  4. Raspi 4 mit IOBroker stürzt immer wieder ab
    6.4k
38 Beiträge 8 Kommentatoren 1.7k Aufrufe 7 Beobachtet
  • W wibear
    @Homoran sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
    iob diag
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: raspi
           Icon name: computer
              Kernel: Linux 6.12.34+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     13:35:13 up 10 days, 22:10,  2 users,  load average: 0.29, 0.38, 0.43
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest                          stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-12-09 13:35:14 CET
               Universal time: Tue 2025-12-09 12:35:14 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    raspi
    HOME=/home/raspi
    GROUPS=raspi adm dialout cdrom sudo audio video plugdev games users input render                          netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        2.8G        146M        294K        1.1G        1.2G
    Swap:           536M        536M        204K
    Total:          4.5G        3.3G        147M
    Active iob-Instances:   27
             3795 M total memory
             2662 M used memory
             1603 M active memory
             1861 M inactive memory
              140 M free memory
               76 M buffer memory
              985 M swap cache
              511 M total swap
              511 M used swap
                0 M free swap
    top - 13:35:14 up 10 days, 22:10,  2 users,  load average: 0.29, 0.38, 0.43
    Tasks: 238 total,   1 running, 237 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us, 16.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.9 total,    139.7 free,   2663.0 used,   1062.0 buff/cache
    MiB Swap:    512.0 total,      0.2 free,    511.8 used.   1132.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/sda2      ext4       55G   26G   27G  49% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   58M  453M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Nov 28 15:24:37 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1                          snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nv                         me.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm                         i=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.maca                         ddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  con                         sole=ttyAMA0,115200 console=tty1 root=PARTUUID=b39521b8-02 rootfstype=ext4 fsck.                         repair=yes rootwait
    [Fri Nov 28 15:24:43 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a                         -87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Fri Nov 28 15:24:44 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd                         44114eb820 r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437                         ,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    7.5G    /var/
    4.0G    /var/log/journal/23c0d95e6b18424ba8497a2a3730c531
    4.0G    /var/log
    1.8G    /var/cache/apt
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
           Icon name: computer
        Architecture: arm64
    OS is similar to:
    Docker          : false
    Kernel          : aarch64
    Userland        : 64 bit
    CPU threads: 4
    Current issues:
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    raspi
    HOME=/home/raspi
    iobroker
    HOME=/home/iobroker
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
             3795 M total memory
             2662 M used memory
              140 M free memory
               76 M buffer memory
              985 M swap cache
              511 M total swap
              511 M used swap
                0 M free swap
    *** FILESYSTEM ***
    TARGET           SOURCE    FSTYPE OPTIOArchived and active journals take up 3.9G                          in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp-display/.piolibdeps/esp-display/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp-display/.piolibdeps/esp-display/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp-display/.piolibdeps/esp-display/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp-display/.piolibdeps/esp-display/ESPAsyncWebServer-esphome': Permission denie                         d
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display4/.piolibdeps/display4/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display4/.piolibdeps/display4/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display4/.piolibdeps/display4/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display7/.piolibdeps/display7/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display7/.piolibdeps/display7/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display7/.piolibdeps/display7/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/AsyncMqttClient-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemos/.piolibdeps/wemos/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemos/.piolibdeps/wemos/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemos/.piolibdeps/wemos/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemos/.piolibdeps/wemos/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/AsyncMqttClient-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosdisplay/.piolibdeps/wemosdisplay/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosdisplay/.piolibdeps/wemosdisplay/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosdisplay/.piolibdeps/wemosdisplay/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosdisplay/.piolibdeps/wemosdisplay/ESPAsyncWebServer-esphome': Permission den                         ied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/AsyncMqttClient-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         displaytft/.piolibdeps/displaytft/ArduinoJson': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         displaytft/.piolibdeps/displaytft/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         displaytft/.piolibdeps/displaytft/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosesp/.piolibdeps/wemosesp/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosesp/.piolibdeps/wemosesp/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosesp/.piolibdeps/wemosesp/ESPAsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosesp/.piolibdeps/wemosesp/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         tftdisplay/.piolibdeps/tftdisplay/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         tftdisplay/.piolibdeps/tftdisplay/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         tftdisplay/.piolibdeps/tftdisplay/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         tftdisplay/.piolibdeps/tftdisplay/ESPAsyncWebServer-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display-tft/.piolibdeps/display-tft/libsodium': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display-tft/.piolibdeps/display-tft/noise-c': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display-tft/.piolibdeps/display-tft/AsyncTCP-esphome': Permission denied
    du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display-tft/.piolibdeps/display-tft/ESPAsyncWebServer-esphome': Permission denie                         d
    1.2G    /opt/iobroker/iobroker-data/
    863M    /opt/iobroker/iobroker-data/esphome.0
    861M    /opt/iobroker/iobroker-data/esphome.0/.esphome
