  4. Test Adapter OnlyCat v0.6.1
39 Beiträge 5 Kommentatoren 3.1k Aufrufe 5 Beobachtet
  • M-A HuebM M-A Hueb
    @sickboy78 anbei das Log wie gewünscht:
    02
    Log-Größe: 1.7 KB
    Zeit
    onlycat.0
    	2025-09-08 15:19:20.500	debug	Events subscribed.
    onlycat.0
    	2025-09-08 15:19:20.500	debug	Subscribing to events...
    onlycat.0
    	2025-09-08 15:19:20.500	debug	setting adapter version to adapter
    onlycat.0
    	2025-09-08 15:19:20.500	debug	Transit policies updated.
    onlycat.0
    	2025-09-08 15:19:20.499	debug	Transit policies for device 'OC-8C1F64481B40' updated.
    onlycat.0
    	2025-09-08 15:19:20.485	debug	Updating transit policies for device 'OC-8C1F64481B40'...
    onlycat.0
    	2025-09-08 15:19:20.485	debug	Updating transit policies...
    onlycat.0
    	2025-09-08 15:19:20.485	debug	Latest events updated.
    onlycat.0
    	2025-09-08 15:19:20.340	silly	Status and latest events: '{"0":{"rfidCodes":["276095300115056","276095300114976"],"276095300115056":{"2":{"globalId":6951055,"deviceId":"OC-8C1F64481B40","eventId":501,"timestamp":"2025-09-08T13:10:33.000Z","frameCount":157,"eventTriggerSource":2,"eventClassification":0,"eventManualClassification":null,"eventManualClassificationUserId":null,"posterFrameIndex":null,"accessToken":"Gr3VCB","deletedAt":null,"rfidCodes":["276095300115056"],"eventIndex":0},"3":{"globalId":6950820,"deviceId":"OC-8C1F64481B40","eventId":499,"timestamp":"2025-09-08T13:00:27.000Z","frameCount":150,"eventTriggerSource":3,"eventClassification":1,"eventManualClassification":null,"eventManualClassificationUserId":null,"posterFrameIndex":19,"accessToken":"2lgFVA","deletedAt":null,"rfidCodes":["276095300115056"],"eventIndex":2},"inside":false},"276095300114976":{"2":{"globalId":6950970,"deviceId":"OC-8C1F64481B40","eventId":500,"timestamp":"2025-09-08T13:07:00.000Z","frameCount":222,"eventTriggerSource":2,"eventClassification":0,"eventManualClassification":null,"eventManualClassificationUserId":null,"posterFrameIndex":null,"accessToken":"CNzjKa","deletedAt":null,"rfidCodes":["276095300114976"],"eventIndex":1},"3":{"globalId":6949055,"deviceId":"OC-8C1F64481B40","eventId":496,"timestamp":"2025-09-08T11:47:20.000Z","frameCount":156,"eventTriggerSource":3,"eventClassification":1,"eventManualClassification":null,"eventManualClassificationUserId":null,"posterFrameIndex":37,"accessToken":"kVCCr1","deletedAt":null,"rfidCodes":["276095300114976"],"eventIndex":5},"inside":false}}}'.
    onlycat.0
    	2025-09-08 15:19:20.339	debug	Status and latest events calculated.
    onlycat.0
    	2025-09-08 15:19:20.339	debug	Calculating status and latest events...
    onlycat.0
    	2025-09-08 15:19:20.339	debug	Updating latest events...
    onlycat.0
    	2025-09-08 15:19:20.339	debug	Last event is final.
    onlycat.0
    	2025-09-08 15:19:20.339	debug	Checking if last event is final...
    onlycat.0
    	2025-09-08 15:19:20.338	debug	setting last update to adapter
    onlycat.0
    	2025-09-08 15:19:20.338	debug	Events updated.
    onlycat.0
    	2025-09-08 15:19:20.338	debug	Updating events...
