  3. Cloud Dienste
  4. BETA-TEST Neuer Amazon Skill "iobroker.assistant"
759 Beiträge 112 Kommentatoren 132.5k Aufrufe 128 Beobachtet
  • BBTownB BBTown
    @haselchen iob Diag findet alles prima ☝🏼🤓
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
      Static hostname: ioBroker
           Icon name: computer-vm
             Chassis: vm 🖴
        AF_VSOCK CID: 1
      Virtualization: kvm
              Kernel: Linux 6.12.48+deb13-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 11y 6month 2w 4d
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:25:45 up 23 min,  1 user,  load average: 0.35, 0.33, 0.35
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-10-18 20:25:45 CEST
               Universal time: Sat 2025-10-18 18:25:45 UTC
                     RTC time: Sat 2025-10-18 18:25:45
                  NTP service: active
              RTC in local TZ: yes
    Warning: The system is configured to read the RTC time in the local time zone.
             This mode cannot be fully supported. It will create various problems
             with time zone changes and daylight saving time adjustments. The RTC
             time is never updated, it relies on external facilities to maintain it.
             If at all possible, use RTC in UTC by calling
             'timedatectl set-local-rtc 0'.
    *** Users and Groups ***
    User that called 'iob diag':
    memyself
    HOME=/home/memyself
    GROUPS=memyself sudo iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/memyself
    GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.1G        2.4G        1.4G        8.6M        543M        1.7G
    Swap:             0B          0B          0B
    Total:          4.1G        2.4G        1.4G
    Active iob-Instances:   26
             3921 M total memory
             2278 M used memory
             2083 M active memory
              283 M inactive memory
             1350 M free memory
               73 M buffer memory
              444 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 20:25:46 up 23 min,  1 user,  load average: 0.40, 0.35, 0.35
    Tasks: 148 total,   3 running, 145 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 21.7 us,  8.7 sy,  0.0 ni, 60.9 id,  0.0 wa,  0.0 hi,  8.7 si,  0.0 st
    MiB Mem :   3921.8 total,   1350.4 free,   2278.5 used,    519.0 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1643.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     393M  5.5M  387M   2% /run
    /dev/sda1      ext4       40G   15G   23G  39% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     2.0G  2.8M  2.0G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     393M   12K  393M   1% /run/user/1003
    [Sat Oct 18 20:03:17 2025] EXT4-fs (sda1): mounted filesystem e627c9a7-1a96-462a-8b7f-0ca843bca944 ro with ordered data mode. Quota mode: none.
    [Sat Oct 18 20:03:18 2025] EXT4-fs (sda1): re-mounted e627c9a7-1a96-462a-8b7f-0ca843bca944 r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    303M    /var/
    155M    /var/lib
    140M    /var/cache
    127M    /var/cache/apt
    97M     /var/lib/apt
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    41M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    409M    /opt/iobroker/iobroker-data/
    280M    /opt/iobroker/iobroker-data/files
    85M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    11M     /opt/iobroker/iobroker-data/objects.json
    8.2M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-DDMXSE9w.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.20.0
    /usr/bin/node           v22.20.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.20.0-1nodesource1
      Candidate: 22.20.0-1nodesource1
      Version table:
     *** 22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://ftp.debian.org/debian trixie/main amd64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree: 0
    #103
    @bbtown sagte in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
    Außer die Uhrzeit und die Gruppenzugehörigkeit zur Gruppe adm.
    Und vielleicht im fehlenden Rest auch noch was.
    Hatt aber nix mit Alexa dann zu tun.
    BBTownB 1 Antwort Letzte Antwort
    • I Offline
      I Offline
      ingel81
      #104
      Gerade bei mir erfolgreich umgestellt auf den neuen Skill.
      Umfangreiches KNX Haus mit über ~400 Geräten (vieles davon Dupletten wegen Kombinationen wie "Licht Küche", "Küche Licht", "Küche Spots", u.s.w.).
      Lichter
      Dimmbare Lichter
      Steckdosen
      Rolläden
      KNX Szenen auslösen (DummyGeräte die ein Script triggern)
      Diverse Sensorik auslesen
      Klappt alles sehr gut! Vielen, vielen Dank euch für die schnelle Aktion! 😃
      Der Aufwand war eigentlich nur das alte Zeug in der App einzeln rauszuwerfen. Die Webseite auf der man alle Geräte löschen konnte gibt es leider nicht mehr.
