5.8k Beiträge 156 Kommentatoren 4.7m Aufrufe 138 Beobachtet
  • E ETGermany
    @sborg Inzwischen habe ich eine ECOWITT, prinzipiell scheint es zu funktioniert, doch der Datentyp scheint nach einem Restart des Services zu wechseln.
    Zuerst diese Fehler im Log:
    simple-api.0
    2025-10-16 11:01:30.680	info	State value to set for "0_userdata.0.Wetterstation.Info.Solarenergie_Jahr" has to be type "number" but received type "string"
    simple-api.0
    2025-10-16 11:01:30.680	info	State value to set for "0_userdata.0.Wetterstation.Info.Solarenergie_Monat" has to be type "number" but received type "string"
    simple-api.0
    2025-10-16 11:01:30.680	info	State value to set for "0_userdata.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
    dann habe ich die Objekte angepasst, nach einem Service Neustart dann aber diese Fehler:
    simple-api.0
    2025-10-16 11:46:03.183	info	State value to set for "0_userdata.0.Wetterstation.Info.Solarenergie_Jahr" has to be type "string" but received type "number"
    simple-api.0
    2025-10-16 11:46:03.182	info	State value to set for "0_userdata.0.Wetterstation.Info.Solarenergie_Woche" has to be type "string" but received type "number"
    simple-api.0
    2025-10-16 11:46:03.182	info	State value to set for "0_userdata.0.Wetterstation.Info.Solarenergie_Tag" has to be type "number" but received type "string"
    simple-api.0
    2025-10-16 11:46:03.052	info	State value to set for "0_userdata.0.Wetterstation.Info.Sonnenschein_Monat" has to be type "number" but received type "string"
    simple-api.0
    2025-10-16 11:46:03.052	info	State value to set for "0_userdata.0.Wetterstation.Info.Sonnenschein_Tag" has to be type "number" but received type "string"
    Weiterhin noch Fehler beim Start bzw. wenn man den Status abfragen tut:
    iobroker@n51-ubuntu:~$ systemctl status wetterstation
    ● wetterstation.service - Service für ioBroker Wetterstation
         Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; preset: enabled)
         Active: active (running) since Thu 2025-10-16 11:29:41 CEST; 1min 59s ago
       Main PID: 1206786 (wetterstation.s)
          Tasks: 5 (limit: 9171)
         Memory: 2.8M (peak: 4.4M)
            CPU: 2.150s
         CGroup: /system.slice/wetterstation.service
                 ├─1206786 /bin/bash /home/iobroker/bresser/wetterstation.sh
                 ├─1207672 /bin/bash /home/iobroker/bresser/wetterstation.sh
                 ├─1207673 timeout 66 nc -nlvw 1 -p 1080
                 ├─1207674 tail -1
                 └─1207675 nc -nlvw 1 -p 1080
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1207406]: /home/iobroker/bresser/wetterstation.sub: line 730: "0_userdata.0.Wetterstation.tempData.Sonnenschein" /86400: syntax error: operand expected (error token is ""0_userdata.0.Wetterstation.tempData.Sonnenschein" /86400")
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1207407]: /home/iobroker/bresser/wetterstation.sub: line 731: "0_userdata.0.Wetterstation.tempData.Sonnenschein" /3600: syntax error: operand expected (error token is ""0_userdata.0.Wetterstation.tempData.Sonnenschein" /3600")
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1207408]: /home/iobroker/bresser/wetterstation.sub: line 732: "0_userdata.0.Wetterstation.tempData.Sonnenschein" % 86400 /3600: syntax error: operand expected (error token is ""0_userdata.0.Wetterstation.tempData.Sonnenschein" % 86400 /3600")
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1207409]: /home/iobroker/bresser/wetterstation.sub: line 733: "0_userdata.0.Wetterstation.tempData.Sonnenschein" % 3600 /60: syntax error: operand expected (error token is ""0_userdata.0.Wetterstation.tempData.Sonnenschein" % 3600 /60")
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1207410]: /home/iobroker/bresser/wetterstation.sub: line 734: "0_userdata.0.Wetterstation.tempData.Sonnenschein" % 60: syntax error: operand expected (error token is ""0_userdata.0.Wetterstation.tempData.Sonnenschein" % 60")
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1206786]: /home/iobroker/bresser/wetterstation.sub: line 736: [: : integer expression expected
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1206786]: /home/iobroker/bresser/wetterstation.sub: line 742: [: : integer expression expected
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1207429]: (standard_in) 1: syntax error
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1207438]: (standard_in) 1: syntax error
    Okt 16 11:30:47 n51-ubuntu wetterstation.sh[1207441]: (standard_in) 1: syntax error
    Aber wie gesagt, prinzipiell funktioniert es.
    icebearI Offline
    icebearI Offline
    icebear
    #5660
    @etgermany said in [Linux Shell-Skript] WLAN-Wetterstation:
    ....doch der Datentyp scheint nach einem Restart des Services zu wechseln.
