  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    5.9k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 697.9k Aufrufe 117 Beobachtet
  • T tombox
    @Ro75 Teste mal v0.3.0
    wolfi913W Online
    wolfi913W Online
    wolfi913
    #1556
    @tombox sagte:
    Teste mal v0.3.0
    Bei mir startet der Adapter leider nicht mehr mit v0.3.0
    Instanz, Objektbaum und Adapter auch mal vorher vollständig gelöscht.
    Aber leider das gleiche Ergebnis
    2026-04-06 08:05:46.915 - info: host.iobroker iobroker add parcel --host iobroker
    2026-04-06 08:05:47.414 - info: host.iobroker iobroker host.iobroker create instance parcel
    2026-04-06 08:05:47.419 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.alive created
    2026-04-06 08:05:47.427 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.connected created
    2026-04-06 08:05:47.430 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.compactMode created
    2026-04-06 08:05:47.432 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.cpu created
    2026-04-06 08:05:47.434 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.cputime created
    2026-04-06 08:05:47.436 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.memHeapUsed created
    2026-04-06 08:05:47.438 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.memHeapTotal created
    2026-04-06 08:05:47.440 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.memRss created
    2026-04-06 08:05:47.443 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.uptime created
    2026-04-06 08:05:47.445 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.inputCount created
    2026-04-06 08:05:47.447 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.outputCount created
    2026-04-06 08:05:47.448 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.eventLoopLag created
    2026-04-06 08:05:47.450 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.sigKill created
    2026-04-06 08:05:47.452 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0.logLevel created
    2026-04-06 08:05:47.453 - info: host.iobroker iobroker host.iobroker object parcel.0.info created
    2026-04-06 08:05:47.455 - info: host.iobroker iobroker host.iobroker object parcel.0.allProviderJson created
    2026-04-06 08:05:47.456 - info: host.iobroker iobroker host.iobroker object parcel.0.allProviderObjects created
    2026-04-06 08:05:47.458 - info: host.iobroker iobroker host.iobroker object parcel.0.notDelivered created
    2026-04-06 08:05:47.462 - info: host.iobroker iobroker host.iobroker object parcel.0.notDeliveredCount created
    2026-04-06 08:05:47.464 - info: host.iobroker iobroker host.iobroker object parcel.0.inDelivery created
    2026-04-06 08:05:47.469 - info: host.iobroker iobroker host.iobroker object parcel.0.inDeliveryCountJson created
    2026-04-06 08:05:47.472 - info: host.iobroker iobroker host.iobroker object parcel.0.inDeliveryCount created
    2026-04-06 08:05:47.474 - info: host.iobroker iobroker host.iobroker object parcel.0.auth created
    2026-04-06 08:05:47.476 - info: host.iobroker iobroker host.iobroker object parcel.0.auth.cookie created
    2026-04-06 08:05:47.477 - info: host.iobroker iobroker host.iobroker object parcel.0.info.connection created
    2026-04-06 08:05:47.478 - info: host.iobroker iobroker host.iobroker object parcel.0.refresh created
    2026-04-06 08:05:47.480 - info: host.iobroker iobroker host.iobroker Set default value of parcel.0.notDelivered: {}
    2026-04-06 08:05:47.481 - info: host.iobroker iobroker host.iobroker Set default value of parcel.0.notDeliveredCount: 0
    2026-04-06 08:05:47.482 - info: host.iobroker iobroker host.iobroker Set default value of parcel.0.inDeliveryCountJson: {}
    2026-04-06 08:05:47.483 - info: host.iobroker iobroker host.iobroker Set default value of parcel.0.info.connection: false
    2026-04-06 08:05:47.485 - info: host.iobroker iobroker host.iobroker Set default value of parcel.0.refresh: false
    2026-04-06 08:05:47.488 - info: host.iobroker iobroker host.iobroker object system.adapter.parcel.0 created
    2026-04-06 08:05:48.502 - info: host.iobroker iobroker exit 0
    2026-04-06 08:05:50.004 - info: admin.0 (381) ==> Connected system.user.admin from ::ffff:192.168.2.130
    2026-04-06 08:05:50.806 - info: host.iobroker instance system.adapter.parcel.0 in version "0.3.0" started with pid 405645
    2026-04-06 08:05:51.526 - error: host.iobroker Caught by controller[0]: node:internal/modules/esm/module_job:450
    2026-04-06 08:05:51.526 - error: host.iobroker Caught by controller[0]: throw new ERR_REQUIRE_ASYNC_MODULE(filename, parentFilename);
    2026-04-06 08:05:51.526 - error: host.iobroker Caught by controller[0]: ^
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: Error [ERR_REQUIRE_ASYNC_MODULE]: require() cannot be used on an ESM graph with top-level await. Use import() instead. To see where the top-level await comes from, use --experimental-print-required-tla.
