  4. Test Adapter Pylontech v0.0.10
226 Beiträge 32 Kommentatoren 56.3k Aufrufe 26 Beobachtet
  • T tasuanetrukiat
    Ah, you mean this small note?:
    Please note: The RS485 and Canbus interfaces are not for this adapter. They speak a different language.
    Ok, maybe RS485 is modbus. By the way I had a technical onsite support at my system who has read the status with a cable to the RS485 connector here. They had used the normal own software to check the status of all cells.
    Maybe there is a hidden RS232 on the port as well or it is possible to switch to a cli like interface.
    I would like to check it. Any idea?
    Maybe it is possible to add support for low voltage force towers if the protocol becomes more clear.
    PLCHome 0P Offline
    PLCHome 0P Offline
    PLCHome 0
    schrieb am zuletzt editiert von PLCHome 0
    #214
    @tasuanetrukiat sagte:
    Yes, RTFM would have solved that issue.
    https://github.com/PLCHome/ioBroker.pylontech/blob/master/media/H2.JPG
      tasuanetrukiat
      schrieb am zuletzt editiert von tasuanetrukiat
      #215
      Ok, I checked my Force-L1 Controller today an found out the connector is labeled as RS485/RS232 against described in my manual which is only shown RS485.
      So looks like RS232 is connected on Pin 3 + 6 where RS485 is on Pin 7 + 8.
      By the way where ist GND for RS232? It is not described in the manual which I found shortly.
        tasuanetrukiat
        #216
        Hello, GND is on Pin 2. I used now a really short Force-L1 CAN Cable to connect a USR-DR162 with the Force-L1 Controllers RS485/RS232 Port.
        The USR-DR162 Serial Setting was left as is with 115200 Baud at 8N1 and CTSRTS = Off, Pack Interval = 20, Pack Size = 1400, Com Heart = OFF, ModBus Enabled = OFF.
        With this settings a telnet connection was possible and I got the PYLON prompt.
        But the enabling all possible request types in the pylontech instance settings results in an error.
        So I enabled on by one type and got the result that only without 'Download battery current data' enabled the adaptor is working without problems.
        If I reenable the setting I get an error in the log and the Instance Icon becomes only yellow and than red:
        By the way without this setting it is working.
          tasuanetrukiat
          #217
          Was noch ein wenig komisch aussieht sind die Namen der Batterien. Des weiteren werden nur beim ersten Modul, also bei den ersten 15 Zellen mehr Werte abgefragt:
          Hier mal die Stats aus der Console:
          pylon>+EVENT=SOCKA_OFF
          Unknown command '+EVENT=SOCKA_OFF' - try 'help'
          pylon>
          pylon>bat 1
          bat 1
          Battery  Volt     Curr     Tempr    Base State   Volt. State  Curr. State  Temp. State  SOC          Coulomb      BAL
          0        3331     340      14000    Charge       Normal       Normal       Normal        87%      64085 mAH   N
          1        3332     340      14000    Charge       Normal       Normal       Normal        87%      64064 mAH   N
          2        3332     340      14000    Charge       Normal       Normal       Normal        86%      63176 mAH   N
          3        3332     340      14000    Charge       Normal       Normal       Normal        87%      64064 mAH   N
          4        3331     340      14000    Charge       Normal       Normal       Normal        87%      64083 mAH   N
          5        3331     340      14000    Charge       Normal       Normal       Normal        87%      64064 mAH   N
          6        3331     340      14000    Charge       Normal       Normal       Normal        86%      63176 mAH   N
          7        3331     340      14000    Charge       Normal       Normal       Normal        87%      64064 mAH   N
          8        3331     340      14000    Charge       Normal       Normal       Normal        87%      64085 mAH   N
          9        3331     340      14000    Charge       Normal       Normal       Normal        87%      64076 mAH   N
          10       3331     340      14000    Charge       Normal       Normal       Normal        87%      64085 mAH   N
          11       3331     340      14000    Charge       Normal       Normal       Normal        87%      64085 mAH   N
          12       3331     340      14000    Charge       Normal       Normal       Normal        87%      64083 mAH   N
          13       3331     340      14000    Charge       Normal       Normal       Normal        87%      64085 mAH   N
          14       3332     340      14000    Charge       Normal       Normal       Normal        87%      64064 mAH   N
          Command completed successfully
          pylon>
          pylon>bat 2
          bat 2
