  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Sourceanalytics ohne funktion
    2.8k
    4.8k
    4.0k
126 Beiträge 7 Kommentatoren 7.7k Aufrufe 6 Beobachtet
  • A Accuface
    @Homoran sagte:
    ...und auf die Ausgabe von iob diag warte ich auch noch
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
     Static hostname: raspberrypi5
           Icon name: computer
              Kernel: Linux 6.12.34+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     22:00:19 up 220 days,  6:44,  2 users,  load average: 0.46, 0.22, 0.19
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-04-30 22:00:20 CEST
               Universal time: Thu 2026-04-30 20:00:20 UTC
                     RTC time: Thu 2026-04-30 20:00:20
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Bernd
    HOME=/home/Bernd
    GROUPS=Bernd adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.5G        3.9G        741M        1.4M        4.1G        4.5G
    Swap:           209M        7.3M        202M
    Total:          8.7G        3.9G        944M
    Active iob-Instances:   32
             8063 M total memory
             3736 M used memory
             3455 M active memory
             3188 M inactive memory
              707 M free memory
              267 M buffer memory
             3633 M swap cache
              199 M total swap
                7 M used swap
              192 M free swap
    top - 22:00:20 up 220 days,  6:44,  2 users,  load average: 0.46, 0.22, 0.19
    Tasks: 215 total,   2 running, 213 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.2 total,    706.3 free,   3737.4 used,   3900.8 buff/cache
    MiB Swap:    200.0 total,    193.0 free,      7.0 used.   4325.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     1.6G  5.3M  1.6G   1% /run
    /dev/mmcblk0p2 ext4       29G   11G   17G  40% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
    [Mon Sep 22 15:15:58 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Mon Sep 22 15:15:59 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.6G    /var/
    2.9G    /var/log/journal/9ba9919aad384e6eaaa1e9cb2eaa4832
    2.9G    /var/log
    355M    /var/cache
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    284M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    842M    /opt/iobroker/iobroker-data/
    504M    /opt/iobroker/iobroker-data/files
    194M    /opt/iobroker/iobroker-data/history
    121M    /opt/iobroker/iobroker-data/files/vis
    114M    /opt/iobroker/iobroker-data/files/vis/widgets
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    16M     /opt/iobroker/iobroker-data/files/vis-2.0/New project/vis-views.json
    15M     /opt/iobroker/iobroker-data/files/vis-2.0/vis-views.json
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.20.2
    /usr/bin/node           v20.20.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    ✓ Node.js installation is correct
    nodejs:
      Installed: 20.20.2-1nodesource1
      Candidate: 20.20.2-1nodesource1
      Version table:
     *** 20.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.20.1-1nodesource1 1001
         20.20.0-1nodesource1 1001
         20.19.6-1nodesource1 1001
         20.19.5-1nodesource1 1001
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    v20.20.2 is end-of-life. There are high chances of being vulnerable. Please upgrade it.
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi5        raspberrypi5 (version: 7.0.7, hostname: raspberrypi5  , alive, uptime: 98284)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi5                             - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
    + system.adapter.daswetter.0              : daswetter             : raspberrypi5                             - disabled
      system.adapter.devices.0                : devices               : raspberrypi5                             - disabled
    + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi5                             - disabled
    + system.adapter.echarts.0                : echarts               : raspberrypi5                             -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi5                             - disabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspberrypi5                             -  enabled
    + system.adapter.fronius.0                : fronius               : raspberrypi5                             -  enabled
    + system.adapter.fronius.1                : fronius               : raspberrypi5                             -  enabled
    + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi5                             - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi5                             - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi5                             - disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi5                             -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi5                             -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : raspberrypi5                             -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi5                             -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi5                             -  enabled
      system.adapter.sql.0                    : sql                   : raspberrypi5                             - disabled, port: 3306
    + system.adapter.synology.0               : synology              : raspberrypi5                             -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi5                             -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi5                             -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi5                             - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi5                             - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi5                             - disabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: raspberrypi5                             - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi5                             - disabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi5                             - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi5                             - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi5                             - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi5                             - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi5                             - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi5                             -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi5                             -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "fronius"      : 2.2.0    , installed 2.2.0
