  4. Adapter: DasWetter
Adapter: DasWetter
1.7k Beiträge 249 Kommentatoren 718.6k Aufrufe 133 Beobachtet
  • stefu87_CHS Offline
    stefu87_CHS Offline
    stefu87_CH
    #1302
    @rene_hm Wieso bekomme ich den Log voll mit diesen Meldungen obwohl die Abfrage auf 10h eingestellt ist?
    2026-01-04 11:45:44.395 - error: daswetter.0 (69430) DasWetter_0: axios error in GetLocationPostcode: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767523544282,"info":{"message":"Quota Exceeded"}}
    2026-01-04 11:45:44.492 - error: daswetter.0 (69430) DasWetter_0: axios error in GetLocationFreetext: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767523544477,"info":{"message":"Quota Exceeded"}}
    2026-01-04 11:45:44.584 - error: daswetter.0 (69430) DasWetter_0: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767523544571,"info":{"message":"Quota Exceeded"}}
    2026-01-04 11:45:44.586 - error: daswetter.0 (69430) DasWetter_0: no location hash available, please check postcode and city settings
    2026-01-04 11:45:44.766 - error: daswetter.0 (69430) DasWetter_1: axios error in GetLocationPostcode: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767523544752,"info":{"message":"Quota Exceeded"}}
    2026-01-04 11:45:44.863 - error: daswetter.0 (69430) DasWetter_1: axios error in GetLocationFreetext: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767523544847,"info":{"message":"Quota Exceeded"}}
    2026-01-04 11:45:44.954 - error: daswetter.0 (69430) DasWetter_1: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767523544940,"info":{"message":"Quota Exceeded"}}
    2026-01-04 11:45:44.956 - error: daswetter.0 (69430) DasWetter_1: no location hash available, please check postcode and city settings
    Cores: 1 × 8 = 8 cores
    Threads: 16
    mit Proxmox
    LXC Container mit Iobroker
    Rene_HMR 1 Antwort Letzte Antwort
    • Rene_HMR Rene_HM
      @Rumpeltec "Symbol_description" wird jetzt (v4.3.0) in die jeweils eingestellte Sprache übersetzt. In meinem Testsystem in deutsch funktioniert das auch.
      Die 41 passenden Icons sind jetzt auch in der "Galeria 7" jetzt enthalten. Einfach in Icon-Einstellungen umschalten...
      Pedder007P Offline
      Pedder007P Offline
      Pedder007
      #1303
      @Rene_HM sagte in Adapter: DasWetter:
      Werden die Symbole denn seitens 'DasWetter' auch über 41 Icons aufgelöst?
      Oder wie erfolgt da eigentlich grundsätzlich die Zuordnung (evtl. nur ganz kurz damit ich's verstehe) ;-)
      Pedder
      All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
      Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
      Under construction: Smart-WoMo auf Raspi4
      • stefu87_CHS stefu87_CH
        Rene_HMR Offline
        Rene_HMR Offline
        Rene_HM
        #1304
        @stefu87_CH wie häufig kommen diese logs? Ich sehe hier um 11:45. Erfolgt die nächste Abfrage wirklich erst um 21:45?
        • Pedder007P Pedder007
          Rene_HMR Offline
          Rene_HMR Offline
          Rene_HM
          #1305
          @Pedder007 sagte in Adapter: DasWetter:
          DasWetter schickt eine Symbol-ID. Zusätzlich kann man die Beschreibung für jeden Wert über die API abholen. In dieser Beschreibung sind 41 Zustände aufgelistet, also müssen 41 Symbole vorhanden sein...
