  3. Cloud Dienste
  4. BETA-TEST Neuer Amazon Skill "iobroker.assistant"
759 Beiträge 112 Kommentatoren 132.5k Aufrufe 128 Beobachtet
  • haselchenH haselchen
    @bbtown
    Schwierig zu sehen, auf was für nen System Du da unterwegs bist .
    Magst mal
    iob diag
    hier präsentieren !?
    Die ganzen Error Meldungen lassen sich vielleicht so eingrenzen .
    BBTownB Offline
    BBTownB Offline
    BBTown
    #100
    @haselchen iob Diag findet alles prima ☝🏼🤓
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
      Static hostname: ioBroker
           Icon name: computer-vm
             Chassis: vm 🖴
        AF_VSOCK CID: 1
      Virtualization: kvm
              Kernel: Linux 6.12.48+deb13-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 11y 6month 2w 4d
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:25:45 up 23 min,  1 user,  load average: 0.35, 0.33, 0.35
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-10-18 20:25:45 CEST
               Universal time: Sat 2025-10-18 18:25:45 UTC
                     RTC time: Sat 2025-10-18 18:25:45
                  NTP service: active
              RTC in local TZ: yes
    Warning: The system is configured to read the RTC time in the local time zone.
             This mode cannot be fully supported. It will create various problems
             with time zone changes and daylight saving time adjustments. The RTC
             time is never updated, it relies on external facilities to maintain it.
             If at all possible, use RTC in UTC by calling
             'timedatectl set-local-rtc 0'.
    *** Users and Groups ***
    User that called 'iob diag':
    memyself
    HOME=/home/memyself
    GROUPS=memyself sudo iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/memyself
    GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.1G        2.4G        1.4G        8.6M        543M        1.7G
    Swap:             0B          0B          0B
    Total:          4.1G        2.4G        1.4G
    Active iob-Instances:   26
             3921 M total memory
             2278 M used memory
             2083 M active memory
              283 M inactive memory
             1350 M free memory
               73 M buffer memory
              444 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 20:25:46 up 23 min,  1 user,  load average: 0.40, 0.35, 0.35
    Tasks: 148 total,   3 running, 145 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 21.7 us,  8.7 sy,  0.0 ni, 60.9 id,  0.0 wa,  0.0 hi,  8.7 si,  0.0 st
    MiB Mem :   3921.8 total,   1350.4 free,   2278.5 used,    519.0 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1643.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     393M  5.5M  387M   2% /run
    /dev/sda1      ext4       40G   15G   23G  39% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     2.0G  2.8M  2.0G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     393M   12K  393M   1% /run/user/1003
    [Sat Oct 18 20:03:17 2025] EXT4-fs (sda1): mounted filesystem e627c9a7-1a96-462a-8b7f-0ca843bca944 ro with ordered data mode. Quota mode: none.
    [Sat Oct 18 20:03:18 2025] EXT4-fs (sda1): re-mounted e627c9a7-1a96-462a-8b7f-0ca843bca944 r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    303M    /var/
    155M    /var/lib
    140M    /var/cache
    127M    /var/cache/apt
    97M     /var/lib/apt
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    41M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    409M    /opt/iobroker/iobroker-data/
    280M    /opt/iobroker/iobroker-data/files
    85M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    11M     /opt/iobroker/iobroker-data/objects.json
    8.2M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-DDMXSE9w.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.20.0
    /usr/bin/node           v22.20.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.20.0-1nodesource1
      Candidate: 22.20.0-1nodesource1
      Version table:
     *** 22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://ftp.debian.org/debian trixie/main amd64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree: 0
    • D docsnyder7
      @sandy konntest du eine Lösung finden? Ich komme leider nicht weiter.. auch das aktivieren vom Alex deprecated bringt bei mir nix, die kleine findet keine neuen Geräte...
      Samson71S Offline
      Samson71S Offline
      Samson71
      #101
      @docsnyder7
      @Sandy
      Die Geräte sind im iot aber unter V2/V3 vorhanden?
      Markus
      Bitte beachten:
      • Samson71S Samson71
        @docsnyder7
        @Sandy
        docsnyder7
        #102
        @samson71 Jepp
        im Screenshot ist das deprecated wieder deaktiviert, weil ich herumprobieren bin, auch mit Zertifikaten etc
        • BBTownB BBTown
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
              AF_VSOCK CID: 1
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
          memyself
          HOME=/home/memyself
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   3921 M total memory
                   2278 M used memory
                   1350 M free memory
                     73 M buffer memory
                    444 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          303M    /var/
          155M    /var/lib
          140M    /var/cache
          127M    /var/cache/apt
          97M     /var/lib/apt
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.3
          /usr/bin/npx            10.9.3
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          #103
          @bbtown sagte in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
          Außer die Uhrzeit und die Gruppenzugehörigkeit zur Gruppe adm.