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "ical"         : 1.20.0   , installed 1.20.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "node-red"     : 6.0.7    , installed 6.0.7
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "rpi2"         : 3.0.2    , installed 2.4.0  [Updatable]
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "socketio"     : 7.0.8    , installed 7.1.3
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
    Adapter    "vis-2-widgets-inventwo": 0.7.2, installed 0.7.2
    Adapter    "vis-2-widgets-jaeger-design": 1.4.19, installed 1.4.19
    Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
    Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        14053
    States:         11481
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 53
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       609903878  2918089/iobroker.js
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       609904805  2918089/iobroker.js
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6304       799/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       609960010  2922682/io.jarvis.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       609907372  2919521/node-red
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       609908999  2919547/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       609911987  2920370/io.sonoff.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       609930160  2921441/io.mqtt.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       609904958  2918118/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       610050649  2925204/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6306       799/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        766        683/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       609907971  2919554/io.shelly.1
    udp        0      0 0.0.0.0:57792           0.0.0.0:*                           104        768        683/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        767        683/avahi-daemon: r
    udp6       0      0 :::43037                :::*                                104        769        683/avahi-daemon: r
    udp6       0      0 fe80::dc25:f03d:c31:546 :::*                                0          609860833  759/NetworkManager
    udp6       0      0 fe80::5c42:ca8c:448:546 :::*                                0          573564624  759/NetworkManager
    2026-04-30 21:59:15.077  - warn: shelly.0 (2919547) [BLE] b0:c7:de:2d:94:96 (via shellyplus1pm-10061cca8844): Script version 0.2 is not supported (expected 1.2), see documentation for latest version
    2026-04-30 21:59:15.253  - warn: shelly.0 (2919547) [BLE] b0:c7:de:2d:94:96 (via shellyplus1pm-cc7b5c0b1820): Script version 0.4 is not supported (expected 1.2), see documentation for latest version
    2026-04-30 21:59:15.406  - warn: shelly.0 (2919547) [BLE] b0:c7:de:2d:94:96 (via shellyplus1pm-cc7b5c0b1820): Script version 1.0 is not supported (expected 1.2), see documentation for latest version
    2026-04-30 21:59:26.967  - info: shelly.0 (2919547) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-04-30 21:59:42.235  - info: shelly.0 (2919547) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-04-30 21:59:57.530  - info: shelly.0 (2919547) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-04-30 22:00:00.092  - info: host.raspberrypi5 instance system.adapter.ical.0 in version "1.20.0" started with pid 2980598
    2026-04-30 22:00:01.147  - info: ical.0 (2980598) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.20.2, js-controller: 7.0.7
    2026-04-30 22:00:01.644  - info: ical.0 (2980598) processing URL: calendar1 https://calendar.google.com/calendar/ical/a6cf4032987a135cfaa81b15ed9c8e6ab549bc95294940726e92fa8244a146d8%40group.calendar.google.com/private-40a643ac0d34c2167eaaf67c3155ea84/basic.ics
    2026-04-30 22:00:01.758  - warn: trashschedule.0 (2922974) no events matches type "Papiertonne" with match "Papier"
    2026-04-30 22:00:06.712  - info: ical.0 (2980598) Terminated (NO_ERROR): Without reason
    2026-04-30 22:00:07.225  - info: host.raspberrypi5 instance system.adapter.ical.0 having pid 2980598 terminated with code 0 (NO_ERROR)
    2026-04-30 22:00:12.798  - info: shelly.0 (2919547) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-04-30 22:00:23.003  - info: mqtt.0 (2921441) Client [Heizoel_0] connection closed: timeout
    2026-04-30 22:00:23.358  - info: mqtt.0 (2921441) Client [Heizoel_0] connected with secret 1777579223356_9502
    2026-04-30 22:00:23.374  - info: mqtt.0 (2921441) Client [Heizoel_0] subscribes on "Heizoel/#" with regex /^Heizoel\..*/
    2026-04-30 22:00:23.374  - info: mqtt.0 (2921441) Client [Heizoel_0] subscribes on "Heizoel/#"  with regex /^mqtt\.0\.Heizoel\..*/
    2026-04-30 22:00:23.574  - info: mqtt.0 (2921441) Client [Heizoel_0] publishOnSubscribe send all known states
    2026-04-30 22:00:28.068  - info: shelly.0 (2919547) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-04-30 22:00:40.414  - info: mqtt.0 (2921441) Client [Heizoel_0] connection closed: timeout
    2026-04-30 22:00:43.338  - info: shelly.0 (2919547) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-04-30 22:00:45.741  - info: mqtt.0 (2921441) Client [Heizoel_0] connected with secret 1777579245741_1162
    2026-04-30 22:00:45.857  - info: mqtt.0 (2921441) Client [Heizoel_0] subscribes on "Heizoel/#" with regex /^Heizoel\..*/
    2026-04-30 22:00:45.857  - info: mqtt.0 (2921441) Client [Heizoel_0] subscribes on "Heizoel/#"  with regex /^mqtt\.0\.Heizoel\..*/
    2026-04-30 22:00:46.058  - info: mqtt.0 (2921441) Client [Heizoel_0] publishOnSubscribe send all known states
    @Homoran sagte:
    @crunchip sagte:
    eingeben musst du schon die ersten Buchstaben, dann taucht er auch auf
    Nee, der muss im beta sein, nicht über npm.
