  4. Raspi 5 - 8Gb Arbeitsspeicher läuft voll
    6.5k
25 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • AutodidaktA Autodidakt
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Get:4 https://apt.grafana.com stable InRelease [7660 B]
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Get:6 https://packages.grafana.com/oss/deb stable InRelease [7660 B]
    Hit:7 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:8 https://deb.nodesource.com/node_22.x nodistro InRelease
    Err:4 https://apt.grafana.com stable InRelease
    Err:6 https://packages.grafana.com/oss/deb stable InRelease
    Reading package lists...
    Pending Updates: 2
    @Autodidakt
    Das ist nicht vollständig.
    Die Quelle für Grafana kannste aber schon mal neuanlegen.
    AutodidaktA 1 Antwort Letzte Antwort
    • AutodidaktA Offline
      AutodidaktA Offline
      Autodidakt
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: IoBMaster
             Icon name: computer
                Kernel: Linux 6.12.47+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       18:38:30 up 12 min,  2 users,  load average: 2.11, 2.46, 1.92
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-12-09 18:38:30 CET
                 Universal time: Tue 2025-12-09 17:38:30 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            8.2G        4.5G        1.5G        9.7M        2.3G        3.7G
      Swap:           536M          0B        536M
      Total:          8.7G        4.5G        2.0G
      Active iob-Instances:   51
               7819 M total memory
               4310 M used memory
               5568 M active memory
                581 M inactive memory
               1429 M free memory
                103 M buffer memory
               2114 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 18:38:30 up 12 min,  2 users,  load average: 2.11, 2.46, 1.92
      Tasks: 264 total,   1 running, 263 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 28.6 us, 28.6 sy,  0.0 ni, 42.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7819.8 total,   1428.1 free,   4312.4 used,   2217.8 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3507.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     782M  9.2M  773M   2% /run
      /dev/sda2      ext4      220G   29G  180G  14% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/sda1      vfat      510M   57M  454M  12% /boot/firmware
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Tue Dec  9 18:25:47 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:84:59:3C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e1e015d3-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Tue Dec  9 18:25:51 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
      [Tue Dec  9 18:25:52 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.2G    /var/
      1.2G    /var/lib
      906M    /var/lib/influxdb
      898M    /var/lib/influxdb/data
      880M    /var/lib/influxdb/data/iobroker/autogen
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      1.4G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      565M    /opt/iobroker/iobroker-data/files
      273M    /opt/iobroker/iobroker-data/backup-objects
      128M    /opt/iobroker/iobroker-data/node-red
      127M    /opt/iobroker/iobroker-data/node-red/node_modules
      49M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      21M     /opt/iobroker/iobroker-data/states.jsonl
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-0658_0200_E3040A02-4A02-0113-1510-041500BFCC64-if00
      /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_889f44373653ef11ab272ce0174bec31-if00-port0
      *** ZigBee Settings ***
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.21.0
      /usr/bin/node           v22.21.0
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.21.0-1nodesource1
        Candidate: 22.21.0-1nodesource1
        Version table:
       *** 22.21.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.20.4+dfsg-1~deb12u1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      IoBMaster           IoBMaster (version: 7.0.7, hostname: IoBMaster     , alive, uptime: 759)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.19
      javascript:     9.0.11
      nodejs modules from github:     4
      +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
      +-- iobroker.life360@0.2.21 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#888e08024c2d93d86aa6eb74f281c574dce86c42)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
      Adapter State
      + system.adapter.admin.0                  : admin                 : IoBMaster                                -  enabled, port: 6969, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : IoBMaster                                -  enabled
      + system.adapter.alexa-shoppinglist.1     : alexa-shoppinglist    : IoBMaster                                -  enabled
      + system.adapter.alexa-shoppinglist.2     : alexa-shoppinglist    : IoBMaster                                -  enabled
      + system.adapter.alexa2.0                 : alexa2                : IoBMaster                                -  enabled
      + system.adapter.backitup.0               : backitup              : IoBMaster                                -  enabled
      + system.adapter.ble.0                    : ble                   : IoBMaster                                -  enabled
      + system.adapter.cloud.0                  : cloud                 : IoBMaster                                -  enabled
      + system.adapter.ds18b20.0                : ds18b20               : IoBMaster                                -  enabled
      + system.adapter.epson_ecotank_et_2750.0  : epson_ecotank_et_2750 : IoBMaster                                -  enabled
        system.adapter.feiertage.0              : feiertage             : IoBMaster                                -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : IoBMaster                                -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : IoBMaster                                -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : IoBMaster                                -  enabled
