  4. Zigbee v3.1.5 plötzlich keine Verbindung mehr
    6.8k
71 Beiträge 9 Kommentatoren 3.6k Aufrufe 8 Beobachtet
  • T tilly
    Nach dem Update des Zigbee Adapters von 3.1.5 auf 3.3.5 bekomme ich wieder keine Verbindung.
    Auch das Ändern des Pfades bring keine Abhilfe.
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
    2026-02-11 10:25:41.607  - debug: zigbee.0 (1869) Test connection for /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
    2026-02-11 10:25:41.609  - debug: zigbee.0 (1869) reading access rights for /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
    2026-02-11 10:25:41.610  - debug: zigbee.0 (1869) read and write access available for /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
    2026-02-11 10:25:41.611  - info: zigbee.0 (1869) Try to reconnect. 1 attempts left
    2026-02-11 10:25:41.612  - info: zigbee.0 (1869) Starting Adapter npm ...
    2026-02-11 10:25:41.617  - info: zigbee.0 (1869) Installed Version: iobroker.zigbee@3.3.5 (Converters 25.112.0 Herdsman 8.1.0)
    2026-02-11 10:25:41.618  - info: zigbee.0 (1869) configured transmit power : high
    2026-02-11 10:25:41.619  - info: zigbee.0 (1869) Starting Zigbee-Herdsman
    2026-02-11 10:25:41.688  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Starting zigbee-herdsman...","ack":true,"ts":1770801941684,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770801941684}
    2026-02-11 10:25:42.092  - info: zigbee.0 (1869) Unable to obtain herdsman settings
    2026-02-11 10:25:42.123  - error: zigbee.0 (1869) Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port
    2026-02-11 10:25:42.125  - error: zigbee.0 (1869) Failed to start Zigbee: no message given
    2026-02-11 10:25:42.147  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Unable to obtain herdsman settings","ack":true,"ts":1770801942143,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770801942143}
    2026-02-11 10:25:42.148  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port","ack":true,"ts":1770801942143,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770801942143}
    2026-02-11 10:25:42.154  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1770801942149,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770724947942}
    2026-02-11 10:25:42.228  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Failed to start Zigbee: no message given","ack":true,"ts":1770801942224,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770801942224}
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @tilly sagte in Zigbee v3.1.5 plötzlich keine Verbindung mehr:
    Bitte genau folgendes machen:
    • Adapter auf info stellen. Das umstellen auf debug oder silly bringt nicht mehr infos, es flutet Dein log nur mit Rauschen.
    • Adapter anhalten (falls er aktiv ist)
    • 60 s warten (wichtig)
    • Konfigurationsinterface des Adapters öffnen (während der Adapter nicht läuft)
    • Auf das 'Hardware' Tab gehen
    • Adapter starten (geht aus der Titelzeile :
    • 60 sekunden abwarten - schauen ob der Adapter durch startet. Im Log-Fenster unten im Hardware Tab sollten meldungen stehen.
    Diese Meldungen hier posten. (als Text)
    • Sollte das ZIgbee Netz nicht starten und keine meldungen erscheinen über den Start/Stop button weiter unten versuchen das Netz zu starten
    A.
    • AsgothianA Asgothian
      A.
      tilly
      @Asgothian Komisch, jetzt hat er durchgestartet.
      Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20200805 (2-1.2.7.1)
      Network parameters: panID=6728 channel=26 extendedPanID=d9dddddddcddddcd
      Unable to disable LED, unsupported function.
      40 devices and 2 groups are part of the network
      • AsgothianA Offline
        AsgothianA Offline
        Asgothian
        Nicht komisch.
        bis 3.3.0 gab es das Problem das der Admin den Zigbee Adapter nicht sauber beendet hat. Dadurch kam es beim Update manchmal zu Problemen wenn der Adapter neu gestartet werden sollte - er wurde neu gestartet bevor er vollständig beendet wurde.