    Wahrscheinlich hat @accuface nach dem Repowechsel nicht das Repo neu geladen
    Sorry leute ich bin gerade so überfordert, das ist zu lange her als ich das alles installiert hatte....irgendwie.
    Ich hab keinen Plan mehr, von wo aus ich das damals installiert hatte.
    Jedenfalls nicht mit diesem repo gedöns ein oder ausgeschalte. einfach nur über den adapter.
    Was wollt ihr von mir? ich checks nicht.
    @Accuface sagte:
    Debian GNU/Linux 12 (bookworm)
    Auf Debian 13 (trixie) bringen.
    Auf nodejs22 bringen.
    Künftig dann regelmäßiger und häufiger updaten.
      @Accuface sagte:
      Accuface
      @Thomas-Braun sagte:
      NEIN, definitiv nicht, denn dass war es was mir am 18.03. alles zerschossen hatte, danach funktionierten die Backup und der sourceanalyticx nicht mehr, und einige Button die in der VIS hatte, waren auch weg.
      Never touch a running system.
      Mir wäre wichtig dass der sourceanalytics wieder läuft, wobei für 2026 meine aufzeichnungen fürn Arsch sind
      Thomas BraunT crunchipC HomoranH 3 Antworten Letzte Antwort
      • A Accuface
        @Accuface sagte:
        Nodejs 20 ist ABEGKÜNDIGT! Da muss auf ein aktuelles und unterstütztes Release gehoben werden.
        Schwachsinn. Schon immer gewesen, wird es immer sein.
        • A Accuface
          crunchipC Offline
          crunchipC Offline
          @Accuface sagte:
          dann bleibst du auf deinem Problem wohl alleine sitzen
          @Accuface sagte:
          bezweifle ich
          • A Accuface
            @Accuface sagte:
            Nein, definitiv nicht!
            Da du sowieso eine Neuinstallation machen musst, machst du die (parallel) auf einer neuen SD-Karte, spielst da das Backup zurück und hast immer noch die alte Karte mit der veralteten und unsicheren Installation.
            Wir suchen mit dir in der neuen Installation nach Lösungen.
            Viele Adapter(updates) benötigen auch eine aktuelle Basis
            Wenn du weiter mit der alten "arbeiten" willst ist das deine Entscheidung.
              @Accuface sagte:
              Accuface
              @Homoran sagte:
              @Accuface sagte:
              Sondern?
              Fakt ist das am Tag nach den ganzen Updates, weder der sourceanalytix weiter funktionierte (was im übrigen auch im Adapter stand. einen Meldung gibts hier im Forum drüber) noch hat anscheinend Backitup funktioniert, da nämlich auch keine Meldungen über erfolgreiche Backups angezeigt werden und auf meinem NAS auch nur bis zum 18.04. backups vorliegen.
              Folglich MUSS es irgendwas mit den Updates zu tun haben. Ich hab sonst ja nix verändert.
              Das heisst was genau? und da komm ich an meine Grenzen.
              Naja die alt hat ja seit 2 Jahren reibungslos funktioniert.
              Jetzt hab ich gedacht ich mach dem System was gutes und mach die nötigen Updates....ZACK.. funktioniert einiges nicht mehr. Im übrigen auch die ganzen erstellten Hintergründe in der VIS waren weg, sprich nur noch diese Quer gestrichelten Hintergründe zu sehen.
