  4. ...nicht in offiziellem Repo
  5. Test Adapter Navimow
    6.3k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
55 Beiträge 13 Kommentatoren 4.0k Aufrufe 11 Beobachtet
  • T tombox
    @denjo
    Bitte mal testen https://forum.iobroker.net/topic/84066/test-adapter-navimow
    denjo
    schrieb am zuletzt editiert von denjo
    @tombox habe zwei mal ein token gemacht aber läuft nicht
    navimow.0
    2026-03-15 14:32:39.886	warn	No token found. Open the Navimow login link in adapter settings, copy the code and paste it into the settings.
    navimow.0
    2026-03-15 14:32:39.884	error	Token exchange failed. Check the authorization code.
    navimow.0
    2026-03-15 14:32:39.884	error	Token exchange failed: {"code":5001,"desc":"Exception.Server.Error","data":null}
    navimow.0
    2026-03-15 14:32:38.526	info	Authorization code found in config, exchanging for token...
    navimow.0
    2026-03-15 14:32:38.457	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.navimow#87ecfc2db1f8360d77930e9d51124408ec937324) in /opt/iobroker/node_modules/iobroker.navimow, node: v22.22.0, js-controller: 7.0.7
    host.iOBroker
    2026-03-15 14:32:37.021	info	instance system.adapter.navimow.0 in version "0.0.1" (non-npm: TA2k/ioBroker.navimow#87ecfc2db1f8360d77930e9d51124408ec937324) started with pid 366252
    host.iOBroker
    2026-03-15 14:32:33.727	info	instance system.adapter.navimow.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    navimow.0
    2026-03-15 14:32:33.620	info	terminating
    host.iOBroker
    2026-03-15 14:32:33.277	info	stopInstance system.adapter.navimow.0 send kill signal
    navimow.0
    2026-03-15 14:32:33.119	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    navimow.0
    2026-03-15 14:32:33.118	info	terminating
    navimow.0
    2026-03-15 14:32:33.117	info	Got terminate signal TERMINATE_YOURSELF
    host.iOBroker
    2026-03-15 14:32:33.115	info	stopInstance system.adapter.navimow.0 (force=false, process=true)
    admin.0
    2026-03-15 14:31:58.490	warn	navimow has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/then/required","keyword":"required","params":{"missingProperty":"type"},"message":"must have required property 'type'"}]
    navimow.0
    2026-03-15 14:31:31.277	warn	No token found. Open the Navimow login link in adapter settings, copy the code and paste it into the settings.
    navimow.0
    2026-03-15 14:31:31.276	error	Token exchange failed. Check the authorization code.
    navimow.0
    2026-03-15 14:31:31.275	error	Token exchange failed: {"code":5001,"desc":"Exception.Server.Error","data":null}
    navimow.0
    2026-03-15 14:31:29.022	info	Authorization code found in config, exchanging for token...
    navimow.0
    2026-03-15 14:31:28.954	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.navimow#87ecfc2db1f8360d77930e9d51124408ec937324) in /opt/iobroker/node_modules/iobroker.navimow, node: v22.22.0, js-controller: 7.0.7
    host.iOBroker
    2026-03-15 14:31:27.787	info	instance system.adapter.navimow.0 in version "0.0.1" (non-npm: TA2k/ioBroker.navimow#87ecfc2db1f8360d77930e9d51124408ec937324) started with pid 366201
    host.iOBroker
    2026-03-15 14:31:24.459	info	instance system.adapter.navimow.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    navimow.0
    2026-03-15 14:31:24.373	info	terminating
    host.iOBroker
    2026-03-15 14:31:23.971	info	stopInstance system.adapter.navimow.0 send kill signal
    navimow.0
    2026-03-15 14:31:23.871	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    navimow.0
    2026-03-15 14:31:23.871	info	terminating
    navimow.0
    2026-03-15 14:31:23.870	info	Got terminate signal TERMINATE_YOURSELF
    host.iOBroker
    2026-03-15 14:31:23.868	info	stopInstance system.adapter.navimow.0 (force=false, process=true)
    • T tombox
      Hi ich habe ein neuen Adapter für NaviMow geschrieben.
      Steuerung über navimow.0.id.remote
      Zum Installieren:
      https://github.com/TA2k/ioBroker.navimow
      aktuelle Version
      Unter Adapter Experten Modus aktivieren:
      Unter Adapter das Github Icon klicken:
      Benutzerdefiniert auswählen und die Url einfügen.
      Dann unter Adapter den Navimow Adapter suchen und ganz rechts auf das Plus klicken.
      Loginablauf:
      Url in den Einstellungen öffne und code url kopieren
      JebaJ Offline
      JebaJ Offline
      Jeba
      schrieb am zuletzt editiert von Jeba
      @tombox
      Erstmal danke für den Adapter.
      Hab ihn installiert und die URL von der Navimov kopiert und eingefügt. Du meinst die ganze URL?
      Leider wird der Adapter nicht grün
      In den Logs kommt:
      No token found.
      Token exchange faild: Check the authorization Code
        tombox
        mit der aktuellen GitHub version testen
        was passiert nach dem login wie ist die url aufgebaut oder gibt es ein Fehler
        • JebaJ Offline
          JebaJ Offline
          Jeba
          Was ist die aktuelle Version?
