  4. Test Adapter Midea Geräten v1.x.x
    6.3k
mideadimstalnethomenethome plus
434 Beiträge 68 Kommentatoren 124.4k Aufrufe 67 Beobachtet
  • Holger EtzelH Holger Etzel
    hallo, ich versuche den Midea-Adapter zu installieren. Bekomme dann die Meldung, das ich Python 3.8 installieren soll. Wie installiert mal Python, und vor allem wo. Ich ahbe schon ein paar Versuche hinter mit und bekomme es nicht hin.
    $ iobroker url TA2k/ioBroker.midea --host raspberry --debug
    install TA2k/ioBroker.midea
    NPM version: 10.9.7
    Installing TA2k/ioBroker.midea... (System call)
    npm error code 1
    npm error git dep preparation failed
    npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > esbuild@0.11.23 postinstallnpm error > node install.jsnpm errornpm errornpm error > iobroker.midea@0.1.0 postinstallnpm error > node ./pythonPackages.jsnpm errornpm errornpm error Start Python package installationnpm errornpm error Python 3 not found. Please install minimum python 3.8npm error npm warn using --force Recommended protections disabled.npm error npm warn deprecated @humanwhocodes/config-array@0.13.0: Use @eslint/config-array insteadnpm error npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema insteadnpm error npm warn deprecated glob@10.5.0: Old versions of glob are not supported, and contain widely publicized security vulnerabilities, which have been fixed in the current version. Please update. Support for old versions may be purchased (at exorbitant rates) by contacting i@izs.menpm error npm warn deprecated eslint@8.57.1: This version is no longer supported. Please see https://eslint.org/version-support for other options.npm error /bin/sh: 1: python3: not foundnpm error npm error code 1npm error npm error path /home/iobroker/.npm/_cacache/tmp/git-clonei3tMNdnpm error npm error command failednpm error npm error command sh -c node ./pythonPackages.jsnpm error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-18T18_18_38_166Z-debug-0.log
    host.raspberry Cannot install TA2k/ioBroker.midea: 1
    ERROR: Process exited with code 25
    tombox
    #381
    @Holger-Etzel das mit dem python wird aber nicht richtig funktionieren.. ich werde es wohl nochmal umschreiben aber brauch jemand zum testen via email tombox2020@gmail.com
    • T tombox
      #382
      @tombox
      Ja, ändere es dahingehend, das es richtig in einem ENV läuft.
      Die obige Installation musste ich etwas dreckig machen...
        @Thomas-Braun
        lässt sich Debian leichter bedienen als Ubuntu, oder warum schwört jeder auf Debian. Sorry für meine blöde Frage, ich kenne es halt nicht
        tombox
        #383
        @Holger-Etzel ist jetzt alles wieder native nodejs.. bitte mal testen
          @Thomas-Braun
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          #384
          @Holger-Etzel als Otto-Normal-Benutzer der Server-Version ohne GUI, also maximal in der Bash unterwegs wirst du Unterschiede mit der Lupe suchen müssen.
          Debian besteht komplett aus freier Software, also ohne proprietäre Treiber oder Programme wie z.B. Grafikkartentreiber.
          Ubuntu integriert bei Bedarf eben diese Treiber und Programme wenn diese benötigt werden.
          Bedienen lässt sich beides gleich. Wenn ich für etwas keine Anleitung für Ubuntu finde, nehme ich eben die von Debian.
          Ubuntu basiert auf Debian, hat aber z.B. seine eigenen Kernel.
          Die Wahrheit liegt wie immer in der Mitte - Proxmox basiert z.B. Debian, nutzt aber den Ubuntu-Kernel.
          Im Gewerblichen Umfeld interessant: Bei Ubuntu kann man direkt bei Canonical (der Firma dahinter) Support einkaufen, bei Debian gibt es so etwas nicht direkt. Weshalb es innerhalb von Appliances steckt, z.B. in Everpure-Storagesystemen (ehemals Pure Storage)
          Ein Unterschied bei den Nutzern von Ubuntu ist, das diese sich nicht negativ über Debian äußern, Debianer aber gerne über Ubuntu herziehen weil es ja nur abgeleitet ist und nicht das Original ist.
          Wie auch über die 51 anderen bekannten Linux-Distributionen die auf Debian basieren: https://de.wikipedia.org/wiki/Kategorie:Debian-basierte_Linux-Distribution
          Also: Kein Problem, nimm was du meinst, du wirst zurecht kommen.
          Thomas BraunT T 2 Antworten Letzte Antwort
          • BananaJoeB BananaJoe
            #385
            @BananaJoe sagte:
            Nein, nicht weil es auf Debian basiert kritisiere ich Ubuntu, sondern wegen deren mehr als seltsamen Entscheidungen und ihrem komischen Sonderstrick (z. B. snap) in der Vergangnenheit, der dann meist auch nach relativ kurzer Zeit wieder eingestellt wurde.
