  4. Iobroker ist extrem langsam
    6.3k
18 Beiträge 6 Kommentatoren 838 Aufrufe 7 Beobachtet
  • D dg19222
    So jetzt habe ich soweit alles erledigt hier nochmal IOB Diag```
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: IOB
           Icon name: computer-laptop
             Chassis: laptop 💻
              Kernel: Linux 6.12.90+deb13-amd64
        Architecture: x86-64
     Hardware Vendor: HP
      Hardware Model: HP ProBook 650 G2
    Firmware Version: N76 Ver. 01.47
       Firmware Date: Mon 2020-04-27
        Firmware Age: 6y 4w
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     22:09:48 up  1:20,  1 user,  load average: 1.89, 1.40, 1.38
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-05-25 22:09:48 CEST
               Universal time: Mon 2026-05-25 20:09:48 UTC
                     RTC time: Mon 2026-05-25 20:09:48
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dg19222
    HOME=/home/dg19222
    GROUPS=dg19222 adm dialout cdrom floppy audio dip video plugdev users netdev bluetooth lpadmin scanner iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/dg19222
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Display-Manager:        * gdm.service - GNOME Display Manager
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.2G        6.0G        1.6G        6.7M        817M        2.2G
    Swap:           9.6G        1.3G        8.3G
    Total:           17G        7.4G        9.9G
    Active iob-Instances:   43
             7828 M total memory
             5761 M used memory
             4875 M active memory
              933 M inactive memory
             1549 M free memory
               68 M buffer memory
              711 M swap cache
             9168 M total swap
             1286 M used swap
             7882 M free swap
    top - 22:09:49 up  1:21,  1 user,  load average: 1.89, 1.40, 1.38
    Tasks: 204 total,   2 running, 202 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 26.7 us,  2.2 sy,  0.0 ni, 71.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7828.3 total,   1548.1 free,   5762.9 used,    780.4 buff/cache
    MiB Swap:   9169.0 total,   7882.6 free,   1286.4 used.   2065.4 avail Mem
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * apache2.service loaded failed failed The Apache HTTP Server
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     783M  1.5M  782M   1% /run
    /dev/sda2      ext4      116G   56G   55G  51% /
    tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
    efivarfs       efivarfs  118K   54K   60K  48% /sys/firmware/efi/efivars
    tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     3.9G  6.0M  3.9G   1% /tmp
    /dev/sda1      vfat      511M  4.4M  507M   1% /boot/efi
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     783M   64K  783M   1% /run/user/1000
    [Mon May 25 20:48:55 2026] EXT4-fs (sda2): mounted filesystem faf31713-3a11-4cc3-a7d2-20738a3ecde0 ro with ordered data mode. Quota mode: none.
    [Mon May 25 20:48:57 2026] EXT4-fs (sda2): re-mounted faf31713-3a11-4cc3-a7d2-20738a3ecde0 r/w.
    Show mounted filesystems:
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    3.9G    /var/
    3.2G    /var/log/journal/765a48c1431c420a94c5083bf6c36421
    3.2G    /var/log
    452M    /var/cache
    Archived and active journals take up 3.1G in the file system.