              Mir kommt es so vor dass einige Adapter mit den Updates nicht zurecht kamen, bzw. einiges geändert wurde und daher meine Ansicht nicht mehr passte.
              Was ich allerdings nicht versteh:
              warum der SA ver. 0.4.14 nach dem einspielen des Backup weiterhin nicht funktioniert, versteh ich nicht.
              Ich dachte immer ein Backup ist dazu da um ein System wieder auf einen Stand zubringen, wo alles ok war.
              Ich bin aber auch kein ITler oder kenn mich besonders gut in dem bereich aus.
              also, wie gehts nun weiter, bitte gebt mir genau anleitungen weil mit der Aussage "musst eh neuinstallation machen" kann ich nicht viel anfangen. Ich ärgere mich gerade so dermasen dass ich die scheiß Updates gemacht hab. es ist alles so gut gelaufen und meine Dokumentation ist nun auch im Arsch durch die Fehltage.
              • A Accuface
                @Homoran sagte:
                @Accuface sagte:
                Sondern?
                @Accuface
                https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie?sort=oldest_to_newest
                und
                iob nodejs-update
                Und dann meinst du beurteilen zu können, dass Updates für dich nicht relevant sind? Gerade dann musst du dich auf das Wissen von anderen verlassen und jedes Update einspielen.
                  @Accuface
                  und
                  iob nodejs-update
                  Accuface
                  schrieb am zuletzt editiert von Accuface
                  @Accuface
                  siehste, da gehts nämlich schon los.... Zitat:
                  gleichen CPU-Architektur aus möglich.
                  und
                  Also Debian 12 'Bookworm' und z.B. arch64. CrossUpgrades von 32Bit 'armhf' auf 'arm64' sind nicht möglich (nur für echte Pinguine!) und bedingen eine Neuinstallation.
                  Puhhhh.... Ich versteh nur Bahnhof. Ich hab nen Pi 5, mehr weiss ich nicht.
                  und
                  iob nodejs-update
                  Theoretisch hast du da Recht, Praktisch ist halt so:
                  Wenn ich als Laie Updates mache, danach irgendwie nur die hälfte noch funktioniert, dann schreckt das erst mal ab. Wenn ich dann als Laie mehrer Stunden benötige um ein Backup einzuspielen, was dann auch nicht wieder alles herstellt und funktioniert, dann ist das erst mal sehr frustrieren und nimmt mir den glauben daran, das Updates was gutes sind.
                  Das klingt vielleicht Traurig, ist aber wahr.
                  Das Problem ist für mich halt auch, wenn ein "Profi" oder halt jemand der sich besser auskennt, etwas Schreibt/erklärt und irgendwelche Fachbegriffe auftauchen, dann ist das für mich als Laie erst mal mit sehr vielen ? verbunden. oft geh ich dann her und versuch mich über Google einzulesen/informieren, und das führt dann meistens dazu dass ich total vom eigentlichen Ziel abweiche und alles meisten schlimmer mache.
                  Deswegen schrieb ich ja, ich bräucht am besten eine Anleitung, schritt für schritt.
                  Ich hoffe ihr versteht was ich meine.
                  • A Accuface
                    @Accuface
                    und
                    und
                    iob nodejs-update
                    @Accuface sagte:
                    Siehe mein Post davor...
                    Umsetzen musst du es selber.
                    Deine Ausgangsbasis ist bereits auf reinem 64Bit, mit CrossUpgrades oder anderen CPU-Architekturen hast du also nichts zu tun.
                    Aus deinem iob diag von oben:
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                      @Accuface sagte:
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      Accuface
                      @Accuface sagte:
                      Frage:
                      Erst das trixie installieren und dann Node.js oder andersrum?
                      und muss ich ein backup vom Pi machen? IOB backup ist von heute nacht gemacht bzw. das vom 17.04. gesichert
                      • A Accuface
                        @Accuface sagte:
                        Frage:
                        @Accuface
                        Kannste machen wie ein Dachdecker.
                          @Accuface
                          Accuface
                          @Accuface
                          danke
                          • A Accuface
                            @Accuface
                            und
                            und
                            iob nodejs-update
                            @Accuface sagte:
                            Klar, aber deine Schlussfolgerung ist falsch.
                            Nur mal als alternative Möglichkeiten:
                            • Beim Update hat es das Dateisystem auf einer Billig-Sd-Karte geschreddert.