      + system.adapter.ham.0                    : ham                   : IoBMaster                                -  enabled
      + system.adapter.history.0                : history               : IoBMaster                                -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : IoBMaster                                -  enabled
        system.adapter.i2c.0                    : i2c                   : IoBMaster                                - disabled
        system.adapter.ical.0                   : ical                  : IoBMaster                                -  enabled
        system.adapter.ical.1                   : ical                  : IoBMaster                                -  enabled
        system.adapter.ical.2                   : ical                  : IoBMaster                                -  enabled
        system.adapter.ical.3                   : ical                  : IoBMaster                                -  enabled
        system.adapter.ical.4                   : ical                  : IoBMaster                                -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: IoBMaster                                -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : IoBMaster                                -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : IoBMaster                                -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBMaster                                -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoBMaster                                -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: IoBMaster                                -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IoBMaster                                -  enabled
      + system.adapter.influxdb.0               : influxdb              : IoBMaster                                -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : IoBMaster                                -  enabled
      + system.adapter.javascript.0             : javascript            : IoBMaster                                -  enabled
      + system.adapter.knx.0                    : knx                   : IoBMaster                                -  enabled, bind: 192.168.178.185
      + system.adapter.lgtv.0                   : lgtv                  : IoBMaster                                -  enabled
        system.adapter.life360.0                : life360               : IoBMaster                                - disabled
      + system.adapter.meross.0                 : meross                : IoBMaster                                -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBMaster                                -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : IoBMaster                                -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : IoBMaster                                -  enabled, port: 1879, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : IoBMaster                                - disabled, port: 1783, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : IoBMaster                                -  enabled
      + system.adapter.node-red.0               : node-red              : IoBMaster                                -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : IoBMaster                                -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : IoBMaster                                -  enabled
        system.adapter.samsung.0                : samsung               : IoBMaster                                - disabled
      + system.adapter.scenes.0                 : scenes                : IoBMaster                                -  enabled
        system.adapter.schoolfree.0             : schoolfree            : IoBMaster                                -  enabled
      + system.adapter.shelly.0                 : shelly                : IoBMaster                                -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : IoBMaster                                -  enabled, port: 1881, bind: 192.168.178.185
      + system.adapter.shuttercontrol.0         : shuttercontrol        : IoBMaster                                -  enabled
      + system.adapter.simple-api.0             : simple-api            : IoBMaster                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonnen.0                 : sonnen                : IoBMaster                                -  enabled
      + system.adapter.sonoff.0                 : sonoff                : IoBMaster                                -  enabled, port: 1516, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : IoBMaster                                -  enabled
      + system.adapter.sql.0                    : sql                   : IoBMaster                                -  enabled, port: 3307
      + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBMaster                                -  enabled
      + system.adapter.telegram.0               : telegram              : IoBMaster                                -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : IoBMaster                                -  enabled
      + system.adapter.tr-064.0                 : tr-064                : IoBMaster                                -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : IoBMaster                                -  enabled
