  4. Raspi 4 mit IOBroker stürzt immer wieder ab
    6.4k
38 Beiträge 8 Kommentatoren 1.7k Aufrufe 7 Beobachtet
    @FritzTheCat sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
    Ich würde mal auf Hitze tippen..
    das hätte iob diag @wibear schon gesagt
    • MartinPM Offline
      MartinPM Offline
      MartinP
      Wie performant ist das Netzteil?
      Irgendwelche "Brown Outs" in den Pi Loggings?
      Was sagt
      dmesg | grep -i "voltage"
      HomoranH W 2 Antworten Letzte Antwort
        W Offline
        W Offline
        wibear
        @Homoran sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
        iob diag
        Script v.2025-08-09
        *** BASE SYSTEM ***
         Static hostname: raspi
               Icon name: computer
                  Kernel: Linux 6.12.34+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         13:35:13 up 10 days, 22:10,  2 users,  load average: 0.29, 0.38, 0.43
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest                          stable release 'trixie' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2025-12-09 13:35:14 CET
                   Universal time: Tue 2025-12-09 12:35:14 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        raspi
        HOME=/home/raspi
        GROUPS=raspi adm dialout cdrom sudo audio video plugdev games users input render                          netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            4.0G        2.8G        146M        294K        1.1G        1.2G
        Swap:           536M        536M        204K
        Total:          4.5G        3.3G        147M
        Active iob-Instances:   27
                 3795 M total memory
                 2662 M used memory
                 1603 M active memory
                 1861 M inactive memory
                  140 M free memory
                   76 M buffer memory
                  985 M swap cache
                  511 M total swap
                  511 M used swap
                    0 M free swap
        top - 13:35:14 up 10 days, 22:10,  2 users,  load average: 0.29, 0.38, 0.43
        Tasks: 238 total,   1 running, 237 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 33.3 us, 16.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.9 total,    139.7 free,   2663.0 used,   1062.0 buff/cache
        MiB Swap:    512.0 total,      0.2 free,    511.8 used.   1132.9 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.2M  379M   1% /run
        /dev/sda2      ext4       55G   26G   27G  49% /
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/sda1      vfat      510M   58M  453M  12% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Fri Nov 28 15:24:37 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1                          snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nv                         me.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm                         i=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.maca                         ddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  con                         sole=ttyAMA0,115200 console=tty1 root=PARTUUID=b39521b8-02 rootfstype=ext4 fsck.                         repair=yes rootwait
        [Fri Nov 28 15:24:43 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a                         -87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
        [Fri Nov 28 15:24:44 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd                         44114eb820 r/w.
        Show mounted filesystems:
        TARGET           SOURCE    FSTYPE OPTIONS
        /                /dev/sda2 ext4   rw,noatime
        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437                         ,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        7.5G    /var/
        4.0G    /var/log/journal/23c0d95e6b18424ba8497a2a3730c531
        4.0G    /var/log
        1.8G    /var/cache/apt
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        raspi
        HOME=/home/raspi
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 3795 M total memory
                 2662 M used memory
                  140 M free memory
                   76 M buffer memory
                  985 M swap cache
                  511 M total swap
                  511 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        TARGET           SOURCE    FSTYPE OPTIOArchived and active journals take up 3.9G                          in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp-display/.piolibdeps/esp-display/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp-display/.piolibdeps/esp-display/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp-display/.piolibdeps/esp-display/AsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp-display/.piolibdeps/esp-display/ESPAsyncWebServer-esphome': Permission denie                         d
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display4/.piolibdeps/display4/ArduinoJson': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display4/.piolibdeps/display4/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display4/.piolibdeps/display4/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display7/.piolibdeps/display7/ArduinoJson': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display7/.piolibdeps/display7/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display7/.piolibdeps/display7/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/ArduinoJson': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/AsyncMqttClient-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/ESPAsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         espwemos/.piolibdeps/espwemos/ESPAsyncWebServer-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemos/.piolibdeps/wemos/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemos/.piolibdeps/wemos/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemos/.piolibdeps/wemos/ESPAsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemos/.piolibdeps/wemos/ESPAsyncWebServer-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/ArduinoJson': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/AsyncMqttClient-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/ESPAsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         test/.piolibdeps/test/ESPAsyncWebServer-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/ArduinoJson': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/AsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp32/.piolibdeps/esp32/ESPAsyncWebServer-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosdisplay/.piolibdeps/wemosdisplay/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosdisplay/.piolibdeps/wemosdisplay/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosdisplay/.piolibdeps/wemosdisplay/ESPAsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosdisplay/.piolibdeps/wemosdisplay/ESPAsyncWebServer-esphome': Permission den                         ied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/ArduinoJson': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/AsyncMqttClient-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/ESPAsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         esp8266/.piolibdeps/esp8266/ESPAsyncWebServer-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         