  4. ...nicht in offiziellem Repo
  5. MotionEye Integration - Alpha
    6.3k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
motionmotioneyecamerainventwocursor ai
67 Beiträge 9 Kommentatoren 4.1k Aufrufe 11 Beobachtet
  • LongbowL Longbow
    @skvarel
    Guten Morgen, also ich es geupdatet.
    Das PW nochmals geändert.... aber kein Erfolg.
    Hier der LOG:
    motioneye.0
    2026-06-29 08:40:46.536	info	MotionEye adapter ready
    motioneye.0
    2026-06-29 08:40:46.492	info	[verbose] Auth failed at startup — check MotionEye password in instance settings (password set (12 chars)). Clear the field, save, re-enter, save again.
    motioneye.0
    2026-06-29 08:40:46.492	warn	MotionEye not reachable at startup: unauthorized
    motioneye.0
    2026-06-29 08:40:46.492	info	[verbose] GET /config/list → HTTP 403: unauthorized
    motioneye.0
    2026-06-29 08:40:46.484	warn	No enabled cameras configured — add cameras on the Cameras tab
    motioneye.0
    2026-06-29 08:40:46.484	info	Webhook server listening on 0.0.0.0:8090
    motioneye.0
    2026-06-29 08:40:46.477	info	[verbose] Enabled cameras in config: 0
    motioneye.0
    2026-06-29 08:40:46.477	info	[verbose] useMotionEyeConfig=true
    motioneye.0
    2026-06-29 08:40:46.476	info	[verbose] Webhook listener: 0.0.0.0:8090, webhook host for MotionEye: 192.168.7.201
    motioneye.0
    2026-06-29 08:40:46.476	info	[verbose] Motion HTTP port: 7999
    motioneye.0
    2026-06-29 08:40:46.476	info	[verbose] MotionEye API: 192.168.7.206:8765, user=admin, password set (12 chars)
    motioneye.0
    2026-06-29 08:40:46.476	info	[verbose] Verbose diagnostic logging enabled — disable after troubleshooting
    motioneye.0
    2026-06-29 08:40:46.461	info	MotionEye adapter starting...
    motioneye.0
    2026-06-29 08:40:46.452	info	starting. Version 0.4.1 (non-npm: inventwo/ioBroker.motioneye#41a69ae8170033381825d444b53af62664ddbf25) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.21.0, js-controller: 7.2.2
    motioneye.0
    2026-06-29 08:40:41.957	info	terminating
    motioneye.0
    motioneye.0
    2026-06-29 08:40:41.457	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    motioneye.0
    2026-06-29 08:40:41.456	info	terminating
    motioneye.0
    2026-06-29 08:40:41.455	info	Got terminate signal TERMINATE_YOURSELF
    motioneye.0
    2026-06-29 08:40:37.091	info	MotionEye adapter ready
    motioneye.0
    2026-06-29 08:40:37.047	info	[verbose] Auth failed at startup — check MotionEye password in instance settings (password not set). Clear the field, save, re-enter, save again.
    motioneye.0
    2026-06-29 08:40:37.046	warn	MotionEye not reachable at startup: unauthorized
    motioneye.0
    2026-06-29 08:40:37.046	info	[verbose] GET /config/list → HTTP 403: unauthorized
    motioneye.0
    2026-06-29 08:40:37.039	warn	No enabled cameras configured — add cameras on the Cameras tab
    motioneye.0
    2026-06-29 08:40:37.038	info	Webhook server listening on 0.0.0.0:8090
    motioneye.0
    2026-06-29 08:40:37.030	info	[verbose] Enabled cameras in config: 0
    motioneye.0
    2026-06-29 08:40:37.030	info	[verbose] useMotionEyeConfig=true
    motioneye.0
    2026-06-29 08:40:37.030	info	[verbose] Webhook listener: 0.0.0.0:8090, webhook host for MotionEye: 192.168.7.201
    motioneye.0
    2026-06-29 08:40:37.030	info	[verbose] Motion HTTP port: 7999
    motioneye.0
    2026-06-29 08:40:37.030	info	[verbose] MotionEye API: 192.168.7.206:8765, user=admin, password not set
    motioneye.0
    2026-06-29 08:40:37.030	info	[verbose] Verbose diagnostic logging enabled — disable after troubleshooting
    motioneye.0
    2026-06-29 08:40:36.989	info	MotionEye adapter starting...