            Das stimmt so auch nicht. Frag mal die Leute von
            https://libre.debian.net/
              tombox
              #386
              @BananaJoe Der Adapter wurde komplett neu geschrieben bitte testen ob er noch funktioniert
              • T tombox
                BananaJoeB Offline
                BananaJoeB Offline
                BananaJoe
                #387
                @tombox Anmeldung klappt nicht.
                Ich nutze die NetHome Plus App, Passwort ist richtig! Gerade mit der App kontrolliert und im Adapter neu gesetzt:
                2026-05-19 11:53:41.900  - info: host.iobroker instance system.adapter.midea.0 in version "1.3.0" (non-npm: TA2k/ioBroker.midea) started with pid 29112
                2026-05-19 11:53:42.930  - info: midea.0 (29112) starting. Version 1.3.0 (non-npm: TA2k/ioBroker.midea) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.1.2
                2026-05-19 11:53:47.981  - info: midea.0 (29112) LAN discovery found 2 appliance(s)
                2026-05-19 11:53:48.468  - warn: midea.0 (29112) Could not fetch token/key for 145135534971917: CloudClient: Account or password incorrect, please re-enter (code=3102) — the device is offline in the cloud account, or the credentials in the adapter config are wrong.
                2026-05-19 11:53:48.888  - warn: midea.0 (29112) Could not fetch token/key for 144036023343615: CloudClient: Account or password incorrect, please re-enter (code=3102) — the device is offline in the cloud account, or the credentials in the adapter config are wrong.
                2026-05-19 11:53:49.195  - warn: midea.0 (29112) Cloud listAppliances failed: CloudClient: Account or password incorrect, please re-enter (code=3102)
                Hier als Debug:
                2026-05-19 11:58:12.264  - info: host.iobroker "system.adapter.midea.0" enabled
                2026-05-19 11:58:13.059  - info: host.iobroker instance system.adapter.midea.0 in version "1.3.0" (non-npm: TA2k/ioBroker.midea) started with pid 30124
                2026-05-19 11:58:13.620  - debug: midea.0 (30124) Redis Objects: Use Redis connection: 0.0.0.0:9001
                2026-05-19 11:58:14.645  - debug: midea.0 (30124) Objects client ready ... initialize now
                2026-05-19 11:58:14.647  - debug: midea.0 (30124) Objects create System PubSub Client
                2026-05-19 11:58:14.647  - debug: midea.0 (30124) Objects create User PubSub Client
                2026-05-19 11:58:14.811  - debug: midea.0 (30124) Objects client initialize lua scripts
                2026-05-19 11:58:14.820  - debug: midea.0 (30124) Objects connected to redis: 0.0.0.0:9001
                2026-05-19 11:58:14.902  - debug: midea.0 (30124) Redis States: Use Redis connection: 127.0.0.1:6379
                2026-05-19 11:58:14.910  - debug: midea.0 (30124) States create System PubSub Client
                2026-05-19 11:58:14.911  - debug: midea.0 (30124) States create User PubSub Client
                2026-05-19 11:58:14.915  - debug: midea.0 (30124) States connected to redis: 127.0.0.1:6379
                2026-05-19 11:58:15.397  - info: midea.0 (30124) starting. Version 1.3.0 (non-npm: TA2k/ioBroker.midea) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.1.2
                2026-05-19 11:58:15.414  - debug: midea.0 (30124) Schedule restart: 1 4,13 * * *
                2026-05-19 11:58:16.461  - debug: midea.0 (30124) Midea adapter starting up, poll interval=30 s
                2026-05-19 11:58:16.462  - debug: midea.0 (30124) discover: starting UDP broadcast target=255.255.255.255 timeoutMs=5000
                2026-05-19 11:58:16.543  - debug: midea.0 (30124) discover: 192.168.1.30 -> id=145135534971917 type=0xac (ac) v3=true
                2026-05-19 11:58:16.551  - debug: midea.0 (30124) discover: 192.168.1.29 -> id=144036023343615 type=0xac (ac) v3=true
                2026-05-19 11:58:21.463  - debug: midea.0 (30124) discover: finished, 2 appliance(s)
                2026-05-19 11:58:21.464  - info: midea.0 (30124) LAN discovery found 2 appliance(s)
                2026-05-19 11:58:21.564  - debug: midea.0 (30124) CloudClient: POST /v1/user/login/id/get bodyLen=205 hasToken=false
                2026-05-19 11:58:22.260  - debug: midea.0 (30124) CloudClient: /v1/user/login/id/get reply code=3102 msg=Account or password incorrect, please re-enter
                2026-05-19 11:58:22.260  - warn: midea.0 (30124) Could not fetch token/key for 145135534971917: CloudClient: Account or password incorrect, please re-enter (code=3102) — the device is offline in the cloud account, or the credentials in the adapter config are wrong.
