  4. Admin lädt nicht mehr/ web Adapter issues
11 Beiträge 5 Kommentatoren 991 Aufrufe 5 Beobachtet
  • L Offline
    lessthanmore
    seit dem Update vom Admin auf 7.7.19 lädt mein Admin nicht mehr.
    Ich sehe im Grunde genommen nur das Logo/ Ladebildschirm ohne Fortschritt.
    Hier die diag - Ausgabe:
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.11-4-pve
        Architecture: x86-64
    OS is similar to:
    model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     13:25:38 up 9 min,  1 user,  load average: 0.46, 0.37, 0.22
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-11-04 13:25:38 CET
               Universal time: Tue 2025-11-04 12:25:38 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    michael
    HOME=/home/michael
    GROUPS=michael sudo users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/michael
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: 	false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session: 		tty
    *** MEMORY ***
    Mem:            8.6G        1.2G        6.7G        4.2M        604M        7.3G
    Swap:           536M          0B        536M
    Total:          9.1G        1.2G        7.3G
    Active iob-Instances: 	13
             8192 M total memory
             1187 M used memory
             1300 M active memory
              323 M inactive memory
             6431 M free memory
                0 M buffer memory
              576 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 13:25:39 up 9 min,  1 user,  load average: 0.46, 0.37, 0.22
    Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   6430.8 free,   1188.2 used,    576.8 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7003.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       25G  5.0G   19G  22% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       67G   38G   26G  61% /dev/ttyACM0
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  152K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs      32G  3.9M   32G   1% /tmp
    tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
    Show mounted filesystems:
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--100--disk--1                       ext4   rw,relatime,stripe=16
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    337M	/var/
    218M	/var/lib
    92M	/var/cache
    91M	/var/cache/apt
    90M	/var/lib/apt
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    1.8M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    62M	/opt/iobroker/iobroker-data/
    56M	/opt/iobroker/iobroker-data/files
    38M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    6.8M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
    5.3M	/opt/iobroker/iobroker-data/objects.jsonl
    3.9M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
    3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
    3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v22.21.1
    /usr/bin/node 		v22.21.1
    /usr/bin/npm 		10.9.4
    /usr/bin/npx 		10.9.4
    /usr/bin/corepack 	0.34.0
    nodejs:
      Installed: 22.21.1-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.1-1nodesource1 100
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 106)
    Core adapters versions
    js-controller: 	7.0.7
    admin: 		7.7.19
    javascript: 	8.9.2
    nodejs modules from github: 	2
    +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#e43328543d35c4555a4a3f3e595dd16417978d85)
    +-- iobroker.lovelace@5.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.lovelace.git#0d3a5f35eecfe52bd4d382a5d9f8a7fb7ccb42ee)
    Adapter State
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
    + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
    + system.adapter.pirate-weather.0         : pirate-weather        : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.17.0   , installed 1.17.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lovelace"     : 5.0.1    , installed 5.0.1
    Adapter    "openknx"      : 0.9.0    , installed 0.9.0
    Adapter    "pirate-weather": 0.7.0   , installed 0.7.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects: 	26515
    States: 	8525
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15147164   308/master
    tcp        0      0 127.0.0.1:36101         0.0.0.0:*               LISTEN      1000       15166411   2241/io.yahka.0
    tcp        0      0 127.0.0.1:39099         0.0.0.0:*               LISTEN      1000       15166407   2241/io.yahka.0
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        15146593   146/redis-server 12
    tcp        0      0 127.0.0.1:42891         0.0.0.0:*               LISTEN      1000       15166415   2241/io.yahka.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        15146834   299/mosquitto
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15139839   1/init
    tcp6       0      0 ::1:6379                :::*                    LISTEN      105        15146594   146/redis-server 12
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15147165   308/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       15173225   2331/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15166047   2109/io.admin.0
    tcp6       0      0 :::8080                 :::*                    LISTEN      1001       15147402   149/node
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       15173158   2301/io.lovelace.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      107        15146835   299/mosquitto