    Dies ist ein bekanntes Problem, wenn dich das stört, stellt den DP Typ auf gemischt, dann kommt der Fehler nicht mehr.
    • E ETGermany
      simple-api.0
      simple-api.0
      simple-api.0
      simple-api.0
      simple-api.0
      simple-api.0
      simple-api.0
      simple-api.0
              CPU: 2.150s
                   ├─1207674 tail -1
      SBorgS Offline
      SBorgS Offline
      SBorg
      #5661
      @etgermany
      Zu String/Number siehe @icebear
      Ich hatte noch eine Vermutung, dass der Simple-API ein Problem mit "Int" bzw. "Float" hat. So kann bspw. Temperatur=3 (also Integer) sein, oder halt zB. 3.1 (Float). Deswegen habe ich dann mal auf Temperatur=3.0 konvertiert (also eine Integer in Float). Ergebnis: keine Änderung. Keinerlei System wann er was als String/Number erkennt. Mal geht es, mal nicht. Das kam irgendwann mit einem Update des Simple-API oder JSC.
      Mögliche Lösung wäre der Switch zur Rest-API. Allerdings ist dies nicht einfach ein umstellen des Aufrufes, sondern bedarf schon einer größeren Programmierarbeit.
      Der letzte Fehler sollte sich dann auch erledigt haben. Das kann passieren wenn man gerade anfängt und die Aüßeren Umstände ungünstig waren. Sollte sich dann mit dem ausführen der ersten Mitternachtjobs erledigt haben. Dann liegen alle Werte vor (sollte dennoch auch beim 1. Start nicht auftreten).
      LG SBorg ( SBorg auf GitHub)
        ManfredR
        #5662
        habe kürzlich von Version 2.17 auf 3.60 aktualisiert. Mit 2.17 lief der Windy - Upload problemlos, mit der aktuellen Version bekomme ich in Windy keine Daten der Anlage angezeigt. Im Debug-Modus sieht das so aus:
        Datenübertragung an windy.com:
        {"update":{"update":{"stations":[],"observations":[{"si":0,"time":"2025-11-22T17:16:46.000Z","temp":-3.08,"wind":0,"wind_dir":271,"wind_gust":0,"rh":94,"dew_point":-6.44,"pressure":98611,"precip":0,"uv":0}]},"errors":{"observations":[],"stations":[]}},"result":{"0":{"stations":[],"observations":[{"success":true,"value":{"si":0,"time":"2025-11-22T17:16:46.000Z","temp":-3.08,"wind":0,"wind_dir":271,"wind_gust":0,"rh":94,"dew_point":-6.44,"pressure":98611,"precip":0,"uv":0}}]}}}
        wenn ich das Script innerhalb von 5 Minuten nochmals laufen lasse, kommt folgende Meldung:
        {"update":{"update":{"stations":[],"observations":[{"si":0,"time":"2025-11-22T17:25:46.000Z","temp":-2.94,"wind":0,"wind_dir":63,"wind_gust":0,"rh":95,"dew_point":-5.94,"pressure":98578,"precip":0,"uv":0}]},"errors":{"observations":[],"stations":[]}},"result":{"0":{"stations":[],"observations":[{"success":false,"value":{"si":0,"time":"2025-11-22T17:25:46.000Z","temp":-2.94,"wind":0,"wind_dir":63,"wind_gust":0,"rh":95,"dew_point":-5.94,"pressure":98578,"precip":0,"uv":0},"error":"Measurement sent too soon, update interval is 5 minutes"}]}}}
        Wenn ich den API - Key verfälsche, dann kommt "invalid user", die Datenübertragung an sich scheint also zu funktionieren mit korrektem API-Schlüssel. Irgendwie erscheint mir der JSON String aber etwas sonderbar aufgebaut, konnte aber auf die Schnelle keine anderen Beispiele finden.
        Habt Ihr eine Ahnung, woran das liegen könnte bzw. wie ich den Fehler finden kann?
        Danke und Grüsse,
        Manfred
        BoronsbruderB SBorgS 2 Antworten Letzte Antwort
        • icebearI Offline
          icebearI Offline
          icebear
          schrieb am zuletzt editiert von icebear
          #5663
          Ich mach das mittlerweile mit meiner Ecowitt Weatherstation anders um den Daten zu Windy. zu schicken. Läuft bei mir seit Monaten problemlos.