                2026-05-19 11:58:22.367  - debug: midea.0 (30124) CloudClient: POST /v1/user/login/id/get bodyLen=205 hasToken=false
                2026-05-19 11:58:22.684  - debug: midea.0 (30124) CloudClient: /v1/user/login/id/get reply code=3102 msg=Account or password incorrect, please re-enter
                2026-05-19 11:58:22.684  - warn: midea.0 (30124) Could not fetch token/key for 144036023343615: CloudClient: Account or password incorrect, please re-enter (code=3102) — the device is offline in the cloud account, or the credentials in the adapter config are wrong.
                2026-05-19 11:58:22.684  - debug: midea.0 (30124) CloudClient: POST /v1/user/login/id/get bodyLen=205 hasToken=false
                2026-05-19 11:58:22.993  - debug: midea.0 (30124) CloudClient: /v1/user/login/id/get reply code=3102 msg=Account or password incorrect, please re-enter
                2026-05-19 11:58:22.993  - warn: midea.0 (30124) Cloud listAppliances failed: CloudClient: Account or password incorrect, please re-enter (code=3102)
                Die alte Version 0.0.7 konnte zwar nicht schalten, aber die Werte abfragen
                Edit: Passende Tokens für die Geräte für den lokalen Zugriff hätte ich sogar, kann man die manuell setzen?
                • BananaJoeB Offline
                  BananaJoeB Offline
                  BananaJoe
                  #388
                  Und im Objekte-Baum habe ich die Anlagen jetzt 2x:
                  Die unteren unterhalb von devices sind von der neuen Version? Das es Klimaanlagen sind, wurde ja scheinbar schon erkannt
                    tombox
                    #389
                    @BananaJoe wie hat der login dann geklappt?
                    bitte v1.4.0 testen
                    • T tombox
                      bitte v1.4.0 testen
                      BananaJoeB Offline
                      BananaJoeB Offline
                      BananaJoe
                      #390
                      @tombox Ok, nachdem ich Entdeckt hatte, das man nun in den Einstellungen die App auswählen kann, klappt es, hier ein Auszug dem dem Debug-Log:
                      2026-05-19 16:00:03.458  - debug: midea.0 (79590) AC[144036023343615]: refreshNewProtocol() -> sending B1 query
                      2026-05-19 16:00:03.458  - debug: midea.0 (79590) Device[144036023343615]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a0009000a8aca
                      2026-05-19 16:00:03.458  - debug: midea.0 (79590) LanClient[144036023343615]: pump label=getNewProtocol queue=0
                      2026-05-19 16:00:03.458  - debug: midea.0 (79590) LanClient[144036023343615]: connecting to 192.168.1.29:6444 (protocol=3)
                      2026-05-19 16:00:03.458  - debug: midea.0 (79590) Device[144036023343615]: _request(getNewProtocol) failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:03.471  - warn: midea.0 (79590) State "midea.0.144036023343615.status.online" has no existing object, this might lead to an error in future versions
                      2026-05-19 16:00:03.895  - debug: midea.0 (79590) LanClient[144036023343615]: connected
                      2026-05-19 16:00:03.896  - debug: midea.0 (79590) LanClient[144036023343615]: handshake start tokenLen=64
                      2026-05-19 16:00:03.896  - debug: midea.0 (79590) LanClient[144036023343615]: pump error label=null (LanClient: not connected)
                      2026-05-19 16:00:05.010  - error: midea.0 (79590) uncaught exception: connect ETIMEDOUT 192.168.1.29:6444
                      2026-05-19 16:00:05.010  - error: midea.0 (79590) Error: connect ETIMEDOUT 192.168.1.29:6444
                      2026-05-19 16:00:05.010  - error: midea.0 (79590) Exception-Code: ETIMEDOUT: connect ETIMEDOUT 192.168.1.29:6444
                      2026-05-19 16:00:05.012  - info: midea.0 (79590) terminating
                      2026-05-19 16:00:05.012  - warn: midea.0 (79590) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2026-05-19 16:00:05.513  - info: midea.0 (79590) terminating
                      2026-05-19 16:00:05.710  - error: host.iobroker instance system.adapter.midea.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2026-05-19 16:00:05.710  - info: host.iobroker Restart adapter system.adapter.midea.0 because enabled
                      2026-05-19 16:00:07.154  - info: host.iobroker instance system.adapter.midea.0 in version "1.6.0" (non-npm: TA2k/ioBroker.midea) started with pid 80756
                      2026-05-19 16:00:07.645  - debug: midea.0 (80756) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2026-05-19 16:00:07.697  - debug: midea.0 (80756) Objects client ready ... initialize now
                      2026-05-19 16:00:07.698  - debug: midea.0 (80756) Objects create System PubSub Client
                      2026-05-19 16:00:07.698  - debug: midea.0 (80756) Objects create User PubSub Client
                      2026-05-19 16:00:07.858  - debug: midea.0 (80756) Objects client initialize lua scripts
                      2026-05-19 16:00:07.861  - debug: midea.0 (80756) Objects connected to redis: 0.0.0.0:9001
                      2026-05-19 16:00:07.944  - debug: midea.0 (80756) Redis States: Use Redis connection: 127.0.0.1:6379
                      2026-05-19 16:00:07.946  - debug: midea.0 (80756) States create System PubSub Client
                      2026-05-19 16:00:07.947  - debug: midea.0 (80756) States create User PubSub Client
                      2026-05-19 16:00:07.949  - debug: midea.0 (80756) States connected to redis: 127.0.0.1:6379
                      2026-05-19 16:00:08.218  - info: midea.0 (80756) starting. Version 1.6.0 (non-npm: TA2k/ioBroker.midea) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.1.2
                      2026-05-19 16:00:08.240  - debug: midea.0 (80756) Schedule restart: 1 4,13 * * *
                      2026-05-19 16:00:08.271  - debug: midea.0 (80756) Midea adapter starting up, poll interval=30 s
