  4. Hue Szenen aus ioBroker steuern
83 Beiträge 25 Kommentatoren 28.4k Aufrufe 6 Beobachtet
  • BBTownB Offline
    BBTownB Offline
    BBTown
    @cernst1980:
    Mindestens eine Szene bräuchte ich mal exemplarisch, owner kannst Du gerne anonymisieren. Müsste der Hue Bridge Benutzer sein, der die Szene erstellt hat. ` ich habe einen Auszug des Logs angefügt
    { "name": "Scene mySceneDim huelabs/chris", "lights": [ "1", "2", "3", "4", "5", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": true, "appdata": {}, "picture": "", "lastupdated": "2018-01-05T14:06:18", "version": 2, "id": "RQj2JRcyGxWKWHG" }, { "name": "Scene myScene1 huelabs/christm", "lights": [ "1", "2", "3", "4", "5", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": true, "appdata": {}, "picture": "", "lastupdated": "2018-01-05T14:06:19", "version": 2, "id": "Wzbzl3V8mS1nDTC" }, { "name": "Scene myScene2 huelabs/christm", "lights": [ "1", "2", "3", "4", "5", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": true, "appdata": {}, "picture": "", "lastupdated": "2018-01-05T14:06:20", "version": 2, "id": "zTCG7lcWMbD7cFi" }, { "name": "Scene myScene3 huelabs/christm", "lights": [ "1", "2", "3", "4", "5", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": true, "appdata": {}, "picture": "", "lastupdated": "2018-01-05T14:06:21", "version": 2, "id": "BiblxsWfZKj2Z3t" }, { "name": "Green day-Animation", "lights": [ "1", "2", "3", "4", "5", "12", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": false, "appdata": { "version": 1, "data": "dfsjkh54:CA06000" }, "picture": "", "lastupdated": "2018-01-14T21:30:15", "version": 2, "id": "i6F7O7VRXDV3ebY" }, { "name": "Green day-Animation", "lights": [ "1", "2", "3", "4", "5", "12", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": false, "appdata": { "version": 1, "data": "j65dfggj:CA06000" }, "picture": "", "lastupdated": "2018-01-14T21:30:16", "version": 2, "id": "7Qef2YB4KXRTkZc" }, { "name": "Green day-Animation", "lights": [ "1", "2", "3", "4", "5", "12", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": false, "appdata": { "version": 1, "data": "jdfh5345:CA06000" }, "picture": "", "lastupdated": "2018-01-14T21:30:17", "version": 2, "id": "AIxffigw1K7gO7C" }, { "name": "Green day-Animation", "lights": [ "1", "2", "3", "4", "5", "12", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": false, "appdata": { "version": 1, "data": "djh5lsef:CA06000" }, "picture": "", "lastupdated": "2018-01-14T21:30:18", "version": 2, "id": "0KbRcqtSX8wKLyi" }, { "name": "The beach-Animation", "lights": [ "1", "2", "3", "4", "5", "12", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": true, "appdata": { "version": 1, "data": "sdfjhe65:CA06000" }, "picture": "", "lastupdated": "2018-01-14T21:31:55", "version": 2, "id": "EOru8lpElqA3yZT" }, { "name": "The beach-Animation", "lights": [ "1", "2", "3", "4", "5", "12", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": true, "appdata": { "version": 1, "data": "sdfkljw4:CA06000" }, "picture": "", "lastupdated": "2018-01-14T21:31:56", "version": 2, "id": "JJjdIDIhsuCY3Yk" }, { "name": "The beach-Animation", "lights": [ "1", "2", "3", "4", "5", "12", "22", "23", "24" ], "owner": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "recycle": true, "locked": true, "appdata": { "version": 1, "data": "fjk76dfg:CA06000" }, "picture": "", "lastupdated": "2018-01-14T21:31:57", "version": 2, "id": "avewviNhrPWQuKP" } ]
    • C Offline
      cernst1980
      Danke Dir.
      Ist gar nicht so trivial…
      Wenn ich mir dies so anschaue, musste ich folgende Annahmen treffen.
      "data": "dfsjkh54:CA06000",
      "data": "j65dfggj:CA06000",
      "data": "jdfh5345:CA06000",
      "data": "djh5lsef:CA06000",
      "data": "sdfjhe65:CA06000",
      "data": "sdfkljw4:CA06000",
      "data": "fjk76dfg:CA06000",
      1\. Die "huelabs" Szenen werden nicht benötigt (haben auch keine "appdata" Einträge).
      2\. Die "Green day-Animation" und "The beach-Animation" Szenen sind alle im selben Raum (ID: 06) und somit Duplikate!?
      Wenn meine Annahmen richtig sind, sollte die aktuelle Version im GitHub funktionieren.