    motioneye.0
    2026-06-29 08:40:36.981	info	starting. Version 0.4.1 (non-npm: inventwo/ioBroker.motioneye#41a69ae8170033381825d444b53af62664ddbf25) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.21.0, js-controller: 7.2.2
    motioneye.0
    2026-06-29 08:40:32.457	info	terminating
    motioneye.0
    2026-06-29 08:40:32.456	info	terminating
    motioneye.0
    2026-06-29 08:40:31.957	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    motioneye.0
    2026-06-29 08:40:31.957	info	terminating
    motioneye.0
    2026-06-29 08:40:31.956	info	Got terminate signal TERMINATE_YOURSELF
    motioneye.0
    2026-06-29 08:36:47.039	info	MotionEye adapter ready
    motioneye.0
    2026-06-29 08:36:46.995	info	[verbose] Auth failed at startup — check MotionEye password in instance settings (password set (11 chars)). Clear the field, save, re-enter, save again.
    motioneye.0
    2026-06-29 08:36:46.995	warn	MotionEye not reachable at startup: unauthorized
    motioneye.0
    2026-06-29 08:36:46.995	info	[verbose] GET /config/list → HTTP 403: unauthorized
    motioneye.0
    2026-06-29 08:36:46.987	warn	No enabled cameras configured — add cameras on the Cameras tab
    motioneye.0
    2026-06-29 08:36:46.987	info	Webhook server listening on 0.0.0.0:8090
    motioneye.0
    2026-06-29 08:36:46.980	info	[verbose] Enabled cameras in config: 0
    motioneye.0
    2026-06-29 08:36:46.980	info	[verbose] useMotionEyeConfig=true
    motioneye.0
    2026-06-29 08:36:46.980	info	[verbose] Webhook listener: 0.0.0.0:8090, webhook host for MotionEye: 192.168.7.201
    motioneye.0
    2026-06-29 08:36:46.979	info	[verbose] Motion HTTP port: 7999
    motioneye.0
    2026-06-29 08:36:46.979	info	[verbose] MotionEye API: 192.168.7.206:8765, user=admin, password set (11 chars)
    motioneye.0
    2026-06-29 08:36:46.979	info	[verbose] Verbose diagnostic logging enabled — disable after troubleshooting
    motioneye.0
    2026-06-29 08:36:46.964	info	MotionEye adapter starting...
    motioneye.0
    2026-06-29 08:36:46.956	info	starting. Version 0.4.1 (non-npm: inventwo/ioBroker.motioneye#41a69ae8170033381825d444b53af62664ddbf25) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.21.0, js-controller: 7.2.2
    motioneye.0
    2026-06-29 08:36:42.458	info	terminating
    motioneye.0
    motioneye.0
    2026-06-29 08:36:41.958	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    motioneye.0
    2026-06-29 08:36:41.957	info	terminating
    motioneye.0
    2026-06-29 08:36:41.956	info	Got terminate signal TERMINATE_YOURSELF
    motioneye.0
    2026-06-29 08:36:20.271	info	MotionEye adapter ready
    motioneye.0
    2026-06-29 08:36:20.226	warn	MotionEye not reachable at startup: unauthorized
    motioneye.0
    2026-06-29 08:36:20.219	warn	No enabled cameras configured — add cameras on the Cameras tab
    motioneye.0
    2026-06-29 08:36:20.219	info	Webhook server listening on 0.0.0.0:8090
    motioneye.0
    2026-06-29 08:36:20.197	info	MotionEye adapter starting...
