  4. Test Adapter e3oncan - Viessmann E3 Serie einbinden
    1.0k
177 Beiträge 14 Kommentatoren 23.0k Aufrufe 16 Beobachtet
    @RaspiCan
    Alle Updates gemacht? Dann zeig jetzt nochmal die Ausgabe von
    iob diag
    RaspiCan
    #167
    @Thomas-Braun
    bookworm hab ich noch nicht auf trixie geschoben
    • R RaspiCan
      @Thomas-Braun
      #168
      @RaspiCan sagte:
      Dann mach das. Der Bücherwurm wird in den nächsten Tagen das EndOfLife erreichen.
      • R Offline
        RaspiCan
        #169
        Script v.2026-06-01
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.12.62+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64bit
        System was installed 451 days ago (on 2025-03-10).
        Systemuptime and Load:
         19:54:38 up  8:06,  4 users,  load average: 1.19, 0.68, 0.53
        CPU threads     : 4
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2026-06-05 19:54:38 CEST
                   Universal time: Fri 2026-06-05 17:54:38 UTC
                         RTC time: n/a
        System clock synchronized: no
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        raspi
        HOME=/home/raspi
        GROUPS=raspi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         Unknown
        Display-Manager:        * lightdm.service - Light Display Manager
        Desktop:
        Session:                tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
        Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            4.0G        1.5G        114M         23M        2.5G        2.5G
        Swap:             0B          0B          0B
        Total:          4.0G        1.5G        114M
        Active iob-Instances:   7
                 3795 M total memory
                 1445 M used memory
                 2438 M active memory
                  893 M inactive memory
                  109 M free memory
                  280 M buffer memory
                 2077 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        top - 19:54:39 up  8:06,  4 users,  load average: 1.19, 0.68, 0.53
        Tasks: 232 total,   1 running, 231 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 40.0 us,  0.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.8 total,    108.4 free,   1446.2 used,   2358.4 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   2349.6 avail Mem
        *** FAILED SERVICES ***
          UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
        * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.4M  379M   1% /run
        /dev/sda2      ext4      916G   20G  849G   3% /
        tmpfs          tmpfs     1.9G  224K  1.9G   1% /dev/shm
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/sda1      vfat      511M   70M  442M  14% /boot/firmware
        tmpfs          tmpfs     380M   48K  380M   1% /run/user/1000
        /dev/mmcblk0p2 ext4       58G  8.0G   48G  15% /media/raspi/rootfs
        /dev/mmcblk0p1 vfat      510M   68M  443M  14% /media/raspi/bootfs
        Messages concerning filesystems in dmesg:
        [Fri Jun  5 11:47:43 2026] EXT4-fs (sda2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
        [Fri Jun  5 11:47:44 2026] EXT4-fs (sda2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w.
        [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): recovery complete
        [Fri Jun  5 11:47:52 2026] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 r/w with ordered data mode. Quota mode: none.
        Show mounted filesystems:
        TARGET                        SOURCE         FSTYPE      OPTIONS
        /                             /dev/sda2      ext4        rw,noatime
        |-/run/user/1000/doc          portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot/firmware              /dev/sda1      vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        |-/media/raspi/rootfs /dev/mmcblk0p2 ext4        rw,nosuid,nodev,relatime,errors=remount-ro
        `-/media/raspi/bootfs /dev/mmcblk0p1 vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
        /var:
        2.5G    /var/
        1.2G    /var/cache
        1.1G    /var/cache/apt
        1002M   /var/cache/apt/archives
        666M    /var/log
        Archived and active journals take up 664.5M in the file system.
        /opt/iobroker/backups:
        4.5G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        5.6G    /opt/iobroker/iobroker-data/
        5.4G    /opt/iobroker/iobroker-data/history
        90M     /opt/iobroker/iobroker-data/files
        55M     /opt/iobroker/iobroker-data/backup-objects
        47M     /opt/iobroker/iobroker-data/files/admin.admin
        16M     /opt/iobroker/iobroker-data/objects.jsonl
        15M     /opt/iobroker/iobroker-data/states.jsonl
        8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
        4.3M    /opt/iobroker/iobroker-data/history/20260221/history.Drehzahl Verdichter Wärmepumpe.json
        4.2M    /opt/iobroker/iobroker-data/history/20260318/history.Drehzahl Verdichter Wärmepumpe.json
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
        please always prefer the links 'by-id':
        No Devices found 'by-id'
        No nvbackup.json found.
