  4. Zigbee v3.1.5 plötzlich keine Verbindung mehr
    6.8k
71 Beiträge 9 Kommentatoren 3.6k Aufrufe 8 Beobachtet
  • T tilly
    Umzug geht weiter, leider bekomme ich zum Zigbee keine Verbindung.
    zigbee.0
    2026-02-07 11:19:02.483	error	Failed to start Zigbee: no message given
    zigbee.0
    2026-02-07 11:19:02.482	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    zigbee.0
    2026-02-07 11:19:02.253	info	Unable to obtain herdsman settings
    zigbee.0
    2026-02-07 11:18:41.290	debug	getDevices called from system.adapter.admin.1 with command "getDevices" without ID
    zigbee.0
    2026-02-07 11:18:41.280	debug	getCoordinatorInfo result: {"installSource":"iobroker.zigbee@3.1.5","channel":"26","port":"/dev/ttyACM0","installedVersion":"3.1.5","type":"zstack","revision":"not connected","version":"not connected","herdsman":"6.4.2","converters":"25.31.0","autostart":true}
    zigbee.0
    2026-02-07 11:18:41.227	debug	get groupes called with {"command":"getGroups","message":{},"from":"system.adapter.admin.1","callback":{"message":{},"id":41,"ack":false,"time":1770459521168},"_id":64084252} disconnected
    zigbee.0
    2026-02-07 11:18:41.179	debug	get groupes called with {"command":"getGroups","message":{},"from":"system.adapter.admin.1","callback":{"message":{},"id":41,"ack":false,"time":1770459521168},"_id":64084252}
    zigbee.0
    2026-02-07 11:18:41.178	debug	Commands: Command getGroups is unknown
    zigbee.0
    2026-02-07 11:18:41.176	debug	readNvBackup returns {"channel":26,"precfgkey":"01030507090b0d0f00020406080a0c0d","extPanID":"d9dddddddcddddcd","panID":6728}
    zigbee.0
    2026-02-07 11:18:41.173	debug	readNvBackup called
    zigbee.0
    2026-02-07 11:18:35.581	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2026_02_07-11_18_35.tar.gz success
    zigbee.0
    2026-02-07 11:18:35.542	info	Starting Zigbee-Herdsman
    zigbee.0
    2026-02-07 11:18:35.541	info	configured transmit power : high
    zigbee.0
    2026-02-07 11:18:35.538	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
    zigbee.0
    2026-02-07 11:18:35.511	info	Starting Adapter npm ...
    zigbee.0
    2026-02-07 11:18:35.510	info	Autostart Zigbee subsystem
    zigbee.0
    2026-02-07 11:18:35.509	info	--- creating device debug ---
    zigbee.0
    2026-02-07 11:18:35.334	info	init localConfig
    zigbee.0
    2026-02-07 11:18:35.329	info	Adapter ready - starting subsystems. Adapter is running in silly mode.
    zigbee.0
    2026-02-07 11:18:35.249	info	starting. Version 3.1.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.22.0, js-controller: 7.0.7
    zigbee.0
    2026-02-07 11:18:34.653	debug	Plugin sentry Initialize Plugin (enabled=true)
    zigbee.0
    2026-02-07 11:18:34.559	debug	States connected to redis: 0.0.0.0:9000
    zigbee.0
    2026-02-07 11:18:34.425	debug	States create User PubSub Client
    zigbee.0
    2026-02-07 11:18:34.424	debug	States create System PubSub Client
    zigbee.0
    2026-02-07 11:18:34.379	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    zigbee.0
    2026-02-07 11:18:34.279	debug	Objects connected to redis: 0.0.0.0:9001
    zigbee.0
    2026-02-07 11:18:34.267	debug	Objects client initialize lua scripts
    zigbee.0
    2026-02-07 11:18:34.111	debug	Objects create User PubSub Client
    zigbee.0
    2026-02-07 11:18:34.109	debug	Objects create System PubSub Client
    zigbee.0
    2026-02-07 11:18:34.106	debug	Objects client ready ... initialize now
    zigbee.0
    2026-02-07 11:18:34.028	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    -- hier stand usinn, sorry.--
    • AsgothianA Asgothian
      tilly
      Jetzt habe ich noch Proble mit SQL.
      sql.0
      2026-02-09 09:19:25.586	error	Error: connect ECONNREFUSED 127.0.0.1:3306
      sql.0
      2026-02-09 09:19:25.574	debug	Borrow connection from pool: 1 now
      Obwohl Backup gemacht und wieder eingespielt:
      Last login: Sat Feb  7 11:42:41 2026 from 192.168.115.26
      superpoli@iobroker:~$ systemctl status mysql.service
      Unit mysql.service could not be found.
      • T tilly
        sql.0
        sql.0
        @tilly sagte in Zigbee v3.1.5 plötzlich keine Verbindung mehr:
        Bitte einen neuen Thread für ein neues Problem.
          tilly
          Nach dem Update des Zigbee Adapters von 3.1.5 auf 3.3.5 bekomme ich wieder keine Verbindung.
          Auch das Ändern des Pfades bring keine Abhilfe.
          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
          2026-02-11 10:25:41.607  - debug: zigbee.0 (1869) Test connection for /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
          2026-02-11 10:25:41.609  - debug: zigbee.0 (1869) reading access rights for /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
          2026-02-11 10:25:41.610  - debug: zigbee.0 (1869) read and write access available for /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L43002RW-if00
          2026-02-11 10:25:41.611  - info: zigbee.0 (1869) Try to reconnect. 1 attempts left
          2026-02-11 10:25:41.612  - info: zigbee.0 (1869) Starting Adapter npm ...
