  4. Test Adapter Midea Geräten v1.x.x
    6.3k
mideadimstalnethomenethome plus
434 Beiträge 68 Kommentatoren 124.5k Aufrufe 67 Beobachtet
  • T tombox
    @BananaJoe wie hat der login dann geklappt?
    bitte v1.4.0 testen
    BananaJoeB Offline
    BananaJoeB Offline
    BananaJoe
    #390
    @tombox Ok, nachdem ich Entdeckt hatte, das man nun in den Einstellungen die App auswählen kann, klappt es, hier ein Auszug dem dem Debug-Log:
    2026-05-19 16:00:03.458  - debug: midea.0 (79590) AC[144036023343615]: refreshNewProtocol() -> sending B1 query
    2026-05-19 16:00:03.458  - debug: midea.0 (79590) Device[144036023343615]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a0009000a8aca
    2026-05-19 16:00:03.458  - debug: midea.0 (79590) LanClient[144036023343615]: pump label=getNewProtocol queue=0
    2026-05-19 16:00:03.458  - debug: midea.0 (79590) LanClient[144036023343615]: connecting to 192.168.1.29:6444 (protocol=3)
    2026-05-19 16:00:03.458  - debug: midea.0 (79590) Device[144036023343615]: _request(getNewProtocol) failed: LanClient: socket closed mid-request
    2026-05-19 16:00:03.471  - warn: midea.0 (79590) State "midea.0.144036023343615.status.online" has no existing object, this might lead to an error in future versions
    2026-05-19 16:00:03.895  - debug: midea.0 (79590) LanClient[144036023343615]: connected
    2026-05-19 16:00:03.896  - debug: midea.0 (79590) LanClient[144036023343615]: handshake start tokenLen=64
    2026-05-19 16:00:03.896  - debug: midea.0 (79590) LanClient[144036023343615]: pump error label=null (LanClient: not connected)
    2026-05-19 16:00:05.010  - error: midea.0 (79590) uncaught exception: connect ETIMEDOUT 192.168.1.29:6444
    2026-05-19 16:00:05.010  - error: midea.0 (79590) Error: connect ETIMEDOUT 192.168.1.29:6444
    2026-05-19 16:00:05.010  - error: midea.0 (79590) Exception-Code: ETIMEDOUT: connect ETIMEDOUT 192.168.1.29:6444
    2026-05-19 16:00:05.012  - info: midea.0 (79590) terminating
    2026-05-19 16:00:05.012  - warn: midea.0 (79590) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2026-05-19 16:00:05.513  - info: midea.0 (79590) terminating
    2026-05-19 16:00:05.710  - error: host.iobroker instance system.adapter.midea.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2026-05-19 16:00:05.710  - info: host.iobroker Restart adapter system.adapter.midea.0 because enabled
    2026-05-19 16:00:07.154  - info: host.iobroker instance system.adapter.midea.0 in version "1.6.0" (non-npm: TA2k/ioBroker.midea) started with pid 80756
    2026-05-19 16:00:07.645  - debug: midea.0 (80756) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2026-05-19 16:00:07.697  - debug: midea.0 (80756) Objects client ready ... initialize now
    2026-05-19 16:00:07.698  - debug: midea.0 (80756) Objects create System PubSub Client
    2026-05-19 16:00:07.698  - debug: midea.0 (80756) Objects create User PubSub Client
    2026-05-19 16:00:07.858  - debug: midea.0 (80756) Objects client initialize lua scripts
    2026-05-19 16:00:07.861  - debug: midea.0 (80756) Objects connected to redis: 0.0.0.0:9001
    2026-05-19 16:00:07.944  - debug: midea.0 (80756) Redis States: Use Redis connection: 127.0.0.1:6379
    2026-05-19 16:00:07.946  - debug: midea.0 (80756) States create System PubSub Client
    2026-05-19 16:00:07.947  - debug: midea.0 (80756) States create User PubSub Client
    2026-05-19 16:00:07.949  - debug: midea.0 (80756) States connected to redis: 127.0.0.1:6379
    2026-05-19 16:00:08.218  - info: midea.0 (80756) starting. Version 1.6.0 (non-npm: TA2k/ioBroker.midea) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.1.2
    2026-05-19 16:00:08.240  - debug: midea.0 (80756) Schedule restart: 1 4,13 * * *
    2026-05-19 16:00:08.271  - debug: midea.0 (80756) Midea adapter starting up, poll interval=30 s
    2026-05-19 16:00:08.273  - debug: midea.0 (80756) CloudClientV1: POST /v1/user/login/id/get hasToken=false
    2026-05-19 16:00:08.381  - debug: midea.0 (80756) CloudClientV1: POST /v1/user/login hasToken=false
    2026-05-19 16:00:08.434  - debug: midea.0 (80756) CloudClientV1: authenticated (app=nethome)
    2026-05-19 16:00:08.434  - debug: midea.0 (80756) CloudClientV1: listAppliances()
    2026-05-19 16:00:08.434  - debug: midea.0 (80756) CloudClientV1: POST /v1/appliance/user/list/get hasToken=true
    2026-05-19 16:00:08.497  - debug: midea.0 (80756) discover: starting UDP broadcast targets=[192.168.3.255] ports=[6445,20086] timeoutMs=5000
    2026-05-19 16:00:08.601  - debug: midea.0 (80756) discover: 192.168.1.30 -> id=145135534971917 type=0xac (ac) protocol=3