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.22.3
        /usr/bin/node           v22.22.3
        /usr/bin/npm            10.9.8
        /usr/bin/npx            10.9.8
        ✓ Node.js installation is correct
        nodejs:
          Installed: 22.22.3-1nodesource1
          Candidate: 22.22.3-1nodesource1
          Version table:
         *** 22.22.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
             22.22.2-1nodesource1 1001
             22.22.1-1nodesource1 1001
             22.22.0-1nodesource1 1001
             22.21.0-1nodesource1 1001
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u2 500
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        No known Vulnerabilities detected!
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 9933)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.8.23
        javascript:     "javascript" not found
        nodejs modules from github:     0
        Adapter State
        + system.adapter.e3oncan.0                : e3oncan               : raspberrypi                              -  enabled
          system.adapter.e3oncan.1                : e3oncan               : raspberrypi                              - disabled
        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        │ (index) │ id                         │ name        │ version  │ upgrade policy │
        │ 0       │ 'system.adapter.admin'     │ 'admin'     │ '7.8.23' │ 'none'         │
        │ 1       │ 'system.adapter.backitup'  │ 'backitup'  │ '3.3.14' │ 'none'         │
        │ 2       │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0'  │ 'none'         │
        │ 3       │ 'system.adapter.e3oncan'   │ 'e3oncan'   │ '1.0.3'  │ 'none'         │
        │ 4       │ 'system.adapter.echarts'   │ 'echarts'   │ '3.1.0'  │ 'none'         │
        │ 5       │ 'system.adapter.history'   │ 'history'   │ '4.0.0'  │ 'none'         │
        │ 6       │ 'system.adapter.socketio'  │ 'socketio'  │ '6.7.1'  │ 'none'         │
        │ 7       │ 'system.adapter.web'       │ 'web'       │ '8.0.0'  │ 'none'         │
        │ 8       │ 'system.adapter.ws'        │ 'ws'        │ '4.0.0'  │ 'none'         │
        ioBroker-Adapter Versions and update status
        Used repository: stable
        Adapter    "admin"        : 7.8.23   , installed 7.8.23
        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
        Adapter    "e3oncan"      : 0.11.3   , installed 1.0.3
        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
        Adapter    "history"      : 4.0.0    , installed 4.0.0
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "socketio"     : 7.1.3    , installed 7.1.3
        Adapter    "web"          : 8.0.0    , installed 8.0.0
        Adapter    "ws"           : 4.0.0    , installed 4.0.0
        Objects and States
        Objects:        6088
        States:         5952
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://mschneider82.github.io/vieventlog stable InRelease
        Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending systemupdates: 0
        *** Listening Ports ***
        Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
        udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=12))
        udp   UNCONN 0      0            0.0.0.0:54621       0.0.0.0:*    users:(("avahi-daemon",pid=495,fd=14))
        udp   UNCONN 0      0                  *:37406             *:*    users:(("avahi-daemon",pid=495,fd=15))
        udp   UNCONN 0      0                  *:mdns              *:*    users:(("avahi-daemon",pid=495,fd=13))
        tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=14888,fd=3))
        tcp   LISTEN 0      128        127.0.0.1:ipp         0.0.0.0:*    users:(("cupsd",pid=629,fd=7))
        tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=39774,fd=29))
        tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=39774,fd=23))
        tcp   LISTEN 0      4096               *:5000              *:*    users:(("vieventlog",pid=25918,fd=5))
        tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=14888,fd=4))
        tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.0",pid=41118,fd=34))
        tcp   LISTEN 0      16                 *:5900              *:*    users:(("wayvnc",pid=680,fd=9))
        tcp   LISTEN 0      128            [::1]:ipp            [::]:*    users:(("cupsd",pid=629,fd=6))
        2026-06-05 18:10:53.480  - warn: backitup.0 (39844) [iobroker/clean] No older backup files are deleted, because this backup was started manually
        2026-06-05 18:12:00.931  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1. backitup
        2026-06-05 18:14:08.604  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:
        2026-06-05 18:14:09.925  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:
        2026-06-05 18:14:15.229  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff: echarts-show
        2026-06-05 18:14:15.244  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 echarts
        2026-06-05 18:16:49.892  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:
        2026-06-05 18:16:51.188  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:
        2026-06-05 18:21:28.956  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 echarts-show
        2026-06-05 18:21:28.968  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 echarts
        2026-06-05 18:23:09.728  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:1
        2026-06-05 18:23:11.340  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:1
