  3. Einsteigerfragen
  4. Daheimladen.de mit Modbus Adapter
32 Beiträge 7 Kommentatoren 9.0k Aufrufe 7 Beobachtet
  • meuteM meute
    Ich erhalte in unregelmäßigen Zeitabständen modbus-Fehler.
    Ob das jetzt am Protokoll liegt, oder die Wallbox kurz nicht erreichbar ist?
    2024-02-27 18:05:20.889 - warn: modbus.0 (11859) Error: undefined
    2024-02-27 18:05:20.890 - error: modbus.0 (11859) Request timed out.
    2024-02-27 18:05:20.890 - error: modbus.0 (11859) Client in error state.
    2024-02-27 18:05:20.891 - warn: modbus.0 (11859) Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2024-02-27 18:05:21.890 - info: modbus.0 (11859) Disconnected from slave 192.168.23.189
    2024-02-27 18:06:33.313 - error: modbus.0 (11859) Socket Error
    2024-02-27 18:06:33.314 - error: modbus.0 (11859) Client in error state.
    2024-02-27 18:06:33.315 - warn: modbus.0 (11859) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.23.189","port":502}
    2024-02-27 18:07:34.330 - info: modbus.0 (11859) Connected to slave 192.168.23.189
    2024-02-27 18:49:32.664 - warn: modbus.0 (11859) Error: undefined
    2024-02-27 18:49:32.665 - error: modbus.0 (11859) Request timed out.
    2024-02-27 18:49:32.665 - error: modbus.0 (11859) Client in error state.
    2024-02-27 18:49:32.666 - warn: modbus.0 (11859) Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2024-02-27 18:49:33.665 - info: modbus.0 (11859) Disconnected from slave 192.168.23.189
    2024-02-27 18:50:33.670 - info: modbus.0 (11859) Connected to slave 192.168.23.189
    2024-02-27 19:30:56.916 - warn: modbus.0 (11859) Error: undefined
    2024-02-27 19:30:56.917 - error: modbus.0 (11859) Request timed out.
    2024-02-27 19:30:56.917 - error: modbus.0 (11859) Client in error state.
    2024-02-27 19:30:56.918 - warn: modbus.0 (11859) Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2024-02-27 19:30:57.919 - info: modbus.0 (11859) Disconnected from slave 192.168.23.189
    2024-02-27 19:31:57.926 - info: modbus.0 (11859) Connected to slave 192.168.23.189
    PLCHome 0P Offline
    PLCHome 0P Offline
    PLCHome 0
    @meute Verbindungsfehler hatte ich auch. Sahen aber anders aus. Ich hab die Box nun am Netzwerkkabel hängen, jetzt kommt alle paar Tage mal ein busy Feher. Also besser, aber nicht weg.
    Ich hab aber auch keine Touch.
    Aber ein Zyklus ist kein Zyklus...
    meuteM 1 Antwort Letzte Antwort
    • PLCHome 0P PLCHome 0
      meuteM Offline
      meuteM Offline
      meute
      Ich habe jetzt einen Modbus-Parameter verändert:
      Datenabfrageintervall (Data polling interval)
      Bisher 1.000 ms (1 Sek.)
      Jetzt 10.000 ms (10 Sek.)
      Seit 2,5 Std. gibt es keine Verbindungsfehler mehr.
      Mal beobachten...
      fraenk for friends Code: MATF103
      • J Offline
        JuFu
        DaheimLaden bietet auch einen LastManager an der dann verschiedene Wallboxen steuert/koordiniert.
        Ist bei uns in der Tiefgarage für 6 Wallboxen installiert.
        Tue mir noch etwas schwer die Daten mit Modbus TCP abzufragen.
        Hat das schon jemand von euch hinbekommen?
        • J JuFu
          meuteM Offline
          meuteM Offline
          meute
          schrieb am zuletzt editiert von meute
          @JuFu sagte in Daheimladen.de mit Modbus Adapter:
          Ja, nutze ich seit ca. 2 Jahren.
          Anleitung:
          https://www.daheimladen.de/post/anleitung-modbus-einrichtung-iobroker
          Bei modbus-Fehler meinen Beitrag beachten:
          https://forum.iobroker.net/post/1134803
          EDIT:
          Zusätzlich lasse ich mir mit einem Blockly bestimmte Stati aufs Handy schicken.
          Zuerst per WhatsApp, jetzt per Pushover.
          G 1 Antwort Letzte Antwort
          • J Offline
            JuFu
            Danke für die Rückmeldung @meute
            Der Beitrag bezieht sich auf die DaheimLaden Wallbox.
            Ich möchte nicht auf die einzelne Wallbox zugreifen sondern auf den LastManager (an welchem 6 Wallboxen hängen).
            • J JuFu
              meuteM Offline
              meuteM Offline
              meute
              Dann solltest Du Dich an den DaheimLaden Support wenden.