          Schau dir mal folgendes an Station Forwarder
          • M ManfredR
            Danke und Grüsse,
            Manfred
            BoronsbruderB Offline
            Boronsbruder
            schrieb am zuletzt editiert von Boronsbruder
            #5664
            edit: Falschaussage
            • M ManfredR
              Danke und Grüsse,
              Manfred
              SBorgS Offline
              SBorgS Offline
              SBorg
              #5665
              @ManfredR
              Sieht alles soweit gut aus. Das JSON kommt direkt von windy, teilt aber "success: true" mit. Die Übermittlung der Daten ist also erfolgt und war valid.
              Ev. aktualisiert sich die Seite im Browser einfach nicht? Hast du mal ein STRG+F5 (neu laden der Seite erzwingen ohne Daten aus dem Cache zu lesen) probiert?
              Seit der Bereitstellung von Windy habe ich nichts mehr an diesem Bereich gemacht, 2.x.x und 3.6.0 sind also in dieser Hinsicht absolut identisch.
              • Rene55R Offline
                Rene55R Offline
                Rene55
                #5666
                Kann mir hier noch jemand auf die Sprünge helfen. Ich habe (leider) erst heute gesehen, dass ich keine Wetterdaten mehr an Awekas sende. Hatte bis August noch funktioniert. Gab es eine Änderung? Wie könnte ich prüfen, was falsch läuft.
                BoronsbruderB 1 Antwort Letzte Antwort
                • SBorgS SBorg
                  @ManfredR
                  ManfredR
                  #5667
                  @SBorg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                  @ManfredR
                  Danke für die Rückmeldung. Habe grad nochmal geschaut, das sieht nun gut aus bei Windy. Komisch, hatte das bei mehreren Browsern getestet - keiner hatte zuvor was angezeigt.
                  • Rene55R Rene55
                    Boronsbruder
                    #5668
                    @Rene55 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                    Ich hab letztens eine Email bekommen von AWEKAS, die natürlich im Spam gelandet ist, daß meine Station ungewöhnliche Daten sendet.
                    Ursache war, dass ich den rel. Luftdruck nachjustiert hatte und dadurch kurzzeitige Schwankungen entstanden sind.
                    Danach musste ich meine Station wieder bei AWEKAS aktivieren.
                    Zeitlich befristete Deaktivierungen können Sie auch selber in Ihren AWEKAS Benutzereinstellungen ( https://www.awekas.at/de/benutzer.php ) reaktivieren
                    Prüfen sie bitte ihre Sensoren und die Übertragungstechnik.
                    Sollten sie die Deaktivierung als ungerechtfertigt empfinden, setzen sie sich bitte mit uns in Verbindung.
                    • Rene55R Offline
                      Rene55R Offline
                      Rene55
                      #5669
                      Danke für die Antwort. Ich komme mit Awekas nicht klar. Da wo ich die Daten zu meinem Account habe, sehe ich unten in rot "Fehler vorhanden - bitte korrigieren Sie alle roten Felder". Nur sehe ich keine roten Felder. Ich schreib Awekas mal an.
                      • Rene55R Offline
                        Rene55R Offline
                        Rene55
                        schrieb am zuletzt editiert von Rene55
                        #5670
                        Die Antwort von Awekas lautet: "Ihr IO Broker sendet keine Daten an uns. Es kommt nichts an:
                        Bitte prüfen Sie die Einstellungen für die Daten Url und Benutzernamen". Daraufhin habe ich das Passwort mal geändert (diesmal ohne Sonderzeichen) - und schon ist Awekas wieder uptodate.
                        Gab oder gibt es die Restriktion auf 'einfache' Passworte?
                        • Rene55R Rene55
                          #5671
                          Kommt halt darauf an, wie Passworte geparst werden. Eigentlich sollte sowas abgefangen werden.
                          Aber manchmal werden Sonderzeichen wie % $ - interpretiert.
                          • Rene55R Offline
                            Rene55R Offline
                            Rene55
                            #5672
                            Ja, stimmt. Da bin ich auch schon mal drüber gestolpert. Vllt. hat @SBorg da noch eine Idee.
                            • Rene55R Rene55
                              SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #5673
                              Nicht nutzen ;)
                              Aber Spaß beiseite. Da die Datenübertragung (auch das Passwort) per URL erfolgt, sind alle Zeichen die in einer URL vorkommen können kritisch, wie zB. /=?&:
                              Dafür kann man (ich) nun encoden: mache aus ":" ein %3A
                              Nur heißt das dann noch lange nicht, dass auch die Gegenseite es wieder korrekt decoded.
