  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Thomas-Braun
    Habe ich oben geändert
    martin@RaspberryPi-Iobroker:/opt/iobroker $ npm cache clear --force
    iobroker url iobroker.rpi2@latest --debug
    npm warn using --force Recommended protections disabled.
    install iobroker.rpi2@latest
    NPM version: 11.6.2
    Installing iobroker.rpi2@latest... (System call)
    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm warn deprecated gauge@2.7.4: This package is no longer supported.
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    > iobroker.rpi2@3.0.2 preinstall
    > bash ./preinstall-check.sh
    Checking package: libgpiod-dev >= 2.2
    libgpiod-dev version OK: 2.2.1-2+deb13u1
    > @stoprocent/bluetooth-hci-socket@1.5.2 install
    > node-gyp-build
    > @stoprocent/noble@1.19.1 install
    > node-gyp-build
    gyp info it worked if it ends with ok
    gyp info using node-gyp@7.1.2
    gyp info using node@24.12.0 | linux | arm64
    (node:10253) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    (Use `node --trace-deprecation ...` to show where the warning was created)
    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
    gyp ERR! Completion callback never invoked!
    gyp ERR! System Linux 6.12.47+rpt-rpi-2712
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
    gyp ERR! node -v v24.12.0
    gyp ERR! node-gyp -v v7.1.2
    gyp ERR! Node-gyp failed to build your package.
    gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    > cpu-features@0.0.10 install
    > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
    (node:10286) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
    > diskusage@1.2.0 install
    > node-gyp rebuild
    (node:10300) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/diskusage
    > node-dht-sensor@0.4.5 install
    > node-gyp configure
    (node:10316) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
    gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
    > opengpio@2.0.2 install
    > node-gyp rebuild
    (node:10330) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/opengpio
    npm error code 6
    npm error path /opt/iobroker/node_modules/opengpio
    npm error command failed
    npm error command sh -c node-gyp rebuild
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T17_51_41_550Z-debug-0.log
    npm error code 6
    host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
    #116
    @Gonzokalle
    ls -l /opt/iobroker/node_modules/.bin/
    G 1 Antwort Letzte Antwort
      @Gonzokalle
      Gonzokalle
      #117
      @Thomas-Braun
      martin@RaspberryPi-Iobroker:/opt/iobroker $ ls -l /opt/iobroker/node_modules/.bin/
      insgesamt 0
      lrwxrwxrwx 1 iobroker iobroker 17 27. Dez 10:52 ci -> ../ci/dist/cli.js
      lrwxrwxrwx 1 iobroker iobroker 23 27. Dez 10:40 color-support -> ../color-support/bin.js
      lrwxrwxrwx 1 iobroker iobroker 23 27. Dez 10:40 crc32 -> ../crc-32/bin/crc32.njs
      lrwxrwxrwx 1 iobroker iobroker 22 27. Dez 10:40 esbuild -> ../esbuild/bin/esbuild
      lrwxrwxrwx 1 iobroker iobroker 33 27. Dez 10:40 fxparser -> ../fast-xml-parser/src/cli/cli.js
      lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 glob -> ../glob/dist/esm/bin.mjs
      lrwxrwxrwx 1 iobroker iobroker 23 27. Dez 10:40 hexy -> ../hexy/bin/hexy_cmd.js
      lrwxrwxrwx 1 iobroker iobroker 37 27. Dez 10:40 iobroker -> ../iobroker.js-controller/iobroker.js
