  4. [Aufruf] Dringender Test sql 1.6.4
203 Beiträge 15 Kommentatoren 65.4k Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    #182
    was sollen mir die Infos sagen:
    sql.0	2018-02-17 17:15:43.140	info	init timed Relog: disable relog because state not set so far for hm-rpc.0.MEQ0381249.0.AES_KEY: null
    sql.0	2018-02-17 17:15:42.070	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104011.2.STATE: null
    sql.0	2018-02-17 17:15:31.123	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX2801001.1.STATE: null
    sql.0	2018-02-17 17:15:17.958	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104010.4.STATE: null
    sql.0	2018-02-17 17:15:16.586	info	init timed Relog: disable relog because state not set so far for hm-rpc.0.MEQ0381127.0.AES_KEY: null
    sql.0	2018-02-17 17:15:12.178	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX4000001.11.PRESS_SHORT: null
    sql.0	2018-02-17 17:15:12.023	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104007.2.STATE: null
    sql.0	2018-02-17 17:15:10.461	error	Please wait till next data record is logged and reload.
    sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.9.diesel.feed: Type empty. Need to write data first. Index = undefined
    sql.0	2018-02-17 17:15:10.460	error	Please wait till next data record is logged and reload.
    sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.6.diesel.feed: Type empty. Need to write data first. Index = undefined
    sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.5.diesel.feed: Type empty. Need to write data first. Index = undefined
    sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.2.diesel.feed: Type empty. Need to write data first. Index = undefined
    sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.1.diesel.feed: Type empty. Need to write data first. Index = undefined
    MfG
    Sissi
    1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
    • apollon77A Offline
      #183
      Die Meldungen sagen folgendes:
      Wenn Du für einen Datenpunkt das "gleiche Werte loggen nach x Sekunden" einschaltest verssucht der Adapter das auch zu tun wenn innerhalb der Zeit kein neuer Wert kam. Er sucht dann im Zweifel dafür den zuletzt gespeicherten Wert raus.
      Wenn es aber keinen gibt - und bei einigen HM-States kann das durchaus passieren - und damit keinerlei "State-Wert" existiert dann kann er auch nichts loggen (NULL loggen macht da keinen Sinn weil es kein echter Wert wäre). Aus dem Grund wird das zeitliche "gleicher Wert loggen" temporär ausgeschaltet. Genau das sagt die Meldung.
      Falls für so einen State ein neuer Wert käme dann würde ab dann automatisch das "gleiche Werte loggen" wieder eingeschaltet werden.
      Zu der Frage wegen:
      Wenn das direkt nach dem Start des Adapters passiert, so kann es sein das deine Grafiken "zu schnell" waren.
      Beim Start des Adapters wird nach dem Verbindung und "Initialisierung" der Datenbanktabellen alle Datenpunkte, typen und Indizes ausgelesen und gespeichert. Ein "Index=undefined" wie in der Meldung oben könnte darauf hinweisen das die History-Daten abgefragt wurden BEVOR die Daten gelesen wurden. Das würde solche meldungen direkt nach dem Start erklären.
      Ich könnte jetzt was einbauen was das im Zweifel behebt und auch das bei getHistory vorher rausliesst … Nötig? :-)
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        #184
        Ich hab auch noch ein kleines Problem mit dem SQL Adapter 1.6.9.
        Situation:
        • Javascript: DP über Skript angelegt
        • Monitoring eingeschaltet -> SQL
        • Monitoring deaktiviert und dann den Datenpunkt gelöscht
        • neuen DP (Name geändert) über Skript angelegt
        • Monitoring aktiviert
        Nun wird das Log mit Errors vollgeschrieben, Beispiel:
        ql.0	2018-02-18 04:13:23.408	error	Cannot insert INSERT INTO `iobrokerng2`.ts_string (id, ts, val, ack, _from, q) VALUES(875, 1518923603385, 'CALL 2 Free', 0, 11, 0);: Error: ER_DUP_ENTRY: Duplicate entry '875-1518923603385' for key primary'
        Beim überfliegen der Fehlermeldungen würde ich sagen, es handelt sich durchgängig um die Duplicate entry Meldungen.
        Ich sehe den Zusammenhang zwar noch nicht. Kann es sein, dass die Zeit zwischen "Logging deaktivieren" und in den Objekten den Datenpunkt per Hand löschen, zu kurz war?