          Und vielleicht im fehlenden Rest auch noch was.
          Hatt aber nix mit Alexa dann zu tun.
          BBTownB 1 Antwort Letzte Antwort
          • I Offline
            I Offline
            ingel81
            #104
            Gerade bei mir erfolgreich umgestellt auf den neuen Skill.
            Umfangreiches KNX Haus mit über ~400 Geräten (vieles davon Dupletten wegen Kombinationen wie "Licht Küche", "Küche Licht", "Küche Spots", u.s.w.).
            Lichter
            Dimmbare Lichter
            Steckdosen
            Rolläden
            KNX Szenen auslösen (DummyGeräte die ein Script triggern)
            Diverse Sensorik auslesen
            Klappt alles sehr gut! Vielen, vielen Dank euch für die schnelle Aktion! 😃
            Der Aufwand war eigentlich nur das alte Zeug in der App einzeln rauszuwerfen. Die Webseite auf der man alle Geräte löschen konnte gibt es leider nicht mehr.
            KNX | ioBroker auf Unraid
            Z 1 Antwort Letzte Antwort
            • WinniW Offline
              WinniW Offline
              Winni
              #105
              Bei mir läuft leider nicht. Habe gerade die 4.1.5 installiert. Es kommen aber unter Alexa-Geräte V3 weiterhin keine Geräte und Fehlermeldungen im Log sind auch noch da.
              iot.0
              2025-10-18 20:41:41.712	error	[AlexaV3::DeviceManager]: TypeError: Cannot read properties of undefined (reading 'type') at /opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:341:47 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:334:42 at Array.forEach (<anonymous>) at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:333:21) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1545:13)
              iot.0
              2025-10-18 20:41:41.634	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot read properties of undefined (reading 'type')
                BBTownB Offline
                BBTownB Offline
                BBTown
                schrieb am zuletzt editiert von BBTown
                #106
                @thomas-braun welchen fehlenden Rest meinst Du?
                das ist die vollständige Ausgabe von "iob diag"
                Welche Auswirkungen hat die ADM Zugehörigkeit bzw. wie korrigiere ich diese? Hier wurde von mir nichts beabsichtigt umgestellt.
                Die Zeitzone ist hingegen gewollt ...
                (Wenn ich dafür ein neues Thema aufmachen soll, bitte gerne Laut geben)
                • BBTownB BBTown
                  #107
                  Nein.
                  Besser ist das.
                  Warum? Die Begründung, warum man die RTC nicht in lokaler Zeit betreiben sollte steht ja dabei.
                    Nein.
                    Besser ist das.
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    #108
                    hier geht es zu desem Thema weiter ...
                    https://forum.iobroker.net/topic/82541/fehler-deprication-warning
                    • WinniW Offline
                      WinniW Offline
                      Winni
                      #109
                      Habe jetzt erneut die Installation über npm durchgeführt. Jetzt wurde die 4.1.6 installiert und alle Geräte sind, soweit ich sehen kann, unter Alexa Geräte V3 vorhanden und es erscheinen auch keine Fehlermeldungen mehr im Log. Allerdings werden die Geräte nicht in der Alexa-App gefunden.
                      • R Offline
                        Rushmed
                        #110
                        Der Umzug hat jetzt größtenteils geklappt. Offen ist noch das Setup von HUE Lmpen.
                        ich habe folgendes eingestellt:
                        Die Farbsteuerung und der dimmer fuktionieren garnicht. Beim Steuern per Sprachbefehlt wird immer auf Kaltweiß und maximale Helligkeit gestellt.
                        Ich weiß auch nicht welchen typ ich für Straturation abgen soll.
                        • Z Offline
                          Z Offline
                          ZeroQool
                          #111
                          @ingel81 said in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
                          Lichter
                          Dimmbare Lichter
                          Steckdosen
                          Rolläden
                          Wie machst du das mit den Rückmeldung an die Gruppenadresse?
                          I 1 Antwort Letzte Antwort
                          • WinniW Winni
                            BBTownB Offline
                            BBTownB Offline
                            BBTown
                            #112
                            @winni
                            @apollon77
                            Ich kann ebenfalls bestätigen, dass mit der v4.1.6 die Geräte bei mir nun in "Amazon Alexa V3" übernommen wurden.