      + system.adapter.tuya.0                   : tuya                  : IoBMaster                                -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: IoBMaster                                -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : IoBMaster                                -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : IoBMaster                                -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBMaster                                -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : IoBMaster                                -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBMaster                                -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBMaster                                -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : IoBMaster                                -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : IoBMaster                                -  enabled
        system.adapter.vis-metro.0              : vis-metro             : IoBMaster                                -  enabled
        system.adapter.vis-players.0            : vis-players           : IoBMaster                                -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : IoBMaster                                -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBMaster                                -  enabled
        system.adapter.vis.0                    : vis                   : IoBMaster                                -  enabled
      + system.adapter.web.0                    : web                   : IoBMaster                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IoBMaster                                -  enabled
        system.adapter.worx.0                   : worx                  : IoBMaster                                - disabled
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : IoBMaster                                -  enabled
      + system.adapter.zwave2.0                 : zwave2                : IoBMaster                                -  enabled
      + instance is alive
      ioBroker-Repositories
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.19   , installed 7.7.19
      Adapter    "alexa-shoppinglist": 1.1.2, installed 1.1.2
      Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
      Adapter    "backitup"     : 3.3.10   , installed 3.3.10
      Adapter    "ble"          : 0.14.0   , installed 0.14.1
      Adapter    "ds18b20"      : 3.1.1    , installed 3.1.1
      Adapter    "epson_ecotank_et_2750": 1.0.1, installed 1.0.1
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "i2c"          : 1.2.1    , installed 1.2.1
      Adapter    "ical"         : 1.18.1   , installed 1.18.1
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 5.0.7    , installed 5.0.7
      Adapter    "javascript"   : 9.0.11   , installed 9.0.11
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "knx"          : 2.0.30   , installed 2.0.30
      Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "scenes"       : 3.2.3    , installed 4.0.2
      Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
      Adapter    "shelly"       : 10.4.1   , installed 10.4.1
      Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonnen"       : 1.18.1   , installed 1.18.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-2-widgets-jaeger-design": 1.4.9, installed 1.4.9
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "worx"         : 3.2.7    , installed 3.2.7
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
      Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
      Objects and States
      Objects:        20845
      States:         19154
      Pending Updates: 2
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      995        5814       788/influxd
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       11138      1144/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        6258       634/mosquitto
      tcp        0      0 0.0.0.0:1879            0.0.0.0:*               LISTEN      1001       15381      1459/io.mqtt.0
      tcp        0      0 0.0.0.0:1516            0.0.0.0:*               LISTEN      1001       12834      1693/io.sonoff.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       8259       877/iobroker.js-con
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       9255       877/iobroker.js-con
      tcp        0      0 192.168.178.185:1881    0.0.0.0:*               LISTEN      1001       14284      1787/io.shelly.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          418        632/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       16765      1971/io.simple-api.
      tcp6       0      0 :::8086                 :::*                    LISTEN      995        7219       788/influxd
      tcp6       0      0 :::8080                 :::*                    LISTEN      1000       50367      5037/node
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22648      2205/io.web.0
      tcp6       0      0 :::3030                 :::*                    LISTEN      1001       11953      1163/io.fullybrowse
      tcp6       0      0 :::3000                 :::*                    LISTEN      105        638        876/grafana
      tcp6       0      0 :::6969                 :::*                    LISTEN      1001       9336       917/io.admin.0
      tcp6       0      0 :::1883                 :::*                    LISTEN      106        6259       634/mosquitto
      tcp6       0      0 :::1821                 :::*                    LISTEN      1001       13311      1832/io.ds18b20.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          420        632/sshd: /usr/sbin
      udp        0      0 192.168.178.185:38788   0.0.0.0:*                           1001       28144      1370/io.knx.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       14318      1746/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       14319      1746/io.tuya.0
      udp        0      0 0.0.0.0:36463           0.0.0.0:*                           104        1964       504/avahi-daemon: r
      udp        0      0 192.168.178.185:36777   0.0.0.0:*                           1001       23641      1370/io.knx.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       14495      1417/io.mihome-vacu
      udp        0      0 192.168.178.185:33371   0.0.0.0:*                           1001       15016      1370/io.knx.0