    2026-05-19 16:00:13.499  - debug: midea.0 (80756) discover: finished, 1 appliance(s)
    2026-05-19 16:00:13.499  - info: midea.0 (80756) LAN discovery found 1 appliance(s)
    2026-05-19 16:00:13.644  - debug: midea.0 (80756) CloudClientV1: getToken(udpId=a6c623fa83691f32c2e4b6e613451dde)
    2026-05-19 16:00:13.645  - debug: midea.0 (80756) CloudClientV1: POST /v1/iot/secure/getToken hasToken=true
    2026-05-19 16:00:13.722  - debug: midea.0 (80756) Device 145135534971917: token/key fetched (token=98C93C8F…)
    2026-05-19 16:00:13.725  - debug: midea.0 (80756) AC[145135534971917]: refreshCapabilities() -> sending B5 query
    2026-05-19 16:00:13.726  - debug: midea.0 (80756) Device[145135534971917]: _request(getCapabilities) cmdHex=aa0eac00000000000303b501118eeb
    2026-05-19 16:00:13.726  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getCapabilities queue=0
    2026-05-19 16:00:13.730  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:13.822  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:13.823  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:14.230  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getCapabilities (LanClient: authenticate ERROR)
    2026-05-19 16:00:14.231  - debug: midea.0 (80756) Device[145135534971917]: _request(getCapabilities) failed: LanClient: authenticate ERROR
    2026-05-19 16:00:14.232  - warn: midea.0 (80756) refreshCapabilities for 145135534971917 failed: LanClient: authenticate ERROR
    2026-05-19 16:00:14.232  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
    2026-05-19 16:00:14.232  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
    2026-05-19 16:00:14.232  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
    2026-05-19 16:00:14.232  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:14.234  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) failed: LanClient: socket closed mid-request
    2026-05-19 16:00:14.234  - warn: midea.0 (80756) refreshStatus for 145135534971917 failed: LanClient: socket closed mid-request
    2026-05-19 16:00:14.235  - debug: midea.0 (80756) AC[145135534971917]: refreshPowerUsage() -> sending C1 query
    2026-05-19 16:00:14.235  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) cmdHex=aa11ac00000000000303412101440001098c
    2026-05-19 16:00:14.235  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getPowerUsage queue=0
    2026-05-19 16:00:14.235  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:14.235  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:14.237  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:14.240  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:14.240  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:14.725  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getPowerUsage (LanClient: authenticate ERROR)
    2026-05-19 16:00:14.725  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) failed: LanClient: authenticate ERROR
    2026-05-19 16:00:14.725  - debug: midea.0 (80756) refreshPowerUsage for 145135534971917 failed (not all units support it): LanClient: authenticate ERROR
    2026-05-19 16:00:14.726  - debug: midea.0 (80756) AC[145135534971917]: refreshOperatingTime() -> sending C1/40 query
    2026-05-19 16:00:14.726  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) cmdHex=aa11ac000000000003034121014000019702
    2026-05-19 16:00:14.726  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getOperatingTime queue=0
    2026-05-19 16:00:14.726  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:14.726  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) failed: LanClient: socket closed mid-request
    2026-05-19 16:00:14.726  - debug: midea.0 (80756) refreshOperatingTime for 145135534971917 failed: LanClient: socket closed mid-request
    2026-05-19 16:00:14.727  - debug: midea.0 (80756) AC[145135534971917]: refreshHumidity() -> sending C1/45 query
    2026-05-19 16:00:14.727  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) cmdHex=aa11ac00000000000303412101450001a2f2
    2026-05-19 16:00:14.727  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getHumidity queue=0
    2026-05-19 16:00:14.727  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:14.787  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:14.787  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:14.788  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:14.788  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:15.240  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getHumidity (LanClient: authenticate ERROR)