    onlycat.0
    	2025-09-08 15:19:20.337	debug	All devices updated.
    onlycat.0
    	2025-09-08 15:19:20.335	silly	States user redis pmessage onlycat.0.*.control.*/onlycat.0.Tor_zur_Freiheit.control.deviceTransitPolicyId:{"val":12329,"ack":true,"ts":1757337560330,"q":0,"from":"system.adapter.onlycat.0","user":"system.user.admin","lc":1757310296085}
    onlycat.0
    	2025-09-08 15:19:20.325	warn	No disconnect reason found for device at index '0'.
    onlycat.0
    	2025-09-08 15:19:20.325	warn	No firmware channel found for device at index '0'.
    onlycat.0
    	2025-09-08 15:19:20.325	debug	Updating all devices...
    onlycat.0
    	2025-09-08 15:19:20.325	debug	Object hierarchy created.
    jetzt startet er auch komplett auf grün.
    Nur der Datenpunkt onlycat.0.Tor_zur_Freiheit.firmwareChannel bleibt auf (null)
    aber ansonsten tut es soweit ichs sehen kann. Policies kann ich auch umschalten
    Sickboy78S Offline
    Sickboy78S Offline
    Sickboy78
    @m-a-hueb said in Test Adapter OnlyCat v0.4.0:
    Danke dir fürs Log!
    Ja, dann lags am firmware channel. Ich war davon ausgegangen, dass da immer ein Wert zurückkommt, weil default steht dass in der App auf Standard. Aber vielleicht wird das erst gesetzt, wenn man das mal geändert hat. (Ich hatte's mal auf Experimental und wieder zurück gestellt.) Das prüfe ich jetzt vorher, damit er nicht versucht 'undefined' zu setzen.
    Beim disconnect reason kommt bei mir null zurück, was zumindest keinen Fehler verursacht, wie 'undefined'.
    Zum WE werd ich eine neue Version bauen und die Warnungen wieder entfernen, damit das Log nicht zugemüllt wird.
    M-A HuebM 1 Antwort Letzte Antwort
    • Sickboy78S Sickboy78
      Danke dir fürs Log!
      M-A HuebM Offline
      M-A HuebM Offline
      M-A Hueb
      @sickboy78 Nach dem umstellen wird der Datenpunkt auch korrekt gefühlt
      iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
      • Sickboy78S Offline
        Sickboy78S Offline
        Sickboy78
        Version 0.5.4 ist da und kann mit entfernten oder umbenannten Geräten und Türrichtlinien umgehen.
        English
        Version 0.5.4 is available and can handle removed or renamed devices and transit policies.
          Aktuelle Test Version 0.6.1
          Veröffentlichungsdatum 10.05.2026
          Github Link https://github.com/Sickboy78/ioBroker.onlycat/
          Beschreibung des Adapters
          OnlyCat ist eine KI-gestützte smarte Katzenklappe mit Beuteerkennung. Der Adapter zeigt die Ereignisse der OnlyCat Katzenklappe an, d.h. Ein- und Austritt der Katzen bzw. verwehrter Eintritt bei Beuteerkennung. Aus den Ereignissen ermittelt der Adapter auch den Aufenthaltsort der Katzen (drin oder draußen).
          Voraussetzung
          Es wird eine OnlyCat Katzenklappe (entweder mit inkludierter Cloudfunktion oder mit Cloud-Abonnement) benötigt, sowie die installierte OnlyCat App (Android oder Apple).
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          @Sickboy78
          Hallo
          Hab gerade die 0.5.4 installiert.