      udp        0      0 192.168.178.43:5353     0.0.0.0:*                           1001       15154      1725/io.tr-064.0
      udp        0      0 192.168.178.185:5353    0.0.0.0:*                           1001       15153      1725/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       9793       1170/io.ham.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1962       504/avahi-daemon: r
      udp        0      0 192.168.178.185:38271   0.0.0.0:*                           1001       12083      1144/node-red
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14035      1630/io.shelly.0
      udp6       0      0 :::57183                :::*                                104        1965       504/avahi-daemon: r
      udp6       0      0 fe80::4346:60a5:253:546 :::*                                0          7163       563/NetworkManager
      udp6       0      0 fe80::c4b7:e652:106:546 :::*                                0          7157       563/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        1963       504/avahi-daemon: r
      2025-12-09 18:39:46.598  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Hygrometer Vorgarten', payload '{"battery":60,"linkquality":152,"soil_moisture":87,"temperature":6,"temperature_unit":"celsius"}'
      2025-12-09 18:39:46.598  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Hügrometer Waschküche', payload '{"battery":20,"comfort_humidity_max":60,"comfort_humidity_min":40,"comfort_temperature_max":27,"comfort_temperature_min":19,"humidity":48.2,"linkquality":204,"temperature":20.7,"temperature_units":"celsius","update":{"installed_version":4105,"latest_version":8960,"state":"available"}}'
      2025-12-09 18:39:46.599  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Hygrometer 1OG', payload '{"battery":80,"comfort_humidity_max":60,"comfort_humidity_min":40,"comfort_temperature_max":27,"comfort_temperature_min":19,"humidity":52,"linkquality":152,"temperature":23,"temperature_units":"celsius","update":{"installed_version":4105,"latest_version":8960,"state":"available"}}'
      2025-12-09 18:39:46.600  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kizi', payload '{"brightness":254,"color":{"hue":32,"saturation":82,"x":0.4599,"y":0.4106},"color_mode":"color_temp","color_temp":370,"color_temp_startup":370,"linkquality":204,"power_on_behavior":"on","state":"ON"}'
      2025-12-09 18:39:46.600  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Block mitte', payload '{"brightness":254,"color":{"hue":27,"saturation":92,"x":0.5056,"y":0.4152},"color_mode":"color_temp","color_temp":454,"color_temp_startup":454,"linkquality":140,"power_on_behavior":"on","state":"ON"}'
      2025-12-09 18:39:46.601  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Block Tür', payload '{"brightness":254,"color":{"x":0.5056,"y":0.4152},"color_mode":"color_temp","color_temp":454,"linkquality":156,"power_on_behavior":"on","state":"ON"}'
      2025-12-09 18:39:46.602  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Block Fenster', payload '{"brightness":254,"color":{"x":0.5056,"y":0.4152},"color_mode":"color_temp","color_temp":454,"linkquality":120,"power_on_behavior":"on","state":"ON"}'
      2025-12-09 18:39:46.604  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Dusche Tür', payload '{"brightness":254,"color":{"x":0.5056,"y":0.4152},"color_mode":"color_temp","color_temp":454,"linkquality":196,"state":"ON"}'
      2025-12-09 18:39:46.604  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Dusche Fenster', payload '{"brightness":254,"color":{"x":0.5056,"y":0.4152},"color_mode":"color_temp","color_temp":454,"linkquality":104,"state":"ON"}'
      2025-12-09 18:39:46.606  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Dusche Nasszelle', payload '{"brightness":254,"color":{"x":0.5056,"y":0.4152},"color_mode":"color_temp","color_temp":454,"linkquality":92,"state":"ON"}'
      2025-12-09 18:39:46.607  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/LED Strip 1', payload '{"brightness":254,"color":{"hue":120,"saturation":100,"x":0.6982,"y":0.2982},"color_mode":"xy","color_power_on_behavior":"customized","do_not_disturb":false,"linkquality":252,"state":"OFF"}'
      2025-12-09 18:39:46.607  - info: zigbee2mqtt.0 (1768) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/LED Strip 2', payload '{"color":{"x":0.1355,"y":0.0399},"color_mode":"xy","linkquality":212,"state":"OFF"}'
      2025-12-09 18:39:46.608  - info: zigbee2mqtt.0 (1768) z2m: Zigbee2MQTT started!
      2025-12-09 18:39:46.608  - error: zigbee2mqtt.0 (1768) z2m: Could not init sd_notify: The module '/opt/zigbee2mqtt/node_modules/.pnpm/unix-dgram@2.0.6/node_modules/unix-dgram/build/Release/unix_dgram.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 115. This version of Node.js requires
      NODE_MODULE_VERSION 127. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      2025-12-09 18:39:46.609  - warn: zigbee2mqtt.0 (1768) z2m: Failed to ping 'Zigbee Steckdose 1' (attempt 1/1, ZCL command 0x70b3d52b600a59f0/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '32381'.))
      2025-12-09 18:39:46.609  - warn: zigbee2mqtt.0 (1768) z2m: Failed to ping 'Kizi' (attempt 1/1, ZCL command 0xa4c13800aa415efb/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '59718'.))
      2025-12-09 18:39:52.308  - warn: zigbee2mqtt.0 (1768) z2m: Failed to ping 'Block mitte' (attempt 1/1, ZCL command 0xa4c13800ac48524c/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '29669'.))
      2025-12-09 18:39:59.126  - warn: zigbee2mqtt.0 (1768) z2m: Failed to ping 'Block Tür' (attempt 1/1, ZCL command 0xa4c13800ac48527c/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '48550'.))
      2025-12-09 18:40:00.016  - debug: shuttercontrol.0 (1651) calculate astrodata ...
      2025-12-09 18:40:00.017  - debug: shuttercontrol.0 (1651) Sun Azimut: 260°
      2025-12-09 18:40:00.018  - debug: shuttercontrol.0 (1651) Sun Elevation: -22°
      iob diag has finished.