    2026-05-19 16:00:15.240  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) failed: LanClient: authenticate ERROR
    2026-05-19 16:00:15.240  - debug: midea.0 (80756) refreshHumidity for 145135534971917 failed: LanClient: authenticate ERROR
    2026-05-19 16:00:15.241  - debug: midea.0 (80756) AC[145135534971917]: refreshNewProtocol() -> sending B1 query
    2026-05-19 16:00:15.241  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a000900024814
    2026-05-19 16:00:15.241  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getNewProtocol queue=0
    2026-05-19 16:00:15.241  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:15.242  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) failed: LanClient: socket closed mid-request
    2026-05-19 16:00:15.242  - debug: midea.0 (80756) refreshNewProtocol for 145135534971917 failed: LanClient: socket closed mid-request
    2026-05-19 16:00:15.244  - warn: midea.0 (80756) Appliance 144036023343615 (Wohnzimmer) is bound to the cloud account but did not respond to LAN discovery — control requires a local broadcast domain, or UDP/6445 is firewalled.
    2026-05-19 16:00:15.294  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:15.294  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:15.295  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=null (LanClient: not connected)
    2026-05-19 16:00:45.249  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
    2026-05-19 16:00:45.250  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
    2026-05-19 16:00:45.250  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
    2026-05-19 16:00:45.250  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:45.254  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:45.255  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:45.553  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getStatus (LanClient: authenticate ERROR)
    2026-05-19 16:00:45.553  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) failed: LanClient: authenticate ERROR
    2026-05-19 16:00:45.553  - debug: midea.0 (80756) refreshStatus(145135534971917) failed: LanClient: authenticate ERROR
    2026-05-19 16:00:45.553  - debug: midea.0 (80756) AC[145135534971917]: refreshPowerUsage() -> sending C1 query
    2026-05-19 16:00:45.553  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) cmdHex=aa11ac00000000000303412101440001098c
    2026-05-19 16:00:45.554  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getPowerUsage queue=0
    2026-05-19 16:00:45.554  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:45.555  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) failed: LanClient: socket closed mid-request
    2026-05-19 16:00:45.555  - debug: midea.0 (80756) AC[145135534971917]: refreshOperatingTime() -> sending C1/40 query
    2026-05-19 16:00:45.555  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) cmdHex=aa11ac000000000003034121014000019702
    2026-05-19 16:00:45.555  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getOperatingTime queue=0
    2026-05-19 16:00:45.555  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:45.560  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:45.560  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:45.561  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:45.561  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:46.052  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getOperatingTime (LanClient: authenticate ERROR)
    2026-05-19 16:00:46.053  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) failed: LanClient: authenticate ERROR
    2026-05-19 16:00:46.053  - debug: midea.0 (80756) AC[145135534971917]: refreshHumidity() -> sending C1/45 query
    2026-05-19 16:00:46.053  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) cmdHex=aa11ac00000000000303412101450001a2f2
    2026-05-19 16:00:46.053  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getHumidity queue=0
    2026-05-19 16:00:46.053  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:46.054  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) failed: LanClient: socket closed mid-request
    2026-05-19 16:00:46.054  - debug: midea.0 (80756) AC[145135534971917]: refreshNewProtocol() -> sending B1 query
    2026-05-19 16:00:46.054  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a000900031645
    2026-05-19 16:00:46.054  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getNewProtocol queue=0