          Pedder007P 1 Antwort Letzte Antwort
          • Rene_HMR Rene_HM
            stefu87_CHS Offline
            stefu87_CHS Offline
            stefu87_CH
            #1306
            Kann ich dann heute Abend schauen und dir eine Rückmeldung geben
            Threads: 16
            mit Proxmox
              stefu87_CHS Offline
              stefu87_CHS Offline
              stefu87_CH
              schrieb am zuletzt editiert von stefu87_CH
              #1307
              @rene_hm
              Ist jetzt schon wieder gekommen:
              2026-01-04 12:30:44.560 - error: daswetter.0 (70140) DasWetter_0: axios error in GetLocationPostcode: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767526244474,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:30:44.655 - error: daswetter.0 (70140) DasWetter_0: axios error in GetLocationFreetext: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767526244642,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:30:44.754 - error: daswetter.0 (70140) DasWetter_0: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767526244733,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:30:44.755 - error: daswetter.0 (70140) DasWetter_0: no location hash available, please check postcode and city settings
              2026-01-04 12:30:44.900 - error: daswetter.0 (70140) DasWetter_1: axios error in GetLocationPostcode: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767526244888,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:30:44.997 - error: daswetter.0 (70140) DasWetter_1: axios error in GetLocationFreetext: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767526244986,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:30:45.083 - error: daswetter.0 (70140) DasWetter_1: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767526245073,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:30:45.084 - error: daswetter.0 (70140) DasWetter_1: no location hash available, please check postcode and city settings
              Und 15 Minuten Später nochmals:
              2026-01-04 12:45:44.459 - error: daswetter.0 (70745) DasWetter_0: axios error in GetLocationPostcode: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767527144339,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:45:44.555 - error: daswetter.0 (70745) DasWetter_0: axios error in GetLocationFreetext: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767527144543,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:45:44.662 - error: daswetter.0 (70745) DasWetter_0: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767527144644,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:45:44.663 - error: daswetter.0 (70745) DasWetter_0: no location hash available, please check postcode and city settings
              2026-01-04 12:45:44.919 - error: daswetter.0 (70745) DasWetter_1: axios error in GetLocationPostcode: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767527144906,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:45:45.012 - error: daswetter.0 (70745) DasWetter_1: axios error in GetLocationFreetext: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767527144999,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:45:45.109 - error: daswetter.0 (70745) DasWetter_1: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767527145095,"info":{"message":"Quota Exceeded"}}
              2026-01-04 12:45:45.110 - error: daswetter.0 (70745) DasWetter_1: no location hash available, please check postcode and city settings
              Threads: 16
              mit Proxmox
              • Rene_HMR Rene_HM
                Pedder007P Offline
                Pedder007P Offline
                Pedder007
                schrieb am zuletzt editiert von Pedder007
                #1308
                @Rene_HM danke Dir !
                Ein anderer Punkt ist mir gerade noch aufgefallen:
                Anscheinend prognostiziert 'DasWetter' auch keine echte Sunshine Duration mehr für den jeweiligen Standort (also z. B. 8 Std. minus 4 Std. Bewölkung o. ä.). Die ausgegeben Zeit scheint einfach nur noch die Zeit zwischen Sonnenauf- und Untergang zu sein.
                Das ist echt schade, da ich anhand der vorher prognostizierten Zeit immer gesteuert habe, wie weit mein PV-Akku entladen werden darf (1. wg. ggf. größerer Reserve und 2. auch um unnötiges Nachladen des Akkus aus dem Netz zu vermeiden).
                Und wo ich gerade so schreibe fällt mir noch etwas auf:
                Bei den Formaten für Mond- und Sonnen- Auf- und Untergang scheint etwas aus dem Tritt geraten zu sein. Ich hatte diese die Tage aktualisiert, nun bekomme ich in der VIS-Widget 'basic - Times Value' allerdings nichts mehr angezeigt.
                Schaut man in den Objektbaum, sieht es dort zw. Mond und Sonne aber auch nochmals unterschiedlich aus:
                Mond: Da stehen Uhrzeiten, allerdings habe die Objekte kein Zeitformat. Um den Inhalt zu sehen muss man z. B. ein 'basic- String' Widget nehmen.