                            Es können jetzt auch manuell im iot-Adapter unter "Alexa-Geräte V3" weitere Geräte hinzugefügt werden.
                            Keine Fehlermeldungen mehr im Log.
                            Die Geräte werden allerdings auch bei mir nicht in der Alexa-App gefunden
                            Nachdem ich in der Alexa App den iobroker.assistent skill noch einmal deaktiviert und erneut mit meinen Iobroker-Pro Account aktiviert habe, wurden meine Geräte eingelesen
                            WinniW 1 Antwort Letzte Antwort
                            • BBTownB BBTown
                              @winni
                              @apollon77
                              WinniW Offline
                              WinniW Offline
                              Winni
                              #113
                              Habe ich auch probiert, aber bei mir leider ohne Erfolg.
                              • WinniW Winni
                                docsnyder7
                                #114
                                @winni das Gleiche hier…
                                • Z ZeroQool
                                  Lichter
                                  Dimmbare Lichter
                                  Steckdosen
                                  Rolläden
                                  I Offline
                                  I Offline
                                  ingel81
                                  schrieb am zuletzt editiert von ingel81
                                  #115
                                  @zeroqool präzisiere mal die Frage oder schreib eine PM, damit ich weiß wie sehr oder wenig ich ausholen muss. Zu den Szenen oder allgemein?
                                  DuffyD 1 Antwort Letzte Antwort
                                  • I ingel81
                                    DuffyD Offline
                                    DuffyD Offline
                                    Duffy
                                    #116
                                    Hallo an alle,
                                    wer kennt folgendes Problem.
                                    Ich habe den iot Adapter 4.1.6 (war auch schon bei 4.1.4 so) installiert und in dem auch Amazon Alexa Custom Skill aktiviert.
                                    wenn ich mich nun über das Handy in dem Skill anmelde wird folgende Meldung angezeigt:
                                    Gleich danach sagt Alexa aber über den Echo:
                                    "Ich habe im Moment schwierigkeiten auf deinen Custom iobroker Skill zuzugreifen"
                                    Auf dem Handy ist nun bei dem Skill wieder der Urspungsscreen zu sehen:
                                    Weis wer Rat?
                                    Und hat es schon einer von euch geschafft Temperatursensoren abzufragen? Das klappt auch noch nicht, vielleicht auch wegen oben genanntem Problem.
                                    Gruß Duffy
                                    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                                    Node.js: v22.23.2
                                    NPM: 10.9.4
                                    js-controller 7.1.2
                                    Linux: Trixie
                                    BBTownB apollon77A 2 Antworten Letzte Antwort
                                    • D docsnyder7
                                      BBTownB Offline
                                      BBTownB Offline
                                      BBTown
                                      #117
                                      @docsnyder7 @Winni
                                      Ich weiß nicht ob das wichtig ist, jedoch habe ich vor dem deaktivieren und neu-aktivieren des "iobroker.assistent" skill auch den "iobroker.iot" skill deaktiviert.
                                      Nachtrag:
                                      Ichhatte zwischendurch im Adapter auch mal den Haken beim Custom skill rausgenommen.
                                      Ich bin mir aber bei den ganzen Versuchen nicht mehr sicher wie der Zustand war, als ich erfolg hatte - sorry!
                                      R WinniW 2 Antworten Letzte Antwort
                                      • DuffyD Duffy
                                        Hallo an alle,
                                        Weis wer Rat?
                                        Gruß Duffy
                                        BBTownB Offline
                                        BBTownB Offline
                                        BBTown
                                        #118
                                        @duffy
                                        Gruß Duffy
                                        Ja, das hat bei mir funktioniert nachdem ich im iot-Adapter den Gerätetyp von "Thermostat" auf "Temperatur" geändert habe.
                                        Ich habe anschließend in der Alexa-App die Geräte neu suchen lassen, ich habe zwar den Hinweis bekommen, dass nichts neues gefunden wurde (das Gerät war ja auch nicht neu) aber die Temperaturen wurden nach einer Weile dann korrekt angesagt
                                        • BBTownB BBTown
                                          @docsnyder7 @Winni
                                          Nachtrag:
                                          Rushmed
                                          #119
                                          @bbtown Ich schaffe es auch nicht den Custom Skill zu aktivieren.
                                          Beim Versuch sagt Alexa "Der Service ist nicht aktiviert. Bitte aktivier die Integration im IOT Adapter.
                                          Die ist natürlich aktiv.
