  4. ...nicht in offiziellem Repo
  5. Aura – Modernes Dashboard für ioBroker (Beta-Tester gesucht)
    6.3k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
352 Beiträge 29 Kommentatoren 38.8k Aufrufe 39 Beobachtet
  • mcm1957M Online
    mcm1957M Online
    mcm1957
    Leider ist auch dieser Adapter wider von AI (artificial ingorance ?) geprägt. Bitte sag der der dämlichen Claude AI dass sie sich merken soll was sie schon 100 mal gesagt bekommen hat:
    Das ioBroker Standard Environment ist zu verwenden.
    Bitte lesen: https://github.com/Jey-Cee/iobroker-ai-developer-guide
    ERRORS:
    ❗ [E0033] @iobroker/adapter-core 3.2.2 specified. 3.2.3 is required as minimum, 3.3.2 (or newer) is current. Please update dependencies at package.json
    ❗ [E0036] @iobroker/testing 4.1.3 specified. 5.2.2 is required as minimum, 5.2.2 (or newer) is current. Please update devDependencies at package.json
    ❗ [E1012] extIcon must be the same as an icon but with github path.
    ❗ [E1057] js-controller 5.0.19 listed as dependency but 6.0.11 is required as minimum. Please update dependency at io-package.json.
    ❗ [E1105] io-package.json schema validation error: Missing required property "platform" in /common
    ❗ [E2001] Bluefox was not found as collaborator on npm. Please execute in adapter directory: npm owner add bluefox iobroker.aura or invite him at npmjs.com
    ❗ [E3002] Workflow file "/.github/workflows/test-and-release.yml" not found. Please create it for standard CI/CD testing.
    ❗ [E6003] NO "## Changelog" found in README.md
    ❗ [E6007] Future year (8082) found in copyright at README.md. Please use "Copyright (c) 2026 Hermann Dering aura@dering-online.de" at start of LICENSE section.
    ❗ [E6012] README.md suggests to install using direct npm commands. Adapters must not be installed using direct npm commands. Please remove these instructions.
    ❗ [E6015] README.md must use English language only but appears to contain German text (detected: "auf das GitHub-Icon"). Please remove or translate.
    ❗ [E8001] No repository about text found. Please go to "https://github.com/hdering/iobroker.aura", press the settings button beside the about title and add the description.
    ❗ [E8002] No topics found in the repository. Please go to "https://github.com/hdering/iobroker.aura", press the settings button beside the about title and add some topics.
    WARNINGS:
    👀 [W0028] Minimum node.js version 20 recommended. Please adapt "{'engines' : { 'node' >= '18' } }" to "{'engines' : { 'node' >= '20' } }" at package.json.
    👀 [W1104] allowInit is only used with scheduled adapters and should be removed
    👀 [W4001] Cannot find "aura" in latest repository. Please ignore if PR to add adapter to repositories already exists.
    👀 [W5034] Files with conflicting extensions found in directory "/": /test-socket.cjs, /test-socket.mjs - Only one JavaScript/TypeScript file extension (.ts, .js, .cjs, or .mjs) should be used per file name.
    👀 [W5042] Package "lucide-react" is used in source files but not found in dependencies of package.json. Dependency might be missing.
    👀 [W5042] Package "react" is used in source files but not found in dependencies of package.json. Dependency might be missing.
    👀 [W5042] Package "react-resizable" is used in source files but not found in dependencies of package.json. Dependency might be missing.
    👀 [W5042] Package "socket.io-client" is used in source files but not found in dependencies of package.json. Dependency might be missing.
    👀 [W5042] Package "zustand" is used in source files but not found in dependencies of package.json. Dependency might be missing.
    SUGGESTIONS:
    📌 [S0062] Consider adding and using package "@alcalzone/release-script".
    📌 [S0062] Consider adding and using package "@alcalzone/release-script-plugin-iobroker".
    📌 [S0062] Consider adding and using package "@alcalzone/release-script-plugin-license".
    📌 [S0062] Consider adding and using package "@alcalzone/release-script-plugin-manual-review".
    📌 [S0062] Consider adding and using package "@iobroker/adapter-dev".
    📌 [S0062] Consider adding and using package "@iobroker/eslint-config".
    📌 [S1039] Please evaluate whether adapter can be modified to support compact mode.
