  4. Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana
    6.4k
75 Beiträge 8 Kommentatoren 6.9k Aufrufe 7 Beobachtet
    @marcelinho sagte in Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana:
    WS eingebe wird der Adapter nicht mehr grün
    und was kommt im log?
    marcelinho
    @crunchip
    zigbee2mqtt.0
    2026-01-04 21:57:08.955	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2026-01-04 21:57:07.951	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2026-01-04 21:57:06.947	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2026-01-04 21:57:05.940	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2026-01-04 21:57:04.934	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2026-01-04 21:57:03.930	warn	Start try again in 1 seconds...
    zigbee2mqtt.0
    2026-01-04 21:57:03.790	info	==================================================================================
    zigbee2mqtt.0
    2026-01-04 21:57:03.790	info	|| Coordinator Check Cron : 0 3 * * *
    zigbee2mqtt.0
    2026-01-04 21:57:03.790	info	|| Coordinator Check Loglevel: info
    zigbee2mqtt.0
    2026-01-04 21:57:03.790	info	|| Use Automatic Coordinator Check: yes
    zigbee2mqtt.0
    2026-01-04 21:57:03.789	info	|| Use Simple Press/Release State: no
    zigbee2mqtt.0
    2026-01-04 21:57:03.789	info	|| Use Simple Move/Stop State: no
    zigbee2mqtt.0
    2026-01-04 21:57:03.789	info	|| Use Simple Hold/Release State: yes
    zigbee2mqtt.0
    2026-01-04 21:57:03.789	info	|| Use Device Icons: no
    zigbee2mqtt.0
    2026-01-04 21:57:03.789	info	|| Use Event In Desc: yes
    zigbee2mqtt.0
    2026-01-04 21:57:03.788	info	|| Use BrightnessStep OnOff: no
    zigbee2mqtt.0
    2026-01-04 21:57:03.788	info	|| Use BrightnessMove OnOff: no
    zigbee2mqtt.0
    2026-01-04 21:57:03.788	info	|| Use ColorTemperature ColorSync: no
    zigbee2mqtt.0
    2026-01-04 21:57:03.788	info	|| Use Kelvin: no
    zigbee2mqtt.0
    2026-01-04 21:57:03.788	info	|| Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
    zigbee2mqtt.0
    2026-01-04 21:57:03.788	info	|| Zigbee2MQTT Debug Log: deactivated
    zigbee2mqtt.0
    2026-01-04 21:57:03.787	info	|| Zigbee2MQTT Websocket Dummy MQTT-Server: deactivated
    zigbee2mqtt.0
    2026-01-04 21:57:03.787	info	|| Zigbee2MQTT Websocket Auth-Token: unused
    zigbee2mqtt.0
    2026-01-04 21:57:03.786	info	|| Zigbee2MQTT Websocket Port: 8080
    zigbee2mqtt.0
    2026-01-04 21:57:03.785	info	|| Zigbee2MQTT Websocket Server: 192.168.2.198
    zigbee2mqtt.0
    2026-01-04 21:57:03.785	info	|| Zigbee2MQTT Websocket Scheme: ws
    zigbee2mqtt.0
    2026-01-04 21:57:03.784	info	|| Zigbee2MQTT Connection Type: ws
    zigbee2mqtt.0
    2026-01-04 21:57:03.784	info	|| Zigbee2MQTT Frontend Port: 8080
    zigbee2mqtt.0
    2026-01-04 21:57:03.784	info	|| Zigbee2MQTT Frontend Server: 192.168.2.198
    zigbee2mqtt.0
    2026-01-04 21:57:03.783	info	|| Zigbee2MQTT Frontend Scheme: http
    zigbee2mqtt.0
    2026-01-04 21:57:03.782	info	================================= Adapter Config =================================
    zigbee2mqtt.0
    2026-01-04 21:57:03.757	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v22.21.0, js-controller: 7.0.7
    host.raspberrypi
    2026-01-04 21:57:01.311	info	instance system.adapter.zigbee2mqtt.0 in version "3.0.9" started with pid 1979
    • M marcelinho
      @crunchip danke, ich möchte das es wie vorher war. Das ich auf die Web Socket komme. Der Adapter ist zwar grün meine Geräte werden alle erkannt (wohl wegen backitup) aber ich bekomme es nicht zum laufen. Bzw. wenn ich manuell zb. Licht aus/an schalte reagiert es nicht. Oder müsste die Yaml anders aussehen?
      crunchipC Offline
      crunchipC Offline
      also so? https://forum.iobroker.net/post/880192
      • MartinPM Online
        MartinPM Online
        MartinP
        Läuft denn überhaupt der externe zigbee2mqtt Server?
        Wenn ja, stimmt Port und IP Adresse?