                              Ich habe dann bewusst darauf verzichtet, da hier das beste Passwort eh nichts nutzt, solange es im Klartext gesendet wird. Auch bietet die bash meines Wissens keine Möglichkeit direkt zu encoden. Dies geht allerdings mittels "jq", der sowieso schon installiert sein muss und für Operationen benutzt wird. Wäre also prinzipiell möglich, aber wegen des Klartext-Versandes eher kontraproduktiv (das super geheime schwierige Passwort für den PC pappt per PostIT am Monitor...).
                              Abhilfe würde nur die Nutzung der API von AWEKAS schaffen (die hat mir Otmar von AWEKAS schon zukommen lassen). Hier wird das Passwort als HASH verschlüsselt und ist so erstmal nicht mehr lesbar. Das ist aber nicht mal gerade so in 5 Minuten umgesetzt und mir fehlt dafür aktuell (und nicht absehbar) schlichtweg die Zeit.
                              • Rene55R Offline
                                Rene55R Offline
                                Rene55
                                #5674
                                Danke für die Antwort. War die Antwort "nicht nutzen" nur ein Scherz oder gibt es dazu einen Grund - ausser dem offenen Password. Und: kann ich dir beim Implementieren der API etwas helfen?
                                -1
                                • wendy2702W Offline
                                  wendy2702W Offline
                                  #5675
                                  Guten Abend zusammen,
                                  Ich habe noch eine der ersten Versionen des Scripts laufen da es mir die Daten liefert die mir wichtig sind.
                                  Jetzt ist mir vor einigen Tagen aufgefallen das bei einigen Objekten die „0“ vor dem Komma fehlt:
                                  In der App und auf den Webseiten der angebundenen Wetterdienste wird mir die „0“ angezeigt und ich meine mir einzubilden das es bei mir auch mal der Fall war.
                                  Jemand eine Idee wie ich die „0“ wieder ins Objekt und damit auch in meine VIS Anzeige bekomme?
                                  • Rene55R Rene55
                                    SBorgS Offline
                                    SBorgS Offline
                                    SBorg
                                    #5676
                                    Nicht ganz ein Scherz, aber ich meinte eigentlich keine "unerlaubten" Sonderzeichen im Passwort nutzen.
                                    Hilfe immer gerne, allerdings musst du Shell-Skript können und die API-Beschreibung darf ich nicht weitergeben. Man sieht zwar später etwas davon im Quelltext, größtenteils ist das dann aber ein Zahlenwirrwarr und viele nicht benutzte Parameter sind überhaupt nicht identifizierbar.
                                    • wendy2702W wendy2702
                                      SBorgS Offline
                                      SBorgS Offline
                                      SBorg
                                      #5677
                                      @wendy2702
                                      Das war mal gar nicht schlecht (keine Ironie).
                                      Ist mir gar nicht aufgefallen, kam wohl mit irgendeinem Firmwareupdate. Die Station/Gateway sendet tatsächlich keine führende Null mehr bei den Werten (ich verarbeite den Wert 1:1).
                                      Und genau das ist auch das String/Number Problem. So wird ein Zahlenwert von ".123" von der Simple-API als String identifiziert, "0.123" aber korrekt als Zahl. Deswegen konnte ich bis dato auch so kein System erkennen warum es mal funktioniert und mal nicht.
                                      Muss ich eine Korrektur einführen die die fehlende Null wieder ergänzt. Dann hast du wieder deine Null und das String/Number - Problem sollte auch gelöst sein.
                                      • SBorgS SBorg
                                        Rene55R Offline
                                        Rene55R Offline
                                        Rene55
                                        #5678
                                        @SBorg Schade - Shell-Script ist gar nicht. Bei Awekas sind übliche Sonderzeichen ja zulässig. Aber mach dir deswegen hier keinen Stress, es funktioniert ja wieder.
                                          mef70
                                          #5679
                                          ich habe eine Bresser 7-1 WLAN ClearView Station
                                          In der WSLink App habe ich unter Andere Wetter Server den Eintrag gemacht der auf meinen raspi zeigt
                                          Wenn ich die wetterstation im debug Modus starte werden auch nach kurzer Zeit Daten geschickt, aber das Skript wirft einen Kommunikationsfehler. Die Stations ID stimmt mit der WS_ID in der wetterstation.conf überein.
                                          00f67383-7afe-47da-84cb-7e387ab17225-cfebd32d-d929-4ea0-8a71-a37b1897ccfa-grafik.png grafik.png
                                          Was mach ich falsch? Danke für euren Input.