                            • Beim Download einer Datei ist es zu Störungen im Netzwerk gekommen, und die Datei war defekt.
                            • Das Update ist nicht korrekt durchgeführt worden
                              • Adapter benötigen bestimmte nodejs Versionen
                              • Nodejs benötigt bestimmte Betriebssystemversionen.
                              • Das Betriebssystem muss zur Hardware passen.
                            Aber lange Rede, kurzer Sinn:
                            Fang so wie beschrieben neu an, wir werden dich führen!
                            WICHTIG:
                            Unbedingt lieber zu oft, als zu wenig nachfragen.
                            Schritt 1: NEUE SD-Karte besorgen und aktuelles Raspberry OS Trixie lite installieren
                            @Accuface sagte:
                            dann Node.js oder
                            Nodejs kommt automatisch richtig mit der iobroker Installation!
                            Das sollte auch nicht manuell "zusammengeschustert" werden
                              @Accuface sagte:
                              WICHTIG:
                              @Accuface sagte:
                              dann Node.js oder
                              Accuface
                              @Homoran sagte:
                              > * Beim Update hat es das Dateisystem auf einer Billig-Sd-Karte geschreddert.
                              Nein, keine SD....SSD, da läuft das system drauf
                              > * Beim Download einer Datei ist es zu Störungen im Netzwerk gekommen, und die Datei war defekt.
                              > * Das Update ist nicht korrekt durchgeführt worden
                              >   * Adapter benötigen bestimmte nodejs Versionen
                              >   * Nodejs benötigt bestimmte Betriebssystemversionen.
                              >   * Das Betriebssystem muss zur Hardware passen.
                              Das kann ich natürlich nicht mit Sicherheit ausschliessen.
                              iob diag inside:
                              ```bash
                              Script v.2026-01-31
                              *** BASE SYSTEM ***
                              Operating System: Debian GNU/Linux 13 (trixie)
                                     Icon name: computer
                                        Kernel: Linux 6.12.75+rpt-rpi-2712
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                               12:40:05 up 7 min,  1 user,  load average: 0.11, 0.35, 0.23
                              CPU threads: 4
                              Operating System is the current Debian stable version codenamed 'trixie'!
                              Current issues:
                                             Local time: Fri 2026-05-01 12:40:06 CEST
                                         Universal time: Fri 2026-05-01 10:40:06 UTC
                                               RTC time: Fri 2026-05-01 10:40:06
                                            NTP service: active
                                        RTC in local TZ: no
                              Bernd
                              HOME=/home/Bernd
                              iobroker
                              HOME=/home/iobroker
                              SUDO_HOME=/home/Bernd
                              Display-Manager:
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Mem:            8.5G        2.8G        4.9G         15M        901M        5.7G
                              Swap:           209M          0B        209M
                              Total:          8.7G        2.8G        5.1G
                              Active iob-Instances:   31
                                       8062 M total memory
                                       2628 M used memory
                                       2450 M active memory
                                        568 M inactive memory
                                       4673 M free memory
                                         87 M buffer memory
                                        772 M swap cache
                                        199 M total swap
                                          0 M used swap
                                        199 M free swap
                              top - 12:40:06 up 7 min,  1 user,  load average: 0.18, 0.36, 0.24
                              Tasks: 225 total,   2 running, 223 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  6.7 us,  0.0 sy,  0.0 ni, 91.1 id,  2.2 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8062.9 total,   4670.2 free,   2630.3 used,    860.9 buff/cache
                              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5432.6 avail Mem
                              *** FILESYSTEM ***
                              Filesystem                            Type      Size  Used Avail Use% Mounted on
                              tmpfs                                 tmpfs     1.6G   15M  1.6G   1% /run
                              /dev/mmcblk0p2                        ext4       29G   12G   16G  42% /
                              tmpfs                                 tmpfs     4.0G   96K  4.0G   1% /tmp
                              tmpfs                                 tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                              /dev/mmcblk0p1                        vfat      510M   74M  437M  15% /boot/firmware
                              tmpfs                                 tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                              tmpfs                                 tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                              //192.168.178.37/home/backup/iobroker cifs      2.7T  1.8T  955G  66% /opt/iobroker/backups
                              tmpfs                                 tmpfs     807M   32K  807M   1% /run/user/1000
                              [Fri May  1 12:32:23 2026] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                              [Fri May  1 12:32:25 2026] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                              `-/opt/iobroker/backups //192.168.178.37/home/backup/iobroker cifs   rw,relatime,vers=3.1.1,cache=strict,upcall_target=app,username=backup,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.37,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,reparse=nfs,rsize=4194304,wsize=4194304,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
                              /var:
                              3.6G    /var/
                              2.8G    /var/log/journal/9ba9919aad384e6eaaa1e9cb2eaa4832
                              2.8G    /var/log
                              373M    /var/cache
                              Archived and active journals take up 2.7G in the file system.