        Mir scheint, der zigbee2mqtt Adapter findet keinen Server
        • MartinPM MartinP
          marcelinho
          @MartinP der externe zigbee2mqtt wird grün aber ich kann die Geräte nicht steuern. Ich denke die sind noch angelegt von dem backitup das ich eingespielt habe.
          || Zigbee2MQTT Version: 1.35.1
          || Coordinator type: zStack3x0
          || Network panid 19452 channel: 11
          mit Mosquitto kam auch die Nachricht an mit einem zweiten Putty Fenster:
          mosquitto_pub -h 192.168.2.198 -p 1885 ...
          mosquitto_sub -h 192.168.2.198 -p 1885 ...
          • MartinPM Online
            MartinPM Online
            MartinP
            Kommst Du denn auf die Webseite des zigbee2mqtt Servers?
            • MartinPM MartinP
              marcelinho
              @MartinP leider nicht. Adapter wird nur bei externer MQTT-Server grün bei Web Socket nicht
                hier die YAML
                ist doch ausgelegt für externen mqtt server, warum möchtest du jetzt umstellen?
                was sagte hier bereits
                @crunchip sagte in Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana:
                hier die YAML
                  hier die YAML
                  marcelinho
                  @Homoran ich glaube das ich den Zusammenhang zwischen externen mqtt server und Websocket nicht ganz verstehe. Ich möchte aufjedenfall wie auf meiner alten Karte das Web Socket konfigurieren.
                  • MartinPM Online
                    MartinPM Online
                    MartinP
                    Hmm ich benutze den zigbee2mqtt Adapter nicht. Der Zigbee2mqtt Server verbindet sich bei mir direkt mit mqtt.0.
                    Wenn Du mit dem Browser nicht auf das Web-Interface vom Zigbee2mqtt Server kommst, liegt dort etwas im Argen
                    • M marcelinho
                      crunchipC Offline
                      crunchipC Offline
                      @marcelinho dann mal nochmals alle Informationen am Stück und Kompakt
                      dein Raspberry/alte SIM mit der IP 192.168.2.198
                      darauf lief
                      • iobroker( darauf bereits ein Adapter/MQTT SERVER)
                      • influx
                      • Grafana
                      • Z2M v1.35.1
                      • Mosquitto
                      deine Neue SIM
                      bis jetzt installiert
                      • iobroker
                      • Z2M v2.7.2
                      • Mosquitto
                      https://github.com/Koenkk/zigbee2mqtt/discussions/24198 breaking changes
                        marcelinho
                        schrieb am zuletzt editiert von marcelinho
                        @crunchip
                        hier iob diag von meiner alten Micro SD:
                        107*** BASE SYSTEM ***
                        Static hostname: raspberrypi
                               Icon name: computer
                                  Kernel: Linux 6.12.47+rpt-rpi-v8
                            Architecture: arm64
                        OS is similar to:
                        Model        : Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                        21:18:05 up 53 min,  1 user,  load average: 0.31, 0.42, 0.59
                        CPU threads: 4
                        107*** LIFE CYCLE STATUS ***
                        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                        107*** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        107*** TIME AND TIMEZONES ***
                                       Local time: Fri 2026-01-02 21:18:05 CET
                                   Universal time: Fri 2026-01-02 20:18:05 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        107*** Users and Groups ***
                        User that called 'iob diag':
                        iobroker
                        HOME=/home/iobroker
                        iobroker
                        HOME=/home/iobroker
                        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                        A root login is not required in most Linux Distributions.
                        Run 'iobroker fix' or use the system tools to create a user.
                        107*** DISPLAY-SERVER SETUP ***
                        Display-Server:     false
                        Unit display-manager.service could not be found.
                        Display-Manager:
                        Desktop:
                        Session:
                        107*** MEMORY ***
                        Mem:            4.0G        3.0G        365M        610K        673M        966M
                        Swap:           209M        209M        516K
                        Total:          4.2G        3.2G        365M
                        Active iob-Instances:     28
                                 3796 M total memory
                                 2874 M used memory
                                 1981 M active memory
                                 1256 M inactive memory
                                  348 M free memory
                                   55 M buffer memory
                                  587 M swap cache
                                  199 M total swap
                                  199 M used swap
                                    0 M free swap
                        107*** top - Table Of Processes  ***
                        top - 21:18:06 up 54 min,  1 user,  load average: 0.31, 0.42, 0.59
                        Tasks: 232 total,   1 running, 231 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 11.1 us, 11.1 sy,  0.0 ni, 66.7 id, 11.1 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3796.9 total,    348.3 free,   2874.9 used,    642.8 buff/cache
                        MiB Swap:    200.0 total,      0.5 free,    199.5 used.    922.0 avail Mem
                        107*** FAILED SERVICES ***
                        0 loaded units listed.