          0        3329     312      13000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          1        3329     312      13000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          2        3330     312      13000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          3        3331     312      13000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          4        3331     312      13000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          5        3329     312      13000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          6        3330     312      13000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          7        3329     312      13000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          8        3331     312      14000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          9        3331     312      14000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          10       3332     312      14000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          11       3332     312      14000    Charge       Normal       Normal       Normal        87%      64249 mAH   N
          12       3331     312      14000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          13       3331     312      14000    Charge       Normal       Normal       Normal        89%      65540 mAH   N
          14       3331     312      14000    Charge       Normal       Normal       Normal        89%      65645 mAH   N
          pylon>
          • PLCHome 0P Offline
            PLCHome 0P Offline
            PLCHome 0
            #218
            Das muss ich mir anschauen. Kannst du vielleicht das Skript build/moc/fetchCmdNet.js oder fetchCmdSerial.js für die Befehle ausführen? Und die Dateien als Zip-Datei zur Verfügung stellen?
            bat, bmuinfo 0, bmuinfo 1 bis n, help, info, log, pwr, soh, stat, sysinfo, time, unit
            Also Force war auf eien H2 zugeschnitten. Vielleicht hast du ja glück das deiner als US läuft.
              tasuanetrukiat
              #219
              bmuinfo und sysinfo kennt die Konsole nicht. Hier die Befehle die gehen sollten:
              pylon>help
              help
              Local command:
              bat Battery data show - bat [pwr][index]
              cmdquit Quit the Console Mode
              shut Shut down - shut
              trst Test Soft Reset - trst
              data History data load - data [event/history/misc][item]
              datalist Show recorded data - datalist [event/history/misc][item/bat][batnun][volt/curr/temp/coul][item]
              disp Display Info at regular intervals - disp [(pwrs pwrNo)/val]/[(bats batNo)/volt/curr/temp]
              getpwr Get power Info - getpwr
              help Help [cmd]
              info Device infomation - info
              log Log information show - log
              login Login Admin mode - login [password]
              logout user mode - logout
              pwr Power data show - pwr
              unit Unit data show - unit
              sys system data show - sys
              pwrsys System Info - sysinfo [pwr]
              Ich habe deinem Tipp mal auf US umgestellt. Die Instanz lässt sich nun mit allen Häckchen starten und der Adapter bricht auch nicht ab. In Objekts machen die Einträge nun auch Sinn. Vielleicht ist die Auswahl US / Force nicht ganz richtig und man muss eher LV (48V Parallel) zu HV (Seriell) unterscheiden 😁
              Was die beiden nicht funktionierenden Befehl genau bewirken weiss ich nicht. Es gibt aber zwei andere die noch vielleicht interessante Werte zeigen: pwrsys und data bzw. datalist. Oder werden die schon abgefragt?
                tasuanetrukiat
                #220
                Mir ist gerade noch was aufgefallen, das das Balancing bei den battery## Werten nicht als eigner Wert auftaucht sondern im coulomb angehängt ist:
                Beim Bat Befehl steht es hinter der Coulomb Spalte als BAL:
                bat
                0        3370     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                1        3365     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                2        3364     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                3        3365     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                4        3367     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                5        3365     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                6        3363     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                7        3365     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                8        3366     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                9        3365     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                10       3369     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                11       3372     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                12       3366     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                13       3366     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                14       3365     3368     14000    Charge       Normal       Normal       Normal        89%      65662 mAH   N
                  PLCHome 0P Offline
                  PLCHome 0
                  #221
                  Ja, schaue ich mir an. Ich brauche trotzdem die Daten als Zip. Ich habe nicht nur einmal Probleme mit abgeschnittenen Leerzeichen und Zeilenenden gehabt.