displaytft/.piolibdeps/displaytft/ArduinoJson': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         displaytft/.piolibdeps/displaytft/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         displaytft/.piolibdeps/displaytft/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosesp/.piolibdeps/wemosesp/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosesp/.piolibdeps/wemosesp/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosesp/.piolibdeps/wemosesp/ESPAsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         wemosesp/.piolibdeps/wemosesp/ESPAsyncWebServer-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         tftdisplay/.piolibdeps/tftdisplay/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         tftdisplay/.piolibdeps/tftdisplay/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         tftdisplay/.piolibdeps/tftdisplay/AsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         tftdisplay/.piolibdeps/tftdisplay/ESPAsyncWebServer-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display-tft/.piolibdeps/display-tft/libsodium': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display-tft/.piolibdeps/display-tft/noise-c': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display-tft/.piolibdeps/display-tft/AsyncTCP-esphome': Permission denied
        du: cannot read directory '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/                         display-tft/.piolibdeps/display-tft/ESPAsyncWebServer-esphome': Permission denie                         d
        1.2G    /opt/iobroker/iobroker-data/
        863M    /opt/iobroker/iobroker-data/esphome.0
        861M    /opt/iobroker/iobroker-data/esphome.0/.esphome
        849M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
        205M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibd                         eps/esp-display/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibd                         eps/esp-display/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibd                         eps/esp-display/AsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp-display/.piolibd                         eps/esp-display/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps                         /display4/ArduinoJson': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps                         /display4/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display4/.piolibdeps                         /display4/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps                         /display7/ArduinoJson': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps                         /display7/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.piolibdeps                         /display7/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/ArduinoJson': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/AsyncMqttClient-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/ESPAsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/espwemos/.piolibdeps                         /espwemos/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/we                         mos/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/we                         mos/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/we                         mos/ESPAsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemos/.piolibdeps/we                         mos/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/ArduinoJson': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/AsyncMqttClient-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/ESPAsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.piolibdeps/tes                         t/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/ArduinoJson': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/AsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.piolibdeps/es                         p32/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolib                         deps/wemosdisplay/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolib                         deps/wemosdisplay/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolib                         deps/wemosdisplay/ESPAsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosdisplay/.piolib                         deps/wemosdisplay/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/ArduinoJson': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/AsyncMqttClient-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/ESPAsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp8266/.piolibdeps/                         esp8266/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibde                         ps/displaytft/ArduinoJson': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibde                         ps/displaytft/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/displaytft/.piolibde                         ps/displaytft/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps                         /wemosesp/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps                         /wemosesp/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps                         /wemosesp/ESPAsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/wemosesp/.piolibdeps                         /wemosesp/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibde                         ps/tftdisplay/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibde                         ps/tftdisplay/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibde                         ps/tftdisplay/AsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.piolibde                         ps/tftdisplay/ESPAsyncWebServer-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibd                         eps/display-tft/libsodium': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibd                         eps/display-tft/noise-c': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibd                         eps/display-tft/AsyncTCP-esphome': Permission denied
        find: '/opt/iobroker/iobroker-data/esphome.0/.esphome/build/display-tft/.piolibd                         eps/display-tft/ESPAsyncWebServer-esphome': Permission denied
        24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32/.pioenvs/esp3                         2/firmware.elf
        23M     /opt/iobroker/iobroker-data/states.jsonl
        21M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/display7/.pioenvs/d                         isplay7/firmware.elf
        19M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/tftdisplay/.pioenvs                         /tftdisplay/firmware.elf
        18M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw                         ays prefer the links 'by-id':
        No Devices found 'by-id'
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.21.0
        /usr/bin/node           v22.21.0
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.21.0-1nodesource1
          Candidate: 22.21.0-1nodesource1
          Version table:
         *** 22.21.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 P                         ackages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspi               raspi (version: 7.0.7, hostname: raspi         , alive, upti                         me: 943932)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.19
        javascript:     9.0.11
        nodejs modules from github:     2
        +-- iobroker.esphome@0.6.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.                         git#ebd79f96c6c48650ad3b818e9b6ef9c6b4106e76)
        +-- iobroker.vw-connect@0.7.15 (git+ssh://git@github.com/ta2k/ioBroker.vw-connec                         t.git#f756508d8a444a476296f880c2ae1ac3e3010beb)
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspi                                                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                         n
        + system.adapter.alexa2.0                 : alexa2                : raspi                                                             -  enabled
        + system.adapter.backitup.0               : backitup              : raspi                                                             -  enabled
          system.adapter.birthdays.0              : birthdays             : raspi                                                             -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : raspi                                                             -  enabled
        + system.adapter.discovery.0              : discovery             : raspi                                                             -  enabled
        + system.adapter.ems-esp.0                : ems-esp               : raspi                                                             -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspi                                                             -  enabled
        + system.adapter.esphome.0                : esphome               : raspi                                                             -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspi                                                             -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspi                                                             -  enabled
          system.adapter.habpanel.0               : habpanel              : raspi                                                             -  enabled
        + system.adapter.history.0                : history               : raspi                                                             -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspi                                                             -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspi                                                             -  enabled, port: 18701
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspi                                                             -  enabled, port: 12001
        + system.adapter.hm-rpc.2                 : hm-rpc                : raspi                                                             -  enabled, port: 12010
        + system.adapter.influxdb.0               : influxdb              : raspi                                                             -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : raspi                                                             -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspi                                                             -  enabled, port: 1883, bind: 192.168.178.10
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                                             - disabled
        + system.adapter.shelly.0                 : shelly                : raspi                                                             -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : raspi                                                             -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : raspi                                                             -  enabled, port: 8087, bind: 192.168.178.10, run a                         s: admin
        + system.adapter.sonoff.0                 : sonoff                : raspi                                                             -  enabled, port: 1886, bind: 192.168.178.10
        + system.adapter.tr-064.0                 : tr-064                : raspi                                                             -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : raspi                                                             -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspi                                                             -  enabled
        + system.adapter.web.0                    : web                   : raspi                                                             -  enabled, port: 8082, bind: 192.168.178.10, run a                         s: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                                             -  enabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name     │ url                                                     │                          auto upgrade │
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │                          true         │
        │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │                          false        │
        Active repo(s): stable
        Upgrade policy: patch
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.7.19   , installed 7.7.19
        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
        Adapter    "backitup"     : 3.3.10   , installed 3.3.10
        Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "ems-esp"      : 6.0.1    , installed 6.0.1
        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
        Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "javascript"   : 9.0.11   , installed 9.0.11
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
        Adapter    "shelly"       : 10.4.1   , installed 10.4.1
        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Objects and States
        Objects:        8353
        States:         6972
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        raspi
        HOME=/home/raspi
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 3795 M total memory
                 2662 M used memory
                  140 M free memory
                   76 M buffer memory
                  985 M swap cache
                  511 M total swap
                  511 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        TARGET           SOURCE    FSTYPE OPTIOW: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
        W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Get:5 https://packages.grafana.com/oss/deb stable InRelease [7660 B]
        Hit:6 https://repos.influxdata.com/debian stable InRelease
        Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
        Hit:8 https://apt.pivccu.de/piVCCU stable InRelease
        Err:5 https://packages.grafana.com/oss/deb stable InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 192.168.178.10:1884     0.0.0.0:*               LISTEN      1001       6157204    62739/io.mqtt.0
        tcp        0      0 192.168.178.10:1886     0.0.0.0:*               LISTEN      1001       13372      2860/io.sonoff.0
        tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       6157203    62739/io.mqtt.0
        tcp        0      0 192.168.178.10:8087     0.0.0.0:*               LISTEN      1001       13504      2971/io.simple-api.
        tcp        0      0 192.168.178.10:8082     0.0.0.0:*               LISTEN      1001       13973      3186/io.web.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3676       625/sshd: /usr/sbin
        tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       634157     9632/io.hm-rpc.1
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        7872       827/influxd
        tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       11665      2647/io.hm-rpc.2
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          3779       802/dnsmasq
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9276       1395/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9281       1395/iobroker.js-co
        tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       10119      2536/io.hm-rpc.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       553251     8425/io.shelly.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          3678       625/sshd: /usr/sbin
        tcp6       0      0 :::3000                 :::*                    LISTEN      107        9267       1382/grafana
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6986       2110/io.admin.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        5574       827/influxd
        udp        0      0 192.168.178.10:5353     0.0.0.0:*                           1001       13648      2867/io.esphome.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2939       495/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       550757     8432/io.shelly.1
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          3778       802/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          3775       802/dnsmasq
        udp        0      0 0.0.0.0:57463           0.0.0.0:*                           104        2941       495/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        2940       495/avahi-daemon: r
        udp6       0      0 :::45156                :::*                                104        2942       495/avahi-daemon: r
        udp6       0      0 fe80::6578:418f:682:546 :::*                                0          6296       567/NetworkManager
        2025-12-09 13:24:45.085  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 24.8
        2025-12-09 13:24:45.086  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
        2025-12-09 13:25:40.046  - info: host.raspi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 63599
        2025-12-09 13:25:42.694  - info: weatherunderground.0 (63599) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
        2025-12-09 13:25:51.977  - info: weatherunderground.0 (63599) Terminated (NO_ERROR): Without reason
        2025-12-09 13:25:52.516  - info: host.raspi instance system.adapter.weatherunderground.0 having pid 63599 terminated with code 0 (NO_ERROR)
        2025-12-09 13:27:08.712  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 24.4
        2025-12-09 13:27:08.713  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
        2025-12-09 13:29:18.072  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 24.1
        2025-12-09 13:29:18.074  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
        2025-12-09 13:32:16.966  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 24
        2025-12-09 13:32:16.967  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
        2025-12-09 13:35:01.354  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 23.9
        2025-12-09 13:35:01.355  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
        2025-12-09 13:35:52.430  - info: host.raspi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 63839
        2025-12-09 13:36:53.233  - warn: influxdb.0 (2337) Error on writePoint("{"value":-16.7,"time":"2025-12-09T12:35:52.827Z","from":"system.adapter.shelly.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
        2025-12-09 13:37:02.196  - info: influxdb.0 (2337) Currently no hosts available, try later
        2025-12-09 13:37:02.701  - warn: fb-checkpresence.0 (2933) checkPresence:  getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath AxiosError: timeout of 6000ms exceeded
        2025-12-09 13:37:10.420  - info: influxdb.0 (2337) Connecting http://localhost:8086/ ...
        2025-12-09 13:37:10.422  - info: influxdb.0 (2337) Influx DB Version used: 1.x
        2025-12-09 13:37:19.307  - info: weatherunderground.0 (63839) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
        2025-12-09 13:37:31.534  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 23.7
        2025-12-09 13:37:31.536  - info: javascript.0 (3150) script.js.Heizung.Luefter-Steuerung: 13.4
        2025-12-09 13:37:39.186  - info: weatherunderground.0 (63839) Terminated (NO_ERROR): Without reason
        2025-12-09 13:37:39.752  - info: host.raspi instance system.adapter.weatherunderground.0 having pid 63839 terminated with code 0 (NO_ERROR)
        iob diag has finished.
        • MartinPM MartinP
          Was sagt
          @MartinP sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
          das sagt alles iob diag
          @thomas-braun hat sich einige Mühe gemacht, dieses Skript zu basteln, damit genau dieses Rätselraten und einzelne abfragen aller möglichen Ursachen nicht mehr nötig ist
          • MartinPM MartinP
            Was sagt
            W Offline
            W Offline
            wibear
            Es gab keine Antwort darauf...
            • W wibear
              iob diag
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              raspi
              HOME=/home/raspi
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       3795 M total memory
                       2662 M used memory
                        140 M free memory
                         76 M buffer memory
                        985 M swap cache
                        511 M total swap
                        511 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              7.5G    /var/
              4.0G    /var/log
              1.8G    /var/cache/apt
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              raspi
              HOME=/home/raspi
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       3795 M total memory
                       2662 M used memory
                        140 M free memory
                         76 M buffer memory
                        985 M swap cache
                        511 M total swap
                        511 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.19
              javascript:     9.0.11
              Adapter State
              + instance is alive
              Objects and States
              Objects:        8353
              States:         6972
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              raspi
              HOME=/home/raspi
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       3795 M total memory
                       2662 M used memory
                        140 M free memory
                         76 M buffer memory
                        985 M swap cache
                        511 M total swap
                        511 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              Pending Updates: 1
              @wibear sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
              DANKE
              über under-voltage oder overtemperature steht da nichts drin.
              nur dass iobroker die rechte fehlen auf Dateien von esphome zuzugreifen
                DANKE
                Muss man mal schauen, warum.
                Generell baut man Software nicht mit root-Rechten.
                Das Grafana-Repo (bzw. der Schlüssel dafür) muss nochmal neuangelegt werden.
                • W wibear
                  Ich habe eher ESPHome mit dem Display im Verdacht. Es ist schon mehrfach passiert, dass beim Kompilieren in ESPHome der Raspi abstürzte. Finden sich nach dem Absturz irgendwo im OS die Info zu möglichen Ursachen?
                  Ja, im journal.
                  • W wibear
                    iob diag
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    raspi
                    HOME=/home/raspi
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                             3795 M total memory
                             2662 M used memory
                              140 M free memory
                               76 M buffer memory
                              985 M swap cache
                              511 M total swap
                              511 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    /var:
                    7.5G    /var/
                    4.0G    /var/log
                    1.8G    /var/cache/apt
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    raspi
                    HOME=/home/raspi
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                             3795 M total memory
                             2662 M used memory
                              140 M free memory
                               76 M buffer memory
                              985 M swap cache
                              511 M total swap
                              511 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.7.19
                    javascript:     9.0.11
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        8353
                    States:         6972
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    raspi
                    HOME=/home/raspi
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                             3795 M total memory
                             2662 M used memory
                              140 M free memory
                               76 M buffer memory
                              985 M swap cache
                              511 M total swap
                              511 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    Pending Updates: 1
                    Das grundsätzliche Problem dürfter hier zu suchen sein:
                    *** MEMORY ***
                    total used free shared buff/cache available
                    Beim kompilieren geht dir der RAM aus.
                    W 1 Antwort Letzte Antwort
                      *** MEMORY ***
                      W Offline
                      W Offline
                      wibear
                      @Thomas-Braun sagte in Raspi 4 mit IOBroker stürzt immer wieder ab:
                      Welche Lösung käme dann in Frage? Ein anderer Raspi?
                      • W wibear
                        @wibear
                        Ja.
                        Oder crosscompiling auf einer dickeren Maschine.
                          @wibear
                          Ja.
                          W Offline
                          W Offline
                          wibear
                          @wibear
                          Ja.
                          Die Abstürze gibt es auch sporadisch, ich habe schon lange nicht mehr ESPHome angefasst.
                          Würde ein Raspi mit 8 GB RAM statt 4 wie jetzt dieses Problem lösen?
                          • W wibear
                            @wibear
                            Ja.
                            Ist ein wenig Glaskugellesen. Aber mehr RAM ist nie verkehrt.
                            Meine Kiste zieht sich im Dauerbetrieb schon mehr als 4GB weg:
                            echad@chet:~ $ free -ht
                            Mem:           7.6Gi       4.2Gi       2.6Gi        10Mi       973Mi       3.5Gi
                            Swap:          511Mi          0B       511Mi
                            Total:         8.1Gi       4.2Gi       3.1Gi
                            echad@chet:~
                              echad@chet:~
                              W Offline
                              W Offline
                              wibear
                              schrieb am zuletzt editiert von wibear
                              @Thomas-Braun
                              Guten Abend, heute schon wieder ohne einen erkennbaren Grund abgestürzt. Über ein HDMI-Kabel verbunden war zwar die Console sichtbar, hat aber auf die Tastatur nicht mehr reagiert.
                              Wie kann ich die Ursache nach dem Restart suchen/analysieren? Danke und Grüße
                              • W wibear
                                @Thomas-Braun
                                Im journal.
                                • W wibear
                                  @Thomas-Braun
                                  das ist meistens ein Zeichen von übermäßiger Load.
                                  • Amoklaufendes Skript mit z.B. Schleifen
                                  Das kann sich wieder fangen, danach könnte man mit top die Load der vergangenen 15 Minuten sehen, es kann aber auch zum reboot führen.
                                  Auch zu wenig Arbeitsspeicher kann zu hoher load führen, wenn auf einmal wie verrückt ausgelagert wird, was natürlich länger dauert und ebenfalls die Load average hochtreibt.
                                    W Offline
                                    W Offline
                                    wibear
                                    @Homoran
                                    Danke für superschnelle Antwort! Ich überlege es mir schon, auf ein NUC mit 8GB RAM mit ProxMox zu migrieren. Würde es Sinn machen?
                                    HomoranH crunchipC 2 Antworten Letzte Antwort
                                    • W wibear
                                      @Homoran
                                      bitte nicht am RAM geizen!
                                      16 oder 32 sollten es bei einem NUC schon sein. So hoch sind die Mehrkosten nicht.
                                      ich bin aber wieder davon weg zu einem dedizierten iob Server in Form eines Pi5 mit 8GB RAM.
                                      • W wibear
                                        @Homoran
                                        crunchipC Offline
                                        crunchipC Offline
                                        nö,
                                        denn aktuell reichen deine 4GB nicht, also brauchst du noch mindestens 2GB dazu, ergo bist du schon bei 6GB. Proxmox selbst braucht auch nochmal gern bis zu 2GB. Somit kein Verfügbarer Speicher für weitere LXC, geschweige denn VM`s
                                          W Offline
                                          W Offline
                                          wibear
                                          es läuft bei mir auch die RaspberryMatic auf dem Raspberry 4.
                                          Welche Lösung würdet Ihr empfehlen?