      KNX | ioBroker auf Unraid
      Z 1 Antwort Letzte Antwort
      • WinniW Offline
        WinniW Offline
        Winni
        #105
        Bei mir läuft leider nicht. Habe gerade die 4.1.5 installiert. Es kommen aber unter Alexa-Geräte V3 weiterhin keine Geräte und Fehlermeldungen im Log sind auch noch da.
        iot.0
        2025-10-18 20:41:41.712	error	[AlexaV3::DeviceManager]: TypeError: Cannot read properties of undefined (reading 'type') at /opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:341:47 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:334:42 at Array.forEach (<anonymous>) at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:333:21) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1545:13)
        iot.0
        2025-10-18 20:41:41.634	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot read properties of undefined (reading 'type')
          BBTownB Offline
          BBTownB Offline
          BBTown
          schrieb am zuletzt editiert von BBTown
          #106
          @thomas-braun welchen fehlenden Rest meinst Du?
          das ist die vollständige Ausgabe von "iob diag"
          Welche Auswirkungen hat die ADM Zugehörigkeit bzw. wie korrigiere ich diese? Hier wurde von mir nichts beabsichtigt umgestellt.
          Die Zeitzone ist hingegen gewollt ...
          (Wenn ich dafür ein neues Thema aufmachen soll, bitte gerne Laut geben)
          • BBTownB BBTown
            #107
            Nein.
            Besser ist das.
            Warum? Die Begründung, warum man die RTC nicht in lokaler Zeit betreiben sollte steht ja dabei.
              Nein.
              Besser ist das.
              BBTownB Offline
              BBTownB Offline
              BBTown
              #108
              hier geht es zu desem Thema weiter ...
              https://forum.iobroker.net/topic/82541/fehler-deprication-warning
              • WinniW Offline
                WinniW Offline
                Winni
                #109
                Habe jetzt erneut die Installation über npm durchgeführt. Jetzt wurde die 4.1.6 installiert und alle Geräte sind, soweit ich sehen kann, unter Alexa Geräte V3 vorhanden und es erscheinen auch keine Fehlermeldungen mehr im Log. Allerdings werden die Geräte nicht in der Alexa-App gefunden.
                • R Offline
                  Rushmed
                  #110
                  Der Umzug hat jetzt größtenteils geklappt. Offen ist noch das Setup von HUE Lmpen.
                  ich habe folgendes eingestellt:
                  Die Farbsteuerung und der dimmer fuktionieren garnicht. Beim Steuern per Sprachbefehlt wird immer auf Kaltweiß und maximale Helligkeit gestellt.
                  Ich weiß auch nicht welchen typ ich für Straturation abgen soll.
                  • Z Offline
                    Z Offline
                    ZeroQool
                    #111
                    @ingel81 said in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
                    Lichter
                    Dimmbare Lichter
                    Steckdosen
                    Rolläden
                    Wie machst du das mit den Rückmeldung an die Gruppenadresse?
                    I 1 Antwort Letzte Antwort
                    • WinniW Winni
                      BBTownB Offline
                      BBTownB Offline
                      BBTown
                      #112
                      @winni
                      @apollon77
                      Ich kann ebenfalls bestätigen, dass mit der v4.1.6 die Geräte bei mir nun in "Amazon Alexa V3" übernommen wurden.
                      Es können jetzt auch manuell im iot-Adapter unter "Alexa-Geräte V3" weitere Geräte hinzugefügt werden.
                      Keine Fehlermeldungen mehr im Log.
                      Die Geräte werden allerdings auch bei mir nicht in der Alexa-App gefunden
                      Nachdem ich in der Alexa App den iobroker.assistent skill noch einmal deaktiviert und erneut mit meinen Iobroker-Pro Account aktiviert habe, wurden meine Geräte eingelesen
                      WinniW 1 Antwort Letzte Antwort
                      • BBTownB BBTown
                        @winni
                        @apollon77
                        WinniW Offline
                        WinniW Offline
                        Winni
                        #113
                        Habe ich auch probiert, aber bei mir leider ohne Erfolg.
                        • WinniW Winni
                          docsnyder7
                          #114
                          @winni das Gleiche hier…
                          • Z ZeroQool
                            Lichter
                            Dimmbare Lichter
                            Steckdosen
                            Rolläden
                            I Offline
                            I Offline
                            ingel81
                            schrieb am zuletzt editiert von ingel81
                            #115
                            @zeroqool präzisiere mal die Frage oder schreib eine PM, damit ich weiß wie sehr oder wenig ich ausholen muss. Zu den Szenen oder allgemein?