    motioneye.0
    2026-06-29 08:36:20.188	info	starting. Version 0.4.1 (non-npm: inventwo/ioBroker.motioneye#41a69ae8170033381825d444b53af62664ddbf25) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.21.0, js-controller: 7.2.2
    motioneye.0
    2026-06-29 08:36:15.649	info	terminating
    motioneye.0
    motioneye.0
    2026-06-29 08:36:15.149	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    motioneye.0
    2026-06-29 08:36:15.148	info	terminating
    motioneye.0
    2026-06-29 08:36:15.147	info	Got terminate signal TERMINATE_YOURSELF
    skvarelS Offline
    skvarelS Offline
    skvarel
    @Longbow .. und bitte das Passwort eintippen anstatt kopieren und einfügen.
    #TeamInventwo
    Unsere Adapter:
    • skvarelS skvarel
      @Thomas-Braun sagte:
      node: v22.21.0
      Updaten.
      Das sollte aber keinen Einfluss auf die Funktion vom Adapter haben. Ja, ein Update ist trotzdem sinnvoll!
      @skvarel sagte:
      Das hab ich auch nicht gesagt.
      Aber die Kisten sind unabhängig von den Problemen immer auf aktuellem Stand zu halten.
      • skvarelS skvarel
        @Longbow ...
        Danke für das ausführliche Log — damit sieht man genau, was passiert.
        Gute Nachricht: MotionEye antwortet (HTTP 403 auf Port 8765). Host und Port passen, ioBroker kommt durch.
        Das Problem: Die API-Anmeldung wird abgelehnt (unauthorized).
        Im Log steht einmal password not set (08:40:37) und danach password set (12 chars) — beides mit unauthorized. MotionEye verlangt also ein Passwort, und das aktuell gespeicherte (12 Zeichen) ist nicht das, was die API akzeptiert.
        Bitte genau so testen:
        1.) Im Browser: http://192.168.7.206:8765/ — klappt Login mit admin und genau diesem 12-Zeichen-Passwort?
        • Nein → Passwort in MotionEye zurücksetzen/klären, nicht im Adapter.
        • Ja → weiter mit Schritt 2.
        2.) Test mit einfachem Passwort: In MotionEye kurz ein Passwort nur aus Buchstaben/Zahlen setzen (z. B. Test1234), im Adapter: Feld komplett leeren → Speichern → Neustart → neues Passwort von Hand tippen → Speichern → Neustart.
        • Klappt das → altes Passwort (Sonderzeichen/Tippfehler) war die Ursache.
        • Klappt nicht → Benutzername prüfen (wirklich admin?) oder motioneye.conf auf dem MotionEye-Server.
        3.) Kameras ohne API: Tab Kameras → Zeile manuell (Name + MotionEye-ID 1, aktiviert) → Speichern → Neustart. Datenpunkte werden angelegt; nur „Kameras laden“ und _info.connection brauchen die API.
        Bitte kurz Rückmeldung: Klappt der Web-Login unter :8765 mit demselben Passwort? Und Ergebnis des Test1234-Tests.
        LongbowL Offline
        LongbowL Offline
        Longbow
        schrieb am zuletzt editiert von Longbow
        @skvarel
        Guten Morgen,
        also ich habe alles so gemacht, wie du es beschrieben hast.
        Benutzer/ PW geändert....
        der Login auf dem Web-Login klappt, mit jeder Veränderung von Unser oder PW. Gebe ich die gleichen Daten dann in den Adapter ein, kommt ständig dann diese aus dem Protokoll.
        Hab Motioneye auch neu installiert auf dem Proxmox Server.