    /opt/iobroker/backups:
    25G     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    6.1G    /opt/iobroker/iobroker-data/
    4.5G    /opt/iobroker/iobroker-data/history
    766M    /opt/iobroker/iobroker-data/files
    237M    /opt/iobroker/iobroker-data/backup-objects
    165M    /opt/iobroker/iobroker-data/files/vis
    432M    /opt/iobroker/iobroker-data/states.jsonl
    208M    /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    14M     /opt/iobroker/iobroker-data/files/minuvis/app/static/js/main.5531d89f.js.map
    13M     /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2697414-if00
    *** ZigBee Settings ***
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
            500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IOB                 IOB (version: 7.0.7, hostname: IOB           , alive, uptime: 4866)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     1
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    Adapter State
    + system.adapter.admin.0                  : admin                 : IOB                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : IOB                                      -  enabled
    + system.adapter.backitup.0               : backitup              : IOB                                      -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : IOB                                      -  enabled
    + system.adapter.cloud.0                  : cloud                 : IOB                                      -  enabled
    + system.adapter.daswetter.0              : daswetter             : IOB                                      -  enabled
    + system.adapter.deconz.0                 : deconz                : IOB                                      -  enabled, port: 80
      system.adapter.discovery.0              : discovery             : IOB                                      - disabled
    + system.adapter.divera247.0              : divera247             : IOB                                      -  enabled
      system.adapter.dwd.0                    : dwd                   : IOB                                      -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IOB                                      -  enabled
      system.adapter.feiertage.0              : feiertage             : IOB                                      -  enabled
      system.adapter.flot.0                   : flot                  : IOB                                      - disabled
    + system.adapter.fritzdect.0              : fritzdect             : IOB                                      -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : IOB                                      -  enabled
      system.adapter.harmony.0                : harmony               : IOB                                      - disabled
    + system.adapter.history.0                : history               : IOB                                      -  enabled
      system.adapter.homekit-controller.0     : homekit-controller    : IOB                                      - disabled
      system.adapter.ical.0                   : ical                  : IOB                                      -  enabled
      system.adapter.ical.1                   : ical                  : IOB                                      -  enabled
      system.adapter.ical.2                   : ical                  : IOB                                      -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: IOB                                      - disabled
      system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: IOB                                      - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : IOB                                      - disabled
      system.adapter.icons-freepic.0          : icons-freepic         : IOB                                      - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : IOB                                      - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : IOB                                      - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : IOB                                      - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOB                                      - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOB                                      - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: IOB                                      - disabled
      system.adapter.icons-smarthome.0        : icons-smarthome       : IOB                                      - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IOB                                      - disabled
    + system.adapter.iot.0                    : iot                   : IOB                                      -  enabled
    + system.adapter.javascript.0             : javascript            : IOB                                      -  enabled
    + system.adapter.linux-control.0          : linux-control         : IOB                                      -  enabled
    + system.adapter.logparser.0              : logparser             : IOB                                      -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : IOB                                      -  enabled
      system.adapter.minuvis.0                : minuvis               : IOB                                      - disabled
    + system.adapter.netatmo.0                : netatmo               : IOB                                      -  enabled
    + system.adapter.nina.0                   : nina                  : IOB                                      -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : IOB                                      -  enabled
    + system.adapter.nuki.0                   : nuki                  : IOB                                      -  enabled
    + system.adapter.openligadb.0             : openligadb            : IOB                                      -  enabled
      system.adapter.panasonic-viera.0        : panasonic-viera       : IOB                                      - disabled
    + system.adapter.ping.0                   : ping                  : IOB                                      -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : IOB                                      -  enabled
      system.adapter.pushover.0               : pushover              : IOB                                      - disabled
    + system.adapter.radar2.0                 : radar2                : IOB                                      -  enabled
    + system.adapter.ring.0                   : ring                  : IOB                                      -  enabled
      system.adapter.samsung.0                : samsung               : IOB                                      - disabled
      system.adapter.scenes.0                 : scenes                : IOB                                      - disabled
    + system.adapter.senec.0                  : senec                 : IOB                                      -  enabled
    + system.adapter.shelly.0                 : shelly                : IOB                                      -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : IOB                                      - disabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : IOB                                      -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : IOB                                      -  enabled
    + system.adapter.systeminfo.0             : systeminfo            : IOB                                      -  enabled
    + system.adapter.tahoma.1                 : tahoma                : IOB                                      -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IOB                                      -  enabled
    + system.adapter.tapo.1                   : tapo                  : IOB                                      -  enabled
    + system.adapter.telegram.0               : telegram              : IOB                                      -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : IOB                                      -  enabled