          #185
          Hm, wüsste nicht wie das zu „duplicate key“ führen sollte. Das ist an sich eher das zum gleichen zeitstempel schon ein wert in der dB existiert.
          Starte mal sql Adapter neu dann sollten pot Probleme vom manuellen löschen weg sein.
          Wenn immer noch duplicate key dann bräuchte ich Debug log.
          • sissiwupS Offline
            sissiwupS Offline
            sissiwup
            #186
            @apollon77:
            Zu der Frage wegen:
            Ich könnte jetzt was einbauen was das im Zweifel behebt und auch das bei getHistory vorher rausliesst … Nötig? :-) `
            nein. Ich habe jetzt die Punkt ausgenommen vom "gleicher Wert loggen"
            MfG
            Sissi
            • sissiwupS Offline
              sissiwupS Offline
              sissiwup
              #187
              Hallo.
              immer noch Duplicate Keys:
              *   2018-02-18 14:42:19 Alarmstatus: im Haus/Lüften
              *   2018-02-18 12:26:32 Alarmstatus: OFF
              *   2018-02-15 21:41:40 Alarmstatus: Haus alles gesichert
              Das Ereignis wird einmal in eine Variable geschrieben (siehe manuelles Protokoll), aber:
              In der Datenbank wird es 3x geschrieben:
              Was mich wundert ist, das er so lange braucht, bis er in die DB Schreibt.
              Und warum er überhaupt doppelt schreibt,
              a) ist entprellen auf 1 Sekunde gesetzt.
              b) sollen nur Änderungen geschrieben werden
              Wie ist denn der Ablauf des SQL-Adapters?
              Beim starten sollte er sich alle Werte für Datenpunkte + ts aus der DB holen. -> Wertecache
              Bei jeder Änderung sollte er
              Das muss Atomar sein:
              a) prüfen ob aktueller ts - Entprell-Intervall > letzter ts
              b) prüfen ob aktueller Wert <> alter Wert aus DB (bei nur Änderungen)
              c) Wenn er denn schreiben möchte, dann Cache aktualisieren
              Jetzt kann parallelisiert werden
              d) schreiben
              MfG
              Sissi
                #188
                Um die Duplicates zu verstehen bräuchte ich Debug Log bitte.
                Die genaue Logik zu beschreiben ist sehr umfangreich. Ganz grob (ohne spezielle Startlogik):
                Sämtliche Abarbeitung ist atomar weil nur ein Prozess läuft. Alles asynchrone bei JS wird am Ende auch nur sequenziell abgearbeitet.
                • Werteänderung kommt rein
                • prüfen ob je nach einstellungen geloggt werden soll oder nicht (vergleich mit letztem geloggten Wert)
                • Wenn nein, geskippten Wert intern zusätzlich sichern
                • Wenn ja, Wert sichern und diesen als Referenzwert speichern
                Wie die Duplicates zustandekommen weiss ich gerade nicht. Ich finde in deinem Screenshot nur nteressant das der timestamp in der Query und die in der Fehlermeldung unterschiedlich sind.
                Ich weiss aber das es sonderlogik für "Duplicates" gibt die das ganze mit +1ms Timestamp nochmals schreibt. Die ist schon ewig drin …
                Ingo
                • ruhr70R Offline
                  ruhr70R Offline
                  ruhr70
                  #189
                  @apollon77:
                  Starte mal sql Adapter neu dann sollten pot Probleme vom manuellen löschen weg sein. `
                  Nach einem Neustart des SQL-Adapters sind die Meldungen weg.
                  • sissiwupS Offline
                    sissiwupS Offline
                    sissiwup
                    #190
                    @apollon77:
                    Ingo `
                    Leider tritt der Fehler nur sporadisch auf und der SQL-Adapter schreibt im debug solche Massen an Logdaten, dass ich den nicht für längere Zeit aktivieren möchte.
                    Es ist scheinbar meistens eine Datenpunkt der vom JavaScript-Adapter ausgelöst/geschrieben wird.
                    MfG
                    Sissi
                      #191
                      Hm … dann ist es echt schwierig dem auf die Spur zu kommen ... :-(
                      Ist es immer der gleiche Datenpunkt?