        Kein erfolg, ja die Kamera ist erst mal wieder raus, mit geht es erst mal nun um den Login.
        motioneye.0
        2026-06-30 09:31:30.882	info	MotionEye adapter ready
        motioneye.0
        2026-06-30 09:31:30.837	info	[verbose] Auth failed at startup — check MotionEye password in instance settings (password set (10 chars)). Clear the field, save, re-enter, save again.
        motioneye.0
        2026-06-30 09:31:30.837	warn	MotionEye not reachable at startup: unauthorized
        motioneye.0
        2026-06-30 09:31:30.837	info	[verbose] GET /config/list → HTTP 403: unauthorized
        motioneye.0
        2026-06-30 09:31:30.829	warn	No enabled cameras configured — add cameras on the Cameras tab
        motioneye.0
        2026-06-30 09:31:30.829	info	Webhook server listening on 0.0.0.0:8090
        motioneye.0
        2026-06-30 09:31:30.822	info	[verbose] Enabled cameras in config: 0
        motioneye.0
        2026-06-30 09:31:30.822	info	[verbose] useMotionEyeConfig=true
        motioneye.0
        2026-06-30 09:31:30.822	info	[verbose] Webhook listener: 0.0.0.0:8090, webhook host for MotionEye: 192.168.7.201
        motioneye.0
        2026-06-30 09:31:30.822	info	[verbose] Motion HTTP port: 7999
        motioneye.0
        2026-06-30 09:31:30.821	info	[verbose] MotionEye API: 192.168.7.206:8765, user=Cliffkirchhof, password set (10 chars)
        motioneye.0
        2026-06-30 09:31:30.821	info	[verbose] Verbose diagnostic logging enabled — disable after troubleshooting
        motioneye.0
        2026-06-30 09:31:30.806	info	MotionEye adapter starting...
        motioneye.0
        2026-06-30 09:31:30.798	info	starting. Version 0.4.1 (non-npm: inventwo/ioBroker.motioneye#41a69ae8170033381825d444b53af62664ddbf25) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.23.1, js-controller: 7.2.2
        motioneye.0
        2026-06-30 09:31:26.322	info	terminating
        motioneye.0
        2026-06-30 09:31:26.321	info	terminating
        motioneye.0
        2026-06-30 09:31:25.821	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        motioneye.0
        2026-06-30 09:31:25.821	info	terminating
        motioneye.0
        2026-06-30 09:31:25.820	info	Got terminate signal TERMINATE_YOURSELF
        skvarelS 2 Antworten Letzte Antwort
        • LongbowL Longbow
          @skvarel
          Guten Morgen,
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          motioneye.0
          skvarelS Offline
          skvarelS Offline
          skvarel
          schrieb am zuletzt editiert von skvarel
          @Longbow .. läuft MotionEye in einem Docker?
          EDIT:
          Ich gebe Cursor AI gerade deinen Log zu Diagnose
          #TeamInventwo
          Unsere Adapter:
          LongbowL 1 Antwort Letzte Antwort
          • skvarelS skvarel
            EDIT:
            LongbowL Offline
            LongbowL Offline
            Longbow
            @skvarel was mein Docker, ich es auf deinem Proxmox Server laufen, also eine einige Container, aber nicht über Doker direkt,
            skvarelS 1 Antwort Letzte Antwort
            • LongbowL Longbow
              @skvarel
              Guten Morgen,
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              motioneye.0
              skvarelS Offline
              skvarelS Offline
              skvarel
              @Longbow .. bitte den admin User für den Adapter nutzen. Ist 'Cliffkirchhof' wirklich der Admin?
              Ich kenne mich mit Proxmox leider nicht aus.
              Bitte kurz bestätigen:
              • Loggst du dich im Browser genau unter http://192.168.7.206:8765/ ein (nicht :7999, nicht ohne Port)?
              • Benutzer im Adapter: Cliffkirchhof — ist das exakt der MotionEye-Admin-User (Groß/Klein)?
              • Läuft MotionEye bei dir in Docker/LXC/VM auf Proxmox? ioBroker auf demselben Host oder woanders?
              Test auf dem ioBroker-Host (ersetzt HIER_DAS_PASSWORT durch dein aktuelles Passwort, von Hand) per ssh:
              node -e "const {createMotionEyeApi}=require('/opt/iobroker/node_modules/iobroker.motioneye/lib/motionEyeApi');createMotionEyeApi({host:'192.168.7.206',motionEyePort:8765,username:'Cliffkirchhof',password:'HIER_DAS_PASSWORT',requestTimeoutMs:10000,listCacheMs:0}).getCameraList().then(c=>console.log('OK',c.length)).catch(e=>console.error('FAIL',e.message));"
              • Ausgabe OK → Zugangsdaten stimmen, Problem ist die ioBroker-Instanz (Passwort-Speicherung). Dann: Instanz löschen, neu anlegen, Passwort von Hand tippen.