      system.adapter.tr-064.1                 : tr-064                : IOB                                      - disabled
      system.adapter.tr-064.2                 : tr-064                : IOB                                      - disabled
    + system.adapter.tr-064.3                 : tr-064                : IOB                                      -  enabled
    + system.adapter.tuya.0                   : tuya                  : IOB                                      -  enabled
      system.adapter.upnp.0                   : upnp                  : IOB                                      - disabled
      system.adapter.viessmannapi.0           : viessmannapi          : IOB                                      - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IOB                                      - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IOB                                      - disabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: IOB                                      - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IOB                                      - disabled
      system.adapter.vis-bars.0               : vis-bars              : IOB                                      - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : IOB                                      - disabled
      system.adapter.vis-history.0            : vis-history           : IOB                                      - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOB                                      - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : IOB                                      - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : IOB                                      -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOB                                      - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : IOB                                      - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : IOB                                      - disabled
      system.adapter.vis-map.0                : vis-map               : IOB                                      - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : IOB                                      - disabled
      system.adapter.vis-material.0           : vis-material          : IOB                                      - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOB                                      - disabled
      system.adapter.vis-metro.0              : vis-metro             : IOB                                      - disabled
      system.adapter.vis-players.0            : vis-players           : IOB                                      - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : IOB                                      - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : IOB                                      - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOB                                      - disabled
      system.adapter.vis-weather.0            : vis-weather           : IOB                                      - disabled
      system.adapter.vis.0                    : vis                   : IOB                                      -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : IOB                                      -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : IOB                                      - disabled
    + system.adapter.web.0                    : web                   : IOB                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : IOB                                      -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "alexa-shoppinglist": 1.1.3, installed 1.1.3
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "cloud"        : 6.0.1    , installed 6.0.1
    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
    Adapter    "deconz"       : 1.7.4    , installed 1.7.4
    Adapter    "divera247"    : 0.2.0    , installed 0.2.0
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "harmony"      : 2.1.0    , installed 2.1.0
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "ical"         : 1.20.0   , installed 1.20.0
    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
    Adapter    "minuvis"      : 2.7.1    , installed 2.7.1
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "openligadb"   : 1.9.3    , installed 1.9.3
    Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "pushover"     : 5.0.0    , installed 5.0.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "ring"         : 6.4.0    , installed 6.4.0
    Adapter    "samsung"      : 0.7.0    , installed 0.7.0
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "senec"        : 2.5.3    , installed 2.5.3
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
    Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 4.0.0    , installed 4.0.0
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
    Adapter    "vis-2-widgets-jaeger-design": 1.4.19, installed 1.4.19
    Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
    Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "worx"         : 3.3.0    , installed 3.3.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        314968
    States:         274235
    Get:1 http://phoscon.de/apt/deconz generic InRelease [4318 B]
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://security.debian.org/debian-security trixie-security InRelease
    Hit:4 http://deb.debian.org/debian trixie-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
    Fetched 4318 B in 1s (4989 B/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13924      1628/io.sonoff.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8178       1289/exim4
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          10411      982/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12303      983/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6936       983/iobroker.js-con
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       9984       754/deCONZ
    tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       10073      754/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6806       1011/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       9983       754/deCONZ
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4504       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6808       1011/sshd: /usr/sbi
    tcp6       0      0 :::111                  :::*                    LISTEN      0          4506       1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8179       1289/exim4
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90716      10606/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12809      1321/io.admin.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          10410      982/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       18010      1444/io.fullybrowse
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       14616      1576/io.radar2.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4505       1/init
    udp        0      0 0.0.0.0:38111           0.0.0.0:*                           106        9938       742/avahi-daemon: r
    udp        0      0 192.168.0.157:5353      0.0.0.0:*                           1001       13936      1664/io.tr-064.3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        9936       742/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18669      1616/io.shelly.0
    udp        0      0 0.0.0.0:50975           0.0.0.0:*                           1001       11249      1396/io.broadlink2.
    udp        0      0 0.0.0.0:46942           0.0.0.0:*                           1001       13497      1396/io.broadlink2.
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13697      1420/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       10075      754/deCONZ
    udp        0      0 0.0.0.0:59659           0.0.0.0:*                           1001       11250      1396/io.broadlink2.
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18451      1676/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18452      1676/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       11108      1396/io.broadlink2.
