  4. iob fix und iob diag ohne Reaktion
    2.7k
    2.9k
94 Beiträge 8 Kommentatoren 9.2k Aufrufe 4 Beobachtet
  • G George_Best
    Oh nein...😢 iobroker läuft wieder nicht an. iob fix lief schon drüber
    jonny@ioBroker-V2:/opt/iobroker$ iob status
    node:internal/modules/package_json_reader:314
      throw new ERR_MODULE_NOT_FOUND(packageName, fileURLToPath(base), null);
    Error [ERR_MODULE_NOT_FOUND]: Cannot find package 'deep-clone' imported from /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup.js
        at Object.getPackageJSONURL (node:internal/modules/package_json_reader:314:9)
        at packageResolve (node:internal/modules/esm/resolve:767:81)
        at moduleResolve (node:internal/modules/esm/resolve:853:18)
        at defaultResolve (node:internal/modules/esm/resolve:983:11)
        at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
        at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
        at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
        at ModuleJob._link (node:internal/modules/esm/module_job:182:49) {
      code: 'ERR_MODULE_NOT_FOUND'
    Node.js v22.21.0
    iob diag:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: ioBroker-V2
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-41-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     19:04:37 up  3:02,  2 users,  load average: 0.41, 0.73, 0.60
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-11-12 19:04:37 CET
               Universal time: Wed 2025-11-12 18:04:37 UTC
                     RTC time: Wed 2025-11-12 18:04:37
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    jonny
    HOME=/home/jonny
    GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             12G        528M        8.5G        565K        3.5G         11G
    Swap:           4.3G          0B        4.3G
    Total:           16G        528M         12G
    Active iob-Instances:   0
            11644 M total memory
              503 M used memory
             1640 M active memory
             1318 M inactive memory
             8133 M free memory
              588 M buffer memory
             2732 M swap cache
             4093 M total swap
                0 M used swap
             4093 M free swap
    top - 19:04:37 up  3:02,  2 users,  load average: 0.41, 0.73, 0.60
    Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  11644.7 total,   8133.2 free,    504.4 used,   3320.4 buff/cache
    MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11140.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  5.7G     0  5.7G   0% /dev
    tmpfs          tmpfs     1.2G  552K  1.2G   1% /run
    /dev/sda1      ext4       28G  9.6G   17G  37% /
    tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
    [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.9G    /var/
    889M    /var/cache
    870M    /var/cache/apt
    815M    /var/log
    793M    /var/cache/apt/archives
    Archived and active journals take up 790.1M in the file system.
    /opt/iobroker/backups:
    22M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    728M    /opt/iobroker/iobroker-data/
    503M    /opt/iobroker/iobroker-data/files
    166M    /opt/iobroker/iobroker-data/backup-objects
    96M     /opt/iobroker/iobroker-data/files/vis-2
    81M     /opt/iobroker/iobroker-data/files/vis
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Node.js v22.21.0
    Hosts:
    Node.js v22.21.0
    Core adapters versions
    Node.js v22.21.0
    js-controller:
    Node.js v22.21.0
    admin:
    Node.js v22.21.0
    javascript:
    nodejs modules from github:     0
    Adapter State
    ioBroker-Repositories
    Node.js v22.21.0
    Installed ioBroker-Adapters
    Node.js v22.21.0
    Objects and States
    Objects:        0
    States:         0
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17410      736/exim4
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15485      553/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17411      736/exim4
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15487      553/sshd: /usr/sbin
    udp        0      0 0.0.0.0:35015           0.0.0.0:*                           107        13947      440/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        13945      440/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13849      376/dhclient