                      Wenn ja vllt zweite ssql-Instanz in Debug Log aufsetzen in zweite DB schreiben und nur wenige Datenpunkte dort aktivieren (die halt wo sowas passiert). Ich kann es aktuell nicht nachvollziehen. Ich brauche aber die Info was passiert wenn es das erste mal passiert
                      • sissiwupS Offline
                        sissiwupS Offline
                        sissiwup
                        #192
                        @apollon77:
                        Wenn ja vllt zweite ssql-Instanz in Debug Log aufsetzen in zweite DB schreiben und nur wenige Datenpunkte dort aktivieren (die halt wo sowas passiert). Ich kann es aktuell nicht nachvollziehen. Ich brauche aber die Info was passiert wenn es das erste mal passiert `
                        War die Woche auf Dienstreise, werde das mal ausprobieren. Habe ja noch einen 2. Server der die DB schon installiert hat und vor sich hinläuft.
                        MfG
                        Sissi
                        • sissiwupS Offline
                          sissiwupS Offline
                          sissiwup
                          #193
                          Wie verhext. Reload im Browser und die Daten sind da.
                          Ist das vlt. ein Timeout?
                          MfG
                          Sissi
                            #194
                            welche sql.Adapter Version? Ehrlich noch die 1.6.4?
                            • sissiwupS Offline
                              sissiwupS Offline
                              sissiwup
                              #195
                              @sissiwup:
                              Ist das vlt. ein Timeout? `
                              1.7.1
                              MfG
                              Sissi
                                #196
                                Hm … wann vorher neu gestartet?
                                • sissiwupS Offline
                                  sissiwupS Offline
                                  sissiwup
                                  #197
                                  @apollon77:
                                  Hm … wann vorher neu gestartet? `
                                  Jede Nacht um 4:00.
                                  Ist aber der erste Aufruf von vis.
                                  MfG
                                  Sissi
                                  • sissiwupS Offline
                                    sissiwupS Offline
                                    sissiwup
                                    #198
                                    Folgendes Script:
                                    setState("vEreignissAkt","------------ NEUSTART ------------");
                                    führt beim Neustart zu:
                                     error: sql.0 Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1521256587638, '------------ NEUSTART ------------', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1521256587638' for key 'PRIMARY'
                                    2018-03-17 04:16:28
                                     error: sql.0 Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1521256587637, '------------ NEUSTART ------------', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1521256587637' for key 'PRIMARY'
                                    Das sieht so aus als würde er beim Neustart das Skript 2x starten?
                                    Alle anderen Datenpunkte mit den duplicates sind auch aus ähnlichen Aktion.
                                    Meistens ist der Datenpunkt aus dem yr.0 Adapter: yr.0.forecast.day0.pressure
                                    MfG
                                    Sissi
                                      #199
                                      Debug Log?
                                      • foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #200
                                        Habe auch mal eine Frage. Nutze den Adapter jetzt entsprechend mittels SQLite - läuft auch soweit. :) Nur beim Neustart loggt er mir haufenweise
                                        Cannot queue new requests, because more than 100
                                        Ich schätze mal, dass er den alten Status nicht mehr kennt und versucht sämtliche abonnierte DPs auf ein mal in die DB zu schreiben, was die SQLite DB überfordert? Kann ich dem irgendwie entgegenwirken?
                                        beste Grüße
                                        fox
                                        Videotutorials & mehr
                                          #201
                                          Ja das liegt an SQLite, Die kann immer nur eine Anfrage abarbeiten und ist daher (und auch aus anderen gründen) nur für nicht so viele Datenpunkte geeignet.
                                          Und ja der Start schreibt den aktuellen Wert überall rein.
                                          Du könntest mal versuchen das Limit höher zu setzen. Wenn Du das versuchen willst mach mal /opt/iobroker/node_modules/iobroker.sql/main.js in einem editor auf. und suche dort nach der Meldung. Gibts mehrfach. Ist immer so grob bei:
                                              if (!multiRequests) {
                                                  if (tasks.length > 100) {
                                                      adapter.log.error('Cannot queue new requests, because more than 100');
                                          Da musst Du das 100 mal durch was anderes tauschen, also 500 oder 1000 :-)
                                          Interessant wäre da vorher/nachher mal Speicherverbrauch und sowas zu vergleichen.
                                          Eine Alternative wäre noch bei SQLite dieses Initiale Schreiben zu verhindern … Denke das ist eher noch "the way to go".
                                          1.7.2 vom SQL Adapter vom Github schaltet WriteNulls bei SQLite automatisch aus