        @Autodidakt
        AutodidaktA Offline
        AutodidaktA Offline
        Autodidakt
        @Thomas-Braun sagte in Raspi 5 - 8Gb Arbeitsspeicher läuft voll:
        Kannst Du mir das näher erklären?
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           536M          0B        536M
                   7819 M total memory
                   4310 M used memory
                   1429 M free memory
                    103 M buffer memory
                   2114 M swap cache
                    511 M total swap
                      0 M used swap
                    511 M free swap
          *** FILESYSTEM ***
          /var:
          2.2G    /var/
          1.2G    /var/lib
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:        20845
          States:         19154
          Pending Updates: 2
          @Autodidakt sagte in Raspi 5 - 8Gb Arbeitsspeicher läuft voll:
          Solltest du bald angehen.
          Du hast kein RAM sondern eher ein CPU-Thema:
          Warum hast du denn den Port vom admmin umgebogen?
          port: 6969
          Bieg das Grafana-Reppo gerade und spiel die beiden ein:
          Pending Updates: 2
          the module (for instance, using npm rebuild or npm install).
          Da muss noch irgendwas gegen das aktuelle nodejs gebaut werden.
          Siehe:
          https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
            AutodidaktA Offline
            Autodidakt
            Ok, Danke.
            Dann leg ich mal los.
            Warum ich den Port geändert habe, kann ich Dir gar nicht mehr sagen. Ist schon eine Weile her...
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Swap:           536M          0B        536M
                       7819 M total memory
                       4310 M used memory
                       1429 M free memory
                        103 M buffer memory
                       2114 M swap cache
                        511 M total swap
                          0 M used swap
                        511 M free swap
              *** FILESYSTEM ***
              /var:
              2.2G    /var/
              1.2G    /var/lib
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
              sieht doch gut aus!
              Entscheidend ist available, nicht free!!
              allerdings ist deine Load etwas h8ch.
              nicht kritisch, aber in meinen Augen erhöht
                AutodidaktA Offline
                Autodidakt
                Ich frag mich nur, warum nach einem Tag ein Teil des Swap genutzt wird?
                  Weil das Speichermanagement des Kernels das als vorteilhaft erachtet.
                  Ist per se nicht schlimm oder bedenklich. Nur wenn das dauerhaft zu 100% gefüllt ist sollte man mal schauen.
                    AutodidaktA Offline
                    Autodidakt
                    schrieb am zuletzt editiert von Autodidakt
                    Nun bleibt noch ein Fehler:
                    z2m: Could not init sd_notify: The module '/opt/zigbee2mqtt/node_modules/.pnpm/unix-dgram@2.0.6/node_modules/unix-dgram/build/Release/unix_dgram.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 115. This version of Node.js requires NODE_MODULE_VERSION 127. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
                    npm rebuild und npm install bringen keine Besserung.
                    /usr/bin/npm 10.9.4
                    /usr/bin/npx 10.9.4
                      /usr/bin/npm 10.9.4
                      /usr/bin/npx 10.9.4
                      Was genau wo genau ausgeführt?
                        AutodidaktA Offline
                        Autodidakt
                        npm rebuild und npm install im Raspberry Home verzeichnis
                          AutodidaktA Offline
                          Autodidakt
                          War das das falsche Verzeichnis?
                            was hast du da denn von npm drin?
                              AutodidaktA Offline
                              Autodidakt
                              Vermutlich nichts, weil ein fehler kam.
                                dann versuch es mal in /opt/iobroker
                                  AutodidaktA Offline
                                  Autodidakt
                                  npm rebuild
                                  O weih...