      Kannst Du bitte folgendes prüfen:
      - Fehlen Szenen?
      - Sind Szenen zuviel?
      - Gibt es Duplikate (gleicher Name und Raum)?
      - Wird bei allen Szenen ein Raumname angezeigt?
      - Stimmen die Raumangaben bei den Szenen?
      • BBTownB Offline
        BBTownB Offline
        BBTown
        Mit dem neuen Script werden bei mir gar keine Szenen angelegt 8-)
        • BBTownB Offline
          BBTownB Offline
          BBTown
          @BBTown:
          Mit dem neuen Script werden bei mir gar keine Szenen angelegt 8-) ` Sorry, Kommando zurück!
          Wenn man seine Log-In Angaben (Host, Username) korrekt setzt, dann klappt natürlich auch die Verbindung 😢
          Die aktuelle Version findet wie auch schon die v.2 insgesamt 11 Szenen.
          Das sind jene welche die ich als "Standardszenen" bezeichnen würde.
          Also Nicht die Szenen aus iConnectHue App die von der v.1 gefunden werden.
          Die Szenen aus der iConnectHue App sind nicht unbedingt einem Raum zugeordnet.
          [EDIT]
          Ich habe 2 ScreenShots angefügt:
          • Szenen aus Script v.2/3
          • Auszug aus den Szenen der v.1.
          • C Offline
            cernst1980
            @BBTown:
            Die Szenen aus der iConnectHue App sind nicht unbedingt einem Raum zugeordnet. `
            Dies scheint der springende Punkt zu sein.
            Wie sieht es denn mit der jetzt aktuellen Version auf GitHub aus? :D
            • BBTownB Offline
              BBTownB Offline
              BBTown
              @cernst1980:
              @BBTown:
              Die Szenen aus der iConnectHue App sind nicht unbedingt einem Raum zugeordnet. ` Dies scheint der springende Punkt zu sein.
              Wie sieht es denn mit der jetzt aktuellen Version auf GitHub aus? :D ` Sieht gut aus, alle 75 Szenen wurden angelegt :)
              • R Offline
                RalfR72
                @BBTown:
                @cernst1980:
                @BBTown:
                Wie sieht es denn mit der jetzt aktuellen Version auf GitHub aus? :D Sieht gut aus, alle 75 Szenen wurden angelegt :)
                Überlege seit längerem mir auch die App iconnect zu kaufen, werden alle szenen aus der App dann angezeigt? Auch Dynamische? Was musich in der App noch dazu kaufen?
                Danke für die Hilfestellungen, Gruss Ralf
                Landkreis Esslingen/BW
                CCU2, Synology NAS 916+, ioBroker auf Pi3, Hue, Bose Soundtouch, iMac5k, Harmony Hub, Mediola aioCreator, Alexa Echo Dot.
                • BBTownB Offline
                  BBTownB Offline
                  BBTown
                  @RalfR72:
                  @BBTown:
                  @cernst1980:
                  Wie sieht es denn mit der jetzt aktuellen Version auf GitHub aus? :D Sieht gut aus, alle 75 Szenen wurden angelegt :) Überlege seit längerem mir auch die App iconnect zu kaufen, werden alle szenen aus der App dann angezeigt? Auch Dynamische? Was musich in der App noch dazu kaufen? ` Moin,
                  ja bei mir werden auch die animierten Szenen angezeigt.
                  Welche In-App Käufe Du tätigst ist natürlich Geschmacksache. Ich habe bspw. eine Art "Weihnachtsedition/Stimmung" gekauft, da kann man sich natürlich trefflich drüber streiten 8-)
                  Es werden stetig Neuerungen und auch Animationen seitens iConnectHue zur Verfügung gestellt; ich selbst finde dass die App sich allemal lohnt.
                  • R Offline
                    RalfR72
                    @BBTown:
                    @RalfR72:
                    @BBTown:
                    Sieht gut aus, alle 75 Szenen wurden angelegt :) Überlege seit längerem mir auch die App iconnect zu kaufen, werden alle szenen aus der App dann angezeigt? Auch Dynamische? Was musich in der App noch dazu kaufen? Moin,
                    Es werden stetig Neuerungen und auch Animationen seitens iConnectHue zur Verfügung gestellt; ich selbst finde dass die App sich allemal lohnt. `
                    Für die Animationen muss ich keine in App Käufe machen?
                    Welche Version würdest du empfehlen, iphone oder ipad?
                    • BBTownB Offline
                      BBTownB Offline
                      BBTown
                      @RalfR72:
                      Welche Version würdest du empfehlen, iphone oder ipad? ` Ich meine doch, aber genau weiss ich das nicht mehr da ich einige InApp Käufe getätigt habe.