              • meuteM meute
                Anleitung:
                EDIT:
                Gonzokalle
                @meute
                Hallo bei uns zieht auch die Daheimladen Touch ein. Ist schon eine Steuerung, Regelung des Ladestroms, über modbus mittlerweile möglich?
                meuteM fuzzy1955F 2 Antworten Letzte Antwort
                • G Gonzokalle
                  @meute
                  meuteM Offline
                  meuteM Offline
                  meute
                  @Gonzokalle sagte:
                  @meute
                  Weiß ich nicht.
                  Habe ich noch nicht benötigt.
                  • G Gonzokalle
                    @meute
                    fuzzy1955F Online
                    fuzzy1955F Online
                    fuzzy1955
                    schrieb am zuletzt editiert von fuzzy1955
                    @Gonzokalle sagte:
                    Hallo Gonzokalle,
                    der Google Copilot (KI) meint folgende Register:
                    DaheimLaden.pdf
                    Vielleicht funktioniert es? Sonst müsstest du den DaheimLaden-Support wegen der Registerliste kontaktieren.
                    Gruß, Fuzzy
                    [EDIT]
                    Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
                    Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
                    Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
                    Großes Danke an alle tatkräftigen Helfer im Forum!
                    • G Offline
                      Gonzokalle
                      Ich danke euch beiden.
                      Ich hatte gehofft, dass da Datenpunke sind in die ich die Werte eintragen kann.
                      So einfach ist es wohl nicht.
                      Mit den Registern muss ich mir mal anschauen.
                      • PLCHome 0P Offline
                        PLCHome 0P Offline
                        PLCHome 0
                        schrieb am zuletzt editiert von PLCHome 0
                        Ich habe den alten ohne Touch. Sie müssten aber vom Modbus her gleich sein meinet Google KI. Ok was technisch bei allen Boxen gleich ist. Du kannst den Strom von 6 A bis 16 A / 32 A in 1‑A‑Schritten regeln, also von 4,2 kW bis 11 kW / 22 kW.
                        Das mit den 6A ist Protokollabhängig. Weniger als 6A ist in der Kommunikation mit dem Auto nicht möglich. Die Begrenzung findet im Auto statt. Wenn man es nachrechnen möchte 16A*230V*3 = 11 kW oder 32A*230V*3 = 22 kW.
                        Wenn du weniger Leistung benötigst und die Möglichkeit in der Verteilung hast, kannst du die Sicherungen für die Phasen 2 und/oder 3 entfernen. Die Box kann – anders als eine EASY – nicht einzelne Phasen selber abschalten.
                        Mit einer Phase liegt der Regelbereich bei 1,4 kW bis 7,3 kW, mit zwei Phasen bei 2,8 kW bis 14,6 kW. Mit einer 11‑kW‑Box oder einem 11 kW PKW, halbiert sich der obere Bereich auf: 3,6 / 7,3 und 11 kW.
                        DIe tatsächlichen Leistungen variieren ein wenig je nach Spannung im Netz.
                        Bis zu welchem Punkt die Batterie geladen wird muss im PKW hinterlegt werden. Die Wallbox hat auch keinen Zugriff auf den Batteriestand.
                        Ich habe dir einmal die Parametrierung von meiner Box angehängt, sie ist aber anders als das, was im PDF oben steht, diese ist aber auch für das PRO Modell.
                        Hier sind die Einstellungen:
                        Einstellungen als Bild nachbearbeitet Text gelöscht (11.07.2026)
                        Nur Holding Registers
                        daheimladen.tsv
                        0A ist aus... 91 Limit_charging_current Limitierung maximaler Ladestrom des Ladevorgangs
                        G PLCHome 0P 2 Antworten Letzte Antwort
                        • G Offline
                          Gonzokalle
                          Vielen Dank für deine Infos.
                          Werde die Wallbox am Wochenende anschließen.
                          Dann werde ich das mal versuchen.
                            daheimladen.tsv
                            Gonzokalle
                            @PLCHome-0
                            Konnte erst jetzt die Wallbox anschließen.
                            Ist das so richtig? Wie geht es dann weiter?
                            • G Gonzokalle
                              @PLCHome-0
                              meuteM Offline
                              meuteM Offline
                              meute
                              @PLCHome-0
                              Schau bitte mal hier:
                              Dann noch die TSV-Config bei HOLDING REGISTER importieren.
                              Ich habe bei EINSTELLUNGEN den Datenabfrageintervall (Data polling interval) von 1.000 ms (1 Sek.) auf 10.000 ms (10 Sek.) geändert.
                              Danach gab es keine Timeout-Verbindungsfehler mehr.
                              Siehe hier:
                              Fehler damals bei mir:
                              https://forum.iobroker.net/topic/67714/daheimladen-de-mit-modbus-adapter/5
                              Meine Lösung:
                              https://forum.iobroker.net/topic/67714/daheimladen-de-mit-modbus-adapter/7
                              So sind meine EINSTELLUNGEN seit 4 Jahren:
                              • meuteM meute
                                @PLCHome-0
                                Siehe hier:
                                Meine Lösung:
                                Gonzokalle
                                @meute
                                Ich danke dir. Es läuft.