      lrwxrwxrwx 1 iobroker iobroker 19 28. Dez 18:51 is-docker -> ../is-docker/cli.js
      lrwxrwxrwx 1 iobroker iobroker 19 27. Dez 10:40 json5 -> ../json5/lib/cli.js
      lrwxrwxrwx 1 iobroker iobroker 25 27. Dez 10:40 js-yaml -> ../js-yaml/bin/js-yaml.js
      lrwxrwxrwx 1 iobroker iobroker 14 27. Dez 10:40 mime -> ../mime/cli.js
      lrwxrwxrwx 1 iobroker iobroker 20 27. Dez 10:40 mkdirp -> ../mkdirp/bin/cmd.js
      lrwxrwxrwx 1 iobroker iobroker 25 27. Dez 10:40 mqtt -> ../mqtt/build/bin/mqtt.js
      lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 mqtt_pub -> ../mqtt/build/bin/pub.js
      lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 mqtt_sub -> ../mqtt/build/bin/sub.js
      lrwxrwxrwx 1 iobroker iobroker 23 27. Dez 10:40 multicast-dns -> ../multicast-dns/cli.js
      lrwxrwxrwx 1 iobroker iobroker 27 28. Dez 18:51 node-gyp -> ../node-gyp/bin/node-gyp.js
      lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 node-gyp-build -> ../node-gyp-build/bin.js
      lrwxrwxrwx 1 iobroker iobroker 29 27. Dez 10:40 node-gyp-build-optional -> ../node-gyp-build/optional.js
      lrwxrwxrwx 1 iobroker iobroker 31 27. Dez 10:40 node-gyp-build-test -> ../node-gyp-build/build-test.js
      lrwxrwxrwx 1 iobroker iobroker 22 27. Dez 10:40 node-inspect -> ../node-inspect/cli.js
      lrwxrwxrwx 1 iobroker iobroker 40 27. Dez 10:40 node-pre-gyp -> ../@mapbox/node-pre-gyp/bin/node-pre-gyp
      lrwxrwxrwx 1 iobroker iobroker 23 27. Dez 10:40 node-which -> ../which/bin/node-which
      lrwxrwxrwx 1 iobroker iobroker 19 27. Dez 10:40 nopt -> ../nopt/bin/nopt.js
      lrwxrwxrwx 1 iobroker iobroker 25 28. Dez 18:51 patch-package -> ../patch-package/index.js
      lrwxrwxrwx 1 iobroker iobroker 28 27. Dez 10:40 prettier -> ../prettier/bin/prettier.cjs
      lrwxrwxrwx 1 iobroker iobroker 57 27. Dez 10:40 proto-loader-gen-types -> ../@grpc/proto-loader/build/bin/proto-loader-gen-types.js
      lrwxrwxrwx 1 iobroker iobroker 26 27. Dez 10:40 rimraf -> ../rimraf/dist/esm/bin.mjs
      lrwxrwxrwx 1 iobroker iobroker 23 27. Dez 10:40 semver -> ../semver/bin/semver.js
      lrwxrwxrwx 1 iobroker iobroker 23 27. Dez 10:40 sshpk-conv -> ../sshpk/bin/sshpk-conv
      lrwxrwxrwx 1 iobroker iobroker 23 27. Dez 10:40 sshpk-sign -> ../sshpk/bin/sshpk-sign
      lrwxrwxrwx 1 iobroker iobroker 25 27. Dez 10:40 sshpk-verify -> ../sshpk/bin/sshpk-verify
      lrwxrwxrwx 1 iobroker iobroker 19 27. Dez 10:40 tldts -> ../tldts/bin/cli.js
      lrwxrwxrwx 1 iobroker iobroker 21 27. Dez 10:40 tsc -> ../typescript/bin/tsc
      lrwxrwxrwx 1 iobroker iobroker 26 27. Dez 10:40 tsserver -> ../typescript/bin/tsserver
      lrwxrwxrwx 1 iobroker iobroker 21 27. Dez 10:40 uuid -> ../uuid/dist/bin/uuid
      lrwxrwxrwx 1 iobroker iobroker 42 27. Dez 10:40 wake -> ../@iobroker-javascript.0/wake_on_lan/wake
      lrwxrwxrwx 1 iobroker iobroker 15 28. Dez 18:51 yaml -> ../yaml/bin.mjs
      • G Gonzokalle
        @Thomas-Braun
        insgesamt 0
        #118
        @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
        Diese Links gibt es auf meinem System nicht:
        Deswegen wird wohl bei mir node-gyp global aufgerufen, vermute ich.
        Keine Ahnung, ob man die beiden mal löschen könnte.
          Gonzokalle
          #119
          @Thomas-Braun
          So kommen wir ja nicht weiter.
          Werde bei Gelegenheit Trixi neu aufspielen.
          Vielen Dank für euren Einsatz.