                              185M    /opt/iobroker/backups/
                              858M    /opt/iobroker/iobroker-data/
                              28M     /opt/iobroker/iobroker-data/objects.jsonl
                              18M     /opt/iobroker/iobroker-data/states.jsonl
                              USB-Devices by-id:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                                   20.19.2+dfsg-1+deb13u2 500
                                      500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                                   20.19.2+dfsg-1 500
                                      500 http://deb.debian.org/debian trixie/main arm64 Packages
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              raspberrypi5        raspberrypi5 (version: 7.0.7, hostname: raspberrypi5  , alive, uptime: 453)
                              admin:          7.7.22
                              javascript:     9.0.18
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        14053
                              States:         11479
                              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_20.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:44:55Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                              W: Failed to fetch https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:44:55Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                              W: Some index files failed to download. They have been ignored, or old ones used instead.
                              Hit:1 http://deb.debian.org/debian trixie InRelease
                              Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
                              Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                              Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                              Err:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Pending systemupdates: 0
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7574       1172/exim4
                              tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       10227      1730/io.jarvis.0
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7457       885/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7001       874/iobroker.js-con
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8368       874/iobroker.js-con
                              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       9573       1335/node-red
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8943       1538/io.shelly.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       9954       1603/io.sonoff.0
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       10658      1586/io.mqtt.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          7459       885/sshd: /usr/sbin
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7575       1172/exim4
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10265      906/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10749      1665/io.web.0
                              udp        0      0 0.0.0.0:46980           0.0.0.0:*                           104        7340       698/avahi-daemon: r
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7338       698/avahi-daemon: r
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       9920       1571/io.shelly.1
                              udp6       0      0 fe80::5c42:ca8c:448:546 :::*                                0          8529       788/NetworkManager
                              udp6       0      0 fe80::dc25:f03d:c31:546 :::*                                0          8410       788/NetworkManager
                              udp6       0      0 :::5353                 :::*                                104        7339       698/avahi-daemon: r
                              udp6       0      0 :::34331                :::*                                104        7341       698/avahi-daemon: r
                              2026-05-01 12:34:50.786  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:35:06.037  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:35:21.293  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:35:36.637  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:35:51.914  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:36:07.201  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:36:22.492  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:36:37.847  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:36:53.115  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:37:08.405  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:37:23.664  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:37:38.922  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:37:54.175  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:38:09.454  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:38:24.728  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:38:29.624  - info: shelly.0 (1538) [MQTT] Device with client id "shellytrv-8CF681B6FADA" connected from 192.168.178.94!
                              2026-05-01 12:38:33.465  - info: shelly.0 (1538) [MQTT] Device with client id "shellytrv-8CF681B6FADA" initialized.
                              2026-05-01 12:38:39.996  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:38:55.338  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:39:10.633  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:39:25.902  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:39:41.181  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:39:56.484  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:40:11.764  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              2026-05-01 12:40:27.045  - info: shelly.0 (1538) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                              • A Accuface
                                @Homoran sagte:
                                iob diag inside:
                                ```bash
                                Script v.2026-01-31
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                CPU threads: 4
                                Current issues:
                                              NTP service: active
                                          RTC in local TZ: no
                                Bernd
                                HOME=/home/Bernd
                                iobroker
                                HOME=/home/iobroker
                                Display-Manager:
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           209M          0B        209M
                                         8062 M total memory
                                         2628 M used memory
                                         4673 M free memory
                                           87 M buffer memory
                                          772 M swap cache
                                          199 M total swap
                                            0 M used swap
                                          199 M free swap
                                *** FILESYSTEM ***
                                /var:
                                3.6G    /var/
                                2.8G    /var/log
                                373M    /var/cache
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.7.22
                                javascript:     9.0.18
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        14053
                                States:         11479
                                @Accuface sagte:
                                Nein, das stimmt nicht:
                                sowie
                                zeigen, dass dein System auf einer SD-Karte liegt. SSDs werden als /dev/sdXY angelegt. So wie auf meinem System z. B.:
                                /dev/sda2      ext4      110G   16G   89G  16% /
                                /                /dev/sda2 ext4   rw,noatime
                                `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                Jetzt noch nodejs auf Version 22 bringen.