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15141524   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          15145985   1/init
    tcp6       0      0 :::45375                :::*                    LISTEN      1000       15166363   2241/io.yahka.0
    tcp6       0      0 :::45177                :::*                    LISTEN      1000       15166359   2241/io.yahka.0
    tcp6       0      0 :::44367                :::*                    LISTEN      1000       15166361   2241/io.yahka.0
    udp        0      0 0.0.0.0:46460           0.0.0.0:*                           1000       15166334   2226/io.openknx.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15139840   1/init
    udp        0      0 0.0.0.0:36157           0.0.0.0:*                           106        15146446   131/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        15146444   131/avahi-daemon: r
    udp6       0      0 :::51173                :::*                                106        15146447   131/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          15145986   1/init
    udp6       0      0 :::5353                 :::*                                106        15146445   131/avahi-daemon: r
    2025-11-04 13:16:04.578  - warn: web.0 (540) setTimeout called, but adapter is shutting down
    2025-11-04 13:16:05.652  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
    2025-11-04 13:16:14.771  - warn: host.iobroker No configuration found for scope "databaseErrors" and category "system"
    2025-11-04 13:16:43.177  - warn: host.iobroker instance system.adapter.zigbee2mqtt.0 terminated due to SIGTERM
    2025-11-04 13:17:11.266  - warn: host.iobroker No configuration found for scope "databaseErrors" and category "system"
    2025-11-04 13:23:43.902  - warn: web.0 (1540) setTimeout called, but adapter is shutting down
    2025-11-04 13:23:49.020  - warn: host.iobroker No configuration found for scope "databaseErrors" and category "system"
    2025-11-04 13:23:58.299  - error: homeconnect.0 (2181) AxiosError: Request failed with status code 429
    2025-11-04 13:23:58.300  - error: homeconnect.0 (2181) {"error":{"description":"The rate limit \"10 successive error calls in 10 minutes\" was reached. Requests are blocked during the remaining period of 202 seconds.","key":"429"}}
    2025-11-04 13:23:58.382  - error: homeconnect.0 (2181) 429 Too Many Requests
    2025-11-04 13:23:58.382  - error: homeconnect.0 (2181) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
    2025-11-04 13:25:08.423  - error: homeconnect.0 (2181) 429 Too Many Requests
    2025-11-04 13:25:08.423  - error: homeconnect.0 (2181) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
    Folgende Warnmeldungen irritieren mich bzw. ich kann damit nichts anfangen:
    Lieben Dank vorab für die Hilfe.
    • L lessthanmore
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      michael
      HOME=/home/michael
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session: 		tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               8192 M total memory
               1187 M used memory
               6431 M free memory
                  0 M buffer memory
                576 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      337M	/var/
      218M	/var/lib
      92M	/var/cache
      91M	/var/cache/apt
      90M	/var/lib/apt
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 		10.9.4
      /usr/bin/npx 		10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin: 		7.7.19
      javascript: 	8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	26515
      States: 	8525
      Pending Updates: 0
      crunchipC Offline
      crunchipC Offline
      @lessthanmore iob fix schon probiert? Bzw das system danach mal neu starten.
      L 1 Antwort Letzte Antwort
        lessthanmore
        schrieb am zuletzt editiert von lessthanmore
        @crunchip Ja, beides. Inklusive Backup von heute Nacht eingespielt.
        Hier nochmal der aktuelle diag - Auszug. Irgendwas war bei nodejs krumm im ersten:
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
         13:38:08 up 3 min,  1 user,  load average: 0.37, 0.68, 0.45
        CPU threads: 2
                       Local time: Tue 2025-11-04 13:38:08 CET
                   Universal time: Tue 2025-11-04 12:38:08 UTC
                         RTC time: n/a
                  RTC in local TZ: no
        michael
        HOME=/home/michael
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session: 		tty
        *** MEMORY ***
        Mem:            8.6G        1.3G        6.7G        4.2M        628M        7.3G
        Swap:           536M          0B        536M
        Total:          9.1G        1.3G        7.2G
                 8192 M total memory
                 1247 M used memory
                 1357 M active memory
                  398 M inactive memory
                 6349 M free memory
                    0 M buffer memory
                  599 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        top - 13:38:08 up 3 min,  1 user,  load average: 0.37, 0.68, 0.45
        %Cpu(s):  4.8 us,  0.0 sy,  0.0 ni, 95.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   8192.0 total,   6348.3 free,   1248.2 used,    599.4 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6943.8 avail Mem
        *** FILESYSTEM ***
        /dev/mapper/pve-vm--100--disk--0 ext4       25G  5.0G   19G  22% /