                                Das importieren der TSV-Datei in Holding war der entscheidende Hinweis.
                                Die Werte sind nur lesend?
                                  daheimladen.tsv
                                  PLCHome 0P Offline
                                  PLCHome 0P Offline
                                  PLCHome 0
                                  PLCHome-0 sagte:
                                  0 aus, 6 bis Größe der Sicherung gibt den Strom an. Ich weiß jetzt nicht welche tsv du Import hast je nach ein Stellung kommt da noch das Offset drauf auf die Register Nummer
                                  • G Offline
                                    Gonzokalle
                                    schrieb am zuletzt editiert von Gonzokalle
                                    Mit der TSV Config von Daheim Laden funktioniert es gut.
                                    Bei der hier im Forum geposteten TSV Config kommen keine Werte. Da gefällt mir aber die deutsche Beschreibung besser.
                                    Ich habe mal den Text in der TSV von Daheim Laden angepasst.
                                    TSV Config von DaheimLaden auf Deutsch.txt
                                      PLCHome-0 sagte:
                                      Gonzokalle
                                      @PLCHome-0
                                      Das schreiben des maximalen Ladestroms funktioniert noch nicht.
                                      Er bleibt schön bei 16 A.
                                        PLCHome 0P Offline
                                        PLCHome 0
                                        Erst einmal zur Frage, warum die eine TSV-Datei funktioniert und die andere nicht: Du nutzt dort jetzt einen Import mit Alias, wodurch die Register bei 40001 beginnen. Ich habe die Register bei Null anfangen lassen – das regelt dieser Schalter. Wenn du in der TSV-Datei 40001 zur ersten Spalte hinzuaddierst, funktioniert sie.
                                        Es kann natürlich viele Ursachen haben, warum die Box den Wert nicht annimmt. Das Erste, was mir einfällt, ist: Hast du den Schalter gesetzt? Aber eigentlich müsste dann der Wert nicht bestätigt sein.
                                        Oder hast du den Wert mit Ack gesetzt? Dann wird er nicht gesendet und auch nicht zurückgeschrieben...
                                        Kein ACK der Wet soll zum Gerät.
                                        ACK der Wert kommt vom Gerät.
                                        Ansonsten einmal das Debugging einschalten und prüfen, ob dort ein Fehler kommt. Zur Not bei Daheimladen nachfragen oder in der App nachschauen, ob es da nicht noch eine Einstellung gibt.
                                        Du hattest mal gefragt, welche Register sich editieren lassen: Die Register 91 bis 95 (also 40092 bis 40096) lassen sich übrigens editieren.
                                        Ich habe bei mir noch ein JavaScript, das man nach dem Update der Register nur einmal laufen lassen muss. Danach wieder STOP. Danach zeigen die Objekte den Zustand an. Leg einfach ein neues JavaScript an, kopiere den Code hinein und passe die Objektnamen an.
                                        async function setState(id, states){
                                          var s = await getObjectAsync(id);
                                          s.common.states = states;
                                          setObjectAsync(id,s);
                                        setState('modbus.1.holdingRegisters.Charge_command',{"0":"default","1":"Start charging","2":"Stop charging"})
                                        setState('modbus.1.holdingRegisters.Charge_control',{"0":"Plug & Change","1":"RFID / OCPP start+stop","2":"Ladestation gesperrt"})
                                        setState('modbus.1.holdingRegisters.Connection_status',{"0":"No connect to electric vehicle","1":"Connect to electric vehicle"})
                                        setState('modbus.1.holdingRegisters.Error_code',{"0":"No error","11":"CP-Control Value","12":"EStop (nur DHL Smart)","13":"Under Voltage","14":"Over Voltage","15":"Over temperature","16":"Meter Value","17":"Leakage Fault","18":"Output Short","19":"Over Current","21":"Vehicle","22":"Vehicle Unrecognizable","23":"Relay Adhesion","24":"Leakage Check Device","25":"PE fault","26":"Start-up Charging fault"})
                                        setState('modbus.1.holdingRegisters.Status',{"0":"No state","1":"Standby","2":"Connected","3":"Start","4":"Charging","5":"Start fail","6":"Charging end","7":"Charger system fail","8":"Appointment","9":"Firmware Upgrade","10":"Power on","31":"station blocked"})
                                        G meuteM 2 Antworten Letzte Antwort
                                          Gonzokalle
                                          @PLCHome-0
                                          Vielen Dank für deine Hilfe.
                                          Also muss "Aliases benutzen" aus um deine TSV-Datei zu benutzen oder ich muss Adresse mit 40001 addieren?
                                          War bei mir aus. Vielleicht war es das ja schon. Nach dem Urlaub werde ich das probieren.