    2026-05-19 16:00:46.054  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:00:46.057  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:46.057  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:46.058  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:00:46.058  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:00:46.546  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getNewProtocol (LanClient: authenticate ERROR)
    2026-05-19 16:00:46.546  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) failed: LanClient: authenticate ERROR
    2026-05-19 16:00:46.549  - warn: midea.0 (80756) State "midea.0.145135534971917.status.online" has no existing object, this might lead to an error in future versions
    2026-05-19 16:01:16.551  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
    2026-05-19 16:01:16.551  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
    2026-05-19 16:01:16.551  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
    2026-05-19 16:01:16.551  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:16.552  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:16.552  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:16.832  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getStatus (LanClient: authenticate ERROR)
    2026-05-19 16:01:16.833  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) failed: LanClient: authenticate ERROR
    2026-05-19 16:01:16.833  - debug: midea.0 (80756) refreshStatus(145135534971917) failed: LanClient: authenticate ERROR
    2026-05-19 16:01:16.833  - debug: midea.0 (80756) AC[145135534971917]: refreshPowerUsage() -> sending C1 query
    2026-05-19 16:01:16.833  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) cmdHex=aa11ac00000000000303412101440001098c
    2026-05-19 16:01:16.834  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getPowerUsage queue=0
    2026-05-19 16:01:16.834  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:16.836  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) failed: LanClient: socket closed mid-request
    2026-05-19 16:01:16.836  - debug: midea.0 (80756) AC[145135534971917]: refreshOperatingTime() -> sending C1/40 query
    2026-05-19 16:01:16.836  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) cmdHex=aa11ac000000000003034121014000019702
    2026-05-19 16:01:16.836  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getOperatingTime queue=0
    2026-05-19 16:01:16.836  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:16.837  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:16.837  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:16.875  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:16.875  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:17.326  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getOperatingTime (LanClient: authenticate ERROR)
    2026-05-19 16:01:17.326  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) failed: LanClient: authenticate ERROR
    2026-05-19 16:01:17.327  - debug: midea.0 (80756) AC[145135534971917]: refreshHumidity() -> sending C1/45 query
    2026-05-19 16:01:17.327  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) cmdHex=aa11ac00000000000303412101450001a2f2
    2026-05-19 16:01:17.327  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getHumidity queue=0
    2026-05-19 16:01:17.327  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:17.327  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) failed: LanClient: socket closed mid-request
    2026-05-19 16:01:17.328  - debug: midea.0 (80756) AC[145135534971917]: refreshNewProtocol() -> sending B1 query
    2026-05-19 16:01:17.328  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a0009000495c5
    2026-05-19 16:01:17.328  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getNewProtocol queue=0
    2026-05-19 16:01:17.328  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:17.370  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:17.370  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:17.371  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:17.371  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:20.876  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getNewProtocol (LanClient: timeout waiting for authenticate — TCP/6444 is being blocked, or another LAN client (the phone app) is currently connected. Only one TCP control session is allowed at a time.)
    2026-05-19 16:01:20.876  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) failed: LanClient: timeout waiting for authenticate — TCP/6444 is being blocked, or another LAN client (the phone app) is currently connected. Only one TCP control session is allowed at a time.