    udp6       0      0 :::36795                :::*                                107        13948      440/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                107        13946      440/avahi-daemon: r
    2025-11-12 19:00:53.505  - info: javascript.0 (47593) terminating
    2025-11-12 19:00:53.508  - info: javascript.0 (47593) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-11-12 19:00:53.549  - info: host.ioBroker-V2 stopInstance system.adapter.admin.0 send kill signal
    2025-11-12 19:00:53.593  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.0 send kill signal
    2025-11-12 19:00:53.593  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.1 send kill signal
    2025-11-12 19:00:53.593  - info: host.ioBroker-V2 stopInstance system.adapter.email.0 send kill signal
    2025-11-12 19:00:53.593  - info: host.ioBroker-V2 stopInstance system.adapter.telegram.0 send kill signal
    2025-11-12 19:00:53.692  - info: history.0 (47655) Terminated (NO_ERROR): Without reason
    2025-11-12 19:00:53.994  - info: javascript.1 (47625) terminating
    2025-11-12 19:00:53.995  - info: telegram.0 (47670) terminating
    2025-11-12 19:00:53.996  - info: telegram.0 (47670) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-11-12 19:00:53.996  - info: email.0 (47640) terminating
    2025-11-12 19:00:53.999  - info: admin.0 (47501) terminating
    2025-11-12 19:00:54.006  - info: javascript.0 (47593) terminating
    2025-11-12 19:00:54.126  - info: host.ioBroker-V2 instance system.adapter.email.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-11-12 19:00:54.414  - info: host.ioBroker-V2 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-11-12 19:00:54.440  - info: host.ioBroker-V2 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-11-12 19:00:54.491  - info: host.ioBroker-V2 instance system.adapter.javascript.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-11-12 19:00:59.547  - error: sql.0 (47561) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-12 19:00:59.548  - error: sql.0 (47561) States database error: connect ECONNREFUSED 0.0.0.0:9000
    2025-11-12 19:01:04.552  - error: sql.0 (47561) States database error: connect ECONNREFUSED 0.0.0.0:9000
    2025-11-12 19:01:04.553  - error: sql.0 (47561) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-12 19:01:05.552  - info: sql.0 (47561) terminating with timeout
    2025-11-12 19:01:05.553  - info: sql.0 (47561) Terminated (NO_ERROR): Without reason
    2025-11-12 19:01:09.556  - error: sql.0 (47561) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    #75
    @george_best
    cd /opt/iobroker && npm ci
    G 1 Antwort Letzte Antwort
      @george_best
      George_Best
      #76
      @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
      sieht wieder sehr wild aus...
      jonny@ioBroker-V2:/opt/iobroker$ cd /opt/iobroker && npm ci
      npm warn old lockfile
      npm warn old lockfile The package-lock.json file was created with an old version of npm,
      npm warn old lockfile so supplemental metadata must be fetched from the registry.
      npm warn old lockfile This is a one-time fix-up, please be patient...
      npm error code EUSAGE
      npm error
      npm error `npm ci` can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with `npm install` before continuing.
      npm error
      npm error Missing: @iobroker-javascript.0/moment@2.30.1 from lock file
      npm error Missing: @iobroker-javascript.0/moment-parseformat@4.0.0 from lock file
      npm error Missing: iobroker.accuweather@2.1.1 from lock file
      npm error Invalid: lock file's iobroker.admin@3.5.10 does not satisfy iobroker.admin@7.7.19
      npm error Missing: iobroker.alias-manager@2.0.0 from lock file
      npm error Missing: iobroker.amazon-dash@1.2.0 from lock file
      npm error Missing: iobroker.chromecast@4.0.0 from lock file
      npm error Missing: iobroker.cloud@5.0.1 from lock file
      npm error Missing: iobroker.daswetter@3.2.3 from lock file
      npm error Missing: iobroker.deconz@1.6.4 from lock file
      npm error Missing: iobroker.devices@1.2.8 from lock file