                      2026-05-19 16:00:08.273  - debug: midea.0 (80756) CloudClientV1: POST /v1/user/login/id/get hasToken=false
                      2026-05-19 16:00:08.381  - debug: midea.0 (80756) CloudClientV1: POST /v1/user/login hasToken=false
                      2026-05-19 16:00:08.434  - debug: midea.0 (80756) CloudClientV1: authenticated (app=nethome)
                      2026-05-19 16:00:08.434  - debug: midea.0 (80756) CloudClientV1: listAppliances()
                      2026-05-19 16:00:08.434  - debug: midea.0 (80756) CloudClientV1: POST /v1/appliance/user/list/get hasToken=true
                      2026-05-19 16:00:08.497  - debug: midea.0 (80756) discover: starting UDP broadcast targets=[192.168.3.255] ports=[6445,20086] timeoutMs=5000
                      2026-05-19 16:00:08.601  - debug: midea.0 (80756) discover: 192.168.1.30 -> id=145135534971917 type=0xac (ac) protocol=3
                      2026-05-19 16:00:13.499  - debug: midea.0 (80756) discover: finished, 1 appliance(s)
                      2026-05-19 16:00:13.499  - info: midea.0 (80756) LAN discovery found 1 appliance(s)
                      2026-05-19 16:00:13.644  - debug: midea.0 (80756) CloudClientV1: getToken(udpId=a6c623fa83691f32c2e4b6e613451dde)
                      2026-05-19 16:00:13.645  - debug: midea.0 (80756) CloudClientV1: POST /v1/iot/secure/getToken hasToken=true
                      2026-05-19 16:00:13.722  - debug: midea.0 (80756) Device 145135534971917: token/key fetched (token=98C93C8F…)
                      2026-05-19 16:00:13.725  - debug: midea.0 (80756) AC[145135534971917]: refreshCapabilities() -> sending B5 query
                      2026-05-19 16:00:13.726  - debug: midea.0 (80756) Device[145135534971917]: _request(getCapabilities) cmdHex=aa0eac00000000000303b501118eeb
                      2026-05-19 16:00:13.726  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getCapabilities queue=0
                      2026-05-19 16:00:13.730  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:13.822  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:13.823  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:14.230  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getCapabilities (LanClient: authenticate ERROR)
                      2026-05-19 16:00:14.231  - debug: midea.0 (80756) Device[145135534971917]: _request(getCapabilities) failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:14.232  - warn: midea.0 (80756) refreshCapabilities for 145135534971917 failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:14.232  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
                      2026-05-19 16:00:14.232  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
                      2026-05-19 16:00:14.232  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
                      2026-05-19 16:00:14.232  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:14.234  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:14.234  - warn: midea.0 (80756) refreshStatus for 145135534971917 failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:14.235  - debug: midea.0 (80756) AC[145135534971917]: refreshPowerUsage() -> sending C1 query
                      2026-05-19 16:00:14.235  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) cmdHex=aa11ac00000000000303412101440001098c
                      2026-05-19 16:00:14.235  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getPowerUsage queue=0
                      2026-05-19 16:00:14.235  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:14.235  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:14.237  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:14.240  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:14.240  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:14.725  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getPowerUsage (LanClient: authenticate ERROR)
                      2026-05-19 16:00:14.725  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:14.725  - debug: midea.0 (80756) refreshPowerUsage for 145135534971917 failed (not all units support it): LanClient: authenticate ERROR
                      2026-05-19 16:00:14.726  - debug: midea.0 (80756) AC[145135534971917]: refreshOperatingTime() -> sending C1/40 query
                      2026-05-19 16:00:14.726  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) cmdHex=aa11ac000000000003034121014000019702
                      2026-05-19 16:00:14.726  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getOperatingTime queue=0
                      2026-05-19 16:00:14.726  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:14.726  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:14.726  - debug: midea.0 (80756) refreshOperatingTime for 145135534971917 failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:14.727  - debug: midea.0 (80756) AC[145135534971917]: refreshHumidity() -> sending C1/45 query
                      2026-05-19 16:00:14.727  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) cmdHex=aa11ac00000000000303412101450001a2f2
                      2026-05-19 16:00:14.727  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getHumidity queue=0
                      2026-05-19 16:00:14.727  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:14.787  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:14.787  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:14.788  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:14.788  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:15.240  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getHumidity (LanClient: authenticate ERROR)
                      2026-05-19 16:00:15.240  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:15.240  - debug: midea.0 (80756) refreshHumidity for 145135534971917 failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:15.241  - debug: midea.0 (80756) AC[145135534971917]: refreshNewProtocol() -> sending B1 query
