            Evtl doch mal an eine Datenbank denken
                            https://github.com/ioBroker/ioBroker.history/blob/master/docs/de/README.md#history-daten-in-sql-oder-influxdb-übernehmen
                            Eine Datenbank geht etwas sorgsamer mit System Ressourcen um.
                            Der history Adapter hat ja für jeden Datenpunkt ein Verzeichnis.
                            Darin ist für jeden Tag eine Datei.
                            Bei jedem Mal einen Wert historisieren bedeutet das Datei öffnen, lesen, Daten anpassen, schreiben.
                            Das selbenpassiert parallel mit der states.jsonl für den aktuellen Wert.
                            Eine Datenbank lebt mit den gerade Interessanten hauptsächlich im Speicher. Schreiben findet dann einnwenigbzeitverzögert dann optimiert nicht pro Wert sondern gesammelt statt.
                            Redis geht leider nur als Ersatz für die aktuellen Daten, aber nicht für die history
                            Links im Profil
