  4. Mein nuc ist scheinbar am Limit
    6.4k
30 Beiträge 7 Kommentatoren 1.7k Aufrufe 8 Beobachtet
  • Dr.PieD Dr.Pie
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
     Static hostname: nuc
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.1.0-43-amd64
        Architecture: x86-64
     Hardware Vendor: Intel Corporation
      Hardware Model: NUC7i3BNK
    Firmware Version: BNKBL357.86A.0083.2020.0714.1344
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     17:51:24 up 1 day,  2:46,  2 users,  load average: 2.65, 2.23, 2.25
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2026-03-17 17:51:25 CET
               Universal time: Tue 2026-03-17 16:51:25 UTC
                     RTC time: Tue 2026-03-17 16:51:25
                  NTP service: n/a
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    jens
    HOME=/home/jens
    GROUPS=jens cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             16G        3.7G         10G        1.0M        2.4G         12G
    Swap:           1.0G          0B        1.0G
    Total:           17G        3.7G         11G
    Active iob-Instances:   30
            15876 M total memory
             3498 M used memory
              954 M active memory
             4060 M inactive memory
            10460 M free memory
              460 M buffer memory
             1792 M swap cache
              975 M total swap
                0 M used swap
              975 M free swap
    top - 17:51:25 up 1 day,  2:46,  2 users,  load average: 2.65, 2.23, 2.25
    Tasks: 150 total,   3 running, 147 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us, 25.0 sy,  0.0 ni, 25.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15876.1 total,  10460.4 free,   3497.9 used,   2253.5 buff/cache
    MiB Swap:    976.0 total,    976.0 free,      0.0 used.  12378.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  792K  1.6G   1% /run
    /dev/nvme0n1p1 ext4      116G   14G   96G  13% /
    tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Mon Mar 16 15:04:29 2026] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Mar 16 15:04:30 2026] EXT4-fs (nvme0n1p1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE         FSTYPE OPTIONS
    /      /dev/nvme0n1p1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.4G    /var/
    1.8G    /var/log/journal/71f4ccb046934bb889999d75429a60cc
    1.8G    /var/log
    416M    /var/cache
    Archived and active journals take up 94.5M in the file system.
    /opt/iobroker/backups:
    4.6G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    672M    /opt/iobroker/iobroker-data/
    389M    /opt/iobroker/iobroker-data/files
    145M    /opt/iobroker/iobroker-data/backup-objects
    60M     /opt/iobroker/iobroker-data/files/vis-2
    47M     /opt/iobroker/iobroker-data/history
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    37M     /opt/iobroker/iobroker-data/states.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    13M     /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.1
    /usr/bin/node           v22.22.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.1-1nodesource1
      Candidate: 22.22.1-1nodesource1
      Version table:
     *** 22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    nuc                 nuc (version: 7.0.7, hostname: nuc           , alive, uptime: 5107)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     4
    +-- iobroker.bambulab@0.4.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#53e3ab3393d16f1939ceadc25da611f21574cbc8)
    +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : nuc                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : nuc                                      -  enabled
    + system.adapter.bambulab.2               : bambulab              : nuc                                      -  enabled, port: 8883
    + system.adapter.bambulab.3               : bambulab              : nuc                                      -  enabled, port: 8883
    + system.adapter.daswetter.0              : daswetter             : nuc                                      -  enabled
    + system.adapter.denon.0                  : denon                 : nuc                                      -  enabled
    + system.adapter.discovery.0              : discovery             : nuc                                      -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : nuc                                      -  enabled
      system.adapter.firetv.0                 : firetv                : nuc                                      - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : nuc                                      -  enabled
    + system.adapter.harmony.0                : harmony               : nuc                                      -  enabled
    + system.adapter.heos.0                   : heos                  : nuc                                      -  enabled
    + system.adapter.history.0                : history               : nuc                                      -  enabled
      system.adapter.ical.0                   : ical                  : nuc                                      -  enabled
      system.adapter.ical.1                   : ical                  : nuc                                      -  enabled
      system.adapter.ical.2                   : ical                  : nuc                                      -  enabled
      system.adapter.ical.3                   : ical                  : nuc                                      -  enabled
    + system.adapter.javascript.0             : javascript            : nuc                                      -  enabled