                                iob nodejs-update 22
                                  @Accuface sagte:
                                  sowie
                                  Accuface
                                  Erledigt:
                                  ```bash
                                  Script v.2026-01-31
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   15:23:51 up  2:51,  1 user,  load average: 0.37, 0.30, 0.37
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Fri 2026-05-01 15:23:51 CEST
                                             Universal time: Fri 2026-05-01 13:23:51 UTC
                                                   RTC time: Fri 2026-05-01 13:23:51
                                                NTP service: active
                                            RTC in local TZ: no
                                  Bernd
                                  HOME=/home/Bernd
                                  iobroker
                                  HOME=/home/iobroker
                                  Display-Manager:
                                  Desktop:
                                  Session:                tty
                                  *** MEMORY ***
                                  Mem:            8.5G        3.3G        3.0G         25M        2.2G        5.1G
                                  Swap:           209M          0B        209M
                                  Total:          8.7G        3.3G        3.3G
                                           8062 M total memory
                                           3190 M used memory
                                           2902 M active memory
                                           1765 M inactive memory
                                           2903 M free memory
                                            297 M buffer memory
                                           1782 M swap cache
                                            199 M total swap
                                              0 M used swap
                                            199 M free swap
                                  top - 15:23:52 up  2:51,  1 user,  load average: 0.37, 0.30, 0.37
                                  Tasks: 218 total,   1 running, 217 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  2.4 us,  0.0 sy,  0.0 ni, 97.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   8062.9 total,   2901.2 free,   3192.6 used,   2080.0 buff/cache
                                  MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4870.3 avail Mem
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs     4.0G  8.9M  4.0G   1% /tmp
                                  /var:
                                  3.6G    /var/
                                  2.8G    /var/log
                                  408M    /var/cache
                                  851M    /opt/iobroker/iobroker-data/
                                  14M     /opt/iobroker/iobroker-data/states.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/nodejs         v22.22.2
                                  /usr/bin/node           v22.22.2
                                  /usr/bin/npm            10.9.7
                                  /usr/bin/npx            10.9.7
                                  nodejs:
                                    Installed: 22.22.2-1nodesource1
                                    Candidate: 22.22.2-1nodesource1
                                    Version table:
                                   *** 22.22.2-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                       22.22.1-1nodesource1 1001
                                       22.22.0-1nodesource1 1001
                                       22.21.0-1nodesource1 1001
                                       22.20.0-1nodesource1 1001
                                       22.19.0-1nodesource1 1001
                                       22.18.0-1nodesource1 1001
                                       22.17.1-1nodesource1 1001
                                       22.17.0-1nodesource1 1001
                                       22.16.0-1nodesource1 1001
                                       22.15.1-1nodesource1 1001
                                       22.15.0-1nodesource1 1001
                                       22.14.0-1nodesource1 1001
                                       22.13.1-1nodesource1 1001
                                       22.13.0-1nodesource1 1001
                                       22.12.0-1nodesource1 1001
                                       22.11.0-1nodesource1 1001
                                       22.10.0-1nodesource1 1001
                                       22.9.0-1nodesource1 1001
                                       22.8.0-1nodesource1 1001
                                       22.7.0-1nodesource1 1001
                                       22.6.0-1nodesource1 1001
                                       22.5.1-1nodesource1 1001
                                       22.5.0-1nodesource1 1001
                                       22.4.1-1nodesource1 1001
                                       22.4.0-1nodesource1 1001
                                       22.3.0-1nodesource1 1001
                                       22.2.0-1nodesource1 1001
                                       22.1.0-1nodesource1 1001
                                       22.0.0-1nodesource1 1001
                                       20.19.2+dfsg-1 500
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  raspberrypi5        raspberrypi5 (version: 7.0.7, hostname: raspberrypi5  , alive, uptime: 1127)
                                  admin:          7.7.22
                                  javascript:     9.0.18
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        14320
                                  States:         11737
                                  Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
                                  Hit:4 http://deb.debian.org/debian trixie-updates InRelease
                                  Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       365179     8198/io.jarvis.0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       363025     7597/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       363030     7597/iobroker.js-co
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       362300     7787/node-red
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       365774     7994/io.shelly.0