    udp6       0      0 :::111                  :::*                                0          4507       1/init
    udp6       0      0 fe80::8882:617f:f9e:546 :::*                                0          91164      955/NetworkManager
    udp6       0      0 :::37548                :::*                                106        9939       742/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                106        9937       742/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       13700      1420/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       13699      1420/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       13698      1420/io.deconz.0
    2026-05-25 22:13:00.027  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getState(id=javascript.0.zeiten.tageslaenge_tageslicht_in_minuten, timerId=undefined) => {"val":"0","ack":false,"ts":1779736440050,"q":0,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1779736440050}
    2026-05-25 22:13:00.027  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getState(id=javascript.0.zeiten.tageslaenge_tageslicht, timerId=undefined) => {"val":"00:00","ack":false,"ts":1779736440050,"q":0,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1779736440050}
    2026-05-25 22:13:00.027  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getAstroDate(pattern=sunrise, date=Mon May 25 2026 12:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)) => Mon May 25 2026 05:34:18 GMT+0200 (Mitteleuropäische Sommerzeit)
    2026-05-25 22:13:00.027  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getState(id=javascript.0.zeiten.nachtlaenge_in_minuten, timerId=undefined) => {"val":"500","ack":false,"ts":1779739200116,"q":0,"c":"script.js.smarthome.system.smarthome.system.Tag_und_Nacht_Länge","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1779660600223}
    2026-05-25 22:13:00.027  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: setForeignState(id=javascript.0.zeiten.nachtlaenge_fortschritt, state={"val":"88","ack":false,"ts":1779739980027,"q":0,"from":"system.adapter.javascript.0","lc":1779739920405,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2"})
    2026-05-25 22:13:00.027  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: setForeignState(id=javascript.0.zeiten.nachtlaenge_keinlicht, state={"val":"07:21","ack":false,"ts":1779739980027,"q":0,"from":"system.adapter.javascript.0","lc":1779739980023,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2"})
    2026-05-25 22:13:02.431  - warn: linux-control.0 (1776) State "linux-control.0.IOB.updates.lastUpdate" has no existing object, this might lead to an error in future versions
    2026-05-25 22:13:04.412  - info: linux-control.0 (1776) successful received data from IOB (192.168.0.157:22)
    2026-05-25 22:13:08.524  - error: tapo.1 (1818) 671 Error Code: Bad control character in string literal in JSON at position 15 (line 1 column 16), undefined 192.168.0.26
    2026-05-25 22:13:09.141  - error: tapo.1 (1818) 671 Error Code: Bad escaped character in JSON at position 16 (line 1 column 17), undefined 192.168.0.32
    2026-05-25 22:14:00.611  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getState(id=javascript.0.zeiten.sonnenaufgang, timerId=undefined) => {"val":"05:34","ack":false,"ts":1779682500359,"q":0,"c":"script.js.Java.Sonenaauf_und_untergang","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1779682500301}
    2026-05-25 22:14:00.621  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getState(id=javascript.0.zeiten.tageslaenge_tageslicht_in_minuten, timerId=undefined) => {"val":"0","ack":false,"ts":1779736440050,"q":0,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1779736440050}
    2026-05-25 22:14:00.621  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getState(id=javascript.0.zeiten.tageslaenge_tageslicht, timerId=undefined) => {"val":"00:00","ack":false,"ts":1779736440050,"q":0,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1779736440050}
    2026-05-25 22:14:00.621  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getAstroDate(pattern=sunrise, date=Mon May 25 2026 12:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)) => Mon May 25 2026 05:34:18 GMT+0200 (Mitteleuropäische Sommerzeit)
    2026-05-25 22:14:00.621  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getState(id=javascript.0.zeiten.nachtlaenge_in_minuten, timerId=undefined) => {"val":"500","ack":false,"ts":1779739200116,"q":0,"c":"script.js.smarthome.system.smarthome.system.Tag_und_Nacht_Länge","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1779660600223}
    2026-05-25 22:14:00.621  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: setForeignState(id=javascript.0.zeiten.nachtlaenge_fortschritt, state={"val":"88","ack":false,"ts":1779740040621,"q":0,"from":"system.adapter.javascript.0","lc":1779739920405,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2"})
    2026-05-25 22:14:00.621  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: setForeignState(id=javascript.0.zeiten.nachtlaenge_keinlicht, state={"val":"07:20","ack":false,"ts":1779740040621,"q":0,"from":"system.adapter.javascript.0","lc":1779740040621,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2"})
    2026-05-25 22:14:00.622  - info: javascript.0 (1348) script.js.smarthome.system.smarthome.system.zeiten_v2: getState(id=javascript.0.zeiten.tageslaenge_tageslicht_in_minuten, timerId=undefined) => {"val":"0","ack":false,"ts":1779736440050,"q":0,"c":"script.js.smarthome.system.smarthome.system.zeiten_v2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1779736440050}
    2026-05-25 22:14:29.942  - info: javascript.0 (1348) script.js.smarthome.Wetter.Windrichtung: Stopping script
    2026-05-25 22:14:34.866  - info: javascript.0 (1348) script.js.smarthome.Wetter.Windrichtung: start JavaScript (Blockly)
    2026-05-25 22:14:34.895  - info: javascript.0 (1348) script.js.smarthome.Wetter.Windrichtung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    iob diag has finished.
    Im Admin ist die höchste Zahl die ich finde 997 der JavaScript Adapter.
    Vissmann Adapter ist aus wirklich schneller wurde es leider  nicht.
    Hat jemand weitere Ideen
    @dg19222 sagte:
    • apache2.service loaded failed failed The Apache HTTP Server
    Was ist denn mit dem los? und warum läuft der apache2 überhaupt auf der Kiste?