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: From /opt/iobroker/node_modules/jsdom/lib/jsdom/living/nodes/Document-impl.js
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: Requiring /opt/iobroker/node_modules/jsdom/node_modules/@asamuzakjp/dom-selector/src/index.js
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at ModuleJobSync.runSync (node:internal/modules/esm/module_job:450:13)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at ModuleLoader.importSyncForRequire (node:internal/modules/esm/loader:435:47)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at loadESMFromCJS (node:internal/modules/cjs/loader:1537:24)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1688:5)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12) {
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: code: 'ERR_REQUIRE_ASYNC_MODULE'
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: }
    2026-04-06 08:05:51.527 - error: host.iobroker Caught by controller[0]: Node.js v22.22.0
    2026-04-06 08:05:51.527 - error: host.iobroker instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2026-04-06 08:05:51.527 - info: host.iobroker Restart adapter system.adapter.parcel.0 because enabled
    • NashraN Offline
      NashraN Offline
      Nashra
      Most Active Forum Testing
      #1557
      Bei mir das selbe, alten deinstalliert, dann neuen
      host.ioBroker
      	2026-04-06 09:26:51.105	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: Node.js v22.22.2
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: }
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: code: 'ERR_REQUIRE_ASYNC_MODULE'
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12) {
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1838:10)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1687:5)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at loadESMFromCJS (node:internal/modules/cjs/loader:1536:24)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at ModuleLoader.importSyncForRequire (node:internal/modules/esm/loader:435:47)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: at ModuleJobSync.runSync (node:internal/modules/esm/module_job:450:13)
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: Requiring /opt/iobroker/node_modules/jsdom/node_modules/@asamuzakjp/dom-selector/src/index.js
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: From /opt/iobroker/node_modules/jsdom/lib/jsdom/living/nodes/Document-impl.js
      host.ioBroker
      	2026-04-06 09:26:51.105	error	Caught by controller[0]: Error [ERR_REQUIRE_ASYNC_MODULE]: require() cannot be used on an ESM graph with top-level await. Use import() instead. To see where the top-level await comes from, use --experimental-print-required-tla.
      Gruß Ralf
      • wolfi913W wolfi913
        @tombox sagte:
        Teste mal v0.3.0
        tombox
        #1558
        @wolfi913 mal die 0.3.1 testen
        wolfi913W 1 Antwort Letzte Antwort
        • T tombox
          wolfi913W Online
          wolfi913W Online
          wolfi913
          schrieb am zuletzt editiert von wolfi913
          #1559
          @tombox
          Funktioniert wieder 👍
          2026-04-06 10:30:55.725 - info: host.iobroker instance system.adapter.parcel.0 in version "0.3.1" (non-npm: TA2k/ioBroker.parcel#c579b7c8e878e72c56ae1c30c2fed9292b469895) started with pid 3109
          2026-04-06 10:30:56.606 - info: parcel.0 (3109) starting. Version 0.3.1 (non-npm: TA2k/ioBroker.parcel#c579b7c8e878e72c56ae1c30c2fed9292b469895) in /opt/iobroker/node_modules/iobroker.parcel, node: v22.22.2, js-controller: 7.0.7
          2026-04-06 10:30:56.620 - info: parcel.0 (3109) Login to DHL via new dhllogin:// code
          2026-04-06 10:30:56.893 - info: parcel.0 (3109) Login to DHL successful
          Vielen Dank
          Edit:
          Auch Login zu Amazon und DPD funktionieren einwandfrei.
          • NashraN Offline
            NashraN Offline
            Nashra
            schrieb am zuletzt editiert von Nashra
            #1560
            0.3.1 installiert und Amazon liefert Daten, aber wo sind die Einträge bei DHL
            für Mail, Passwort usw.
            Gruß Ralf
            • NashraN Nashra
              TT-Tom
              #1561
              @Nashra
              du musst genau das da machen, was da steht. Der Link ist die rote Schrift und du musst den ioBroker im Chrome Browser öffnen, sonst findest du nicht den Link.
              Gruß Tom
              Public Transport
              NSPanel Adapter Wiki
              • T TT-Tom
                @Nashra
                NashraN Offline
                NashraN Offline
                Nashra
                #1562
                @TT-Tom sagte:
                @Nashra
                Sorry, die Fehlermeldung finde ich nicht und auch nicht die url die passt.
                Gruß Ralf
                • NashraN Nashra
                  @TT-Tom sagte:
                  @Nashra
                  #1563
                  @Nashra sagte:
                  Verwendest du auch den Chrome-Browser?
                    @Nashra sagte:
                    NashraN Offline
                    NashraN Offline
                    Nashra
                    #1564
                    @Thomas-Braun sagte:
                    @Nashra sagte:
                    Jow Google-Chrome. Anmeldeseite kommt, ammeldem geht nicht und in Dev-Tools finde ich nichts mit Failed.