                      Am besten du schaust dir die Beschreibung der APP an.
                      Ich nutze die App sowohl auf dem iPhone als auch auf dem iPad
                        Kueppert
                        Kann man solche Szenen eigentlich auch exportieren und anderen zur Verfügung stellen??
                        Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                        • BBTownB Offline
                          BBTownB Offline
                          BBTown
                          @Kueppert:
                          Kann man solche Szenen eigentlich auch exportieren und anderen zur Verfügung stellen?? `
                          Können heißt ja nicht automatisch auch dürfen …
                            Kueppert
                            Das stimmt… Ging mir erst Mal nur um können... Kann ja sein dass jemand auch eine Szene gebaut hat und die teilen möchte ;) ist das in der Theorie möglich? Dürfen muss man das dann natürlich auch :) überlege auch, all4hue zu kaufen... Aber evtl kann man das, was man möchte, auch alles manuell im ioBroker mit Board Mitteln realisieren?! Ist erst Mal eine Idee...
                            • BBTownB Offline
                              BBTownB Offline
                              BBTown
                              Ist es denn nicht so, dass über das HUE-Szene-Objekt eine bestehende HUE-Szene gestartet werden kann, und "mehr nicht" ?
                              Soll heißen, wir schreiben ja nix in die Echos`s
                              Daher bin ich unsicher ob/wie ein Export bei jemand anderen zum Abspielen bewegt werden kann 8-)
                              • C Offline
                                cernst1980
                                @Kueppert:
                                Aber evtl kann man das, was man möchte, auch alles manuell im ioBroker mit Board Mitteln realisieren?! Ist erst Mal eine Idee… `
                                Ja, kann man…
                                http://forum.iobroker.net/viewtopic.php ... hue+szenen
                                • C Offline
                                  cernst1980
                                  @BBTown:
                                  Ist es denn nicht so, dass über das HUE-Szene-Objekt eine bestehende HUE-Szene gestartet werden kann, und "mehr nicht" ? `
                                  Das ist korrekt.
                                  Es gibt zwei Ansätze:
                                  1. Man baut Szenen in ioBroker und steuert dann die einzelnen Lampen über den Hue Adapter in Helligkeit, Farbe, … (z.B. verlinktes Skript vorheriger Beitrag)
                                  2. Man nutzt die Szenen, die in der Hue Bridge gespeichert sind, und aktiviert diese über ioBroker (mein Skript)
                                  Jetzt könnte man natürlich theoretisch auch noch beide Punkte kombinieren, und über ioBroker Szenen in der Hue Bridge erstellen, die man dann aktivieren kann.
                                  Dann würde man aber sowas wie "iConnectHue" nachbauen, das scheint mir nicht sinnvoll zu sein, hätte aber den Vorteil, dass man die Szenen auch ohne ioBroker nutzen kann, z.B. Hue Dimmer Switch, ...
                                  Dies geht bei Option 1 erstmal nicht OOB.
                                    mikiline
                                    ich bin nach dem ersten Post gegangen und installiert….
                                    Nun habe ich leider das Problem das der Javascript Adapter das npm Modul node-hue-api nicht lädt.
                                    Ich kann es eintragen aber es wird nicht gespeichert.
                                    Nach erneutem Aufruf des Adapters steht kein Modul zum Laden mehr drinne
                                    Hat wer einen Rat?
                                    • C Offline
                                      cernst1980
                                      @mikiline:
                                      Ich kann es eintragen aber es wird nicht gespeichert. `
                                      Eintragen und Enter drücken, damit es grau hinterlegt wird, erst dann speichern!?
                                        mikiline
                                        Jaaa, das war der Trick….Herzlichen Dank ;)
                                        • cashC Offline
                                          cashC Offline
                                          cash
                                          Mal eine andere Frage: Und zwar habe ich eine Hue Iris. In der App habe ich einen Wecker erstellt mit Sonnenlicht hokus pokus. Dabei wird das Licht während der Weckdauer immer heller…
                                          Durch das script hier habe ich jetzt auch u. a. eine Wake-up Szene. Da ich die nicht selber angelegt habe gehe ich davon aus das diese eben durch den Wecker in der Hue App angelegt wurde. Jetzt wäre meine Idee diese Szene in einen Wecker in iobroker zu nutzen, weil der Hue Wecker halt irgendwie dumm ist und nicht weiß wann ein Feiertag oder wann ich Urlaub habe...
                                          Leider funktioniert die Szene nicht richtig. Schalte ich diese über iobroker ein wird zwar das richtige Licht eingeschaltet und auch auf kleinster Stufe nur heller wird es leider nicht.
                                          Ich vermute dafür sind die Szenen eigentlich nicht gemacht und es funktioniert deshalb nicht?