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       364810     8062/io.sonoff.0
                                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       364759     8045/io.mqtt.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       362102     7621/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       365036     8129/io.web.0
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       364725     8029/io.shelly.1
                                  2026-05-01 15:20:22.608  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:20:37.864  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:20:53.118  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:21:08.428  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:21:23.819  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:21:28.622  - info: web.0 (8129) <== Disconnect system.user.admin from ::ffff:192.168.178.22
                                  2026-05-01 15:21:29.633  - info: web.0 (8129) ==> Connected system.user.admin from ::ffff:192.168.178.22
                                  2026-05-01 15:21:39.077  - info: web.0 (8129) <== Disconnect system.user.admin from ::ffff:192.168.178.22
                                  2026-05-01 15:21:39.129  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:21:40.055  - info: web.0 (8129) ==> Connected system.user.admin from ::ffff:192.168.178.22
                                  2026-05-01 15:21:54.415  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:22:02.608  - info: admin.0 (7621) ==> Connected system.user.admin from ::ffff:192.168.178.22
                                  2026-05-01 15:22:09.808  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:22:25.588  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:22:27.252  - info: admin.0 (7621) ==> Connected system.user.admin from ::ffff:192.168.178.22
                                  2026-05-01 15:22:40.914  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:22:56.201  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:23:05.864  - warn: backitup.0 (7799) [iobroker/clean] No older backup files are deleted, because this backup was started manually
                                  2026-05-01 15:23:11.495  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:23:25.210  - info: web.0 (8129) <== Disconnect system.user.admin from ::ffff:192.168.178.22
                                  2026-05-01 15:23:26.085  - info: web.0 (8129) ==> Connected system.user.admin from ::ffff:192.168.178.22
                                  2026-05-01 15:23:26.781  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:23:42.086  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:23:57.350  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2026-05-01 15:24:12.629  - info: shelly.0 (7994) [authEnabled] 192.168.178.101 (shellyplus2pm / shellyplus2pm-a0dd6cbe021c / shellyplus2pm#a0dd6cbe021c#1): This device is not protected via restricted login (see adapter documentation for details)
                                  • A Accuface
                                    Erledigt:
                                    ```bash
                                    Script v.2026-01-31
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                    Current issues:
                                                  NTP service: active
                                              RTC in local TZ: no
                                    Bernd
                                    HOME=/home/Bernd
                                    iobroker
                                    HOME=/home/iobroker
                                    Display-Manager:
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                    Swap:           209M          0B        209M
                                             8062 M total memory
                                             3190 M used memory
                                             2903 M free memory
                                              297 M buffer memory
                                             1782 M swap cache
                                              199 M total swap
                                                0 M used swap
                                              199 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    3.6G    /var/
                                    2.8G    /var/log
                                    408M    /var/cache
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.9.7
                                    /usr/bin/npx            10.9.7
                                    nodejs:
                                      Version table:
                                         20.19.2+dfsg-1 500
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.7.22
                                    javascript:     9.0.18
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        14320
                                    States:         11737
                                    @Accuface
                                    Dann ist jetzt ja deine Basis auf einem aktuellen Stand und du kannst weiter machen.
                                    rpi2-Adapter z. B. noch updaten.
                                      @Accuface
                                      Accuface
                                      @Accuface
                                      den nutz ich aktuell eh nicht und der interessiert mich gerade auch ned wirklich.
                                      der SA muss wieder funktionieren.
                                      Also die Pfade in der VIS passen, der SA spuckt keine werte, bzw nur 0 aus.
                                      und was heisst weiter machen, womit denn?
                                      • A Accuface
                                        @Accuface
                                        @Accuface sagte:
                                        Dann damit deine verwendeten Adapter in Betrieb zu nehmen.
                                        Und schmeiß nicht verwendete Adapter raus. Macht die Codebasis kleiner, macht das System stabiler und leichter zu unterhalten.
                                          @Accuface sagte:
                                          Accuface
                                          @Accuface sagte:
                                          Die laufen doch jetzt soweit alle, bis auf den SA.
                                          ja müsste ich mal machen tatsächlich