                    Gruß Ralf
                    • NashraN Nashra
                      @Nashra sagte:
                      TT-Tom
                      #1565
                      @Nashra
                      nur noch mal zum Abgleich,
                      Wenn du die Anmeldeseite offen hast (mehr sollte nicht zusehen sein)
                      startest die Entwicklerkonsole von Chrome. Dann deine Logindaten eingeben und nach dem Anmelden sollte in der Konsole eine Fehlermeldung mit Link erscheinen.
                      Gruß Tom
                      Public Transport
                      • T TT-Tom
                        @Nashra
                        NashraN Offline
                        NashraN Offline
                        Nashra
                        #1566
                        @TT-Tom sagte:
                        @Nashra
                        Genauso bin ich vorgegangen, bekomme aber die Meldung das Benutzername oder Passwort falsch sind.
                        Rufe ich die normale DHL Seite auf, kann ich mich problemlos einloggen.
                        Gruß Ralf
                        T T 2 Antworten Letzte Antwort
                        • NashraN Nashra
                          @TT-Tom sagte:
                          @Nashra
                          TT-Tom
                          #1567
                          @nashra
                          Da kann ich dann auch nicht weiter helfen.
                          Gruß Tom
                          Public Transport
                          • BoronsbruderB Offline
                            Boronsbruder
                            schrieb am zuletzt editiert von Boronsbruder
                            #1568
                            @nashra
                            Bei mir hat er auch nix angezeigt bis ich hier geklickt habe:
                            • NashraN Nashra
                              @TT-Tom sagte:
                              @Nashra
                              tombox
                              #1569
                              @Nashra Password vergessen funktion nutzen
                              • NashraN Offline
                                NashraN Offline
                                Nashra
                                #1570
                                So, jetzt hat er mir was angezeigt (ohne Passwort zu ändern) und habe den Link kopiert,
                                aber da ist wohl immer noch was faul
                                parcel.0	2026-04-06 18:39:29.176	info	Relogin to Amazon successful
                                parcel.0	2026-04-06 18:39:26.873	error	{"error":"invalid_grant","error_description":"code not found or expired"}
                                parcel.0	2026-04-06 18:39:26.873	error	AxiosError: Request failed with status code 400
                                parcel.0	2026-04-06 18:39:26.714	info	Login to DHL via new dhllogin:// code
                                parcel.0	2026-04-06 18:39:26.713	info	Relogin to Amazon successful
                                parcel.0	2026-04-06 18:39:24.291	info	Login to Amazon
                                Gruß Ralf
                                • Walter.O.W Offline
                                  Walter.O.W Offline
                                  Walter.O.
                                  #1571
                                  Sorry, wo finde ich die Version 0.3.1
                                  • Walter.O.W Walter.O.
                                    #1572
                                    @Walter.O.
                                    Im üblichen Update (des Beta-Repos).
                                    • NashraN Offline
                                      NashraN Offline
                                      Nashra
                                      #1573
                                      Hat sich erledigt....
                                      Adapter nochmal neu installiert, dann den Link, eingeloggt und den angezeigten Link kopiert
                                      Jetzt hat er sich mit DHL verbunden. Schwere Geburt und danke an Alle Helfer.
                                      parcel.0 2026-04-06 18:53:06.526	info	Relogin to Amazon successful
                                      parcel.0 2026-04-06 18:53:01.387	info	Login to DHL successful
                                      parcel.0 2026-04-06 18:53:01.049	info	Login to DHL via new dhllogin:// code
                                      parcel.0 2026-04-06 18:53:01.048	info	Relogin to Amazon successful
                                      parcel.0 2026-04-06 18:52:58.596	info	Login to Amazon
                                      parcel.0 2026-04-06 18:52:58.573	info	starting. Version 0.3.1 (non-npm: TA2k/ioBroker.parcel#c579b7c8e878e72c56ae1c30c2fed9292b469895) in /opt/iobroker/node_modules/iobroker.parcel, node: v22.22.2, js-controller: 7.0.7
                                      host.ioBroker 2026-04-06 18:52:53.232	warn	instance system.adapter.parcel.0 terminated due to SIGKILL
                                      Gruß Ralf
                                      • NashraN Nashra
                                        #1574
                                        Hm. Irgendwie stehe ich da auch auf dem Schlauch:
                                        Ich finde da den Link nicht in der Console.
                                        Edit: Hat sich erledigt. Ich musste mehrfach auf 'Anmelden' klicken, irgendwann erschien der Link dann.
                                          basty2
                                          #1575
                                          Vielen Dank. Echt klasse. Jetzt funktioniert bei mir sowohl Amazon als auch DHL.