      npm error Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@5.0.0
      npm error Missing: iobroker.email@2.0.4 from lock file
      npm error Missing: iobroker.flot@1.12.0 from lock file
      npm error Missing: iobroker.fronius@2.1.1 from lock file
      npm error Missing: iobroker.fronius-solarweb@0.0.3 from lock file
      npm error Missing: iobroker.frontier_silicon@0.5.0 from lock file
      npm error Missing: iobroker.habpanel@0.5.0 from lock file
      npm error Missing: iobroker.history@3.0.1 from lock file
      npm error Missing: iobroker.hm-rega@5.1.0 from lock file
      npm error Missing: iobroker.hm-rpc@2.0.2 from lock file
      npm error Missing: iobroker.hs100@3.0.5 from lock file
      npm error Missing: iobroker.icons-addictive-flavour-png@0.1.0 from lock file
      npm error Missing: iobroker.icons-fatcow-hosting@0.1.0 from lock file
      npm error Missing: iobroker.icons-icons8@0.0.1 from lock file
      npm error Missing: iobroker.icons-material-png@0.1.0 from lock file
      npm error Missing: iobroker.icons-material-svg@0.1.0 from lock file
      npm error Missing: iobroker.icons-mfd-png@1.2.1 from lock file
      npm error Missing: iobroker.icons-mfd-svg@1.2.0 from lock file
      npm error Missing: iobroker.icons-open-icon-library-png@0.1.2 from lock file
      npm error Missing: iobroker.icons-ultimate-png@1.0.1 from lock file
      npm error Missing: iobroker.influxdb@4.0.2 from lock file
      npm error Missing: iobroker.info@2.0.0 from lock file
      npm error Missing: iobroker.iot@5.0.7 from lock file
      npm error Missing: iobroker.javascript@8.9.2 from lock file
      npm error Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@7.0.7
      npm error Missing: iobroker.mihome-vacuum@5.2.0 from lock file
      npm error Missing: iobroker.mqtt@6.1.4 from lock file
      npm error Missing: iobroker.net-tools@1.1.2 from lock file
      npm error Missing: iobroker.octoprint@5.1.0 from lock file
      npm error Missing: iobroker.openweathermap@1.1.2 from lock file
      npm error Missing: iobroker.parser@2.2.4 from lock file
      npm error Missing: iobroker.ping@1.6.2 from lock file
      npm error Missing: iobroker.proxmox@2.4.0 from lock file
      [2025-11-12T18_10_30_372Z-debug-0.log](/assets/uploads/files/1762971379377-2025-11-12t18_10_30_372z-debug-0.log)
      • G George_Best
        npm error
        npm error
        #77
        @george_best
        Dann bin ich raus.
        • G Offline
          George_Best
          #78
          Irgendjemand eine Idee, wie ich das wieder hinbekomme?
          jonny@ioBroker-V2:~$ iob status
          Node.js v22.21.0
          • crunchipC Abwesend
            crunchipC Abwesend
            #79
            Dann bin ich raus.
            was hälst du davon?
            @george_best sagte in iob fix und iob diag ohne Reaktion:
            eine Idee
            Hauptprobleme
            1. Fehlende Dependency "deep-clone"
            Das Package deep-clone wird vom js-controller (bzw. js-controller-cli) im ESM-Modus benötigt und fehlt komplett in deinem node_modules-Verzeichnis. Der js-controller 7.0.7 benötigt deep-clone@^3.0.3 als kritische Abhängigkeit.​
            1. Package-Lock.json massiv desynchronisiert
            Dein package-lock.json ist völlig veraltet und passt nicht mehr zur package.json:
            Lock-File enthält admin@3.5.10, tatsächlich installiert ist aber admin@7.7.19
            Lock-File enthält js-controller@1.4.2, installiert ist aber js-controller@7.0.7
            Dutzende Adapter fehlen komplett im Lock-File (accuweather, alias-manager, chromecast, cloud, etc.)​
            1. Node.js 22.x Kompatibilitätsprobleme
            Der js-controller 7.0.7 unterstützt zwar "probably" Node.js 22.x, ist aber primär für 18.x und 20.x getestet. Einige Adapter-Dependencies haben explizite Node-Restriktionen (wie @homebridge/ciao), die Node.js 22 blockieren.​
            1. npm ci schlägt fehl
            npm ci kann nur funktionieren, wenn package.json und package-lock.json synchron sind. Bei dir sind sie massiv inkonsistent, weshalb npm ci mit "old lockfile" und "Missing/Invalid" Fehlern abbricht.​
            Warum ist das passiert?