        Das war leider (auch) ein problem des JSControllers und wurde dann erst mit dem JSCOntroller 7.1 gefixed.
        A.
          Nicht komisch.
          A.
          tilly
          @Asgothian sagte in Zigbee v3.1.5 plötzlich keine Verbindung mehr:
          JSCOntroller 7.1
          habe gerade mal geschaut
          superpoli@iobroker:~$ iobroker -v
          7.0.7
          Warum installiert er denn nicht die 7.1?
          Host    "iobroker"       is up to date.
          • T tilly
            JSCOntroller 7.1
            7.0.7
            weil du wahrscheinlich brav im stable Repository unterwegs bist!.
              tilly
              schrieb am zuletzt editiert von tilly
              Ich habe nun Iobroker auf 7.1 geupdatet. Habe aber nach einen Neustart immer wieder Probleme, das Zigbee nicht richtig startet.
              Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
              Nach mehreren Versuchen funktioniert es dann.
              Thomas BraunT arteckA 2 Antworten Letzte Antwort
              • T tilly
                @tilly
                Aktualisier mal die Firmware auf dem Stick.
                • T tilly
                  arteckA Offline
                  arteckA Offline
                  arteck
                  20200805
                  das ist aber arg ALT
                    tilly
                    Ich finde leider keine passende Firmware.
                    UniFlash zum flashen habe ich installiert, aber wo gibts die aktuelle Firmware, bei TI finde ich leider nichts.
                    • T tilly
                      @tilly
                      Findet sich hier:
                      https://github.com/Koenkk/Z-Stack-firmware
                      bzw. genauer hier:
                      https://github.com/Koenkk/Z-Stack-firmware/releases/tag/Z-Stack_3.x.0_coordinator_20250321
                        tilly
                        Habe diese "CC1352P2_CC2652P_launchpad_coordinator_20250321.zip"
                        UniFlash drauf gespielt.
                        Er bekommt aber leider keine Verbindung.
                        Network parameters in Config     : panID=6728 channel=26 extendedPanID=cddddddcddddddd9
                        Network parameters on Coordinator: panID=65534 channel=0 extendedPanID=cddddddcddddddd9
                        • T tilly
                          @tilly
                          Die panID muss übereinstimmen.
                            tilly
                            Oh Danke, das war es.
                              tilly
                              Zu früh gefreut, nach kurzer Zeit wieder die Verbindung verloren.
                              Wenn ich es jetzt ausschalte, mind. 60s warte und wieder einschalte, kommt das:
                              • T tilly
                                kommt das:
                                wo?
                                nach einem iob log sieht das nicht aus.
                                klingt nach serial Problemen
                                  tilly
                                  Im Zigbee Adapter unter Hardware.
                                  HomoranH haselchenH 2 Antworten Letzte Antwort
                                  • T tilly
                                    @tilly
                                    immer noch?
                                    wenn ja, was sagt in dem Moment ls -la /dev/serial/by-id/ ?
                                      tilly
                                      Ja immer noch.
                                      total 0
                                      drwxr-xr-x 2 root root 80 Mär 21 15:37 .
                                      drwxr-xr-x 4 root root 80 Mär 21 15:37 ..
                                      lrwxrwxrwx 1 root root 13 Mär 21 15:37 usb-Texas_Instruments_XDS110__03.00.00.41__Embed_with_CMSIS-DAP_L43002RW-if00 -> ../../ttyACM0
                                      lrwxrwxrwx 1 root root 13 Mär 21 15:37 usb-Texas_Instruments_XDS110__03.00.00.41__Embed_with_CMSIS-DAP_L43002RW-if03 -> ../../ttyACM1
                                      • T tilly
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @tilly
                                        Korrigiere mal Deinen Channel (gelbes Dreieck)
                                        Haste sonst noch woanders gelbe Dreiecke?
                                        • T tilly
                                          Ja immer noch.
                                          total 0
                                          Ja immer noch.
                                          welcher davon ist der zuständige Stick?
                                          und was steht in der Konfiguration?