                        107*** DMESG CRITICAL ERRORS ***
                        sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
                        sudo: a password is required
                        No critical errors detected
                        107*** FILESYSTEM ***
                        udev           devtmpfs  1.6G     0  1.6G   0% /dev
                        tmpfs          tmpfs     760M  1.2M  759M   1% /run
                        /dev/mmcblk0p2 ext4       29G   18G  9.3G  66% /
                        tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                        /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
                        tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
                        sudo
                        Show mounted filesystems:
                        TARGET           SOURCE         FSTYPE OPTIONS
                        /                /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        Archived and active journals take up 170.2M in the file system.
                        /opt/iobroker/backups:
                        145M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        1.8G    /opt/iobroker/iobroker-data/
                        1.4G    /opt/iobroker/iobroker-data/history
                        236M    /opt/iobroker/iobroker-data/files
                        109M    /opt/iobroker/iobroker-data/backup-objects
                        47M    /opt/iobroker/iobroker-data/files/admin.admin
                        49M    /opt/iobroker/iobroker-data/objects.jsonl
                        24M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                        9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                        9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
                        9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
                        107*** ZigBee Settings ***
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        107*** NodeJS-Installation ***
                        /usr/bin/nodejs     v22.21.1
                        /usr/bin/node         v22.21.1
                        /usr/bin/npm         11.6.4
                        /usr/bin/npx         11.6.4
                        /usr/bin/corepack     0.34.0
                        nodejs:
                          Installed: 22.21.1-1nodesource1
                          Candidate: 22.21.1-1nodesource1
                          Version table:
                        *** 22.21.1-1nodesource1 100
                        No problems detected
                        Errors in npm tree: 0
                        107*** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 3217)
                        Core adapters versions
                        admin:         7.7.19
                        javascript:     9.0.11
                        nodejs modules from github:     1
                        +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
                        Adapter State
                        + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
                        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                        + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
                        + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
                        + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
                        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                        + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                        + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
                        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
                        + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                        + system.adapter.sun2000.0                : sun2000               : raspberrypi                              -  enabled, port: 502
                        + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                        + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
                        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                          system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
                        + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Adapters
                        Used repository: stable
                        Adapter    "admin"        : 7.7.19   , installed 7.7.19
                        Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
                        Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                        Adapter    "daikin"       : 1.5.1    , installed 1.5.1
                        Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
                        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
                        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
                        Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
                        Adapter    "homekit-controller": 0.5.11, installed 0.5.11
                        Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                        Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                        Controller "js-controller": 7.0.7    , installed 7.0.7
                        Adapter    "lg-thinq"     : 1.1.3    , installed 1.1.3
                        Adapter    "meross"       : 1.17.0   , installed 1.17.0
                        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                        Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
                        Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
                        Adapter    "openhab"      : 1.2.0    , installed 1.2.0
                        Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                        Adapter    "sun2000"      : 2.3.5    , installed 2.3.5
                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                        Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                        Adapter    "vis-2"        : 2.13.4   , installed 2.13.8
                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                        Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
                        Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
                        auf meiner neuen Micro SD Karte sind alle Adapter Identisch zu meiner alten Micro SD Karte aus backitup wiederhergestellt, installiert und "grün".
                        MQTT Adapter ist ebenfalls grün, Zigbee2mqtt geht nicht über Web Socket.. Mosquitto ist ebenfalls installiert.
                        Was benötigst du noch? (kann Dir alle Daten von Zigbee2mqtt aus der json geben falls benötigt von der alten Karte)
                        Aber ich habe glaube einen grundlegenden Fehler nach der Installation gemacht, ich habe keinen seperaten user angelegt. Er lässt mich auch nicht auf der neuen Karte "iob diag" machen. Könnte das damit zusammenhängen?
                        pi@raspberrypi:~ $ iob diag
                        [sudo] password for iobroker:
                        Was influx betrifft und Grafana -- bin ich noch nicht gekommen, möchte erst Zigbee2mqtt zum laufen bekommen das zumindest mal wieder meine Automationen, Lichter etc. laufen.
                        crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                        • MartinPM Online
                          MartinPM Online
                          MartinP
                          So lange das Web-Interface des externen zigbee2mqtt Servers nicht läuft ist die Fehlersuche von iobroker aus meiner Meinung nach wenig erfolgversprechend...