        /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
        /var:
        337M	/var/
        218M	/var/lib
        92M	/var/cache
        91M	/var/cache/apt
        90M	/var/lib/apt
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm 		10.9.4
        /usr/bin/npx 		10.9.4
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: redis
        States  type: redis
        Hosts:
        iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 196)
        admin: 		7.7.19
        javascript: 	8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	26515
        States: 	8525
        Hit:1 http://security.debian.org trixie-security InRelease
        Hit:2 http://deb.debian.org/debian trixie InRelease
        Pending Updates: 0
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        15205722   146/redis-server 12
        tcp        0      0 127.0.0.1:39611         0.0.0.0:*               LISTEN      1000       15202045   474/io.yahka.0
        tcp        0      0 127.0.0.1:40673         0.0.0.0:*               LISTEN      1000       15202049   474/io.yahka.0
        tcp        0      0 127.0.0.1:33209         0.0.0.0:*               LISTEN      1000       15202041   474/io.yahka.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15205860   287/master
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        15206223   319/mosquitto
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15197967   1/init
        tcp6       0      0 :::44523                :::*                    LISTEN      1000       15201191   474/io.yahka.0
        tcp6       0      0 :::8091                 :::*                    LISTEN      1000       15209881   644/io.lovelace.0
        tcp6       0      0 :::8080                 :::*                    LISTEN      1001       15206328   150/node
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15206491   337/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       15211290   888/io.web.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15205861   287/master
        tcp6       0      0 :::38507                :::*                    LISTEN      1000       15201189   474/io.yahka.0
        tcp6       0      0 ::1:6379                :::*                    LISTEN      105        15205723   146/redis-server 12
        tcp6       0      0 :::1883                 :::*                    LISTEN      107        15206224   319/mosquitto
        tcp6       0      0 :::32987                :::*                    LISTEN      1000       15201193   474/io.yahka.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15205404   1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          15197969   1/init
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15197968   1/init
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        15203038   120/avahi-daemon: r
        udp        0      0 0.0.0.0:44688           0.0.0.0:*                           106        15203040   120/avahi-daemon: r
        udp        0      0 0.0.0.0:44913           0.0.0.0:*                           1000       15202004   459/io.openknx.0
        udp6       0      0 :::111                  :::*                                0          15197970   1/init
        udp6       0      0 :::5353                 :::*                                106        15203039   120/avahi-daemon: r
        udp6       0      0 :::46990                :::*                                106        15203041   120/avahi-daemon: r
        2025-11-04 13:34:44.536  - warn: host.iobroker No configuration found for scope "databaseErrors" and category "system"
        Kann das am neuen MacOS/ iOS liegen? Sonst wurde eigentlich kein Update gemacht.
        Auf der Windows Maschine mit Edge läuft es nämlich problemlos ...
        • L lessthanmore
          Script v.2025-08-09
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 2
                           RTC time: n/a
                    RTC in local TZ: no
          michael
          HOME=/home/michael
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session: 		tty
          *** MEMORY ***
          Swap:           536M          0B        536M
                   8192 M total memory
                   1247 M used memory
                   6349 M free memory
                      0 M buffer memory
                    599 M swap cache
                    512 M total swap
                      0 M used swap
                    512 M free swap
          *** FILESYSTEM ***
          /var:
          337M	/var/
          218M	/var/lib
          92M	/var/cache
          91M	/var/cache/apt
          90M	/var/lib/apt
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm 		10.9.4
          /usr/bin/npx 		10.9.4
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: redis
          States  type: redis
          Hosts:
          admin: 		7.7.19
          javascript: 	8.9.2
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	26515
          States: 	8525
          Pending Updates: 0
          crunchipC Offline
          crunchipC Offline
          @lessthanmore sagte in Admin lädt nicht mehr/ web Adapter issues:
          Hat eigentlich nix damit zu tun, von welchem Rechner du aufrufst
            lessthanmore
            @crunchip said in Admin lädt nicht mehr/ web Adapter issues:
            In dem Fall offensichtlich doch. Hab es gerade mit zwei identischen iPad Air getestet, eins noch mit 26.0.1 und eins mit 26.1.
            Letzteres öffnet iob nicht.