                            DuffyD 1 Antwort Letzte Antwort
                            • I ingel81
                              DuffyD Offline
                              DuffyD Offline
                              Duffy
                              #116
                              Hallo an alle,
                              wer kennt folgendes Problem.
                              Ich habe den iot Adapter 4.1.6 (war auch schon bei 4.1.4 so) installiert und in dem auch Amazon Alexa Custom Skill aktiviert.
                              wenn ich mich nun über das Handy in dem Skill anmelde wird folgende Meldung angezeigt:
                              Gleich danach sagt Alexa aber über den Echo:
                              "Ich habe im Moment schwierigkeiten auf deinen Custom iobroker Skill zuzugreifen"
                              Auf dem Handy ist nun bei dem Skill wieder der Urspungsscreen zu sehen:
                              Weis wer Rat?
                              Und hat es schon einer von euch geschafft Temperatursensoren abzufragen? Das klappt auch noch nicht, vielleicht auch wegen oben genanntem Problem.
                              Gruß Duffy
                              Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                              Node.js: v22.23.2
                              NPM: 10.9.4
                              js-controller 7.1.2
                              Linux: Trixie
                              BBTownB apollon77A 2 Antworten Letzte Antwort
                              • D docsnyder7
                                BBTownB Offline
                                BBTownB Offline
                                BBTown
                                #117
                                @docsnyder7 @Winni
                                Ich weiß nicht ob das wichtig ist, jedoch habe ich vor dem deaktivieren und neu-aktivieren des "iobroker.assistent" skill auch den "iobroker.iot" skill deaktiviert.
                                Nachtrag:
                                Ichhatte zwischendurch im Adapter auch mal den Haken beim Custom skill rausgenommen.
                                Ich bin mir aber bei den ganzen Versuchen nicht mehr sicher wie der Zustand war, als ich erfolg hatte - sorry!
                                R WinniW 2 Antworten Letzte Antwort
                                • DuffyD Duffy
                                  Hallo an alle,
                                  Weis wer Rat?
                                  Gruß Duffy
                                  BBTownB Offline
                                  BBTownB Offline
                                  BBTown
                                  #118
                                  @duffy
                                  Gruß Duffy
                                  Ja, das hat bei mir funktioniert nachdem ich im iot-Adapter den Gerätetyp von "Thermostat" auf "Temperatur" geändert habe.
                                  Ich habe anschließend in der Alexa-App die Geräte neu suchen lassen, ich habe zwar den Hinweis bekommen, dass nichts neues gefunden wurde (das Gerät war ja auch nicht neu) aber die Temperaturen wurden nach einer Weile dann korrekt angesagt
                                  • BBTownB BBTown
                                    @docsnyder7 @Winni
                                    Nachtrag:
                                    Rushmed
                                    #119
                                    @bbtown Ich schaffe es auch nicht den Custom Skill zu aktivieren.
                                    Beim Versuch sagt Alexa "Der Service ist nicht aktiviert. Bitte aktivier die Integration im IOT Adapter.
                                    Die ist natürlich aktiv.
                                    • R Rushmed
                                      BBTownB Offline
                                      BBTownB Offline
                                      BBTown
                                      #120
                                      @rushmed
                                      Hast Du zuvor einmal auf der Zugangsseite von ioBroker.Pro deine Zugangsdaten geprüft?
                                      Ansonsten , kann es sein, dass Du in den Einstellungen vom IOT-Adapter einemal neue Verbindungszertifikate erstellen musst?
                                      • BBTownB BBTown
                                        @duffy
                                        Gruß Duffy
                                        DuffyD Offline
                                        DuffyD Offline
                                        Duffy
                                        #121
                                        @bbtown
                                        Ok danke, das lässt hoffen. Das mit der Temperatur hatte ich auch schon mal versucht aber da wollte es noch nicht.
                                        Es schien bei mir auch Probleme mit dem Namen "Garten" zu geben weil zu viele Namen mit Garten sind. Habe es dann auf Hauptgarten umbenannt. Trotdem wollte es noch nicht.
                                        Ist bei der Amazon Alexa Custom Skill aktiviert?
                                        Node.js: v22.23.2
                                        NPM: 10.9.4
                                        js-controller 7.1.2
                                        Linux: Trixie
                                        • DuffyD Duffy
                                          @bbtown
                                          BBTownB Offline
                                          BBTownB Offline
                                          BBTown
                                          #122
                                          @duffy sagte in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
                                          Ja, der ist im Adapter aktiv..
                                          Der war in der Alexa-App auch nie deaktiviert, nur hier im Adapter hatte ich mal zwischendurch den Haken rausgemacht