          Ich hab die neu geladen und es ist die v0.0.1
          http://localhost:1/callback?code=xxxxxxxx&state=null
          • JebaJ Jeba
            tombox
            @Jeba 1.0.0 sollte jetzt alles gehen
            • JebaJ Offline
              JebaJ Offline
              Jeba
              Prima das hat super einfach geklappt.
              Danke für die Arbeit.
              Wie bekomm ich den MQTT Fehler noch weg.
              Wie kann man die verbinden herstellen?
              • JebaJ Jeba
                tombox
                @Jeba bräuchte ein account mit gerät via email oder detaillierte logs
                tombox2020@gmail.com
                • JebaJ Offline
                  JebaJ Offline
                  Jeba
                  navimow.0
                  2026-03-15 19:36:55.575 info MQTT connection closed
                  navimow.0
                  2026-03-15 19:36:55.574 error MQTT error: getaddrinfo ENOTFOUND wss
                  navimow.0
                  2026-03-15 19:36:45.567 info MQTT connection closed
                  navimow.0
                  2026-03-15 19:36:45.567 error MQTT error: getaddrinfo ENOTFOUND wss
                  • JebaJ Jeba
                    navimow.0
                    navimow.0
                    navimow.0
                    navimow.0
                    tombox
                    @Jeba Mal die GitHub version darüber installieren und mit debug log posten
                    • JebaJ Offline
                      JebaJ Offline
                      Jeba
                      Du meint meinst die zweite Version. Die hab ich schon geladen. Dann war der Adapter grün und alles gut. Nur die MQTT Meldung in den Logs gibt’s noch
                      • T tombox
                        Zum Installieren:
                        aktuelle Version
                        Loginablauf:
                        tombox
                        Nein ich meinte die dritte Version. einfach drüber installieren
                        • JebaJ Offline
                          JebaJ Offline
                          Jeba
                          😂 ah ok. Schnell gefixt. Ich versuche es
                          • JebaJ Offline
                            JebaJ Offline
                            Jeba
                            Prima. Fehlermeldung ist weg.
                            Was hat es mit MQTT denn auf sich.
                            Wofür war oder ist das vorgesehen
                            • Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              so. Hat geklappt. Nach dem ersten Start der Instanz wurde sie wirder rot und im Log waren Fehler. Sie ist dann aber neu gestartet und liefert Werte.
                              Genial!
                              VIELEN DANK!!!!!!!!!!!!
                              Beta-Tester
                                Kippe
                                Hallo 🙋‍♂️
                                Habe den Adapter mal installiert und mit meinem Navimow i208 verbunden.
                                Was soll ich sagen es läuft wie geschmiert 🙏
                                Top 👍 Jetzt noch eine schöne View von den Mäher und der Sommer ist gesichert .
                                • JebaJ Offline
                                  JebaJ Offline
                                  Jeba
                                  War der Datenpunkt mit Fortschritt in % nicht greifbar.
                                  Adapter läuft perfekt. Gute Arbeit
                                    Merlin123M Offline
                                    Merlin123
                                    schrieb am zuletzt editiert von Merlin123
                                    Im vehicleState gibt es ja diese Optionen:
                                        "states": {
                                          "isDocked": "Docked",
                                          "isIdel": "Idle",
                                          "isIdle": "Idle",
                                          "isMapping": "Mapping",
                                          "isRunning": "Mowing",
                                          "isPaused": "Paused",
                                          "isDocking": "Returning to Dock",
                                          "Error": "Error",
                                          "error": "Error",
                                          "isLifted": "Lifted (Error)",
                                          "inSoftwareUpdate": "Software Update",
                                          "Self-Checking": "Self-Checking",
                                          "Self-checking": "Self-Checking",
                                          "Offline": "Offline",
                                          "offline": "Offline"
                                    Was muss ich denn z.B. in der VIS als Vergleichswert eintragen, wenn ich wissen will ob er "Mowing" ist?
                                    Hab da verschiedene Optionen erfolglos ausprobiert.
                                    Beta-Tester
                                    • Merlin123M Merlin123
                                          "states": {
                                            "isIdel": "Idle",
                                            "isIdle": "Idle",
                                            "Error": "Error",
                                            "error": "Error",
                                      tombox
                                      @Merlin123 isRunning würde ich vermuten wenn er im iob das anzeigt wenn er läuft
                                      Merlin123M 1 Antwort Letzte Antwort
                                      • T tombox
                                        Merlin123M Offline
                                        Merlin123M Offline
                                        Merlin123
                                        @tombox ah... die Variante hatte ich noch nicht probiert... geht natürlich :P Dank Dir!
                                        Beta-Tester
                                          Merlin123M Offline
                                          Merlin123
                                          Wenn ich möchte, dass der Mäher nicht im geplanten Zeitraum mäht, wie muss ich da vorgehen?
                                          Meine Idee:
                                          Ist der vehicleState = "isDocked" muss ich einfach den
                                          navimow.0.xxx.remote.pause
                                          auf true setzen.
                                          Bei einem anderen vehicleState löse ich erst
                                          navimow.0.xxx.remote.dock
                                          aus und warte, bis er "isDocked" ist, dann wie oben Pause auslösen.
                                          Wenn er weiter machen soll, einfach
                                          navimow.0.xxx.remote.resume
                                          auf true.
                                          Macht er dann das Resume nur innerhalb der geplanten Mähzeiten?
                                          Stimmt diese Überlegung grundsätzlich?
                                          Beta-Tester
