  4. iob fix und iob diag ohne Reaktion
    6.4k
94 Beiträge 8 Kommentatoren 12.8k Aufrufe 4 Beobachtet
  • G George_Best
    Ok - sieht das jetzt gut aus?
    jonny@ioBroker-V2:/opt/iobroker$ npm i
    npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
    npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
    npm warn deprecated lodash.get@4.4.2: This package is deprecated. Use the optional chaining (?.) operator instead.
    npm warn deprecated uid-number@0.0.6: This package is no longer supported.
    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
    npm warn deprecated npmlog@6.0.2: This package is no longer supported.
    npm warn deprecated lodash.isequal@4.5.0: This package is deprecated. Use require('node:util').isDeepStrictEqual instead.
    npm warn deprecated lodash.clone@4.5.0: This package is deprecated. Use structuredClone instead.
    npm warn deprecated har-validator@5.1.5: this library is no longer supported
    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
    npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated q@1.5.1: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
    npm warn deprecated
    npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
    npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm warn deprecated gauge@3.0.2: This package is no longer supported.
    npm warn deprecated gauge@4.0.4: This package is no longer supported.
    npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm warn deprecated gauge@2.7.4: This package is no longer supported.
    npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    > iobroker.inst@2.0.2 install
    > node lib/checkVersions.js
    NPM version: 10.9.4
    > iobroker.inst@2.0.2 postinstall
    > node lib/install.js
    lib/install.js is not being run as part of an installation - skipping...
    added 1019 packages, and changed 826 packages in 3m
    205 packages are looking for funding
      run `npm fund` for details
    #73
    @george_best sagte in iob fix und iob diag ohne Reaktion:
    Ich würde sagen das geht in die richtige Richtung.
    Gib mir nochmal ein
    iob diag
    G 1 Antwort Letzte Antwort
      Gib mir nochmal ein
      iob diag
      George_Best
      #74
      Oh nein...😢 iobroker läuft wieder nicht an. iob fix lief schon drüber
      jonny@ioBroker-V2:/opt/iobroker$ iob status
      node:internal/modules/package_json_reader:314
        throw new ERR_MODULE_NOT_FOUND(packageName, fileURLToPath(base), null);
      Error [ERR_MODULE_NOT_FOUND]: Cannot find package 'deep-clone' imported from /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup.js
          at Object.getPackageJSONURL (node:internal/modules/package_json_reader:314:9)
          at packageResolve (node:internal/modules/esm/resolve:767:81)
          at moduleResolve (node:internal/modules/esm/resolve:853:18)
          at defaultResolve (node:internal/modules/esm/resolve:983:11)
          at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
          at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
          at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
          at ModuleJob._link (node:internal/modules/esm/module_job:182:49) {
        code: 'ERR_MODULE_NOT_FOUND'
      Node.js v22.21.0
      iob diag:
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: ioBroker-V2
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-41-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
      OS is similar to:
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:04:37 up  3:02,  2 users,  load average: 0.41, 0.73, 0.60
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-11-12 19:04:37 CET
                 Universal time: Wed 2025-11-12 18:04:37 UTC
                       RTC time: Wed 2025-11-12 18:04:37
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      jonny
      HOME=/home/jonny
      GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             12G        528M        8.5G        565K        3.5G         11G
      Swap:           4.3G          0B        4.3G
      Total:           16G        528M         12G
      Active iob-Instances:   0
              11644 M total memory
                503 M used memory
               1640 M active memory
               1318 M inactive memory
               8133 M free memory
                588 M buffer memory
               2732 M swap cache
               4093 M total swap
                  0 M used swap
               4093 M free swap
      top - 19:04:37 up  3:02,  2 users,  load average: 0.41, 0.73, 0.60
      Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  11644.7 total,   8133.2 free,    504.4 used,   3320.4 buff/cache
      MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11140.3 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  5.7G     0  5.7G   0% /dev
      tmpfs          tmpfs     1.2G  552K  1.2G   1% /run
      /dev/sda1      ext4       28G  9.6G   17G  37% /
      tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
      [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      1.9G    /var/
      889M    /var/cache
      870M    /var/cache/apt
      815M    /var/log
      793M    /var/cache/apt/archives
      Archived and active journals take up 790.1M in the file system.
      /opt/iobroker/backups:
      22M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      728M    /opt/iobroker/iobroker-data/
      503M    /opt/iobroker/iobroker-data/files
      166M    /opt/iobroker/iobroker-data/backup-objects
      96M     /opt/iobroker/iobroker-data/files/vis-2
      81M     /opt/iobroker/iobroker-data/files/vis
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.21.0
      /usr/bin/node           v22.21.0
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.21.0-1nodesource1
        Candidate: 22.21.0-1nodesource1
        Version table:
       *** 22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.20.4+dfsg-1~deb12u1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Node.js v22.21.0
      Hosts:
      Node.js v22.21.0
      Core adapters versions
      Node.js v22.21.0
      js-controller:
      Node.js v22.21.0
      admin:
      Node.js v22.21.0
      javascript:
      nodejs modules from github:     0
      Adapter State
      ioBroker-Repositories
      Node.js v22.21.0
      Installed ioBroker-Adapters
      Node.js v22.21.0
      Objects and States
      Objects:        0
      States:         0
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17410      736/exim4
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15485      553/sshd: /usr/sbin
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17411      736/exim4
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15487      553/sshd: /usr/sbin
      udp        0      0 0.0.0.0:35015           0.0.0.0:*                           107        13947      440/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        13945      440/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13849      376/dhclient
      udp6       0      0 :::36795                :::*                                107        13948      440/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                107        13946      440/avahi-daemon: r
      2025-11-12 19:00:53.505  - info: javascript.0 (47593) terminating
      2025-11-12 19:00:53.508  - info: javascript.0 (47593) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-11-12 19:00:53.549  - info: host.ioBroker-V2 stopInstance system.adapter.admin.0 send kill signal
      2025-11-12 19:00:53.593  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.0 send kill signal
      2025-11-12 19:00:53.593  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.1 send kill signal
      2025-11-12 19:00:53.593  - info: host.ioBroker-V2 stopInstance system.adapter.email.0 send kill signal
      2025-11-12 19:00:53.593  - info: host.ioBroker-V2 stopInstance system.adapter.telegram.0 send kill signal
      2025-11-12 19:00:53.692  - info: history.0 (47655) Terminated (NO_ERROR): Without reason
      2025-11-12 19:00:53.994  - info: javascript.1 (47625) terminating
      2025-11-12 19:00:53.995  - info: telegram.0 (47670) terminating
      2025-11-12 19:00:53.996  - info: telegram.0 (47670) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-11-12 19:00:53.996  - info: email.0 (47640) terminating
      2025-11-12 19:00:53.999  - info: admin.0 (47501) terminating
      2025-11-12 19:00:54.006  - info: javascript.0 (47593) terminating
      2025-11-12 19:00:54.126  - info: host.ioBroker-V2 instance system.adapter.email.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-11-12 19:00:54.414  - info: host.ioBroker-V2 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-11-12 19:00:54.440  - info: host.ioBroker-V2 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-11-12 19:00:54.491  - info: host.ioBroker-V2 instance system.adapter.javascript.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-11-12 19:00:59.547  - error: sql.0 (47561) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2025-11-12 19:00:59.548  - error: sql.0 (47561) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2025-11-12 19:01:04.552  - error: sql.0 (47561) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2025-11-12 19:01:04.553  - error: sql.0 (47561) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2025-11-12 19:01:05.552  - info: sql.0 (47561) terminating with timeout
      2025-11-12 19:01:05.553  - info: sql.0 (47561) Terminated (NO_ERROR): Without reason
      2025-11-12 19:01:09.556  - error: sql.0 (47561) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      • G George_Best
        Node.js v22.21.0
        iob diag:
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        jonny
        HOME=/home/jonny
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           4.3G          0B        4.3G
        Total:           16G        528M         12G
                  503 M used memory
                 8133 M free memory
                  588 M buffer memory
                 2732 M swap cache
                 4093 M total swap
                    0 M used swap
                 4093 M free swap
        *** FILESYSTEM ***
        /var:
        1.9G    /var/
        889M    /var/cache
        870M    /var/cache/apt
        815M    /var/log
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
        ioBroker Status
        Node.js v22.21.0
        Hosts:
        Node.js v22.21.0
        Node.js v22.21.0
        js-controller:
        Node.js v22.21.0
        admin:
        Node.js v22.21.0
        javascript:
        Adapter State
        Node.js v22.21.0
        Node.js v22.21.0
        Objects and States
        Objects:        0
        States:         0
        Pending Updates: 0
        #75
        @george_best
        cd /opt/iobroker && npm ci
          @george_best
          George_Best
          #76
          @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
          sieht wieder sehr wild aus...
          jonny@ioBroker-V2:/opt/iobroker$ cd /opt/iobroker && npm ci
          npm warn old lockfile
          npm warn old lockfile The package-lock.json file was created with an old version of npm,
          npm warn old lockfile so supplemental metadata must be fetched from the registry.
          npm warn old lockfile This is a one-time fix-up, please be patient...
          npm error code EUSAGE
          npm error
          npm error `npm ci` can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with `npm install` before continuing.
          npm error
          npm error Missing: @iobroker-javascript.0/moment@2.30.1 from lock file
          npm error Missing: @iobroker-javascript.0/moment-parseformat@4.0.0 from lock file
          npm error Missing: iobroker.accuweather@2.1.1 from lock file
          npm error Invalid: lock file's iobroker.admin@3.5.10 does not satisfy iobroker.admin@7.7.19
          npm error Missing: iobroker.alias-manager@2.0.0 from lock file
          npm error Missing: iobroker.amazon-dash@1.2.0 from lock file
          npm error Missing: iobroker.chromecast@4.0.0 from lock file
          npm error Missing: iobroker.cloud@5.0.1 from lock file
          npm error Missing: iobroker.daswetter@3.2.3 from lock file
          npm error Missing: iobroker.deconz@1.6.4 from lock file
          npm error Missing: iobroker.devices@1.2.8 from lock file
          npm error Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@5.0.0
          npm error Missing: iobroker.email@2.0.4 from lock file
          npm error Missing: iobroker.flot@1.12.0 from lock file
          npm error Missing: iobroker.fronius@2.1.1 from lock file
          npm error Missing: iobroker.fronius-solarweb@0.0.3 from lock file
          npm error Missing: iobroker.frontier_silicon@0.5.0 from lock file
          npm error Missing: iobroker.habpanel@0.5.0 from lock file
          npm error Missing: iobroker.history@3.0.1 from lock file
          npm error Missing: iobroker.hm-rega@5.1.0 from lock file
          npm error Missing: iobroker.hm-rpc@2.0.2 from lock file
          npm error Missing: iobroker.hs100@3.0.5 from lock file
          npm error Missing: iobroker.icons-addictive-flavour-png@0.1.0 from lock file
          npm error Missing: iobroker.icons-fatcow-hosting@0.1.0 from lock file
          npm error Missing: iobroker.icons-icons8@0.0.1 from lock file
          npm error Missing: iobroker.icons-material-png@0.1.0 from lock file
          npm error Missing: iobroker.icons-material-svg@0.1.0 from lock file
          npm error Missing: iobroker.icons-mfd-png@1.2.1 from lock file
          npm error Missing: iobroker.icons-mfd-svg@1.2.0 from lock file
          npm error Missing: iobroker.icons-open-icon-library-png@0.1.2 from lock file
          npm error Missing: iobroker.icons-ultimate-png@1.0.1 from lock file
          npm error Missing: iobroker.influxdb@4.0.2 from lock file
          npm error Missing: iobroker.info@2.0.0 from lock file
          npm error Missing: iobroker.iot@5.0.7 from lock file
          npm error Missing: iobroker.javascript@8.9.2 from lock file
          npm error Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@7.0.7
          npm error Missing: iobroker.mihome-vacuum@5.2.0 from lock file
          npm error Missing: iobroker.mqtt@6.1.4 from lock file
          npm error Missing: iobroker.net-tools@1.1.2 from lock file
          npm error Missing: iobroker.octoprint@5.1.0 from lock file
          npm error Missing: iobroker.openweathermap@1.1.2 from lock file
          npm error Missing: iobroker.parser@2.2.4 from lock file
          npm error Missing: iobroker.ping@1.6.2 from lock file
          npm error Missing: iobroker.proxmox@2.4.0 from lock file
          [2025-11-12T18_10_30_372Z-debug-0.log](/assets/uploads/files/1762971379377-2025-11-12t18_10_30_372z-debug-0.log)
          • G George_Best
            npm error
            npm error
            #77
            @george_best
            Dann bin ich raus.
            • G Offline
              George_Best
              #78
              Irgendjemand eine Idee, wie ich das wieder hinbekomme?
              jonny@ioBroker-V2:~$ iob status
              Node.js v22.21.0
              • crunchipC Offline
                crunchipC Offline
                #79
                Dann bin ich raus.
                was hälst du davon?
                eine Idee
                Hauptprobleme
                1. Fehlende Dependency "deep-clone"
                Das Package deep-clone wird vom js-controller (bzw. js-controller-cli) im ESM-Modus benötigt und fehlt komplett in deinem node_modules-Verzeichnis. Der js-controller 7.0.7 benötigt deep-clone@^3.0.3 als kritische Abhängigkeit.​
                1. Package-Lock.json massiv desynchronisiert
                Dein package-lock.json ist völlig veraltet und passt nicht mehr zur package.json:
                Lock-File enthält admin@3.5.10, tatsächlich installiert ist aber admin@7.7.19
                Lock-File enthält js-controller@1.4.2, installiert ist aber js-controller@7.0.7
                Dutzende Adapter fehlen komplett im Lock-File (accuweather, alias-manager, chromecast, cloud, etc.)​
                1. Node.js 22.x Kompatibilitätsprobleme
                Der js-controller 7.0.7 unterstützt zwar "probably" Node.js 22.x, ist aber primär für 18.x und 20.x getestet. Einige Adapter-Dependencies haben explizite Node-Restriktionen (wie @homebridge/ciao), die Node.js 22 blockieren.​
                1. npm ci schlägt fehl
                npm ci kann nur funktionieren, wenn package.json und package-lock.json synchron sind. Bei dir sind sie massiv inkonsistent, weshalb npm ci mit "old lockfile" und "Missing/Invalid" Fehlern abbricht.​
                Warum ist das passiert?
                Höchstwahrscheinlich wurde:
                Ein Node.js-Update von einer älteren Version direkt auf 22.x gemacht
                Adapter und js-controller über die Admin-Oberfläche aktualisiert (ohne npm-Kommandos)
                Der package-lock.json wurde dabei nie neu generiert
                Jetzt ist der node_modules-Ordner teilweise defekt/unvollständig​
                Lösung: Schritt-für-Schritt-Reparatur
                Option A: Saubere Neuinstallation der Dependencies (empfohlen)
                # 1. ioBroker stoppen
                iob stop
                # 2. Ins ioBroker-Verzeichnis wechseln
                cd /opt/iobroker
                # 3. Korrupte Dateien entfernen
                sudo rm -rf node_modules package-lock.json
                # 4. Dependencies komplett neu installieren
                npm install --loglevel=verbose
                # 5. Optional: ioBroker-Reparatur
                iob fix
                # 6. ioBroker starten
                iob start
                Falls Fehler auftreten, versuche zusätzlich:
                npm cache clean --force
                oder
                **Option B : ** Node.js auf LTS 20.x downgraden (sicherer)
                Node.js 22.x ist noch zu neu für viele ioBroker-Adapter. Downgrade auf die empfohlene Version 20.x:​
                # 1. Node.js 20.x installieren (siehe ioBroker-Forum-Anleitung)
                # Beispiel mit NodeSource:
                curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                sudo apt-get install -y nodejs
                # 2. Verifizieren
                node -v  # sollte v20.x.x zeigen
                npm -v
                # 3. Dann Option A durchführen
                oder
                Option C : Manuelles Nachinstallieren (Notlösung)
                Falls du nicht alles löschen willst:
                cd /opt/iobroker
                # deep-clone explizit installieren
                npm install deep-clone@^3.0.3
                # Weitere fehlende Core-Dependencies
                npm install @iobroker/db-objects-file @iobroker/db-objects-jsonl \
                            @iobroker/adapter-core fs-extra jsonwebtoken
                # Lock-File neu generieren
                npm install --package-lock-only
                # Dann normales install
                npm install --production
                Debugging-Befehle zur Überprüfung
                # Dependency-Baum prüfen
                npm ls deep-clone
                npm ls @iobroker/js-controller-cli
                # Lock-File neu generieren (ohne Installation)
                # Verwaiste Packages entfernen
                npm prune
                G Thomas BraunT 2 Antworten Letzte Antwort
                  Dann bin ich raus.
                  was hälst du davon?
                  eine Idee
                  Hauptprobleme
                  iob stop
                  cd /opt/iobroker
                  iob fix
                  iob start
                  oder
                  # 2. Verifizieren
                  npm -v
                  oder
                  cd /opt/iobroker
                  npm ls deep-clone
                  npm prune
                  George_Best
                  schrieb am zuletzt editiert von George_Best
                  #80
                  @crunchip
                  Vielen, Vielen Dank - ich habe Option A gewählt. Bis jetzt läuft es wieder.
                  Aber was meinst du mit "Neuinstallation" (der Dependencies) bzw. dann bei C "falls du nicht alles löschen willst".
                  Bei A wurde doch nichts gelöscht.
                  Und kann ich nun irgendwo/irgendwie überprüfen wo es noch haken könnte?
                  • G George_Best
                    @crunchip
                    crunchipC Offline
                    crunchipC Offline
                    #81
                    ja doch, deine veraltete package-lock.json, die noch diese alten "Bausteine", wie admin@3.5.10, js-controller@1.4.2 beinhaltet
                    nochmal ein ìob diag preisgeben
                      George_Best
                      #82
                      @crunchip
                      ok - aber es wurden keine Objekte, Aliase, Scripte, Adapter-Konfigurationen o.ä. gelöscht.
                        Dann bin ich raus.
                        was hälst du davon?
                        eine Idee
                        Hauptprobleme
                        iob stop
                        cd /opt/iobroker
                        iob fix
                        iob start
                        oder
                        # 2. Verifizieren
                        npm -v
                        oder
                        cd /opt/iobroker
                        npm ls deep-clone
                        npm prune
                        #83
                        @crunchip sagte in iob fix und iob diag ohne Reaktion:
                        was hälst du davon?
                        In die Richtung package.lock löschen hatte ich auch schon gedacht.
                        Da ich aber nicht genau weiß, wie und woher sich da eine aktuelle 'Einkaufsliste' generiert und weil das Versionsdelta so groß ist hab ich davon als generelle Empfehlung für ein mir fremdes System Abstand genommen.
                        Bei nodejs@22 gehe ich allerdings nicht mit, das ist schon länger die für den ioBroker vorgesehene und empfohlene Version.
                        • G George_Best
                          @crunchip
                          crunchipC Offline
                          crunchipC Offline
                          #84
                          @george_best nein, ist eine Datei, die automatisch von npm erstellt wird, um die exakten Versionen aller Abhängigkeiten (sowohl direkte als auch Unterabhängigkeiten) eines Node.js-Projekts zu speichern
                          • G Offline
                            George_Best
                            #85
                            iob diag:
                            ```bash
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             20:41:00 up  1:23,  2 users,  load average: 0.17, 0.13, 0.18
                            CPU threads: 8
                                           Local time: Wed 2025-11-12 20:41:00 CET
                                       Universal time: Wed 2025-11-12 19:41:00 UTC
                                             RTC time: Wed 2025-11-12 19:41:00
                                          NTP service: active
                                      RTC in local TZ: no
                            jonny
                            HOME=/home/jonny
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev bluetooth
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:             12G        3.6G        5.6G        561K        3.4G        8.6G
                            Swap:           4.3G          0B        4.3G
                            Total:           16G        3.6G        9.9G
                            Active iob-Instances:   37
                                     3396 M used memory
                                     1414 M active memory
                                     4379 M inactive memory
                                     5299 M free memory
                                      337 M buffer memory
                                     2923 M swap cache
                                     4093 M total swap
                                        0 M used swap
                                     4093 M free swap
                            top - 20:41:00 up  1:23,  2 users,  load average: 0.17, 0.13, 0.18
                            Tasks: 145 total,   1 running, 144 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :  11644.7 total,   5299.9 free,   3396.6 used,   3261.2 buff/cache
                            MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   8248.1 avail Mem
                            *** FILESYSTEM ***
                            /dev/sda1      ext4       28G   11G   16G  41% /
                            [Wed Nov 12 19:17:11 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                            [Wed Nov 12 19:17:11 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                            /var:
                            1.9G    /var/
                            889M    /var/cache
                            870M    /var/cache/apt
                            800M    /var/log
                            Archived and active journals take up 774.1M in the file system.
                            743M    /opt/iobroker/iobroker-data/
                            28M     /opt/iobroker/iobroker-data/objects.jsonl
                            17M     /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.4
                            /usr/bin/npx            10.9.4
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , alive, uptime: 2327)
                            js-controller:  7.0.7
                            admin:          7.7.19
                            javascript:     8.9.2
                            Adapter State
                            + system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
                            + system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                              system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
                              system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
                            + system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
                              system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
                              system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
                              system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
                              system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
                            + system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
                            + system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
                              system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
                            + system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
                            + system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
                            + system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
                              system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
                            + system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
                              system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              - disabled
                              system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              - disabled, port: 0
                              system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              - disabled, port: 0
                              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
                              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
                              system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
                              system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
                              system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
                              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
                              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
                              system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                              system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                            + system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
                            + system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
                            + system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
                            + system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
                              system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
                            + system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
                              system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
                            + system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
                            + system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
                            + system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
                              system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
                              system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              - disabled, port: 8006
                              system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
                              system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
                            + system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
                            + system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
                            + system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
                              system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
                            + system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
                            + system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
                            + system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
                            + system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
                            + system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
                            + system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
                              system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                              system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
                              system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
                            + system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
                              system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
                            + system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
                              system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
                            + system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                            + system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
                            + system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
                            + system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
                              system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
                              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
                            + system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
                              system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
                              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
                              system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
                              system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
                              system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
                              system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
                              system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
                              system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
                              system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
                              system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
                              system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
                              system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
                              system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
                            + system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            Active repo(s): stable
                            Upgrade policy: none
                            Used repository: stable
                            Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
                            Adapter    "admin"        : 7.7.19   , installed 7.7.19
                            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                            Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                            Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                            Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                            Adapter    "devices"      : 1.2.8    , installed 1.2.8
                            Adapter    "email"        : 2.0.4    , installed 2.0.4
                            Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                            Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                            Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
                            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                            Adapter    "iot"          : 5.0.7    , installed 5.0.7
                            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                            Controller "js-controller": 7.0.7    , installed 7.0.7
                            Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                            Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
                            Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                            Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                            Adapter    "parser"       : 2.2.4    , installed 2.2.4
                            Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                            Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                            Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                            Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                            Adapter    "s7"           : 1.5.0    , installed 1.5.0
                            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                            Adapter    "sql"          : 3.0.1    , installed 3.0.1
                            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                            Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
                            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                            Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                            Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                            Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
                            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                            Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                            Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                            Adapter    "web"          : 7.0.8    , installed 7.0.8
                            Objects and States
                            Objects:        24941
                            States:         20249
                            Pending Updates: 0
                            tcp        0      0 192.168.178.121:1883    0.0.0.0:*               LISTEN      1001       62221      16319/io.mqtt.0
                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       61869      16021/iobroker.js-c
                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       60923      16021/iobroker.js-c
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14195      493/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          14236      717/exim4
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14197      493/sshd: /usr/sbin
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       62430      16537/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       61921      16046/io.admin.0
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       65374      17265/io.socketio.0
                            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       64470      16708/io.terminal.0
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          14237      717/exim4
                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       64173      16450/io.radar2.1
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15581      353/dhclient
                            udp        0      0 0.0.0.0:59203           0.0.0.0:*                           1001       64745      16673/io.upnp.0
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       64783      16673/io.upnp.0
                            udp        0      0 0.0.0.0:37286           0.0.0.0:*                           107        754        424/avahi-daemon: r
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       62236      16349/io.chromecast
                            udp        0      0 192.168.178.121:5353    0.0.0.0:*                           1001       62234      16334/io.tr-064.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        752        424/avahi-daemon: r
                            udp6       0      0 :::60234                :::*                                107        755        424/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                107        753        424/avahi-daemon: r
                            2025-11-12 20:37:14.754  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:37:33.615  - warn: radar2.1 (16450) arp-scan maybe without rights because no data returned!
                            2025-11-12 20:38:15.937  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:38:16.063  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:38:16.185  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:38:16.595  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:38:33.614  - warn: radar2.1 (16450) arp-scan maybe without rights because no data returned!
                            2025-11-12 20:39:18.277  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:39:18.428  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:39:18.563  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:39:18.917  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:39:33.614  - warn: radar2.1 (16450) arp-scan maybe without rights because no data returned!
                            2025-11-12 20:40:20.305  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:40:20.448  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:40:20.565  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:40:20.971  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:40:33.615  - warn: radar2.1 (16450) arp-scan maybe without rights because no data returned!
                            2025-11-12 20:40:34.008  - info: host.ioBroker-V2 instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 18012
                            2025-11-12 20:40:35.089  - info: weatherunderground.0 (18012) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
                            2025-11-12 20:40:53.538  - info: weatherunderground.0 (18012) Terminated (NO_ERROR): Without reason
                            2025-11-12 20:40:54.052  - info: host.ioBroker-V2 instance system.adapter.weatherunderground.0 having pid 18012 terminated with code 0 (NO_ERROR)
                            2025-11-12 20:41:22.160  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:41:22.288  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:41:22.405  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            2025-11-12 20:41:22.766  - info: tr-064.0 (16334) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                            iob diag has finished.
                              was hälst du davon?
                              crunchipC Offline
                              crunchipC Offline
                              #86
                              ok, ist vllt etwas falsch formuliert, die meisten Adapter sind darauf vorbereitet, mit jedoch immer noch bestehenden "Ausnahmen". Aufgrund seiner Konstellation, scheinbar viele Abhängigkeiten veraltet oder generell fehlten.
                              • G George_Best
                                iob diag:
                                ```bash
                                Script v.2025-08-09
                                *** BASE SYSTEM ***
                                         Chassis: vm 🖴
                                  Virtualization: kvm
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 8
                                              NTP service: active
                                          RTC in local TZ: no
                                jonny
                                HOME=/home/jonny
                                iobroker
                                HOME=/home/iobroker
                                Display-Manager:
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           4.3G          0B        4.3G
                                         3396 M used memory
                                         5299 M free memory
                                          337 M buffer memory
                                         2923 M swap cache
                                         4093 M total swap
                                            0 M used swap
                                         4093 M free swap
                                *** FILESYSTEM ***
                                /var:
                                1.9G    /var/
                                889M    /var/cache
                                870M    /var/cache/apt
                                800M    /var/log
                                USB-Devices by-id:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.9.4
                                /usr/bin/npx            10.9.4
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.7.19
                                javascript:     8.9.2
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        24941
                                States:         20249
                                Pending Updates: 0
                                #87
                                @george_best
                                Dann schau jetzt nochmal den npm-tree an.
                                  @george_best
                                  George_Best
                                  #88
                                  jonny@ioBroker-V2:/opt/iobroker$ npm ls
                                  [sudo] Passwort für jonny:
                                  iobroker.inst@2.0.2 /opt/iobroker
                                  ├── @iobroker-javascript.0/moment-parseformat@npm:moment-parseformat@4.0.0
                                  ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
                                  ├── colors@1.4.0
                                  ├── fs-extra@7.0.1
                                  ├── iobroker.accuweather@2.1.1
                                  ├── iobroker.admin@7.7.19
                                  ├── iobroker.alias-manager@2.0.0
                                  ├── iobroker.amazon-dash@1.2.0
                                  ├── iobroker.chromecast@4.0.0
                                  ├── iobroker.cloud@5.0.1
                                  ├── iobroker.daswetter@3.2.3
                                  ├── iobroker.deconz@1.6.4
                                  ├── iobroker.devices@1.2.8
                                  ├── iobroker.discovery@5.0.0
                                  ├── iobroker.email@2.0.4
                                  ├── iobroker.flot@1.12.0
                                  ├── iobroker.fronius-solarweb@0.0.3
                                  ├── iobroker.fronius@2.1.1
                                  ├── iobroker.frontier_silicon@0.5.0
                                  ├── iobroker.habpanel@0.5.0
                                  ├── iobroker.history@3.0.1
                                  ├── iobroker.hm-rega@5.1.0
                                  ├── iobroker.hm-rpc@2.0.2
                                  ├── iobroker.icons-addictive-flavour-png@0.1.0
                                  ├── iobroker.icons-fatcow-hosting@0.1.0
                                  ├── iobroker.icons-icons8@0.0.1
                                  ├── iobroker.icons-material-png@0.1.0
                                  ├── iobroker.icons-material-svg@0.1.0
                                  ├── iobroker.icons-mfd-png@1.2.1
                                  ├── iobroker.icons-mfd-svg@1.2.0
                                  ├── iobroker.icons-open-icon-library-png@0.1.2
                                  ├── iobroker.icons-ultimate-png@1.0.1
                                  ├── iobroker.influxdb@4.0.2
                                  ├── iobroker.info@2.0.0
                                  ├── iobroker.iot@5.0.7
                                  ├── iobroker.javascript@8.9.2
                                  ├── iobroker.js-controller@7.0.7
                                  ├── iobroker.mihome-vacuum@5.2.0
                                  ├── iobroker.mqtt@6.1.4
                                  ├── iobroker.net-tools@1.1.2
                                  ├── iobroker.octoprint@5.1.0
                                  ├── iobroker.openweathermap@1.1.2
                                  ├── iobroker.parser@2.2.4
                                  ├── iobroker.ping@1.6.2
                                  ├── iobroker.proxmox@2.4.0
                                  ├── iobroker.radar@1.2.1
                                  ├── iobroker.radar2@2.4.0
                                  ├── iobroker.reolink@1.2.3
                                  ├── iobroker.rickshaw@1.0.0
                                  ├── iobroker.s7@1.5.0
                                  ├── iobroker.sayit@5.0.0
                                  ├── iobroker.simple-api@2.8.0
                                  ├── iobroker.smartmeter@3.4.0
                                  ├── iobroker.socketio@6.7.1
                                  ├── iobroker.sql@3.0.1
                                  ├── iobroker.statistics@2.4.0
                                  ├── iobroker.systeminfo@1.3.0
                                  ├── iobroker.telegram@4.1.0
                                  ├── iobroker.terminal@1.0.0
                                  ├── iobroker.tr-064@4.3.0
                                  ├── iobroker.unifi@0.7.0
                                  ├── iobroker.upnp@1.1.0
                                  ├── iobroker.vis-2-widgets-inventwo@0.2.2
                                  ├── iobroker.vis-2-widgets-material@1.4.10
                                  ├── iobroker.vis-2@2.13.4
                                  ├── iobroker.vis-bars@0.1.4
                                  ├── iobroker.vis-canvas-gauges@1.0.1
                                  ├── iobroker.vis-colorpicker@2.0.3
                                  ├── iobroker.vis-fancyswitch@1.1.0
                                  ├── iobroker.vis-google-fonts@1.0.4
                                  ├── iobroker.vis-history@1.0.0
                                  ├── iobroker.vis-hqwidgets@1.5.1
                                  ├── iobroker.vis-jqui-mfd@1.1.1
                                  ├── iobroker.vis-justgage@2.1.7
                                  ├── iobroker.vis-keyboard@0.0.2
                                  ├── iobroker.vis-lcars@1.1.1
                                  ├── iobroker.vis-map@1.1.2
                                  ├── iobroker.vis-materialdesign@0.5.9
                                  ├── iobroker.vis-metro@1.2.0
                                  ├── iobroker.vis-rgraph@0.0.2
                                  ├── iobroker.vis-weather@2.5.12
                                  ├── iobroker.vis@1.5.6
                                  ├── iobroker.weatherunderground@3.7.0
                                  ├── iobroker.web@7.0.8
                                  ├── iobroker.ws@2.6.2
                                  ├── iobroker@2.0.3
                                  ├── semver@5.7.2
                                  └── yargs@7.1.2
                                  npm ls graceful-fs
                                  jonny@ioBroker-V2:/opt/iobroker$ npm ls graceful-fs
                                  ├─┬ fs-extra@7.0.1
                                  │ ├── graceful-fs@4.2.11
                                  │ └─┬ jsonfile@4.0.0
                                  │   └── graceful-fs@4.2.11 deduped
                                  ├─┬ iobroker.admin@7.7.19
                                  │ └─┬ archiver@7.0.1
                                  │   └─┬ archiver-utils@5.0.2
                                  ├─┬ iobroker.js-controller@7.0.7
                                  │ ├─┬ @iobroker/db-objects-file@7.0.7
                                  │ │ ├─┬ @iobroker/db-base@7.0.7
                                  │ │ │ └─┬ fs-extra@11.3.2
                                  │ │ │   ├── graceful-fs@4.2.11 deduped
                                  │ │ │   └─┬ jsonfile@6.2.0
                                  │ │ │     └── graceful-fs@4.2.11 deduped
                                  │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
                                  │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
                                  │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                                  │ │ │ │ └── graceful-fs@4.2.11 deduped
                                  │ │ │ └─┬ fs-extra@10.1.0
                                  │ ├─┬ @iobroker/js-controller-adapter@7.0.7
                                  │ │ ├─┬ @alcalzone/pak@0.8.1
                                  │ ├─┬ @iobroker/js-controller-cli@7.0.7
                                  │ ├─┬ @iobroker/js-controller-common-db@7.0.7
                                  │ ├─┬ @iobroker/js-controller-common@7.0.7
                                  ├─┬ iobroker.radar@1.2.1
                                  │ └─┬ @abandonware/noble@1.9.2-26
                                  │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-12
                                  │     └─┬ node-gyp@10.3.1
                                  ├─┬ iobroker.radar2@2.4.0
                                  │ └─┬ @stoprocent/noble@1.19.1
                                  │   └─┬ @stoprocent/bluetooth-hci-socket@1.5.2
                                  │     └─┬ patch-package@8.0.1
                                  │       ├─┬ fs-extra@10.1.0
                                  │       └─┬ klaw-sync@6.0.0
                                  ├─┬ iobroker.simple-api@2.8.0
                                  │ └─┬ @iobroker/testing@4.1.3
                                  ├─┬ iobroker.sql@3.0.1
                                  │ └─┬ sqlite3@5.1.7
                                  │   └─┬ node-gyp@8.4.1
                                  ├─┬ iobroker.vis-map@1.1.2
                                  │ └─┬ @iobroker/dev-server@0.7.8
                                  │   ├─┬ @iobroker/testing@5.2.2
                                  │   ├─┬ browser-sync@3.0.4
                                  │   │ └─┬ fs-extra@3.0.1
                                  │   │   └─┬ jsonfile@3.0.1
                                  └─┬ yargs@7.1.2
                                    └─┬ read-pkg-up@1.0.1
                                      └─┬ read-pkg@1.1.0
                                        ├─┬ load-json-file@1.1.0
                                        └─┬ path-type@1.1.0
                                  • G George_Best
                                    iob diag:
                                    ```bash
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    CPU threads: 8
                                                  NTP service: active
                                              RTC in local TZ: no
                                    jonny
                                    HOME=/home/jonny
                                    iobroker
                                    HOME=/home/iobroker
                                    Display-Manager:
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                    Swap:           4.3G          0B        4.3G
                                             3396 M used memory
                                             5299 M free memory
                                              337 M buffer memory
                                             2923 M swap cache
                                             4093 M total swap
                                                0 M used swap
                                             4093 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.9G    /var/
                                    889M    /var/cache
                                    870M    /var/cache/apt
                                    800M    /var/log
                                    USB-Devices by-id:
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.9.4
                                    /usr/bin/npx            10.9.4
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.7.19
                                    javascript:     8.9.2
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        24941
                                    States:         20249
                                    Pending Updates: 0
                                    crunchipC Offline
                                    crunchipC Offline
                                    #89
                                    @george_best und generell würde ich da mal etwas aufräumen, manch Adapter Instanzen doppelt und dreifach, die gar keinen Sinn ergeben oder den terminal adapter der im Normalfall gar nicht nötig ist.
                                      George_Best
                                      #90
                                      @crunchip
                                      Ja, ich befürchte ich werde mal iobroker inkl. der VM komplett neu installieren... müssen...
                                      An alle die mir in diesem Beitrag geholfen haben: Vielen, vielen Dank für eure professionelle Unterstützung 😁🙏
                                      • Thomas BraunT Online
                                        #91
                                        Und in der Vergangenheit auch mal derbe Probleme verursacht hatte. Weswegen ich den damals auch immer zum 'Hausverbot' vorgesehen hatte.
                                        iobroker.systeminfo
                                        iobroker.rickshaw
                                        iobroker.radar
                                        iobroker.info
                                        wären dafür auch gute Kandidaten.
                                        • G Offline
                                          George_Best
                                          #92
                                          Ich hab etwas Panik von der Neuinstallation, ob dann alle Adapter-Konfiguration, Objekte, Aliase, Skripte, Sql und und halbwegs restored werden können