                      2026-05-19 16:00:15.241  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a000900024814
                      2026-05-19 16:00:15.241  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getNewProtocol queue=0
                      2026-05-19 16:00:15.241  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:15.242  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:15.242  - debug: midea.0 (80756) refreshNewProtocol for 145135534971917 failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:15.244  - warn: midea.0 (80756) Appliance 144036023343615 (Wohnzimmer) is bound to the cloud account but did not respond to LAN discovery — control requires a local broadcast domain, or UDP/6445 is firewalled.
                      2026-05-19 16:00:15.294  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:15.294  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:15.295  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=null (LanClient: not connected)
                      2026-05-19 16:00:45.249  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
                      2026-05-19 16:00:45.250  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
                      2026-05-19 16:00:45.250  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
                      2026-05-19 16:00:45.250  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:45.254  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:45.255  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:45.553  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getStatus (LanClient: authenticate ERROR)
                      2026-05-19 16:00:45.553  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:45.553  - debug: midea.0 (80756) refreshStatus(145135534971917) failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:45.553  - debug: midea.0 (80756) AC[145135534971917]: refreshPowerUsage() -> sending C1 query
                      2026-05-19 16:00:45.553  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) cmdHex=aa11ac00000000000303412101440001098c
                      2026-05-19 16:00:45.554  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getPowerUsage queue=0
                      2026-05-19 16:00:45.554  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:45.555  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:45.555  - debug: midea.0 (80756) AC[145135534971917]: refreshOperatingTime() -> sending C1/40 query
                      2026-05-19 16:00:45.555  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) cmdHex=aa11ac000000000003034121014000019702
                      2026-05-19 16:00:45.555  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getOperatingTime queue=0
                      2026-05-19 16:00:45.555  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:45.560  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:45.560  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:45.561  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:45.561  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:46.052  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getOperatingTime (LanClient: authenticate ERROR)
                      2026-05-19 16:00:46.053  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:46.053  - debug: midea.0 (80756) AC[145135534971917]: refreshHumidity() -> sending C1/45 query
                      2026-05-19 16:00:46.053  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) cmdHex=aa11ac00000000000303412101450001a2f2
                      2026-05-19 16:00:46.053  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getHumidity queue=0
                      2026-05-19 16:00:46.053  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:46.054  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) failed: LanClient: socket closed mid-request
                      2026-05-19 16:00:46.054  - debug: midea.0 (80756) AC[145135534971917]: refreshNewProtocol() -> sending B1 query
                      2026-05-19 16:00:46.054  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a000900031645
                      2026-05-19 16:00:46.054  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getNewProtocol queue=0
                      2026-05-19 16:00:46.054  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:00:46.057  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:46.057  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:46.058  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:00:46.058  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:00:46.546  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getNewProtocol (LanClient: authenticate ERROR)
                      2026-05-19 16:00:46.546  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) failed: LanClient: authenticate ERROR
                      2026-05-19 16:00:46.549  - warn: midea.0 (80756) State "midea.0.145135534971917.status.online" has no existing object, this might lead to an error in future versions
                      2026-05-19 16:01:16.551  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
                      2026-05-19 16:01:16.551  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
                      2026-05-19 16:01:16.551  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
                      2026-05-19 16:01:16.551  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:16.552  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:16.552  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:16.832  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getStatus (LanClient: authenticate ERROR)
                      2026-05-19 16:01:16.833  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) failed: LanClient: authenticate ERROR
                      2026-05-19 16:01:16.833  - debug: midea.0 (80756) refreshStatus(145135534971917) failed: LanClient: authenticate ERROR
                      2026-05-19 16:01:16.833  - debug: midea.0 (80756) AC[145135534971917]: refreshPowerUsage() -> sending C1 query