                                  pi@IoBMaster:/opt/iobroker $ npm rebuild
                                  npm error code 1
                                  npm error path /opt/iobroker/node_modules/opengpio
                                  npm error command failed
                                  npm error command sh -c node-gyp rebuild
                                  npm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'
                                  npm error   CXX(target) Release/obj.target/opengpio/cpp/opengpio.o
                                  npm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'
                                  npm error gyp info it worked if it ends with ok
                                  npm error gyp info using node-gyp@8.4.1
                                  npm error gyp info using node@22.21.0 | linux | arm64
                                  npm error (node:186327) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                  npm error (Use `node --trace-deprecation ...` to show where the warning was created)
                                  npm error gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                                  npm error gyp info spawn /usr/bin/python3
                                  npm error gyp info spawn args [
                                  npm error gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                                  npm error gyp info spawn args   'binding.gyp',
                                  npm error gyp info spawn args   '-f',
                                  npm error gyp info spawn args   'make',
                                  npm error gyp info spawn args   '-I',
                                  npm error gyp info spawn args   '/opt/iobroker/node_modules/opengpio/build/config.gypi',
                                  npm error gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                                  npm error gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.21.0/include/node/common.gypi',
                                  npm error gyp info spawn args   '-Dlibrary=shared_library',
                                  npm error gyp info spawn args   '-Dvisibility=default',
                                  npm error gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.21.0',
                                  npm error gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                                  npm error gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.21.0/<(target_arch)/node.lib',
                                  npm error gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',
                                  npm error gyp info spawn args   '-Dnode_engine=v8',
                                  npm error gyp info spawn args   '--depth=.',
                                  npm error gyp info spawn args   '--no-parallel',
                                  npm error gyp info spawn args   '--generator-output',
                                  npm error gyp info spawn args   'build',
                                  npm error gyp info spawn args   '-Goutput_dir=.'
                                  npm error gyp info spawn args ]
                                  npm error gyp info spawn make
                                  npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                                  npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioInput(const Napi::CallbackInfo&)’:
                                  npm error ../cpp/opengpio.cpp:14:17: error: expected primary-expression before ‘line’
                                  npm error    14 |     gpiod::line line = chip.get_line(lineNumber);
                                  npm error       |                 ^~~~
                                  npm error ../cpp/opengpio.cpp:19:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?
                                  npm error    19 |         line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});
                                  npm error       |         ^~~~
                                  npm error       |         gpiod::line
                                  npm error In file included from /usr/include/gpiodcxx/chip.hpp:21,
                                  npm error                  from /usr/include/gpiod.hpp:27,
                                  npm error                  from ../cpp/opengpio.cpp:3:
                                  npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared here
                                  npm error    24 | namespace line {
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:19:58: error: ‘DIRECTION_INPUT’ is not a member of ‘gpiod::line_request’
                                  npm error       |                                                          ^~~~~~~~~~~~~~~
                                  npm error ../cpp/opengpio.cpp:28:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?
                                  npm error    28 |     Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)
                                  npm error       |                                                              ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp: In lambda function:
                                  npm error ../cpp/opengpio.cpp:30:22: error: ‘line’ is not captured
                                  npm error    30 |         bool value = line.get_value();
                                  npm error       |                      ^~~~
                                  npm error ../cpp/opengpio.cpp:28:66: note: the lambda has no capture-default
                                  npm error       |        ^
                                  npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared here
                                  npm error       |                                                              ^~~~
                                  npm error ../cpp/opengpio.cpp:34:52: error: ‘line’ is not captured
                                  npm error    34 |                                                  { line.release(); });
                                  npm error       |                                                    ^~~~
                                  npm error ../cpp/opengpio.cpp:33:67: note: the lambda has no capture-default
                                  npm error    33 |     Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)
                                  npm error       |        ^
                                  npm error       |                                                              ^~~~
                                  npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioOutput(const Napi::CallbackInfo&)’:
                                  npm error ../cpp/opengpio.cpp:49:17: error: expected primary-expression before ‘line’
                                  npm error    49 |     gpiod::line line = chip.get_line(lineNumber);
                                  npm error       |                 ^~~~
                                  npm error ../cpp/opengpio.cpp:54:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?
                                  npm error    54 |         line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);
                                  npm error       |         ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:54:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’
                                  npm error       |                                                          ^~~~~~~~~~~~~~~~
                                  npm error ../cpp/opengpio.cpp:63:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?
                                  npm error    63 |     Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)
                                  npm error       |                                                              ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:66:9: error: ‘line’ is not captured
                                  npm error    66 |         line.set_value(value); });
                                  npm error       |         ^~~~
                                  npm error ../cpp/opengpio.cpp:63:66: note: the lambda has no capture-default
                                  npm error       |        ^
                                  npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared here
                                  npm error       |                                                              ^~~~
                                  npm error ../cpp/opengpio.cpp:69:52: error: ‘line’ is not captured
                                  npm error    69 |                                                  { line.release(); });
                                  npm error       |                                                    ^~~~
                                  npm error ../cpp/opengpio.cpp:68:67: note: the lambda has no capture-default
                                  npm error    68 |     Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)
                                  npm error       |        ^
                                  npm error       |                                                              ^~~~
                                  npm error ../cpp/opengpio.cpp: At global scope:
                                  npm error ../cpp/opengpio.cpp:81:12: error: ‘line’ in namespace ‘gpiod’ does not name a type
                                  npm error    81 |     gpiod::line line;
                                  npm error       |            ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:
                                  npm error ../cpp/opengpio.cpp:92:17: error: expected primary-expression before ‘line’
                                  npm error    92 |     gpiod::line line = chip.get_line(lineNumber);
                                  npm error       |                 ^~~~
                                  npm error ../cpp/opengpio.cpp:100:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?