    2026-05-19 16:01:20.879  - warn: midea.0 (80756) State "midea.0.145135534971917.status.online" has no existing object, this might lead to an error in future versions
    2026-05-19 16:01:36.146  - warn: midea.0 (80756) LanClient[145135534971917]: socket error read ETIMEDOUT
    2026-05-19 16:01:36.658  - warn: midea.0 (80756) LanClient[145135534971917]: socket error read ETIMEDOUT
    2026-05-19 16:01:37.170  - warn: midea.0 (80756) LanClient[145135534971917]: socket error read ETIMEDOUT
    2026-05-19 16:01:37.683  - warn: midea.0 (80756) LanClient[145135534971917]: socket error read ETIMEDOUT
    2026-05-19 16:01:50.881  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
    2026-05-19 16:01:50.881  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
    2026-05-19 16:01:50.881  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
    2026-05-19 16:01:50.881  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:50.898  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:50.898  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:51.379  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getStatus (LanClient: authenticate ERROR)
    2026-05-19 16:01:51.379  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) failed: LanClient: authenticate ERROR
    2026-05-19 16:01:51.379  - debug: midea.0 (80756) refreshStatus(145135534971917) failed: LanClient: authenticate ERROR
    2026-05-19 16:01:51.379  - debug: midea.0 (80756) AC[145135534971917]: refreshPowerUsage() -> sending C1 query
    2026-05-19 16:01:51.379  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) cmdHex=aa11ac00000000000303412101440001098c
    2026-05-19 16:01:51.379  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getPowerUsage queue=0
    2026-05-19 16:01:51.379  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:51.380  - debug: midea.0 (80756) Device[145135534971917]: _request(getPowerUsage) failed: LanClient: socket closed mid-request
    2026-05-19 16:01:51.380  - debug: midea.0 (80756) AC[145135534971917]: refreshOperatingTime() -> sending C1/40 query
    2026-05-19 16:01:51.380  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) cmdHex=aa11ac000000000003034121014000019702
    2026-05-19 16:01:51.380  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getOperatingTime queue=0
    2026-05-19 16:01:51.380  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:51.385  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:51.385  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:51.386  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:51.877  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getOperatingTime (LanClient: authenticate ERROR)
    2026-05-19 16:01:51.877  - debug: midea.0 (80756) Device[145135534971917]: _request(getOperatingTime) failed: LanClient: authenticate ERROR
    2026-05-19 16:01:51.877  - debug: midea.0 (80756) AC[145135534971917]: refreshHumidity() -> sending C1/45 query
    2026-05-19 16:01:51.877  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) cmdHex=aa11ac00000000000303412101450001a2f2
    2026-05-19 16:01:51.878  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getHumidity queue=0
    2026-05-19 16:01:51.878  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:01:51.878  - debug: midea.0 (80756) Device[145135534971917]: _request(getHumidity) failed: LanClient: socket closed mid-request
    2026-05-19 16:01:51.878  - debug: midea.0 (80756) AC[145135534971917]: refreshNewProtocol() -> sending B1 query
    2026-05-19 16:01:51.878  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) cmdHex=aa1eac00000000000303b108420018001500170033024b000a00090005cb8e
    2026-05-19 16:01:51.878  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getNewProtocol queue=0
    2026-05-19 16:01:51.881  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:51.881  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:51.882  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:01:51.882  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    2026-05-19 16:01:52.369  - debug: midea.0 (80756) LanClient[145135534971917]: pump error label=getNewProtocol (LanClient: authenticate ERROR)
    2026-05-19 16:01:52.369  - debug: midea.0 (80756) Device[145135534971917]: _request(getNewProtocol) failed: LanClient: authenticate ERROR
    2026-05-19 16:01:52.371  - warn: midea.0 (80756) State "midea.0.145135534971917.status.online" has no existing object, this might lead to an error in future versions
    2026-05-19 16:02:22.374  - debug: midea.0 (80756) AC[145135534971917]: refreshStatus() -> sending C0 query
    2026-05-19 16:02:22.374  - debug: midea.0 (80756) Device[145135534971917]: _request(getStatus) cmdHex=aa20ac00000000000003418100ff03ff000200000000000000000000000003cd9c
    2026-05-19 16:02:22.374  - debug: midea.0 (80756) LanClient[145135534971917]: pump label=getStatus queue=0
    2026-05-19 16:02:22.374  - debug: midea.0 (80756) LanClient[145135534971917]: connecting to 192.168.1.30:6444 (protocol=3)
    2026-05-19 16:02:22.390  - debug: midea.0 (80756) LanClient[145135534971917]: connected
    2026-05-19 16:02:22.391  - debug: midea.0 (80756) LanClient[145135534971917]: handshake start tokenLen=64
    Schalten geht jedenfalls nicht:
    2026-05-19 16:10:43.990  - warn: midea.0 (80756) Control powerOn written for unknown/unregistered device 144036023343615
    • BananaJoeB BananaJoe
      tombox
      #391
      @BananaJoe 1.6.1 testen und kompletten debug log via mail schicken
      tombox2020@gmail.com
      • MichaelFM Offline
        MichaelFM Offline
        MichaelF
        #392
        Hi, ich habe auch grade getestet. Habe diese Fehlermeldung:
        midea.0
        2026-05-19 18:06:20.315	warn	Control powerOn ignored: device 152832116580279 (Entfeuchter) is in your cloud account but currently unreachable on the LAN — it did not respond to LAN discovery (different broadcast domain or UDP/6445 firewalled). ioBroker is broadcasting to [192.168.178.255] on UDP/6445 — make sure one of these covers the appliance's subnet. Power-cycle the appliance or fix the network path, then restart the adapter.