        2026-06-05 19:00:04.847  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 echarts-show
        2026-06-05 19:00:05.528  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:1
        2026-06-05 19:02:43.833  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 echarts-show
        2026-06-05 19:02:43.844  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 echarts
        2026-06-05 19:23:48.248  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:1
        2026-06-05 19:28:10.339  - warn: backitup.0 (39844) [iobroker/clean] No older backup files are deleted, because this backup was started manually
        2026-06-05 19:28:57.464  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 backitup
        2026-06-05 19:53:51.327  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 admin
        2026-06-05 19:54:14.615  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:
        2026-06-05 19:54:29.615  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 admin
        2026-06-05 19:54:42.588  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:1
        2026-06-05 19:55:02.650  - info: admin.0 (41118) <== Disconnect system.user.admin from ::ffff:1 admin
        2026-06-05 19:55:40.533  - info: admin.0 (41118) ==> Connected system.user.admin from ::ffff:1
        ============= Mark until here for C&P =============
        • R RaspiCan
          Script v.2026-06-01
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64bit
          CPU threads     : 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          raspi
          HOME=/home/raspi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   3795 M total memory
                   1445 M used memory
                    109 M free memory
                    280 M buffer memory
                   2077 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G    /var/
          1.2G    /var/cache
          1.1G    /var/cache/apt
          666M    /var/log
          USB-Devices by-id:
          /usr/bin/npm            10.9.8
          /usr/bin/npx            10.9.8
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.8.23
          Adapter State
          + instance is alive
          Objects and States
          Objects:        6088
          States:         5952
          #170
          @RaspiCan
          • R Offline
            RaspiCan
            #171
            den bookworm mach ich morgen
            • R RaspiCan
              Script v.2026-06-01
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64bit
              CPU threads     : 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              raspi
              HOME=/home/raspi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Session:                tty
              *** MEMORY ***
              Swap:             0B          0B          0B
                       3795 M total memory
                       1445 M used memory
                        109 M free memory
                        280 M buffer memory
                       2077 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              2.5G    /var/
              1.2G    /var/cache
              1.1G    /var/cache/apt
              666M    /var/log
              USB-Devices by-id:
              /usr/bin/npm            10.9.8
              /usr/bin/npx            10.9.8
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.8.23
              Adapter State
              + instance is alive
              Objects and States
              Objects:        6088
              States:         5952
              #172
              @RaspiCan sagte:
              Boot Target: graphical.target
              Schalt das aus, wenn da kein Monitor am Raspberry hängt.
              Swap: 0B 0B 0B
              Schalt SWAP wieder an, im neuen System dann rpi-swap aktivieren.
              Ansonsten schaut das jetzt soweit i.O. aus.
              • R Offline
                RaspiCan
                #173
                Danke für die Info
                Hab immer wieder mal nen Monitor mit dem Raspi verbunden
                Swap hab ich eingerichtet
                • R RaspiCan
                  Danke für die Info
                  #174
                  @RaspiCan sagte:
                  Für Wartungszwecke unnötig, das macht man ohne GUI per SSH und Terminal.
                  Also ausschalten.
                    @RaspiCan sagte:
                    Beowolf
                    #175
                    @Thomas-Braun sagte:
                    @RaspiCan sagte:
                    Kann ich das so eigentlich auch machen?
                    https://www.bjoerns-techblog.de/2025/08/upgrade-debian-bookworm-zu-trixie/
                    Oder besser Backup - Trixie neu auf SD-Karte - Restore.
                    • B Beowolf
                      @RaspiCan sagte:
                      HomoranH Offline
                      HomoranH Offline
                      #176
                      @Beowolf sagte:
                      Dein Link bezieht sich auf Debian, nicht auf Raspberry Pi OS!
                      • B Beowolf
                        @RaspiCan sagte:
                        #177
                        @Beowolf
                        Die offizielle Verlautbarung lautet:
                        Neuinstallation, Upgrades von Vorversionen werden nicht unterstützt.
                        Ich mache es meist dennoch, dann danach:
                        https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                        • HomoranH Homoran hat dieses Thema am aufgespalten