          • G Gonzokalle
            @Thomas-Braun
            #120
            @Gonzokalle
            Wenn du ohnehin neuinstallieren willst kannst du ja zuvor einfach mal den Link löschen und schauen was passiert.
            crunchipC G 2 Antworten Letzte Antwort
              @Gonzokalle
              crunchipC Abwesend
              crunchipC Abwesend
              #121
              @Thomas-Braun oder noch auslesen woher node-gyp@7.1.2 kommt bzw local löschen und neu installieren
                @Gonzokalle
                Gonzokalle
                #122
                @Thomas-Braun
                Das würde ich ja machen.
                Dazu bräuchte ich aber den vollständigen Pfad.
                Mit dem Desktop kann ich ja nicht mehr suchen.
                • G Gonzokalle
                  @Thomas-Braun
                  #123
                  @Gonzokalle
                  rm /opt/iobroker/node_modules/.bin/node-gyp
                  rm /opt/iobroker/node_modules/.bin/node-pre-gyp
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    #124
                    oder vllt einfach so
                    sudo -u iobroker bash
                    cd /opt/iobroker
                    iob stop
                    rm -rf node_modules/node-gyp node_modules/.bin/node-gyp*
                    npm cache clean --force
                    npm i
                    iob add rpi2 --unsafe-permissions
                    iob start
                      @Gonzokalle
                      Gonzokalle
                      schrieb am zuletzt editiert von Gonzokalle
                      #125
                      @Thomas-Braun
                      Das hat wohl geklappt
                      martin@RaspberryPi-Iobroker:~ $ rm /opt/iobroker/node_modules/.bin/node-gyp
                      martin@RaspberryPi-Iobroker:~ $ rm /opt/iobroker/node_modules/.bin/node-pre-gyp
                      rm: das Entfernen von '/opt/iobroker/node_modules/.bin/node-pre-gyp' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                      rm: das Entfernen von '/opt/iobroker/node_modules/.bin/node-gyp' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                      Das sieht nicht so gut aus.
                      martin@RaspberryPi-Iobroker:~ $ iob stop
                      martin@RaspberryPi-Iobroker:~ $ npm cache clean --force
                      martin@RaspberryPi-Iobroker:~ $ npm i
                      npm error code ENOENT
                      npm error syscall open
                      npm error path /home/martin/package.json
                      npm error errno -2
                      npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/martin/package.json'
                      npm error enoent This is related to npm not being able to find a file.
                      npm error enoent
                      npm error A complete log of this run can be found in: /home/martin/.npm/_logs/2025-12-29T16_37_52_751Z-debug-0.log
                      martin@RaspberryPi-Iobroker:~ $ iob add rpi2 --unsafe-permissions
                      NPM version: 11.6.2
                      Installing iobroker.rpi2@2.4.0... (System call)
                      npm error code 6
                      npm error (node:94916) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                      npm error (Use `node --trace-deprecation ...` to show where the warning was created)
                      npm error gyp ERR! Completion callback never invoked!
                      npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712
                      npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                      npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                      npm error gyp ERR! node -v v24.12.0
                      npm error gyp ERR! node-gyp -v v7.1.2
                      npm error gyp ERR! Node-gyp failed to build your package.
                      npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-29T16_38_17_978Z-debug-0.log
                      host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@2.4.0: 6
                      • G Gonzokalle
                        @Thomas-Braun
                        npm error errno -2
                        npm error enoent
                        NPM version: 11.6.2
                        npm error code 6
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #126
                        im falschen Verzeichnis
                          Gonzokalle
                          #127
                          @crunchip
                          In das Verzeichnis komme ich erst gar nicht.
                          Ich denke mal das PW vom iobroker ist gemeint.
                          martin@RaspberryPi-Iobroker:~ $ su - iobroker && cd /opt/iobroker
                          Passwort:
                          su: Fehler bei Authentifizierung
                          Passwort:
                          Passwort:
                          HomoranH crunchipC Thomas BraunT 3 Antworten Letzte Antwort
                          • G Gonzokalle
                            @crunchip
                            Passwort:
                            Passwort:
                            Passwort:
                            #128
                            das gibt es nicht!