        midea.0
        2026-05-19 18:05:49.514	info	Discovery summary: cloud=1, lan=0, both=0, registered=0 cloud-only=[152832116580279]
        midea.0
        2026-05-19 18:05:49.513	warn	Appliance 152832116580279 (Entfeuchter) is bound to the cloud account but did not respond to LAN discovery — control requires a local broadcast domain, or UDP/6445 is firewalled.
        midea.0
        2026-05-19 18:05:49.512	warn	LAN discovery found 0 appliance(s) — your ioBroker host is not on the same broadcast domain as the appliance, or UDP 6445 is firewalled. Across VLANs you need a UDP broadcast relay (e.g. udpbroadcastrelay).
        midea.0
        2026-05-19 18:05:43.946	info	starting. Version 1.6.1 (non-npm: TA2k/ioBroker.midea#dc19875b9866be0253afd3645992189636d8913f) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
        midea.0
        2026-05-19 18:05:37.037	info	terminating
        midea.0
        2026-05-19 18:05:36.534	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        midea.0
        2026-05-19 18:05:36.533	info	terminating
        midea.0
        2026-05-19 18:05:36.530	info	Got terminate signal TERMINATE_YOURSELF
        • T tombox
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          #393
          @tombox Mail ist raus.
          Ich steuere die Anlage ja schon länger per midea-beautiful-air-cli, die hat sich damals einfach lokal einen eigenen Key geholt/generiert den ich seit dem Benutze.
          Mein System ist auch kein Container sondern eine native Ubuntu VM die direkt mit dem Netzwerk sprechen darf / dort seine eigene IP hat, es gibt keine VLANs oder Subnetze.
          Die anderen Tokens hatte ich mir seinerzeit mal per msmart-ng geholt
            tombox
            #394
            @BananaJoe habe noch keine erhalte aber probiere mal 1.7 dort kann man manuell die ip eintragen
            BananaJoeB 2 Antworten Letzte Antwort
            • MichaelFM Offline
              MichaelFM Offline
              MichaelF
              #395
              Ich habe nun das:
              midea.0
              2026-05-19 21:22:46.283	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:22:41.130	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:22:35.989	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:22:30.626	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:22:25.402	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:22:24.464	error	setStatus(152832116580279, powerOn=true) failed: LanClient: authenticate ERROR
              midea.0
              2026-05-19 21:22:20.175	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:22:14.953	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:22:09.827	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:22:04.609	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
              midea.0
              2026-05-19 21:21:59.441	info	Discovery summary: cloud=1, lan=1, both=1, registered=1
              midea.0
              2026-05-19 21:21:59.178	warn	refreshStatus for 152832116580279 failed: LanClient: authenticate ERROR
              midea.0
              2026-05-19 21:21:59.069	warn	refreshCapabilities for 152832116580279 failed: LanClient: authenticate ERROR
              midea.0
              2026-05-19 21:21:58.447	info	LAN discovery found 1 appliance(s)
              midea.0
              2026-05-19 21:21:53.439	info	LAN discovery: also unicast-probing configured device IPs [192.168.178.51]
              midea.0
              2026-05-19 21:21:53.436	info	Cloud listing: 1 appliance(s)
              midea.0
              2026-05-19 21:21:53.111	info	starting. Version 1.6.2 (non-npm: TA2k/ioBroker.midea#ec069dcd8be8e95e44b0099b4ea9678c93fa5755) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
              midea.0
              2026-05-19 21:21:45.853	info	terminating
              midea.0
              2026-05-19 21:21:45.351	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              midea.0
              2026-05-19 21:21:45.349	info	terminating
              midea.0
              2026-05-19 21:21:45.345	info	Got terminate signal TERMINATE_YOURSELF
              • T tombox
                BananaJoeB Offline
                BananaJoeB Offline
                BananaJoe
                #396
                @tombox tja, ich hatte die Email geschrieben, aber Outlook nicht gestartet, habe ich gerade nachgeholt und jetzt ist auch versendet
                • T tombox
                  BananaJoeB Offline
                  BananaJoeB Offline
                  BananaJoe
                  #397
                  @tombox über von GitHub / Katze installiert er die 1.6.2?