    + system.adapter.shelly.0                 : shelly                : nuc                                      -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : nuc                                      -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.smartthings.0            : smartthings           : nuc                                      - disabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : nuc                                      -  enabled
    + system.adapter.sql.0                    : sql                   : nuc                                      -  enabled
      system.adapter.synology.0               : synology              : nuc                                      - disabled, port: 5000
    + system.adapter.synology.1               : synology              : nuc                                      -  enabled, port: 5002
    + system.adapter.synology.2               : synology              : nuc                                      -  enabled, port: 5003
    + system.adapter.tankerkoenig.0           : tankerkoenig          : nuc                                      -  enabled
    + system.adapter.tankerkoenig.1           : tankerkoenig          : nuc                                      -  enabled
    + system.adapter.telegram.0               : telegram              : nuc                                      -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : nuc                                      -  enabled
    + system.adapter.tr-064.2                 : tr-064                : nuc                                      -  enabled
    + system.adapter.tr-064.3                 : tr-064                : nuc                                      -  enabled
    + system.adapter.upnp.0                   : upnp                  : nuc                                      -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : nuc                                      -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : nuc                                      -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : nuc                                      -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : nuc                                      -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : nuc                                      -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : nuc                                      -  enabled
      system.adapter.vis.0                    : vis                   : nuc                                      -  enabled
    + system.adapter.web.0                    : web                   : nuc                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : nuc                                      -  enabled
      system.adapter.wled.1                   : wled                  : nuc                                      - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "harmony"      : 2.0.5    , installed 2.0.5
    Adapter    "heos"         : 3.0.4    , installed 3.0.4
    Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "shelly"       : 10.5.2   , installed 10.5.2
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.3    , installed 0.7.3
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        39782
    States:         32817
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       2864918    22024/io.shelly.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13888      516/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15799      1/init
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      104        15158      494/influxd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2867453    21710/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2865443    21710/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13890      516/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          15801      1/init
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       2865692    21905/io.harmony.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       2876776    22216/io.upnp.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2867490    21730/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2869415    22260/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      104        18913      494/influxd
    udp        0      0 0.0.0.0:52621           0.0.0.0:*                           1001       2867621    21925/io.heos.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       2865693    21905/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2869369    22276/io.wled.0
    udp        0      0 192.168.178.28:5353     0.0.0.0:*                           1001       2865856    22088/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       2864852    22008/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15116      350/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15800      1/init
    udp        0      0 192.168.178.28:123      0.0.0.0:*                           0          20463      639/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          20461      639/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          20457      639/ntpd
    udp        0      0 0.0.0.0:50036           0.0.0.0:*                           1001       2869281    22216/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2866138    22216/io.upnp.0
    udp6       0      0 :::111                  :::*                                0          15802      1/init
    udp6       0      0 fe80::96c6:91ff:fea:123 :::*                                0          20467      639/ntpd
    udp6       0      0 ::1:123                 :::*                                0          20465      639/ntpd
    udp6       0      0 :::123                  :::*                                0          20454      639/ntpd
    Ich hoffe mal das alles dabei ist
    @Dr.Pie sagte in Mein nuc ist scheinbar am Limit:
    Bring es auf Debian 13 'Trixie'. Der Bücherwurm erreicht in ein paar Wochen das letzte Kapitel.
    Siehe auch:
    Pack den jens in die Gruppe 'adm'.