          Adapter bleibt leider gelb.
          onlycat.0 2026-03-29 18:26:52.841	info	Automatic Reconnecting is active.
          onlycat.0 2026-03-29 18:26:52.841	info	Disconnected.
          onlycat.0 2026-03-29 18:26:52.841	debug	setting connection status to adapter
          onlycat.0 2026-03-29 18:26:52.840	error	TypeError: Cannot read properties of null (reading 'replace')
          onlycat.0 2026-03-29 18:26:52.840	debug	(OnlyCatApi) [1] <- event: ''getDevices'' - response: '[ { deviceId: 'OC-0CBFB4902871', description: null, timeZone: 'Europe/Vienna', deviceTransitPolicyId: 29056, cursorId: 8047 } ]'
          onlycat.0 2026-03-29 18:26:52.794	debug	User changed for user: 7710.
          onlycat.0 2026-03-29 18:26:52.794	debug	(OnlyCatApi) UserUpdate: '7710'
          onlycat.0 2026-03-29 18:26:52.791	debug	(OnlyCatApi) [1] -> event: ''getDevices'' - args: '[ { subscribe: true } ]'
          onlycat.0 2026-03-29 18:26:52.791	debug	Getting devices...
          onlycat.0 2026-03-29 18:26:52.790	debug	New connection state: 'CONNECTED'
          onlycat.0 2026-03-29 18:26:52.790	info	Connected.
          onlycat.0 2026-03-29 18:26:52.790	debug	setting connection status to adapter
          onlycat.0 2026-03-29 18:26:52.789	debug	(OnlyCatApi) Connected.
          onlycat.0 2026-03-29 18:26:52.542	debug	New initial connection state: 'CONNECTING'
          onlycat.0 2026-03-29 18:26:52.542	debug	(OnlyCatApi) Connecting to https://gateway.onlycat.com
          onlycat.0 2026-03-29 18:26:52.542	debug	New initial connection state: 'STARTING'
          onlycat.0 2026-03-29 18:26:52.541	info	Connecting...
          onlycat.0 2026-03-29 18:26:52.541	debug	setting connection status to adapter
          onlycat.0 2026-03-29 18:26:52.540	debug	Starting OnlyCat Adapter v0.5.2
          onlycat.0 2026-03-29 18:26:52.540	info	adapter configuration ok
          onlycat.0 2026-03-29 18:26:52.540	debug	checking adapter configuration...
          onlycat.0 2026-03-29 18:26:52.539	debug	setting connection status to adapter
          onlycat.0 2026-03-29 18:26:52.528	info	starting. Version 0.5.4 in /opt/iobroker/node_modules/iobroker.onlycat, node: v22.22.1, js-controller: 7.1.0
          onlycat.0 2026-03-29 18:26:47.057	info	terminating
          onlycat.0 2026-03-29 18:26:46.556	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          onlycat.0 2026-03-29 18:26:46.555	info	terminating
          onlycat.0 2026-03-29 18:26:46.555	info	everything cleaned up
          onlycat.0 2026-03-29 18:26:46.554	warn	(OnlyCatApi) Disconnected.
          onlycat.0 2026-03-29 18:26:46.553	info	Got terminate signal TERMINATE_YOURSELF
          ° Fixer ---> iob fix
            Sickboy78S Offline
            Sickboy78
            Hi @negalein ,
            deine OnlyCat Klappe hat keinen Gerätenamen (description: null).
            Als Quick Fix vergib bitte in der Onlycat App einen Gerätenamen.
            Als Code Fix werde ich in der nächsten Version einen Fallback auf die deviceId einbauen.
              Hi @negalein ,
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              @Sickboy78 sagte in Test Adapter OnlyCat v0.5.4:
              Danke, das wars. :)
              PS: gibt es eine Möglichkeit über die API die Videos anzuzeigen?
                Sickboy78S Offline
                Sickboy78
                @negalein
                Ja, mit der deviceId, der eventId und dem accessToken aus dem jeweiligen event kannst du dir eine URL zum Video zusammenbauen:
                https://onlycat.app/events/{deviceId}/{eventId}?t={accessToken}
                Könnte ich eigentlich im Adapter zusammenbauen und bei den entsprechenden Events als Link ergänzen. ->Kommt auf meine TODO.