                  Da kann ich unten die Geräte hinzufügen, aber nichts in die Felder tippen.
                  In meinem Skript was ich bisher nutze braucht es zur Steuerung folgendes
                  • IP
                  • ID
                  • Key
                  • Token
                  Wenn müsste man das alles angeben Können (und gerne ein Feld für den Namen)
                  Log der 1.6.2 habe ich dir gerade gesendet
                  Edit: die midea-beautiful-air-cli braucht keine ID! Nur IP, Key und Token!
                  • MichaelFM MichaelF
                    Ich habe nun das:
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    midea.0
                    tombox
                    #398
                    @MichaelF bitte mal 1.6.3 testen
                    MichaelFM 1 Antwort Letzte Antwort
                    • T tombox
                      MichaelFM Offline
                      MichaelFM Offline
                      MichaelF
                      schrieb am zuletzt editiert von MichaelF
                      #399
                      @tombox
                      Adapter verbindet, aber gleicher Fehler und keine Aktualisierung der Datenpunkte:
                      midea.0
                      2026-05-19 22:46:02.202	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:57.066	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:51.938	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:46.820	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:41.701	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:36.577	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:31.461	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:26.344	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:21.192	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:14.060	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:09.793	error	setStatus(152832116580279, powerOn=false) failed: LanClient: authenticate ERROR
                      midea.0
                      2026-05-19 22:45:08.931	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:45:03.714	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:44:58.499	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:44:53.369	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:44:47.965	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:44:42.722	warn	State "midea.0.152832116580279.status.online" has no existing object, this might lead to an error in future versions
                      midea.0
                      2026-05-19 22:44:37.600	info	Discovery summary: cloud=1, lan=1, both=1, registered=1
                      midea.0
                      2026-05-19 22:44:37.590	warn	refreshStatus for 152832116580279 failed: LanClient: authenticate ERROR
                      midea.0
                      2026-05-19 22:44:37.385	warn	refreshCapabilities for 152832116580279 failed: LanClient: authenticate ERROR
                      midea.0
                      2026-05-19 22:44:36.991	info	LAN discovery found 1 appliance(s)
                      midea.0
                      2026-05-19 22:44:31.978	info	LAN discovery: also unicast-probing configured device IPs [192.168.178.51]
                      midea.0
                      2026-05-19 22:44:31.975	info	Cloud listing: 1 appliance(s)
                      midea.0
                      2026-05-19 22:44:31.648	info	starting. Version 1.6.3 (non-npm: TA2k/ioBroker.midea#c47b737db9a7805087c0829c27448555d4666d1d) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
                      midea.0
                      2026-05-19 22:44:24.834	info	terminating
                      midea.0
                      2026-05-19 22:44:24.331	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      midea.0
                      2026-05-19 22:44:24.330	info	terminating
                      midea.0
                      2026-05-19 22:44:24.329	info	cleaned everything up...
                      midea.0
                      2026-05-19 22:44:24.327	info	Got terminate signal TERMINATE_YOURSELF
                        @tombox
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        midea.0
                        tombox
                        #400
                        @MichaelF 1.6.4 testen auch gerne log per mail tombox2020@gmail.com
                        • T tombox
                          MichaelFM Offline
                          MichaelFM Offline
                          MichaelF
                          #401
                          @tombox funktioniert bis auf eine Warnmeldung kompletter Log ist unterwegs.