            Höchstwahrscheinlich wurde:
            Ein Node.js-Update von einer älteren Version direkt auf 22.x gemacht
            Adapter und js-controller über die Admin-Oberfläche aktualisiert (ohne npm-Kommandos)
            Der package-lock.json wurde dabei nie neu generiert
            Jetzt ist der node_modules-Ordner teilweise defekt/unvollständig​
            Lösung: Schritt-für-Schritt-Reparatur
            Option A: Saubere Neuinstallation der Dependencies (empfohlen)
            # 1. ioBroker stoppen
            iob stop
            # 2. Ins ioBroker-Verzeichnis wechseln
            cd /opt/iobroker
            # 3. Korrupte Dateien entfernen
            sudo rm -rf node_modules package-lock.json
            # 4. Dependencies komplett neu installieren
            npm install --loglevel=verbose
            # 5. Optional: ioBroker-Reparatur
            iob fix
            # 6. ioBroker starten
            iob start
            Falls Fehler auftreten, versuche zusätzlich:
            npm cache clean --force
            oder
            **Option B : ** Node.js auf LTS 20.x downgraden (sicherer)
            Node.js 22.x ist noch zu neu für viele ioBroker-Adapter. Downgrade auf die empfohlene Version 20.x:​
            # 1. Node.js 20.x installieren (siehe ioBroker-Forum-Anleitung)
            # Beispiel mit NodeSource:
            curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
            sudo apt-get install -y nodejs
            # 2. Verifizieren
            node -v  # sollte v20.x.x zeigen
            npm -v
            # 3. Dann Option A durchführen
            oder
            Option C : Manuelles Nachinstallieren (Notlösung)
            Falls du nicht alles löschen willst:
            cd /opt/iobroker
            # deep-clone explizit installieren
            npm install deep-clone@^3.0.3
            # Weitere fehlende Core-Dependencies
            npm install @iobroker/db-objects-file @iobroker/db-objects-jsonl \
                        @iobroker/adapter-core fs-extra jsonwebtoken
            # Lock-File neu generieren
            npm install --package-lock-only
            # Dann normales install
            npm install --production
            Debugging-Befehle zur Überprüfung
            # Dependency-Baum prüfen
            npm ls deep-clone
            npm ls @iobroker/js-controller-cli
            # Lock-File neu generieren (ohne Installation)
            # Verwaiste Packages entfernen
            npm prune
            G Thomas BraunT 2 Antworten Letzte Antwort
              Dann bin ich raus.
              was hälst du davon?
              eine Idee
              Hauptprobleme
              iob stop
              cd /opt/iobroker
              iob fix
              iob start
              oder
              # 2. Verifizieren
              npm -v
              oder
              cd /opt/iobroker
              npm ls deep-clone
              npm prune
              George_Best
              schrieb am zuletzt editiert von George_Best
              #80
              @crunchip
              Vielen, Vielen Dank - ich habe Option A gewählt. Bis jetzt läuft es wieder.
              Aber was meinst du mit "Neuinstallation" (der Dependencies) bzw. dann bei C "falls du nicht alles löschen willst".
              Bei A wurde doch nichts gelöscht.
              Und kann ich nun irgendwo/irgendwie überprüfen wo es noch haken könnte?
              • G George_Best
                @crunchip
                crunchipC Abwesend
                crunchipC Abwesend
                #81
                ja doch, deine veraltete package-lock.json, die noch diese alten "Bausteine", wie admin@3.5.10, js-controller@1.4.2 beinhaltet
                nochmal ein ìob diag preisgeben
                  George_Best
                  #82
                  @crunchip
                  ok - aber es wurden keine Objekte, Aliase, Scripte, Adapter-Konfigurationen o.ä. gelöscht.
                    Dann bin ich raus.
                    was hälst du davon?
                    eine Idee
                    Hauptprobleme
                    iob stop
                    cd /opt/iobroker
                    iob fix
                    iob start
                    oder
                    # 2. Verifizieren
                    npm -v
                    oder
                    cd /opt/iobroker
                    npm ls deep-clone
                    npm prune
                    #83
                    @crunchip sagte in iob fix und iob diag ohne Reaktion:
                    was hälst du davon?
                    In die Richtung package.lock löschen hatte ich auch schon gedacht.
                    Da ich aber nicht genau weiß, wie und woher sich da eine aktuelle 'Einkaufsliste' generiert und weil das Versionsdelta so groß ist hab ich davon als generelle Empfehlung für ein mir fremdes System Abstand genommen.
                    Bei nodejs@22 gehe ich allerdings nicht mit, das ist schon länger die für den ioBroker vorgesehene und empfohlene Version.