          2026-02-11 10:25:41.617  - info: zigbee.0 (1869) Installed Version: iobroker.zigbee@3.3.5 (Converters 25.112.0 Herdsman 8.1.0)
          2026-02-11 10:25:41.618  - info: zigbee.0 (1869) configured transmit power : high
          2026-02-11 10:25:41.619  - info: zigbee.0 (1869) Starting Zigbee-Herdsman
          2026-02-11 10:25:41.688  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Starting zigbee-herdsman...","ack":true,"ts":1770801941684,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770801941684}
          2026-02-11 10:25:42.092  - info: zigbee.0 (1869) Unable to obtain herdsman settings
          2026-02-11 10:25:42.123  - error: zigbee.0 (1869) Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port
          2026-02-11 10:25:42.125  - error: zigbee.0 (1869) Failed to start Zigbee: no message given
          2026-02-11 10:25:42.147  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Unable to obtain herdsman settings","ack":true,"ts":1770801942143,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770801942143}
          2026-02-11 10:25:42.148  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port","ack":true,"ts":1770801942143,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770801942143}
          2026-02-11 10:25:42.154  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1770801942149,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770724947942}
          2026-02-11 10:25:42.228  - silly: zigbee.0 (1869) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Failed to start Zigbee: no message given","ack":true,"ts":1770801942224,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1770801942224}
          Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
          • T tilly
            Irgendwas / irgendwer greift auf das Gerät schon zu.
            Stehst du da (vielleicht in der Konsole) selber drauf?
            Versuch mal einen Neustart, das ist am saubersten und wirft ziemlich sicher die bestehenden locks raus.
            • T tilly
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              Bitte genau folgendes machen:
              • Adapter auf info stellen. Das umstellen auf debug oder silly bringt nicht mehr infos, es flutet Dein log nur mit Rauschen.
              • Adapter anhalten (falls er aktiv ist)
              • 60 s warten (wichtig)
              • Konfigurationsinterface des Adapters öffnen (während der Adapter nicht läuft)
              • Auf das 'Hardware' Tab gehen
              • Adapter starten (geht aus der Titelzeile :
              • 60 sekunden abwarten - schauen ob der Adapter durch startet. Im Log-Fenster unten im Hardware Tab sollten meldungen stehen.
              Diese Meldungen hier posten. (als Text)
              • Sollte das ZIgbee Netz nicht starten und keine meldungen erscheinen über den Start/Stop button weiter unten versuchen das Netz zu starten
              A.
                A.
                tilly
                @Asgothian Komisch, jetzt hat er durchgestartet.
                Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20200805 (2-1.2.7.1)
                Network parameters: panID=6728 channel=26 extendedPanID=d9dddddddcddddcd
                Unable to disable LED, unsupported function.
                40 devices and 2 groups are part of the network
                • AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  Nicht komisch.
                  bis 3.3.0 gab es das Problem das der Admin den Zigbee Adapter nicht sauber beendet hat. Dadurch kam es beim Update manchmal zu Problemen wenn der Adapter neu gestartet werden sollte - er wurde neu gestartet bevor er vollständig beendet wurde.
                  Das war leider (auch) ein problem des JSControllers und wurde dann erst mit dem JSCOntroller 7.1 gefixed.
                  A.
                    Nicht komisch.
                    A.
                    tilly
                    @Asgothian sagte in Zigbee v3.1.5 plötzlich keine Verbindung mehr:
                    JSCOntroller 7.1
                    habe gerade mal geschaut
                    superpoli@iobroker:~$ iobroker -v
                    7.0.7
                    Warum installiert er denn nicht die 7.1?
                    Host    "iobroker"       is up to date.
                    • T tilly
                      JSCOntroller 7.1
                      7.0.7
                      weil du wahrscheinlich brav im stable Repository unterwegs bist!.
                        tilly
                        schrieb am zuletzt editiert von tilly
                        Ich habe nun Iobroker auf 7.1 geupdatet. Habe aber nach einen Neustart immer wieder Probleme, das Zigbee nicht richtig startet.
                        Nach mehreren Versuchen funktioniert es dann.
                        Thomas BraunT arteckA 2 Antworten Letzte Antwort
                        • T tilly
                          @tilly
                          Aktualisier mal die Firmware auf dem Stick.
                          • T tilly
                            arteckA Offline
                            arteckA Offline
                            arteck
                            20200805
                            das ist aber arg ALT
                              tilly
                              Ich finde leider keine passende Firmware.
                              UniFlash zum flashen habe ich installiert, aber wo gibts die aktuelle Firmware, bei TI finde ich leider nichts.
                              • T tilly
                                @tilly
                                Findet sich hier:
                                https://github.com/Koenkk/Z-Stack-firmware
                                bzw. genauer hier:
                                https://github.com/Koenkk/Z-Stack-firmware/releases/tag/Z-Stack_3.x.0_coordinator_20250321
                                  tilly
                                  Habe diese "CC1352P2_CC2652P_launchpad_coordinator_20250321.zip"
                                  UniFlash drauf gespielt.
                                  Er bekommt aber leider keine Verbindung.
                                  Network parameters in Config     : panID=6728 channel=26 extendedPanID=cddddddcddddddd9
                                  Network parameters on Coordinator: panID=65534 channel=0 extendedPanID=cddddddcddddddd9
                                  • T tilly
                                    @tilly
                                    Die panID muss übereinstimmen.
                                      tilly
                                      Oh Danke, das war es.
                                        tilly
                                        Zu früh gefreut, nach kurzer Zeit wieder die Verbindung verloren.
                                        Wenn ich es jetzt ausschalte, mind. 60s warte und wieder einschalte, kommt das:
                                        • T tilly
                                          kommt das:
                                          wo?
                                          nach einem iob log sieht das nicht aus.
                                          klingt nach serial Problemen