                                  npm error   100 |         line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);
                                  npm error       |         ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:100:58: error: ‘EVENT_BOTH_EDGES’ is not a member of ‘gpiod::line_request’
                                  npm error ../cpp/opengpio.cpp:109:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?
                                  npm error   109 |     Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)
                                  npm error       |                                                              ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:111:22: error: ‘line’ is not captured
                                  npm error   111 |         bool value = line.get_value();
                                  npm error       |                      ^~~~
                                  npm error ../cpp/opengpio.cpp:109:66: note: the lambda has no capture-default
                                  npm error       |        ^
                                  npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared here
                                  npm error       |                                                              ^~~~
                                  npm error ../cpp/opengpio.cpp:115:11: error: ‘struct WatchContext’ has no member named ‘line’
                                  npm error   115 |     data->line = line;
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:127:25: error: expected primary-expression before ‘line’
                                  npm error   127 |             gpiod::line line = data->line;
                                  npm error       |                         ^~~~
                                  npm error ../cpp/opengpio.cpp:131:33: error: ‘line’ is not captured
                                  npm error   131 |                 bool hasEvent = line.event_wait(chrono::milliseconds(1));
                                  npm error       |                                 ^~~~
                                  npm error ../cpp/opengpio.cpp:124:10: note: the lambda has no capture-default
                                  npm error   124 |         [](uv_work_t *req)
                                  npm error       |          ^
                                  npm error       |                                                              ^~~~
                                  npm error ../cpp/opengpio.cpp:134:28: error: ‘line_event’ is not a member of ‘gpiod’; did you mean ‘info_event’?
                                  npm error   134 |                     gpiod::line_event event = line.event_read();
                                  npm error       |                            info_event
                                  npm error ../cpp/opengpio.cpp:135:34: error: ‘event’ was not declared in this scope; did you mean ‘servent’?
                                  npm error   135 |                     bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;
                                  npm error       |                                  ^~~~~
                                  npm error       |                                  servent
                                  npm error ../cpp/opengpio.cpp:135:61: error: ‘gpiod::line_event’ has not been declared
                                  npm error ../cpp/opengpio.cpp:147:19: error: ‘struct WatchContext’ has no member named ‘line’
                                  npm error   147 |             data->line.release();
                                  npm error       |                   ^~~~
                                  npm error ../cpp/opengpio.cpp:168:12: error: ‘line’ in namespace ‘gpiod’ does not name a type
                                  npm error   168 |     gpiod::line line;
                                  npm error       |            ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioPwm(const Napi::CallbackInfo&)’:
                                  npm error ../cpp/opengpio.cpp:196:17: error: expected primary-expression before ‘line’
                                  npm error   196 |     gpiod::line line = chip.get_line(lineNumber);
                                  npm error       |                 ^~~~
                                  npm error ../cpp/opengpio.cpp:201:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?
                                  npm error   201 |         line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);
                                  npm error       |         ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:201:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’
                                  npm error ../cpp/opengpio.cpp:213:11: error: ‘struct PwmContext’ has no member named ‘line’
                                  npm error   213 |     data->line = line;
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:213:18: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?
                                  npm error       |                  ^~~~
                                  npm error       |           ^~~~
                                  npm error ../cpp/opengpio.cpp:224:25: error: expected primary-expression before ‘line’
                                  npm error   224 |             gpiod::line line = data->line;
                                  npm error       |                         ^~~~
                                  npm error ../cpp/opengpio.cpp:264:17: error: ‘line’ is not captured
                                  npm error   264 |                 line.set_value(true);
                                  npm error       |                 ^~~~
                                  npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-default
                                  npm error   221 |         [](uv_work_t *req)
                                  npm error       |          ^
                                  npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared here
                                  npm error       |                  ^~~~
                                  npm error ../cpp/opengpio.cpp:278:17: error: ‘line’ is not captured
                                  npm error   278 |                 line.set_value(false);
                                  npm error       |                 ^~~~
                                  npm error       |          ^
                                  npm error       |                  ^~~~
                                  npm error ../cpp/opengpio.cpp:327:25: error: expected primary-expression before ‘line’
                                  npm error   327 |             gpiod::line line = data->line;
                                  npm error       |                         ^~~~
                                  npm error ../cpp/opengpio.cpp:328:13: error: ‘line’ is not captured
                                  npm error   328 |             line.release();
                                  npm error       |             ^~~~
                                  npm error ../cpp/opengpio.cpp:324:10: note: the lambda has no capture-default
                                  npm error   324 |         [](uv_work_t *req, int status)
                                  npm error       |          ^
                                  npm error       |                  ^~~~
                                  npm error make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1
                                  npm error gyp ERR! build error
                                  npm error gyp ERR! stack Error: `make` failed with exit code: 2
                                  npm error gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
                                  npm error gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
                                  npm error gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
                                  npm error gyp ERR! System Linux 6.12.47+rpt-rpi-v8
                                  npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                                  npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                                  npm error gyp ERR! node -v v22.21.0
                                  npm error gyp ERR! node-gyp -v v8.4.1
                                  npm error gyp ERR! not ok
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-10T07_17_34_569Z-debug-0.log
                                    AutodidaktA Offline
                                    Autodidakt
                                    npm install :
                                    pi@IoBMaster:/opt/iobroker $ npm install
                                    removed 69 packages in 24s
                                    490 packages are looking for funding
                                      run `npm fund` for details
                                    Jetzt sieht es gut aus. Der Fehler scheint behoben zu sein.
                                    Danke euch für die Unterstützung.
                                      npm install :
                                      @Autodidakt
                                      Du musst dich in das Verzeichnis
                                      /opt/zigbee2mqtt/
                                      stellen.
                                        @Autodidakt
                                        /opt/zigbee2mqtt/
                                        stellen.
                                        AutodidaktA Offline
                                        AutodidaktA Offline
                                        Autodidakt
                                        @Autodidakt
                                        /opt/zigbee2mqtt/
                                        stellen.
                                        Der Fehler ist verschwunden, trotzdem nochmal in /opt/zigbee2mqtt/ ausführen?
                                        Zu früh gefreut, Fehler ist noch da.
                                        pi@IoBMaster:/opt/zigbee2mqtt $ npm rebuild
                                        npm error code 127
                                        npm error path /opt/zigbee2mqtt/node_modules/.pnpm/magicast@0.3.5/node_modules/magicast
                                        npm error command sh -c esno ./scripts/vendor.ts
                                        npm error sh: 1: esno: not found
                                        npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-12-10T07_29_08_213Z-debug-0.log
                                        pi@IoBMaster:/opt/zigbee2mqtt $ npm install
                                        npm error Cannot read properties of null (reading 'matches')
                                        npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-12-10T07_29_22_260Z-debug-0.log
                                        pi@IoBMaster:~ $ tail /home/pi/.npm/_logs/2025-12-10T07_29_08_213Z-debug-0.log
                                        42 silly unfinished npm timer build:run:prepare:node_modules/.pnpm/jackspeak@3.4.3/node_modules/jackspeak 1765351751604
                                        43 silly unfinished npm timer build:run:prepare:node_modules/.pnpm/minimatch@9.0.5/node_modules/minimatch 1765351751623
                                        44 silly unfinished npm timer build:run:prepare:node_modules/.pnpm/minipass@7.1.2/node_modules/minipass 1765351751636
                                        45 verbose cwd /opt/zigbee2mqtt
                                        46 verbose os Linux 6.12.47+rpt-rpi-v8
                                        47 verbose node v22.21.0
                                        48 verbose npm  v10.9.4
                                        49 verbose exit 127
                                        50 verbose code 127
                                        51 error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-12-10T07_29_08_213Z-debug-0.log
                                          @Autodidakt
                                          /opt/zigbee2mqtt/
                                          stellen.
                                          npm error code 127
                                          49 verbose exit 127
                                          50 verbose code 127
                                          @Autodidakt
                                          Ich kenne z2m nicht genau. Musste mal schauen wie man das neubaut. Sollte sich auf deren Homepage finden.