                Sonne: Das steht im Feld des Objektbaumes direkt 'Invalide Date'
                Hierzu noch ein Nachtrag, der mich gerade etwas stutzen lässt:
                Die o. g. Angaben zu den 'in' und 'out' Datenfeldern beziehen sich auf die Auswahl-View via VIS1.
                Geht man direkt in den IOB Objektbaum stehen da in allen 4 Feldern zwar Uhrzeiten, aber es sind alles 'String-Felder'.
                PS. bin auf der 4.3.0
                Pedder
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  schrieb am zuletzt editiert von Rene_HM
                  #1309
                  Das hat DasWetter noch nie gemacht. In der alten Version des Adapters habe ich das selbst ausgerechnet, genau mit dem von dir beschriebenen Ziel. Basis war die Bewölkung in %, die die alte API geliefert hat. Die neue Version der API liefert diesen Wert nur noch für die Stundenbasierten Daten, aber nicht für den ganzen Tag. Somit ist die Sonnenscheindauer immer die Zeit zwischen Sonnenaufgang und -untergang. Hier muss ich ich mir noch etwas einfallen lassen...
                  Bzgl. der Zeiten hatte ich etwas Probleme. Ich war der Meinung, dass nun gelöst zu haben. Hintergrund ist, dass iobroker selbst die Zeitdarstellung im Menü anpasst je nachdem ob ein string oder eine number kommt und welcher Datentyp für den DP eingestellt ist. Anscheinend ist da immer noch etwas nicht richtig.
                  Bei mir sieht das aktuell so aus:
                  • Rene_HMR Rene_HM
                    Pedder007P Offline
                    Pedder007P Offline
                    Pedder007
                    #1310
                    @Rene_HM ok, das ist komisch, da ich da eine andere Erinnerung habe, aber wahrscheinlich steckst Du da tiefer drin :-) und ich bin da evtl. einem Irrtum aufgesessen.
                    Meinst Du mit dem 'einfallen lassen' eine Lösung, die Du entsprechend über den Adapter anbieten möchtest? Weil dann spare ich mir erstmal weitere eigene 'Basteleien'.
                    Bzgl. der Zeiten, siehe ggf. auch noch meinen Nachtrag im letzen Post.
                    Pedder
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      #1311
                      @Pedder007 ja, ich baue bzgl. der sunshine_duration etwas in den Adapter ein. Ich habe ja noch ein paar Tage, bis die Sonne wieder vernünftig für PV nutzbar ist und wir das benötigen...
                      Bzgl. der Zeiten: wahrscheinlich muss ich beides anbieten: "string" zur direkten Anzeige und "date" (und damit als Unix-timestamp) zur Weiterverarbeitung... Von der API kommt nur der Unix-timestamp und auf Hinweis hier aus der Forum wollte ich nur die Zeit ohne Datum anbieten....
                      • Rene_HMR Rene_HM
                        Rumpeltec
                        #1312
                        @Rene_HM
                        Ich habe auf v4.3.0 aktualisiert, leider bleibt der DP Symbol_description immer noch leer.
                        Vermutlich liegt es aber auch an dieser Fehlermeldung
                        "DasWetter_0: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767533108175,"info":{"message":"Quota Exceeded"}} DasWetter_0: axios error in GetSymbols: message=Request failed with status code 429, code=ERR_BAD_REQUEST, status=429, data={"ok":false,"expiracion":1767533108175,"info":{"message":"Quota Exceeded"}}"
                        Aktualisierungsintervall ist auf 360min gestellt.
                          @rene_hm
                          Rene_HMR Offline
                          Rene_HMR Offline
                          Rene_HM
                          #1313
                          @stefu87_CH @rumpeltec Wenn so häufig abgerufen wird, erklärt das auch den 429 - Status.