                            es geht um DEIN sudo passwort
                            doch!
                            aber den systemuser user iobroker bekommst du nicht aufgerufen
                            • G Gonzokalle
                              @crunchip
                              Passwort:
                              Passwort:
                              Passwort:
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #129
                              @Gonzokalle habs oben korrigiert
                              • G Gonzokalle
                                @crunchip
                                Passwort:
                                Passwort:
                                Passwort:
                                #130
                                @Gonzokalle
                                Dann schau jetzt mal ob du den Adapter installiert bekommst.
                                  @Gonzokalle
                                  Gonzokalle
                                  #131
                                  @Thomas-Braun
                                  martin@RaspberryPi-Iobroker:~ $ iobroker url iobroker.rpi2@latest  --debug
                                  NPM version: 11.6.2
                                  > node-gyp-build
                                  > node-gyp-build
                                  (node:98580) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                  (node:98614) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                  > node-gyp rebuild
                                  (node:98629) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                  > node-gyp configure
                                  (node:98643) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                  > node-gyp rebuild
                                  (node:98657) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                  npm error code 6
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-29T17_42_20_656Z-debug-0.log
                                  npm error code 6
                                  • G Gonzokalle
                                    @Thomas-Braun
                                    NPM version: 11.6.2
                                    > node-gyp-build
                                    > node-gyp-build
                                    > node-gyp rebuild
                                    > node-gyp configure
                                    > node-gyp rebuild
                                    npm error code 6
                                    npm error code 6
                                    #132
                                    Zieht sich immer noch irgendwoher die veraltete Version.
                                    Bei dir wird vermutlich dies der Fall sein:
                                    Lokale Installation im Projekt
                                    Viele Projekte installieren node-gyp als lokale Abhängigkeit (in node_modules/.bin).
                                    Wenn du npm install ausführst, wird oft die in der package.json oder package-lock.json festgelegte Version verwendet – und die kann veraltet sein.
                                    Lösung: Prüfe die package.json und package-lock.json auf die Version von node-gyp und aktualisiere sie ggf. mit:
                                    npm update node-gyp
                                    Also wird in einer deiner package.json oder package-lock.json die alte node-gyp drin stehen.
                                    Schau mal per
                                    cd /opt/iobroker/
                                    grep -R --include \*package* '"node-gyp":'
                                    danach.
                                    G HomoranH 2 Antworten Letzte Antwort
                                      npm update node-gyp
                                      Schau mal per
                                      cd /opt/iobroker/
                                      danach.
                                      Gonzokalle
                                      #133
                                      @Thomas-Braun
                                      cd /opt/iobroker/
                                      node_modules/nan/package.json:    "node-gyp": "~v10.3.1",
                                      node_modules/@serialport/bindings-cpp/package.json:    "node-gyp": "9.4.0",
                                      node_modules/iobroker.zigbee/node_modules/@serialport/bindings-cpp/package.json:    "node-gyp": "11.0.0",
                                      node_modules/zigbee-herdsman/node_modules/@serialport/bindings-cpp/package.json:    "node-gyp": "11.0.0",
                                      grep: node_modules/.bin/patch-package: Datei oder Verzeichnis nicht gefunden
                                      node_modules/zigbee-herdsman-converters/node_modules/@serialport/bindings-cpp/package.json:    "node-gyp": "11.0.0",
                                      package-lock.json:        "node-gyp": "bin/node-gyp.js"
                                      package-lock.json:        "node-gyp": "^7.1.2"
                                        npm update node-gyp
                                        Schau mal per
                                        cd /opt/iobroker/
                                        danach.
                                        #134
                                        @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
                                        du hast ja editiert 😉
                                        ich wollte dich gestern schon fragen ob es Sinn ergäbe die package-lock.json zu löschen.
                                        aber da steht ja ^ 7.1.2 drin
                                        • G Gonzokalle
                                          @Thomas-Braun
                                          cd /opt/iobroker/
                                          #135
                                          @Gonzokalle
                                          iob stop
                                          rm /opt/iobroker/package-lock.json
                                          cd /opt/iobroker/
                                          npm i
                                          iob start