    Der ioBroker braucht den jedenfalls nicht.
    Schau dir deine Skripte an.
      dg19222
      Apache ist Deinstalliert auf was soll ich genau achten bei den Skripten?
      LG Daniel
      • D dg19222
        LG Daniel
        @dg19222 sagte:
        Keine Ahnung. Aber man kann sich in den Skripten halt sehr einfach selber ein Bein stellen.
          dg19222
          Danke dir für die schnelle Hilfe werde die Skripte mal alle durchgehen hoffentlich finde ich noch was denn so macht es kein wirklichen Spass.
          • D dg19222
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @dg19222
            wie du oben geschrieben hast, hat der javascript adapter über 900 events.
            du hast leider nicht geschrieben ob input oder output events
            deaktiviere mal den ganzen adapter und schaue ob die performance besser wird.
            wenn die performance besser wird,
            dann gehe deine skripte der reihe nach durch und prüfe insbesondere darauf wieviel datenpunkte so in einer zeiteinheit (sekunde/minute) gelesen und geschrieben wird und überlege dir bspw bei sekündlichem schreiben ob diese detaillierte auflösung von daten wichtig sind. of reicht eigentlich auch nur 30sekunden oder gar mehr.
            jedes lesen und insbesondere schreiben beansprucht performance. besonders dann, wenn der datenpunkt auch noch über den history adapter in eine datenbank geschrieben wird.
            evtl kannst du generell nach nicht so wichtigen datenpunkten suchen, ob die wirklich in eine datenbank geschrieben werden müssen.
            um herauszufinden welches skript viel input/output hat, kannst du auch mal alle skripte deaktivieren, der reihe nach aktivieren und dann die input/output anzeige im admin beobachten. funktioniert natürlich nur wenn die immer gleichmäßig schreiben. wenn das getimte zeiten sind, dann halt nur dann.
            du hast nichts von abstürzen geschrieben. gerade bei javascripts kann man sich gerne mit falscher behandlung von setInterval oder gar verschachtelten setIntervals sogenannte memory leaks holen, die irgendwann mal zum Absturz führen, davor sich aber mit einem kontinuierlichen verbrauch das RAMs ankündigen. je nach schwere und häufigkeit der memory leaks kann das auch länger dauern.
            also ggfs mal über einen zeitraum auch den ram verbrauch beobachten. zu wenig freier ram kann sich ebenfalls in schlechter performance zeigen, falls das betriebssystem mit dem swappen anfängt.
            Meine Adapter und Widgets
            Links im Profil
              @rscsb sagte:
              Dein viessmannapi müllt Dir Dein Sytem zu.
              Das ist ja auch einer aus dem trüben github gefischter. Und auch nicht mehr auf aktuellem Stand. Da muss @dg19222 ja ohnehin mal putzen und auch den anderen Krempel auf repo-gestützte Versionen bringen.
              viessmannapi
              github:	2.4.5
              latest:	2.4.5 for 24 days
              stable:	-.-.-
              Aber warum vermutest du genau diesen Adapter? Eigene Erfahrung?
              rscsb
              schrieb am zuletzt editiert von rscsb
              @Thomas-Braun sagte:
              Nein, ich habe keine Viessmann, aber in Thread ioB sehr langsam, Proxmox ständig im Staubsaugermodus hatten wir auch über 350000 Objekte und da waren die unter viessmann drin.
              Deshalb war das meine Empfehlung dort gleich zu schauen.
              @dg19222 sagte:
              Du sollst auch nicht nur den Adapter ausschalten, sondern schauen, wo diese hohe Anzahl an Objekte und States vergraben sind. Im obigen Thread war dieser Adapter der Übeltäter, der in der Baumstruktur Müll erzeugt hat.
                dg19222
                So jetzt aber habe mal etwas aufgeräumt den Vissman Adapter gelöscht und sie da die Kiste rennt wieder danke euch für die Hilfe
                  dg19222
                  So nochmal ich meint ihr ein multi Host würde mir noch was bringen an Leistung?
                  • D dg19222
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @dg19222 sagte:
                    warum dann
                    @dg19222 sagte:
                    außerdem ein 2tes System zur Wartung
                      dg19222
                      Was haltet ihr von dem als neue Hardware
                      https://www.ram-koenig.de/dell-optiplex-3000-tc-d15u-intel-n6005-16ddr4-256nvme-wifi-psu/10191