                    tasuanetrukiat
                    #222
                    Hallo, ich würde ja gerne eine zip-Datei generieren aber wie komme ich da nun ran? Gibt es eine Beschreibung irgendwo wie ich die Daten zusammen sammel?
                    build/moc/fetchCmdNet.js würde ich ja ausführen aber muss das nicht im iobroker Context geschehen? Woher bekommt das Script sonst seine Verbindungsparameter?
                    Und wie geschrieben läuft iob bei mir im Container. Da finde ich nicht mal das skript drin, habe aber ggf. einfach was übersehen?
                    Oder reicht es das Script einfach mit runter zu laden und auf einen beliebigen Rechner auszuführen?
                      tasuanetrukiat
                      #223
                      Ich habe mal gerate was zu tun wäre bin aber nicht weit gekommen:
                      user@host:~/test/pylontech$ git clone https://github.com/PLCHome/ioBroker.pylontech.git
                      Klone nach 'ioBroker.pylontech' ...
                      remote: Enumerating objects: 971, done.
                      remote: Counting objects: 100% (31/31), done.
                      remote: Compressing objects: 100% (24/24), done.
                      remote: Total 971 (delta 14), reused 14 (delta 6), pack-reused 940 (from 1)
                      Empfange Objekte: 100% (971/971), 888.60 KiB | 6.30 MiB/s, fertig.
                      Löse Unterschiede auf: 100% (684/684), fertig.
                      user@host:~/test/pylontech$ cd ioBroker.pylontech/build/moc/
                      user@host:~/test/pylontech/ioBroker.pylontech/build/moc$ node fetchCmdNet.js 192.168.2.44 8899 help
                      internal/modules/cjs/loader.js:818
                        throw err;
                      Error: Cannot find module 'fs/promises'
                      Require stack:
                      - /home/user/test/pylontech/ioBroker.pylontech/build/moc/fetchCmdNet.js
                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                          at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                          at Module.require (internal/modules/cjs/loader.js:887:19)
                          at require (internal/modules/cjs/helpers.js:74:18)
                          at Object.<anonymous> (/home/user/test/pylontech/ioBroker.pylontech/build/moc/fetchCmdNet.js:24:23)
                          at Module._compile (internal/modules/cjs/loader.js:999:30)
                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                          at Module.load (internal/modules/cjs/loader.js:863:32)
                          at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: [
                          '/home/user/test/pylontech/ioBroker.pylontech/build/moc/fetchCmdNet.js'
                        tasuanetrukiat
                        #224
                        Ok, mein Debian ist zu alt. Wird mal Zeit für ein Upgrade. Ich bekomme damit nur eine inkompatible Version mit apt installiert.
                        Ich konnte aber die Problematische Zeile const fs = require('fs/promises'); erfolgreich zu const fs = require('fs').promises; ändern und damit das script zum laufen bewegen. Achja ich musste noch ein npm install ausführen. Wusste ich auch nicht.
                        Das Skript erzeugt von sich aus keine zip-Datei. Daher rate ich noch mal:
                        Ich führe aus:
                        user@host:~/test/pylontech/ioBroker.pylontech/build/moc$ for i in bat bmuinfo\ 0 bmuinfo\ 2 bmuinfo\ 2 help info log pwr soh stat sysinfo time unit ; do node fetchCmdNet.js 192.168.2.44 8899 "${i}" >"${i}" 2>&1 ; zip -u -m fetchCmdNet-output.zip "${i}" ; done
                        Da ich danach doch noch die txt-dateien gefunden habe packe ich die einfach mit in die Zip-Datei.
                        • H Offline
                          Helge_Muc
                          #225
                          erstmal vielen Dank für den Adapter.
                          Ich betreibe ein PowerCube H1 - Sprich SC1000-100 mit 14xH48050 Packs.
                          Die Daten kommen, sind aber bissel verschoben und nicht immer 100% schlüssig (das kann aber an mir liegen).
                          Ich hab mal die JSON der Objekte mit angehängt - bissel groß - sind in Summe 210 Zellen.
                          pylontech.json
                          Helge
                            andibr
                            schrieb am zuletzt editiert von andibr
                            #226
                            Bin gerade auf diesen tollen Adapter gestossen und es direkt mal ausgetestet. Mein 8x Pytes 48100R C16 werden direkt erkannt und auch jedes einzelne Zelle in den Datenpunkten erstellt.
                            Nur steht bei jeder Zeile der Wert (null) drin, was mache ich falsch?
                            installiert ist:
                            node-js 22.23.2
                            npm 10.9.8
                            Adapter 0.0.10
                            Edit:
                            Bei jeder Zeile kommt da:
                            pylontech.0	2026-08-06 17:08:24.084	warn	State "pylontech.0.ES1003338P119837.battery15.volt" has no existing object, this might lead to an error in future versions
                            pylontech.0	2026-08-06 17:08:24.084	warn	State "pylontech.0.ES1003338P119837.battery14.coulomb" has no existing object, this might lead to an error in future versions
                            pylontech.0	2026-08-06 17:08:24.084	warn	State "pylontech.0.ES1003338P119837.battery14.curr_state" has no existing object, this might lead to an error in future versions
                            Ich gehe mal davon aus, das Pytes BMS möchte gerne anderst gefragt werden, aber genau da setzen meine Kentnisse aus.
                            Edit: 07.08.26 11:00
                            Mittels Minicom (auf der Konsole des Iobroker-Containers) konnte ich folgendes ermitteln:
                            Welcome to minicom 2.10
                            OPTIONS: I18n
                            Port /dev/ttyUSB1, 17:08:19 [U]
                            Press CTRL-A Z for help on special keys
                            PYTES_debug>bat 1
                            Battery  Volt     Tempr    Base State   Volt. State  Curr. State  Temp. State  Coulomb
                            0        3470     30000    Charge       Normal       Normal       Normal        97%      95920 mAH
                            1        3471     30000    Charge       Normal       Normal       Normal        97%      96084 mAH
                            2        3469     30000    Charge       Normal       Normal       Normal        97%      96249 mAH
                            3        3473     30000    Charge       Normal       Normal       Normal        97%      96414 mAH
                            4        3460     30000    Charge       Normal       Normal       Normal        95%      94283 mAH
                            5        3467     30000    Charge       Normal       Normal       Normal        97%      96002 mAH
                            6        3466     30000    Charge       Normal       Normal       Normal        97%      96578 mAH
                            7        3469     30000    Charge       Normal       Normal       Normal        97%      96002 mAH
                            8        3459     30000    Charge       Normal       Normal       Normal        95%      94142 mAH
                            9        3472     30000    Charge       Normal       Normal       Normal        97%      96249 mAH
                            10       3464     29000    Charge       Normal       Normal       Normal        96%      94904 mAH
                            11       3472     29000    Charge       Normal       Normal       Normal        97%      96414 mAH
                            12       3461     29000    Charge       Normal       Normal       Normal        95%      94424 mAH
                            13       3457     29000    Charge       Normal       Normal       Normal        97%      96167 mAH
                            14       3462     29000    Charge       Normal       Normal       Normal        95%      94565 mAH
                            15       3460     29000    Charge       Normal       Normal       Normal        95%      94706 mAH
                            PYTES_debug>bat 2
                            Das heisst eigentlich es würde alles funktionieren, nur der Adapter macht entweder die Abfrage anderst, oder sortiert die erhaltenen Daten nicht richtig ein?