                          Kommst Du mit dem Browser auf die Seite
                          http://192.168.2.198:8080/#/settings/settings
                          • M marcelinho
                            @crunchip
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            iobroker
                            HOME=/home/iobroker
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:
                            107*** MEMORY ***
                                     3796 M total memory
                                     2874 M used memory
                                      348 M free memory
                                       55 M buffer memory
                                      587 M swap cache
                                      199 M total swap
                                      199 M used swap
                                        0 M free swap
                            sudo
                            /var:
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm         11.6.4
                            /usr/bin/npx         11.6.4
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:         7.7.19
                            javascript:     9.0.11
                            Adapter State
                            + instance is alive
                            crunchipC Offline
                            crunchipC Offline
                            darum habe ich oben gelistet, was installiert war und ist (Mosquitto trage ich nach) dann sollte dir selbst auffallen was fehlt
                            naja, das Grundgerüst sollte schon passen
                            • MartinPM MartinP
                              marcelinho
                              @MartinP ja komme ich aber da muss ich alles einstellen obwohl ich die YAML konfiguriert habe.
                              • M marcelinho
                                @crunchip
                                       Icon name: computer
                                    Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                iobroker
                                HOME=/home/iobroker
                                iobroker
                                HOME=/home/iobroker
                                Display-Manager:
                                Desktop:
                                Session:
                                107*** MEMORY ***
                                         3796 M total memory
                                         2874 M used memory
                                          348 M free memory
                                           55 M buffer memory
                                          587 M swap cache
                                          199 M total swap
                                          199 M used swap
                                            0 M free swap
                                sudo
                                /var:
                                USB-Devices by-id:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm         11.6.4
                                /usr/bin/npx         11.6.4
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:         7.7.19
                                javascript:     9.0.11
                                Adapter State
                                + instance is alive
                                Natürlich.
                                Mit welchem user hast du denn den ioBroker installiert?
                                Diesem user werden dann im Zuge der Installation auch die passenden Rechte übertragen.
                                Nach der iob-Installation einmal reboot und als erste Aktion dann ein
                                iob stop
                                iob fix
                                iob start
                                schließt die Installation final ab.
                                • M marcelinho
                                  crunchipC Offline
                                  crunchipC Offline
                                  ich weiß zwar nicht was mit backitup alles bei z2m gesichert wird, gehe aber mal davon aus, wenn man das zurückspielt, nichts mehr eingestellt werden muss, andernfalls passt ggf etwas mit deinen Rechten nicht. Allerdings mit fehlender yaml z2m gar nicht erst starten dürfte
                                    marcelinho
                                    @crunchip das heisst ich installiere z2m und mosquitto manuell über SSH und das hat nichts mit dem z2m adapter in iobroker zu tun, richtig?
                                    • M marcelinho
                                      crunchipC Offline
                                      crunchipC Offline
                                      @marcelinho na der zigbee2mqtt Adapter ist der eine Baustein, ohne den anderen Baustein z2m installiert zu haben geht der Adapter nicht. Mosquitto ist dafür auch nicht zwingend nötig
                                      zeig mal die Ausgabe von
                                      systemctl status zigbee2mqtt.service
                                        marcelinho
                                        @crunchip
                                        pi@raspberrypi:~/zigbee2mqtt $ systemctl status zigbee2mqtt
                                        ● zigbee2mqtt.service - Zigbee2MQTT
                                             Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
                                             Active: active (running) since Mon 2026-01-05 23:10:43 CET; 3min 43s ago
                                         Invocation: 79bf1356b73f443196ef4396a24b1f7e
                                           Main PID: 4504 (npm start)
                                              Tasks: 19 (limit: 3920)
                                                CPU: 2.499s
                                             CGroup: /system.slice/zigbee2mqtt.service
                                                     ├─4504 "npm start"
                                                     ├─4515 sh -c "node index.js"
                                                     └─4516 node index.js
                                        Jan 05 23:10:43 raspberrypi systemd[1]: Started zigbee2mqtt.service - Zigbee2MQTT.
                                        Jan 05 23:10:44 raspberrypi npm[4504]: > zigbee2mqtt@2.7.2 start
                                        Jan 05 23:10:44 raspberrypi npm[4504]: > node index.js
                                        Jan 05 23:10:44 raspberrypi npm[4516]: Starting Zigbee2MQTT without watchdog.
                                        Jan 05 23:10:45 raspberrypi npm[4516]: Onboarding page is available at http://0.0.0.0:8080/
                                        pi@raspberrypi:~/zigbee2mqtt $ journalctl -u zigbee2mqtt -f
                                        • M marcelinho
                                          @crunchip
                                                  CPU: 2.499s
                                                       ├─4504 "npm start"
                                          crunchipC Offline
                                          crunchipC Offline
                                          active (running)
                                          ist installiert (ergänze ich oben) und v 2.7.2 läuft, passt, aber laut
                                          hast du dies eigentlich gemacht?
                                          https://forum.iobroker.net/post/1318134