              • Ausgabe FAIL unauthorized → Web-Login läuft sehr wahrscheinlich nicht auf Port 8765 mit denselben Daten — bitte Screenshot der Browser-Adresszeile beim Login schicken.
              #TeamInventwo
              Unsere Adapter:
              • LongbowL Longbow
                skvarelS Offline
                skvarelS Offline
                skvarel
                @Longbow
                Bei mir kommt per ssh dann folgendes zurück:
                EDIT:
                Irgendwie müssen wir das schaffen! Bei anderen Usern läuft der Adapter ja auch.
                #TeamInventwo
                Unsere Adapter:
                • skvarelS skvarel
                  LongbowL Offline
                  LongbowL Offline
                  Longbow
                  @skvarel
                  also ja, Cliffkirchhof war der admin, hab es wieder auf admin geändert
                  Hier kommt das Web-Login http://192.168.7.206:8765/, kommt auf die Oberfläche. MotionEye läuft auf einem Proxmox in einem LXC. Motioneye LXC Container, ist die Meldung,
                  wenn das eingebe, kommt das nun
                  -bash: node: command not found
                  • skvarelS Offline
                    skvarelS Offline
                    skvarel
                    In der aktuellen Github Version habe ich jetzt einen Verbindungstest einbauen lassen:
                    EDIT:
                    In dem Log sollte dann folgendes auftauchen:
                    motioneye.0
                    	2026-06-30 10:04:33.224	info	Test connection OK — 9 camera(s) at 192.168.130.240:8765, MotionEye 0.43.1
                    #TeamInventwo
                    Unsere Adapter:
                    • LongbowL Longbow
                      @skvarel
                      skvarelS Offline
                      skvarelS Offline
                      skvarel
                      @Longbow .. node: command not found heißt, du warst nicht auf dem ioBroker-Host, sondern vermutlich auf Proxmox oder im MotionEye-LXC. Dort ist Node nicht installiert.
                      Einfacher Weg (ohne SSH): Aktuelle GitHub-Version installieren — darin ist der Button „Verbindung testen“ (siehe Screenshot oben):
                      #TeamInventwo
                      Unsere Adapter:
                      • skvarelS Offline
                        skvarelS Offline
                        skvarel
                        Ich habe die Anleitung erweitern lassen:
                        https://github.com/inventwo/ioBroker.motioneye/blob/main/docs/de/faq.md#verbindung-testen-admin
                        #TeamInventwo
                        Unsere Adapter:
                        • skvarelS Offline
                          skvarelS Offline
                          skvarel
                          @longbow
                          Version 0.4.2 ist jetzt bei npm.
                          Bitte aktualisieren:
                          Instanz neu starten → Einstellungen → User admin, Passwort von Hand → Speichern → Verbindung testen.
                          FAQ: https://github.com/inventwo/ioBroker.motioneye/blob/main/docs/de/faq.md
                          #TeamInventwo
                          Unsere Adapter:
                          • FredFF FredF
                            @skvarel
                            Danke für den Hinweis. ich hätte auch selbst darauf kommen können...
                            Mein ioBroker Testsystem läuft auf einem Custom Network und der motionEye container läuft als Host, kann ja nicht funktionieren.
                            Aus Zeitgründen stelle ich das jetzt nicht um, teste deinen Adapter dann später weiter.
                            FredFF Online
                            FredFF Online
                            FredF
                            Most Active Forum Testing
                            FredF sagte:
                            @skvarel
                            @skvarel
                            So, ich habe mich "getraut" den Adapter auf meinem Life System zu installieren, läuft, keine Probleme. Top.