    📌 [S1084] "common.singleton" detected for non onlyWWW adapter. Is this really desired?
    📌 [S4036] Consider adding .vscode/settings.json file with JSON schema definitions for better development experience with Visual Studio Code.
    📌 [S5043] Package "http" is a built-in Node.js module. Please use "node:http" instead.
    📌 [S5043] Package "https" is a built-in Node.js module. Please use "node:https" instead.
    📌 [S5043] Package "util" is a built-in Node.js module. Please use "node:util" instead.
    📌 [S8901] Dependabot configuration file ".github/dependabot.yml" not found. Consider adding dependabot to keep dependencies up to date.
    📌 [S9006] .commitinfo file should be excluded by .gitignore, please add a line with text ".commitinfo" to .gitignore
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • mcm1957M Online
      mcm1957M Online
      mcm1957
      ⚠ ACHTUNG - unvollständiger Adapter⚠
      Dieser Adapter ist derzeit offensichtlich noch im Zustand PRE-ALPHA. Er dürfte mittels KI ohne Verwendung der Standardtools entwickelt worden sein - es fehlen derzeit zahlreiche Standardkomponenten eines ordnungsgemäßen Adapters. Insbesondere sind die verpflichtenden Standardtests nicht vorhanden oder werden nicht erfolgreich ausgeführt.
      Von einer Installation muss derzeit für produktive Zecke und für Benutzer die sich nicht als 'Early - Tester' einstufen explizit abgeraten werden.
        dering
        @mcu @mcm1957
        Vielen Dank für die Hinweise. Genau deswegen melde ich mich hier, damit ich alle Anforderungen erfülle :).
        Ich melde mich wieder, wenn alles "grün" ist.
        Wer einen Kaffee spendieren will: https://paypal.me/HermannDering
        sigi234S mcm1957M 2 Antworten Letzte Antwort
        • D dering
          @mcu @mcm1957
          sigi234S Online
          sigi234S Online
          @dering sagte:
          Ja, und dann erst werde ich Ihn testen.
          • D dering
            @mcu @mcm1957
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @dering sagte:
            @mcu @mcm1957
            SUPER und Danke für die Rückmeldung.
            Sorry wenn ich so scharf reagiere - die "liebe" Claude bringt mich auf 100. Nicht weil AI Entwicklung nicht erwünscht ist - das ist an sich voll OK und benutzen die meisten. Aber sie wirft massenweise halbgares Zeug raus und lernft änlich langsam wie ein 100jähriger die Bedienung eines Quantencomputers...
            Bitte daher nicht persönlich nehmen. Ich sag explizit DANKE dass du hier mitarbeitest.
            Bitte frag wenn was unklar ist oder du wo hilfe brauchst - gern auch Menschen :-). Und meld dich gern auch in unseren Entwicklerchannels auf Telegramm und Discord - invites auf www.iobroker.dev.
            (Und optisch sieht die VIS toll aus !)
            • mcm1957M mcm1957
              @dering sagte:
              @mcu @mcm1957
              dering
              @mcm1957 alles gut :).
              Ich bekomme nur noch 2 Fehler:
              [E2001] Bluefox was not found as collaborator on npm. Please execute in adapter directory: "npm owner add bluefox iobroker.aura" or invite him at npmjs.com
              Ich hoffe das extIcon ist nur eine Cache Sache.
              Beim anderen habe ich Bluefox als maintainer eingeladen. Da muss er wohl erstmal bestätigen.
              • mcm1957M Online
                mcm1957M Online
                mcm1957
                Nö exticon ist eine Konfiguration in io.package.json. Schau am einfachsten bei anderen Adaotern rein dann solltest du es erkennen.
                Bei E2001 musst ein wenig warten. Ist kein Problem nur blocking für Latest. Aber da mach dir mal keinen Stress, er akzeotiert das normalerweise in wenigen Stunden bis Tagen.
                DANKE für deine rasche Reaktion. Wenn du eine Idee hats wie man der dämlichen Claude beibringen kann die Grundstruktur sauber zu beachten, dann lass uns das wissen. GgF auch in einem eigenen Topic, weil es ja nicht direkt deinen Adapter beträfe.
                • D dering
                  ich möchte euch heute mein neues Projekt vorstellen: Aura – ein modernes Visualisierungs-Dashboard für ioBroker.
                  Warum ein neues Dashboard?
                  Ich war treuer Nutzer von Jarvis, jedoch wird Jarvis scheinbar nicht mehr aktiv weiterentwickelt, und die klassische VIS ist mir persönlich zu statisch und zu aufwändig in der Konfiguration. Ich wollte etwas, das schnell eingerichtet ist, modern aussieht und auf dem Tablet genauso gut funktioniert wie im Browser.
                  Aura ist komplett neu entwickelt – KI-gestützt mit Claude von Anthropic. Das hat die Entwicklungsgeschwindigkeit deutlich erhöht, aber natürlich steckt das Projekt noch in den Kinderschuhen.
                  Was kann Aura?
                  • Flexibles Grid-Layout mit Drag & Drop
                  • Mehrere Tabs / Seiten
                  • Dark Mode, Light Mode und diverse Themes (inkl. Catppuccin, Apple Liquid Glass)
                  • Widgets:
                    • Schalter, Dimmer, Thermostat
                    • Gauge, Füllstandsanzeige (Tank/Wasser/Gas)
                    • Diagramm (EChart, Linien/Balken/Pie)
                    • Kalender (iCal/Google Calendar)
                    • Wetter
                    • Uhr
                    • Kamera / iFrame
                    • EVCC (Wallbox / Solar)
                    • Müllabfuhr-Anzeige
                    • Gruppe (verschachtelte Widgets)
                    • und weitere...
                  • Widget-Konfiguration direkt im Browser, kein YAML, kein JSON-Editieren
                  • Admin-Interface für Layouts, Themes und Einstellungen
                  Initiale Installation
                  Noch nicht im offiziellen ioBroker-Repository. Manuell über die URL im ioBroker Admin:
                  Admin → Adapter → Von URL installieren (GitHub-Icon oben rechts) → folgende URL eingeben:
                  Updates
                  Updates sollten über NPM installiert werden:
                  Admin -> Adapters -> expert mode aktivieren -> Install from Github URL -> danach From NPM wählen
                  Den aktuellen Stand und alle Änderungen findet ihr hier:
                  👉 https://github.com/hdering/iobroker.aura/releases
                  Was ich suche
                  Beta-Tester, die das Dashboard ausprobieren und Feedback geben. Speziell interessiert mich:
                  • Welche Widgets fehlen euch?
                  • Was funktioniert nicht wie erwartet?
                  • Wie verhält es sich auf euren Geräten (Tablet, Smartphone, PC)?
                  Bugs und Feature-Wünsche bitte hier melden:
                  👉 https://github.com/hdering/iobroker.aura/issues
                  Gerne direkt als GitHub Issue – so kann ich alles strukturiert nachverfolgen. Wer keinen GitHub-Account hat, kann auch hier im Thread antworten.
                  Hinweis
                  Das Projekt ist ein Hobby-Projekt im frühen Stadium. Es kann noch zu Fehlern kommen, und die Konfigurationsstruktur kann sich noch ändern. Produktiver Einsatz auf eigene Verantwortung.
                  Über jedes Feedback freue ich mich!
                  Viele Grüße,
                  hdering
                  Ein paar Screenshots:
                  Frontend
                  Backend:
                  sigi234S Online
                  sigi234S Online
                  @dering
                  So, mal getestet.
                  Installation ok, Admin gestartet.
                  Leider werden keine Geräte geladen. Weder Automatisch noch manuel-
                  Plattform: Windows
                  RAM: 15.9 GB
                  Node.js: v22.22.2
                  NPM: 10.9.7
                  Admin: 7.8.20
                  JS: 7.1.1
                  EDIT:
                  Denke mal weil IOB auf
                  http://localhost:8082/aura/#/admin
                  läuft.
                  IOB ist auch nicht verbunden.
                  EDIT:
                  Erledigt, Socketio auf 8084 gestellt und es läuft.
                  • D dering
                    Was kann Aura?
                    • Widgets:
                      • Wetter
                      • Uhr
                      • Kamera / iFrame
                      • und weitere...
                    Updates
                    Was ich suche
                    Hinweis
                    Viele Grüße,
                    hdering
                    Frontend
                    Backend:
                    sigi234S Online
                    sigi234S Online
                    @dering sagte:
                    Also, sehr cool gemacht! 👍
                      dering
                      Ich kämpfe noch mit dem Deployment Prozess und dass der iobroker checker zufrieden ist. Danach gehe ich auf eure Punkte ein.
                      • mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        DANKE dass du deine Zeit für den Adapetr einsetzt.
                        Wie schon im PR angemerkt, organisiere bitte deine Sourcen passend. Im 'src' Verzeichnis sollten sich die Sourcen für einen Adapter, genauer das Backend bzw. für den Code der am ioBroker Host läuft - befinden. Da dein Adapter anscheinend keinen Backendcode hat, bitte deine Sourcen für den Browsercode NICHT in src abelegen sondern z.B. wie bei vis-2 in src-vis. Aoder alternativ auch unter www (wenn es nur statischer Code wäre).
                        Auch dürfte der js-controller sich verwirrt zeigen wenn in package.json main:main.tsx steht und das gar kein Adaptercode ist den er starten soll...
                        Da ich sel bst keine vis / react / UI Entwicklung betreibe kann ich leider die optimale Verzeichnisstrukut für deine Anwendung nicht sagen. Entweder kann dir hier ein UI Entwickler helfen (@bluefox , @oliverio ...?) oder meld dich in useren Developmentchannles auf telegramm / discord (Invites auf ww.iobroker.dev). Die standard Verzeichnisse für Adapter -Backendcode jedenfalls bitte nicht verwenden - das kann nur zu Problemen führen.
                        • D dering
                          Was kann Aura?
                          • Widgets:
                            • Wetter
                            • Uhr
                            • Kamera / iFrame
                            • und weitere...
                          Updates
                          Was ich suche
                          Hinweis
                          Viele Grüße,
                          hdering
                          Frontend
                          Backend:
                          flkontaktF Online
                          flkontaktF Online
                          flkontakt
                          @dering sagte:
                          Auch auf die Gefahr hin, dass ich mich hier blamiere: Adapter ist installiert, die ersten Widgets angelegt, alles wunderbar. Zugriff aber nur per PC, auf Handy oder Tablet kommt die Meldung "Getrennt" im Dashboard. Was mache ich falsch? Danke!
                          P.S.: sieht schon mit den ersten Ergebnissen gut aus, freue mich auf eine hoffentliche Weiterentwicklung!
                          Mod-Edit: Vollzitat gekürzt
                          • mcm1957M mcm1957
                            ERRORS:
                            WARNINGS:
                            SUGGESTIONS:
                            dering
                            @mcm1957 sagte:
                            für claude kann man eine claude.md anlegen im Projektverzeichnis, dann folgt er immer diesen Anweisungen. Meine sieht jetzt so aus: https://github.com/hdering/ioBroker.aura/blob/main/CLAUDE.md
                            • D dering
                              @mcm1957 sagte:
                              MCU
                              @dering Wo sollen die Verbessungsvorschläge und Fehler hin? ioBroker oder github (sinnvoller)?
                              • M MCU
                                dering
                                @MCU ich hätte gesagt GitHub ist am besten. Da kann man auch direkt Flaggen als Bug, Feature usw.
                                • D dering
                                  Was kann Aura?
                                  • Widgets:
                                    • Wetter
                                    • Uhr
                                    • Kamera / iFrame
                                    • und weitere...
                                  Updates
                                  Was ich suche
                                  Hinweis
                                  Viele Grüße,
                                  hdering
                                  Frontend
                                  Backend:
                                  sigi234S Online
                                  sigi234S Online
                                  @dering
                                  Wird schon, werde dennächst Wünsche und ev. Fehler melden.
                                  Hier oder Git?
                                    dering
                                    Mit KI kriegen wir eine absolut krasse Geschwindigkeit hin
                                    • sigi234S sigi234
                                      @dering
                                      Hier oder Git?
                                      dering
                                      @sigi234 du bist ja ein Hammer :)
                                      Aber Strukturen können sich noch ändern, also Vorsicht. Ist dann aber auch interessant zu sehen, wenn ein Update vielleicht etwas bei dir zerstört
                                      • D dering
                                        sigi234S Online
                                        sigi234S Online
                                        @dering sagte:
                                        Jupp, das ist mir klar, aber ich teste mal alles durch. 😀
                                        • sigi234S sigi234
                                          @dering sagte:
                                          MCU
                                          Hier eine kleine Übersicht für aura VIS
                                          https://mcuiobroker.gitbook.io/iobroker-tipps/tipps/aura-visualisierung