    849M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
    205M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibd                         eps/esp-display/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibd                         eps/esp-display/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibd                         eps/esp-display/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibd                         eps/esp-display/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps                         /display4/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps                         /display4/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps                         /display4/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps                         /display7/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps                         /display7/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps                         /display7/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/AsyncMqttClient-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/we                         mos/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/we                         mos/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/we                         mos/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/we                         mos/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/AsyncMqttClient-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolib                         deps/wemosdisplay/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolib                         deps/wemosdisplay/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolib                         deps/wemosdisplay/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolib                         deps/wemosdisplay/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/AsyncMqttClient-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibde                         ps/displaytft/ArduinoJson': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibde                         ps/displaytft/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibde                         ps/displaytft/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps                         /wemosesp/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps                         /wemosesp/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps                         /wemosesp/ESPAsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps                         /wemosesp/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibde                         ps/tftdisplay/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibde                         ps/tftdisplay/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibde                         ps/tftdisplay/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibde                         ps/tftdisplay/ESPAsyncWebServer-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibd                         eps/display-tft/libsodium': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibd                         eps/display-tft/noise-c': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibd                         eps/display-tft/AsyncTCP-esphome': Permission denied
    find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibd                         eps/display-tft/ESPAsyncWebServer-esphome': Permission denied
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.pioenvs/esp3                         2/firmware.elf
    23M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.pioenvs/d                         isplay7/firmware.elf
    19M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.pioenvs                         /tftdisplay/firmware.elf
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw                         ays prefer the links 'by-id':
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 P                         ackages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspi               raspi (version: 7.0.7, hostname: raspi         , alive, upti                         me: 943932)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     2
    +-- iobroker.esphome@0.6.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.                         git#ebd79f96c6c48650ad3b818e9b6ef9c6b4106e76)
    +-- iobroker.vw-connect@0.7.15 (git+ssh://git@github.com/ta2k/ioBroker.vw-connec                         t.git#f756508d8a444a476296f880c2ae1ac3e3010beb)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi                                                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                         n
    + system.adapter.alexa2.0                 : alexa2                : raspi                                                             -  enabled
    + system.adapter.backitup.0               : backitup              : raspi                                                             -  enabled
      system.adapter.birthdays.0              : birthdays             : raspi                                                             -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : raspi                                                             -  enabled
    + system.adapter.discovery.0              : discovery             : raspi                                                             -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : raspi                                                             -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspi                                                             -  enabled
    + system.adapter.esphome.0                : esphome               : raspi                                                             -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspi                                                             -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspi                                                             -  enabled
      system.adapter.habpanel.0               : habpanel              : raspi                                                             -  enabled
    + system.adapter.history.0                : history               : raspi                                                             -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspi                                                             -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspi                                                             -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspi                                                             -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspi                                                             -  enabled, port: 12010
    + system.adapter.influxdb.0               : influxdb              : raspi                                                             -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : raspi                                                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspi                                                             -  enabled, port: 1883, bind: 192.168.178.10
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                                             - disabled
