  2. English
  3. ioBroker general
  4. Disable OS update on none debian/ubuntu installations
Geplant Angeheftet Gesperrt Verschoben ioBroker general
5 Beiträge 3 Kommentatoren 2.2k Aufrufe 3 Beobachtet
  • A
    A
    AIXroot
    I would like to get rid of the following annoying warning message:
    "Could not check for new OS updates: Command failed: sudo apt list --upgradeable The flag --upgradeable is not known."
    I am running iobroker on openSUSE, which is known not to work with apt/.deb, but with zypper/.rpm.
    Where do I disable the OS updates check in iobroker?
    Thanks and regards
    Norbert
    System data:
    Operating System: openSUSE Tumbleweed
    Hardware: Standard PC
    Core adapters versions:
    js-controller: 7.0.7
    admin: 7.7.19
    javascript: 9.0.11
    /usr/bin/node v22.21.1
    /usr/bin/npm 10.9.4
    /usr/bin/npx 10.9.4
    Installation Type: manually without docker
    • A AIXroot
      Thanks and regards
      Norbert
      System data:
      admin: 7.7.19
      javascript: 9.0.11
      /usr/bin/npm 10.9.4
      /usr/bin/npx 10.9.4
      crunchipC
      crunchipC
      Developer Global Moderator Most Active Forum Testing
      @AIXroot sagte in Disable OS update on none debian/ubuntu installations:
      • A
        A
        AIXroot
        I had not installed notification.manager until now. Installing it and activating the option did not help either.
        • ilovegymI
          ilovegymI
          ilovegym
          Hi Norbert, how does it appears? In the admin-tab of the web interface, or in the command line, can you provide a screenshot, please?
          • A AIXroot
            crunchipC
            crunchipC
            @AIXroot
            Corrected Workaround for openSUSE (zypper/rpm)
            The js-controller executes sudo apt list --upgradeable directly, which fails on openSUSE because apt exists but lacks the --upgradeable flag.
            Exact Procedure
            sudo ln -sf /bin/true /usr/bin/apt
            iobroker restart
            What happens?
            Before: sudo apt list --upgradeable → "The flag --upgradeable is not known" error.
            After: /usr/bin/apt links to /bin/true (always exits with code 0/success).
            Result: js-controller receives "success" → logs "OS updates: 0 available", no more error messages.​
            Why safe & reversible?
            /bin/true is a standard Linux binary (does nothing, always succeeds).
            No real apt functionality affected (openSUSE doesn't use apt anyway).
            Undo: sudo rm /usr/bin/apt && iobroker restart.
            83.8k