                      2026-05-19 16:01:16.833  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) cmdHex=aa11ac00000000000303412101440001098c
                      2026-05-19 16:01:16.834  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getPowerUsage queue=0
                      2026-05-19 16:01:16.834  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:16.836  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) failed: LanClient: socket closed mid-request
                      2026-05-19 16:01:16.836  - debug: midea.0 (80756) AC[145135534971917]: refreshOperatingTime() -> sending C1/40 query
                      2026-05-19 16:01:16.836  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) cmdHex=aa11ac000000000003034121014000019702
                      2026-05-19 16:01:16.836  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getOperatingTime queue=0
                      2026-05-19 16:01:16.836  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:16.837  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:16.837  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:16.875  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:16.875  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:17.326  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getOperatingTime (LanClient: authenticate ERROR)
                      2026-05-19 16:01:17.326  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) failed: LanClient: authenticate ERROR
                      2026-05-19 16:01:17.327  - debug: midea.0 (80756) AC[145135534971917]: refreshHumidity() -> sending C1/45 query
                      2026-05-19 16:01:17.327  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) cmdHex=aa11ac00000000000303412101450001a2f2
                      2026-05-19 16:01:17.327  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getHumidity queue=0
                      2026-05-19 16:01:17.327  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:17.327  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) failed: LanClient: socket closed mid-request
                      2026-05-19 16:01:17.328  - debug: midea.0 (80756) AC[145135534971917]: refreshNewProtocol() -> sending B1 query
                      2026-05-19 16:01:17.328  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a0009000495c5
                      2026-05-19 16:01:17.328  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getNewProtocol queue=0
                      2026-05-19 16:01:17.328  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:17.370  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:17.370  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:17.371  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:17.371  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:20.876  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getNewProtocol (LanClient: timeout waiting for authenticate — TCP/6444 is being blocked, or another LAN client (the phone app) is currently connected. Only one TCP control session is allowed at a time.)
                      2026-05-19 16:01:20.876  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) failed: LanClient: timeout waiting for authenticate — TCP/6444 is being blocked, or another LAN client (the phone app) is currently connected. Only one TCP control session is allowed at a time.
                      2026-05-19 16:01:20.879  - warn: midea.0 (80756) State "midea.0.145135534971917.status.online" has no existing object, this might lead to an error in future versions
                      2026-05-19 16:01:36.146  - warn: midea.0 (80756) LanClient[145135534971917]: socket error read ETIMEDOUT
                      2026-05-19 16:01:36.658  - warn: midea.0 (80756) LanClient[145135534971917]: socket error read ETIMEDOUT
                      2026-05-19 16:01:37.170  - warn: midea.0 (80756) LanClient[145135534971917]: socket error read ETIMEDOUT
                      2026-05-19 16:01:37.683  - warn: midea.0 (80756) LanClient[145135534971917]: socket error read ETIMEDOUT
                      2026-05-19 16:01:50.881  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
                      2026-05-19 16:01:50.881  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
                      2026-05-19 16:01:50.881  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
                      2026-05-19 16:01:50.881  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:50.898  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:50.898  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:51.379  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getStatus (LanClient: authenticate ERROR)
                      2026-05-19 16:01:51.379  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) failed: LanClient: authenticate ERROR
                      2026-05-19 16:01:51.379  - debug: midea.0 (80756) refreshStatus(145135534971917) failed: LanClient: authenticate ERROR
                      2026-05-19 16:01:51.379  - debug: midea.0 (80756) AC[145135534971917]: refreshPowerUsage() -> sending C1 query
                      2026-05-19 16:01:51.379  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) cmdHex=aa11ac00000000000303412101440001098c
                      2026-05-19 16:01:51.379  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getPowerUsage queue=0
                      2026-05-19 16:01:51.379  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:51.380  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) failed: LanClient: socket closed mid-request
                      2026-05-19 16:01:51.380  - debug: midea.0 (80756) AC[145135534971917]: refreshOperatingTime() -> sending C1/40 query
                      2026-05-19 16:01:51.380  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) cmdHex=aa11ac000000000003034121014000019702
                      2026-05-19 16:01:51.380  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getOperatingTime queue=0
                      2026-05-19 16:01:51.380  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:51.385  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:51.385  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:51.386  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:51.877  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getOperatingTime (LanClient: authenticate ERROR)
                      2026-05-19 16:01:51.877  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) failed: LanClient: authenticate ERROR
                      2026-05-19 16:01:51.877  - debug: midea.0 (80756) AC[145135534971917]: refreshHumidity() -> sending C1/45 query
                      2026-05-19 16:01:51.877  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) cmdHex=aa11ac00000000000303412101450001a2f2
                      2026-05-19 16:01:51.878  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getHumidity queue=0
                      2026-05-19 16:01:51.878  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:01:51.878  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) failed: LanClient: socket closed mid-request
                      2026-05-19 16:01:51.878  - debug: midea.0 (80756) AC[145135534971917]: refreshNewProtocol() -> sending B1 query
                      2026-05-19 16:01:51.878  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a00090005cb8e
                      2026-05-19 16:01:51.878  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getNewProtocol queue=0
                      2026-05-19 16:01:51.881  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:51.881  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:51.882  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:01:51.882  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      2026-05-19 16:01:52.369  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getNewProtocol (LanClient: authenticate ERROR)
                      2026-05-19 16:01:52.369  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) failed: LanClient: authenticate ERROR
                      2026-05-19 16:01:52.371  - warn: midea.0 (80756) State "midea.0.145135534971917.status.online" has no existing object, this might lead to an error in future versions
                      2026-05-19 16:02:22.374  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
                      2026-05-19 16:02:22.374  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
                      2026-05-19 16:02:22.374  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
                      2026-05-19 16:02:22.374  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
                      2026-05-19 16:02:22.390  - debug: midea.0 (80756) LanClient[145135534971917]: connected
                      2026-05-19 16:02:22.391  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
                      Schalten geht jedenfalls nicht:
                      2026-05-19 16:10:43.990  - warn: midea.0 (80756) Control powerOn written for unknown/unregistered device 144036023343615
                        tombox
                        #391
                        @BananaJoe 1.6.1 testen und kompletten debug log via mail schicken
                        • MichaelFM Offline
                          MichaelFM Offline
                          MichaelF
                          #392
                          Hi, ich habe auch grade getestet. Habe diese Fehlermeldung:
                          midea.0
                          2026-05-19 18:06:20.315	warn	Control powerOn ignored: device 152832116580279 (Entfeuchter) is in your cloud account but currently unreachable on the LAN — it did not respond to LAN discovery (different broadcast domain or UDP/6445 firewalled). ioBroker is broadcasting to [192.168.178.255] on UDP/6445 — make sure one of these covers the appliance's subnet. Power-cycle the appliance or fix the network path, then restart the adapter.
                          midea.0
                          2026-05-19 18:05:49.514	info	Discovery summary: cloud=1, lan=0, both=0, registered=0 cloud-only=[152832116580279]
                          midea.0
                          2026-05-19 18:05:49.513	warn	Appliance 152832116580279 (Entfeuchter) is bound to the cloud account but did not respond to LAN discovery — control requires a local broadcast domain, or UDP/6445 is firewalled.
                          midea.0
                          2026-05-19 18:05:49.512	warn	LAN discovery found 0 appliance(s) — your ioBroker host is not on the same broadcast domain as the appliance, or UDP 6445 is firewalled. Across VLANs you need a UDP broadcast relay (e.g. udpbroadcastrelay).
                          midea.0
                          2026-05-19 18:05:43.946	info	starting. Version 1.6.1 (non-npm: TA2k/ioBroker.midea#dc19875b9866be0253afd3645992189636d8913f) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
                          midea.0
                          2026-05-19 18:05:37.037	info	terminating
                          midea.0
                          2026-05-19 18:05:36.534	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          midea.0
                          2026-05-19 18:05:36.533	info	terminating
                          midea.0
                          2026-05-19 18:05:36.530	info	Got terminate signal TERMINATE_YOURSELF
                          • T tombox
                            BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            #393
                            @tombox Mail ist raus.
                            Ich steuere die Anlage ja schon länger per midea-beautiful-air-cli, die hat sich damals einfach lokal einen eigenen Key geholt/generiert den ich seit dem Benutze.
                            Mein System ist auch kein Container sondern eine native Ubuntu VM die direkt mit dem Netzwerk sprechen darf / dort seine eigene IP hat, es gibt keine VLANs oder Subnetze.