    + system.adapter.shelly.0                 : shelly                : raspi                                                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspi                                                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspi                                                             -  enabled, port: 8087, bind: 192.168.178.10, run a                         s: admin
    + system.adapter.sonoff.0                 : sonoff                : raspi                                                             -  enabled, port: 1886, bind: 192.168.178.10
    + system.adapter.tr-064.0                 : tr-064                : raspi                                                             -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : raspi                                                             -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspi                                                             -  enabled
    + system.adapter.web.0                    : web                   : raspi                                                             -  enabled, port: 8082, bind: 192.168.178.10, run a                         s: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                                             -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                                     │                          auto upgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │                          true         │
    │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │                          false        │
    Active repo(s): stable
    Upgrade policy: patch
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "ems-esp"      : 6.0.1    , installed 6.0.1
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Objects and States
    Objects:        8353
    States:         6972
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
           Icon name: computer
        Architecture: arm64
    OS is similar to:
    Docker          : false
    Kernel          : aarch64
    Userland        : 64 bit
    CPU threads: 4
    Current issues:
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    raspi
    HOME=/home/raspi
    iobroker
    HOME=/home/iobroker
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
             3795 M total memory
             2662 M used memory
              140 M free memory
               76 M buffer memory
              985 M swap cache
              511 M total swap
              511 M used swap
                0 M free swap
    *** FILESYSTEM ***
    TARGET           SOURCE    FSTYPE OPTIOW: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Get:5 https://packages.grafana.com/oss/deb stable InRelease [7660 B]
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:8 https://apt.pivccu.de/piVCCU stable InRelease
    Err:5 https://packages.grafana.com/oss/deb stable InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 192.168.178.10:1884     0.0.0.0:*               LISTEN      1001       6157204    62739/io.mqtt.0
    tcp        0      0 192.168.178.10:1886     0.0.0.0:*               LISTEN      1001       13372      2860/io.sonoff.0
    tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       6157203    62739/io.mqtt.0
    tcp        0      0 192.168.178.10:8087     0.0.0.0:*               LISTEN      1001       13504      2971/io.simple-api.
    tcp        0      0 192.168.178.10:8082     0.0.0.0:*               LISTEN      1001       13973      3186/io.web.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3676       625/sshd: /usr/sbin
    tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       634157     9632/io.hm-rpc.1
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        7872       827/influxd
    tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       11665      2647/io.hm-rpc.2
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          3779       802/dnsmasq
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9276       1395/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9281       1395/iobroker.js-co
    tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       10119      2536/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       553251     8425/io.shelly.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3678       625/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      107        9267       1382/grafana
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6986       2110/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        5574       827/influxd
    udp        0      0 192.168.178.10:5353     0.0.0.0:*                           1001       13648      2867/io.esphome.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2939       495/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       550757     8432/io.shelly.1
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          3778       802/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          3775       802/dnsmasq
    udp        0      0 0.0.0.0:57463           0.0.0.0:*                           104        2941       495/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        2940       495/avahi-daemon: r
    udp6       0      0 :::45156                :::*                                104        2942       495/avahi-daemon: r
    udp6       0      0 fe80::6578:418f:682:546 :::*                                0          6296       567/NetworkManager
    2025-12-09 13:24:45.085  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 24.8
    2025-12-09 13:24:45.086  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
    2025-12-09 13:25:40.046  - info: host.raspi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 63599
    2025-12-09 13:25:42.694  - info: weatherunderground.0 (63599) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
    2025-12-09 13:25:51.977  - info: weatherunderground.0 (63599) Terminated (NO_ERROR): Without reason
    2025-12-09 13:25:52.516  - info: host.raspi instance system.adapter.weatherunderground.0 having pid 63599 terminated with code 0 (NO_ERROR)
    2025-12-09 13:27:08.712  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 24.4
    2025-12-09 13:27:08.713  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
    2025-12-09 13:29:18.072  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 24.1
    2025-12-09 13:29:18.074  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
    2025-12-09 13:32:16.966  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 24
    2025-12-09 13:32:16.967  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
    2025-12-09 13:35:01.354  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 23.9
    2025-12-09 13:35:01.355  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
    2025-12-09 13:35:52.430  - info: host.raspi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 63839
    2025-12-09 13:36:53.233  - warn: influxdb.0 (2337) Error on writePoint("{"value":-16.7,"time":"2025-12-09T12:35:52.827Z","from":"system.adapter.shelly.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
    2025-12-09 13:37:02.196  - info: influxdb.0 (2337) Currently no hosts available, try later
    2025-12-09 13:37:02.701  - warn: fb-checkpresence.0 (2933) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
    2025-12-09 13:37:10.420  - info: influxdb.0 (2337) Connecting http://localhost:8086/ ...
    2025-12-09 13:37:10.422  - info: influxdb.0 (2337) Influx DB Version used: 1.x
    2025-12-09 13:37:19.307  - info: weatherunderground.0 (63839) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
    2025-12-09 13:37:31.534  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 23.7
    2025-12-09 13:37:31.536  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
    2025-12-09 13:37:39.186  - info: weatherunderground.0 (63839) Terminated (NO_ERROR): Without reason
    2025-12-09 13:37:39.752  - info: host.raspi instance system.adapter.weatherunderground.0 having pid 63839 terminated with code 0 (NO_ERROR)
    iob diag has finished.
    @wibear sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
    Das grundsätzliche Problem dürfter hier zu suchen sein:
    *** MEMORY ***
    total used free shared buff/cache available
    Beim kompilieren geht dir der RAM aus.
    W 1 Antwort Letzte Antwort
      *** MEMORY ***
      W Offline
      W Offline
      wibear
      @Thomas-Braun sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
      Welche Lösung käme dann in Frage? Ein anderer Raspi?
      • W wibear
        @wibear
        Ja.
        Oder crosscompiling auf einer dickeren Maschine.
          @wibear
          Ja.
          W Offline
          W Offline
          wibear
          @wibear
          Ja.
          Die Abstürze gibt es auch sporadisch, ich habe schon lange nicht mehr ESPHome angefasst.
          Würde ein Raspi mit 8 GB RAM statt 4 wie jetzt dieses Problem lösen?
          • W wibear
            @wibear
            Ja.
            Ist ein wenig Glaskugellesen. Aber mehr RAM ist nie verkehrt.
            Meine Kiste zieht sich im Dauerbetrieb schon mehr als 4GB weg:
            echad@chet:~ $ free -ht
            Mem:           7.6Gi       4.2Gi       2.6Gi        10Mi       973Mi       3.5Gi
            Swap:          511Mi          0B       511Mi
            Total:         8.1Gi       4.2Gi       3.1Gi
            echad@chet:~
              echad@chet:~
              W Offline
              W Offline
              wibear
              schrieb am zuletzt editiert von wibear
              @Thomas-Braun
              Guten Abend, heute schon wieder ohne einen erkennbaren Grund abgestürzt. Über ein HDMI-Kabel verbunden war zwar die Console sichtbar, hat aber auf die Tastatur nicht mehr reagiert.
              Wie kann ich die Ursache nach dem Restart suchen/analysieren? Danke und Grüße
              • W wibear
                @Thomas-Braun
                Im journal.
                • W wibear
                  @Thomas-Braun
                  das ist meistens ein Zeichen von übermäßiger Load.
                  • Amoklaufendes Skript mit z.B. Schleifen
                  Das kann sich wieder fangen, danach könnte man mit top die Load der vergangenen 15 Minuten sehen, es kann aber auch zum reboot führen.
                  Auch zu wenig Arbeitsspeicher kann zu hoher load führen, wenn auf einmal wie verrückt ausgelagert wird, was natürlich länger dauert und ebenfalls die Load average hochtreibt.
                    W Offline
                    W Offline
                    wibear
                    @Homoran
                    Danke für superschnelle Antwort! Ich überlege es mir schon, auf ein NUC mit 8GB RAM mit ProxMox zu migrieren. Würde es Sinn machen?
                    HomoranH crunchipC 2 Antworten Letzte Antwort
                    • W wibear
                      @Homoran
                      bitte nicht am RAM geizen!
                      16 oder 32 sollten es bei einem NUC schon sein. So hoch sind die Mehrkosten nicht.
                      ich bin aber wieder davon weg zu einem dedizierten iob Server in Form eines Pi5 mit 8GB RAM.
                      • W wibear
                        @Homoran
                        crunchipC Offline
                        crunchipC Offline
                        nö,
                        denn aktuell reichen deine 4GB nicht, also brauchst du noch mindestens 2GB dazu, ergo bist du schon bei 6GB. Proxmox selbst braucht auch nochmal gern bis zu 2GB. Somit kein Verfügbarer Speicher für weitere LXC, geschweige denn VM`s
                          W Offline
                          W Offline
                          wibear
                          es läuft bei mir auch die RaspberryMatic auf dem Raspberry 4.
                          Welche Lösung würdet Ihr empfehlen?
                          • W wibear
                            sicher?
                            Meines Wissens läuft die nicht unter normalem Linux, sondern standalone unter buildroot.
                            Das läuft bei mir auf einem Tinkerboard mit 2GB RAM.
                            und wenn, dann hast du noch weniger Ressourcen.
                              sicher?
                              W Offline
                              W Offline
                              wibear
                              sicher?
                              die laufen schon seit ein Paar Jahren zusammen. Die Abstürze, vermute ich, hängen mit dem Einsatz eines ESPHome Displays mit vielen übertragenen Infos zusammen.
                              Was wäre Eurer Meinung nach für diese Kombination besser: ein NUC mit ProxMoc oder Raspi 5 8GB?
                              • W Offline
                                W Offline
                                wibear
                                Preislich gebraucht sind sie etwa gleich.
                                • W wibear
                                  sicher?
                                  crunchipC Offline
                                  crunchipC Offline
                                  was läuft denn aktuell und was soll künftig noch laufen, das weißt nur du. Was ist denn der Grund für Proxmox?
                                  Fakt ist, du brauchst mehr Ram
                                  • W Offline
                                    W Offline
                                    wibear
                                    Wie es schon im 1. Post steht, auf einem Raspi 4 mit 4 GB laufen IOBroker und pivCCU. Er stürzt sporadisch immer wieder ab und ich will einfach, dass es stabil läuft. Das ist alles. Es wird ein RAM Problem vermutet. Ich suche nach einer Lösung, ob ich zB einen Raspi mit mehr Speicher oder gleich einen NUC dafür einsetze.
                                    • W wibear
                                      und pivCCU
                                      das passt!
                                      nicht aber
                                      die RaspberryMatic
                                      was es auch sein wird!
                                      warum beantwortest du denn Fragen nicht?
                                      @crunchip sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
                                      • W Offline
                                        W Offline
                                        wibear
                                        Was Proxmox betrifft, hängt es mit einem Mini-PC zusammen, da dieser irgendein OS braucht. Außerdem hat so ein Mini deutlich mehr Power als Raspi.
                                        • W wibear
                                          woher hast du denn diese Informationen?
                                          beides ist so nicht richtig
                                          Proxmox ist eine Virtualisierungsumgebung, ein OS braucst du zusätzlich
                                          Du kannst auch direkt Debian auf dem NUC laufen lassen.
                                          Und ein kleiner Nuc muss noch lange nicht leistungsfähiger sein, als ein Pi5