                          midea.0
                          2026-05-20 00:34:34.102	warn	LanClient[152832116580279]: unsolicited frame 8370008e2063330bb8cd53f82b89ff6fc4835e828b985909d6cf3ce11c5aedb1750d922c5da7e4eb5cda6603cab9b18ad1f2c3fd91e34e02faa1eba001d5f9f0e3f0d64373327de2c9bbc5f43fef03130ecd8d3a49f9ac452fe8d71be766db23adba9b3509e5c424c7c34b7bd57deb4438e4149bb56be6f776c3a5adeb6950042d88b505cc912d7af607101f5921fb96b59c3c21c931
                          midea.0
                          2026-05-20 00:34:22.025	info	Discovery summary: cloud=1, lan=1, both=1, registered=1
                          midea.0
                          2026-05-20 00:34:21.240	info	Device 152832116580279: using token/key from device list (admin override, token=97F67491…)
                          midea.0
                          2026-05-20 00:34:21.068	info	LAN discovery found 1 appliance(s)
                          midea.0
                          2026-05-20 00:34:16.059	info	LAN discovery: also unicast-probing configured device IPs [192.168.178.51]
                          midea.0
                          2026-05-20 00:34:16.056	info	Cloud listing: 1 appliance(s)
                          midea.0
                          2026-05-20 00:34:15.591	info	starting. Version 1.6.4 (non-npm: TA2k/ioBroker.midea#992b5ed13bad722ceaed0adc0e4409b1e48f6d6e) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
                          midea.0
                          2026-05-20 00:33:07.359	info	terminating
                          midea.0
                          2026-05-20 00:33:06.856	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          midea.0
                          2026-05-20 00:33:06.854	info	terminating
                          midea.0
                          2026-05-20 00:33:06.849	info	Got terminate signal TERMINATE_YOURSELF
                          • MichaelFM Offline
                            MichaelFM Offline
                            MichaelF
                            #402
                            Die Version 1.7.1 läuft perfekt.
                            Super Danke!
                            • BananaJoeB Offline
                              BananaJoeB Offline
                              BananaJoe
                              #403
                              @tombox was soll ich sagen: auch bei mir funktioniert es nun. Am Anfang gab es kurz gemecker das wohl eine andere App stört, da hatte ich mein Skript aber gerade erst 1 bis 2 Minuten beendet.
                              Die Tokens etc. hat er sich wohl selbst geholt und benutzt immer diese, richtig?
                              Jetzt muss ich meine Steuerung umbauen auf deinen Adapter - ganz ohne Ironie, Danke!
                                tombox
                                #404
                                @BananaJoe Sehr gut ja das wird automatisch geholt.
                                Wenn noch Anpassungen notwendig sind einfach bescheid sagen.
                                • H Offline
                                  hoschi2007
                                  #405
                                  Ich bin ein wenig verwirrt: sollte der Adapter mit der Midea Portalsplit funktionieren?
                                  • H hoschi2007
                                    BananaJoeB Offline
                                    BananaJoeB Offline
                                    BananaJoe
                                    #406
                                    @hoschi2007 welche App nutzt die denn?
                                    H 1 Antwort Letzte Antwort
                                      hoschi2007
                                      schrieb am zuletzt editiert von hoschi2007
                                      #407
                                      @BananaJoe sagte:
                                      Das sollte die Midea SmartHome App sein. Ich habe die App bisher nicht installiert.
                                      Die Portalsplit habe ich bisher mittels msmart-ng an den iobroker gekoppelt, aber auch so richtige Erfahrungen noch nicht sammeln können, da die Anlage noch im Keller eingemottet steht und in den nächsten Tagen aktiviert werden soll. Deshalb bin ich am überlegen den Iobroker-Adapter zu nutzen
                                      • H hoschi2007
                                        @BananaJoe sagte:
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        #408
                                        @hoschi2007 also, wenn deine Klimaanlage mit einer der folgenden Apps funktioniert
                                        • Midea Air
                                        • NetHome Plus
                                        • Smarthome (ehemals MSmartHome)
                                        • Ariston Clima
                                          Sollte es gehen, die App würde sich mit dem Account der App alles notwendige holen.
                                        Wenn du
                                        • Geräte-ID
                                        • IP
                                        • Token
                                        • Key
                                          deiner Anlagen hast, dann könntest du diese Dinge auch manuell im Adapter eintragen
                                          @tombox könnte beantworten ob der Adapter auch ganz ohne Account funktionieren würde, nur mit lokal eingetragenen Geräten?
                                          • Midea Air
                                          • NetHome Plus
                                          • Ariston Clima
                                          Wenn du
                                          • Geräte-ID
                                          • IP
                                          • Token
                                          • Key
                                          tombox
                                          #409
                                          @BananaJoe theoretisch ja aber ist eher schwer alle die information zu haben