                    • G George_Best
                      @crunchip
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #84
                      @george_best nein, ist eine Datei, die automatisch von npm erstellt wird, um die exakten Versionen aller Abhängigkeiten (sowohl direkte als auch Unterabhängigkeiten) eines Node.js-Projekts zu speichern
                      • G Offline
                        George_Best
                        #85
                        iob diag:
                        ```bash
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                                 Chassis: vm 🖴
                          Virtualization: kvm
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         20:41:00 up  1:23,  2 users,  load average: 0.17, 0.13, 0.18
                        CPU threads: 8
                                       Local time: Wed 2025-11-12 20:41:00 CET
                                   Universal time: Wed 2025-11-12 19:41:00 UTC
                                         RTC time: Wed 2025-11-12 19:41:00
                                      NTP service: active
                                  RTC in local TZ: no
                        jonny
                        HOME=/home/jonny
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev bluetooth
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:             12G        3.6G        5.6G        561K        3.4G        8.6G
                        Swap:           4.3G          0B        4.3G
                        Total:           16G        3.6G        9.9G
                        Active iob-Instances:   37
                                 3396 M used memory
                                 1414 M active memory
                                 4379 M inactive memory
                                 5299 M free memory
                                  337 M buffer memory
                                 2923 M swap cache
                                 4093 M total swap
                                    0 M used swap
                                 4093 M free swap
                        top - 20:41:00 up  1:23,  2 users,  load average: 0.17, 0.13, 0.18
                        Tasks: 145 total,   1 running, 144 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :  11644.7 total,   5299.9 free,   3396.6 used,   3261.2 buff/cache
                        MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   8248.1 avail Mem
                        *** FILESYSTEM ***
                        /dev/sda1      ext4       28G   11G   16G  41% /
                        [Wed Nov 12 19:17:11 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                        [Wed Nov 12 19:17:11 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                        /var:
                        1.9G    /var/
                        889M    /var/cache
                        870M    /var/cache/apt
                        800M    /var/log
                        Archived and active journals take up 774.1M in the file system.
                        743M    /opt/iobroker/iobroker-data/
                        28M     /opt/iobroker/iobroker-data/objects.jsonl
                        17M     /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , alive, uptime: 2327)
                        js-controller:  7.0.7
                        admin:          7.7.19
                        javascript:     8.9.2
                        Adapter State
                        + system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
                        + system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
                          system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
                        + system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
                          system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
                          system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
                          system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
                          system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
                        + system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
                        + system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
                          system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
                        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
                        + system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
                        + system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
                          system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
                        + system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
                          system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              - disabled
                          system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              - disabled, port: 0
                          system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              - disabled, port: 0
                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
                          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
                          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
                          system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
                          system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                          system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                        + system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
                        + system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
                        + system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
                        + system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
                          system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
                        + system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
                          system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
                        + system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
                        + system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
                        + system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
                          system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
                          system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              - disabled, port: 8006
                          system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
                          system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
                        + system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
                        + system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
                        + system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
                          system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
                        + system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
                        + system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
                        + system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
                        + system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
                        + system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
                        + system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
                          system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
                          system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
                        + system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                        + system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
                          system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
                        + system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
                          system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
                        + system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                        + system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
                        + system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
                        + system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
                          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
                        + system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
                          system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
                          system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
                          system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
                          system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
                          system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
                          system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
                          system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
                        + system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + instance is alive
                        Active repo(s): stable
                        Upgrade policy: none
                        Used repository: stable
                        Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
                        Adapter    "admin"        : 7.7.19   , installed 7.7.19
                        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                        Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                        Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                        Adapter    "devices"      : 1.2.8    , installed 1.2.8
                        Adapter    "email"        : 2.0.4    , installed 2.0.4
                        Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                        Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                        Adapter    "iot"          : 5.0.7    , installed 5.0.7
                        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                        Controller "js-controller": 7.0.7    , installed 7.0.7
                        Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                        Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
                        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                        Adapter    "parser"       : 2.2.4    , installed 2.2.4
                        Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                        Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                        Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                        Adapter    "s7"           : 1.5.0    , installed 1.5.0
                        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                        Adapter    "sql"          : 3.0.1    , installed 3.0.1
                        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                        Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                        Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
                        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                        Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                        Objects and States
                        Objects:        24941
                        States:         20249
                        Pending Updates: 0
                        tcp        0      0 192.168.178.121:1883    0.0.0.0:*               LISTEN      1001       62221      16319/io.mqtt.0
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       61869      16021/iobroker.js-c
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       60923      16021/iobroker.js-c
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14195      493/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          14236      717/exim4
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14197      493/sshd: /usr/sbin
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       62430      16537/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       61921      16046/io.admin.0
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       65374      17265/io.socketio.0
                        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       64470      16708/io.terminal.0
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          14237      717/exim4
                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       64173      16450/io.radar2.1
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15581      353/dhclient
                        udp        0      0 0.0.0.0:59203           0.0.0.0:*                           1001       64745      16673/io.upnp.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       64783      16673/io.upnp.0
                        udp        0      0 0.0.0.0:37286           0.0.0.0:*                           107        754        424/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       62236      16349/io.chromecast
                        udp        0      0 192.168.178.121:5353    0.0.0.0:*                           1001       62234      16334/io.tr-064.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        752        424/avahi-daemon: r
                        udp6       0      0 :::60234                :::*                                107        755        424/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                107        753        424/avahi-daemon: r
                        2025-11-12 20:37:14.754  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:37:33.615  - warn: radar2.1 (16450) arp-scan maybe without rights because no data returned!