                            • FredFF FredF
                              FredF sagte:
                              @skvarel
                              @skvarel
                              skvarelS Offline
                              skvarelS Offline
                              skvarel
                              @FredF .. vielen Dank für die Rückmeldung
                              #TeamInventwo
                              Unsere Adapter:
                              • skvarelS Offline
                                skvarelS Offline
                                skvarel
                                @homoran .. kannst du ausnahmsweise diesen Beitrag in den Tester Bereich verschieben? Der Adapter ist seit heute im Latest. Ich würde kern die Posts behalten, da ein User noch Probleme hat und ich den Zusammenhang behalten möchte.
                                Den Titel würde ich dann von 'MotionEye Integration - Alpha' in 'MotionEye Integration - Latest' umbenennen.
                                @mcm1957 ... vielen Dank für deinen Support und deine Geduld mit mir!
                                #TeamInventwo
                                Unsere Adapter:
                                • skvarelS skvarel
                                  @longbow
                                  LongbowL Offline
                                  LongbowL Offline
                                  Longbow
                                  @skvarel
                                  das ist nun auf dem LXC vo iobroker
                                  longbow@iobroker:~$ node -e "const {createMotionEyeApi}=require('/opt/iobroker/node_modules/iobroker.motioneye/lib/motionEyeApi');createMotionEyeApi({host:'192.168.7.206',motionEyePort:8765,username:'admin',password:'Ck23021979',requestTimeoutMs:10000,listCach
                                  FAIL unauthorized
                                  longbow@iobroker:~$
                                  Hab nichts kopiert von den PW oder so, alles neu eingeben. Aber es bleibt dabei, es verbindet sich nichts. Habe auch alles gelöscht und auch das dein Update etc.
                                  • LongbowL Longbow
                                    @skvarel
                                    FAIL unauthorized
                                    longbow@iobroker:~$
                                    skvarelS Offline
                                    skvarelS Offline
                                    skvarel
                                    @Longbow .. hast du die aktuelle npm Version ausprobiert? Was passiert beim Klicken auf den Test Button?
                                    EDIT:
                                    Bitte dein Post bearbeiten und das Passwort in MotionEye ändern. Du hast es hier im Klartext gepostet.
                                    #TeamInventwo
                                    Unsere Adapter:
                                    • skvarelS skvarel
                                      EDIT:
                                      LongbowL Offline
                                      LongbowL Offline
                                      Longbow
                                      @skvarel
                                      Das gleiche das es sich nicht verbinden kann….
                                      Das PW ist geändert… hatte ich bewusst gemacht, damit du siehst… vollkommen einfach.
                                      Ja hab es neu runter geladen und installiert neue Version.
                                      • LongbowL Longbow
                                        @skvarel
                                        skvarelS Offline
                                        skvarelS Offline
                                        skvarel
                                        @Longbow .. so langsam gehen Cursor und mir die Ideen aus.
                                        Kannst du mir bitte noch deine motionEye-Version aus der Weboberfläche posten (wie bei mir: 0.43.1 / Motion 4.x / OS). Damit können wir ausschließen, dass es an der Version liegt.
                                        EDIT:
                                        Ich befürchte, da wurde etwas ab der MotionEye 0.44.0 geändert.
                                        #TeamInventwo
                                        Unsere Adapter:
                                        • skvarelS Offline
                                          skvarelS Offline
                                          skvarel
                                          Mit der MotionEye 0.44.0 bekomme ich auch Probelme
                                          motioneye.1
                                          	2026-07-01 09:00:55.581	info	MotionEye adapter ready
                                          motioneye.1
                                          	2026-07-01 09:00:55.577	warn	MotionEye not reachable at startup: unauthorized
                                          motioneye.1
                                          	2026-07-01 09:00:55.560	warn	No enabled cameras configured — add cameras on the Cameras tab
                                          motioneye.1
                                          	2026-07-01 09:00:55.560	info	Webhook server listening on 0.0.0.0:8090
                                          motioneye.1
                                          Wir testen gerade eine Alpha-Version und passen den Login für die >= 0.44.0 an.
                                          #TeamInventwo
                                          Unsere Adapter:
