  4. iob fix und iob diag ohne Reaktion
    6.4k
94 Beiträge 8 Kommentatoren 12.8k Aufrufe 4 Beobachtet
    @george_best
    cd /opt/iobroker
    npm install iobroker.js-controller@7.0.7 --omit=dev
    Und bring das auf nodejs@22:
    iob nodejs-update
    George_Best
    @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
    iob diag und iob fix funktioniert nun seltsamerweise wieder...
    Aber npm install iobroker.js-controller@7.0.7 --omit=dev sagt:
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm error code 1
    npm error path /opt/iobroker/node_modules/iobroker.js-controller
    npm error command failed
    npm error command sh -c node iobroker.js setup first
    npm error node:internal/process/promises:394
    npm error     triggerUncaughtException(err, true /* fromPromise */);
    npm error     ^
    npm error
    npm error Error: Cannot find package '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/index.js' imported from /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup.js
    npm error Did you mean to import "fs-extra/lib/index.js"?
    npm error     at legacyMainResolve (node:internal/modules/esm/resolve:204:26)
    npm error     at packageResolve (node:internal/modules/esm/resolve:777:12)
    npm error     at moduleResolve (node:internal/modules/esm/resolve:853:18)
    npm error     at defaultResolve (node:internal/modules/esm/resolve:983:11)
    npm error     at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
    npm error     at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
    npm error     at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
    npm error     at ModuleJob._link (node:internal/modules/esm/module_job:182:49) {
    npm error   code: 'ERR_MODULE_NOT_FOUND'
    npm error }
    npm error
    npm error Node.js v22.21.0
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-11T09_21_00_448Z-debug-0.log
    • G George_Best
      npm error code 1
      npm error     ^
      npm error
      npm error }
      npm error
      @george_best sagte in iob fix und iob diag ohne Reaktion:
      Ja, nun ist ja auch wieder etwas Platz auf der Kiste.
      Die Skripte werden ja jeweils frisch vom Server geladen und müssen dann erstmal irgendwo abgelegt werden.
      Wie viel 'Tanzfläche' haste denn da nun wieder?
      G 1 Antwort Letzte Antwort
        George_Best
        Größe Benutzt Verf. Verw% Eingehängt auf
        udev            5,7G       0  5,7G    0% /dev
        tmpfs           1,2G    528K  1,2G    1% /run
        /dev/sda1        28G     25G  1,3G   96% /
        tmpfs           5,7G       0  5,7G    0% /dev/shm
        tmpfs           5,0M       0  5,0M    0% /run/lock
        tmpfs           1,2G       0  1,2G    0% /run/user/1000
        Immerhin 1,3G 🤕 , aber vermutlich noch nicht genug?
        • G George_Best
          @george_best
          Man sagt, das Partitionen am besten nicht über 90% vollgeschrieben werden.
          • G George_Best
            Also ein großer Brocken scheint in /home/iobroker zu liegen:
            /home/iobroker$ sudo du -h --max-depth=1
            350M    ./.cache
            16K     ./.config
            16G     ./.npm
            6,0M    ./.node-gyp
            8,0K    ./.ssh
            17G     .
            und dort:
            /home/iobroker/.npm$ sudo du -h --max-depth=1
            6,4M    ./_logs
            39M     ./_libvips
            4,0K    ./_locks
            16G     ./_cacache
            48K     ./index-v5
            932K    ./_npx
            4,8M    ./_prebuilds
            16G     .
            und dort liegen dann sehr viele Verzeichnisse:
            /home/iobroker/.npm/_cacache/content-v2/sha512$ sudo du -h --max-depth=1
            60M     ./d3
            113M    ./dd
            77M     ./f9
            70M     ./75
            66M     ./14
            35M     ./38
            72M     ./72
            58M     ./cc
            83M     ./df
            86M     ./4d
            75M     ./29
            72M     ./0a
            51M     ./56
            60M     ./b3
            67M     ./c1
            31M     ./fc
            29M     ./bc
            70M     ./ce
            64M     ./22
            156M    ./2b
            _cacache
            npm cache clean sagt dann:
            npm cache clean
            npm error code ENOSPC
            npm error syscall write
            npm error errno -28
            npm error nospc ENOSPC: no space left on device, write
            npm error nospc There appears to be insufficient space on your system to finish.
            npm error nospc Clear up some disk space and try again.
            und zwar ausser in .npm noch mal im root von /home/iobroker
              Marc BergM Online
              Marc BergM Online
              Marc Berg
              @homoran sagte in iob fix und iob diag ohne Reaktion:
              Nein, die angezeigte Größe (hier 17G) ist die Gesamtsumme aller Dateien und Unterverzeichnisse in diesem Verzeichnis, also die Summe der darüber aufgeführten Einträge.
              350M    ./.cache
              16K     ./.config
              16G     ./.npm
              6,0M    ./.node-gyp
              8,0K    ./.ssh
              17G     .
              • G Offline
                George_Best
                schrieb am zuletzt editiert von George_Best
                Kann man
                npm cache clean --force
                ohne Gefahr ausführen?
                ==> Habe ich nun gemacht -> Jetzt ist wieder mehr Platz. Jetzt versuche ich die anderen Schritte
                • G Offline
                  George_Best
                  Ich habe nun folgendes versucht
                  sudo -H -u iobroker npm install iobroker.js-controller
                  Leider ohne Erfolg:
                  npm error code 6
                  npm error path /opt/iobroker/node_modules/iobroker.vis
                  npm error command sh -c node main.js --install
                  Hat noch jemand eine Idee?
                  • G George_Best
                    Leider ohne Erfolg:
                    npm error code 6
                    immer alles Zeigen!
                    alle Zeilen und Antworten von einem Prompt bis zum nächsten
                      immer alles Zeigen!
                      George_Best
                      sorry, sorry, sorry für das Durcheinander...
                      Ich habe zwischenzeitlich "iob diag" durchlaufen lassen und nun war die Ausgabe von "npm install..." weg. Als ich es erneut durchlaufen ließ, lief es auch ohne Problem durch...
                      Ich update / upgrade jetzt mal iobroker...
                      • G George_Best
                        wahrscheinlich jetzt in dem korrekten Pfad
                          George_Best
                          Iobroker upgrade lief auch ohne Probleme durch und iobroker startete auch nach einem Reboot.
                          iob status zeigte keine Auffälligkeiten.
                          Aber (!) iobroker war auch erreichbar, "stürzte" dann aber nach einigen Minuten ab. D.h. war nicht erreichbar und iob status sagt:
                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              at Function._load (node:internal/modules/cjs/loader:1192:37)
                              at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                              at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                              at node:internal/main/run_main_module:36:49 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          iob diag sagt:
                          ```bash
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                           Static hostname: ioBroker-V2
                                 Icon name: computer-vm
                                   Chassis: vm 🖴
                            Virtualization: kvm
                                    Kernel: Linux 6.1.0-40-amd64
                              Architecture: x86-64
                           Hardware Vendor: QEMU
                            Hardware Model: Standard PC _i440FX + PIIX, 1996_
                          Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
                          OS is similar to:
                          model name      : Common KVM processor
                          Docker          : false
                          Virtualization  : kvm
                          Kernel          : x86_64
                          Userland        : 64 bit
                          Systemuptime and Load:
                           13:06:01 up 7 min,  2 users,  load average: 0.13, 0.50, 0.33
                          CPU threads: 8
                          *** LIFE CYCLE STATUS ***
                          Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                          *** TIME AND TIMEZONES ***
                                         Local time: Tue 2025-11-11 13:06:01 CET
                                     Universal time: Tue 2025-11-11 12:06:01 UTC
                                           RTC time: Tue 2025-11-11 12:06:01
                                        NTP service: active
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          jonny
                          HOME=/home/jonny
                          GROUPS=jonny cdrom floppy sudo audio dip video plugdev netdev iobroker
                          js-controller is not running
                          *** DISPLAY-SERVER SETUP ***
                          Display-Server:         false
                          Unit display-manager.service could not be found.
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Mem:             12G        440M         10G        552K        1.4G         11G
                          Swap:           4.3G          0B        4.3G
                          Total:           16G        440M         14G
                          Active iob-Instances:   0
                                  11644 M total memory
                                    420 M used memory
                                    983 M active memory
                                    299 M inactive memory
                                  10172 M free memory
                                    152 M buffer memory
                                   1173 M swap cache
                                   4093 M total swap
                                      0 M used swap
                                   4093 M free swap
                          top - 13:06:01 up 7 min,  2 users,  load average: 0.12, 0.49, 0.32
                          Tasks: 127 total,   1 running, 126 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 25.0 us, 25.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  11644.7 total,  10171.6 free,    421.3 used,   1325.8 buff/cache
                          MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11223.4 avail Mem
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** DMESG CRITICAL ERRORS ***
                          No critical errors detected
                          *** FILESYSTEM ***
                          udev           devtmpfs  5.7G     0  5.7G   0% /dev
                          tmpfs          tmpfs     1.2G  540K  1.2G   1% /run
                          /dev/sda1      ext4       28G  9.2G   17G  36% /
                          tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
                          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                          tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
                          [Tue Nov 11 12:58:48 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                          [Tue Nov 11 12:58:48 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                          Show mounted filesystems:
                          TARGET SOURCE    FSTYPE OPTIONS
                          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                          /var:
                          1.9G    /var/
                          904M    /var/log
                          856M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
                          792M    /var/cache
                          Archived and active journals take up 18.8M in the file system.
                          /opt/iobroker/backups:
                          4.0K    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          673M    /opt/iobroker/iobroker-data/
                          443M    /opt/iobroker/iobroker-data/files
                          166M    /opt/iobroker/iobroker-data/backup-objects
                          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                          73M     /opt/iobroker/iobroker-data/files/vis
                          29M     /opt/iobroker/iobroker-data/objects.jsonl
                          12M     /opt/iobroker/iobroker-data/objects.json.migrated
                          12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                          9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                          4.7M    /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v22.21.0
                          /usr/bin/node           v22.21.0
                          /usr/bin/npm            10.9.4
                          /usr/bin/npx            10.9.4
                          /usr/bin/corepack       0.34.0
                          nodejs:
                            Installed: 22.21.0-1nodesource1
                            Candidate: 22.21.0-1nodesource1
                            Version table:
                           *** 22.21.0-1nodesource1 1001
                               22.20.0-1nodesource1 1001
                               22.19.0-1nodesource1 1001
                               22.18.0-1nodesource1 1001
                               22.17.1-1nodesource1 1001
                               22.17.0-1nodesource1 1001
                               22.16.0-1nodesource1 1001
                               22.15.1-1nodesource1 1001
                               22.15.0-1nodesource1 1001
                               22.14.0-1nodesource1 1001
                               22.13.1-1nodesource1 1001
                               22.13.0-1nodesource1 1001
                               22.12.0-1nodesource1 1001
                               22.11.0-1nodesource1 1001
                               22.10.0-1nodesource1 1001
                               22.9.0-1nodesource1 1001
                               22.8.0-1nodesource1 1001
                               22.7.0-1nodesource1 1001
                               22.6.0-1nodesource1 1001
                               22.5.1-1nodesource1 1001
                               22.5.0-1nodesource1 1001
                               22.4.1-1nodesource1 1001
                               22.4.0-1nodesource1 1001
                               22.3.0-1nodesource1 1001
                               22.2.0-1nodesource1 1001
                               22.1.0-1nodesource1 1001
                               22.0.0-1nodesource1 1001
                               18.20.4+dfsg-1~deb12u1 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                  500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                          Temp directories causing deletion problem: 1204
                          Some problems detected, please run iob fix
                          Errors in npm tree: 0
                          No problems detected
                          *** ioBroker-Installation ***
                          ioBroker Status
                          node:internal/modules/cjs/loader:1386
                            throw err;
                            requireStack: []
                          Node.js v22.21.0
                          Hosts:
                            throw err;
                            requireStack: []
                          Node.js v22.21.0
                          Core adapters versions
                            throw err;
                            requireStack: []
                          Node.js v22.21.0
                          js-controller:
                            throw err;
                            requireStack: []
                          Node.js v22.21.0
                          admin:
                            throw err;
                            requireStack: []
                          Node.js v22.21.0
                          javascript:
                          nodejs modules from github:     0
                          Adapter State
                          ioBroker-Repositories
                            throw err;
                            requireStack: []
                          Node.js v22.21.0
                          Installed ioBroker-Adapters
                            throw err;
                            requireStack: []
                          Node.js v22.21.0
                          Objects and States
                          Objects:        0
                          States:         0
                          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14916      504/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          680        738/exim4
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          681        738/exim4
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          14927      504/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        16026      371/avahi-daemon: r
                          udp        0      0 0.0.0.0:47695           0.0.0.0:*                           107        16028      371/avahi-daemon: r
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15931      359/dhclient
                          udp6       0      0 :::46284                :::*                                107        16029      371/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                107        16027      371/avahi-daemon: r
                          2025-11-11 13:02:19.356  - info: parser.0 (1617) terminating with timeout
                          2025-11-11 13:02:19.680  - warn: sql.0 (1043) No Connection to database
                          2025-11-11 13:02:19.681  - warn: sql.0 (1043) No Connection to database
                          2025-11-11 13:02:19.681  - error: sql.0 (1043) No database connection
                          2025-11-11 13:02:19.922  - info: vis.0 (1647) Terminated (NO_ERROR): Without reason
                          2025-11-11 13:02:20.679  - warn: sql.0 (1043) No Connection to database
                          2025-11-11 13:02:20.680  - warn: sql.0 (1043) No Connection to database
                          2025-11-11 13:02:23.745  - warn: vis.0 (1647) get state error: DB closed
                          2025-11-11 13:02:23.751  - error: parser.0 (1617) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                          2025-11-11 13:02:23.829  - error: sql.0 (1043) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                          2025-11-11 13:02:23.831  - error: sql.0 (1043) States database error: connect ECONNREFUSED 0.0.0.0:9000
                          2025-11-11 13:02:28.831  - error: sql.0 (1043) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                          2025-11-11 13:02:28.835  - error: sql.0 (1043) States database error: connect ECONNREFUSED 0.0.0.0:9000
                          2025-11-11 13:02:29.397  - info: sql.0 (1043) terminating with timeout
                          2025-11-11 13:02:29.398  - info: sql.0 (1043) Terminated (NO_ERROR): Without reason
                          2025-11-11 13:02:33.832  - error: sql.0 (1043) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                          2025-11-11 13:02:33.838  - warn: sql.0 (1043) get state error: DB closed
                          iob diag has finished.
                          • G George_Best
                              requireStack: []
                            iob diag sagt:
                            ```bash
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 8
                                          NTP service: active
                                      RTC in local TZ: no
                            jonny
                            HOME=/home/jonny
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           4.3G          0B        4.3G
                            Total:           16G        440M         14G
                                      420 M used memory
                                      983 M active memory
                                    10172 M free memory
                                      152 M buffer memory
                                     1173 M swap cache
                                     4093 M total swap
                                        0 M used swap
                                     4093 M free swap
                            *** FILESYSTEM ***
                            /var:
                            1.9G    /var/
                            904M    /var/log
                            792M    /var/cache
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.4
                            /usr/bin/npx            10.9.4
                            nodejs:
                              Version table:
                            ioBroker Status
                              throw err;
                              requireStack: []
                            Node.js v22.21.0
                            Hosts:
                              throw err;
                              requireStack: []
                            Node.js v22.21.0
                              throw err;
                              requireStack: []
                            Node.js v22.21.0
                            js-controller:
                              throw err;
                              requireStack: []
                            Node.js v22.21.0
                            admin:
                              throw err;
                              requireStack: []
                            Node.js v22.21.0
                            javascript:
                            Adapter State
                              throw err;
                              requireStack: []
                            Node.js v22.21.0
                              throw err;
                              requireStack: []
                            Node.js v22.21.0
                            Objects and States
                            Objects:        0
                            States:         0
                            Pending Updates: 0
                            You are currently not seeing messages from other users and the system.
                            das braucht man aber um zu sehen warum
                              George_Best
                              ok... Aber was kann ich da tun?
                              • G George_Best
                                setz deinen
                                jonny
                                in groups 'adm', 'systemd-journal'
                                  setz deinen
                                  jonny
                                  George_Best
                                  Ok - hab ich gemacht. Ergebnis:
                                  groups jonny
                                  jonny : jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
                                  iob diag sagt nun:
                                  ```bash
                                  Script v.2025-08-09
                                  *** BASE SYSTEM ***
                                           Chassis: vm 🖴
                                    Virtualization: kvm
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                   14:28:47 up 0 min,  2 users,  load average: 0.00, 0.00, 0.00
                                  CPU threads: 8
                                                 Local time: Tue 2025-11-11 14:28:48 CET
                                             Universal time: Tue 2025-11-11 13:28:48 UTC
                                                   RTC time: Tue 2025-11-11 13:28:48
                                                NTP service: active
                                            RTC in local TZ: no
                                  jonny
                                  HOME=/home/jonny
                                  GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
                                  Display-Manager:
                                  Desktop:
                                  Session:                tty
                                  *** MEMORY ***
                                  Mem:             12G        396M         11G        548K        233M         11G
                                  Swap:           4.3G          0B        4.3G
                                  Total:           16G        396M         16G
                                            378 M used memory
                                            104 M active memory
                                            132 M inactive memory
                                          11286 M free memory
                                             36 M buffer memory
                                            186 M swap cache
                                           4093 M total swap
                                              0 M used swap
                                           4093 M free swap
                                  top - 14:28:48 up 0 min,  2 users,  load average: 0.00, 0.00, 0.00
                                  Tasks: 113 total,   1 running, 112 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :  11644.7 total,  11285.7 free,    379.1 used,    223.6 buff/cache
                                  MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11265.6 avail Mem
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs     1.2G  536K  1.2G   1% /run
                                  [Tue Nov 11 14:28:04 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Tue Nov 11 14:28:04 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                  /var:
                                  1.9G    /var/
                                  923M    /var/log
                                  872M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
                                  792M    /var/cache
                                  Archived and active journals take up 871.4M in the file system.
                                  USB-Devices by-id:
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  /usr/bin/npm            10.9.4
                                  /usr/bin/npx            10.9.4
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                    throw err;
                                    requireStack: []
                                  Node.js v22.21.0
                                  Hosts:
                                    throw err;
                                    requireStack: []
                                  Node.js v22.21.0
                                    throw err;
                                    requireStack: []
                                  Node.js v22.21.0
                                  js-controller:
                                    throw err;
                                    requireStack: []
                                  Node.js v22.21.0
                                  admin:
                                    throw err;
                                    requireStack: []
                                  Node.js v22.21.0
                                  javascript:
                                  Adapter State
                                    throw err;
                                    requireStack: []
                                  Node.js v22.21.0
                                    throw err;
                                    requireStack: []
                                  Node.js v22.21.0
                                  Objects and States
                                  Objects:        0
                                  States:         0
                                  Pending Updates: 0
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15158      718/exim4
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14107      453/sshd: /usr/sbin
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14118      453/sshd: /usr/sbin
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15159      718/exim4
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        14087      425/avahi-daemon: r
                                  udp        0      0 0.0.0.0:55628           0.0.0.0:*                           107        14089      425/avahi-daemon: r
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15001      355/dhclient
                                  udp6       0      0 :::5353                 :::*                                107        14088      425/avahi-daemon: r
                                  udp6       0      0 :::59888                :::*                                107        14090      425/avahi-daemon: r
                                  • G George_Best
                                    groups jonny
                                    iob diag sagt nun:
                                    ```bash
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    CPU threads: 8
                                                  NTP service: active
                                              RTC in local TZ: no
                                    jonny
                                    HOME=/home/jonny
                                    Display-Manager:
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                    Swap:           4.3G          0B        4.3G
                                    Total:           16G        396M         16G
                                              378 M used memory
                                              104 M active memory
                                            11286 M free memory
                                               36 M buffer memory
                                              186 M swap cache
                                             4093 M total swap
                                                0 M used swap
                                             4093 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.9G    /var/
                                    923M    /var/log
                                    792M    /var/cache
                                    USB-Devices by-id:
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.9.4
                                    /usr/bin/npx            10.9.4
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                      throw err;
                                      requireStack: []
                                    Node.js v22.21.0
                                    Hosts:
                                      throw err;
                                      requireStack: []
                                    Node.js v22.21.0
                                      throw err;
                                      requireStack: []
                                    Node.js v22.21.0
                                    js-controller:
                                      throw err;
                                      requireStack: []
                                    Node.js v22.21.0
                                    admin:
                                      throw err;
                                      requireStack: []
                                    Node.js v22.21.0
                                    javascript:
                                    Adapter State
                                      throw err;
                                      requireStack: []
                                    Node.js v22.21.0
                                      throw err;
                                      requireStack: []
                                    Node.js v22.21.0
                                    Objects and States
                                    Objects:        0
                                    States:         0
                                    Pending Updates: 0
                                    Jag da mal den
                                    iob fix
                                    drüber.
                                    • G George_Best
                                      groups jonny
                                      iob diag sagt nun:
                                      ```bash
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                               Chassis: vm 🖴
                                        Virtualization: kvm
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      CPU threads: 8
                                                    NTP service: active
                                                RTC in local TZ: no
                                      jonny
                                      HOME=/home/jonny
                                      Display-Manager:
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                      Swap:           4.3G          0B        4.3G
                                      Total:           16G        396M         16G
                                                378 M used memory
                                                104 M active memory
                                              11286 M free memory
                                                 36 M buffer memory
                                                186 M swap cache
                                               4093 M total swap
                                                  0 M used swap
                                               4093 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      1.9G    /var/
                                      923M    /var/log
                                      792M    /var/cache
                                      USB-Devices by-id:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.9.4
                                      /usr/bin/npx            10.9.4
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                        throw err;
                                        requireStack: []
                                      Node.js v22.21.0
                                      Hosts:
                                        throw err;
                                        requireStack: []
                                      Node.js v22.21.0
                                        throw err;
                                        requireStack: []
                                      Node.js v22.21.0
                                      js-controller:
                                        throw err;
                                        requireStack: []
                                      Node.js v22.21.0
                                      admin:
                                        throw err;
                                        requireStack: []
                                      Node.js v22.21.0
                                      javascript:
                                      Adapter State
                                        throw err;
                                        requireStack: []
                                      Node.js v22.21.0
                                        throw err;
                                        requireStack: []
                                      Node.js v22.21.0
                                      Objects and States
                                      Objects:        0
                                      States:         0
                                      Pending Updates: 0
                                      iob diag sagt nun:
                                      und jetzt bin ich überfordert warum er keine Adapter und Instanzen anzeigt.
                                      Vielleicht hat @Thomas-Braun noch eine Idee
                                      • G Offline
                                        George_Best
                                        iob fix:
                                        library: loaded
                                        Library version=2025-08-09
                                            Welcome to the ioBroker installation fixer!
                                            Script version: 2025-08-09
                                            You might need to enter your password a couple of times.
                                            Installing prerequisites (1/5)
                                        OK:1 http://deb.debian.org/debian bookworm InRelease
                                        OK:2 http://deb.debian.org/debian bookworm-updates InRelease
                                        OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                        OK:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                            Checking ioBroker user and directory permissions (2/5)
                                            Check and cleanup npm temporary directories (3/5)
                                        Done.
                                            Database maintenance (4/5)
                                        Checking for uncompressed JSONL databases... This might take a while!
                                        Compressing /opt/iobroker/iobroker-data/states.jsonl
                                        Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                        Compressed 2 JSONL files. Done
                                            Checking autostart (5/5)
                                        ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                                        Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
                                        Authenticating as: jonny,,, (jonny)
                                        Password:
                                        ==== AUTHENTICATION COMPLETE ====
                                        Enabling autostart...
                                        Autostart enabled!
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                        iob diag:
                                        ```bash
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                                 Chassis: vm 🖴
                                          Virtualization: kvm
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         15:20:29 up 52 min,  2 users,  load average: 0.09, 0.07, 0.02
                                        CPU threads: 8
                                                       Local time: Tue 2025-11-11 15:20:29 CET
                                                   Universal time: Tue 2025-11-11 14:20:29 UTC
                                                         RTC time: Tue 2025-11-11 14:20:29
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        jonny
                                        HOME=/home/jonny
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:             12G        461M         11G        544K        704M         11G
                                        Swap:           4.3G          0B        4.3G
                                        Total:           16G        461M         15G
                                                  440 M used memory
                                                  361 M active memory
                                                  262 M inactive memory
                                                10812 M free memory
                                                  163 M buffer memory
                                                  508 M swap cache
                                                 4093 M total swap
                                                    0 M used swap
                                                 4093 M free swap
                                        top - 15:20:29 up 52 min,  2 users,  load average: 0.16, 0.08, 0.02
                                        Tasks: 112 total,   1 running, 111 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :  11644.7 total,  10811.1 free,    442.2 used,    671.9 buff/cache
                                        MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11202.4 avail Mem
                                        *** FILESYSTEM ***
                                        /dev/sda1      ext4       28G  7.9G   19G  31% /
                                        /var:
                                        1.9G    /var/
                                        941M    /var/log
                                        888M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
                                        792M    /var/cache
                                        Archived and active journals take up 887.4M in the file system.
                                        668M    /opt/iobroker/iobroker-data/
                                        25M     /opt/iobroker/iobroker-data/objects.jsonl
                                        4.6M    /opt/iobroker/iobroker-data/states.jsonl
                                        USB-Devices by-id:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/npm            10.9.4
                                        /usr/bin/npx            10.9.4
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                          throw err;
                                          requireStack: []
                                        Node.js v22.21.0
                                        Hosts:
                                          throw err;
                                          requireStack: []
                                        Node.js v22.21.0
                                          throw err;
                                          requireStack: []
                                        Node.js v22.21.0
                                        js-controller:
                                          throw err;
                                          requireStack: []
                                        Node.js v22.21.0
                                        admin:
                                          throw err;
                                          requireStack: []
                                        Node.js v22.21.0
                                        javascript:
                                        Adapter State
                                          throw err;
                                          requireStack: []
                                        Node.js v22.21.0
                                          throw err;
                                          requireStack: []
                                        Node.js v22.21.0
                                        Objects and States
                                        Objects:        0
                                        States:         0
                                        Pending Updates: 0
                                        • G George_Best
                                          iob fix:
                                          library: loaded
                                          Done.
                                          Password:
                                          Autostart enabled!
                                          iob diag:
                                          ```bash
                                          Script v.2025-08-09
                                          *** BASE SYSTEM ***
                                                   Chassis: vm 🖴
                                            Virtualization: kvm
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          CPU threads: 8
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          jonny
                                          HOME=/home/jonny
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Swap:           4.3G          0B        4.3G
                                          Total:           16G        461M         15G
                                                    440 M used memory
                                                    361 M active memory
                                                  10812 M free memory
                                                    163 M buffer memory
                                                    508 M swap cache
                                                   4093 M total swap
                                                      0 M used swap
                                                   4093 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          1.9G    /var/
                                          941M    /var/log
                                          792M    /var/cache
                                          USB-Devices by-id:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            10.9.4
                                          /usr/bin/npx            10.9.4
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                            throw err;
                                            requireStack: []
                                          Node.js v22.21.0
                                          Hosts:
                                            throw err;
                                            requireStack: []
                                          Node.js v22.21.0
                                            throw err;
                                            requireStack: []
                                          Node.js v22.21.0
                                          js-controller:
                                            throw err;
                                            requireStack: []
                                          Node.js v22.21.0
                                          admin:
                                            throw err;
                                            requireStack: []
                                          Node.js v22.21.0
                                          javascript:
                                          Adapter State
                                            throw err;
                                            requireStack: []
                                          Node.js v22.21.0
                                            throw err;
                                            requireStack: []
                                          Node.js v22.21.0
                                          Objects and States
                                          Objects:        0
                                          States:         0
                                          Pending Updates: 0
                                          @george_best
                                          Dann bügel den aktuellen js-controller noch mal rein:
                                          cd /opt/iobroker