                          Die Frage ist nur, warum wird das update-Intervall nicht eingehalten. Kann es sein, dass aufgrund der Versuche mit dem Adapter noch irgendetwas bei euch im Hintergrund läuft? Im Adapter selbst läuft eigentlich nur ein s.g. intervall mit der eingestellten Zeit. Den Rest macht das System selbst. Beim Beenden des Adapters räume ich das intervall auf. Also sollte eigentlich alles drin sein, was notwendig ist.
                          -> velleicht die Systeme bei euch mal neu starten?
                          stefu87_CHS R 2 Antworten Letzte Antwort
                          • Rene_HMR Rene_HM
                            stefu87_CHS Offline
                            stefu87_CHS Offline
                            stefu87_CH
                            #1314
                            Da ich heute eh an meinem internen Netzwerk dran bin und diverse Systeme neu starte, werde ich den IOB auch mal direkt neu starten. Werde es beobachten.
                            Threads: 16
                            mit Proxmox
                            • Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #1315
                              Sollten die Mond Icons aktuell gehen?
                              In dem DP steht
                              /daswetter.admin/icons/luna-moon/15.png
                              aber wenn ich den DP
                              mit
                              {daswetter.0.location_1.ForecastDaily.Day_1.Moon_symbol_URL}
                              einbinde, findet er kein Bild.
                              Das Symbol für das aktuelle Wetter klappt.
                              Beta-Tester
                                Merlin123M Offline
                                Merlin123
                                #1316
                                Wie funktioniert das mit den Bildern für die Mondphasen?
                                Aktuell sollte er einen Halbmond anzeigen. Er nutzt das Bild
                                aber das sieht so aus
                                Beta-Tester
                                • 1Topf1 Offline
                                  1Topf1 Offline
                                  1Topf
                                  #1317
                                  Also bei uns ist aktuell Vollmond. Lebst Du in Deutschland? 😉
                                  Merlin123M 1 Antwort Letzte Antwort
                                  • 1Topf1 1Topf
                                    Merlin123M Offline
                                    Merlin123M Offline
                                    Merlin123
                                    #1318
                                    @1Topf Boah.... Ja... Du hast recht....
                                    Ich habe nach der aktuellen Mondphase gegoogelt und da steht
                                    Abnehmender Halbmond
                                    Jo... wenn man dann die Seite anklickt steht da:
                                    "Abnehmender Halbmond Erleuchtung: 98%"
                                    was eigentlich fast Vollmond ist. Da muss man erstmal drauf kommen....
                                    aber: Wieso wird der Vollmond dunkel dargestellt? Hätte da was helleres erwartet....
                                    Beta-Tester
                                    FeuersturmF 1Topf1 Thomas BraunT 3 Antworten Letzte Antwort
                                    • Merlin123M Merlin123
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      #1319
                                      @Merlin123 Kannst du mir sagen, wie ich mir die Wetter icons anzeigen lassen kann oder z.B. in vis1 verwenden kann?
                                      NegaleinN Merlin123M 2 Antworten Letzte Antwort
                                      • FeuersturmF Feuersturm
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #1320
                                        @Feuersturm sagte in Adapter: DasWetter:
                                        mein Widget
                                        [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"{daswetter.0.location_1.ForecastDaily.Day_1.symbol_URL}","stretch":true,"refreshOnWakeUp":true,"refreshOnViewChange":true},"style":{"left":"53px","top":"111px","width":"200px","height":"200px","z-index":"100"},"widgetSet":"basic"}]
                                        basic Image
                                        und als Quelle {daswetter.0.location_1.ForecastDaily.Day_1.symbol_URL}
                                        ° Fixer ---> iob fix
                                        • NegaleinN Negalein
                                          mein Widget
                                          basic Image
                                          FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          #1321
                                          @Negalein sagte in Adapter: DasWetter:
                                          basic Image
                                          Danke. Leider wird bei mir mit diesem Widget und der Quelle nichts angezeigt.