                  @negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  super, danke dir
                    Sickboy78S Offline
                    Sickboy78
                    Version 0.6.0 hat neue Datenpunkte für Ereignisse: deletedAt, eventManualClassification, eventManualClassificationUserId und link. Letzterer enthält einen Link zum Ereignis mit Video.
                    English
                    Version 0.6.0 includes new data points for events: deletedAt, eventManualClassification, eventManualClassificationUserId, and link. The latter contains a link to the event with video.
                      English
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      @Sickboy78 sagte:
                      sind bei mir alle (null)
                      für was sind die (Bedeutung)?
                      .Event.01 usw.
                      Ist 01 immer der letzte/aktuellste Event?
                      • NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        noch was?
                        wie oft wird abgefragt?
                        sind zT Stunden dazwischen
                        Striezi zB
                        Adapter
                        Wert:
                        outside
                        Typ:
                        string
                        Zeitstempel:
                        21 minutes ago
                        Bestätigt:
                        Bestätigt (true)
                        Zuletzt geändert:
                        8 hours ago
                        Qualität:
                        0x00 - good
                        Von:
                        Benutzer:
                        system.user.admin
                        App
                          Sickboy78S Offline
                          Sickboy78
                          schrieb am zuletzt editiert von Sickboy78
                          deletedAt - wann das Event in der App gelöscht wurde
                          eventManualClassification - manuell gesetzter Eventstatus in der App
                          eventManualClassificationUserId - Benutzer der den Eventstatus in der App manuell gesetzt
                          Ja. Kommt eine neues Event rein, ist es wieder 01, das alte 01 wird zu 02 usw.
                          Gar nicht. Der Adapter abonniert Events, die als Push Benachrichtigung reinkommen. Es sollte sich also nahezu in Echtzeit aktualisieren.
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            @Sickboy78 sagte:
                            Danke, werde es beobachten.
                            Mir ist der doch sehr große Unterschied erst heute aufgefallen.
                            Sickboy78S 1 Antwort Letzte Antwort
                            • NegaleinN Negalein
                              @Sickboy78 sagte:
                              Sickboy78S Offline
                              Sickboy78S Offline
                              Sickboy78
                              @Negalein sagte:
                              Was meinst du mit sehr großem Unterschied? Bekommst du die Events erst zeitverzögert?
                                @Negalein sagte:
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                @Sickboy78 sagte:
                                War gestern so. Heute passt alles.
                                Btw., im Home Assistant bekommt man zusätzlich noch einen Snapshot.
                                Kannst du das noch einbauen?
                                  @Sickboy78 sagte:
                                  Sickboy78S Offline
                                  Sickboy78S Offline
                                  Sickboy78
                                  Version 0.6.1 hat einen neue Datenpunkt für Ereignisse: image, mit einem Link zum Vorschaubild für das Video.
                                  English
                                  Version 0.6.1 includes a new data point for events: image, which contains a link to the video thumbnail.
                                    English
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    @Sickboy78 sagte:
                                    fehlt bei mir noch mit 0.6.1
                                    Edit: ist jetzt vorhanden :)
                                    • NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      @sickboy78
                                      hast du einen tip, wie ich onlycat.0.King_s_Gate___.events.01.link in Vis bekomme?
                                      Habs mit dem iframe widget mit {onlycat.0.King_s_Gate___.events.01.link} versucht. kommt nix.
                                        Sickboy78S Offline
                                        Sickboy78
                                        @negalein
                                        Also bei mir funktionierts mit dem Basic Iframe. Im Editor bekomme ich auch 404 angezeigt, aber auf dem finalen View wird es korrekt angezeigt.
                                        1e7e9826-d278-4637-bcc4-8de129805edd-image.jpeg 7da46264-91ab-41c8-a571-5a5ac39e0896-image.jpeg
                                          @negalein
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          @Sickboy78 sagte:
                                          kannst du mir einen Export schicken?
                                          hab beide so
                                          kommt aber nix