                            Die anderen Tokens hatte ich mir seinerzeit mal per msmart-ng geholt
                              tombox
                              #394
                              @BananaJoe habe noch keine erhalte aber probiere mal 1.7 dort kann man manuell die ip eintragen
                              BananaJoeB 2 Antworten Letzte Antwort
                              • MichaelFM Offline
                                MichaelFM Offline
                                MichaelF
                                #395
                                Ich habe nun das:
                                midea.0
                                2026-05-19 21:22:46.283	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:22:41.130	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:22:35.989	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:22:30.626	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:22:25.402	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:22:24.464	error	setStatus(152832116580279, powerOn=true) failed: LanClient: authenticate ERROR
                                midea.0
                                2026-05-19 21:22:20.175	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:22:14.953	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:22:09.827	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:22:04.609	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                midea.0
                                2026-05-19 21:21:59.441	info	Discovery summary: cloud=1, lan=1, both=1, registered=1
                                midea.0
                                2026-05-19 21:21:59.178	warn	refreshStatus for 152832116580279 failed: LanClient: authenticate ERROR
                                midea.0
                                2026-05-19 21:21:59.069	warn	refreshCapabilities for 152832116580279 failed: LanClient: authenticate ERROR
                                midea.0
                                2026-05-19 21:21:58.447	info	LAN discovery found 1 appliance(s)
                                midea.0
                                2026-05-19 21:21:53.439	info	LAN discovery: also unicast-probing configured device IPs [192.168.178.51]
                                midea.0
                                2026-05-19 21:21:53.436	info	Cloud listing: 1 appliance(s)
                                midea.0
                                2026-05-19 21:21:53.111	info	starting. Version 1.6.2 (non-npm: TA2k/ioBroker.midea#ec069dcd8be8e95e44b0099b4ea9678c93fa5755) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
                                midea.0
                                2026-05-19 21:21:45.853	info	terminating
                                midea.0
                                2026-05-19 21:21:45.351	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                midea.0
                                2026-05-19 21:21:45.349	info	terminating
                                midea.0
                                2026-05-19 21:21:45.345	info	Got terminate signal TERMINATE_YOURSELF
                                • T tombox
                                  BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  #396
                                  @tombox tja, ich hatte die Email geschrieben, aber Outlook nicht gestartet, habe ich gerade nachgeholt und jetzt ist auch versendet
                                  • T tombox
                                    BananaJoeB Offline
                                    BananaJoeB Offline
                                    BananaJoe
                                    #397
                                    @tombox über von GitHub / Katze installiert er die 1.6.2?
                                    Da kann ich unten die Geräte hinzufügen, aber nichts in die Felder tippen.
                                    In meinem Skript was ich bisher nutze braucht es zur Steuerung folgendes
                                    • IP
                                    • ID
                                    • Key
                                    • Token
                                    Wenn müsste man das alles angeben Können (und gerne ein Feld für den Namen)
                                    Log der 1.6.2 habe ich dir gerade gesendet
                                    Edit: die midea-beautiful-air-cli braucht keine ID! Nur IP, Key und Token!
                                    • MichaelFM MichaelF
                                      Ich habe nun das:
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      midea.0
                                      tombox
                                      #398
                                      @MichaelF bitte mal 1.6.3 testen
                                      MichaelFM 1 Antwort Letzte Antwort
                                      • T tombox
                                        MichaelFM Offline
                                        MichaelFM Offline
                                        MichaelF
                                        schrieb am zuletzt editiert von MichaelF
                                        #399
                                        @tombox
                                        Adapter verbindet, aber gleicher Fehler und keine Aktualisierung der Datenpunkte:
                                        midea.0
                                        2026-05-19 22:46:02.202	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:57.066	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:51.938	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:46.820	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:41.701	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:36.577	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:31.461	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:26.344	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:21.192	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:14.060	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:09.793	error	setStatus(152832116580279, powerOn=false) failed: LanClient: authenticate ERROR
                                        midea.0
                                        2026-05-19 22:45:08.931	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:45:03.714	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:44:58.499	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:44:53.369	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:44:47.965	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:44:42.722	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                                        midea.0
                                        2026-05-19 22:44:37.600	info	Discovery summary: cloud=1, lan=1, both=1, registered=1
                                        midea.0
                                        2026-05-19 22:44:37.590	warn	refreshStatus for 152832116580279 failed: LanClient: authenticate ERROR
                                        midea.0
                                        2026-05-19 22:44:37.385	warn	refreshCapabilities for 152832116580279 failed: LanClient: authenticate ERROR
                                        midea.0
                                        2026-05-19 22:44:36.991	info	LAN discovery found 1 appliance(s)
                                        midea.0
                                        2026-05-19 22:44:31.978	info	LAN discovery: also unicast-probing configured device IPs [192.168.178.51]
                                        midea.0
                                        2026-05-19 22:44:31.975	info	Cloud listing: 1 appliance(s)
                                        midea.0
                                        2026-05-19 22:44:31.648	info	starting. Version 1.6.3 (non-npm: TA2k/ioBroker.midea#c47b737db9a7805087c0829c27448555d4666d1d) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
                                        midea.0
                                        2026-05-19 22:44:24.834	info	terminating
                                        midea.0
                                        2026-05-19 22:44:24.331	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        midea.0
                                        2026-05-19 22:44:24.330	info	terminating
                                        midea.0
                                        2026-05-19 22:44:24.329	info	cleaned everything up...
                                        midea.0
                                        2026-05-19 22:44:24.327	info	Got terminate signal TERMINATE_YOURSELF
                                          @tombox
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          midea.0
                                          tombox
                                          #400
                                          @MichaelF 1.6.4 testen auch gerne log per mail tombox2020@gmail.com