    Dr.PieD BananaJoeB 2 Antworten Letzte Antwort
    • Dr.PieD Dr.Pie
       21710 iobroker  20   0   11,6g 637412  58140 R 101,0   3,9  92:47.54 iobroker.js-con
        22260 iobroker  20   0   11,4g 254624  53740 S  27,9   1,6  26:31.40 io.web.0
        21798 iobroker  20   0   11,4g 309652  58008 R  21,3   1,9  23:34.42 io.javascript.0
        21754 iobroker  20   0   11,1g 120476  51988 S  15,6   0,7  14:58.15 io.history.0
        22136 iobroker  20   0   11,4g 228100  53140 S  11,6   1,4  13:08.74 io.bambulab.2
        22288 iobroker  20   0   11,4g 243636  53100 R  10,6   1,5  14:33.00 io.bambulab.3
        22024 iobroker  20   0   11,3g 192760  57684 S   3,0   1,2   5:01.43 io.shelly.1
        22008 iobroker  20   0   11,1g 153124  57688 S   1,7   0,9   2:22.85 io.shelly.0
        21730 iobroker  20   0   21,5g 285724  59812 S   1,0   1,8   1:08.51 io.admin.0
        22184 iobroker  20   0   11,1g 127260  57508 S   1,0   0,8   1:02.37 io.sourceanalyt
        21814 iobroker  20   0   11,3g 117244  53976 S   0,3   0,7   0:40.79 io.sql.0
        21830 iobroker  20   0   11,3g 130708  58600 S   0,3   0,8   0:44.88 io.telegram.0
        21870 iobroker  20   0   11,1g  90308  52000 S   0,3   0,6   0:09.07 io.denon.0
        21925 iobroker  20   0   11,1g 113356  52716 S   0,3   0,7   0:19.92 io.heos.0
        23697 jens      20   0   11828   5388   3220 R   0,3   0,0   0:00.02 top
            1 root      20   0  167808  12232   9184 S   0,0   0,1   0:01.47 systemd
            2 root      20   0       0      0      0 S   0,0   0,0   0:00.01 kthreadd
            3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
            4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
            5 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 slub_flushwq
            6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
            8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-events_highpri
           10 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
           11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_kthread
           12 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_rude_kthread
           13 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_trace_kthread
           14 root      20   0       0      0      0 R   0,0   0,0   0:15.75 ksoftirqd/0
           15 root      20   0       0      0      0 I   0,0   0,0   0:42.74 rcu_preempt
           16 root      rt   0       0      0      0 S   0,0   0,0   0:00.62 migration/0
           18 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
           19 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
           20 root      rt   0       0      0      0 S   0,0   0,0   0:00.65 migration/1
           21 root      20   0       0      0      0 S   0,0   0,0   0:05.75 ksoftirqd/1
           23 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-events_highpri
           24 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
           25 root      rt   0       0      0      0 S   0,0   0,0   0:00.25 migration/2
           26 root      20   0       0      0      0 S   0,0   0,0   0:05.32 ksoftirqd/2
           28 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/2:0H-events_highpri
           29 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
           30 root      rt   0       0      0      0 S   0,0   0,0   0:00.24 migration/3
           31 root      20   0       0      0      0 S   0,0   0,0   0:05.27 ksoftirqd/3
           33 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/3:0H-events_highpri
           38 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
           39 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 inet_frag_wq
           40 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
           41 root      20   0       0      0      0 S   0,0   0,0   0:00.03 khungtaskd
           42 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
           43 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
           44 root      20   0       0      0      0 S   0,0   0,0   0:01.62 kcompactd0
           45 root      25   5       0      0      0 S   0,0   0,0   0:00.00 ksmd
           46 root      39  19       0      0      0 S   0,0   0,0   0:01.60 khugepaged
           47 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
           48 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
           49 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
           52 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 tpm_dev_wq
           53 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 edac-poller
           54 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 devfreq_wq