                        2025-11-12 20:38:15.937  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:38:16.063  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:38:16.185  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:38:16.595  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:38:33.614  - warn: radar2.1 (16450) arp-scan maybe without rights because no data returned!
                        2025-11-12 20:39:18.277  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:39:18.428  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:39:18.563  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:39:18.917  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:39:33.614  - warn: radar2.1 (16450) arp-scan maybe without rights because no data returned!
                        2025-11-12 20:40:20.305  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:40:20.448  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:40:20.565  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:40:20.971  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:40:33.615  - warn: radar2.1 (16450) arp-scan maybe without rights because no data returned!
                        2025-11-12 20:40:34.008  - info: host.ioBroker-V2 instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 18012
                        2025-11-12 20:40:35.089  - info: weatherunderground.0 (18012) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
                        2025-11-12 20:40:53.538  - info: weatherunderground.0 (18012) Terminated (NO_ERROR): Without reason
                        2025-11-12 20:40:54.052  - info: host.ioBroker-V2 instance system.adapter.weatherunderground.0 having pid 18012 terminated with code 0 (NO_ERROR)
                        2025-11-12 20:41:22.160  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:41:22.288  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:41:22.405  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        2025-11-12 20:41:22.766  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                        iob diag has finished.
                          was hälst du davon?
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #86
                          ok, ist vllt etwas falsch formuliert, die meisten Adapter sind darauf vorbereitet, mit jedoch immer noch bestehenden "Ausnahmen". Aufgrund seiner Konstellation, scheinbar viele Abhängigkeiten veraltet oder generell fehlten.
                          • G George_Best
                            iob diag:
                            ```bash
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 8
                                          NTP service: active
                                      RTC in local TZ: no
                            jonny
                            HOME=/home/jonny
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           4.3G          0B        4.3G
                                     3396 M used memory
                                     5299 M free memory
                                      337 M buffer memory
                                     2923 M swap cache
                                     4093 M total swap
                                        0 M used swap
                                     4093 M free swap
                            *** FILESYSTEM ***
                            /var:
                            1.9G    /var/
                            889M    /var/cache
                            870M    /var/cache/apt
                            800M    /var/log
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.4
                            /usr/bin/npx            10.9.4
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.7.19
                            javascript:     8.9.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        24941
                            States:         20249
                            Pending Updates: 0
                            #87
                            @george_best
                            Dann schau jetzt nochmal den npm-tree an.
                              @george_best
                              George_Best
                              #88
                              jonny@ioBroker-V2:/opt/iobroker$ npm ls
                              [sudo] Passwort für jonny:
                              iobroker.inst@2.0.2 /opt/iobroker
                              ├── @iobroker-javascript.0/moment-parseformat@npm:moment-parseformat@4.0.0
                              ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
                              ├── colors@1.4.0
                              ├── fs-extra@7.0.1
                              ├── iobroker.accuweather@2.1.1
                              ├── iobroker.admin@7.7.19
                              ├── iobroker.alias-manager@2.0.0
                              ├── iobroker.amazon-dash@1.2.0
                              ├── iobroker.chromecast@4.0.0
                              ├── iobroker.cloud@5.0.1
                              ├── iobroker.daswetter@3.2.3
                              ├── iobroker.deconz@1.6.4
                              ├── iobroker.devices@1.2.8
                              ├── iobroker.discovery@5.0.0
                              ├── iobroker.email@2.0.4
                              ├── iobroker.flot@1.12.0
                              ├── iobroker.fronius-solarweb@0.0.3
                              ├── iobroker.fronius@2.1.1
                              ├── iobroker.frontier_silicon@0.5.0
                              ├── iobroker.habpanel@0.5.0
                              ├── iobroker.history@3.0.1