            • L lessthanmore
              Script v.2025-08-09
              *** BASE SYSTEM ***
                Virtualization: lxc
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 2
                               RTC time: n/a
                        RTC in local TZ: no
              michael
              HOME=/home/michael
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session: 		tty
              *** MEMORY ***
              Swap:           536M          0B        536M
                       8192 M total memory
                       1187 M used memory
                       6431 M free memory
                          0 M buffer memory
                        576 M swap cache
                        512 M total swap
                          0 M used swap
                        512 M free swap
              *** FILESYSTEM ***
              /var:
              337M	/var/
              218M	/var/lib
              92M	/var/cache
              91M	/var/cache/apt
              90M	/var/lib/apt
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm 		10.9.4
              /usr/bin/npx 		10.9.4
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              ioBroker Status
              Objects type: redis
              States  type: redis
              Hosts:
              admin: 		7.7.19
              javascript: 	8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	26515
              States: 	8525
              Pending Updates: 0
              crunchipC Offline
              crunchipC Offline
              Auf die schnelle
              Das Problem mit endlosen Login-Schleifen in der ioBroker iOS-App nach iOS 26.1 ist bekannt und betrifft vor allem die Authentifizierung. Die App dreht sich beim Login endlos, springt ständig zwischen dem Anmeldebildschirm und der Projekt-Auswahl hin und her. Dieses Verhalten tritt vor allem dann auf, wenn in der ioBroker-Instanz die Authentifizierung aktiviert ist.Ursachen und Lösungen laut Community-Berichten:iOS Safari und die ioBroker App haben Schwierigkeiten mit bestimmten SSL-Zertifikaten, was zu Authentifizierungsabbrüchen führt.Temporäres Deaktivieren der Authentifizierung im ioBroker Web-Adapter kann das Problem beheben und die Views laden.Neuinstallation der App und manuelle Neueingabe der Parameter hilft manchmal nicht.Login-Probleme treten teils nur auf iOS-Geräten auf, während der Zugriff über MacOS-Browser ohne Probleme läuft.VPN- oder Cloud-Zugriffe scheinen anfälliger zu sein als lokale WLAN-Verbindungen.Einige Nutzer berichten, dass die App-Version 7.0.6 funktioniert
                Auf die schnelle
                lessthanmore
                @crunchip Danke. Authentifikation ist deaktiviert.
                Lustigerweise lädt der Bildschirm direkt, sobald ich die URL in einem zweiten Fenster erneut öffne.
                Fehler taucht bei allen Geräten mit 26.1 auf (MacOS, iOS, iPadOS).
                • miwiM Offline
                  miwiM Offline
                  miwi
                  Gleiches Verhalten hier. MacOS 26.1. Bei Safari nur Startlogo. Firefox offnet die WebUi. Danach geht auch es auch wieder in Safari. Beim nächsten Start des Rechners geht der Spaß von vorne los.
                  Berechtigung zum Finden von lokalen Geräten im Netzwerk ist für Firefox aktiviert. Für Safari existiert die Option garnicht.
                  O 1 Antwort Letzte Antwort
                  • miwiM miwi
                    O Offline
                    O Offline
                    oreus
                    schrieb am zuletzt editiert von oreus
                    Auch bei mir ... Gleiches Verhalten.
                    MacOS 26.1:
                    Nur Firefox öffnet problemlos den admin.
                    Safari nur wenn man ein 2.Fenster öffnet, aber auch nicht zuverlässig.
                    Chrome funktioniert überhaupt nicht.
                    iOS 26.1:
                    Chrome geht nicht
                    Safari geht auch nicht (nur das Startbild mit dem drehenden Kreis um das I)
                    • O oreus
                      MacOS 26.1:
                      iOS 26.1:
                      Chrome geht nicht
                      O Offline
                      O Offline
                      oreus
                      @oreus
                      Für Chrome habe folgende Lösung als Workaround gefunden:
                      Script in Automator einbauen und als Link auf den Desktop legen:
                      #!/bin/bash
                      open -a "/Applications/Google Chrome.app" --args --disable-features=BlockInsecurePrivateNetworkRequests
                      Startet den Chrome und man kann dann alle lokalen Netzwerkgeräte wieder erreichen, auch ohne SSL etc ...
                      Darunter auch alle Shelly Oberflächen
                        Tobi 1
                        Mein Workaround zu diesem Problem auf dem iPhone:
                        Wlan Aus, VPN Verbindung zur Fritzbox herstellen, dann lädt die VIS2 Runtime und ioBroker wie gewohnt.