           56 root       0 -20       0      0      0 I   0,0   0,0   0:00.57 kworker/0:1H-kblockd
           57 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kswapd0
           63 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
           65 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 acpi_thermal_pm
           66 root      20   0       0      0      0 S   0,0   0,0   0:01.93 hwrng
           67 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mld
           68 root       0 -20       0      0      0 I   0,0   0,0   0:00.54 kworker/3:1H-kblockd
           69 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ipv6_addrconf
           74 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kstrp
           79 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 zswap-shrink
           80 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/u9:0-hci0
          133 root       0 -20       0      0      0 I   0,0   0,0   0:00.57 kworker/1:1H-kblockd
          134 root       0 -20       0      0      0 I   0,0   0,0   0:00.54 kworker/2:1H-kblockd
          155 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ata_sff
          156 root      20   0       0      0      0 S   0,0   0,0   0:00.00 scsi_eh_0
          157 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 scsi_tmf_0
          158 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nvme-wq
          159 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nvme-reset-wq
          160 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nvme-delete-wq
          190 root      20   0       0      0      0 S   0,0   0,0   0:07.23 jbd2/nvme0n1p1-8
          191 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ext4-rsv-conver
          240 root      20   0  144840  60080  58884 S   0,0   0,4   0:00.81 systemd-journal
          263 root      20   0   26904   6392   4744 S   0,0   0,0   0:00.34 systemd-udevd
          350 root      20   0    5880   3476   2636 S   0,0   0,0   0:00.00 dhclient
      HomoranH Offline
      HomoranH Offline
      @Dr.Pie Der Header fehlt.
      Dr.PieD 1 Antwort Letzte Antwort
        Siehe auch:
        Dr.PieD Offline
        Dr.PieD Offline
        Dr.Pie
        @Thomas-Braun sagte in Mein nuc ist scheinbar am Limit:
        Das hatte ich auch schon mal in Erwägung gezogen.
        ... ob das gut geht ???
        eine Anleitung hatte ich mal:
        https://www.bjoerns-techblog.de/2025/08/upgrade-debian-bookworm-zu-trixie/
          Dr.PieD Offline
          Dr.PieD Offline
          Dr.Pie
          @Homoran sagte in Mein nuc ist scheinbar am Limit:
          top - 18:34:07 up 1 day,  3:29,  1 user,  load average: 2,06, 2,28, 2,24
          Tasks: 142 total,   6 running, 136 sleeping,   0 stopped,   0 zombie
          %CPU(s): 43,1 us,  3,1 sy,  0,0 ni, 52,1 id,  0,0 wa,  0,0 hi,  1,6 si,  0,0 st
          MiB Spch:  15876,1 total,  10105,0 free,   3771,8 used,   2342,3 buff/cache
          MiB Swap:    976,0 total,    976,0 free,      0,0 used.  12104,3 avail Spch
          • Dr.PieD Dr.Pie
            @Dr.Pie
            Da gibt es nix zu 'erwägen', das muss gemacht werden. Am besten bevor das EndOfLife erreicht wird.
            Hier noch eine Anleitung:
            https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie/222
            • Dr.PieD Dr.Pie
              HomoranH Offline
              HomoranH Offline
              @Dr.Pie Die Tabelle fehlt 😉
              top ist immer eine Momentaufnahme.
              Header und Tabelle ergeben nur zeitgleich Sinn.
              aber schonmal vorweg
              ist wahrscheinlich nicht kritisch aber nicht wenig.
              Was für ein Professor?
              aber der Controller
              belegt einen Kern vollständig
                Siehe auch:
                BananaJoeB Offline
                BananaJoeB Offline
                BananaJoe
                @dr.pie Primär:
                halte mal den history an. und den JavaScript sowie die beiden Bambulab und schaue ob es besser wird.
                Könnte ein Javascript sein was ständig viele Datenpunkte ändert bzw. eine irgendwie geartete Schleife (hatten wir mit MQTT schon mal) die ständig viele Datenpunkte ändert. Könnte also auch aus einen der anderen Adapter kommen.
                HomoranH Dr.PieD 2 Antworten Letzte Antwort
                • BananaJoeB BananaJoe
                  @dr.pie Primär:
                  HomoranH Offline
                  HomoranH Offline
                  @BananaJoe sagte in Mein nuc ist scheinbar am Limit:
                  eine irgendwie geartete Schleife (hatten wir...schon mal
                  ich weiss nur nicht mehr wo das war, dass der Controller am Anschlag ist.
                  Javascript hat nur 27% eines Kerns. Das ist zum Zeitpunkt des Tops zumindest nicht kritisch.
                    aber der Controller
                    HomoranH Offline
                    HomoranH Offline
                    doch! es ist bereits kritisch!
                    Dein Supercomputer hat nur einen 2-Kerner!!
                    Dann sind Werte >2 zu viel.
                    • Dr.PieD Offline
                      Dr.PieD Offline
                      Dr.Pie
                      Sooooo Update ist durch ...hoffe ich zumindest:
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                      Operating System: Debian GNU/Linux 13 (trixie)
                               Chassis: desktop 🖥️
                                Kernel: Linux 6.12.74+deb13+1-amd64
                         Firmware Date: Tue 2020-07-14
                          Firmware Age: 5y 8month 3d
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       20:09:12 up 1 min,  1 user,  load average: 1.30, 0.43, 0.15
                      CPU threads: 4
                      Operating System is the current Debian stable version codenamed 'trixie'!
                                     Local time: Tue 2026-03-17 20:09:13 CET
                                 Universal time: Tue 2026-03-17 19:09:13 UTC
                                       RTC time: Tue 2026-03-17 19:09:13
                      System clock synchronized: no
                                    NTP service: active
                                RTC in local TZ: no
                      jens
                      HOME=/home/jens
                      iobroker
                      HOME=/home/iobroker
                      SUDO_HOME=/home/jens
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:             16G        2.1G         14G        2.0M        660M         14G
                      Swap:           1.0G          0B        1.0G
                      Total:           17G        2.1G         15G
                      Active iob-Instances:   12
                              15882 M total memory
                               1955 M used memory
                               1648 M active memory
                                424 M inactive memory
                              13578 M free memory
                                 52 M buffer memory
                                577 M swap cache
                                975 M total swap
                                  0 M used swap
                                975 M free swap
                      top - 20:09:13 up 1 min,  1 user,  load average: 1.30, 0.43, 0.15
                      Tasks: 161 total,   2 running, 159 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 32.6 us,  2.3 sy,  0.0 ni, 65.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  15882.7 total,  13565.5 free,   1968.1 used,    631.4 buff/cache
                      MiB Swap:    976.0 total,    976.0 free,      0.0 used.  13914.6 avail Mem
                      *** FILESYSTEM ***
                      tmpfs          tmpfs     1.6G  800K  1.6G   1% /run
                      /dev/nvme0n1p1 ext4      116G   15G   96G  13% /
                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                      tmpfs          tmpfs     7.8G  2.0M  7.8G   1% /tmp
                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                      tmpfs          tmpfs     1.6G  8.0K  1.6G   1% /run/user/1000
                      [Tue Mar 17 20:08:10 2026] EXT4-fs (nvme0n1p1): mounted filesystem 59b1f09e-4134-4f42-9ebd-23b24ce0ef05 ro with ordered data mode. Quota mode: none.
                      [Tue Mar 17 20:08:11 2026] EXT4-fs (nvme0n1p1): re-mounted 59b1f09e-4134-4f42-9ebd-23b24ce0ef05 r/w.
                      /var:
                      2.4G    /var/
                      1.8G    /var/log
                      433M    /var/cache
                      Archived and active journals take up 102.5M in the file system.
                      628M    /opt/iobroker/iobroker-data/
                      329M    /opt/iobroker/iobroker-data/files
                      47M     /opt/iobroker/iobroker-data/files/admin.admin
                      58M     /opt/iobroker/iobroker-data/states.jsonl
                      41M     /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                              500 http://deb.debian.org/debian trixie/main amd64 Packages
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      nuc                 nuc (version: 7.0.7, hostname: nuc           , alive, uptime: 63)
                      admin:          7.7.22
                      javascript:     9.0.18
                      Adapter State
                      + system.adapter.ical.0                   : ical                  : nuc                                      -  enabled
                      + instance is alive
                      Objects and States
                      Objects:        39780
                      States:         32740
                      Hit:1 http://security.debian.org/debian-security trixie-security InRelease
                      Hit:2 http://deb.debian.org/debian trixie InRelease
                      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                      tcp        5      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12794      1733/io.shelly.1
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6046       757/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1400       1/init
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       968        700/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7681       700/iobroker.js-con
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6105       979/exim4
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      104        6694       699/influxd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          6048       757/sshd: /usr/sbin
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          1402       1/init
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6106       979/exim4
                      tcp6       0      0 :::61991                :::*                    LISTEN      1001       7146       1314/io.harmony.0
                      tcp6       0      0 :::8086                 :::*                    LISTEN      104        6732       699/influxd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7789       1012/io.admin.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7575       661/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1401       1/init
                      udp        0      0 192.168.178.28:123      0.0.0.0:*                           0          9231       1057/ntpd
                      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          9229       1057/ntpd
                      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          9225       1057/ntpd
                      udp        0      0 0.0.0.0:50497           0.0.0.0:*                           1001       8651       1341/io.heos.0
                      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       7147       1314/io.harmony.0
                      udp        0      0 192.168.178.28:5353     0.0.0.0:*                           1001       10237      1911/io.tr-064.0
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11729      1670/io.shelly.0
                      udp6       0      0 :::111                  :::*                                0          1403       1/init
                      udp6       0      0 fe80::96c6:91ff:fea:123 :::*                                0          9235       1057/ntpd
                      udp6       0      0 ::1:123                 :::*                                0          9233       1057/ntpd
                      udp6       0      0 :::123                  :::*                                0          9222       1057/ntpd
                      2026-03-17 20:09:41.996  - info: synology.2 (1818) DSM 7 detected, set all to true
                      2026-03-17 20:09:42.767  - info: host.nuc instance system.adapter.tr-064.3 in version "4.3.0" started with pid 1981
                      2026-03-17 20:09:42.780  - info: tr-064.2 (1941) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v22.22.1, js-controller: 7.0.7
                      2026-03-17 20:09:43.567  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-4855199d1ee8" connected from 192.168.178.148!
                      2026-03-17 20:09:44.522  - info: admin.0 (1012) ==> Connected system.user.admin from ::ffff:192.168.178.10
                      2026-03-17 20:09:47.248  - info: host.nuc instance system.adapter.bambulab.2 in version "0.4.2" (non-npm: DrozmotiX/ioBroker.bambulab#53e3ab3393d16f1939ceadc25da611f21574cbc8) started with pid 2011
                      2026-03-17 20:09:48.363  - info: tr-064.3 (1981) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v22.22.1, js-controller: 7.0.7
                      2026-03-17 20:09:50.105  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-a0dd6c30eb80" connected from 192.168.178.80!
                      2026-03-17 20:09:51.477  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-d4d4da359380" connected from 192.168.178.118!
                      2026-03-17 20:09:52.718  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-485519995a74" connected from 192.168.178.155!
                      2026-03-17 20:09:53.022  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-e86beae6ad68" connected from 192.168.178.173!
                      2026-03-17 20:09:53.635  - info: host.nuc instance system.adapter.discovery.0 in version "5.0.0" started with pid 2052
                      2026-03-17 20:09:54.415  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-0cdc7ef659d8" connected from 192.168.178.145!
                      2026-03-17 20:09:54.423  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-485519999a18" connected from 192.168.178.158!
                      2026-03-17 20:09:55.456  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-0cdc7ef5a954" connected from 192.168.178.144!
                      2026-03-17 20:09:55.457  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-d4d4daeafe14" connected from 192.168.178.168!
                      2026-03-17 20:09:56.777  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-08b61f6ea000" connected from 192.168.178.170!
                      2026-03-17 20:09:56.911  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-4855199c1ee8" connected from 192.168.178.151!
                      2026-03-17 20:09:57.034  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-48551999cd30" connected from 192.168.178.182!
                      2026-03-17 20:09:57.252  - info: host.nuc instance system.adapter.fb-checkpresence.0 in version "1.4.2" started with pid 2082
                      2026-03-17 20:10:00.085  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-b0b21c1b2274" connected from 192.168.178.166!
                      2026-03-17 20:10:01.323  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-48551999cdcc" connected from 192.168.178.157!
                      2026-03-17 20:10:01.341  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-4855199c05e8" connected from 192.168.178.152!
                      2026-03-17 20:10:02.203  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-e86beae73c98" connected from 192.168.178.172!
                      2026-03-17 20:10:02.381  - info: shelly.1 (1733) [MQTT] Device with client id "shellyplus1pm-a0dd6c312d20" connected from 192.168.178.136!
                      iob diag has finished.
                      • Dr.PieD Offline
                        Dr.PieD Offline
                        Dr.Pie
                        schrieb am zuletzt editiert von Dr.Pie
                        Scheint alles zu laufen ... aaalter schwede
                        Aber die CPU ist noch immer über 100%.
                        • Dr.PieD Dr.Pie
                          @Dr.Pie
                          sudo usermod -aG adm jens
                            @Dr.Pie
                            Dr.PieD Offline
                            Dr.PieD Offline
                            Dr.Pie
                            @Dr.Pie
                            Ok
                            • Dr.PieD Dr.Pie
                              HomoranH Offline
                              HomoranH Offline
                              wo siehst du das?
                              %Cpu(s): 32.6 us,
                              32,6% used
                                @dr.pie Primär:
                                Dr.PieD Offline
                                Dr.PieD Offline
                                Dr.Pie
                                @dr.pie Primär:
                                Also weder history noch JavaScript half die Last zu verringern.
                                Erst als ich die die beiden Bambulab gestoppt hatte viel die Last auf unter 10%.
                                • Dr.PieD Dr.Pie
                                  @dr.pie Primär:
                                  CodierknechtC Offline
                                  Codierknecht
                                  Mein Ender hat diese Probleme zwar nicht. Aber trotzdem schalte ich den über eine NOUS ein und starte auch nur dann die Instanz.
                                  HmIP|ZigBee|Tasmota|Unifi
                                  Zabbix Certified Specialist
                                  • CodierknechtC Codierknecht
                                    Dr.PieD Offline
                                    Dr.PieD Offline
                                    Dr.Pie
                                    @Codierknecht sagte in Mein nuc ist scheinbar am Limit:
                                    NOUS ??????
                                    • Dr.PieD Dr.Pie
                                      NOUS ??????
                                      BananaJoeB Offline
                                      BananaJoeB Offline
                                      BananaJoe
                                      @Dr.Pie schaltbare Steckdose / Zwischenstecker, z.B. https://www.amazon.de/dp/B0054PSIPA
                                        Dr.PieD Offline
                                        Dr.PieD Offline
                                        Dr.Pie
                                        Aha ... bei mir läuft das alles über Shelly.
                                        Aber Shellys ersetzen halt nicht den Adapter.
                                        In der Vis sieht das dann so aus.
                                        • BananaJoeB Offline
                                          BananaJoeB Offline
                                          BananaJoe
                                          Du sollst die Bambulab-Adapter stoppen. Und nur starten wenn die Drucker an sind.
                                          Kannst du auch über den Ping-Adapter machen und ein Skript. Wenn der Drucker per ping erreichbar ist = Adapter starten, wenn nicht dann stoppen.
                                          Ich hatte den Klipper-Moonraker im Ensatz, der hat das gleiche Problem. Abgesehen davon das die Adapter unfassbar viele Daten + -änderungen pro Sekunde liefern.
                                          und rum zicken wenn die den Drucker nicht erreichen können.
                                          Wird es besser wenn die Drucker an sind mit der Leistung?