                              ├── iobroker.hm-rega@5.1.0
                              ├── iobroker.hm-rpc@2.0.2
                              ├── iobroker.icons-addictive-flavour-png@0.1.0
                              ├── iobroker.icons-fatcow-hosting@0.1.0
                              ├── iobroker.icons-icons8@0.0.1
                              ├── iobroker.icons-material-png@0.1.0
                              ├── iobroker.icons-material-svg@0.1.0
                              ├── iobroker.icons-mfd-png@1.2.1
                              ├── iobroker.icons-mfd-svg@1.2.0
                              ├── iobroker.icons-open-icon-library-png@0.1.2
                              ├── iobroker.icons-ultimate-png@1.0.1
                              ├── iobroker.influxdb@4.0.2
                              ├── iobroker.info@2.0.0
                              ├── iobroker.iot@5.0.7
                              ├── iobroker.javascript@8.9.2
                              ├── iobroker.js-controller@7.0.7
                              ├── iobroker.mihome-vacuum@5.2.0
                              ├── iobroker.mqtt@6.1.4
                              ├── iobroker.net-tools@1.1.2
                              ├── iobroker.octoprint@5.1.0
                              ├── iobroker.openweathermap@1.1.2
                              ├── iobroker.parser@2.2.4
                              ├── iobroker.ping@1.6.2
                              ├── iobroker.proxmox@2.4.0
                              ├── iobroker.radar@1.2.1
                              ├── iobroker.radar2@2.4.0
                              ├── iobroker.reolink@1.2.3
                              ├── iobroker.rickshaw@1.0.0
                              ├── iobroker.s7@1.5.0
                              ├── iobroker.sayit@5.0.0
                              ├── iobroker.simple-api@2.8.0
                              ├── iobroker.smartmeter@3.4.0
                              ├── iobroker.socketio@6.7.1
                              ├── iobroker.sql@3.0.1
                              ├── iobroker.statistics@2.4.0
                              ├── iobroker.systeminfo@1.3.0
                              ├── iobroker.telegram@4.1.0
                              ├── iobroker.terminal@1.0.0
                              ├── iobroker.tr-064@4.3.0
                              ├── iobroker.unifi@0.7.0
                              ├── iobroker.upnp@1.1.0
                              ├── iobroker.vis-2-widgets-inventwo@0.2.2
                              ├── iobroker.vis-2-widgets-material@1.4.10
                              ├── iobroker.vis-2@2.13.4
                              ├── iobroker.vis-bars@0.1.4
                              ├── iobroker.vis-canvas-gauges@1.0.1
                              ├── iobroker.vis-colorpicker@2.0.3
                              ├── iobroker.vis-fancyswitch@1.1.0
                              ├── iobroker.vis-google-fonts@1.0.4
                              ├── iobroker.vis-history@1.0.0
                              ├── iobroker.vis-hqwidgets@1.5.1
                              ├── iobroker.vis-jqui-mfd@1.1.1
                              ├── iobroker.vis-justgage@2.1.7
                              ├── iobroker.vis-keyboard@0.0.2
                              ├── iobroker.vis-lcars@1.1.1
                              ├── iobroker.vis-map@1.1.2
                              ├── iobroker.vis-materialdesign@0.5.9
                              ├── iobroker.vis-metro@1.2.0
                              ├── iobroker.vis-rgraph@0.0.2
                              ├── iobroker.vis-weather@2.5.12
                              ├── iobroker.vis@1.5.6
                              ├── iobroker.weatherunderground@3.7.0
                              ├── iobroker.web@7.0.8
                              ├── iobroker.ws@2.6.2
                              ├── iobroker@2.0.3
                              ├── semver@5.7.2
                              └── yargs@7.1.2
                              npm ls graceful-fs
                              jonny@ioBroker-V2:/opt/iobroker$ npm ls graceful-fs
                              ├─┬ fs-extra@7.0.1
                              │ ├── graceful-fs@4.2.11
                              │ └─┬ jsonfile@4.0.0
                              │   └── graceful-fs@4.2.11 deduped
                              ├─┬ iobroker.admin@7.7.19
                              │ └─┬ archiver@7.0.1
                              │   └─┬ archiver-utils@5.0.2
                              ├─┬ iobroker.js-controller@7.0.7
                              │ ├─┬ @iobroker/db-objects-file@7.0.7
                              │ │ ├─┬ @iobroker/db-base@7.0.7
                              │ │ │ └─┬ fs-extra@11.3.2
                              │ │ │   ├── graceful-fs@4.2.11 deduped
                              │ │ │   └─┬ jsonfile@6.2.0
                              │ │ │     └── graceful-fs@4.2.11 deduped
                              │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
                              │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
                              │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                              │ │ │ │ └── graceful-fs@4.2.11 deduped
                              │ │ │ └─┬ fs-extra@10.1.0
                              │ ├─┬ @iobroker/js-controller-adapter@7.0.7
                              │ │ ├─┬ @alcalzone/pak@0.8.1
                              │ ├─┬ @iobroker/js-controller-cli@7.0.7
                              │ ├─┬ @iobroker/js-controller-common-db@7.0.7
                              │ ├─┬ @iobroker/js-controller-common@7.0.7
                              ├─┬ iobroker.radar@1.2.1
                              │ └─┬ @abandonware/noble@1.9.2-26
                              │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-12
                              │     └─┬ node-gyp@10.3.1
                              ├─┬ iobroker.radar2@2.4.0
                              │ └─┬ @stoprocent/noble@1.19.1
                              │   └─┬ @stoprocent/bluetooth-hci-socket@1.5.2
                              │     └─┬ patch-package@8.0.1
                              │       ├─┬ fs-extra@10.1.0
                              │       └─┬ klaw-sync@6.0.0
                              ├─┬ iobroker.simple-api@2.8.0
                              │ └─┬ @iobroker/testing@4.1.3
                              ├─┬ iobroker.sql@3.0.1
                              │ └─┬ sqlite3@5.1.7
                              │   └─┬ node-gyp@8.4.1
                              ├─┬ iobroker.vis-map@1.1.2
                              │ └─┬ @iobroker/dev-server@0.7.8
                              │   ├─┬ @iobroker/testing@5.2.2
                              │   ├─┬ browser-sync@3.0.4
                              │   │ └─┬ fs-extra@3.0.1
                              │   │   └─┬ jsonfile@3.0.1
                              └─┬ yargs@7.1.2
                                └─┬ read-pkg-up@1.0.1
                                  └─┬ read-pkg@1.1.0
                                    ├─┬ load-json-file@1.1.0
                                    └─┬ path-type@1.1.0
                              • G George_Best
                                iob diag:
                                ```bash
                                Script v.2025-08-09
                                *** BASE SYSTEM ***
                                         Chassis: vm 🖴
                                  Virtualization: kvm
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 8
                                              NTP service: active
                                          RTC in local TZ: no
                                jonny
                                HOME=/home/jonny
                                iobroker
                                HOME=/home/iobroker
                                Display-Manager:
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           4.3G          0B        4.3G
                                         3396 M used memory
                                         5299 M free memory
                                          337 M buffer memory
                                         2923 M swap cache
                                         4093 M total swap
                                            0 M used swap
                                         4093 M free swap
                                *** FILESYSTEM ***
                                /var:
                                1.9G    /var/
                                889M    /var/cache
                                870M    /var/cache/apt
                                800M    /var/log
                                USB-Devices by-id:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.9.4
                                /usr/bin/npx            10.9.4
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.7.19
                                javascript:     8.9.2
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        24941
                                States:         20249
                                Pending Updates: 0
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #89
                                @george_best und generell würde ich da mal etwas aufräumen, manch Adapter Instanzen doppelt und dreifach, die gar keinen Sinn ergeben oder den terminal adapter der im Normalfall gar nicht nötig ist.
                                  George_Best
                                  #90
                                  @crunchip
                                  Ja, ich befürchte ich werde mal iobroker inkl. der VM komplett neu installieren... müssen...
                                  An alle die mir in diesem Beitrag geholfen haben: Vielen, vielen Dank für eure professionelle Unterstützung 😁🙏
                                  • Thomas BraunT Online
                                    #91
                                    Und in der Vergangenheit auch mal derbe Probleme verursacht hatte. Weswegen ich den damals auch immer zum 'Hausverbot' vorgesehen hatte.
                                    iobroker.systeminfo
                                    iobroker.rickshaw
                                    iobroker.radar
                                    iobroker.info
                                    wären dafür auch gute Kandidaten.
                                    • G Offline
                                      George_Best
                                      #92
                                      Ich hab etwas Panik von der Neuinstallation, ob dann alle Adapter-Konfiguration, Objekte, Aliase, Skripte, Sql und und halbwegs restored werden können
                                      • G George_Best
                                        #93
                                        @george_best
                                        Vorher aufräumen, sonst zieht die Rumpelkammer ja mit.
                                        • G George_Best
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #94
                                          @george_best das erledigt doch backitup, darin ist alles enthalten, zumindest für deinen iobroker.
                                          • HomoranH Homoran hat dieses Thema am aufgespalten
